[U-Boot] [PATCH] rpi4: fix dram bank initialization
Raspberry Pi's memory address & size cells are defined in FDT's root node. So, original fdtdec_decode_ram_size() having the cells in memory node will get wrong size cells which misleads memory's reg parsing and have wrong memory banks. This patch provides new decode_ram_size() to parse the memory's reg in FDT for Raspberry Pi 4.
Fixes: commit 9de5b89e4c89 ("rpi4: enable dram bank initialization") Signed-off-by: Jian-Hong Pan jian-hong@endlessm.com --- board/raspberrypi/rpi/rpi.c | 60 +++++++++++++++++++++++++++++++++++-- 1 file changed, 58 insertions(+), 2 deletions(-)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 9e0abdda31..419fb61db5 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -314,10 +314,66 @@ int dram_init(void)
#ifdef CONFIG_OF_BOARD #ifdef CONFIG_BCM2711 +static int decode_ram_size(const void *blob, phys_size_t *sizep, bd_t *bd) +{ + int addr_cells, size_cells; + u64 total_size, size, addr; + const u32 *cell; + int node; + int bank; + int len; + + /* Raspberry Pi's address and size cells are defined in root node */ + addr_cells = fdt_address_cells(blob, 0); + size_cells = fdt_size_cells(blob, 0); + + node = fdt_path_offset(blob, "/memory"); + if (node < 0) { + debug("No /memory node found\n"); + return -ENOENT; + } + + cell = fdt_getprop(blob, node, "reg", &len); + if (!cell) { + debug("No reg property found\n"); + return -ENOENT; + } + + if (bd) { + memset(bd->bi_dram, '\0', sizeof(bd->bi_dram[0]) * + CONFIG_NR_DRAM_BANKS); + } + + total_size = 0; + for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { + addr = 0; + if (addr_cells == 2) + addr += (u64)fdt32_to_cpu(*cell++) << 32UL; + addr += fdt32_to_cpu(*cell++); + if (bd) + bd->bi_dram[bank].start = addr; + + size = 0; + if (size_cells == 2) + size += (u64)fdt32_to_cpu(*cell++) << 32UL; + size += fdt32_to_cpu(*cell++); + if (bd) + bd->bi_dram[bank].size = size; + + total_size += size; + } + + debug("Memory size %llu\n", total_size); + if (sizep) + *sizep = (phys_size_t)total_size; + + return 0; +} + int dram_init_banksize(void) { - return fdtdec_decode_ram_size(gd->fdt_blob, NULL, 0, NULL, - (phys_size_t *)&gd->ram_size, gd->bd); + return decode_ram_size(gd->fdt_blob, (phys_size_t *)&gd->ram_size, + gd->bd); } #endif #endif
Hi Jiang,
Thanks for your patch. I think what you try to fix is already fixed in v2020.01-rc1 with the following commits: 7a3f15e718 ("dm: Fix default address cells return value") 8076fc298e ("libfdt: Allow #size-cells of 0") 0ba41ce1b7 ("libfdt: return correct value if #size-cells property is not present") ce2dae3a44 ("libfdt: fdt_address_cells() and fdt_size_cells()")
Regards, Matthias
- int addr_cells, size_cells;
- u64 total_size, size, addr;
- const u32 *cell;
- int node;
- int bank;
- int len;
- /* Raspberry Pi's address and size cells are defined in root node */
- addr_cells = fdt_address_cells(blob, 0);
- size_cells = fdt_size_cells(blob, 0);
- node = fdt_path_offset(blob, "/memory");
- if (node < 0) {
return -ENOENT;
- cell = fdt_getprop(blob, node, "reg", &len);
- if (!cell) {
return -ENOENT;
- if (bd) {
- total_size = 0;
- for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) {
addr = 0;
if (bd)
size = 0;
if (bd)
total_size += size;
- debug("Memory size %llu\n", total_size);
- if (sizep)
- return decode_ram_size(gd->fdt_blob, (phys_size_t *)&gd->ram_size,
gd->bd);
} #endif #endif
Matthias Brugger mbrugger@suse.com 於 2019年11月7日 週四 下午4:02寫道:
Hi Jiang,
Okay! Thanks for the information. I will try the commits. The v2 patch can be forgot.
Thank you Jian-Hong Pan
Jian-Hong Pan
Matthias Brugger
