[U-Boot] [PATCH 1/4] cfi_flash: Add manufact_match helper function
Consolidate manufacturer matching into the function manufact_match() and use it.
Signed-off-by: Stefan Roese sr@denx.de --- drivers/mtd/cfi_flash.c | 16 +++++++++------- 1 file changed, 9 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index b2dfc53..d865c40 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1425,13 +1425,18 @@ int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) return flash_write_cfiword (info, wp, cword); }
+static inline int manufact_match(flash_info_t *info, u32 manu) +{ + return info->manufacturer_id == ((manu & FLASH_VENDMASK) >> 16); +} + /*----------------------------------------------------------------------- */ #ifdef CONFIG_SYS_FLASH_PROTECTION
static int cfi_protect_bugfix(flash_info_t *info, long sector, int prot) { - if (info->manufacturer_id == ((INTEL_MANUFACT & FLASH_VENDMASK) >> 16) + if (manufact_match(info, INTEL_MANUFACT) && info->device_id == NUMONYX_256MBIT) { /* * see errata called @@ -1488,8 +1493,7 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) case CFI_CMDSET_AMD_EXTENDED: case CFI_CMDSET_AMD_STANDARD: /* U-Boot only checks the first byte */ - if (info->manufacturer_id == - ((ATM_MANUFACT & FLASH_VENDMASK) >> 16)) { + if (manufact_match(info, ATM_MANUFACT)) { if (prot) { flash_unlock_seq (info, 0); flash_write_cmd (info, 0, @@ -1507,8 +1511,7 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) 0, ATM_CMD_UNLOCK_SECT); } } - if (info->manufacturer_id == - ((AMD_MANUFACT & FLASH_VENDMASK) >> 16)) { + if (manufact_match(info, AMD_MANUFACT)) { int flag = disable_interrupts(); int lock_flag;
@@ -1738,8 +1741,7 @@ static int cmdset_amd_init(flash_info_t *info, struct cfi_qry *qry) flash_write_cmd(info, 0, info->cfi_offset, FLASH_CMD_CFI);
#ifdef CONFIG_SYS_FLASH_PROTECTION - if (info->ext_addr && info->manufacturer_id == - ((AMD_MANUFACT & FLASH_VENDMASK) >> 16)) { + if (info->ext_addr && manufact_match(info, AMD_MANUFACT)) { ushort spus;
/* read sector protect/unprotect scheme */
Patch 66863b05 [cfi_flash: add support for Spansion flash PPB sector protection] introduced the PPB (Persistent Protection Bit) locking for Spansion chips. But right now the sector protection status (locked vs unlocked) is set to unlocked for all sectors upon bootup. The real sector protection status is ignored.
This patch now reads the current sector protection status and uses it for these AMD/Spansion flash chips.
Signed-off-by: Stefan Roese sr@denx.de Cc: Anatolij Gustschin agust@denx.de Cc: Holger Brunck holger.brunck@keymile.com --- v2: - Added reset command before issuing the autoselect command (FLASH_CMD_READ_ID). Otherwise STM flash chips didn't report the correct protection status (on a4m2k board) - Line length reduced (checkpatch warning)
drivers/mtd/cfi_flash.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index d865c40..045cf4a 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -2160,6 +2160,27 @@ ulong flash_get_size (phys_addr_t base, int banknum) FLASH_OFFSET_PROTECT, FLASH_STATUS_PROTECT); break; + case CFI_CMDSET_AMD_EXTENDED: + case CFI_CMDSET_AMD_STANDARD: + if (!manufact_match(info, AMD_MANUFACT)) { + /* default: not protected */ + info->protect[sect_cnt] = 0; + break; + } + + /* Read protection (PPB) from sector */ + flash_write_cmd(info, 0, 0, + info->cmd_reset); + flash_unlock_seq(info, 0); + flash_write_cmd(info, 0, + info->addr_unlock1, + FLASH_CMD_READ_ID); + info->protect[sect_cnt] = + flash_isset( + info, sect_cnt, + FLASH_OFFSET_PROTECT, + FLASH_STATUS_PROTECT); + break; default: /* default: not protected */ info->protect[sect_cnt] = 0;
Hi Stefan,
Tested-by: Holger Brunck holger.brunck@keymile.com
Regards Holger
Not only Spansion supports the Persistent Protection Bits (PPB) locking. Other devices like the Micron JS28F512M29EWx also support this type of locking/unlocking. Detection of support is done in the same way as done for the Spansion chips - via the 0x49 CFI word.
This patch enables this PPB protection mechanism for all AMD type (AMD commandset) chips.
Signed-off-by: Stefan Roese sr@denx.de Cc: Anatolij Gustschin agust@denx.de Cc: Holger Brunck holger.brunck@keymile.com --- drivers/mtd/cfi_flash.c | 13 +++++-------- 1 file changed, 5 insertions(+), 8 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 045cf4a..5176d62 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1511,7 +1511,7 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) 0, ATM_CMD_UNLOCK_SECT); } } - if (manufact_match(info, AMD_MANUFACT)) { + if (info->legacy_unlock) { int flag = disable_interrupts(); int lock_flag;
@@ -1741,12 +1741,9 @@ static int cmdset_amd_init(flash_info_t *info, struct cfi_qry *qry) flash_write_cmd(info, 0, info->cfi_offset, FLASH_CMD_CFI);
#ifdef CONFIG_SYS_FLASH_PROTECTION - if (info->ext_addr && manufact_match(info, AMD_MANUFACT)) { - ushort spus; - - /* read sector protect/unprotect scheme */ - spus = flash_read_uchar(info, info->ext_addr + 9); - if (spus == 0x8) + if (info->ext_addr) { + /* read sector protect/unprotect scheme (at 0x49) */ + if (flash_read_uchar(info, info->ext_addr + 9) == 0x8) info->legacy_unlock = 1; } #endif @@ -2162,7 +2159,7 @@ ulong flash_get_size (phys_addr_t base, int banknum) break; case CFI_CMDSET_AMD_EXTENDED: case CFI_CMDSET_AMD_STANDARD: - if (!manufact_match(info, AMD_MANUFACT)) { + if (!info->legacy_unlock) { /* default: not protected */ info->protect[sect_cnt] = 0; break;
Hi Stefan,
Regards Holger
Report the usage of the Advanced Sector Protection (PPB) to the user upon 'flinfo' command. E.g:
Bank # 1: CFI conformant flash (16 x 16) Size: 64 MB in 512 Sectors AMD Standard command set, Manufacturer ID: 0x01, Device ID: 0x227E2301 Advanced Sector Protection (PPB) enabled Erase timeout: 16384 ms, write timeout: 2 ms Buffer write timeout: 5 ms, buffer size: 32 bytes
Sector Start Addresses: FC000000 E FC020000 E RO FC040000 E FC060000 E FC080000 E ...
Signed-off-by: Stefan Roese sr@denx.de Cc: Anatolij Gustschin agust@denx.de Cc: Holger Brunck holger.brunck@keymile.com --- drivers/mtd/cfi_flash.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 5176d62..adb0a9b 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1247,6 +1247,8 @@ void flash_print_info (flash_info_t * info) printf(info->chipwidth == FLASH_CFI_16BIT ? "%04X" : "%02X", info->device_id2); } + if ((info->vendor == CFI_CMDSET_AMD_STANDARD) && (info->legacy_unlock)) + printf("\n Advanced Sector Protection (PPB) enabled"); printf ("\n Erase timeout: %ld ms, write timeout: %ld ms\n", info->erase_blk_tout, info->write_tout);
Hi Stefan,
Regards Holger
For all patches of this series (1...4):
Applied to u-boot-cfi-flash/master.
Thanks, Stefan
Holger Brunck
Stefan Roese
Stefan Roese
