[U-Boot] [PATCH 0/4] Update gdsys board support
Dirk Eibach (4): ioep-fpga: Support intempo compression gdsys: osd: Allow osdsize on valid screens only strider: Support con-dp flavor strider: Support cpu-dp flavor
board/gdsys/common/Makefile | 1 + board/gdsys/common/ioep-fpga.c | 17 +++++---- board/gdsys/common/osd.c | 3 ++ board/gdsys/mpc8308/strider.c | 37 +++++++++++++++++++ configs/strider_con_dp_defconfig | 20 +++++++++++ configs/strider_cpu_dp_defconfig | 20 +++++++++++ include/configs/strider.h | 77 ++++++++++++++++++++++++++++++++++++---- include/gdsys_fpga.h | 2 +- 8 files changed, 164 insertions(+), 13 deletions(-) create mode 100644 configs/strider_con_dp_defconfig create mode 100644 configs/strider_cpu_dp_defconfig
There is a new "intempo" compression type that can be reported on startup.
Signed-off-by: Dirk Eibach dirk.eibach@gdsys.cc ---
board/gdsys/common/ioep-fpga.c | 17 +++++++++++------ 1 file changed, 11 insertions(+), 6 deletions(-)
diff --git a/board/gdsys/common/ioep-fpga.c b/board/gdsys/common/ioep-fpga.c index 96f02d6..f72a01e 100644 --- a/board/gdsys/common/ioep-fpga.c +++ b/board/gdsys/common/ioep-fpga.c @@ -25,8 +25,9 @@ enum {
enum { COMPRESSION_NONE = 0, - COMPRESSION_TYPE1_DELTA = 1, - COMPRESSION_TYPE1_TYPE2_DELTA = 3, + COMPRESSION_TYPE_1 = 1, + COMPRESSION_TYPE_1_2 = 3, + COMPRESSION_TYPE_1_2_3 = 7, };
enum { @@ -158,12 +159,16 @@ void ioep_fpga_print_info(unsigned int fpga) printf(" no compression"); break;
- case COMPRESSION_TYPE1_DELTA: - printf(" type1-deltacompression"); + case COMPRESSION_TYPE_1: + printf(" compression type1(delta)"); break;
- case COMPRESSION_TYPE1_TYPE2_DELTA: - printf(" type1-deltacompression, type2-inlinecompression"); + case COMPRESSION_TYPE_1_2: + printf(" compression type1(delta), type2(inline)"); + break; + + case COMPRESSION_TYPE_1_2_3: + printf(" compression type1(delta), type2(inline), type3(intempo)"); break;
default:
Signed-off-by: Dirk Eibach dirk.eibach@gdsys.cc Reviewed-by: Tom Rini trini@konsulko.com
Limit "osdsize"-command to access valid screens only.
board/gdsys/common/osd.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/board/gdsys/common/osd.c b/board/gdsys/common/osd.c index 4e292f5..add9574 100644 --- a/board/gdsys/common/osd.c +++ b/board/gdsys/common/osd.c @@ -469,6 +469,9 @@ int osd_size(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) }
for (screen = 0; screen < MAX_OSD_SCREEN; ++screen) { + if (!(osd_screen_mask & (1 << screen))) + continue; + OSD_SET_REG(screen, xy_size, ((x - 1) << 8) | (y - 1)); OSD_SET_REG(screen, x_pos, 32767 * (640 - 12 * x) / 65535); OSD_SET_REG(screen, y_pos, 32767 * (480 - 18 * y) / 65535);
There is a new strider console flavor with DisplayPort video.
board/gdsys/common/Makefile | 1 + board/gdsys/mpc8308/strider.c | 37 ++++++++++++++++++++++ configs/strider_con_dp_defconfig | 20 ++++++++++++ include/configs/strider.h | 67 +++++++++++++++++++++++++++++++++++++--- include/gdsys_fpga.h | 2 +- 5 files changed, 121 insertions(+), 6 deletions(-) create mode 100644 configs/strider_con_dp_defconfig
diff --git a/board/gdsys/common/Makefile b/board/gdsys/common/Makefile index ce23045..d4f0e70 100644 --- a/board/gdsys/common/Makefile +++ b/board/gdsys/common/Makefile @@ -16,3 +16,4 @@ obj-$(CONFIG_HRCON) += osd.o mclink.o dp501.o phy.o ioep-fpga.o fanctrl.o obj-$(CONFIG_STRIDER) += mclink.o dp501.o phy.o ioep-fpga.o adv7611.o ch7301.o obj-$(CONFIG_STRIDER) += fanctrl.o obj-$(CONFIG_STRIDER_CON) += osd.o +obj-$(CONFIG_STRIDER_CON_DP) += osd.o diff --git a/board/gdsys/mpc8308/strider.c b/board/gdsys/mpc8308/strider.c index eee582b..121977d 100644 --- a/board/gdsys/mpc8308/strider.c +++ b/board/gdsys/mpc8308/strider.c @@ -133,6 +133,9 @@ int last_stage_init(void) unsigned char mclink_controllers_dp[] = { 0x24, 0x25, 0x26 }; #endif bool hw_type_cat = pca9698_get_value(0x20, 18); +#ifdef CONFIG_STRIDER_CON_DP + bool is_dh = pca9698_get_value(0x20, 25); +#endif bool ch0_sgmii2_present = false;
/* Turn on Analog Devices ADV7611 */ @@ -140,6 +143,7 @@ int last_stage_init(void)
/* Turn on Parade DP501 */ pca9698_direction_output(0x20, 10, 1); + pca9698_direction_output(0x20, 11, 1);
ch0_sgmii2_present = !pca9698_get_value(0x20, 37);
@@ -202,6 +206,14 @@ int last_stage_init(void) osd_probe(0); #endif
+#ifdef CONFIG_STRIDER_CON_DP + if (ioep_fpga_has_osd(0)) { + osd_probe(0); + if (is_dh) + osd_probe(4); + } +#endif + #ifdef CONFIG_STRIDER_CPU ch7301_probe(0, false); dp501_probe(0, false); @@ -226,6 +238,13 @@ int last_stage_init(void) if (ioep_fpga_has_osd(k)) osd_probe(k); #endif +#ifdef CONFIG_STRIDER_CON_DP + if (ioep_fpga_has_osd(k)) { + osd_probe(k); + if (is_dh) + osd_probe(k + 4); + } +#endif #ifdef CONFIG_STRIDER_CPU if (!adv7611_probe(k)) printf(" Advantiv ADV7611 HDMI Receiver\n"); @@ -270,6 +289,24 @@ int fpga_gpio_get(unsigned int bus, int pin) return val & pin; }
+#ifdef CONFIG_STRIDER_CON_DP +void fpga_control_set(unsigned int bus, int pin) +{ + u16 val; + + FPGA_GET_REG(bus, control, &val); + FPGA_SET_REG(bus, control, val | pin); +} + +void fpga_control_clear(unsigned int bus, int pin) +{ + u16 val; + + FPGA_GET_REG(bus, control, &val); + FPGA_SET_REG(bus, control, val & ~pin); +} +#endif + void mpc8308_init(void) { pca9698_direction_output(0x20, 26, 1); diff --git a/configs/strider_con_dp_defconfig b/configs/strider_con_dp_defconfig new file mode 100644 index 0000000..b7a16b7 --- /dev/null +++ b/configs/strider_con_dp_defconfig @@ -0,0 +1,20 @@ +CONFIG_PPC=y +CONFIG_MPC83xx=y +CONFIG_TARGET_STRIDER=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_EXTRA_OPTIONS="STRIDER_CON_DP" +CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_SYS_NS16550=y +CONFIG_OF_LIBFDT=y diff --git a/include/configs/strider.h b/include/configs/strider.h index 5803b66..20ffc0c 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -22,6 +22,8 @@
#ifdef CONFIG_STRIDER_CPU #define CONFIG_IDENT_STRING " strider cpu 0.01" +#elif defined(CONFIG_STRIDER_CON_DP) +#define CONFIG_IDENT_STRING " strider con dp 0.01" #else #define CONFIG_IDENT_STRING " strider con 0.01" #endif @@ -225,15 +227,11 @@ /* * FLASH on the Local Bus */ -#if 1 #define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ #define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_FLASH_CFI_LEGACY #define CONFIG_SYS_FLASH_LEGACY_512Kx16 -#else -#define CONFIG_SYS_NO_FLASH -#endif
#define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ #define CONFIG_SYS_FLASH_SIZE 8 /* FLASH size is up to 8M */ @@ -341,6 +339,22 @@ #define CONFIG_SYS_I2C_IHS_SPEED_3 50000 #define CONFIG_SYS_I2C_IHS_SLAVE_3 0x7F
+#ifdef CONFIG_STRIDER_CON_DP +#define CONFIG_SYS_I2C_IHS_DUAL +#define CONFIG_SYS_I2C_IHS_CH0_1 +#define CONFIG_SYS_I2C_IHS_SPEED_0_1 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_0_1 0x7F +#define CONFIG_SYS_I2C_IHS_CH1_1 +#define CONFIG_SYS_I2C_IHS_SPEED_1_1 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_1_1 0x7F +#define CONFIG_SYS_I2C_IHS_CH2_1 +#define CONFIG_SYS_I2C_IHS_SPEED_2_1 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_2_1 0x7F +#define CONFIG_SYS_I2C_IHS_CH3_1 +#define CONFIG_SYS_I2C_IHS_SPEED_3_1 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_3_1 0x7F +#endif + /* * Software (bit-bang) I2C driver configuration */ @@ -357,7 +371,7 @@ #define I2C_SOFT_DECLARATIONS4 #define CONFIG_SYS_I2C_SOFT_SPEED_4 50000 #define CONFIG_SYS_I2C_SOFT_SLAVE_4 0x7F -#ifdef CONFIG_STRIDER_CON +#if defined(CONFIG_STRIDER_CON) || defined(CONFIG_STRIDER_CON_DP) #define I2C_SOFT_DECLARATIONS5 #define CONFIG_SYS_I2C_SOFT_SPEED_5 50000 #define CONFIG_SYS_I2C_SOFT_SLAVE_5 0x7F @@ -371,6 +385,20 @@ #define CONFIG_SYS_I2C_SOFT_SPEED_8 50000 #define CONFIG_SYS_I2C_SOFT_SLAVE_8 0x7F #endif +#ifdef CONFIG_STRIDER_CON_DP +#define I2C_SOFT_DECLARATIONS9 +#define CONFIG_SYS_I2C_SOFT_SPEED_9 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_9 0x7F +#define I2C_SOFT_DECLARATIONS10 +#define CONFIG_SYS_I2C_SOFT_SPEED_10 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_10 0x7F +#define I2C_SOFT_DECLARATIONS11 +#define CONFIG_SYS_I2C_SOFT_SPEED_11 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_11 0x7F +#define I2C_SOFT_DECLARATIONS12 +#define CONFIG_SYS_I2C_SOFT_SPEED_12 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_12 0x7F +#endif
#ifdef CONFIG_STRIDER_CON #define CONFIG_SYS_ICS8N3QV01_I2C {5, 6, 7, 8} @@ -379,6 +407,13 @@ #define CONFIG_SYS_DP501_I2C {1, 2, 3, 4} #define CONFIG_STRIDER_FANS { {10, 0x4c}, {11, 0x4c}, \ {12, 0x4c} } +#elif defined(CONFIG_STRIDER_CON_DP) +#define CONFIG_SYS_ICS8N3QV01_I2C {13, 14, 15, 16, 17, 18, 19, 20} +#define CONFIG_SYS_CH7301_I2C {1, 3, 5, 7} +#define CONFIG_SYS_ADV7611_I2C {1, 3, 5, 7} +#define CONFIG_SYS_DP501_I2C {1, 3, 5, 7, 2, 4, 6, 8} +#define CONFIG_STRIDER_FANS { {10, 0x4c}, {11, 0x4c}, \ + {12, 0x4c} } #else #define CONFIG_SYS_CH7301_I2C {1, 2, 3, 4} #define CONFIG_SYS_ADV7611_I2C {1, 2, 3, 4} @@ -391,6 +426,8 @@ void fpga_gpio_set(unsigned int bus, int pin); void fpga_gpio_clear(unsigned int bus, int pin); int fpga_gpio_get(unsigned int bus, int pin); +void fpga_control_set(unsigned int bus, int pin); +void fpga_control_clear(unsigned int bus, int pin); #endif
#ifdef CONFIG_STRIDER_CON @@ -398,12 +435,28 @@ int fpga_gpio_get(unsigned int bus, int pin); #define I2C_SCL_GPIO ((I2C_ADAP_HWNR > 3) ? 0x0100 : 0x0020) #define I2C_FPGA_IDX ((I2C_ADAP_HWNR > 3) ? \ (I2C_ADAP_HWNR - 4) : I2C_ADAP_HWNR) +#elif defined(CONFIG_STRIDER_CON_DP) +#define I2C_SDA_GPIO ((I2C_ADAP_HWNR > 3) ? 0x0040 : 0x0200) +#define I2C_SCL_GPIO ((I2C_ADAP_HWNR > 3) ? 0x0020 : 0x0100) +#define I2C_FPGA_IDX (I2C_ADAP_HWNR % 4) #else #define I2C_SDA_GPIO 0x0040 #define I2C_SCL_GPIO 0x0020 #define I2C_FPGA_IDX I2C_ADAP_HWNR #endif + +#ifdef CONFIG_STRIDER_CON_DP +#define I2C_ACTIVE \ + do { \ + if (I2C_ADAP_HWNR > 7) \ + fpga_control_set(I2C_FPGA_IDX, 0x0004); \ + else \ + fpga_control_clear(I2C_FPGA_IDX, 0x0004); \ + } while (0) +#else #define I2C_ACTIVE { } +#endif + #define I2C_TRISTATE { } #define I2C_READ \ (fpga_gpio_get(I2C_FPGA_IDX, I2C_SDA_GPIO) ? 1 : 0) @@ -436,6 +489,10 @@ int fpga_gpio_get(unsigned int bus, int pin); #define CONFIG_SYS_DP501_DIFFERENTIAL #define CONFIG_SYS_DP501_VCAPCTRL0 0x01 /* DDR mode 0, DE for H/VSYNC */
+#ifdef CONFIG_STRIDER_CON_DP +#define CONFIG_SYS_OSD_DH +#endif + /* * General PCI * Addresses are mapped 1-1. diff --git a/include/gdsys_fpga.h b/include/gdsys_fpga.h index 3b8762d..e1b9c64 100644 --- a/include/gdsys_fpga.h +++ b/include/gdsys_fpga.h @@ -163,7 +163,7 @@ struct ihs_fpga { }; #endif
-#ifdef CONFIG_HRCON +#if defined(CONFIG_HRCON) || defined(CONFIG_STRIDER_CON_DP) struct ihs_fpga { u16 reflection_low; /* 0x0000 */ u16 versions; /* 0x0002 */
There is new strider cpu flavor with DisplayPort video.
configs/strider_cpu_dp_defconfig | 20 ++++++++++++++++++++ include/configs/strider.h | 10 +++++++++- 2 files changed, 29 insertions(+), 1 deletion(-) create mode 100644 configs/strider_cpu_dp_defconfig
diff --git a/configs/strider_cpu_dp_defconfig b/configs/strider_cpu_dp_defconfig new file mode 100644 index 0000000..db75c0d --- /dev/null +++ b/configs/strider_cpu_dp_defconfig @@ -0,0 +1,20 @@ +CONFIG_PPC=y +CONFIG_MPC83xx=y +CONFIG_TARGET_STRIDER=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_EXTRA_OPTIONS="STRIDER_CPU,STRIDER_CPU_DP" +CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_SYS_NS16550=y +CONFIG_OF_LIBFDT=y diff --git a/include/configs/strider.h b/include/configs/strider.h index 20ffc0c..90492f4 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -20,7 +20,9 @@
#define CONFIG_SYS_TEXT_BASE 0xFE000000
-#ifdef CONFIG_STRIDER_CPU +#ifdef CONFIG_STRIDER_CPU_DP +#define CONFIG_IDENT_STRING " strider cpu dp 0.01" +#elif defined(CONFIG_STRIDER_CPU) #define CONFIG_IDENT_STRING " strider cpu 0.01" #elif defined(CONFIG_STRIDER_CON_DP) #define CONFIG_IDENT_STRING " strider con dp 0.01" @@ -414,6 +416,12 @@ #define CONFIG_SYS_DP501_I2C {1, 3, 5, 7, 2, 4, 6, 8} #define CONFIG_STRIDER_FANS { {10, 0x4c}, {11, 0x4c}, \ {12, 0x4c} } +#elif defined(CONFIG_STRIDER_CPU_DP) +#define CONFIG_SYS_CH7301_I2C {1, 2, 3, 4} +#define CONFIG_SYS_ADV7611_I2C {1, 2, 3, 4} +#define CONFIG_SYS_DP501_I2C {1, 2, 3, 4} +#define CONFIG_STRIDER_FANS { {6, 0x4c}, {7, 0x4c}, \ + {8, 0x4c} } #else #define CONFIG_SYS_CH7301_I2C {1, 2, 3, 4} #define CONFIG_SYS_ADV7611_I2C {1, 2, 3, 4}
Any chance you can review and ack/nak https://patchwork.ozlabs.org/patch/567150/ ? Thanks! :)
