[PATCH 1/2] test: Avoid assuming sandbox board for bloblist test
This tests assumes it is running on sandbox. Add a few functions to handle silencing the console on any board and use those instead.
Reported-by: Kever Yang kever.yang@rock-chips.com
include/test/ut.h | 18 ++++++++++++++++++ test/bloblist.c | 13 ++++--------- test/ut.c | 18 ++++++++++++++++++ 3 files changed, 40 insertions(+), 9 deletions(-)
diff --git a/include/test/ut.h b/include/test/ut.h index 3f2ee7514b8..17400c73ea9 100644 --- a/include/test/ut.h +++ b/include/test/ut.h @@ -338,4 +338,22 @@ ulong ut_check_free(void); */ long ut_check_delta(ulong last);
+/** + * ut_silence_console() - Silence the console if requested by the user + * + * This stops test output from appear on the console. It is the default on + * sandbox, unless the -v flag is given. For other boards, this does nothing. + * + * @uts: Test state (in case in future we want to keep state here) + */ +void ut_silence_console(struct unit_test_state *uts); + +/** + * ut_unsilence_console() - Unsilence the console after a test + * + * This restarts console output again and turns off console recording. This + * happens on all boards, including sandbox. + */ +void ut_unsilence_console(struct unit_test_state *uts); + #endif diff --git a/test/bloblist.c b/test/bloblist.c index 0bb9e2d81e7..900299dd68e 100644 --- a/test/bloblist.c +++ b/test/bloblist.c @@ -7,7 +7,6 @@ #include <bloblist.h> #include <log.h> #include <mapmem.h> -#include <asm/state.h> #include <test/suites.h> #include <test/test.h> #include <test/ut.h> @@ -240,7 +239,6 @@ BLOBLIST_TEST(bloblist_test_checksum, 0); /* Test the 'bloblist info' command */ static int bloblist_test_cmd_info(struct unit_test_state *uts) { - struct sandbox_state *state = state_get_current(); struct bloblist_hdr *hdr; char *data, *data2;
@@ -250,8 +248,7 @@ static int bloblist_test_cmd_info(struct unit_test_state *uts) data2 = bloblist_ensure(TEST_TAG2, TEST_SIZE2);
console_record_reset_enable(); - if (!state->show_test_output) - gd->flags |= GD_FLG_SILENT; + ut_silence_console(uts); console_record_reset(); run_command("bloblist info", 0); ut_assert_nextline("base: %lx", (ulong)map_to_sysmem(hdr)); @@ -259,7 +256,7 @@ static int bloblist_test_cmd_info(struct unit_test_state *uts) ut_assert_nextline("alloced: 70 112 Bytes"); ut_assert_nextline("free: 390 912 Bytes"); ut_assert_console_end(); - gd->flags &= ~(GD_FLG_SILENT | GD_FLG_RECORD); + ut_unsilence_console(uts);
return 0; } @@ -268,7 +265,6 @@ BLOBLIST_TEST(bloblist_test_cmd_info, 0); /* Test the 'bloblist list' command */ static int bloblist_test_cmd_list(struct unit_test_state *uts) { - struct sandbox_state *state = state_get_current(); struct bloblist_hdr *hdr; char *data, *data2;
@@ -278,8 +274,7 @@ static int bloblist_test_cmd_list(struct unit_test_state *uts) data2 = bloblist_ensure(TEST_TAG2, TEST_SIZE2);
console_record_reset_enable(); - if (!state->show_test_output) - gd->flags |= GD_FLG_SILENT; + ut_silence_console(uts); console_record_reset(); run_command("bloblist list", 0); ut_assert_nextline("Address Size Tag Name"); @@ -288,7 +283,7 @@ static int bloblist_test_cmd_list(struct unit_test_state *uts) ut_assert_nextline("%08lx %8x 2 SPL hand-off", (ulong)map_to_sysmem(data2), TEST_SIZE2); ut_assert_console_end(); - gd->flags &= ~(GD_FLG_SILENT | GD_FLG_RECORD); + ut_unsilence_console(uts);
return 0; } diff --git a/test/ut.c b/test/ut.c index 95bdd66de6a..44ed1ba2d31 100644 --- a/test/ut.c +++ b/test/ut.c @@ -8,6 +8,9 @@ #include <common.h> #include <console.h> #include <malloc.h> +#ifdef CONFIG_SANDBOX +#include <asm/state.h> +#endif #include <test/test.h> #include <test/ut.h>
@@ -114,3 +117,18 @@ int ut_check_console_dump(struct unit_test_state *uts, int total_bytes)
return upto == total_bytes ? 0 : 1; } + +void ut_silence_console(struct unit_test_state *uts) +{ +#ifdef CONFIG_SANDBOX + struct sandbox_state *state = state_get_current(); + + if (!state->show_test_output) + gd->flags |= GD_FLG_SILENT; +#endif +} + +void ut_unsilence_console(struct unit_test_state *uts) +{ + gd->flags &= ~(GD_FLG_SILENT | GD_FLG_RECORD); +}
This test cannot work unless CONFIG_BLOBLIST is enabled. Update it to add that condition.
Reported-by: Kever Yang kever.yang@rock-chips.com Signed-off-by: Simon Glass sjg@chromium.org ---
test/Makefile | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/test/Makefile b/test/Makefile index 1c930b31485..cdbfa61cda3 100644 --- a/test/Makefile +++ b/test/Makefile @@ -2,7 +2,9 @@ # # (C) Copyright 2012 The Chromium Authors
+ifneq ($(CONFIG_$(SPL_)BLOBLIST),) obj-$(CONFIG_$(SPL_)CMDLINE) += bloblist.o +endif obj-$(CONFIG_$(SPL_)CMDLINE) += cmd/ obj-$(CONFIG_$(SPL_)CMDLINE) += cmd_ut.o obj-$(CONFIG_$(SPL_)CMDLINE) += command_ut.o
This patch conflicts with my patch
[1/1] test: test/bloblist.c depends on asm/state.h https://patchwork.ozlabs.org/project/uboot/patch/20201031073806.30736-1-xypr...
It seems that my patch is obsoleted by the first patch of Kever's series:
test: Avoid assuming sandbox board for bloblist test https://patchwork.ozlabs.org/project/uboot/patch/20201108210834.1.I08cec35c8...
Best regards
Heinrich
Hi Heinrich,
I believe your patch was already applied, so there should not be a patch conflict.
Yes there was a request to be able to run the test on boards other than sandbox. I think we should try to do that if possible.
