[U-Boot] Please pull u-boot-ti/master, v2
Hey,
The following changes since commit 4c54419737ffbfadd605263d97a1357bb03c04e8:
socfpga: Adding Freeze Controller driver (2013-12-03 14:38:56 +0100)
git://git.denx.de/u-boot-ti.git master
for you to fetch changes up to 18a02e8050b7af165efa72325753e7880bf5567c:
AM3517 EVM: Enable ethernet (2013-12-06 07:04:26 -0500)
---------------------------------------------------------------- Hardik Patel (1): pandaboard: 1/1] ARM:OMAP4+: panda-es: Support Rev B3 Elpida DDR2 RAM
Ilya Ledvich (3): cm_t335: add cm_t335 board support cm_t335: add support for status LED cm_t335: add support for pca9555 i2c gpio extender
Lars Poeschel (1): pcm051: Support for revision 3
Lokesh Vutla (1): ARM: OMAP5+: Remove unnecessary EFUSE settings
Lubomir Popov (1): ARM: OMAP4: Fix bug in omap4470_volts struct
Michael Trimarchi (2): arm: omap3: Add uart4 omap3 adddress arm: omap3: Enable clocks for peripherals only if they are used
Oleg Kosheliev (2): ARMV7: OMAP4: Add struct for twl603x data ARMV7: OMAP4: Add twl6032 support
Roger Quadros (11): ahci: Error out with message on malloc() failure ahci: Fix cache align error messages ARM: OMAP5: Add Pipe3 PHY driver ARM: OMAP5: Add PRCM and Control information for SATA ARM: OMAP5: Add SATA platform glue ARM: omap5_uevm: Add SATA support ARM: DRA7xx: Add PRCM and Control information for SATA ARM: dra7_evm: Add SATA support usb: ehci-omap: Reset the USB Host OMAP module omap3_beagle: Don't use ulpi_reset omap4_panda: Don't use ulpi_reset
SRICHARAN R (3): ARM: DRA7: Add is_dra7xx cpu check definition ARM: DRA: EMIF: Change DDR3 settings to use hw leveling ARM: DRA7/OMAP5: EMIF: Add workaround for bug 0039
Stefan Roese (1): arm: am335x: Add DT (FDT) support to Siemens boards
Tom Rini (3): am33xx: Stop modifying certain EMIF4D registers am335x_evm: Update nandboot to use partitions and DT AM3517 EVM: Enable ethernet
Viktar Palstsiuk (1): davinci: fix Master Priority Registers location
Vladimir Koutny (1): am335x: cpsw: optimize cpsw_recv to increase network performance
arch/arm/cpu/armv7/am33xx/ddr.c | 7 - arch/arm/cpu/armv7/omap-common/Makefile | 5 + arch/arm/cpu/armv7/omap-common/emif-common.c | 142 ++++++++++++---- arch/arm/cpu/armv7/omap-common/pipe3-phy.c | 231 ++++++++++++++++++++++++++ arch/arm/cpu/armv7/omap-common/pipe3-phy.h | 36 ++++ arch/arm/cpu/armv7/omap-common/sata.c | 75 +++++++++ arch/arm/cpu/armv7/omap3/clock.c | 2 - arch/arm/cpu/armv7/omap4/hw_data.c | 12 +- arch/arm/cpu/armv7/omap4/sdram_elpida.c | 9 +- arch/arm/cpu/armv7/omap5/hw_data.c | 9 +- arch/arm/cpu/armv7/omap5/hwinit.c | 18 +- arch/arm/cpu/armv7/omap5/prcm-regs.c | 7 + arch/arm/cpu/armv7/omap5/sdram.c | 214 +++++++++++++++++------- arch/arm/include/asm/arch-am33xx/ddr_defs.h | 37 ++--- arch/arm/include/asm/arch-davinci/hardware.h | 3 +- arch/arm/include/asm/arch-omap3/clock.h | 2 - arch/arm/include/asm/arch-omap3/omap3.h | 1 + arch/arm/include/asm/arch-omap4/sys_proto.h | 4 + arch/arm/include/asm/arch-omap5/clock.h | 3 + arch/arm/include/asm/arch-omap5/omap.h | 4 + arch/arm/include/asm/arch-omap5/sata.h | 48 ++++++ arch/arm/include/asm/emif.h | 14 +- arch/arm/include/asm/omap_common.h | 10 ++ board/compulab/cm_t335/Makefile | 10 ++ board/compulab/cm_t335/cm_t335.c | 162 ++++++++++++++++++ board/compulab/cm_t335/mux.c | 117 +++++++++++++ board/compulab/cm_t335/spl.c | 106 ++++++++++++ board/compulab/cm_t335/u-boot.lds | 101 +++++++++++ board/isee/igep0033/board.c | 4 - board/phytec/pcm051/board.c | 53 ++++-- board/siemens/dxr2/board.c | 4 - board/siemens/pxm2/board.c | 5 - board/siemens/rut/board.c | 5 - board/ti/am335x/board.c | 17 -- board/ti/dra7xx/evm.c | 7 + board/ti/omap5_uevm/evm.c | 7 + board/ti/panda/panda.c | 60 +++++++ board/ti/ti814x/evm.c | 5 - board/ti/ti816x/evm.c | 17 -- boards.cfg | 4 +- drivers/block/ahci.c | 18 +- drivers/net/cpsw.c | 2 +- drivers/power/twl6030.c | 77 +++++++-- drivers/usb/host/ehci-omap.c | 57 +++++-- include/configs/am335x_evm.h | 9 +- include/configs/am3517_evm.h | 14 +- include/configs/cm_t335.h | 182 ++++++++++++++++++++ include/configs/dra7xx_evm.h | 11 ++ include/configs/omap3_beagle.h | 3 - include/configs/omap4_panda.h | 3 - include/configs/omap5_uevm.h | 10 ++ include/configs/siemens-am33x-common.h | 5 + include/twl6030.h | 38 +++++ 53 files changed, 1745 insertions(+), 261 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/pipe3-phy.c create mode 100644 arch/arm/cpu/armv7/omap-common/pipe3-phy.h create mode 100644 arch/arm/cpu/armv7/omap-common/sata.c create mode 100644 arch/arm/include/asm/arch-omap5/sata.h create mode 100644 board/compulab/cm_t335/Makefile create mode 100644 board/compulab/cm_t335/cm_t335.c create mode 100644 board/compulab/cm_t335/mux.c create mode 100644 board/compulab/cm_t335/spl.c create mode 100644 board/compulab/cm_t335/u-boot.lds create mode 100644 include/configs/cm_t335.h
Hi Tom,
On Fri, 6 Dec 2013 07:15:25 -0500, Tom Rini trini@ti.com wrote:
Hey,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
