[PATCH v2] mkeficapsule: Miscellaneous fixes in the utility
Miscellaneous fixes in the mkeficapsule utility -- these include a few resource leak issues flagged by Coverity along with some additional code improvements suggested by Heinrich during code review.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org ---
Changes since V1: * Use a comparison with -1 for file descriptors before closing the fd's. * Remove the superfluous error != 0 check after a call to mmap. * Remove a printf that was used during debugging. * Return EXIT_SUCCESS and EXIT_FAILURE as return values through the exit libc call.
tools/mkeficapsule.c | 38 +++++++++++++++++++++++--------------- 1 file changed, 23 insertions(+), 15 deletions(-)
diff --git a/tools/mkeficapsule.c b/tools/mkeficapsule.c index 270943fc90..c797d240d8 100644 --- a/tools/mkeficapsule.c +++ b/tools/mkeficapsule.c @@ -137,8 +137,8 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, bool overlay) { int ret; - int srcfd = 0; - int destfd = 0; + int srcfd = -1; + int destfd = -1; void *sptr = NULL; void *dptr = NULL; off_t src_size; @@ -150,6 +150,7 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, if (srcfd == -1) { fprintf(stderr, "%s: Can't open %s: %s\n", __func__, pkey_file, strerror(errno)); + ret = -1; goto err; }
@@ -157,6 +158,7 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, if (ret == -1) { fprintf(stderr, "%s: Can't stat %s: %s\n", __func__, pkey_file, strerror(errno)); + ret = -1; goto err; }
@@ -164,9 +166,10 @@ static int add_public_key(const char *pkey_file, const char *dtb_file,
/* mmap the public key esl file */ sptr = mmap(0, src_size, PROT_READ, MAP_SHARED, srcfd, 0); - if ((sptr == MAP_FAILED) || (errno != 0)) { + if (sptr == MAP_FAILED) { fprintf(stderr, "%s: Failed to mmap %s:%s\n", __func__, pkey_file, strerror(errno)); + ret = -1; goto err; }
@@ -175,6 +178,7 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, if (destfd == -1) { fprintf(stderr, "%s: Can't open %s: %s\n", __func__, dtb_file, strerror(errno)); + ret = -1; goto err; }
@@ -189,21 +193,24 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, if (ftruncate(destfd, dtb.st_size)) { fprintf(stderr, "%s: Can't expand %s: %s\n", __func__, dtb_file, strerror(errno)); - goto err;; + ret = -1; + goto err; }
errno = 0; /* mmap the dtb file */ dptr = mmap(0, dtb.st_size, PROT_READ | PROT_WRITE, MAP_SHARED, destfd, 0); - if ((dptr == MAP_FAILED) || (errno != 0)) { + if (dptr == MAP_FAILED) { fprintf(stderr, "%s: Failed to mmap %s:%s\n", __func__, dtb_file, strerror(errno)); + ret = -1; goto err; }
if (fdt_check_header(dptr)) { fprintf(stderr, "%s: Invalid FDT header\n", __func__); + ret = -1; goto err; }
@@ -211,6 +218,7 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, if (ret) { fprintf(stderr, "%s: Cannot expand FDT: %s\n", __func__, fdt_strerror(ret)); + ret = -1; goto err; }
@@ -219,10 +227,11 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, if (ret < 0) { fprintf(stderr, "%s: Unable to add public key to the FDT\n", __func__); + ret = -1; goto err; }
- return 0; + ret = 0;
err: if (sptr) @@ -231,13 +240,13 @@ err: if (dptr) munmap(dptr, dtb.st_size);
- if (srcfd >= 0) + if (srcfd != -1) close(srcfd);
- if (destfd >= 0) + if (destfd != -1) close(destfd);
- return -1; + return ret; }
static int create_fwbin(char *path, char *bin, efi_guid_t *guid, @@ -421,26 +430,25 @@ int main(int argc, char **argv)
/* need a fit image file or raw image file */ if (!file && !pkey_file && !dtb_file) { - printf("%s: %d\n", __func__, __LINE__); print_usage(); - return -1; + exit(EXIT_FAILURE); }
if (pkey_file && dtb_file) { ret = add_public_key(pkey_file, dtb_file, overlay); if (ret == -1) { printf("Adding public key to the dtb failed\n"); - return -1; + exit(EXIT_FAILURE); } else { - return 0; + exit(EXIT_SUCCESS); } }
if (create_fwbin(argv[optind], file, guid, index, instance) < 0) { printf("Creating firmware capsule failed\n"); - return -1; + exit(EXIT_FAILURE); }
Sughosh Ganu
