[U-Boot] [PATCH] mmc: Fix error in RPMB code
Since we do not build any board with CONFIG_SUPPORT_EMMC_RPMB , this piece of code evaded conversion. Fix the following compiler error:
cmd/mmc.c: In function 'do_mmcrpmb': cmd/mmc.c:316:32: error: 'struct blk_desc' has no member named 'part_num' original_part = mmc->block_dev.part_num; ^
Signed-off-by: Marek Vasut marex@denx.de Cc: Pantelis Antoniou panto@antoniou-consulting.com Cc: Tom Rini trini@konsulko.com --- cmd/mmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/mmc.c b/cmd/mmc.c index 39ef072..c5454bf 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -313,7 +313,7 @@ static int do_mmcrpmb(cmd_tbl_t *cmdtp, int flag, return CMD_RET_FAILURE; } /* Switch to the RPMB partition */ - original_part = mmc->block_dev.part_num; + original_part = mmc->block_dev.hwpart; if (mmc_select_hwpart(curr_device, MMC_PART_RPMB) != 0) return CMD_RET_FAILURE; ret = cp->cmd(cmdtp, flag, argc, argv);
