[U-Boot-Users] [PATCH] word alignment fixes for word aligned NS16550 UART peripheral
The patch is created against current CVS 2005 feb. 23 and fixes problems for boards that only have word access to the NS16550 UART peripheral.
CHANGELOG: * Patch by Jean-Paul Saman, 23 Feb 2005 common/cmd_bdinfo.c - fixes bug with negative baudrate: correct use of unsigned long datatype for bi_baudrate, properly cast bd_t *bd = (bd_t*) gd->bd; make information more clear: print_num("DRAM bank nr", i); include/asm-arm/u-boot.h - fixes bug with negative baudrate: use of unsigned long for bi_baudrate and adding an unsigned char pad[2] makes the struct word aligned changed ulong into unsigned long for consistency include/ns16550.h - fixes alignement bug with UART that only supports word aligned access: removed "__attribute__ ((packed));" for "(CFG_NS16550_REG_SIZE == 4)" GCC generates bytes access when it encounters the packed attribute regardless if the struct is already word aligned for a platform. Peripherals that can only handle word aligned access won't work properly when accessed with byte access. The struct NS16550 is already word aligned for REG_SIZE = 4, so there is no need to packed the struct in that case.
Kind greetings,
Jean-Paul Saman
Philips Semiconductors CTO/RTG Philips HighTech Campus, building WDB 3.29 Professor van den Holstlaan 4 5655 AA Eindhoven tel: +31 (0)40 27 45131
Dear Jean-Paul,
in message OF43B05629.5234CA85-ONC1256FB1.003C850C-C1256FB1.003CAA59@philips.com you wrote:
CHANGELOG:
- Patch by Jean-Paul Saman, 23 Feb 2005 common/cmd_bdinfo.c - fixes bug with negative baudrate: correct use of unsigned long datatype for
I reject this patch because I cannot read the "CHANGELOG". Please stick to standard netiquette rules for formatting. See also the Coding Style rules in the README.
diff -X ignore -urNpb u-boot-cvs/common/cmd_bdinfo.c u-boot-aps/common/cmd_bdinfo.c --- u-boot-cvs/common/cmd_bdinfo.c 2004-12-31 10:32:50.000000000 +0100 +++ u-boot-aps/common/cmd_bdinfo.c 2005-02-23 09:18:42.000000000 +0100 @@ -216,14 +216,14 @@ int do_bdinfo ( cmd_tbl_t *cmdtp, int fl DECLARE_GLOBAL_DATA_PTR;
int i;
bd_t *bd = gd->bd;
Why do you add a cast here? None is needed - "bd" is already of type "bd_t *". Rejected.
print_num("DRAM bank", i);
Why do you change the output format here? Rejected.
@@ -236,7 +236,7 @@ int do_bdinfo ( cmd_tbl_t *cmdtp, int fl "ip_addr = "); print_IPaddr (bd->bi_ip_addr); printf ("\n"
"baudrate = %d bps\n", bd->bi_baudrate);
"baudrate = %u bps\n", bd->bi_baudrate );
How could you end up with a negative baudrate?
+++ u-boot-aps/include/asm-arm/u-boot.h 2005-02-04 15:24:04.000000000 +0100 @@ -30,16 +30,17 @@ #define _U_BOOT_H_ 1
typedef struct bd_info {
- int bi_baudrate; /* serial console baudrate */
- unsigned long bi_baudrate; /* serial console baudrate */
Not necessary.
unsigned long bi_ip_addr; /* IP Address */ unsigned char bi_enetaddr[6]; /* Ethernet adress */
- unsigned char pad[2];
Not necessary.
struct environment_s *bi_env;
- ulong bi_arch_number; /* unique id for this board */
- ulong bi_boot_params; /* where this board expects params */
- unsigned long bi_arch_number; /* unique id for this board */
- unsigned long bi_boot_params; /* where this board expects params */
Bogus change.
struct /* RAM configuration */ {
ulong start;
ulong size;
unsigned long start;
unsigned long size;
Bogus change.
Rejected.
jean-paul.saman@philips.com
