[U-Boot] [PATCH] mips: xilfpga: fix DTC warnings
This fixes following DTC warning:
arch/mips/dts/nexys4ddr.dtb: Warning (compatible_is_string_list): /ethernet@10e00000/mdio/phy@1:compatible: property is not a string list
As upstream DTS in Linux doesn't have the offending property, simply remove it to fix the warning.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
arch/mips/dts/nexys4ddr.dts | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/mips/dts/nexys4ddr.dts b/arch/mips/dts/nexys4ddr.dts index e254ab1eaa..6de8584ea7 100644 --- a/arch/mips/dts/nexys4ddr.dts +++ b/arch/mips/dts/nexys4ddr.dts @@ -40,7 +40,6 @@ #address-cells = <1>; #size-cells = <0>; phy0: phy@1 { - compatible = <0x0007c0f0 0xfffffff0>; device_type = "ethernet-phy"; reg = <1>; } ;
Daniel Schwierzeck
