[U-Boot] [PATCH] usb: dwc2: Add brcm,bcm2708-usb compatible
When using CONFIG_OF_BOARD on rpi to use the dtb provided by the RaspberryPi Fundation, the compatible string isn't the same, resulting in not-functional usb from u-boot.
Signed-off-by: Oleksandr Tymoshenko gonzo@FreeBSD.org Signed-off-by: Emmanuel Vadot manu@freebsd.org --- drivers/usb/host/dwc2.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index dd956110fc..cbe065bbaf 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -1314,6 +1314,7 @@ struct dm_usb_ops dwc2_usb_ops = {
static const struct udevice_id dwc2_usb_ids[] = { { .compatible = "brcm,bcm2835-usb" }, + { .compatible = "brcm,bcm2708-usb" }, { .compatible = "snps,dwc2" }, { } };
- { .compatible = "brcm,bcm2708-usb" }, { .compatible = "snps,dwc2" }, { }
Applied, thanks
Emmanuel Vadot
