[PATCH v6 00/22] Fixes for Rockchip NFC driver part 1
This serie contains fixes for the Rockchip NFC driver, which was ported to U-boot and merged with little review and testing it seems. Part 1 aims at passing the probe function without errors. Extended with tree wide function cleanup needed for 64bit DT parsing.
Fixed are: 64bit FDT parsing compatible string removal add missing layout structure add missing flash_node pointer add missing chip ID
Changed V6: use -EINVAL on return drop cast use map_sysmem() function as cast add and rename patch
Changed V5: sort patch order add more fixes with pointer functions add debug text fixes test with binman for ARM only due to limited resources
Changed V4: fix cast and divider in syscon-uclass.c
Changed V3: use dev_read_addr_ptr fix oobfree
TODO: Time consuming binman test for other SoC types then ARM. Help with testing appreciated.
Johan Jonker (21): mtd: nand: raw: rockchip_nfc: use dev_read_addr_ptr mtd: nand: raw: rockchip_nfc: remove the compatible string "rockchip,rk3308-nfc" mtd: nand: raw: rockchip_nfc: add layout structure mtd: nand: raw: rockchip_nfc: add flash_node to chip structure mtd: nand: raw: rockchip_nfc: fix oobfree offset and description rockchip: adc: rockchip-saradc: use dev_read_addr_ptr rockchip: timer: dw-apb-timer: use reg variable with phys_addr_t size rockchip: pwm: rk_pwm: use reg variable with phys_addr_t size include: dm: ofnode: fix headers core: remap: convert regmap_init_mem_plat() input to phys_addr_t core: fdtaddr: add devfdt_get_addr_size_index_ptr function core: read: add dev_read_addr_index_ptr function spi: spi-aspeed-smc: use devfdt_get_addr_index_ptr drivers: use dev_read_addr_index_ptr when cast to pointer drivers: use dev_read_addr_ptr when cast to pointer drivers: use devfdt_get_addr_size_index_ptr when cast to pointer drivers: use devfdt_get_addr_index_ptr when cast to pointer drivers: use devfdt_get_addr_ptr when cast to pointer drivers: fix debug string with fdt_addr_t input arm: stm32mp: spl: fix function with fdt_addr_t input include: fdtdec: decouple fdt_addr_t and phys_addr_t size
Paweł Jarosz (1): mtd: nand: add support for the Sandisk SDTNQGAMA chip
Kconfig | 8 ++ arch/arm/mach-mvebu/cpu.c | 2 +- arch/arm/mach-mvebu/system-controller.c | 4 +- arch/arm/mach-stm32mp/spl.c | 6 +- doc/develop/driver-model/livetree.rst | 2 +- drivers/adc/rockchip-saradc.c | 6 +- drivers/ata/dwc_ahsata.c | 2 +- drivers/cache/cache-l2x0.c | 2 +- drivers/cache/cache-v5l2.c | 2 +- drivers/clk/at91/sama7g5.c | 2 +- drivers/clk/at91/sckc.c | 2 +- drivers/clk/clk-hsdk-cgu.c | 4 +- drivers/clk/ti/clk-ctrl.c | 9 ++- drivers/core/fdtaddr.c | 8 ++ drivers/core/read.c | 15 +++- drivers/core/regmap.c | 2 +- drivers/core/syscon-uclass.c | 4 +- drivers/ddr/altera/sdram_gen5.c | 4 +- drivers/gpio/mscc_sgpio.c | 2 +- drivers/gpio/tegra_gpio.c | 4 +- drivers/gpio/xilinx_gpio.c | 2 +- drivers/i2c/i2c-cdns.c | 4 +- drivers/i2c/tegra_i2c.c | 4 +- drivers/mmc/am654_sdhci.c | 2 +- drivers/mmc/davinci_mmc.c | 2 +- drivers/mmc/piton_mmc.c | 2 +- drivers/mmc/tegra_mmc.c | 2 +- drivers/mmc/xenon_sdhci.c | 2 +- drivers/mmc/zynq_sdhci.c | 6 +- drivers/mtd/nand/raw/arasan_nfc.c | 2 +- drivers/mtd/nand/raw/cortina_nand.c | 6 +- drivers/mtd/nand/raw/mxic_nand.c | 2 +- drivers/mtd/nand/raw/nand_ids.c | 3 + drivers/mtd/nand/raw/rockchip_nfc.c | 78 +++++++------------ drivers/mtd/nand/raw/tegra_nand.c | 2 +- drivers/mtd/nand/raw/zynq_nand.c | 2 +- drivers/net/dm9000x.c | 2 +- drivers/net/dwmac_meson8b.c | 4 +- drivers/net/mvmdio.c | 2 +- drivers/net/mvpp2.c | 24 +++--- drivers/net/qe/dm_qe_uec_phy.c | 2 +- drivers/pci/pci-aardvark.c | 4 +- drivers/pci/pcie_dw_meson.c | 8 +- drivers/pci/pcie_dw_mvebu.c | 10 +-- drivers/pci/pcie_dw_rockchip.c | 8 +- drivers/pci/pcie_imx.c | 4 +- drivers/pci/pcie_layerscape_ep.c | 8 +- drivers/phy/allwinner/phy-sun50i-usb3.c | 6 +- drivers/phy/marvell/comphy_core.c | 12 +-- drivers/phy/phy-stm32-usbphyc.c | 4 +- drivers/phy/qcom/phy-qcom-usb-hs-28nm.c | 4 +- drivers/phy/qcom/phy-qcom-usb-ss.c | 4 +- .../phy/rockchip/phy-rockchip-snps-pcie3.c | 4 +- drivers/phy/rockchip/phy-rockchip-typec.c | 6 +- drivers/pwm/rk_pwm.c | 2 +- drivers/pwm/tegra_pwm.c | 2 +- drivers/ram/rockchip/sdram_rk3066.c | 2 +- drivers/ram/rockchip/sdram_rk3188.c | 2 +- drivers/ram/rockchip/sdram_rk322x.c | 2 +- drivers/ram/rockchip/sdram_rk3288.c | 2 +- drivers/ram/rockchip/sdram_rk3328.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 2 +- drivers/serial/serial_zynq.c | 6 +- drivers/spi/cadence_qspi.c | 5 +- drivers/spi/mpc8xxx_spi.c | 2 +- drivers/spi/mscc_bb_spi.c | 2 +- drivers/spi/mtk_snor.c | 2 +- drivers/spi/mtk_spim.c | 2 +- drivers/spi/sh_qspi.c | 2 +- drivers/spi/spi-aspeed-smc.c | 17 ++-- drivers/spi/spi-mxic.c | 2 +- drivers/spi/xilinx_spi.c | 2 +- drivers/timer/dw-apb-timer.c | 2 +- drivers/ufs/ufs.c | 2 +- drivers/usb/host/ehci-tegra.c | 2 +- drivers/usb/musb-new/ti-musb.c | 2 +- drivers/video/dw_mipi_dsi.c | 4 +- drivers/video/rockchip/rk_vop.c | 2 +- drivers/video/stm32/stm32_dsi.c | 4 +- drivers/video/stm32/stm32_ltdc.c | 4 +- drivers/video/tegra124/display.c | 2 +- drivers/video/tegra124/sor.c | 6 +- drivers/video/ti/tilcdc.c | 4 +- drivers/watchdog/cdns_wdt.c | 6 +- drivers/watchdog/sbsa_gwdt.c | 12 +-- drivers/watchdog/sp805_wdt.c | 6 +- drivers/watchdog/xilinx_tb_wdt.c | 6 +- include/dm/fdtaddr.h | 17 +++- include/dm/ofnode.h | 16 ++-- include/fdtdec.h | 13 +++- include/regmap.h | 2 +- include/syscon.h | 13 ++-- 92 files changed, 269 insertions(+), 241 deletions(-)
-- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expext 64-bit data from the device tree parser, so use dev_read_addr_ptr in the rockchip_nfc.c file.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com ---
Changed V6: use -EINVAL on return --- drivers/mtd/nand/raw/rockchip_nfc.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index d016d255..9f424a25 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -1180,9 +1180,9 @@ static int rk_nfc_probe(struct udevice *dev) nfc->cfg = (void *)dev_get_driver_data(dev); nfc->dev = dev;
- nfc->regs = (void *)dev_read_addr(dev); - if (IS_ERR(nfc->regs)) { - ret = PTR_ERR(nfc->regs); + nfc->regs = dev_read_addr_ptr(dev); + if (!nfc->regs) { + ret = -EINVAL; goto release_nfc; }
-- 2.20.1
The compatible string for rk3308 has as fallback string "rockchip,rv1108-nfc". As there is no logic in probe priority between the SoC orientated string and the fall back, so remove the compatible string "rockchip,rk3308-nfc" from the driver.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/mtd/nand/raw/rockchip_nfc.c | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index 9f424a25..021e7ef7 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -1165,10 +1165,6 @@ static const struct udevice_id rk_nfc_id_table[] = { .compatible = "rockchip,rv1108-nfc", .data = (unsigned long)&nfc_v8_cfg }, - { - .compatible = "rockchip,rk3308-nfc", - .data = (unsigned long)&nfc_v8_cfg - }, { /* sentinel */ } };
-- 2.20.1
The MTD framework in U-boot is not identical for drivers ported from Linux. The rockchip_nfc driver was ported with OOB ops functions while the framework expects a layout structure per chip. Fix by adding a structure with OOB data and remove unused functions.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/mtd/nand/raw/rockchip_nfc.c | 61 ++++++++++------------------- 1 file changed, 20 insertions(+), 41 deletions(-)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index 021e7ef7..90cd86a2 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -814,47 +814,9 @@ static void rk_nfc_disable_clks(struct rk_nfc *nfc) clk_disable_unprepare(nfc->ahb_clk); }
-static int rk_nfc_ooblayout_free(struct mtd_info *mtd, int section, - struct mtd_oob_region *oob_region) -{ - struct nand_chip *chip = mtd_to_nand(mtd); - struct rk_nfc_nand_chip *rknand = rk_nfc_to_rknand(chip); - - if (section) - return -ERANGE; - - /* - * The beginning of the OOB area stores the reserved data for the NFC, - * the size of the reserved data is NFC_SYS_DATA_SIZE bytes. - */ - oob_region->length = rknand->metadata_size - NFC_SYS_DATA_SIZE - 2; - oob_region->offset = NFC_SYS_DATA_SIZE + 2; - - return 0; -} - -static int rk_nfc_ooblayout_ecc(struct mtd_info *mtd, int section, - struct mtd_oob_region *oob_region) -{ - struct nand_chip *chip = mtd_to_nand(mtd); - struct rk_nfc_nand_chip *rknand = rk_nfc_to_rknand(chip); - - if (section) - return -ERANGE; - - oob_region->length = mtd->oobsize - rknand->metadata_size; - oob_region->offset = rknand->metadata_size; - - return 0; -} - -static const struct mtd_ooblayout_ops rk_nfc_ooblayout_ops = { - .rfree = rk_nfc_ooblayout_free, - .ecc = rk_nfc_ooblayout_ecc, -}; - static int rk_nfc_ecc_init(struct rk_nfc *nfc, struct nand_chip *chip) { + struct rk_nfc_nand_chip *rknand = rk_nfc_to_rknand(chip); const u8 *strengths = nfc->cfg->ecc_strengths; struct mtd_info *mtd = nand_to_mtd(chip); struct nand_ecc_ctrl *ecc = &chip->ecc; @@ -892,6 +854,21 @@ static int rk_nfc_ecc_init(struct rk_nfc *nfc, struct nand_chip *chip) ecc->steps = mtd->writesize / ecc->size; ecc->bytes = DIV_ROUND_UP(ecc->strength * fls(8 * chip->ecc.size), 8);
+ if (ecc->bytes * ecc->steps > mtd->oobsize - rknand->metadata_size) + return -EINVAL; + + ecc->layout = kzalloc(sizeof(*ecc->layout), GFP_KERNEL); + if (!ecc->layout) + return -ENOMEM; + + ecc->layout->eccbytes = ecc->bytes * ecc->steps; + + for (i = 0; i < ecc->layout->eccbytes; i++) + ecc->layout->eccpos[i] = rknand->metadata_size + i; + + ecc->layout->oobfree[0].length = rknand->metadata_size - NFC_SYS_DATA_SIZE - 2; + ecc->layout->oobfree[0].offset = NFC_SYS_DATA_SIZE + 2; + return 0; }
@@ -969,7 +946,6 @@ static int rk_nfc_nand_chip_init(ofnode node, struct rk_nfc *nfc, int devnum) chip->bbt_options = NAND_BBT_USE_FLASH | NAND_BBT_NO_OOB; chip->options |= NAND_NO_SUBPAGE_WRITE | NAND_USE_BOUNCE_BUFFER;
- mtd_set_ooblayout(mtd, &rk_nfc_ooblayout_ops); rk_nfc_hw_init(nfc); ret = nand_scan_ident(mtd, nsels, NULL); if (ret) @@ -998,13 +974,16 @@ static int rk_nfc_nand_chip_init(ofnode node, struct rk_nfc *nfc, int devnum)
if (!nfc->page_buf) { nfc->page_buf = kzalloc(NFC_MAX_PAGE_SIZE, GFP_KERNEL); - if (!nfc->page_buf) + if (!nfc->page_buf) { + kfree(ecc->layout); return -ENOMEM; + } }
if (!nfc->oob_buf) { nfc->oob_buf = kzalloc(NFC_MAX_OOB_SIZE, GFP_KERNEL); if (!nfc->oob_buf) { + kfree(ecc->layout); kfree(nfc->page_buf); nfc->page_buf = NULL; return -ENOMEM; -- 2.20.1
Add flash_node to the rockchip_nfc driver chip structure in order to find the partitions in the add_mtd_partitions_of() function.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/mtd/nand/raw/rockchip_nfc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index 90cd86a2..25e04974 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -934,6 +934,7 @@ static int rk_nfc_nand_chip_init(ofnode node, struct rk_nfc *nfc, int devnum)
nand_set_controller_data(chip, nfc);
+ chip->flash_node = node; chip->chip_delay = NFC_RB_DELAY_US; chip->select_chip = rk_nfc_select_chip; chip->cmd_ctrl = rk_nfc_cmd; -- 2.20.1
The MTD framework reserves 1 or 2 bytes for the bad block marker depending on the bus size. The rockchip_nfc driver currently only supports a 8 bit bus, but reserves standard 2 bytes for the BBM. The first free OOB byte is therefore OOB2 at offset 2. Page address(PA) bytes are moved to the last 4 positions before ECC. Update the description for U-boot.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/mtd/nand/raw/rockchip_nfc.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index 25e04974..5fcf6a6b 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -487,10 +487,10 @@ static int rk_nfc_write_page_raw(struct mtd_info *mtd, * * BBM OOB1 OOB2 OOB3 |......| PA0 PA1 PA2 PA3 * - * The rk_nfc_ooblayout_free() function already has reserved - * these 4 bytes with: + * The oobfree structure already has reserved these 4 bytes + * together with 2 bytes for BBM by reducing it's length: * - * oob_region->offset = NFC_SYS_DATA_SIZE + 2; + * oobfree[0].length = rknand->metadata_size - NFC_SYS_DATA_SIZE - 2; */ if (!i) memcpy(rk_nfc_oob_ptr(chip, i), @@ -867,7 +867,7 @@ static int rk_nfc_ecc_init(struct rk_nfc *nfc, struct nand_chip *chip) ecc->layout->eccpos[i] = rknand->metadata_size + i;
ecc->layout->oobfree[0].length = rknand->metadata_size - NFC_SYS_DATA_SIZE - 2; - ecc->layout->oobfree[0].offset = NFC_SYS_DATA_SIZE + 2; + ecc->layout->oobfree[0].offset = 2;
return 0; } -- 2.20.1
Sandisk SDTNQGAMA is a 8GB size, 3.3V 8 bit chip with 16KB page size, 1KB write size and 40 bit ecc support
Signed-off-by: Paweł Jarosz paweljarosz3691@gmail.com Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/mtd/nand/raw/nand_ids.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mtd/nand/raw/nand_ids.c b/drivers/mtd/nand/raw/nand_ids.c index d0cfacc6..22ea5e2f 100644 --- a/drivers/mtd/nand/raw/nand_ids.c +++ b/drivers/mtd/nand/raw/nand_ids.c @@ -48,6 +48,9 @@ struct nand_flash_dev nand_flash_ids[] = { {"TC58NVG6D2 64G 3.3V 8-bit", { .id = {0x98, 0xde, 0x94, 0x82, 0x76, 0x56, 0x04, 0x20} }, SZ_8K, SZ_8K, SZ_2M, 0, 8, 640, NAND_ECC_INFO(40, SZ_1K) }, + {"SDTNQGAMA 64G 3.3V 8-bit", + { .id = {0x45, 0xde, 0x94, 0x93, 0x76, 0x57} }, + SZ_16K, SZ_8K, SZ_4M, 0, 6, 1280, NAND_ECC_INFO(40, SZ_1K) }, {"SDTNRGAMA 64G 3.3V 8-bit", { .id = {0x45, 0xde, 0x94, 0x93, 0x76, 0x50} }, SZ_16K, SZ_8K, SZ_4M, 0, 6, 1280, NAND_ECC_INFO(40, SZ_1K) }, -- 2.20.1
-- 2.20.1
Acked-by: Michael Trimarchi michael@amarulasolutions.com
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expext 64-bit data from the device tree parser, so use dev_read_addr_ptr in the rockchip-saradc.c file.
Changed V6: use -EINVAL on return drop cast --- drivers/adc/rockchip-saradc.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/adc/rockchip-saradc.c b/drivers/adc/rockchip-saradc.c index 760f8fe6..809486eb 100644 --- a/drivers/adc/rockchip-saradc.c +++ b/drivers/adc/rockchip-saradc.c @@ -145,10 +145,10 @@ int rockchip_saradc_of_to_plat(struct udevice *dev) struct rockchip_saradc_data *data;
data = (struct rockchip_saradc_data *)dev_get_driver_data(dev); - priv->regs = (struct rockchip_saradc_regs *)dev_read_addr(dev); - if (priv->regs == (struct rockchip_saradc_regs *)FDT_ADDR_T_NONE) { + priv->regs = dev_read_addr_ptr(dev); + if (!priv->regs) { pr_err("Dev: %s - can't get address!", dev->name); - return -ENODATA; + return -EINVAL; }
priv->data = data; -- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so use a reg variable with phys_addr_t size in the dw-apb-timer.c file.
Signed-off-by: Johan Jonker jbx6244@gmail.com ---
Changed V6: remove cast change title --- drivers/timer/dw-apb-timer.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/timer/dw-apb-timer.c b/drivers/timer/dw-apb-timer.c index 10f0a9f6..c92728da 100644 --- a/drivers/timer/dw-apb-timer.c +++ b/drivers/timer/dw-apb-timer.c @@ -23,7 +23,7 @@ #define DW_APB_CTRL 0x8
struct dw_apb_timer_priv { - fdt_addr_t regs; + phys_addr_t regs; struct reset_ctl_bulk resets; };
-- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so use a reg variable with phys_addr_t size in the rk_pwm.c file.
Changed V6: new patch --- drivers/pwm/rk_pwm.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pwm/rk_pwm.c b/drivers/pwm/rk_pwm.c index 071eb04f..b2784530 100644 --- a/drivers/pwm/rk_pwm.c +++ b/drivers/pwm/rk_pwm.c @@ -30,7 +30,7 @@ struct rockchip_pwm_data { };
struct rk_pwm_priv { - fdt_addr_t base; + phys_addr_t base; ulong freq; u32 conf_polarity; const struct rockchip_pwm_data *data; -- 2.20.1
When fdt_addr_t and phys_addr_t are split it turns out that the header don't match the functions, so fix the headers.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Kever Yang kever.yang@rock-chips.com --- include/dm/ofnode.h | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 3f6b0843..cd966f6a 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -678,8 +678,8 @@ int ofnode_read_size(ofnode node, const char *propname); * @size: Pointer to size of the address * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ -phys_addr_t ofnode_get_addr_size_index(ofnode node, int index, - fdt_size_t *size); +fdt_addr_t ofnode_get_addr_size_index(ofnode node, int index, + fdt_size_t *size);
/** * ofnode_get_addr_size_index_notrans() - get an address/size from a node @@ -695,8 +695,8 @@ phys_addr_t ofnode_get_addr_size_index(ofnode node, int index, * @size: Pointer to size of the address * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ -phys_addr_t ofnode_get_addr_size_index_notrans(ofnode node, int index, - fdt_size_t *size); +fdt_addr_t ofnode_get_addr_size_index_notrans(ofnode node, int index, + fdt_size_t *size);
/** * ofnode_get_addr_index() - get an address from a node @@ -707,7 +707,7 @@ phys_addr_t ofnode_get_addr_size_index_notrans(ofnode node, int index, * @index: Index of address to read (0 for first) * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ -phys_addr_t ofnode_get_addr_index(ofnode node, int index); +fdt_addr_t ofnode_get_addr_index(ofnode node, int index);
/** * ofnode_get_addr() - get an address from a node @@ -717,7 +717,7 @@ phys_addr_t ofnode_get_addr_index(ofnode node, int index); * @node: node to read from * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ -phys_addr_t ofnode_get_addr(ofnode node); +fdt_addr_t ofnode_get_addr(ofnode node);
/** * ofnode_get_size() - get size from a node @@ -1067,8 +1067,8 @@ const void *ofprop_get_property(const struct ofprop *prop, * @sizep: place to put size value (on success) * Return: address value, or FDT_ADDR_T_NONE on error */ -phys_addr_t ofnode_get_addr_size(ofnode node, const char *propname, - phys_size_t *sizep); +fdt_addr_t ofnode_get_addr_size(ofnode node, const char *propname, + fdt_size_t *sizep);
/** * ofnode_read_u8_array_ptr() - find an 8-bit array -- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so convert regmap_init_mem_plat() input to phys_addr_t in files that use this function. Also correct struct syscon_base_plat depending on CONFIG_PHYS_64BIT setting and fix ARRAY_SIZE divider.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/core/regmap.c | 2 +- drivers/core/syscon-uclass.c | 4 ++-- drivers/ram/rockchip/sdram_rk3066.c | 2 +- drivers/ram/rockchip/sdram_rk3188.c | 2 +- drivers/ram/rockchip/sdram_rk322x.c | 2 +- drivers/ram/rockchip/sdram_rk3288.c | 2 +- drivers/ram/rockchip/sdram_rk3328.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 2 +- include/regmap.h | 2 +- include/syscon.h | 13 +++++++------ 10 files changed, 17 insertions(+), 16 deletions(-)
diff --git a/drivers/core/regmap.c b/drivers/core/regmap.c index e33bb9d7..37da64b2 100644 --- a/drivers/core/regmap.c +++ b/drivers/core/regmap.c @@ -79,7 +79,7 @@ static struct regmap *regmap_alloc(int count) }
#if CONFIG_IS_ENABLED(OF_PLATDATA) -int regmap_init_mem_plat(struct udevice *dev, fdt_val_t *reg, int count, +int regmap_init_mem_plat(struct udevice *dev, phys_addr_t *reg, int count, struct regmap **mapp) { struct regmap_range *range; diff --git a/drivers/core/syscon-uclass.c b/drivers/core/syscon-uclass.c index 25fdb66e..b557a24f 100644 --- a/drivers/core/syscon-uclass.c +++ b/drivers/core/syscon-uclass.c @@ -58,8 +58,8 @@ static int syscon_pre_probe(struct udevice *dev) #if CONFIG_IS_ENABLED(OF_PLATDATA) struct syscon_base_plat *plat = dev_get_plat(dev);
- return regmap_init_mem_plat(dev, plat->reg, ARRAY_SIZE(plat->reg), - &priv->regmap); + return regmap_init_mem_plat(dev, (phys_addr_t *)plat->reg, + ARRAY_SIZE(plat->reg) / 2, &priv->regmap); #else return regmap_init_mem(dev_ofnode(dev), &priv->regmap); #endif diff --git a/drivers/ram/rockchip/sdram_rk3066.c b/drivers/ram/rockchip/sdram_rk3066.c index a2425f22..9bb26b64 100644 --- a/drivers/ram/rockchip/sdram_rk3066.c +++ b/drivers/ram/rockchip/sdram_rk3066.c @@ -801,7 +801,7 @@ static int rk3066_dmc_conv_of_plat(struct udevice *dev) memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base)); /* RK3066 supports dual-channel, set default channel num to 2. */ plat->num_channels = 1; - ret = regmap_init_mem_plat(dev, of_plat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)of_plat->reg, ARRAY_SIZE(of_plat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk3188.c b/drivers/ram/rockchip/sdram_rk3188.c index 272b1b2d..1838985c 100644 --- a/drivers/ram/rockchip/sdram_rk3188.c +++ b/drivers/ram/rockchip/sdram_rk3188.c @@ -867,7 +867,7 @@ static int conv_of_plat(struct udevice *dev) memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base)); /* rk3188 supports dual-channel, set default channel num to 2 */ plat->num_channels = 1; - ret = regmap_init_mem_plat(dev, of_plat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)of_plat->reg, ARRAY_SIZE(of_plat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk322x.c b/drivers/ram/rockchip/sdram_rk322x.c index 1b204fb5..33599dc5 100644 --- a/drivers/ram/rockchip/sdram_rk322x.c +++ b/drivers/ram/rockchip/sdram_rk322x.c @@ -769,7 +769,7 @@ static int conv_of_plat(struct udevice *dev) memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base));
plat->num_channels = 1; - ret = regmap_init_mem_plat(dev, of_plat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)of_plat->reg, ARRAY_SIZE(of_plat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk3288.c b/drivers/ram/rockchip/sdram_rk3288.c index 83778ad1..1a548da5 100644 --- a/drivers/ram/rockchip/sdram_rk3288.c +++ b/drivers/ram/rockchip/sdram_rk3288.c @@ -1029,7 +1029,7 @@ static int conv_of_plat(struct udevice *dev) memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base)); /* Rk3288 supports dual-channel, set default channel num to 2 */ plat->num_channels = 2; - ret = regmap_init_mem_plat(dev, of_plat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)of_plat->reg, ARRAY_SIZE(of_plat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk3328.c b/drivers/ram/rockchip/sdram_rk3328.c index 184c93f7..41da7ca2 100644 --- a/drivers/ram/rockchip/sdram_rk3328.c +++ b/drivers/ram/rockchip/sdram_rk3328.c @@ -54,7 +54,7 @@ static int conv_of_plat(struct udevice *dev) struct dtd_rockchip_rk3328_dmc *dtplat = &plat->dtplat; int ret;
- ret = regmap_init_mem_plat(dev, dtplat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)dtplat->reg, ARRAY_SIZE(dtplat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index b1fea04e..e3f76fa4 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -3048,7 +3048,7 @@ static int conv_of_plat(struct udevice *dev) struct dtd_rockchip_rk3399_dmc *dtplat = &plat->dtplat; int ret;
- ret = regmap_init_mem_plat(dev, dtplat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)dtplat->reg, ARRAY_SIZE(dtplat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/include/regmap.h b/include/regmap.h index e81a3602..a274fb27 100644 --- a/include/regmap.h +++ b/include/regmap.h @@ -388,7 +388,7 @@ int regmap_init_mem(ofnode node, struct regmap **mapp); * Use regmap_uninit() to free it. * */ -int regmap_init_mem_plat(struct udevice *dev, fdt_val_t *reg, int count, +int regmap_init_mem_plat(struct udevice *dev, phys_addr_t *reg, int count, struct regmap **mapp);
int regmap_init_mem_index(ofnode node, struct regmap **mapp, int index); diff --git a/include/syscon.h b/include/syscon.h index f5e6cc1a..836ae07c 100644 --- a/include/syscon.h +++ b/include/syscon.h @@ -27,14 +27,15 @@ struct syscon_ops {
#if CONFIG_IS_ENABLED(OF_PLATDATA) /* - * We don't support 64-bit machines. If they are so resource-contrained that - * they need to use OF_PLATDATA, something is horribly wrong with the - * education of our hardware engineers. - * - * Update: 64-bit is now supported and we have an education crisis. + * Support for 64bit or 32bit fdt addresses + * depending on the physical SoC properties. */ struct syscon_base_plat { - fdt_val_t reg[2]; +#ifdef CONFIG_PHYS_64BIT + fdt64_t reg[2]; +#else + fdt32_t reg[2]; +#endif }; #endif
-- 2.20.1
This patch must be put in the garbage bin for now.
The size of plat data is unknown. Where is this plat data defined? struct syscon_base_plat is not used elsewhere. With rk3288 this can be 32 or 64bit size. The only place that this can be found out is in the syscon driver that holds the compatible and the struct dtd. Must test if data from struct dtd can be transfered to dev->plat by dev_set_plat() into a fixed struct syscon_base_plat format. Any ideas on how to move forward/fix are welcome!
Johan
&priv->regmap);
- return regmap_init_mem_plat(dev, (phys_addr_t *)plat->reg,
This patch
- We don't support 64-bit machines. If they are so resource-contrained that
- they need to use OF_PLATDATA, something is horribly wrong with the
- education of our hardware engineers.
- Update: 64-bit is now supported and we have an education crisis.
- Support for 64bit or 32bit fdt addresses
- depending on the physical SoC properties.
- fdt_val_t reg[2];
- fdt64_t reg[2];
+#else
- fdt32_t reg[2];
+#endif }; #endif
-- 2.20.1
Hi Johan,
You could have two functions, one for 32 and one for 64 bits.
Johan
&priv->regmap);
This patch
fdt_val_t reg[2];
fdt64_t reg[2];
+#else
fdt32_t reg[2];
+#endif }; #endif
-- 2.20.1
Add devfdt_get_addr_size_index_ptr function with the same functionality as devfdt_get_addr_size_index, but instead a return pointer is given.
Suggested-by: Michael Nazzareno Trimarchi michael@amarulasolutions.com Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com ---
Changed V5: fix spelling use tabs --- drivers/core/fdtaddr.c | 8 ++++++++ include/dm/fdtaddr.h | 17 ++++++++++++++++- 2 files changed, 24 insertions(+), 1 deletion(-)
diff --git a/drivers/core/fdtaddr.c b/drivers/core/fdtaddr.c index 91bcd1a2..f5906ff9 100644 --- a/drivers/core/fdtaddr.c +++ b/drivers/core/fdtaddr.c @@ -122,6 +122,14 @@ fdt_addr_t devfdt_get_addr_size_index(const struct udevice *dev, int index, #endif }
+void *devfdt_get_addr_size_index_ptr(const struct udevice *dev, int index, + fdt_size_t *size) +{ + fdt_addr_t addr = devfdt_get_addr_size_index(dev, index, size); + + return (addr == FDT_ADDR_T_NONE) ? NULL : (void *)(uintptr_t)addr; +} + fdt_addr_t devfdt_get_addr_name(const struct udevice *dev, const char *name) { #if CONFIG_IS_ENABLED(OF_CONTROL) diff --git a/include/dm/fdtaddr.h b/include/dm/fdtaddr.h index c9d2b27b..dcdc1913 100644 --- a/include/dm/fdtaddr.h +++ b/include/dm/fdtaddr.h @@ -111,7 +111,7 @@ void *devfdt_get_addr_index_ptr(const struct udevice *dev, int index); * @dev: Pointer to a device * @index: the 'reg' property can hold a list of <addr, size> pairs * and @index is used to select which one is required - * @size: Pointer to size varible - this function returns the size + * @size: Pointer to size variable - this function returns the size * specified in the 'reg' property here * * Return: addr @@ -119,6 +119,21 @@ void *devfdt_get_addr_index_ptr(const struct udevice *dev, int index); fdt_addr_t devfdt_get_addr_size_index(const struct udevice *dev, int index, fdt_size_t *size);
+/** + * devfdt_get_addr_size_index_ptr() - Return indexed pointer to the address of the + * reg property of a device + * + * @dev: Pointer to a device + * @index: the 'reg' property can hold a list of <addr, size> pairs + * and @index is used to select which one is required + * @size: Pointer to size variable - this function returns the size + * specified in the 'reg' property here + * + * Return: Pointer to addr, or NULL if there is no such property + */ +void *devfdt_get_addr_size_index_ptr(const struct udevice *dev, int index, + fdt_size_t *size); + /** * devfdt_get_addr_name() - Get the reg property of a device, indexed by name * -- 2.20.1
Hi Johan,
fdt_size_t *size)
Shouldn't this use map_to_sysmem()? We should not cast addresses to pointers.
Regards, SImon
On 3/6/23 18:53, Simon Glass wrote:
Hi Johan,
fdt_size_t *size)
Just wondering, as a side question: Why is Uboot maintaining/exporting 2 sets of functions that do the do the more or less the same thing.
For example: devfdt_get_addr_size_index_ptr vs. dev_read_addr_size_index_ptr
Or should we standardize and replace all by dev_read_addr_size_index_ptr if possible?
Johan
Regards, SImon
Hi Johan,
Hi Johan,
fdt_size_t *size)
Yes that is a bit wonky. The flat/live tree selection is supposed to be in ofnode.c, so we could change it to call the ofnode version in both cases, moving the logic into there. That is how other functions work.
Add dev_read_addr_index_ptr function with the same functionality as dev_read_addr_index, but instead a return pointer is given. Use map_sysmem() function as cast for the return. Make same fix for dev_read_addr_ptr() function.
Changed V6: use map_sysmem()
Changed V5: new patch --- drivers/core/read.c | 15 ++++++++++++++- 1 file changed, 14 insertions(+), 1 deletion(-)
diff --git a/drivers/core/read.c b/drivers/core/read.c index e0543bba..0289a2ed 100644 --- a/drivers/core/read.c +++ b/drivers/core/read.c @@ -131,6 +131,16 @@ fdt_addr_t dev_read_addr_index(const struct udevice *dev, int index) return devfdt_get_addr_index(dev, index); }
+void *dev_read_addr_index_ptr(const struct udevice *dev, int index) +{ + fdt_addr_t addr = dev_read_addr_index(dev, index); + + if (addr == FDT_ADDR_T_NONE) + return NULL; + + return map_sysmem(addr, 0); +} + fdt_addr_t dev_read_addr_size_index(const struct udevice *dev, int index, fdt_size_t *size) { @@ -190,7 +200,10 @@ void *dev_read_addr_ptr(const struct udevice *dev) { fdt_addr_t addr = dev_read_addr(dev);
- return (addr == FDT_ADDR_T_NONE) ? NULL : (void *)(uintptr_t)addr; + if (addr == FDT_ADDR_T_NONE) + return NULL; + + return map_sysmem(addr, 0); }
void *dev_remap_addr(const struct udevice *dev) -- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so use devfdt_get_addr_index_ptr and devfdt_get_addr_size_index_ptr function in the spi-aspeed-smc.c file. Also fix dev_dbg to be able to handle both sizes.
Changed V6: use -EINVAL on return --- drivers/spi/spi-aspeed-smc.c | 17 ++++++++--------- 1 file changed, 8 insertions(+), 9 deletions(-)
diff --git a/drivers/spi/spi-aspeed-smc.c b/drivers/spi/spi-aspeed-smc.c index 4b6ea9f8..39620310 100644 --- a/drivers/spi/spi-aspeed-smc.c +++ b/drivers/spi/spi-aspeed-smc.c @@ -1125,17 +1125,16 @@ static int apseed_spi_of_to_plat(struct udevice *bus) int ret; struct clk hclk;
- priv->regs = (void __iomem *)devfdt_get_addr_index(bus, 0); - if ((u32)priv->regs == FDT_ADDR_T_NONE) { + priv->regs = devfdt_get_addr_index_ptr(bus, 0); + if (!priv->regs) { dev_err(bus, "wrong ctrl base\n"); - return -ENODEV; + return -EINVAL; }
- plat->ahb_base = - (void __iomem *)devfdt_get_addr_size_index(bus, 1, &plat->ahb_sz); - if ((u32)plat->ahb_base == FDT_ADDR_T_NONE) { + plat->ahb_base = devfdt_get_addr_size_index_ptr(bus, 1, &plat->ahb_sz); + if (!plat->ahb_base) { dev_err(bus, "wrong AHB base\n"); - return -ENODEV; + return -EINVAL; }
plat->max_cs = dev_read_u32_default(bus, "num-cs", ASPEED_SPI_MAX_CS); @@ -1151,8 +1150,8 @@ static int apseed_spi_of_to_plat(struct udevice *bus) plat->hclk_rate = clk_get_rate(&hclk); clk_free(&hclk);
- dev_dbg(bus, "ctrl_base = 0x%x, ahb_base = 0x%p, size = 0x%lx\n", - (u32)priv->regs, plat->ahb_base, plat->ahb_sz); + dev_dbg(bus, "ctrl_base = 0x%x, ahb_base = 0x%p, size = 0x%llx\n", + (u32)priv->regs, plat->ahb_base, (fdt64_t)plat->ahb_sz); dev_dbg(bus, "hclk = %dMHz, max_cs = %d\n", plat->hclk_rate / 1000000, plat->max_cs);
-- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so use dev_read_addr_index_ptr instead of the dev_read_addr_index function in the various files in the drivers directory that cast to a pointer.
Changed V6: use -EINVAL on return drop cast --- drivers/mtd/nand/raw/cortina_nand.c | 4 ++-- drivers/net/dm9000x.c | 2 +- drivers/net/dwmac_meson8b.c | 4 ++-- drivers/pci/pcie_dw_meson.c | 8 ++++---- drivers/pci/pcie_dw_rockchip.c | 8 ++++---- drivers/watchdog/sbsa_gwdt.c | 12 ++++++------ 6 files changed, 19 insertions(+), 19 deletions(-)
diff --git a/drivers/mtd/nand/raw/cortina_nand.c b/drivers/mtd/nand/raw/cortina_nand.c index 88798f23..8de35731 100644 --- a/drivers/mtd/nand/raw/cortina_nand.c +++ b/drivers/mtd/nand/raw/cortina_nand.c @@ -1175,8 +1175,8 @@ static int fdt_decode_nand(struct udevice *dev, struct nand_drv *info) int ecc_strength;
info->reg = (struct nand_ctlr *)dev_read_addr(dev); - info->dma_glb = (struct dma_global *)dev_read_addr_index(dev, 1); - info->dma_nand = (struct dma_ssp *)dev_read_addr_index(dev, 2); + info->dma_glb = dev_read_addr_index_ptr(dev, 1); + info->dma_nand = dev_read_addr_index_ptr(dev, 2); info->config.enabled = dev_read_enabled(dev); ecc_strength = dev_read_u32_default(dev, "nand-ecc-strength", 16); info->flash_base = diff --git a/drivers/net/dm9000x.c b/drivers/net/dm9000x.c index b46bdeb2..bec8d67d 100644 --- a/drivers/net/dm9000x.c +++ b/drivers/net/dm9000x.c @@ -651,7 +651,7 @@ static int dm9000_of_to_plat(struct udevice *dev)
pdata->iobase = dev_read_addr_index(dev, 0); db->base_io = (void __iomem *)pdata->iobase; - db->base_data = (void __iomem *)dev_read_addr_index(dev, 1); + db->base_data = dev_read_addr_index_ptr(dev, 1);
return 0; } diff --git a/drivers/net/dwmac_meson8b.c b/drivers/net/dwmac_meson8b.c index ddbaa87d..871171e1 100644 --- a/drivers/net/dwmac_meson8b.c +++ b/drivers/net/dwmac_meson8b.c @@ -41,8 +41,8 @@ static int dwmac_meson8b_of_to_plat(struct udevice *dev) { struct dwmac_meson8b_plat *pdata = dev_get_plat(dev);
- pdata->regs = (void *)dev_read_addr_index(dev, 1); - if ((fdt_addr_t)pdata->regs == FDT_ADDR_T_NONE) + pdata->regs = dev_read_addr_index_ptr(dev, 1); + if (!pdata->regs) return -EINVAL;
pdata->dwmac_setup = (void *)dev_get_driver_data(dev); diff --git a/drivers/pci/pcie_dw_meson.c b/drivers/pci/pcie_dw_meson.c index 07da9fa5..f9537979 100644 --- a/drivers/pci/pcie_dw_meson.c +++ b/drivers/pci/pcie_dw_meson.c @@ -337,15 +337,15 @@ static int meson_pcie_parse_dt(struct udevice *dev) struct meson_pcie *priv = dev_get_priv(dev); int ret;
- priv->dw.dbi_base = (void *)dev_read_addr_index(dev, 0); + priv->dw.dbi_base = dev_read_addr_index_ptr(dev, 0); if (!priv->dw.dbi_base) - return -ENODEV; + return -EINVAL;
dev_dbg(dev, "ELBI address is 0x%p\n", priv->dw.dbi_base);
- priv->meson_cfg_base = (void *)dev_read_addr_index(dev, 1); + priv->meson_cfg_base = dev_read_addr_index_ptr(dev, 1); if (!priv->meson_cfg_base) - return -ENODEV; + return -EINVAL;
dev_dbg(dev, "CFG address is 0x%p\n", priv->meson_cfg_base);
diff --git a/drivers/pci/pcie_dw_rockchip.c b/drivers/pci/pcie_dw_rockchip.c index 9322e735..624ca1cb 100644 --- a/drivers/pci/pcie_dw_rockchip.c +++ b/drivers/pci/pcie_dw_rockchip.c @@ -353,15 +353,15 @@ static int rockchip_pcie_parse_dt(struct udevice *dev) struct rk_pcie *priv = dev_get_priv(dev); int ret;
dev_dbg(dev, "DBI address is 0x%p\n", priv->dw.dbi_base);
- priv->apb_base = (void *)dev_read_addr_index(dev, 1); + priv->apb_base = dev_read_addr_index_ptr(dev, 1); if (!priv->apb_base) - return -ENODEV; + return -EINVAL;
dev_dbg(dev, "APB address is 0x%p\n", priv->apb_base);
diff --git a/drivers/watchdog/sbsa_gwdt.c b/drivers/watchdog/sbsa_gwdt.c index f43cd3fd..96d04665 100644 --- a/drivers/watchdog/sbsa_gwdt.c +++ b/drivers/watchdog/sbsa_gwdt.c @@ -98,13 +98,13 @@ static int sbsa_gwdt_of_to_plat(struct udevice *dev) { struct sbsa_gwdt_priv *priv = dev_get_priv(dev);
- priv->reg_control = (void __iomem *)dev_read_addr_index(dev, 0); - if (IS_ERR(priv->reg_control)) - return PTR_ERR(priv->reg_control); + priv->reg_control = dev_read_addr_index_ptr(dev, 0); + if (!priv->reg_control) + return -EINVAL;
- priv->reg_refresh = (void __iomem *)dev_read_addr_index(dev, 1); - if (IS_ERR(priv->reg_refresh)) - return PTR_ERR(priv->reg_refresh); + priv->reg_refresh = dev_read_addr_index_ptr(dev, 1); + if (!priv->reg_refresh) + return -EINVAL;
Hi Johan,
Why is that? It seems quite inefficient.
Regards, SImon
On 3/6/23 19:20, Simon Glass wrote:
Hi Johan,
1: === Because the device tree does describes more then just only the internal io/mem range. When a NAND chip is connected it must be able to describe partitions far beyond that 32bit range. This change only changes the PARSE capacity defined by fdt_addr_t and fdt_size_t and not the phys_addr_t and phys_size_t. Most drivers make a little mess when taking a DT reg value and then trying to make it fit in a structure of multiple registers with various offsets. Fixing all of that is beyond my capacity/this serie and more a MAINTAINER task.
https://elixir.bootlin.com/u-boot/latest/source/drivers/mtd/mtdpart.c#L933
struct mtd_partition { const char *name; /* identifier string */ uint64_t size; /* partition size */ uint64_t offset; /* offset within the master MTD space */ uint32_t mask_flags; /* master MTD flags to mask out for this partition */ struct nand_ecclayout *ecclayout; /* out of band layout for this partition (NAND only) */ };
int add_mtd_partitions_of(struct mtd_info *master) struct mtd_partition part = { 0 }; fdt_addr_t offset; fdt_size_t size;
[..] part.offset = offset; part.size = size;
While the mtd_partition structure is ready with uint64_t size all the parse functions that export this reg value were typedef to a 32bit value.
=== Given mk808 rk3066a with NAND:
[ 38.750789] nand: Hynix H27UCG8T2ATR-BC 64G 3.3V 8-bit [ 38.756650] nand: 8192 MiB, MLC, erase size: 2048 KiB, page size: 8192, OOB size: 640
=== BEFORE:
List of MTD devices: * nand0 - type: MLC NAND flash - block size: 0x200000 bytes - min I/O: 0x2000 bytes - OOB size: 640 bytes - OOB available: 4294967290 bytes - ECC strength: 40 bits - ECC step size: 1024 bytes - bitflip threshold: 30 bits - 0x000000000000-0x000200000000 : "nand0" - 0x000000400000-0x000000600000 : "boot-blk-0" - 0x000000600000-0x000000800000 : "boot-blk-1" - 0x000000800000-0x000000a00000 : "boot-blk-2" - 0x000000a00000-0x000000c00000 : "boot-blk-3" - 0x000000c00000-0x000000e00000 : "boot-blk-4" - 0x000001000000-0x0000fe000000 : "rootfs" - 0x0000fe000000-0x000100000000 : "bbt"
# This output is corrupted.
=== AFTER:
List of MTD devices: * nand0 - type: MLC NAND flash - block size: 0x200000 bytes - min I/O: 0x2000 bytes - OOB size: 640 bytes - OOB available: 4294967290 bytes - ECC strength: 40 bits - ECC step size: 1024 bytes - bitflip threshold: 30 bits - 0x000000000000-0x000200000000 : "nand0" - 0x000000400000-0x000000600000 : "boot-blk-0" - 0x000000600000-0x000000800000 : "boot-blk-1" - 0x000000800000-0x000000a00000 : "boot-blk-2" - 0x000000a00000-0x000000c00000 : "boot-blk-3" - 0x000000c00000-0x000000e00000 : "boot-blk-4" - 0x000001000000-0x0001fe000000 : "rootfs" - 0x0001fe000000-0x000200000000 : "bbt" === Example: partitions { compatible = "fixed-partitions"; #address-cells = <2>; #size-cells = <2>;
partition@400000 { reg = <0x0 0x00400000 0x0 0x00200000>; label = "boot-blk-0"; };
partition@600000 { reg = <0x0 0x00600000 0x0 0x00200000>; label = "boot-blk-1"; };
partition@800000 { reg = <0x0 0x00800000 0x0 0x00200000>; label = "boot-blk-2"; };
partition@a00000 { reg = <0x0 0x00a00000 0x0 0x00200000>; label = "boot-blk-3"; };
partition@c00000 { reg = <0x0 0x00c00000 0x0 0x00200000>; label = "boot-blk-4"; };
partition@1000000 { reg = <0x0 0x01000000 0x1 0xfd000000>; label = "rootfs"; };
partition@1fe000000 { reg = <0x1 0xfe000000 0x0 0x02000000>; label = "bbt"; }; }; ===
2: As a side effect Rockchip rk3288 with 32bit reg should be able to parse 64bit size device tree synced from Linux. (No need to maintain simply copy and paste) How ever popmetal-rk3288 and phycore-rk3288 must be changed to use TPL/SPL to fit in size again. (Could someone finally make some progress in making these boards future proof? And could Simon Glass make/help with rk3288 video/mipi/lvds/hdmi Uboot drivers for work with Linux nodes?) (This seems to work only on Google boards that nobody has, but it blocks all progress for the rest)
Regards, SImon
Hi Johan,
Hi Johan,
1:
=== BEFORE:
- nand0
=== AFTER:
- nand0
partition@400000 { reg = <0x0 0x00400000 0x0 0x00200000>; label = "boot-blk-0"; }; partition@600000 { reg = <0x0 0x00600000 0x0 0x00200000>; label = "boot-blk-1"; }; partition@800000 { reg = <0x0 0x00800000 0x0 0x00200000>; label = "boot-blk-2"; }; partition@a00000 { reg = <0x0 0x00a00000 0x0 0x00200000>; label = "boot-blk-3"; }; partition@c00000 { reg = <0x0 0x00c00000 0x0 0x00200000>; label = "boot-blk-4"; }; partition@1000000 { reg = <0x0 0x01000000 0x1 0xfd000000>; label = "rootfs"; }; partition@1fe000000 { reg = <0x1 0xfe000000 0x0 0x02000000>; label = "bbt"; }; };
OK I think I understand. I had thought that fdt_addr_t was changing to 64-bits on 32-bit boards, but I misunderstood. I checked your series and it is still 32-bit.
Yes I can, but unfortunately my lab is broken due to a servod update. I need to spend some time to get it running again and likely can't even start that for another 5 weeks.
If you'd like to do some patches I can test it then. Otherwise when I get the lab going I can take a look.
Hi Johan,
On Fri, 10 Mar 2023 at 17:37, Simon Glass sjg@chromium.org wrote:
Hi Johan,
Hi Johan,
1:
=== BEFORE:
- nand0
=== AFTER:
- nand0
Actually I was able to hack it into life so can test bob and jerry if you'd like to send some patches. I had a bit of a look at it and it seems that rk3288 is wildly different from upstream Linux at present.
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so use dev_read_addr_ptr instead of the dev_read_addr function in the various files in the drivers directory that cast to a pointer.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changed V5: rebase fix typo fix more files --- arch/arm/mach-mvebu/system-controller.c | 4 ++-- doc/develop/driver-model/livetree.rst | 2 +- drivers/ata/dwc_ahsata.c | 2 +- drivers/cache/cache-l2x0.c | 2 +- drivers/cache/cache-v5l2.c | 2 +- drivers/gpio/mscc_sgpio.c | 2 +- drivers/gpio/tegra_gpio.c | 4 ++-- drivers/gpio/xilinx_gpio.c | 2 +- drivers/i2c/i2c-cdns.c | 4 ++-- drivers/i2c/tegra_i2c.c | 4 ++-- drivers/mmc/am654_sdhci.c | 2 +- drivers/mmc/davinci_mmc.c | 2 +- drivers/mmc/piton_mmc.c | 2 +- drivers/mmc/tegra_mmc.c | 2 +- drivers/mmc/zynq_sdhci.c | 6 +++--- drivers/mtd/nand/raw/arasan_nfc.c | 2 +- drivers/mtd/nand/raw/cortina_nand.c | 2 +- drivers/mtd/nand/raw/mxic_nand.c | 2 +- drivers/mtd/nand/raw/tegra_nand.c | 2 +- drivers/mtd/nand/raw/zynq_nand.c | 2 +- drivers/net/mvmdio.c | 2 +- drivers/net/qe/dm_qe_uec_phy.c | 2 +- drivers/pci/pci-aardvark.c | 4 ++-- drivers/phy/allwinner/phy-sun50i-usb3.c | 6 +++--- drivers/phy/qcom/phy-qcom-usb-hs-28nm.c | 4 ++-- drivers/phy/qcom/phy-qcom-usb-ss.c | 4 ++-- drivers/phy/rockchip/phy-rockchip-snps-pcie3.c | 4 ++-- drivers/phy/rockchip/phy-rockchip-typec.c | 6 +++--- drivers/pwm/tegra_pwm.c | 2 +- drivers/serial/serial_zynq.c | 6 +++--- drivers/spi/mpc8xxx_spi.c | 2 +- drivers/spi/mscc_bb_spi.c | 2 +- drivers/spi/sh_qspi.c | 2 +- drivers/spi/spi-mxic.c | 2 +- drivers/spi/xilinx_spi.c | 2 +- drivers/ufs/ufs.c | 2 +- drivers/usb/host/ehci-tegra.c | 2 +- drivers/video/dw_mipi_dsi.c | 4 ++-- drivers/video/rockchip/rk_vop.c | 2 +- drivers/video/stm32/stm32_dsi.c | 4 ++-- drivers/video/stm32/stm32_ltdc.c | 4 ++-- drivers/video/tegra124/display.c | 2 +- drivers/video/tegra124/sor.c | 6 +++--- drivers/video/ti/tilcdc.c | 4 ++-- drivers/watchdog/cdns_wdt.c | 6 +++--- drivers/watchdog/sp805_wdt.c | 6 +++--- drivers/watchdog/xilinx_tb_wdt.c | 6 +++--- 47 files changed, 75 insertions(+), 75 deletions(-)
diff --git a/arch/arm/mach-mvebu/system-controller.c b/arch/arm/mach-mvebu/system-controller.c index e90aff0c..7cdde11c 100644 --- a/arch/arm/mach-mvebu/system-controller.c +++ b/arch/arm/mach-mvebu/system-controller.c @@ -71,8 +71,8 @@ static int mvebu_reset_of_to_plat(struct udevice *dev) { struct mvebu_reset_data *data = dev_get_priv(dev);
- data->base = (void *)dev_read_addr(dev); - if ((fdt_addr_t)data->base == FDT_ADDR_T_NONE) + data->base = dev_read_addr_ptr(dev); + if (!data->base) return -EINVAL;
return 0; diff --git a/doc/develop/driver-model/livetree.rst b/doc/develop/driver-model/livetree.rst index 579eef5c..20055d55 100644 --- a/doc/develop/driver-model/livetree.rst +++ b/doc/develop/driver-model/livetree.rst @@ -103,7 +103,7 @@ The new code is:
struct udevice *bus;
- i2c_bus->regs = (struct i2c_ctlr *)dev_read_addr(dev); + i2c_bus->regs = dev_read_addr_ptr(dev); plat->frequency = dev_read_u32_default(bus, "spi-max-frequency", 500000);
The dev_read_...() interface is more convenient and works with both the diff --git a/drivers/ata/dwc_ahsata.c b/drivers/ata/dwc_ahsata.c index 167b5a39..6a4d861b 100644 --- a/drivers/ata/dwc_ahsata.c +++ b/drivers/ata/dwc_ahsata.c @@ -912,7 +912,7 @@ int dwc_ahsata_probe(struct udevice *dev) #endif uc_priv->host_flags = ATA_FLAG_SATA | ATA_FLAG_NO_LEGACY | ATA_FLAG_MMIO | ATA_FLAG_PIO_DMA | ATA_FLAG_NO_ATAPI; - uc_priv->mmio_base = (void __iomem *)dev_read_addr(dev); + uc_priv->mmio_base = dev_read_addr_ptr(dev);
/* initialize adapter */ ret = ahci_host_init(uc_priv); diff --git a/drivers/cache/cache-l2x0.c b/drivers/cache/cache-l2x0.c index a1556fbf..560f4c94 100644 --- a/drivers/cache/cache-l2x0.c +++ b/drivers/cache/cache-l2x0.c @@ -13,7 +13,7 @@ static void l2c310_of_parse_and_init(struct udevice *dev) { u32 tag[3] = { 0, 0, 0 }; u32 saved_reg, prefetch; - struct pl310_regs *regs = (struct pl310_regs *)dev_read_addr(dev); + struct pl310_regs *regs = dev_read_addr_ptr(dev);
/* Disable the L2 Cache */ clrbits_le32(®s->pl310_ctrl, L2X0_CTRL_EN); diff --git a/drivers/cache/cache-v5l2.c b/drivers/cache/cache-v5l2.c index eda07d3f..fe3f9392 100644 --- a/drivers/cache/cache-v5l2.c +++ b/drivers/cache/cache-v5l2.c @@ -119,7 +119,7 @@ static int v5l2_of_to_plat(struct udevice *dev) struct v5l2_plat *plat = dev_get_plat(dev); struct l2cache *regs;
- regs = (struct l2cache *)(uintptr_t)dev_read_addr(dev); + regs = dev_read_addr_ptr(dev); plat->regs = regs;
plat->iprefetch = -EINVAL; diff --git a/drivers/gpio/mscc_sgpio.c b/drivers/gpio/mscc_sgpio.c index 1cbcc434..c97e4400 100644 --- a/drivers/gpio/mscc_sgpio.c +++ b/drivers/gpio/mscc_sgpio.c @@ -232,7 +232,7 @@ static int mscc_sgpio_probe(struct udevice *dev) debug("probe: gpios = %d, bit-count = %d\n", uc_priv->gpio_count, priv->bitcount);
- priv->regs = (u32 __iomem *)dev_read_addr(dev); + priv->regs = dev_read_addr_ptr(dev); uc_priv->bank_name = "sgpio";
sgpio_clrsetbits(priv, REG_SIO_CONFIG, 0, diff --git a/drivers/gpio/tegra_gpio.c b/drivers/gpio/tegra_gpio.c index 4291e496..55105f28 100644 --- a/drivers/gpio/tegra_gpio.c +++ b/drivers/gpio/tegra_gpio.c @@ -339,8 +339,8 @@ static int gpio_tegra_bind(struct udevice *parent) if (len < 0) return len; bank_count = len / 3 / sizeof(u32); - ctlr = (struct gpio_ctlr *)dev_read_addr(parent); - if ((ulong)ctlr == FDT_ADDR_T_NONE) + ctlr = dev_read_addr_ptr(parent); + if (!ctlr) return -EINVAL; } #endif diff --git a/drivers/gpio/xilinx_gpio.c b/drivers/gpio/xilinx_gpio.c index 510838d2..fa8d630b 100644 --- a/drivers/gpio/xilinx_gpio.c +++ b/drivers/gpio/xilinx_gpio.c @@ -268,7 +268,7 @@ static int xilinx_gpio_of_to_plat(struct udevice *dev) struct xilinx_gpio_plat *plat = dev_get_plat(dev); int is_dual;
- plat->regs = (struct gpio_regs *)dev_read_addr(dev); + plat->regs = dev_read_addr_ptr(dev);
plat->bank_max[0] = dev_read_u32_default(dev, "xlnx,gpio-width", 0); plat->bank_input[0] = dev_read_u32_default(dev, "xlnx,all-inputs", 0); diff --git a/drivers/i2c/i2c-cdns.c b/drivers/i2c/i2c-cdns.c index c1672ca1..1a892072 100644 --- a/drivers/i2c/i2c-cdns.c +++ b/drivers/i2c/i2c-cdns.c @@ -479,9 +479,9 @@ static int cdns_i2c_of_to_plat(struct udevice *dev) struct clk clk; int ret;
- i2c_bus->regs = (struct cdns_i2c_regs *)dev_read_addr(dev); + i2c_bus->regs = dev_read_addr_ptr(dev); if (!i2c_bus->regs) - return -ENOMEM; + return -EINVAL;
if (pdata) i2c_bus->quirks = pdata->quirks; diff --git a/drivers/i2c/tegra_i2c.c b/drivers/i2c/tegra_i2c.c index 2394e9d0..5864a1ad 100644 --- a/drivers/i2c/tegra_i2c.c +++ b/drivers/i2c/tegra_i2c.c @@ -364,8 +364,8 @@ static int tegra_i2c_probe(struct udevice *dev)
i2c_bus->id = dev_seq(dev); i2c_bus->type = dev_get_driver_data(dev); - i2c_bus->regs = (struct i2c_ctlr *)dev_read_addr(dev); - if ((ulong)i2c_bus->regs == FDT_ADDR_T_NONE) { + i2c_bus->regs = dev_read_addr_ptr(dev); + if (!i2c_bus->regs) { debug("%s: Cannot get regs address\n", __func__); return -EINVAL; } diff --git a/drivers/mmc/am654_sdhci.c b/drivers/mmc/am654_sdhci.c index 42a61343..fd667aea 100644 --- a/drivers/mmc/am654_sdhci.c +++ b/drivers/mmc/am654_sdhci.c @@ -584,7 +584,7 @@ static int am654_sdhci_of_to_plat(struct udevice *dev) int ret;
host->name = dev->name; - host->ioaddr = (void *)dev_read_addr(dev); + host->ioaddr = dev_read_addr_ptr(dev); plat->non_removable = dev_read_bool(dev, "non-removable");
if (plat->flags & DLL_PRESENT) { diff --git a/drivers/mmc/davinci_mmc.c b/drivers/mmc/davinci_mmc.c index 05ca3612..3a3d23ae 100644 --- a/drivers/mmc/davinci_mmc.c +++ b/drivers/mmc/davinci_mmc.c @@ -506,7 +506,7 @@ static int davinci_mmc_of_to_plat(struct udevice *dev) struct davinci_mmc_plat *plat = dev_get_plat(dev); struct mmc_config *cfg = &plat->cfg;
- plat->reg_base = (struct davinci_mmc_regs *)dev_read_addr(dev); + plat->reg_base = dev_read_addr_ptr(dev); cfg->f_min = 200000; cfg->f_max = 25000000; cfg->voltages = MMC_VDD_32_33 | MMC_VDD_33_34, diff --git a/drivers/mmc/piton_mmc.c b/drivers/mmc/piton_mmc.c index 9f5da6d6..a330bbf8 100644 --- a/drivers/mmc/piton_mmc.c +++ b/drivers/mmc/piton_mmc.c @@ -74,7 +74,7 @@ static int piton_mmc_ofdata_to_platdata(struct udevice *dev) struct mmc *mmc; struct blk_desc *bdesc;
- priv->base_addr = (void *)dev_read_addr(dev); + priv->base_addr = dev_read_addr_ptr(dev); cfg = &plat->cfg; cfg->name = "PITON MMC"; cfg->host_caps = MMC_MODE_8BIT; diff --git a/drivers/mmc/tegra_mmc.c b/drivers/mmc/tegra_mmc.c index 760eca40..f76fee3e 100644 --- a/drivers/mmc/tegra_mmc.c +++ b/drivers/mmc/tegra_mmc.c @@ -708,7 +708,7 @@ static int tegra_mmc_probe(struct udevice *dev)
cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
- priv->reg = (void *)dev_read_addr(dev); + priv->reg = dev_read_addr_ptr(dev);
ret = reset_get_by_name(dev, "sdhci", &priv->reset_ctl); if (ret) { diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 91e309d2..6e22aef4 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -1195,9 +1195,9 @@ static int arasan_sdhci_of_to_plat(struct udevice *dev) arasan_dt_parse_clk_phases(dev); #endif
- priv->host->ioaddr = (void *)dev_read_addr(dev); - if (IS_ERR(priv->host->ioaddr)) - return PTR_ERR(priv->host->ioaddr); + priv->host->ioaddr = dev_read_addr_ptr(dev); + if (!priv->host->ioaddr) + return -EINVAL;
priv->bank = dev_read_u32_default(dev, "xlnx,mio-bank", 0); priv->no_1p8 = dev_read_bool(dev, "no-1-8-v"); diff --git a/drivers/mtd/nand/raw/arasan_nfc.c b/drivers/mtd/nand/raw/arasan_nfc.c index 4621bfb0..d5726351 100644 --- a/drivers/mtd/nand/raw/arasan_nfc.c +++ b/drivers/mtd/nand/raw/arasan_nfc.c @@ -1232,7 +1232,7 @@ static int arasan_probe(struct udevice *dev) struct mtd_info *mtd; int err = -1;
- info->reg = (struct nand_regs *)dev_read_addr(dev); + info->reg = dev_read_addr_ptr(dev); mtd = nand_to_mtd(nand_chip); nand_set_controller_data(nand_chip, &arasan->nand_ctrl);
diff --git a/drivers/mtd/nand/raw/cortina_nand.c b/drivers/mtd/nand/raw/cortina_nand.c index 8de35731..b7be6602 100644 --- a/drivers/mtd/nand/raw/cortina_nand.c +++ b/drivers/mtd/nand/raw/cortina_nand.c @@ -1174,7 +1174,7 @@ static int fdt_decode_nand(struct udevice *dev, struct nand_drv *info) { int ecc_strength;
- info->reg = (struct nand_ctlr *)dev_read_addr(dev); + info->reg = dev_read_addr_ptr(dev); info->dma_glb = dev_read_addr_index_ptr(dev, 1); info->dma_nand = dev_read_addr_index_ptr(dev, 2); info->config.enabled = dev_read_enabled(dev); diff --git a/drivers/mtd/nand/raw/mxic_nand.c b/drivers/mtd/nand/raw/mxic_nand.c index e54df461..6abdc24b 100644 --- a/drivers/mtd/nand/raw/mxic_nand.c +++ b/drivers/mtd/nand/raw/mxic_nand.c @@ -538,7 +538,7 @@ static int mxic_nfc_probe(struct udevice *dev) ofnode child; int err;
- nfc->regs = (void *)dev_read_addr(dev); + nfc->regs = dev_read_addr_ptr(dev);
nfc->send_clk = devm_clk_get(dev, "send"); if (IS_ERR(nfc->send_clk)) diff --git a/drivers/mtd/nand/raw/tegra_nand.c b/drivers/mtd/nand/raw/tegra_nand.c index d2801d48..139d978a 100644 --- a/drivers/mtd/nand/raw/tegra_nand.c +++ b/drivers/mtd/nand/raw/tegra_nand.c @@ -906,7 +906,7 @@ static int fdt_decode_nand(struct udevice *dev, struct fdt_nand *config) { int err;
- config->reg = (struct nand_ctlr *)dev_read_addr(dev); + config->reg = dev_read_addr_ptr(dev); config->enabled = dev_read_enabled(dev); config->width = dev_read_u32_default(dev, "nvidia,nand-width", 8); err = gpio_request_by_name(dev, "nvidia,wp-gpios", 0, &config->wp_gpio, diff --git a/drivers/mtd/nand/raw/zynq_nand.c b/drivers/mtd/nand/raw/zynq_nand.c index 14cb2ba7..9e3ee741 100644 --- a/drivers/mtd/nand/raw/zynq_nand.c +++ b/drivers/mtd/nand/raw/zynq_nand.c @@ -1085,7 +1085,7 @@ static int zynq_nand_probe(struct udevice *dev) int ondie_ecc_enabled = 0; int is_16bit_bw;
- smc->reg = (struct zynq_nand_smc_regs *)dev_read_addr(dev); + smc->reg = dev_read_addr_ptr(dev); of_nand = dev_read_subnode(dev, "nand-controller@0,0"); if (!ofnode_valid(of_nand)) { of_nand = dev_read_subnode(dev, "flash@e1000000"); diff --git a/drivers/net/mvmdio.c b/drivers/net/mvmdio.c index 6fb8a985..c0ebcdb1 100644 --- a/drivers/net/mvmdio.c +++ b/drivers/net/mvmdio.c @@ -208,7 +208,7 @@ static int mvmdio_probe(struct udevice *dev) { struct mvmdio_priv *priv = dev_get_priv(dev);
- priv->mdio_base = (void *)dev_read_addr(dev); + priv->mdio_base = dev_read_addr_ptr(dev); priv->type = (enum mvmdio_bus_type)dev_get_driver_data(dev);
return 0; diff --git a/drivers/net/qe/dm_qe_uec_phy.c b/drivers/net/qe/dm_qe_uec_phy.c index 038b8104..a0bcc8d3 100644 --- a/drivers/net/qe/dm_qe_uec_phy.c +++ b/drivers/net/qe/dm_qe_uec_phy.c @@ -97,7 +97,7 @@ static int qe_uec_mdio_probe(struct udevice *dev) u32 num = 0; int ret = -ENODEV;
- priv->base = (struct ucc_mii_mng *)dev_read_addr(dev); + priv->base = dev_read_addr_ptr(dev); base = (fdt_size_t)priv->base;
/* diff --git a/drivers/pci/pci-aardvark.c b/drivers/pci/pci-aardvark.c index b0fc9caa..af0e55cd 100644 --- a/drivers/pci/pci-aardvark.c +++ b/drivers/pci/pci-aardvark.c @@ -983,8 +983,8 @@ static int pcie_advk_of_to_plat(struct udevice *dev) struct pcie_advk *pcie = dev_get_priv(dev);
/* Get the register base address */ - pcie->base = (void *)dev_read_addr(dev); - if ((fdt_addr_t)pcie->base == FDT_ADDR_T_NONE) + pcie->base = dev_read_addr_ptr(dev); + if (!pcie->base) return -EINVAL;
return 0; diff --git a/drivers/phy/allwinner/phy-sun50i-usb3.c b/drivers/phy/allwinner/phy-sun50i-usb3.c index e5a3d2d9..609d9d4e 100644 --- a/drivers/phy/allwinner/phy-sun50i-usb3.c +++ b/drivers/phy/allwinner/phy-sun50i-usb3.c @@ -149,9 +149,9 @@ static int sun50i_usb3_phy_probe(struct udevice *dev) return ret; }
- priv->regs = (void __iomem *)dev_read_addr(dev); - if (IS_ERR(priv->regs)) - return PTR_ERR(priv->regs); + priv->regs = dev_read_addr_ptr(dev); + if (!priv->regs) + return -EINVAL;
return 0; } diff --git a/drivers/phy/qcom/phy-qcom-usb-hs-28nm.c b/drivers/phy/qcom/phy-qcom-usb-hs-28nm.c index 14c3d839..05a9a2cf 100644 --- a/drivers/phy/qcom/phy-qcom-usb-hs-28nm.c +++ b/drivers/phy/qcom/phy-qcom-usb-hs-28nm.c @@ -184,8 +184,8 @@ static int hsphy_probe(struct udevice *dev) struct hsphy_priv *priv = dev_get_priv(dev); int ret;
- priv->base = (void *)dev_read_addr(dev); - if ((ulong)priv->base == FDT_ADDR_T_NONE) + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) return -EINVAL;
ret = reset_get_by_name(dev, "phy", &priv->phy_rst); diff --git a/drivers/phy/qcom/phy-qcom-usb-ss.c b/drivers/phy/qcom/phy-qcom-usb-ss.c index 4e816879..1b03a3c4 100644 --- a/drivers/phy/qcom/phy-qcom-usb-ss.c +++ b/drivers/phy/qcom/phy-qcom-usb-ss.c @@ -115,8 +115,8 @@ static int ssphy_probe(struct udevice *dev) struct ssphy_priv *priv = dev_get_priv(dev); int ret;
ret = ssphy_clk_init(dev, priv); diff --git a/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c b/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c index 5ae41fbe..66c75f98 100644 --- a/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c +++ b/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c @@ -93,8 +93,8 @@ static int rockchip_p3phy_probe(struct udevice *dev) struct udevice *syscon; int ret;
- priv->mmio = (void __iomem *)dev_read_addr(dev); - if ((fdt_addr_t)priv->mmio == FDT_ADDR_T_NONE) + priv->mmio = dev_read_addr_ptr(dev); + if (!priv->mmio) return -EINVAL;
ret = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, diff --git a/drivers/phy/rockchip/phy-rockchip-typec.c b/drivers/phy/rockchip/phy-rockchip-typec.c index ca63b856..47c69dd6 100644 --- a/drivers/phy/rockchip/phy-rockchip-typec.c +++ b/drivers/phy/rockchip/phy-rockchip-typec.c @@ -674,9 +674,9 @@ static int rockchip_tcphy_probe(struct udevice *dev) unsigned int reg; int index, ret;
- priv->reg_base = (void __iomem *)dev_read_addr(dev); - if (IS_ERR(priv->reg_base)) - return PTR_ERR(priv->reg_base); + priv->reg_base = dev_read_addr_ptr(dev); + if (!priv->reg_base) + return -EINVAL;
ret = dev_read_u32_index(dev, "reg", 1, ®); if (ret) { diff --git a/drivers/pwm/tegra_pwm.c b/drivers/pwm/tegra_pwm.c index 95fc2645..87034706 100644 --- a/drivers/pwm/tegra_pwm.c +++ b/drivers/pwm/tegra_pwm.c @@ -59,7 +59,7 @@ static int tegra_pwm_of_to_plat(struct udevice *dev) { struct tegra_pwm_priv *priv = dev_get_priv(dev);
- priv->regs = (struct pwm_ctlr *)dev_read_addr(dev); + priv->regs = dev_read_addr_ptr(dev);
return 0; } diff --git a/drivers/serial/serial_zynq.c b/drivers/serial/serial_zynq.c index 9bb9b7d3..1847d1f6 100644 --- a/drivers/serial/serial_zynq.c +++ b/drivers/serial/serial_zynq.c @@ -259,9 +259,9 @@ static int zynq_serial_of_to_plat(struct udevice *dev) { struct zynq_uart_plat *plat = dev_get_plat(dev);
- plat->regs = (struct uart_zynq *)dev_read_addr(dev); - if (IS_ERR(plat->regs)) - return PTR_ERR(plat->regs); + plat->regs = dev_read_addr_ptr(dev); + if (!plat->regs) + return -EINVAL;
return 0; } diff --git a/drivers/spi/mpc8xxx_spi.c b/drivers/spi/mpc8xxx_spi.c index 6869d60d..3990f003 100644 --- a/drivers/spi/mpc8xxx_spi.c +++ b/drivers/spi/mpc8xxx_spi.c @@ -54,7 +54,7 @@ static int mpc8xxx_spi_of_to_plat(struct udevice *dev) struct clk clk; int ret;
- priv->spi = (spi8xxx_t *)dev_read_addr(dev); + priv->spi = dev_read_addr_ptr(dev);
ret = gpio_request_list_by_name(dev, "gpios", priv->gpios, ARRAY_SIZE(priv->gpios), GPIOD_IS_OUT | GPIOD_ACTIVE_LOW); diff --git a/drivers/spi/mscc_bb_spi.c b/drivers/spi/mscc_bb_spi.c index 2a01ea06..95bea0da 100644 --- a/drivers/spi/mscc_bb_spi.c +++ b/drivers/spi/mscc_bb_spi.c @@ -217,7 +217,7 @@ static int mscc_bb_spi_probe(struct udevice *bus)
debug("%s: loaded, priv %p\n", __func__, priv);
- priv->regs = (void __iomem *)dev_read_addr(bus); + priv->regs = dev_read_addr_ptr(bus);
priv->deactivate_delay_us = dev_read_u32_default(bus, "spi-deactivate-delay", 0); diff --git a/drivers/spi/sh_qspi.c b/drivers/spi/sh_qspi.c index 861423be..7dd1fe75 100644 --- a/drivers/spi/sh_qspi.c +++ b/drivers/spi/sh_qspi.c @@ -334,7 +334,7 @@ static int sh_qspi_of_to_plat(struct udevice *dev) { struct sh_qspi_slave *plat = dev_get_plat(dev);
- plat->regs = (struct sh_qspi_regs *)dev_read_addr(dev); + plat->regs = dev_read_addr_ptr(dev);
return 0; } diff --git a/drivers/spi/spi-mxic.c b/drivers/spi/spi-mxic.c index 6aae9f79..f663b9dc 100644 --- a/drivers/spi/spi-mxic.c +++ b/drivers/spi/spi-mxic.c @@ -508,7 +508,7 @@ static int mxic_spi_probe(struct udevice *bus) { struct mxic_spi_priv *priv = dev_get_priv(bus);
- priv->regs = (void *)dev_read_addr(bus); + priv->regs = dev_read_addr_ptr(bus);
priv->send_clk = devm_clk_get(bus, "send_clk"); if (IS_ERR(priv->send_clk)) diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c index 4e9115da..7ff6d6e1 100644 --- a/drivers/spi/xilinx_spi.c +++ b/drivers/spi/xilinx_spi.c @@ -114,7 +114,7 @@ static int xilinx_spi_probe(struct udevice *bus) struct xilinx_spi_priv *priv = dev_get_priv(bus); struct xilinx_spi_regs *regs = priv->regs;
- priv->regs = (struct xilinx_spi_regs *)dev_read_addr(bus); + priv->regs = dev_read_addr_ptr(bus);
priv->fifo_depth = dev_read_u32_default(bus, "fifo-size", 0);
diff --git a/drivers/ufs/ufs.c b/drivers/ufs/ufs.c index 13e730b8..8dd29edd 100644 --- a/drivers/ufs/ufs.c +++ b/drivers/ufs/ufs.c @@ -1880,7 +1880,7 @@ int ufshcd_probe(struct udevice *ufs_dev, struct ufs_hba_ops *hba_ops)
hba->dev = ufs_dev; hba->ops = hba_ops; - hba->mmio_base = (void *)dev_read_addr(ufs_dev); + hba->mmio_base = dev_read_addr_ptr(ufs_dev);
/* Set descriptor lengths to specification defaults */ ufshcd_def_desc_sizes(hba); diff --git a/drivers/usb/host/ehci-tegra.c b/drivers/usb/host/ehci-tegra.c index 76562bd7..2cf16256 100644 --- a/drivers/usb/host/ehci-tegra.c +++ b/drivers/usb/host/ehci-tegra.c @@ -723,7 +723,7 @@ static int fdt_decode_usb(struct udevice *dev, struct fdt_usb *config) { const char *phy, *mode;
- config->reg = (struct usb_ctlr *)dev_read_addr(dev); + config->reg = dev_read_addr_ptr(dev); debug("reg=%p\n", config->reg); mode = dev_read_string(dev, "dr_mode"); if (mode) { diff --git a/drivers/video/dw_mipi_dsi.c b/drivers/video/dw_mipi_dsi.c index 6d9c5a94..6146a0f0 100644 --- a/drivers/video/dw_mipi_dsi.c +++ b/drivers/video/dw_mipi_dsi.c @@ -800,8 +800,8 @@ static int dw_mipi_dsi_init(struct udevice *dev, dsi->dsi_host.ops = &dw_mipi_dsi_host_ops; device->host = &dsi->dsi_host;
- dsi->base = (void *)dev_read_addr(device->dev); - if ((fdt_addr_t)dsi->base == FDT_ADDR_T_NONE) { + dsi->base = dev_read_addr_ptr(device->dev); + if (!dsi->base) { dev_err(device->dev, "dsi dt register address error\n"); return -EINVAL; } diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_vop.c index bc98ab68..e54bb277 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -446,7 +446,7 @@ int rk_vop_probe(struct udevice *dev) efi_add_memory_map(plat->base, plat->size, EFI_RESERVED_MEMORY_TYPE); #endif
- priv->regs = (struct rk3288_vop *)dev_read_addr(dev); + priv->regs = dev_read_addr_ptr(dev);
/* * Try all the ports until we find one that works. In practice this diff --git a/drivers/video/stm32/stm32_dsi.c b/drivers/video/stm32/stm32_dsi.c index e6347bb8..a7420fb2 100644 --- a/drivers/video/stm32/stm32_dsi.c +++ b/drivers/video/stm32/stm32_dsi.c @@ -427,8 +427,8 @@ static int stm32_dsi_probe(struct udevice *dev)
device->dev = dev;
- priv->base = (void *)dev_read_addr(dev); - if ((fdt_addr_t)priv->base == FDT_ADDR_T_NONE) { + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) { dev_err(dev, "dsi dt register address error\n"); return -EINVAL; } diff --git a/drivers/video/stm32/stm32_ltdc.c b/drivers/video/stm32/stm32_ltdc.c index 58b6434a..f48badc5 100644 --- a/drivers/video/stm32/stm32_ltdc.c +++ b/drivers/video/stm32/stm32_ltdc.c @@ -507,8 +507,8 @@ static int stm32_ltdc_probe(struct udevice *dev) ulong rate; int ret;
- priv->regs = (void *)dev_read_addr(dev); - if ((fdt_addr_t)priv->regs == FDT_ADDR_T_NONE) { + priv->regs = dev_read_addr_ptr(dev); + if (!priv->regs) { dev_err(dev, "ltdc dt register address error\n"); return -EINVAL; } diff --git a/drivers/video/tegra124/display.c b/drivers/video/tegra124/display.c index 78ab3f99..9261cc93 100644 --- a/drivers/video/tegra124/display.c +++ b/drivers/video/tegra124/display.c @@ -361,7 +361,7 @@ static int display_init(struct udevice *dev, void *lcdbase, return ret; }
- dc_ctlr = (struct dc_ctlr *)dev_read_addr(dev); + dc_ctlr = dev_read_addr_ptr(dev); if (ofnode_decode_display_timing(dev_ofnode(dev), 0, timing)) { debug("%s: Failed to decode display timing\n", __func__); return -EINVAL; diff --git a/drivers/video/tegra124/sor.c b/drivers/video/tegra124/sor.c index ef1a2e6d..f291db3d 100644 --- a/drivers/video/tegra124/sor.c +++ b/drivers/video/tegra124/sor.c @@ -765,7 +765,7 @@ int tegra_dc_sor_attach(struct udevice *dc_dev, struct udevice *dev,
/* Use the first display controller */ debug("%s\n", __func__); - disp_ctrl = (struct dc_ctlr *)dev_read_addr(dc_dev); + disp_ctrl = dev_read_addr_ptr(dc_dev);
tegra_dc_sor_enable_dc(disp_ctrl); tegra_dc_sor_config_panel(sor, 0, link_cfg, timing); @@ -978,7 +978,7 @@ int tegra_dc_sor_detach(struct udevice *dc_dev, struct udevice *dev)
debug("%s\n", __func__); /* Use the first display controller */ - disp_ctrl = (struct dc_ctlr *)dev_read_addr(dev); + disp_ctrl = dev_read_addr_ptr(dev);
/* Sleep mode */ tegra_sor_writel(sor, SUPER_STATE1, SUPER_STATE1_ASY_HEAD_OP_SLEEP | @@ -1047,7 +1047,7 @@ static int tegra_sor_of_to_plat(struct udevice *dev) struct tegra_dc_sor_data *priv = dev_get_priv(dev); int ret;
- priv->base = (void *)dev_read_addr(dev); + priv->base = dev_read_addr_ptr(dev);
priv->pmc_base = (void *)syscon_get_first_range(TEGRA_SYSCON_PMC); if (IS_ERR(priv->pmc_base)) diff --git a/drivers/video/ti/tilcdc.c b/drivers/video/ti/tilcdc.c index 88043fc1..2734754e 100644 --- a/drivers/video/ti/tilcdc.c +++ b/drivers/video/ti/tilcdc.c @@ -387,8 +387,8 @@ static int tilcdc_of_to_plat(struct udevice *dev) { struct tilcdc_priv *priv = dev_get_priv(dev);
- priv->regs = (struct tilcdc_regs *)dev_read_addr(dev); - if ((fdt_addr_t)priv->regs == FDT_ADDR_T_NONE) { + priv->regs = dev_read_addr_ptr(dev); + if (!priv->regs) { dev_err(dev, "failed to get base address\n"); return -EINVAL; } diff --git a/drivers/watchdog/cdns_wdt.c b/drivers/watchdog/cdns_wdt.c index 6dfdd31c..743ab648 100644 --- a/drivers/watchdog/cdns_wdt.c +++ b/drivers/watchdog/cdns_wdt.c @@ -271,9 +271,9 @@ static int cdns_wdt_of_to_plat(struct udevice *dev) { struct cdns_wdt_priv *priv = dev_get_priv(dev);
- priv->regs = (struct cdns_regs *)dev_read_addr(dev); - if (IS_ERR(priv->regs)) - return PTR_ERR(priv->regs); + priv->regs = dev_read_addr_ptr(dev); + if (!priv->regs) + return -EINVAL;
priv->rst = dev_read_bool(dev, "reset-on-timeout");
diff --git a/drivers/watchdog/sp805_wdt.c b/drivers/watchdog/sp805_wdt.c index 0d6fb120..6d58fd3c 100644 --- a/drivers/watchdog/sp805_wdt.c +++ b/drivers/watchdog/sp805_wdt.c @@ -116,9 +116,9 @@ static int sp805_wdt_of_to_plat(struct udevice *dev) struct sp805_wdt_priv *priv = dev_get_priv(dev); struct clk clk;
- priv->reg = (void __iomem *)dev_read_addr(dev); - if (IS_ERR(priv->reg)) - return PTR_ERR(priv->reg); + priv->reg = dev_read_addr_ptr(dev); + if (!priv->reg) + return -EINVAL;
if (!clk_get_by_index(dev, 0, &clk)) priv->clk_rate = clk_get_rate(&clk); diff --git a/drivers/watchdog/xilinx_tb_wdt.c b/drivers/watchdog/xilinx_tb_wdt.c index 1687a459..0f9fb020 100644 --- a/drivers/watchdog/xilinx_tb_wdt.c +++ b/drivers/watchdog/xilinx_tb_wdt.c @@ -94,9 +94,9 @@ static int xlnx_wdt_of_to_plat(struct udevice *dev) { struct xlnx_wdt_plat *plat = dev_get_plat(dev);
- plat->regs = (struct watchdog_regs *)dev_read_addr(dev); - if (IS_ERR(plat->regs)) - return PTR_ERR(plat->regs); + plat->regs = dev_read_addr_ptr(dev); + if (!plat->regs) + return -EINVAL;
plat->enable_once = dev_read_u32_default(dev, "xlnx,wdt-enable-once", 0); -- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so use devfdt_get_addr_size_index_ptr instead of the devfdt_get_addr_size_index function in the various files in the drivers directory that cast to a pointer.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/pci/pcie_dw_mvebu.c | 6 +++--- drivers/spi/cadence_qspi.c | 3 +-- 2 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/drivers/pci/pcie_dw_mvebu.c b/drivers/pci/pcie_dw_mvebu.c index a0b82c78..3b2ada54 100644 --- a/drivers/pci/pcie_dw_mvebu.c +++ b/drivers/pci/pcie_dw_mvebu.c @@ -569,9 +569,9 @@ static int pcie_dw_mvebu_of_to_plat(struct udevice *dev) return -EINVAL;
/* Get the config space base address and size */ - pcie->cfg_base = (void *)devfdt_get_addr_size_index(dev, 1, - &pcie->cfg_size); - if ((fdt_addr_t)pcie->cfg_base == FDT_ADDR_T_NONE) + pcie->cfg_base = devfdt_get_addr_size_index_ptr(dev, 1, + &pcie->cfg_size); + if (!pcie->cfg_base) return -EINVAL;
return 0; diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index c7f10c50..6a52676a 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -384,8 +384,7 @@ static int cadence_spi_of_to_plat(struct udevice *bus) ofnode subnode;
plat->regbase = (void *)devfdt_get_addr_index(bus, 0); - plat->ahbbase = (void *)devfdt_get_addr_size_index(bus, 1, - &plat->ahbsize); + plat->ahbbase = devfdt_get_addr_size_index_ptr(bus, 1, &plat->ahbsize); plat->is_decoded_cs = dev_read_bool(bus, "cdns,is-decoded-cs"); plat->fifo_depth = dev_read_u32_default(bus, "cdns,fifo-depth", 128); plat->fifo_width = dev_read_u32_default(bus, "cdns,fifo-width", 4); -- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so use devfdt_get_addr_index_ptr instead of the devfdt_get_addr_index function in the various files in the drivers directory that cast to a pointer.
Changed V6: use -EINVAL on return drop cast --- drivers/clk/clk-hsdk-cgu.c | 4 ++-- drivers/ddr/altera/sdram_gen5.c | 4 ++-- drivers/mmc/xenon_sdhci.c | 2 +- drivers/net/mvpp2.c | 24 ++++++++++++------------ drivers/pci/pcie_dw_mvebu.c | 4 ++-- drivers/pci/pcie_imx.c | 4 ++-- drivers/pci/pcie_layerscape_ep.c | 8 ++++---- drivers/phy/marvell/comphy_core.c | 12 ++++++------ drivers/spi/cadence_qspi.c | 2 +- drivers/usb/musb-new/ti-musb.c | 2 +- 10 files changed, 33 insertions(+), 33 deletions(-)
diff --git a/drivers/clk/clk-hsdk-cgu.c b/drivers/clk/clk-hsdk-cgu.c index 26b0aa9a..e28543ef 100644 --- a/drivers/clk/clk-hsdk-cgu.c +++ b/drivers/clk/clk-hsdk-cgu.c @@ -753,11 +753,11 @@ static int hsdk_cgu_clk_probe(struct udevice *dev) else hsdk_clk->map = hsdk_4xd_clk_map;
- hsdk_clk->cgu_regs = (void __iomem *)devfdt_get_addr_index(dev, 0); + hsdk_clk->cgu_regs = devfdt_get_addr_index_ptr(dev, 0); if (!hsdk_clk->cgu_regs) return -EINVAL;
- hsdk_clk->creg_regs = (void __iomem *)devfdt_get_addr_index(dev, 1); + hsdk_clk->creg_regs = devfdt_get_addr_index_ptr(dev, 1); if (!hsdk_clk->creg_regs) return -EINVAL;
diff --git a/drivers/ddr/altera/sdram_gen5.c b/drivers/ddr/altera/sdram_gen5.c index 8d3ce495..34d2a278 100644 --- a/drivers/ddr/altera/sdram_gen5.c +++ b/drivers/ddr/altera/sdram_gen5.c @@ -567,9 +567,9 @@ static int altera_gen5_sdram_of_to_plat(struct udevice *dev) { struct altera_gen5_sdram_plat *plat = dev_get_plat(dev);
- plat->sdr = (struct socfpga_sdr *)devfdt_get_addr_index(dev, 0); + plat->sdr = devfdt_get_addr_index_ptr(dev, 0); if (!plat->sdr) - return -ENODEV; + return -EINVAL;
return 0; } diff --git a/drivers/mmc/xenon_sdhci.c b/drivers/mmc/xenon_sdhci.c index 2f880509..16ac84a2 100644 --- a/drivers/mmc/xenon_sdhci.c +++ b/drivers/mmc/xenon_sdhci.c @@ -537,7 +537,7 @@ static int xenon_sdhci_of_to_plat(struct udevice *dev) host->ioaddr = dev_read_addr_ptr(dev);
if (device_is_compatible(dev, "marvell,armada-3700-sdhci")) - priv->pad_ctrl_reg = (void *)devfdt_get_addr_index(dev, 1); + priv->pad_ctrl_reg = devfdt_get_addr_index_ptr(dev, 1);
name = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "marvell,pad-type", NULL); diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index 1bad50d3..a4be8497 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -5349,18 +5349,18 @@ static int mvpp2_base_probe(struct udevice *dev) }
/* Save base addresses for later use */ - priv->base = (void *)devfdt_get_addr_index(dev, 0); - if (IS_ERR(priv->base)) - return PTR_ERR(priv->base); + priv->base = devfdt_get_addr_index_ptr(dev, 0); + if (!priv->base) + return -EINVAL;
if (priv->hw_version == MVPP21) { - priv->lms_base = (void *)devfdt_get_addr_index(dev, 1); - if (IS_ERR(priv->lms_base)) - return PTR_ERR(priv->lms_base); + priv->lms_base = devfdt_get_addr_index_ptr(dev, 1); + if (!priv->lms_base) + return -EINVAL; } else { - priv->iface_base = (void *)devfdt_get_addr_index(dev, 1); - if (IS_ERR(priv->iface_base)) - return PTR_ERR(priv->iface_base); + priv->iface_base = devfdt_get_addr_index_ptr(dev, 1); + if (!priv->iface_base) + return -EINVAL;
/* Store common base addresses for all ports */ priv->mpcs_base = priv->iface_base + MVPP22_MPCS; @@ -5399,10 +5399,10 @@ static int mvpp2_probe(struct udevice *dev) if (priv->hw_version == MVPP21) { int priv_common_regs_num = 2;
- port->base = (void __iomem *)devfdt_get_addr_index( + port->base = devfdt_get_addr_index_ptr( dev->parent, priv_common_regs_num + port->id); - if (IS_ERR(port->base)) - return PTR_ERR(port->base); + if (!port->base) + return -EINVAL; } else { port->gop_id = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), "gop-port-id", -1); diff --git a/drivers/pci/pcie_dw_mvebu.c b/drivers/pci/pcie_dw_mvebu.c index 3b2ada54..c41f3f15 100644 --- a/drivers/pci/pcie_dw_mvebu.c +++ b/drivers/pci/pcie_dw_mvebu.c @@ -564,8 +564,8 @@ static int pcie_dw_mvebu_of_to_plat(struct udevice *dev) struct pcie_dw_mvebu *pcie = dev_get_priv(dev);
/* Get the controller base address */ - pcie->ctrl_base = (void *)devfdt_get_addr_index(dev, 0); - if ((fdt_addr_t)pcie->ctrl_base == FDT_ADDR_T_NONE) + pcie->ctrl_base = devfdt_get_addr_index_ptr(dev, 0); + if (!pcie->ctrl_base) return -EINVAL;
/* Get the config space base address and size */ diff --git a/drivers/pci/pcie_imx.c b/drivers/pci/pcie_imx.c index da484664..4a18b0e0 100644 --- a/drivers/pci/pcie_imx.c +++ b/drivers/pci/pcie_imx.c @@ -751,8 +751,8 @@ static int imx_pcie_of_to_plat(struct udevice *dev) { struct imx_pcie_priv *priv = dev_get_priv(dev);
- priv->dbi_base = (void __iomem *)devfdt_get_addr_index(dev, 0); - priv->cfg_base = (void __iomem *)devfdt_get_addr_index(dev, 1); + priv->dbi_base = devfdt_get_addr_index_ptr(dev, 0); + priv->cfg_base = devfdt_get_addr_index_ptr(dev, 1); if (!priv->dbi_base || !priv->cfg_base) return -EINVAL;
diff --git a/drivers/pci/pcie_layerscape_ep.c b/drivers/pci/pcie_layerscape_ep.c index ff26a5cd..83f7eebd 100644 --- a/drivers/pci/pcie_layerscape_ep.c +++ b/drivers/pci/pcie_layerscape_ep.c @@ -250,13 +250,13 @@ static int ls_pcie_ep_probe(struct udevice *dev)
pcie_ep->pcie = pcie;
- pcie->dbi = (void __iomem *)devfdt_get_addr_index(dev, 0); + pcie->dbi = devfdt_get_addr_index_ptr(dev, 0); if (!pcie->dbi) - return -ENOMEM; + return -EINVAL;
- pcie->ctrl = (void __iomem *)devfdt_get_addr_index(dev, 1); + pcie->ctrl = devfdt_get_addr_index_ptr(dev, 1); if (!pcie->ctrl) - return -ENOMEM; + return -EINVAL;
ret = fdt_get_named_resource(gd->fdt_blob, dev_of_offset(dev), "reg", "reg-names", diff --git a/drivers/phy/marvell/comphy_core.c b/drivers/phy/marvell/comphy_core.c index df2460db..7272dfb9 100644 --- a/drivers/phy/marvell/comphy_core.c +++ b/drivers/phy/marvell/comphy_core.c @@ -88,13 +88,13 @@ static int comphy_probe(struct udevice *dev) int res;
/* Save base addresses for later use */ - chip_cfg->comphy_base_addr = (void *)devfdt_get_addr_index(dev, 0); - if (IS_ERR(chip_cfg->comphy_base_addr)) - return PTR_ERR(chip_cfg->comphy_base_addr); + chip_cfg->comphy_base_addr = devfdt_get_addr_index_ptr(dev, 0); + if (!chip_cfg->comphy_base_addr) + return -EINVAL;
- chip_cfg->hpipe3_base_addr = (void *)devfdt_get_addr_index(dev, 1); - if (IS_ERR(chip_cfg->hpipe3_base_addr)) - return PTR_ERR(chip_cfg->hpipe3_base_addr); + chip_cfg->hpipe3_base_addr = devfdt_get_addr_index_ptr(dev, 1); + if (!chip_cfg->hpipe3_base_addr) + return -EINVAL;
if (device_is_compatible(dev, "marvell,comphy-a3700")) { chip_cfg->comphy_init_map = comphy_a3700_init_serdes_map; diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 6a52676a..92e80506 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -383,7 +383,7 @@ static int cadence_spi_of_to_plat(struct udevice *bus) struct cadence_spi_priv *priv = dev_get_priv(bus); ofnode subnode;
- plat->regbase = (void *)devfdt_get_addr_index(bus, 0); + plat->regbase = devfdt_get_addr_index_ptr(bus, 0); plat->ahbbase = devfdt_get_addr_size_index_ptr(bus, 1, &plat->ahbsize); plat->is_decoded_cs = dev_read_bool(bus, "cdns,is-decoded-cs"); plat->fifo_depth = dev_read_u32_default(bus, "cdns,fifo-depth", 128); diff --git a/drivers/usb/musb-new/ti-musb.c b/drivers/usb/musb-new/ti-musb.c index 91042935..3be3f93d 100644 --- a/drivers/usb/musb-new/ti-musb.c +++ b/drivers/usb/musb-new/ti-musb.c @@ -88,7 +88,7 @@ static int ti_musb_of_to_plat(struct udevice *dev) int usb_index; struct musb_hdrc_config *musb_config;
- plat->base = (void *)devfdt_get_addr_index(dev, 1); + plat->base = devfdt_get_addr_index_ptr(dev, 1);
phys = fdtdec_lookup_phandle(fdt, node, "phys"); ctrl_mod = fdtdec_lookup_phandle(fdt, phys, "ti,ctrl_mod"); -- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so use devfdt_get_addr_ptr instead of the devfdt_get_addr function in the various files in the drivers directory that cast to a pointer.
Changed V6: drop cast skip livetree.rst
Changed V5: new patch --- drivers/clk/at91/sama7g5.c | 2 +- drivers/clk/at91/sckc.c | 2 +- drivers/spi/mtk_snor.c | 2 +- drivers/spi/mtk_spim.c | 2 +- 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/clk/at91/sama7g5.c b/drivers/clk/at91/sama7g5.c index d1ec3c82..7a5a2906 100644 --- a/drivers/clk/at91/sama7g5.c +++ b/drivers/clk/at91/sama7g5.c @@ -1114,7 +1114,7 @@ static const struct pmc_clk_setup {
static int sama7g5_clk_probe(struct udevice *dev) { - void __iomem *base = (void *)devfdt_get_addr(dev); + void __iomem *base = devfdt_get_addr_ptr(dev); unsigned int *clkmuxallocs[SAMA7G5_MAX_MUX_ALLOCS]; unsigned int *muxallocs[SAMA7G5_MAX_MUX_ALLOCS]; const char *p[10]; diff --git a/drivers/clk/at91/sckc.c b/drivers/clk/at91/sckc.c index 34ce611a..43136ab2 100644 --- a/drivers/clk/at91/sckc.c +++ b/drivers/clk/at91/sckc.c @@ -123,7 +123,7 @@ U_BOOT_DRIVER(at91_sam9x60_td_slck) = { static int at91_sam9x60_sckc_probe(struct udevice *dev) { struct sam9x60_sckc *sckc = dev_get_priv(dev); - void __iomem *base = (void *)devfdt_get_addr(dev); + void __iomem *base = devfdt_get_addr_ptr(dev); const char *slow_rc_osc, *slow_osc; const char *parents[2]; struct clk *clk, c; diff --git a/drivers/spi/mtk_snor.c b/drivers/spi/mtk_snor.c index 04f588a7..4b7d4a6e 100644 --- a/drivers/spi/mtk_snor.c +++ b/drivers/spi/mtk_snor.c @@ -470,7 +470,7 @@ static int mtk_snor_probe(struct udevice *bus) int ret; u32 reg;
- priv->base = (void __iomem *)devfdt_get_addr(bus); + priv->base = devfdt_get_addr_ptr(bus); if (!priv->base) return -EINVAL;
diff --git a/drivers/spi/mtk_spim.c b/drivers/spi/mtk_spim.c index a7c0fc59..ebb8ee8e 100644 --- a/drivers/spi/mtk_spim.c +++ b/drivers/spi/mtk_spim.c @@ -641,7 +641,7 @@ static int mtk_spim_probe(struct udevice *dev) struct mtk_spim_priv *priv = dev_get_priv(dev); int ret;
- priv->base = (void __iomem *)devfdt_get_addr(dev); + priv->base = devfdt_get_addr_ptr(dev); if (!priv->base) return -EINVAL;
-- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so fix some debug strings with fdt_addr_t to be able to handle both sizes.
Changed V5: new patch --- arch/arm/mach-mvebu/cpu.c | 2 +- drivers/clk/ti/clk-ctrl.c | 9 +++++---- drivers/phy/phy-stm32-usbphyc.c | 4 ++-- 3 files changed, 8 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 329d1369..f58689e1 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -631,7 +631,7 @@ int board_xhci_enable(fdt_addr_t base) { const struct mbus_dram_target_info *dram;
- printf("MVEBU XHCI INIT controller @ 0x%lx\n", base); + printf("MVEBU XHCI INIT controller @ 0x%llx\n", (fdt64_t)base);
dram = mvebu_mbus_dram_info(); xhci_mvebu_mbus_config((void __iomem *)base, dram); diff --git a/drivers/clk/ti/clk-ctrl.c b/drivers/clk/ti/clk-ctrl.c index 6cc02d2e..8926e57e 100644 --- a/drivers/clk/ti/clk-ctrl.c +++ b/drivers/clk/ti/clk-ctrl.c @@ -44,7 +44,7 @@ static int clk_ti_ctrl_disable(struct clk *clk) offs = priv->offs[0].start + clk->id; err = clk_ti_ctrl_check_offs(clk, offs); if (err) { - dev_err(clk->dev, "invalid offset: 0x%lx\n", offs); + dev_err(clk->dev, "invalid offset: 0x%llx\n", (fdt64_t)offs); return err; }
@@ -64,7 +64,7 @@ static int clk_ti_ctrl_enable(struct clk *clk) offs = priv->offs[0].start + clk->id; err = clk_ti_ctrl_check_offs(clk, offs); if (err) { - dev_err(clk->dev, "invalid offset: 0x%lx\n", offs); + dev_err(clk->dev, "invalid offset: 0x%llx\n", (fdt64_t)offs); return err; }
@@ -125,8 +125,9 @@ static int clk_ti_ctrl_of_to_plat(struct udevice *dev) }
priv->offs[i].end = priv->offs[i].start + fdt_size; - dev_dbg(dev, "start=0x%08lx, end=0x%08lx\n", - priv->offs[i].start, priv->offs[i].end); + dev_dbg(dev, "start=0x%016llx, end=0x%016llx\n", + (fdt64_t)priv->offs[i].start, + (fdt64_t)priv->offs[i].end); }
return 0; diff --git a/drivers/phy/phy-stm32-usbphyc.c b/drivers/phy/phy-stm32-usbphyc.c index dcf2194e..15bd60ca 100644 --- a/drivers/phy/phy-stm32-usbphyc.c +++ b/drivers/phy/phy-stm32-usbphyc.c @@ -583,8 +583,8 @@ static int stm32_usbphyc_probe(struct udevice *dev)
phy_id = ofnode_read_u32_default(node, "reg", FDT_ADDR_T_NONE); if (phy_id >= MAX_PHYS) { - dev_err(dev, "invalid reg value %lx for %s\n", - phy_id, ofnode_get_name(node)); + dev_err(dev, "invalid reg value %llx for %s\n", + (fdt64_t)phy_id, ofnode_get_name(node)); return -ENOENT; }
-- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so fix ofnode_get_addr_size function with fdt_addr_t input to be able to handle both sizes for stm32mp SoC in spl.c file.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- arch/arm/mach-stm32mp/spl.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-stm32mp/spl.c b/arch/arm/mach-stm32mp/spl.c index 19d9fe04..6b26641b 100644 --- a/arch/arm/mach-stm32mp/spl.c +++ b/arch/arm/mach-stm32mp/spl.c @@ -112,7 +112,7 @@ uint32_t stm32mp_get_dram_size(void)
static int optee_get_reserved_memory(uint32_t *start, uint32_t *size) { - phys_size_t fdt_mem_size; + fdt_addr_t fdt_mem_size; fdt_addr_t fdt_start; ofnode node;
@@ -121,8 +121,8 @@ static int optee_get_reserved_memory(uint32_t *start, uint32_t *size) return 0;
fdt_start = ofnode_get_addr_size(node, "reg", &fdt_mem_size); - *start = fdt_start; - *size = fdt_mem_size; + *start = (uint32_t)fdt_start; + *size = (uint32_t)fdt_mem_size; return (fdt_start < 0) ? fdt_start : 0; }
-- 2.20.1
The DT specification supports CPUs with both 32-bit and 64-bit addressing capabilities. In U-boot the fdt_addr_t and phys_addr_t size are coupled by a typedef. The MTD NAND drivers for 32-bit CPU's can describe partitions with a 64-bit reg property. These partitions synced from Linux end up with the wrong offset and sizes when only the lower 32-bit is passed. Decouple the fdt_addr_t and phys_addr_t size as they don't necessary match.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Kever Yang kever.yang@rock-chips.com ---
Note: Due to the large number of references to fdt_addr_t this patch serie fixes only some bugs, but not all. Apply only when all remaining errors and warnings due to this patch are fixed. Help with testing/debug appreciated. --- Kconfig | 8 ++++++++ include/fdtdec.h | 13 +++++++++---- 2 files changed, 17 insertions(+), 4 deletions(-)
diff --git a/Kconfig b/Kconfig index a75cce7e..7697dade 100644 --- a/Kconfig +++ b/Kconfig @@ -422,11 +422,19 @@ endif # EXPERT
config PHYS_64BIT bool "64bit physical address support" + select FDT_64BIT help Say Y here to support 64bit physical memory address. This can be used not only for 64bit SoCs, but also for large physical address extension on 32bit SoCs.
+config FDT_64BIT + bool "64bit fdt address support" + help + Say Y here to support 64bit fdt addresses. + This can be used not only for 64bit SoCs, but also + for large address extensions on 32bit SoCs. + config HAS_ROM bool select BINMAN diff --git a/include/fdtdec.h b/include/fdtdec.h index aa61a0fc..6b768ed5 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -18,15 +18,18 @@ #include <pci.h>
/* - * A typedef for a physical address. Note that fdt data is always big + * Support for 64bit fdt addresses. + * This can be used not only for 64bit SoCs, but also + * for large address extensions on 32bit SoCs. + * Note that fdt data is always big * endian even on a litle endian machine. */ -typedef phys_addr_t fdt_addr_t; -typedef phys_size_t fdt_size_t;
#define FDT_SIZE_T_NONE (-1U)
-#ifdef CONFIG_PHYS_64BIT +#ifdef CONFIG_FDT_64BIT +typedef u64 fdt_addr_t; +typedef u64 fdt_size_t; #define FDT_ADDR_T_NONE ((ulong)(-1))
#define fdt_addr_to_cpu(reg) be64_to_cpu(reg) @@ -35,6 +38,8 @@ typedef phys_size_t fdt_size_t; #define cpu_to_fdt_size(reg) cpu_to_be64(reg) typedef fdt64_t fdt_val_t; #else +typedef u32 fdt_addr_t; +typedef u32 fdt_size_t; #define FDT_ADDR_T_NONE (-1U)
#define fdt_addr_to_cpu(reg) be32_to_cpu(reg) -- 2.20.1
Johan Jonker
Michael Nazzareno Trimarchi
