[PATCH v9 1/2] net: brcm: netXtreme driver
Broadcom bnxt L2 driver support. Used by the Broadcom iproc platforms.
Signed-off-by: Bharat Gooty bharat.gooty@broadcom.com Reviewed-by: Ramon Fried rfried.dev@gmail.com
Signed-off-by: Roman Bacik roman.bacik@broadcom.com ---
Changes in v9: - remove bnxt_ver.h - add DRIVER_VERSION_* definitions to bnxt.h - remove pci_read_/pci_write_/pci_map_ definitions from bnxt.h
Changes in v8: - remove PCICFG_ME_REGISTER
Changes in v7: - move bnxt_*.h files to drivers/net/bnxt/ - remove display_banner() - replace pci_map_bar() with dm_pci_map_bar() - remove changes to dev->flags_ - move PCI DID and VID definitions to include/pci_ids.h - move bnxt_nics[] to bnxt.c - move bnxt_alloc_mem to bnxt_read_rom_hw - return proper error codes in bnxt_read_rom_hwaddr
Changes in v6: - remove bnxt_eth_* env variables - clean up include headers
Changes in v5: - remove bnxt_env_set_ethaddr/bnxt_env_del_ethaddr methods - add .read_rom_hwaddr = bnxt_read_rom_hwaddr - move bnxt_bring_pci/bnxt_bring_chip to bnxt_read_rom_hwddr - move mac copy from priv to plat to bnxt_read_rom_hwaddr
Changes in v4: - remove static num_cards and use dev_seq(dev) instead - add .probe - merged probe/remove methods - select PCI_INIT_R when BNXT_ETH is selected
Changes in v3: - change printf to debug in display_banner - remove get/set/print mac/speed - remove bnxt_hwrm_set_nvmem
Changes in v2: - rebase and remove DM_PCI dependency from BNXT_ETH - remove tautology assignment from debug_resp()
drivers/net/Kconfig | 1 + drivers/net/Makefile | 1 + drivers/net/bnxt/Kconfig | 7 + drivers/net/bnxt/Makefile | 5 + drivers/net/bnxt/bnxt.c | 1706 +++++++++++++++++++++++++++++++++++ drivers/net/bnxt/bnxt.h | 390 ++++++++ drivers/net/bnxt/bnxt_dbg.h | 536 +++++++++++ drivers/net/bnxt/bnxt_hsi.h | 889 ++++++++++++++++++ include/pci_ids.h | 3 + 9 files changed, 3538 insertions(+) create mode 100644 drivers/net/bnxt/Kconfig create mode 100644 drivers/net/bnxt/Makefile create mode 100644 drivers/net/bnxt/bnxt.c create mode 100644 drivers/net/bnxt/bnxt.h create mode 100644 drivers/net/bnxt/bnxt_dbg.h create mode 100644 drivers/net/bnxt/bnxt_hsi.h
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 6c12959f3794..8dc81a3d6cf9 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -1,6 +1,7 @@ source "drivers/net/phy/Kconfig" source "drivers/net/pfe_eth/Kconfig" source "drivers/net/fsl-mc/Kconfig" +source "drivers/net/bnxt/Kconfig"
config ETH def_bool y diff --git a/drivers/net/Makefile b/drivers/net/Makefile index e4078d15a99f..1d9fbd6693cc 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -101,3 +101,4 @@ obj-$(CONFIG_HIGMACV300_ETH) += higmacv300.o obj-$(CONFIG_MDIO_SANDBOX) += mdio_sandbox.o obj-$(CONFIG_FSL_ENETC) += fsl_enetc.o fsl_enetc_mdio.o obj-$(CONFIG_FSL_LS_MDIO) += fsl_ls_mdio.o +obj-$(CONFIG_BNXT_ETH) += bnxt/ diff --git a/drivers/net/bnxt/Kconfig b/drivers/net/bnxt/Kconfig new file mode 100644 index 000000000000..412ecd430335 --- /dev/null +++ b/drivers/net/bnxt/Kconfig @@ -0,0 +1,7 @@ +config BNXT_ETH + bool "BNXT PCI support" + depends on DM_ETH + select PCI_INIT_R + help + This driver implements support for bnxt pci controller + driver of ethernet class. diff --git a/drivers/net/bnxt/Makefile b/drivers/net/bnxt/Makefile new file mode 100644 index 000000000000..a9d6ce00d5e0 --- /dev/null +++ b/drivers/net/bnxt/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright 2019-2021 Broadcom. + +# Broadcom nxe Ethernet driver +obj-y += bnxt.o diff --git a/drivers/net/bnxt/bnxt.c b/drivers/net/bnxt/bnxt.c new file mode 100644 index 000000000000..210fb55891d7 --- /dev/null +++ b/drivers/net/bnxt/bnxt.c @@ -0,0 +1,1706 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019-2021 Broadcom. + */ + +#include <common.h> + +#include <asm/io.h> +#include <dm.h> +#include <linux/delay.h> +#include <memalign.h> +#include <net.h> + +#include "bnxt.h" +#include "bnxt_dbg.h" + +#define bnxt_down_chip(bp) bnxt_hwrm_run(down_chip, bp, 0) +#define bnxt_bring_chip(bp) bnxt_hwrm_run(bring_chip, bp, 1) + +/* Broadcom ethernet driver PCI APIs. */ +static void bnxt_bring_pci(struct bnxt *bp) +{ + u16 cmd_reg = 0; + + dm_pci_read_config16(bp->pdev, PCI_VENDOR_ID, &bp->vendor_id); + dm_pci_read_config16(bp->pdev, PCI_DEVICE_ID, &bp->device_id); + dm_pci_read_config16(bp->pdev, PCI_SUBSYSTEM_VENDOR_ID, &bp->subsystem_vendor); + dm_pci_read_config16(bp->pdev, PCI_SUBSYSTEM_ID, &bp->subsystem_device); + dm_pci_read_config16(bp->pdev, PCI_COMMAND, &bp->cmd_reg); + dm_pci_read_config8(bp->pdev, PCI_INTERRUPT_LINE, &bp->irq); + bp->bar0 = dm_pci_map_bar(bp->pdev, PCI_BASE_ADDRESS_0, PCI_REGION_MEM); + bp->bar1 = dm_pci_map_bar(bp->pdev, PCI_BASE_ADDRESS_2, PCI_REGION_MEM); + bp->bar2 = dm_pci_map_bar(bp->pdev, PCI_BASE_ADDRESS_4, PCI_REGION_MEM); + cmd_reg = bp->cmd_reg | PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER; + cmd_reg |= PCI_COMMAND_INTX_DISABLE; /* disable intr */ + dm_pci_write_config16(bp->pdev, PCI_COMMAND, cmd_reg); + dm_pci_read_config16(bp->pdev, PCI_COMMAND, &cmd_reg); + dbg_pci(bp, __func__, cmd_reg); +} + +int bnxt_free_rx_iob(struct bnxt *bp) +{ + unsigned int i; + + if (!(FLAG_TEST(bp->flag_hwrm, VALID_RX_IOB))) + return STATUS_SUCCESS; + + for (i = 0; i < bp->rx.buf_cnt; i++) { + if (bp->rx.iob[i]) { + free(bp->rx.iob[i]); + bp->rx.iob[i] = NULL; + } + } + + FLAG_RESET(bp->flag_hwrm, VALID_RX_IOB); + + return STATUS_SUCCESS; +} + +static void set_rx_desc(u8 *buf, void *iob, u16 cons_id, u32 iob_idx) +{ + struct rx_prod_pkt_bd *desc; + u16 off = cons_id * sizeof(struct rx_prod_pkt_bd); + + desc = (struct rx_prod_pkt_bd *)&buf[off]; + desc->flags_type = RX_PROD_PKT_BD_TYPE_RX_PROD_PKT; + desc->len = MAX_ETHERNET_PACKET_BUFFER_SIZE; + desc->opaque = iob_idx; + desc->dma.addr = virt_to_bus(iob); +} + +static int bnxt_alloc_rx_iob(struct bnxt *bp, u16 cons_id, u16 iob_idx) +{ + void *iob; + + iob = memalign(BNXT_DMA_ALIGNMENT, RX_STD_DMA_ALIGNED); + if (!iob) + return -ENOMEM; + + dbg_rx_iob(iob, iob_idx, cons_id); + set_rx_desc((u8 *)bp->rx.bd_virt, iob, cons_id, (u32)iob_idx); + bp->rx.iob[iob_idx] = iob; + + return 0; +} + +void bnxt_mm_init(struct bnxt *bp, const char *func) +{ + memset(bp->hwrm_addr_req, 0, REQ_BUFFER_SIZE); + memset(bp->hwrm_addr_resp, 0, RESP_BUFFER_SIZE); + memset(bp->cq.bd_virt, 0, CQ_RING_DMA_BUFFER_SIZE); + memset(bp->tx.bd_virt, 0, TX_RING_DMA_BUFFER_SIZE); + memset(bp->rx.bd_virt, 0, RX_RING_DMA_BUFFER_SIZE); + + bp->data_addr_mapping = virt_to_bus(bp->hwrm_addr_data); + bp->req_addr_mapping = virt_to_bus(bp->hwrm_addr_req); + bp->resp_addr_mapping = virt_to_bus(bp->hwrm_addr_resp); + bp->wait_link_timeout = LINK_DEFAULT_TIMEOUT; + bp->link_status = STATUS_LINK_DOWN; + bp->media_change = 1; + bp->mtu = MAX_ETHERNET_PACKET_BUFFER_SIZE; + bp->hwrm_max_req_len = HWRM_MAX_REQ_LEN; + bp->rx.buf_cnt = NUM_RX_BUFFERS; + bp->rx.ring_cnt = MAX_RX_DESC_CNT; + bp->tx.ring_cnt = MAX_TX_DESC_CNT; + bp->cq.ring_cnt = MAX_CQ_DESC_CNT; + bp->cq.completion_bit = 0x1; + bp->link_set = LINK_SPEED_DRV_100G; + dbg_mem(bp, func); +} + +void bnxt_free_mem(struct bnxt *bp) +{ + if (bp->cq.bd_virt) { + free(bp->cq.bd_virt); + bp->cq.bd_virt = NULL; + } + + if (bp->rx.bd_virt) { + free(bp->rx.bd_virt); + bp->rx.bd_virt = NULL; + } + + if (bp->tx.bd_virt) { + free(bp->tx.bd_virt); + bp->tx.bd_virt = NULL; + } + + if (bp->hwrm_addr_resp) { + free(bp->hwrm_addr_resp); + bp->resp_addr_mapping = 0; + bp->hwrm_addr_resp = NULL; + } + + if (bp->hwrm_addr_req) { + free(bp->hwrm_addr_req); + bp->req_addr_mapping = 0; + bp->hwrm_addr_req = NULL; + } + + if (bp->hwrm_addr_data) { + free(bp->hwrm_addr_data); + bp->data_addr_mapping = 0; + bp->hwrm_addr_data = NULL; + } + + dbg_mem_free_done(__func__); +} + +int bnxt_alloc_mem(struct bnxt *bp) +{ + bp->hwrm_addr_data = memalign(BNXT_DMA_ALIGNMENT, DMA_BUF_SIZE_ALIGNED); + bp->hwrm_addr_req = memalign(BNXT_DMA_ALIGNMENT, REQ_BUF_SIZE_ALIGNED); + bp->hwrm_addr_resp = MEM_HWRM_RESP; + + memset(&bp->tx, 0, sizeof(struct lm_tx_info_t)); + memset(&bp->rx, 0, sizeof(struct lm_rx_info_t)); + memset(&bp->cq, 0, sizeof(struct lm_cmp_info_t)); + + bp->tx.bd_virt = memalign(BNXT_DMA_ALIGNMENT, TX_RING_DMA_BUFFER_SIZE); + bp->rx.bd_virt = memalign(BNXT_DMA_ALIGNMENT, RX_RING_DMA_BUFFER_SIZE); + bp->cq.bd_virt = memalign(BNXT_DMA_ALIGNMENT, CQ_RING_DMA_BUFFER_SIZE); + + if (bp->hwrm_addr_req && + bp->hwrm_addr_resp && + bp->hwrm_addr_data && + bp->tx.bd_virt && + bp->rx.bd_virt && + bp->cq.bd_virt) { + bnxt_mm_init(bp, __func__); + return STATUS_SUCCESS; + } + + dbg_mem_alloc_fail(__func__); + bnxt_free_mem(bp); + + return -ENOMEM; +} + +static void hwrm_init(struct bnxt *bp, struct input *req, u16 cmd, u16 len) +{ + memset(req, 0, len); + req->req_type = cmd; + req->cmpl_ring = (u16)HWRM_NA_SIGNATURE; + req->target_id = (u16)HWRM_NA_SIGNATURE; + req->resp_addr = bp->resp_addr_mapping; + req->seq_id = bp->seq_id++; +} + +static void hwrm_write_req(struct bnxt *bp, void *req, u32 cnt) +{ + u32 i = 0; + + for (i = 0; i < cnt; i++) { + writel(((u32 *)req)[i], bp->bar0 + GRC_COM_CHAN_BASE + (i * 4)); + } + + writel(0x1, (bp->bar0 + GRC_COM_CHAN_BASE + GRC_COM_CHAN_TRIG)); +} + +static void short_hwrm_cmd_req(struct bnxt *bp, u16 len) +{ + struct hwrm_short_input sreq; + + memset(&sreq, 0, sizeof(struct hwrm_short_input)); + sreq.req_type = (u16)((struct input *)bp->hwrm_addr_req)->req_type; + sreq.signature = SHORT_REQ_SIGNATURE_SHORT_CMD; + sreq.size = len; + sreq.req_addr = bp->req_addr_mapping; + dbg_short_cmd((u8 *)&sreq, __func__, sizeof(struct hwrm_short_input)); + hwrm_write_req(bp, &sreq, sizeof(struct hwrm_short_input) / 4); +} + +static int wait_resp(struct bnxt *bp, u32 tmo, u16 len, const char *func) +{ + struct input *req = (struct input *)bp->hwrm_addr_req; + struct output *resp = (struct output *)bp->hwrm_addr_resp; + u8 *ptr = (u8 *)resp; + u32 idx; + u32 wait_cnt = HWRM_CMD_DEFAULT_MULTIPLAYER((u32)tmo); + u16 resp_len = 0; + u16 ret = STATUS_TIMEOUT; + + if (len > bp->hwrm_max_req_len) + short_hwrm_cmd_req(bp, len); + else + hwrm_write_req(bp, req, (u32)(len / 4)); + + for (idx = 0; idx < wait_cnt; idx++) { + resp_len = resp->resp_len; + if (resp->seq_id == req->seq_id && resp->req_type == req->req_type && + ptr[resp_len - 1] == 1) { + bp->last_resp_code = resp->error_code; + ret = resp->error_code; + break; + } + + udelay(HWRM_CMD_POLL_WAIT_TIME); + } + + dbg_hw_cmd(bp, func, len, resp_len, tmo, ret); + + return (int)ret; +} + +static void bnxt_db_cq(struct bnxt *bp) +{ + writel(CQ_DOORBELL_KEY_IDX(bp->cq.cons_idx), bp->bar1); +} + +static void bnxt_db_rx(struct bnxt *bp, u32 idx) +{ + writel(RX_DOORBELL_KEY_RX | idx, bp->bar1); +} + +static void bnxt_db_tx(struct bnxt *bp, u32 idx) +{ + writel((u32)(TX_DOORBELL_KEY_TX | idx), bp->bar1); +} + +int iob_pad(void *packet, int length) +{ + if (length >= ETH_ZLEN) + return length; + + memset(((u8 *)packet + length), 0x00, (ETH_ZLEN - length)); + + return ETH_ZLEN; +} + +static inline u32 bnxt_tx_avail(struct bnxt *bp) +{ + barrier(); + + return TX_AVAIL(bp->tx.ring_cnt) - + ((bp->tx.prod_id - bp->tx.cons_id) & + (bp->tx.ring_cnt - 1)); +} + +void set_txq(struct bnxt *bp, int entry, dma_addr_t mapping, int len) +{ + struct tx_bd_short *prod_bd; + + prod_bd = (struct tx_bd_short *)BD_NOW(bp->tx.bd_virt, + entry, + sizeof(struct tx_bd_short)); + if (len < 512) + prod_bd->flags_type = TX_BD_SHORT_FLAGS_LHINT_LT512; + else if (len < 1024) + prod_bd->flags_type = TX_BD_SHORT_FLAGS_LHINT_LT1K; + else if (len < 2048) + prod_bd->flags_type = TX_BD_SHORT_FLAGS_LHINT_LT2K; + else + prod_bd->flags_type = TX_BD_SHORT_FLAGS_LHINT_GTE2K; + + prod_bd->flags_type |= TX_BD_FLAGS; + prod_bd->dma.addr = mapping; + prod_bd->len = len; + prod_bd->opaque = (u32)entry; + dump_tx_bd(prod_bd, (u16)(sizeof(struct tx_bd_short))); +} + +static void bnxt_tx_complete(struct bnxt *bp) +{ + bp->tx.cons_id = NEXT_IDX(bp->tx.cons_id, bp->tx.ring_cnt); + bp->tx.cnt++; + dump_tx_stat(bp); +} + +int post_rx_buffers(struct bnxt *bp) +{ + u16 cons_id = (bp->rx.cons_idx % bp->rx.ring_cnt); + u16 iob_idx; + + while (bp->rx.iob_cnt < bp->rx.buf_cnt) { + iob_idx = (cons_id % bp->rx.buf_cnt); + if (!bp->rx.iob[iob_idx]) { + if (bnxt_alloc_rx_iob(bp, cons_id, iob_idx) < 0) { + dbg_rx_alloc_iob_fail(iob_idx, cons_id); + break; + } + } + + cons_id = NEXT_IDX(cons_id, bp->rx.ring_cnt); + bp->rx.iob_cnt++; + } + + if (cons_id != bp->rx.cons_idx) { + dbg_rx_cid(bp->rx.cons_idx, cons_id); + bp->rx.cons_idx = cons_id; + bnxt_db_rx(bp, (u32)cons_id); + } + + FLAG_SET(bp->flag_hwrm, VALID_RX_IOB); + + return STATUS_SUCCESS; +} + +u8 bnxt_rx_drop(struct bnxt *bp, u8 *rx_buf, struct rx_pkt_cmpl_hi *rx_cmp_hi) +{ + u8 chksum_err = 0; + u8 i; + u16 error_flags; + + error_flags = (rx_cmp_hi->errors_v2 >> + RX_PKT_CMPL_ERRORS_BUFFER_ERROR_SFT); + if (rx_cmp_hi->errors_v2 == 0x20 || rx_cmp_hi->errors_v2 == 0x21) + chksum_err = 1; + + if (error_flags && !chksum_err) { + bp->rx.err++; + return 1; + } + + for (i = 0; i < 6; i++) { + if (rx_buf[6 + i] != bp->mac_set[i]) + break; + } + + if (i == 6) { + bp->rx.dropped++; + return 2; /* Drop the loopback packets */ + } + + return 0; +} + +static void bnxt_adv_cq_index(struct bnxt *bp, u16 count) +{ + u16 cons_idx = bp->cq.cons_idx + count; + + if (cons_idx >= MAX_CQ_DESC_CNT) { + /* Toggle completion bit when the ring wraps. */ + bp->cq.completion_bit ^= 1; + cons_idx = cons_idx - MAX_CQ_DESC_CNT; + } + + bp->cq.cons_idx = cons_idx; +} + +void bnxt_adv_rx_index(struct bnxt *bp, u8 *iob, u32 iob_idx) +{ + u16 cons_id = (bp->rx.cons_idx % bp->rx.ring_cnt); + + set_rx_desc((u8 *)bp->rx.bd_virt, (void *)iob, cons_id, iob_idx); + cons_id = NEXT_IDX(cons_id, bp->rx.ring_cnt); + if (cons_id != bp->rx.cons_idx) { + dbg_rx_cid(bp->rx.cons_idx, cons_id); + bp->rx.cons_idx = cons_id; + bnxt_db_rx(bp, (u32)cons_id); + } +} + +void rx_process(struct bnxt *bp, struct rx_pkt_cmpl *rx_cmp, + struct rx_pkt_cmpl_hi *rx_cmp_hi) +{ + u32 desc_idx = rx_cmp->opaque; + u8 *iob = bp->rx.iob[desc_idx]; + + dump_rx_bd(rx_cmp, rx_cmp_hi, desc_idx); + bp->rx.iob_len = rx_cmp->len; + bp->rx.iob_rx = iob; + if (bnxt_rx_drop(bp, iob, rx_cmp_hi)) + bp->rx.iob_recv = PKT_DROPPED; + else + bp->rx.iob_recv = PKT_RECEIVED; + + bp->rx.rx_cnt++; + + dbg_rxp(bp->rx.iob_rx, bp->rx.iob_len, bp->rx.iob_recv); + bnxt_adv_rx_index(bp, iob, desc_idx); + bnxt_adv_cq_index(bp, 2); /* Rx completion is 2 entries. */ +} + +static int bnxt_rx_complete(struct bnxt *bp, struct rx_pkt_cmpl *rx_cmp) +{ + struct rx_pkt_cmpl_hi *rx_cmp_hi; + u8 completion_bit = bp->cq.completion_bit; + + if (bp->cq.cons_idx == (bp->cq.ring_cnt - 1)) { + rx_cmp_hi = (struct rx_pkt_cmpl_hi *)bp->cq.bd_virt; + completion_bit ^= 0x1; /* Ring has wrapped. */ + } else { + rx_cmp_hi = (struct rx_pkt_cmpl_hi *)(rx_cmp + 1); + } + + if (!((rx_cmp_hi->errors_v2 & RX_PKT_CMPL_V2) ^ completion_bit)) + rx_process(bp, rx_cmp, rx_cmp_hi); + + return NO_MORE_CQ_BD_TO_SERVICE; +} + +static int bnxt_hwrm_ver_get(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_ver_get_input); + struct hwrm_ver_get_input *req; + struct hwrm_ver_get_output *resp; + int rc; + + req = (struct hwrm_ver_get_input *)bp->hwrm_addr_req; + resp = (struct hwrm_ver_get_output *)bp->hwrm_addr_resp; + hwrm_init(bp, (void *)req, (u16)HWRM_VER_GET, cmd_len); + req->hwrm_intf_maj = HWRM_VERSION_MAJOR; + req->hwrm_intf_min = HWRM_VERSION_MINOR; + req->hwrm_intf_upd = HWRM_VERSION_UPDATE; + rc = wait_resp(bp, HWRM_CMD_DEFAULT_TIMEOUT, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + bp->hwrm_spec_code = + resp->hwrm_intf_maj_8b << 16 | + resp->hwrm_intf_min_8b << 8 | + resp->hwrm_intf_upd_8b; + bp->hwrm_cmd_timeout = (u32)resp->def_req_timeout; + if (!bp->hwrm_cmd_timeout) + bp->hwrm_cmd_timeout = (u32)HWRM_CMD_DEFAULT_TIMEOUT; + + if (resp->hwrm_intf_maj_8b >= 1) + bp->hwrm_max_req_len = resp->max_req_win_len; + + bp->chip_id = + resp->chip_rev << 24 | + resp->chip_metal << 16 | + resp->chip_bond_id << 8 | + resp->chip_platform_type; + bp->chip_num = resp->chip_num; + if ((resp->dev_caps_cfg & SHORT_CMD_SUPPORTED) && + (resp->dev_caps_cfg & SHORT_CMD_REQUIRED)) + FLAG_SET(bp->flags, BNXT_FLAG_HWRM_SHORT_CMD_SUPP); + + bp->hwrm_max_ext_req_len = resp->max_ext_req_len; + bp->fw_maj = resp->hwrm_fw_maj_8b; + bp->fw_min = resp->hwrm_fw_min_8b; + bp->fw_bld = resp->hwrm_fw_bld_8b; + bp->fw_rsvd = resp->hwrm_fw_rsvd_8b; + print_fw_ver(resp, bp->hwrm_cmd_timeout); + + return STATUS_SUCCESS; +} + +/* Broadcom ethernet driver Function HW cmds APIs. */ +static int bnxt_hwrm_func_resource_qcaps(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_func_resource_qcaps_input); + struct hwrm_func_resource_qcaps_input *req; + struct hwrm_func_resource_qcaps_output *resp; + int rc; + + req = (struct hwrm_func_resource_qcaps_input *)bp->hwrm_addr_req; + resp = (struct hwrm_func_resource_qcaps_output *)bp->hwrm_addr_resp; + hwrm_init(bp, (void *)req, (u16)HWRM_FUNC_RESOURCE_QCAPS, cmd_len); + req->fid = (u16)HWRM_NA_SIGNATURE; + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc != STATUS_SUCCESS) + return STATUS_SUCCESS; + + FLAG_SET(bp->flags, BNXT_FLAG_RESOURCE_QCAPS_SUPPORT); + /* VFs */ + bp->max_vfs = resp->max_vfs; + bp->vf_res_strategy = resp->vf_reservation_strategy; + /* vNICs */ + bp->min_vnics = resp->min_vnics; + bp->max_vnics = resp->max_vnics; + /* MSI-X */ + bp->max_msix = resp->max_msix; + /* Ring Groups */ + bp->min_hw_ring_grps = resp->min_hw_ring_grps; + bp->max_hw_ring_grps = resp->max_hw_ring_grps; + /* TX Rings */ + bp->min_tx_rings = resp->min_tx_rings; + bp->max_tx_rings = resp->max_tx_rings; + /* RX Rings */ + bp->min_rx_rings = resp->min_rx_rings; + bp->max_rx_rings = resp->max_rx_rings; + /* Completion Rings */ + bp->min_cp_rings = resp->min_cmpl_rings; + bp->max_cp_rings = resp->max_cmpl_rings; + /* RSS Contexts */ + bp->min_rsscos_ctxs = resp->min_rsscos_ctx; + bp->max_rsscos_ctxs = resp->max_rsscos_ctx; + /* L2 Contexts */ + bp->min_l2_ctxs = resp->min_l2_ctxs; + bp->max_l2_ctxs = resp->max_l2_ctxs; + /* Statistic Contexts */ + bp->min_stat_ctxs = resp->min_stat_ctx; + bp->max_stat_ctxs = resp->max_stat_ctx; + dbg_func_resource_qcaps(bp); + + return STATUS_SUCCESS; +} + +static u32 set_ring_info(struct bnxt *bp) +{ + u32 enables = 0; + + bp->num_cmpl_rings = DEFAULT_NUMBER_OF_CMPL_RINGS; + bp->num_tx_rings = DEFAULT_NUMBER_OF_TX_RINGS; + bp->num_rx_rings = DEFAULT_NUMBER_OF_RX_RINGS; + bp->num_hw_ring_grps = DEFAULT_NUMBER_OF_RING_GRPS; + bp->num_stat_ctxs = DEFAULT_NUMBER_OF_STAT_CTXS; + if (bp->min_cp_rings <= DEFAULT_NUMBER_OF_CMPL_RINGS) + bp->num_cmpl_rings = bp->min_cp_rings; + + if (bp->min_tx_rings <= DEFAULT_NUMBER_OF_TX_RINGS) + bp->num_tx_rings = bp->min_tx_rings; + + if (bp->min_rx_rings <= DEFAULT_NUMBER_OF_RX_RINGS) + bp->num_rx_rings = bp->min_rx_rings; + + if (bp->min_hw_ring_grps <= DEFAULT_NUMBER_OF_RING_GRPS) + bp->num_hw_ring_grps = bp->min_hw_ring_grps; + + if (bp->min_stat_ctxs <= DEFAULT_NUMBER_OF_STAT_CTXS) + bp->num_stat_ctxs = bp->min_stat_ctxs; + + print_num_rings(bp); + enables = (FUNC_CFG_REQ_ENABLES_NUM_CMPL_RINGS | + FUNC_CFG_REQ_ENABLES_NUM_TX_RINGS | + FUNC_CFG_REQ_ENABLES_NUM_RX_RINGS | + FUNC_CFG_REQ_ENABLES_NUM_STAT_CTXS | + FUNC_CFG_REQ_ENABLES_NUM_HW_RING_GRPS); + + return enables; +} + +static void bnxt_hwrm_assign_resources(struct bnxt *bp) +{ + struct hwrm_func_cfg_input *req; + u32 enables = 0; + + if (FLAG_TEST(bp->flags, BNXT_FLAG_RESOURCE_QCAPS_SUPPORT)) + enables = set_ring_info(bp); + + req = (struct hwrm_func_cfg_input *)bp->hwrm_addr_req; + req->num_cmpl_rings = bp->num_cmpl_rings; + req->num_tx_rings = bp->num_tx_rings; + req->num_rx_rings = bp->num_rx_rings; + req->num_stat_ctxs = bp->num_stat_ctxs; + req->num_hw_ring_grps = bp->num_hw_ring_grps; + req->enables = enables; +} + +int bnxt_hwrm_nvm_flush(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_nvm_flush_input); + struct hwrm_nvm_flush_input *req; + int rc; + + req = (struct hwrm_nvm_flush_input *)bp->hwrm_addr_req; + + hwrm_init(bp, (void *)req, (u16)HWRM_NVM_FLUSH, cmd_len); + + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + return STATUS_SUCCESS; +} + +static int bnxt_hwrm_func_qcaps_req(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_func_qcaps_input); + struct hwrm_func_qcaps_input *req; + struct hwrm_func_qcaps_output *resp; + int rc; + + req = (struct hwrm_func_qcaps_input *)bp->hwrm_addr_req; + resp = (struct hwrm_func_qcaps_output *)bp->hwrm_addr_resp; + hwrm_init(bp, (void *)req, (u16)HWRM_FUNC_QCAPS, cmd_len); + req->fid = (u16)HWRM_NA_SIGNATURE; + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + bp->fid = resp->fid; + bp->port_idx = (u8)resp->port_id; + + /* Get MAC address for this PF */ + memcpy(&bp->mac_addr[0], &resp->mac_address[0], ETH_ALEN); + + memcpy(&bp->mac_set[0], &bp->mac_addr[0], ETH_ALEN); + + print_func_qcaps(bp); + + return STATUS_SUCCESS; +} + +static int bnxt_hwrm_func_qcfg_req(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_func_qcfg_input); + struct hwrm_func_qcfg_input *req; + struct hwrm_func_qcfg_output *resp; + int rc; + + req = (struct hwrm_func_qcfg_input *)bp->hwrm_addr_req; + resp = (struct hwrm_func_qcfg_output *)bp->hwrm_addr_resp; + hwrm_init(bp, (void *)req, (u16)HWRM_FUNC_QCFG, cmd_len); + req->fid = (u16)HWRM_NA_SIGNATURE; + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + if (resp->flags & FUNC_QCFG_RESP_FLAGS_MULTI_HOST) + FLAG_SET(bp->flags, BNXT_FLAG_MULTI_HOST); + + if (resp->port_partition_type & + FUNC_QCFG_RESP_PORT_PARTITION_TYPE_NPAR1_0) + FLAG_SET(bp->flags, BNXT_FLAG_NPAR_MODE); + + bp->ordinal_value = (u8)resp->pci_id & 0x0F; + bp->stat_ctx_id = resp->stat_ctx_id; + memcpy(&bp->mac_addr[0], &resp->mac_address[0], ETH_ALEN); + print_func_qcfg(bp); + dbg_flags(__func__, bp->flags); + + return STATUS_SUCCESS; +} + +static int bnxt_hwrm_func_reset_req(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_func_reset_input); + struct hwrm_func_reset_input *req; + + req = (struct hwrm_func_reset_input *)bp->hwrm_addr_req; + hwrm_init(bp, (void *)req, (u16)HWRM_FUNC_RESET, cmd_len); + req->func_reset_level = FUNC_RESET_REQ_FUNC_RESET_LEVEL_RESETME; + + return wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); +} + +static int bnxt_hwrm_func_cfg_req(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_func_cfg_input); + struct hwrm_func_cfg_input *req; + + req = (struct hwrm_func_cfg_input *)bp->hwrm_addr_req; + hwrm_init(bp, (void *)req, (u16)HWRM_FUNC_CFG, cmd_len); + req->fid = (u16)HWRM_NA_SIGNATURE; + bnxt_hwrm_assign_resources(bp); + + return wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); +} + +static int bnxt_hwrm_func_drv_rgtr(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_func_drv_rgtr_input); + struct hwrm_func_drv_rgtr_input *req; + int rc; + + req = (struct hwrm_func_drv_rgtr_input *)bp->hwrm_addr_req; + hwrm_init(bp, (void *)req, (u16)HWRM_FUNC_DRV_RGTR, cmd_len); + /* Register with HWRM */ + req->enables = FUNC_DRV_RGTR_REQ_ENABLES_OS_TYPE | + FUNC_DRV_RGTR_REQ_ENABLES_ASYNC_EVENT_FWD | + FUNC_DRV_RGTR_REQ_ENABLES_VER; + req->async_event_fwd[0] |= 0x01; + req->os_type = FUNC_DRV_RGTR_REQ_OS_TYPE_OTHER; + req->ver_maj = DRIVER_VERSION_MAJOR; + req->ver_min = DRIVER_VERSION_MINOR; + req->ver_upd = DRIVER_VERSION_UPDATE; + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + FLAG_SET(bp->flag_hwrm, VALID_DRIVER_REG); + + return STATUS_SUCCESS; +} + +static int bnxt_hwrm_func_drv_unrgtr(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_func_drv_unrgtr_input); + struct hwrm_func_drv_unrgtr_input *req; + int rc; + + if (!(FLAG_TEST(bp->flag_hwrm, VALID_DRIVER_REG))) + return STATUS_SUCCESS; + + req = (struct hwrm_func_drv_unrgtr_input *)bp->hwrm_addr_req; + hwrm_init(bp, (void *)req, (u16)HWRM_FUNC_DRV_UNRGTR, cmd_len); + req->flags = FUNC_DRV_UNRGTR_REQ_FLAGS_PREPARE_FOR_SHUTDOWN; + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + FLAG_RESET(bp->flag_hwrm, VALID_DRIVER_REG); + + return STATUS_SUCCESS; +} + +static int bnxt_hwrm_cfa_l2_filter_alloc(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_cfa_l2_filter_alloc_input); + struct hwrm_cfa_l2_filter_alloc_input *req; + struct hwrm_cfa_l2_filter_alloc_output *resp; + int rc; + u32 flags = CFA_L2_FILTER_ALLOC_REQ_FLAGS_PATH_RX; + u32 enables; + + req = (struct hwrm_cfa_l2_filter_alloc_input *)bp->hwrm_addr_req; + resp = (struct hwrm_cfa_l2_filter_alloc_output *)bp->hwrm_addr_resp; + enables = CFA_L2_FILTER_ALLOC_REQ_ENABLES_DST_ID | + CFA_L2_FILTER_ALLOC_REQ_ENABLES_L2_ADDR | + CFA_L2_FILTER_ALLOC_REQ_ENABLES_L2_ADDR_MASK; + + hwrm_init(bp, (void *)req, (u16)HWRM_CFA_L2_FILTER_ALLOC, cmd_len); + req->flags = flags; + req->enables = enables; + memcpy((char *)&req->l2_addr[0], (char *)&bp->mac_set[0], ETH_ALEN); + memset((char *)&req->l2_addr_mask[0], 0xff, ETH_ALEN); + memcpy((char *)&req->t_l2_addr[0], (char *)&bp->mac_set[0], ETH_ALEN); + memset((char *)&req->t_l2_addr_mask[0], 0xff, ETH_ALEN); + req->src_type = CFA_L2_FILTER_ALLOC_REQ_SRC_TYPE_NPORT; + req->src_id = (u32)bp->port_idx; + req->dst_id = bp->vnic_id; + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + FLAG_SET(bp->flag_hwrm, VALID_L2_FILTER); + bp->l2_filter_id = resp->l2_filter_id; + + return STATUS_SUCCESS; +} + +static int bnxt_hwrm_cfa_l2_filter_free(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_cfa_l2_filter_free_input); + struct hwrm_cfa_l2_filter_free_input *req; + int rc; + + if (!(FLAG_TEST(bp->flag_hwrm, VALID_L2_FILTER))) + return STATUS_SUCCESS; + + req = (struct hwrm_cfa_l2_filter_free_input *)bp->hwrm_addr_req; + hwrm_init(bp, (void *)req, (u16)HWRM_CFA_L2_FILTER_FREE, cmd_len); + req->l2_filter_id = bp->l2_filter_id; + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + FLAG_RESET(bp->flag_hwrm, VALID_L2_FILTER); + + return STATUS_SUCCESS; +} + +u32 bnxt_set_rx_mask(u32 rx_mask) +{ + u32 mask = 0; + + if (!rx_mask) + return mask; + mask = CFA_L2_SET_RX_MASK_REQ_MASK_BCAST; + if (rx_mask != RX_MASK_ACCEPT_NONE) { + if (rx_mask & RX_MASK_ACCEPT_MULTICAST) + mask |= CFA_L2_SET_RX_MASK_REQ_MASK_MCAST; + + if (rx_mask & RX_MASK_ACCEPT_ALL_MULTICAST) + mask |= CFA_L2_SET_RX_MASK_REQ_MASK_ALL_MCAST; + + if (rx_mask & RX_MASK_PROMISCUOUS_MODE) + mask |= CFA_L2_SET_RX_MASK_REQ_MASK_PROMISCUOUS; + } + + return mask; +} + +static int bnxt_hwrm_set_rx_mask(struct bnxt *bp, u32 rx_mask) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_cfa_l2_set_rx_mask_input); + struct hwrm_cfa_l2_set_rx_mask_input *req; + u32 mask = bnxt_set_rx_mask(rx_mask); + + req = (struct hwrm_cfa_l2_set_rx_mask_input *)bp->hwrm_addr_req; + hwrm_init(bp, (void *)req, (u16)HWRM_CFA_L2_SET_RX_MASK, cmd_len); + req->vnic_id = bp->vnic_id; + req->mask = mask; + + return wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); +} + +static int bnxt_hwrm_port_mac_cfg(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_port_mac_cfg_input); + struct hwrm_port_mac_cfg_input *req; + + req = (struct hwrm_port_mac_cfg_input *)bp->hwrm_addr_req; + hwrm_init(bp, (void *)req, (u16)HWRM_PORT_MAC_CFG, cmd_len); + req->lpbk = PORT_MAC_CFG_REQ_LPBK_NONE; + + return wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); +} + +static int bnxt_hwrm_port_phy_qcfg(struct bnxt *bp, u16 idx) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_port_phy_qcfg_input); + struct hwrm_port_phy_qcfg_input *req; + struct hwrm_port_phy_qcfg_output *resp; + int rc; + + req = (struct hwrm_port_phy_qcfg_input *)bp->hwrm_addr_req; + resp = (struct hwrm_port_phy_qcfg_output *)bp->hwrm_addr_resp; + hwrm_init(bp, (void *)req, (u16)HWRM_PORT_PHY_QCFG, cmd_len); + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + if (idx & SUPPORT_SPEEDS) + bp->support_speeds = resp->support_speeds; + + if (idx & DETECT_MEDIA) + bp->media_detect = resp->module_status; + + if (idx & PHY_SPEED) + bp->current_link_speed = resp->link_speed; + + if (idx & PHY_STATUS) { + if (resp->link == PORT_PHY_QCFG_RESP_LINK_LINK) + bp->link_status = STATUS_LINK_ACTIVE; + else + bp->link_status = STATUS_LINK_DOWN; + } + + return STATUS_SUCCESS; +} + +u16 set_link_speed_mask(u16 link_cap) +{ + u16 speed_mask = 0; + + if (link_cap & SPEED_CAPABILITY_DRV_100M) + speed_mask |= PORT_PHY_CFG_REQ_AUTO_LINK_SPEED_MASK_100MB; + + if (link_cap & SPEED_CAPABILITY_DRV_1G) + speed_mask |= PORT_PHY_CFG_REQ_AUTO_LINK_SPEED_MASK_1GB; + + if (link_cap & SPEED_CAPABILITY_DRV_10G) + speed_mask |= PORT_PHY_CFG_REQ_AUTO_LINK_SPEED_MASK_10GB; + + if (link_cap & SPEED_CAPABILITY_DRV_25G) + speed_mask |= PORT_PHY_CFG_REQ_AUTO_LINK_SPEED_MASK_25GB; + + if (link_cap & SPEED_CAPABILITY_DRV_40G) + speed_mask |= PORT_PHY_CFG_REQ_AUTO_LINK_SPEED_MASK_40GB; + + if (link_cap & SPEED_CAPABILITY_DRV_50G) + speed_mask |= PORT_PHY_CFG_REQ_AUTO_LINK_SPEED_MASK_50GB; + + if (link_cap & SPEED_CAPABILITY_DRV_100G) + speed_mask |= PORT_PHY_CFG_REQ_AUTO_LINK_SPEED_MASK_100GB; + + return speed_mask; +} + +static int bnxt_hwrm_port_phy_cfg(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_port_phy_cfg_input); + struct hwrm_port_phy_cfg_input *req; + u32 flags; + u32 enables = 0; + u16 force_link_speed = 0; + u16 auto_link_speed_mask = 0; + u8 auto_mode = 0; + u8 auto_pause = 0; + u8 auto_duplex = 0; + + /* + * If multi_host or NPAR is set to TRUE, + * do not issue hwrm_port_phy_cfg + */ + if (FLAG_TEST(bp->flags, PORT_PHY_FLAGS)) { + dbg_flags(__func__, bp->flags); + return STATUS_SUCCESS; + } + + req = (struct hwrm_port_phy_cfg_input *)bp->hwrm_addr_req; + flags = PORT_PHY_CFG_REQ_FLAGS_FORCE | + PORT_PHY_CFG_REQ_FLAGS_RESET_PHY; + + switch (GET_MEDIUM_SPEED(bp->medium)) { + case MEDIUM_SPEED_1000MBPS: + force_link_speed = PORT_PHY_CFG_REQ_FORCE_LINK_SPEED_1GB; + break; + case MEDIUM_SPEED_10GBPS: + force_link_speed = PORT_PHY_CFG_REQ_FORCE_LINK_SPEED_10GB; + break; + case MEDIUM_SPEED_25GBPS: + force_link_speed = PORT_PHY_CFG_REQ_FORCE_LINK_SPEED_25GB; + break; + case MEDIUM_SPEED_40GBPS: + force_link_speed = PORT_PHY_CFG_REQ_FORCE_LINK_SPEED_40GB; + break; + case MEDIUM_SPEED_50GBPS: + force_link_speed = PORT_PHY_CFG_REQ_FORCE_LINK_SPEED_50GB; + break; + case MEDIUM_SPEED_100GBPS: + force_link_speed = PORT_PHY_CFG_REQ_FORCE_LINK_SPEED_100GB; + break; + default: + /* Enable AUTONEG by default */ + auto_mode = PORT_PHY_CFG_REQ_AUTO_MODE_SPEED_MASK; + flags &= ~PORT_PHY_CFG_REQ_FLAGS_FORCE; + enables |= PORT_PHY_CFG_REQ_ENABLES_AUTO_MODE | + PORT_PHY_CFG_REQ_ENABLES_AUTO_LINK_SPEED_MASK | + PORT_PHY_CFG_REQ_ENABLES_AUTO_DUPLEX | + PORT_PHY_CFG_REQ_ENABLES_AUTO_PAUSE; + auto_pause = PORT_PHY_CFG_REQ_AUTO_PAUSE_TX | + PORT_PHY_CFG_REQ_AUTO_PAUSE_RX; + auto_duplex = PORT_PHY_CFG_REQ_AUTO_DUPLEX_BOTH; + auto_link_speed_mask = bp->support_speeds; + break; + } + + hwrm_init(bp, (void *)req, (u16)HWRM_PORT_PHY_CFG, cmd_len); + req->flags = flags; + req->enables = enables; + req->port_id = bp->port_idx; + req->force_link_speed = force_link_speed; + req->auto_mode = auto_mode; + req->auto_duplex = auto_duplex; + req->auto_pause = auto_pause; + req->auto_link_speed_mask = auto_link_speed_mask; + + return wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); +} + +static int bnxt_qphy_link(struct bnxt *bp) +{ + u16 flag = QCFG_PHY_ALL; + + /* Query Link Status */ + if (bnxt_hwrm_port_phy_qcfg(bp, flag) != STATUS_SUCCESS) + return STATUS_FAILURE; + + if (bp->link_status != STATUS_LINK_ACTIVE) { + /* + * Configure link if it is not up. + * try to bring link up, but don't return + * failure if port_phy_cfg() fails + */ + bnxt_hwrm_port_phy_cfg(bp); + /* refresh link speed values after bringing link up */ + if (bnxt_hwrm_port_phy_qcfg(bp, flag) != STATUS_SUCCESS) + return STATUS_FAILURE; + } + + return STATUS_SUCCESS; +} + +static int bnxt_hwrm_stat_ctx_alloc(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_stat_ctx_alloc_input); + struct hwrm_stat_ctx_alloc_input *req; + struct hwrm_stat_ctx_alloc_output *resp; + int rc; + + req = (struct hwrm_stat_ctx_alloc_input *)bp->hwrm_addr_req; + resp = (struct hwrm_stat_ctx_alloc_output *)bp->hwrm_addr_resp; + hwrm_init(bp, (void *)req, (u16)HWRM_STAT_CTX_ALLOC, cmd_len); + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + FLAG_SET(bp->flag_hwrm, VALID_STAT_CTX); + bp->stat_ctx_id = (u16)resp->stat_ctx_id; + + return STATUS_SUCCESS; +} + +static int bnxt_hwrm_stat_ctx_free(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_stat_ctx_free_input); + struct hwrm_stat_ctx_free_input *req; + int rc; + + if (!(FLAG_TEST(bp->flag_hwrm, VALID_STAT_CTX))) + return STATUS_SUCCESS; + + req = (struct hwrm_stat_ctx_free_input *)bp->hwrm_addr_req; + hwrm_init(bp, (void *)req, (u16)HWRM_STAT_CTX_FREE, cmd_len); + req->stat_ctx_id = (u32)bp->stat_ctx_id; + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + FLAG_RESET(bp->flag_hwrm, VALID_STAT_CTX); + + return STATUS_SUCCESS; +} + +static int bnxt_hwrm_ring_free_grp(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_ring_grp_free_input); + struct hwrm_ring_grp_free_input *req; + int rc; + + if (!(FLAG_TEST(bp->flag_hwrm, VALID_RING_GRP))) + return STATUS_SUCCESS; + + req = (struct hwrm_ring_grp_free_input *)bp->hwrm_addr_req; + hwrm_init(bp, (void *)req, (u16)HWRM_RING_GRP_FREE, cmd_len); + req->ring_group_id = (u32)bp->ring_grp_id; + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + FLAG_RESET(bp->flag_hwrm, VALID_RING_GRP); + + return STATUS_SUCCESS; +} + +static int bnxt_hwrm_ring_alloc_grp(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_ring_grp_alloc_input); + struct hwrm_ring_grp_alloc_input *req; + struct hwrm_ring_grp_alloc_output *resp; + int rc; + + req = (struct hwrm_ring_grp_alloc_input *)bp->hwrm_addr_req; + resp = (struct hwrm_ring_grp_alloc_output *)bp->hwrm_addr_resp; + hwrm_init(bp, (void *)req, (u16)HWRM_RING_GRP_ALLOC, cmd_len); + req->cr = bp->cq_ring_id; + req->rr = bp->rx_ring_id; + req->ar = (u16)HWRM_NA_SIGNATURE; + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + FLAG_SET(bp->flag_hwrm, VALID_RING_GRP); + bp->ring_grp_id = (u16)resp->ring_group_id; + + return STATUS_SUCCESS; +} + +int bnxt_hwrm_ring_free(struct bnxt *bp, u16 ring_id, u8 ring_type) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_ring_free_input); + struct hwrm_ring_free_input *req; + + req = (struct hwrm_ring_free_input *)bp->hwrm_addr_req; + hwrm_init(bp, (void *)req, (u16)HWRM_RING_FREE, cmd_len); + req->ring_type = ring_type; + req->ring_id = ring_id; + + return wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); +} + +static int bnxt_hwrm_ring_alloc(struct bnxt *bp, + dma_addr_t ring_map, + u16 length, + u16 ring_id, + u8 ring_type, + u8 int_mode) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_ring_alloc_input); + struct hwrm_ring_alloc_input *req; + struct hwrm_ring_alloc_output *resp; + int rc; + + req = (struct hwrm_ring_alloc_input *)bp->hwrm_addr_req; + resp = (struct hwrm_ring_alloc_output *)bp->hwrm_addr_resp; + hwrm_init(bp, (void *)req, (u16)HWRM_RING_ALLOC, cmd_len); + req->ring_type = ring_type; + req->page_tbl_addr = ring_map; + req->page_size = LM_PAGE_SIZE; + req->length = (u32)length; + req->cmpl_ring_id = ring_id; + req->int_mode = int_mode; + if (ring_type == RING_ALLOC_REQ_RING_TYPE_TX) { + req->queue_id = TX_RING_QID; + } else if (ring_type == RING_ALLOC_REQ_RING_TYPE_RX) { + req->queue_id = RX_RING_QID; + req->enables = RING_ALLOC_REQ_ENABLES_RX_BUF_SIZE_VALID; + req->rx_buf_size = MAX_ETHERNET_PACKET_BUFFER_SIZE; + } + + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + if (ring_type == RING_ALLOC_REQ_RING_TYPE_L2_CMPL) { + FLAG_SET(bp->flag_hwrm, VALID_RING_CQ); + bp->cq_ring_id = resp->ring_id; + } else if (ring_type == RING_ALLOC_REQ_RING_TYPE_TX) { + FLAG_SET(bp->flag_hwrm, VALID_RING_TX); + bp->tx_ring_id = resp->ring_id; + } else if (ring_type == RING_ALLOC_REQ_RING_TYPE_RX) { + FLAG_SET(bp->flag_hwrm, VALID_RING_RX); + bp->rx_ring_id = resp->ring_id; + } + + return STATUS_SUCCESS; +} + +static int bnxt_hwrm_ring_alloc_cq(struct bnxt *bp) +{ + return bnxt_hwrm_ring_alloc(bp, + virt_to_bus(bp->cq.bd_virt), + bp->cq.ring_cnt, + 0, + RING_ALLOC_REQ_RING_TYPE_L2_CMPL, + BNXT_CQ_INTR_MODE()); +} + +static int bnxt_hwrm_ring_alloc_tx(struct bnxt *bp) +{ + return bnxt_hwrm_ring_alloc(bp, + virt_to_bus(bp->tx.bd_virt), + bp->tx.ring_cnt, bp->cq_ring_id, + RING_ALLOC_REQ_RING_TYPE_TX, + BNXT_INTR_MODE()); +} + +static int bnxt_hwrm_ring_alloc_rx(struct bnxt *bp) +{ + return bnxt_hwrm_ring_alloc(bp, + virt_to_bus(bp->rx.bd_virt), + bp->rx.ring_cnt, + bp->cq_ring_id, + RING_ALLOC_REQ_RING_TYPE_RX, + BNXT_INTR_MODE()); +} + +static int bnxt_hwrm_ring_free_cq(struct bnxt *bp) +{ + int ret = STATUS_SUCCESS; + + if (!(FLAG_TEST(bp->flag_hwrm, VALID_RING_CQ))) + return ret; + + ret = RING_FREE(bp, bp->cq_ring_id, RING_FREE_REQ_RING_TYPE_L2_CMPL); + if (ret == STATUS_SUCCESS) + FLAG_RESET(bp->flag_hwrm, VALID_RING_CQ); + + return ret; +} + +static int bnxt_hwrm_ring_free_tx(struct bnxt *bp) +{ + int ret = STATUS_SUCCESS; + + if (!(FLAG_TEST(bp->flag_hwrm, VALID_RING_TX))) + return ret; + + ret = RING_FREE(bp, bp->tx_ring_id, RING_FREE_REQ_RING_TYPE_TX); + if (ret == STATUS_SUCCESS) + FLAG_RESET(bp->flag_hwrm, VALID_RING_TX); + + return ret; +} + +static int bnxt_hwrm_ring_free_rx(struct bnxt *bp) +{ + int ret = STATUS_SUCCESS; + + if (!(FLAG_TEST(bp->flag_hwrm, VALID_RING_RX))) + return ret; + + ret = RING_FREE(bp, bp->rx_ring_id, RING_FREE_REQ_RING_TYPE_RX); + if (ret == STATUS_SUCCESS) + FLAG_RESET(bp->flag_hwrm, VALID_RING_RX); + + return ret; +} + +static int bnxt_hwrm_vnic_alloc(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_vnic_alloc_input); + struct hwrm_vnic_alloc_input *req; + struct hwrm_vnic_alloc_output *resp; + int rc; + + req = (struct hwrm_vnic_alloc_input *)bp->hwrm_addr_req; + resp = (struct hwrm_vnic_alloc_output *)bp->hwrm_addr_resp; + hwrm_init(bp, (void *)req, (u16)HWRM_VNIC_ALLOC, cmd_len); + req->flags = VNIC_ALLOC_REQ_FLAGS_DEFAULT; + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + FLAG_SET(bp->flag_hwrm, VALID_VNIC_ID); + bp->vnic_id = resp->vnic_id; + + return STATUS_SUCCESS; +} + +static int bnxt_hwrm_vnic_free(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_vnic_free_input); + struct hwrm_vnic_free_input *req; + int rc; + + if (!(FLAG_TEST(bp->flag_hwrm, VALID_VNIC_ID))) + return STATUS_SUCCESS; + + req = (struct hwrm_vnic_free_input *)bp->hwrm_addr_req; + hwrm_init(bp, (void *)req, (u16)HWRM_VNIC_FREE, cmd_len); + req->vnic_id = bp->vnic_id; + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + if (rc) + return STATUS_FAILURE; + + FLAG_RESET(bp->flag_hwrm, VALID_VNIC_ID); + + return STATUS_SUCCESS; +} + +static int bnxt_hwrm_vnic_cfg(struct bnxt *bp) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_vnic_cfg_input); + struct hwrm_vnic_cfg_input *req; + + req = (struct hwrm_vnic_cfg_input *)bp->hwrm_addr_req; + hwrm_init(bp, (void *)req, (u16)HWRM_VNIC_CFG, cmd_len); + req->enables = VNIC_CFG_REQ_ENABLES_MRU; + req->mru = bp->mtu; + req->enables |= VNIC_CFG_REQ_ENABLES_DFLT_RING_GRP; + req->dflt_ring_grp = bp->ring_grp_id; + req->vnic_id = bp->vnic_id; + + return wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); +} + +static int set_phy_speed(struct bnxt *bp) +{ + char name[20]; + u16 flag = PHY_STATUS | PHY_SPEED | DETECT_MEDIA; + + /* Query Link Status */ + if (bnxt_hwrm_port_phy_qcfg(bp, flag) != STATUS_SUCCESS) + return STATUS_FAILURE; + + switch (bp->current_link_speed) { + case PORT_PHY_QCFG_RESP_LINK_SPEED_100GB: + sprintf(name, "%s %s", str_100, str_gbps); + break; + case PORT_PHY_QCFG_RESP_LINK_SPEED_50GB: + sprintf(name, "%s %s", str_50, str_gbps); + break; + case PORT_PHY_QCFG_RESP_LINK_SPEED_40GB: + sprintf(name, "%s %s", str_40, str_gbps); + break; + case PORT_PHY_QCFG_RESP_LINK_SPEED_25GB: + sprintf(name, "%s %s", str_25, str_gbps); + break; + case PORT_PHY_QCFG_RESP_LINK_SPEED_20GB: + sprintf(name, "%s %s", str_20, str_gbps); + break; + case PORT_PHY_QCFG_RESP_LINK_SPEED_10GB: + sprintf(name, "%s %s", str_10, str_gbps); + break; + case PORT_PHY_QCFG_RESP_LINK_SPEED_2_5GB: + sprintf(name, "%s %s", str_2_5, str_gbps); + break; + case PORT_PHY_QCFG_RESP_LINK_SPEED_2GB: + sprintf(name, "%s %s", str_2, str_gbps); + break; + case PORT_PHY_QCFG_RESP_LINK_SPEED_1GB: + sprintf(name, "%s %s", str_1, str_gbps); + break; + case PORT_PHY_QCFG_RESP_LINK_SPEED_100MB: + sprintf(name, "%s %s", str_100, str_mbps); + break; + case PORT_PHY_QCFG_RESP_LINK_SPEED_10MB: + sprintf(name, "%s %s", str_10, str_mbps); + break; + default: + sprintf(name, "%s %x", str_unknown, bp->current_link_speed); + } + + dbg_phy_speed(bp, name); + + return STATUS_SUCCESS; +} + +static int set_phy_link(struct bnxt *bp, u32 tmo) +{ + int ret; + + set_phy_speed(bp); + dbg_link_status(bp); + ret = STATUS_FAILURE; + if (bp->link_status == STATUS_LINK_ACTIVE) { + dbg_link_state(bp, tmo); + ret = STATUS_SUCCESS; + } + + return ret; +} + +static int get_phy_link(struct bnxt *bp) +{ + u16 flag = PHY_STATUS | PHY_SPEED | DETECT_MEDIA; + + dbg_chip_info(bp); + /* Query Link Status */ + if (bnxt_hwrm_port_phy_qcfg(bp, flag) != STATUS_SUCCESS) + return STATUS_FAILURE; + + set_phy_link(bp, 100); + + return STATUS_SUCCESS; +} + +static int bnxt_hwrm_set_async_event(struct bnxt *bp) +{ + int rc; + u16 cmd_len = (u16)sizeof(struct hwrm_func_cfg_input); + struct hwrm_func_cfg_input *req; + + req = (struct hwrm_func_cfg_input *)bp->hwrm_addr_req; + hwrm_init(bp, (void *)req, (u16)HWRM_FUNC_CFG, cmd_len); + req->fid = (u16)HWRM_NA_SIGNATURE; + req->enables = FUNC_CFG_REQ_ENABLES_ASYNC_EVENT_CR; + req->async_event_cr = bp->cq_ring_id; + rc = wait_resp(bp, bp->hwrm_cmd_timeout, cmd_len, __func__); + + return rc; +} + +int bnxt_hwrm_get_nvmem(struct bnxt *bp, + u16 data_len, + u16 option_num, + u16 dimensions, + u16 index_0) +{ + u16 cmd_len = (u16)sizeof(struct hwrm_nvm_get_variable_input); + struct hwrm_nvm_get_variable_input *req; + + req = (struct hwrm_nvm_get_variable_input *)bp->hwrm_addr_req; + hwrm_init(bp, (void *)req, (u16)HWRM_NVM_GET_VARIABLE, cmd_len); + req->dest_data_addr = bp->data_addr_mapping; + req->data_len = data_len; + req->option_num = option_num; + req->dimensions = dimensions; + req->index_0 = index_0; + + return wait_resp(bp, + HWRM_CMD_FLASH_MULTIPLAYER(bp->hwrm_cmd_timeout), + cmd_len, + __func__); +} + +static void set_medium(struct bnxt *bp) +{ + switch (bp->link_set & LINK_SPEED_DRV_MASK) { + case LINK_SPEED_DRV_1G: + bp->medium = SET_MEDIUM_SPEED(bp, MEDIUM_SPEED_1000MBPS); + break; + case LINK_SPEED_DRV_2_5G: + bp->medium = SET_MEDIUM_SPEED(bp, MEDIUM_SPEED_2500MBPS); + break; + case LINK_SPEED_DRV_10G: + bp->medium = SET_MEDIUM_SPEED(bp, MEDIUM_SPEED_10GBPS); + break; + case LINK_SPEED_DRV_25G: + bp->medium = SET_MEDIUM_SPEED(bp, MEDIUM_SPEED_25GBPS); + break; + case LINK_SPEED_DRV_40G: + bp->medium = SET_MEDIUM_SPEED(bp, MEDIUM_SPEED_40GBPS); + break; + case LINK_SPEED_DRV_50G: + bp->medium = SET_MEDIUM_SPEED(bp, MEDIUM_SPEED_50GBPS); + break; + case LINK_SPEED_DRV_100G: + bp->medium = SET_MEDIUM_SPEED(bp, MEDIUM_SPEED_100GBPS); + break; + case LINK_SPEED_DRV_200G: + bp->medium = SET_MEDIUM_SPEED(bp, MEDIUM_SPEED_200GBPS); + break; + case LINK_SPEED_DRV_AUTONEG: + bp->medium = SET_MEDIUM_SPEED(bp, MEDIUM_SPEED_AUTONEG); + break; + default: + bp->medium = SET_MEDIUM_DUPLEX(bp, MEDIUM_FULL_DUPLEX); + break; + } +} + +static int bnxt_hwrm_get_link_speed(struct bnxt *bp) +{ + u32 *ptr32 = (u32 *)bp->hwrm_addr_data; + + if (bnxt_hwrm_get_nvmem(bp, + 4, + (u16)LINK_SPEED_DRV_NUM, + 1, + (u16)bp->port_idx) != STATUS_SUCCESS) + return STATUS_FAILURE; + + bp->link_set = *ptr32; + bp->link_set &= SPEED_DRV_MASK; + set_medium(bp); + + return STATUS_SUCCESS; +} + +typedef int (*hwrm_func_t)(struct bnxt *bp); + +hwrm_func_t down_chip[] = { + bnxt_hwrm_cfa_l2_filter_free, /* Free l2 filter */ + bnxt_free_rx_iob, /* Free rx iob */ + bnxt_hwrm_vnic_free, /* Free vnic */ + bnxt_hwrm_ring_free_grp, /* Free ring group */ + bnxt_hwrm_ring_free_rx, /* Free rx ring */ + bnxt_hwrm_ring_free_tx, /* Free tx ring */ + bnxt_hwrm_ring_free_cq, /* Free CQ ring */ + bnxt_hwrm_stat_ctx_free, /* Free Stat ctx */ + bnxt_hwrm_func_drv_unrgtr, /* unreg driver */ + NULL, +}; + +hwrm_func_t bring_chip[] = { + bnxt_hwrm_ver_get, /* HWRM_VER_GET */ + bnxt_hwrm_func_reset_req, /* HWRM_FUNC_RESET */ + bnxt_hwrm_func_drv_rgtr, /* HWRM_FUNC_DRV_RGTR */ + bnxt_hwrm_func_resource_qcaps, /* HWRM_FUNC_RESOURCE_QCAPS */ + bnxt_hwrm_func_qcfg_req, /* HWRM_FUNC_QCFG */ + bnxt_hwrm_func_qcaps_req, /* HWRM_FUNC_QCAPS */ + bnxt_hwrm_get_link_speed, /* HWRM_NVM_GET_VARIABLE - 203 */ + bnxt_hwrm_port_mac_cfg, /* HWRM_PORT_MAC_CFG */ + bnxt_qphy_link, /* HWRM_PORT_PHY_QCFG */ + bnxt_hwrm_func_cfg_req, /* HWRM_FUNC_CFG - ring resource*/ + bnxt_hwrm_stat_ctx_alloc, /* Allocate Stat Ctx ID */ + bnxt_hwrm_ring_alloc_cq, /* Allocate CQ Ring */ + bnxt_hwrm_ring_alloc_tx, /* Allocate Tx ring */ + bnxt_hwrm_ring_alloc_rx, /* Allocate Rx Ring */ + bnxt_hwrm_ring_alloc_grp, /* Create Ring Group */ + post_rx_buffers, /* Post RX buffers */ + bnxt_hwrm_set_async_event, /* ENABLES_ASYNC_EVENT_CR */ + bnxt_hwrm_vnic_alloc, /* Alloc VNIC */ + bnxt_hwrm_vnic_cfg, /* Config VNIC */ + bnxt_hwrm_cfa_l2_filter_alloc, /* Alloc L2 Filter */ + get_phy_link, /* Get Physical Link */ + NULL, +}; + +int bnxt_hwrm_run(hwrm_func_t cmds[], struct bnxt *bp, int flag) +{ + hwrm_func_t *ptr; + int ret; + int status = STATUS_SUCCESS; + + for (ptr = cmds; *ptr; ++ptr) { + ret = (*ptr)(bp); + if (ret) { + status = STATUS_FAILURE; + /* Continue till all cleanup routines are called */ + if (flag) + return STATUS_FAILURE; + } + } + + return status; +} + +/* Broadcom ethernet driver Network interface APIs. */ +static int bnxt_start(struct udevice *dev) +{ + struct bnxt *bp = dev_get_priv(dev); + + if (bnxt_hwrm_set_rx_mask(bp, RX_MASK) != STATUS_SUCCESS) + return STATUS_FAILURE; + + bp->card_en = true; + return STATUS_SUCCESS; +} + +static int bnxt_send(struct udevice *dev, void *packet, int length) +{ + struct bnxt *bp = dev_get_priv(dev); + int len; + u16 entry; + dma_addr_t mapping; + + if (bnxt_tx_avail(bp) < 1) { + dbg_no_tx_bd(); + return -ENOBUFS; + } + + entry = bp->tx.prod_id; + len = iob_pad(packet, length); + mapping = virt_to_bus(packet); + set_txq(bp, entry, mapping, len); + entry = NEXT_IDX(entry, bp->tx.ring_cnt); + dump_tx_pkt(packet, mapping, len); + bnxt_db_tx(bp, (u32)entry); + bp->tx.prod_id = entry; + bp->tx.cnt_req++; + bnxt_tx_complete(bp); + + return 0; +} + +static void bnxt_link_evt(struct bnxt *bp, struct cmpl_base *cmp) +{ + struct hwrm_async_event_cmpl *evt; + + evt = (struct hwrm_async_event_cmpl *)cmp; + switch (evt->event_id) { + case ASYNC_EVENT_CMPL_EVENT_ID_LINK_STATUS_CHANGE: + if (evt->event_data1 & 0x01) + bp->link_status = STATUS_LINK_ACTIVE; + else + bp->link_status = STATUS_LINK_DOWN; + + set_phy_link(bp, 0); + break; + default: + break; + } +} + +static int bnxt_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct bnxt *bp = dev_get_priv(dev); + struct cmpl_base *cmp; + u16 old_cons_idx = bp->cq.cons_idx; + int done = SERVICE_NEXT_CQ_BD; + u32 cq_type; + + while (done == SERVICE_NEXT_CQ_BD) { + cmp = (struct cmpl_base *)BD_NOW(bp->cq.bd_virt, + bp->cq.cons_idx, + sizeof(struct cmpl_base)); + if ((cmp->info3_v & CMPL_BASE_V) ^ bp->cq.completion_bit) + break; + + cq_type = cmp->type & CMPL_BASE_TYPE_MASK; + dump_evt((u8 *)cmp, cq_type, bp->cq.cons_idx); + dump_CQ(cmp, bp->cq.cons_idx); + switch (cq_type) { + case CMPL_BASE_TYPE_HWRM_ASYNC_EVENT: + bnxt_link_evt(bp, cmp); + fallthrough; + case CMPL_BASE_TYPE_TX_L2: + case CMPL_BASE_TYPE_STAT_EJECT: + bnxt_adv_cq_index(bp, 1); + break; + case CMPL_BASE_TYPE_RX_L2: + done = bnxt_rx_complete(bp, (struct rx_pkt_cmpl *)cmp); + break; + default: + done = NO_MORE_CQ_BD_TO_SERVICE; + break; + } + } + + if (bp->cq.cons_idx != old_cons_idx) + bnxt_db_cq(bp); + + if (bp->rx.iob_recv == PKT_RECEIVED) { + *packetp = bp->rx.iob_rx; + return bp->rx.iob_len; + } + + return -EAGAIN; +} + +static void bnxt_stop(struct udevice *dev) +{ + struct bnxt *bp = dev_get_priv(dev); + + if (bp->card_en) { + bnxt_hwrm_set_rx_mask(bp, 0); + bp->card_en = false; + } +} + +static int bnxt_free_pkt(struct udevice *dev, uchar *packet, int length) +{ + struct bnxt *bp = dev_get_priv(dev); + + dbg_rx_pkt(bp, __func__, packet, length); + bp->rx.iob_recv = PKT_DONE; + bp->rx.iob_len = 0; + bp->rx.iob_rx = NULL; + + return 0; +} + +static int bnxt_read_rom_hwaddr(struct udevice *dev) +{ + struct eth_pdata *plat = dev_get_plat(dev); + struct bnxt *bp = dev_get_priv(dev); + int ret; + + ret = bnxt_alloc_mem(bp); + if (ret) { + printf("*** error: bnxt_alloc_mem failed! ***\n"); + return ret; + } + bp->pdev = (struct udevice *)dev; + bnxt_bring_pci(bp); + ret = bnxt_bring_chip(bp); + if (ret) { + printf("*** error: bnxt_bring_chip failed! ***\n"); + return -ENODATA; + } + memcpy(plat->enetaddr, bp->mac_set, ETH_ALEN); + + return 0; +} + +static const struct eth_ops bnxt_eth_ops = { + .start = bnxt_start, + .send = bnxt_send, + .recv = bnxt_recv, + .stop = bnxt_stop, + .free_pkt = bnxt_free_pkt, + .read_rom_hwaddr = bnxt_read_rom_hwaddr, +}; + +static const struct udevice_id bnxt_eth_ids[] = { + { .compatible = "broadcom,nxe" }, + { } +}; + +static int bnxt_eth_bind(struct udevice *dev) +{ + char name[20]; + + sprintf(name, "bnxt_eth%u", dev_seq(dev)); + + return device_set_name(dev, name); +} + +static int bnxt_eth_probe(struct udevice *dev) +{ + struct bnxt *bp = dev_get_priv(dev); + + bp->name = dev->name; + bp->cardnum = dev_seq(dev); + + return 0; +} + +static int bnxt_eth_remove(struct udevice *dev) +{ + struct bnxt *bp = dev_get_priv(dev); + + bnxt_down_chip(bp); + bnxt_free_mem(bp); + + return 0; +} + +static struct pci_device_id bnxt_nics[] = { + {PCI_DEVICE(PCI_VENDOR_ID_BROADCOM, PCI_DEVICE_ID_NXT_57320)}, + {} +}; + +U_BOOT_DRIVER(eth_bnxt) = { + .name = "eth_bnxt", + .id = UCLASS_ETH, + .of_match = bnxt_eth_ids, + .bind = bnxt_eth_bind, + .probe = bnxt_eth_probe, + .remove = bnxt_eth_remove, + .ops = &bnxt_eth_ops, + .priv_auto = sizeof(struct bnxt), + .plat_auto = sizeof(struct eth_pdata), + .flags = DM_FLAG_ACTIVE_DMA, +}; + +U_BOOT_PCI_DEVICE(eth_bnxt, bnxt_nics); diff --git a/drivers/net/bnxt/bnxt.h b/drivers/net/bnxt/bnxt.h new file mode 100644 index 000000000000..6c648272af1b --- /dev/null +++ b/drivers/net/bnxt/bnxt.h @@ -0,0 +1,390 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019-2021 Broadcom. + */ + +#ifndef _BNXT_H_ +#define _BNXT_H_ + +#include <pci.h> +#include <linux/if_ether.h> + +#include "bnxt_hsi.h" + +union dma_addr64_t { + dma_addr_t addr; + u64 as_u64; +}; + +#define DRIVER_VERSION_MAJOR 1 +#define DRIVER_VERSION_MINOR 0 +#define DRIVER_VERSION_UPDATE 0 + +/* Broadcom ethernet driver defines. */ +#define FLAG_SET(f, b) ((f) |= (b)) +#define FLAG_TEST(f, b) ((f) & (b)) +#define FLAG_RESET(f, b) ((f) &= ~(b)) +#define BNXT_FLAG_HWRM_SHORT_CMD_SUPP BIT(0) +#define BNXT_FLAG_HWRM_SHORT_CMD_REQ BIT(1) +#define BNXT_FLAG_RESOURCE_QCAPS_SUPPORT BIT(2) +#define BNXT_FLAG_MULTI_HOST BIT(3) +#define BNXT_FLAG_NPAR_MODE BIT(4) +/******************************************************************************* + * Status codes. + ******************************************************************************/ +#define STATUS_SUCCESS 0 +#define STATUS_FAILURE 1 +#define STATUS_LINK_ACTIVE 4 +#define STATUS_LINK_DOWN 5 +#define STATUS_TIMEOUT 0xffff +/******************************************************************************* + * Receive filter masks. + ******************************************************************************/ +#define RX_MASK_ACCEPT_NONE 0x0000 +#define RX_MASK_ACCEPT_MULTICAST 0x0002 +#define RX_MASK_ACCEPT_ALL_MULTICAST 0x0004 +#define RX_MASK_ACCEPT_BROADCAST 0x0008 +#define RX_MASK_PROMISCUOUS_MODE 0x10000 +/******************************************************************************* + * media speed. + ******************************************************************************/ +#define MEDIUM_SPEED_AUTONEG 0x0000L +#define MEDIUM_SPEED_1000MBPS 0x0300L +#define MEDIUM_SPEED_2500MBPS 0x0400L +#define MEDIUM_SPEED_10GBPS 0x0600L +#define MEDIUM_SPEED_25GBPS 0x0800L +#define MEDIUM_SPEED_40GBPS 0x0900L +#define MEDIUM_SPEED_50GBPS 0x0a00L +#define MEDIUM_SPEED_100GBPS 0x0b00L +#define MEDIUM_SPEED_200GBPS 0x0c00L +#define MEDIUM_SPEED_MASK 0xff00L +#define GET_MEDIUM_SPEED(m) ((m) & MEDIUM_SPEED_MASK) +#define SET_MEDIUM_SPEED(bp, s) (((bp)->medium & ~MEDIUM_SPEED_MASK) | (s)) +#define MEDIUM_UNKNOWN_DUPLEX 0x00000L +#define MEDIUM_FULL_DUPLEX 0x00000L +#define MEDIUM_HALF_DUPLEX 0x10000L +#define GET_MEDIUM_DUPLEX(m) ((m) & MEDIUM_HALF_DUPLEX) +#define SET_MEDIUM_DUPLEX(bp, d) (((bp)->medium & ~MEDIUM_HALF_DUPLEX) | (d)) +#define MEDIUM_SELECTIVE_AUTONEG 0x01000000L +#define GET_MEDIUM_AUTONEG_MODE(m) ((m) & 0xff000000L) +#define GRC_COM_CHAN_BASE 0 +#define GRC_COM_CHAN_TRIG 0x100 +#define HWRM_CMD_DEFAULT_TIMEOUT 500 /* in Miliseconds */ +#define HWRM_CMD_POLL_WAIT_TIME 100 /* In MicroeSconds */ +#define HWRM_CMD_DEFAULT_MULTIPLAYER(a) ((a) * 10) +#define HWRM_CMD_FLASH_MULTIPLAYER(a) ((a) * 100) +#define HWRM_CMD_FLASH_ERASE_MULTIPLAYER(a) ((a) * 1000) +#define MAX_ETHERNET_PACKET_BUFFER_SIZE 1536 +#define DEFAULT_NUMBER_OF_CMPL_RINGS 0x01 +#define DEFAULT_NUMBER_OF_TX_RINGS 0x01 +#define DEFAULT_NUMBER_OF_RX_RINGS 0x01 +#define DEFAULT_NUMBER_OF_RING_GRPS 0x01 +#define DEFAULT_NUMBER_OF_STAT_CTXS 0x01 +#define NUM_RX_BUFFERS 512 +#define MAX_RX_DESC_CNT 1024 +#define MAX_TX_DESC_CNT 512 +#define MAX_CQ_DESC_CNT 2048 +#define TX_RING_DMA_BUFFER_SIZE (MAX_TX_DESC_CNT * sizeof(struct tx_bd_short)) +#define RX_RING_DMA_BUFFER_SIZE \ + (MAX_RX_DESC_CNT * sizeof(struct rx_prod_pkt_bd)) +#define CQ_RING_DMA_BUFFER_SIZE (MAX_CQ_DESC_CNT * sizeof(struct cmpl_base)) +#define BNXT_DMA_ALIGNMENT 256 //64 +#define REQ_BUFFER_SIZE 1024 +#define RESP_BUFFER_SIZE 1024 +#define DMA_BUFFER_SIZE 1024 +#define LM_PAGE_BITS 8 +#define BNXT_RX_STD_DMA_SZ 1536 +#define NEXT_IDX(N, S) (((N) + 1) & ((S) - 1)) +#define BD_NOW(bd, entry, len) (&((u8 *)(bd))[(entry) * (len)]) +#define BNXT_CQ_INTR_MODE() RING_ALLOC_REQ_INT_MODE_POLL +#define BNXT_INTR_MODE() RING_ALLOC_REQ_INT_MODE_POLL +/* Set default link timeout period to 500 millseconds */ +#define LINK_DEFAULT_TIMEOUT 500 +#define RX_MASK \ + (RX_MASK_ACCEPT_BROADCAST | \ + RX_MASK_ACCEPT_ALL_MULTICAST | \ + RX_MASK_ACCEPT_MULTICAST) +#define TX_RING_QID ((u16)bp->port_idx * 10) +#define RX_RING_QID 0 +#define LM_PAGE_SIZE LM_PAGE_BITS +#define virt_to_bus(a) ((dma_addr_t)(a)) +#define REQ_BUF_SIZE_ALIGNED ALIGN(REQ_BUFFER_SIZE, BNXT_DMA_ALIGNMENT) +#define RESP_BUF_SIZE_ALIGNED ALIGN(RESP_BUFFER_SIZE, BNXT_DMA_ALIGNMENT) +#define DMA_BUF_SIZE_ALIGNED ALIGN(DMA_BUFFER_SIZE, BNXT_DMA_ALIGNMENT) +#define RX_STD_DMA_ALIGNED ALIGN(BNXT_RX_STD_DMA_SZ, BNXT_DMA_ALIGNMENT) +#define PCI_COMMAND_INTX_DISABLE 0x0400 /* Interrupt disable */ +#define TX_AVAIL(r) ((r) - 1) +#define NO_MORE_CQ_BD_TO_SERVICE 1 +#define SERVICE_NEXT_CQ_BD 0 +#define PHY_STATUS 0x0001 +#define PHY_SPEED 0x0002 +#define DETECT_MEDIA 0x0004 +#define SUPPORT_SPEEDS 0x0008 +#define str_1 "1" +#define str_2 "2" +#define str_2_5 "2.5" +#define str_10 "10" +#define str_20 "20" +#define str_25 "25" +#define str_40 "40" +#define str_50 "50" +#define str_100 "100" +#define str_gbps "Gbps" +#define str_mbps "Mbps" +#define str_unknown "Unknown" +/* Broadcom ethernet driver nvm defines. */ +/* nvm cfg 1 - MAC settings */ +#define FUNC_MAC_ADDR_NUM 1 +/* nvm cfg 203 - u32 link_settings */ +#define LINK_SPEED_DRV_NUM 203 +#define LINK_SPEED_DRV_MASK 0x0000000F +#define LINK_SPEED_DRV_SHIFT 0 +#define LINK_SPEED_DRV_AUTONEG 0x0 +#define LINK_SPEED_DRV_1G 0x1 +#define LINK_SPEED_DRV_10G 0x2 +#define LINK_SPEED_DRV_25G 0x3 +#define LINK_SPEED_DRV_40G 0x4 +#define LINK_SPEED_DRV_50G 0x5 +#define LINK_SPEED_DRV_100G 0x6 +#define LINK_SPEED_DRV_200G 0x7 +#define LINK_SPEED_DRV_2_5G 0xE +#define LINK_SPEED_DRV_100M 0xF +/* nvm cfg 201 - u32 speed_cap_mask */ +#define SPEED_CAPABILITY_DRV_1G 0x1 +#define SPEED_CAPABILITY_DRV_10G 0x2 +#define SPEED_CAPABILITY_DRV_25G 0x4 +#define SPEED_CAPABILITY_DRV_40G 0x8 +#define SPEED_CAPABILITY_DRV_50G 0x10 +#define SPEED_CAPABILITY_DRV_100G 0x20 +#define SPEED_CAPABILITY_DRV_100M 0x8000 +/* nvm cfg 202 */ +/* nvm cfg 205 */ +#define LINK_SPEED_FW_NUM 205 +/* nvm cfg 210 */ +/* nvm cfg 211 */ +/* nvm cfg 213 */ +#define SPEED_DRV_MASK LINK_SPEED_DRV_MASK +/****************************************************************************** + * Doorbell info. + *****************************************************************************/ +#define RX_DOORBELL_KEY_RX (0x1UL << 28) +#define TX_DOORBELL_KEY_TX (0x0UL << 28) + +#define CMPL_DOORBELL_IDX_VALID 0x4000000UL +#define CMPL_DOORBELL_KEY_CMPL (0x2UL << 28) + +/****************************************************************************** + * Transmit info. + *****************************************************************************/ +struct tx_bd_short { + u16 flags_type; +#define TX_BD_SHORT_TYPE_TX_BD_SHORT 0x0UL +#define TX_BD_SHORT_FLAGS_PACKET_END 0x40UL +#define TX_BD_SHORT_FLAGS_NO_CMPL 0x80UL +#define TX_BD_SHORT_FLAGS_BD_CNT_SFT 8 +#define TX_BD_SHORT_FLAGS_LHINT_LT512 (0x0UL << 13) +#define TX_BD_SHORT_FLAGS_LHINT_LT1K (0x1UL << 13) +#define TX_BD_SHORT_FLAGS_LHINT_LT2K (0x2UL << 13) +#define TX_BD_SHORT_FLAGS_LHINT_GTE2K (0x3UL << 13) +#define TX_BD_SHORT_FLAGS_COAL_NOW 0x8000UL + u16 len; + u32 opaque; + union dma_addr64_t dma; +}; + +struct lm_tx_info_t { + void *bd_virt; + u16 prod_id; /* Tx producer index. */ + u16 cons_id; + u16 ring_cnt; + u32 cnt; /* Tx statistics. */ + u32 cnt_req; +}; + +struct cmpl_base { + u16 type; +#define CMPL_BASE_TYPE_MASK 0x3fUL +#define CMPL_BASE_TYPE_TX_L2 0x0UL +#define CMPL_BASE_TYPE_RX_L2 0x11UL +#define CMPL_BASE_TYPE_STAT_EJECT 0x1aUL +#define CMPL_BASE_TYPE_HWRM_ASYNC_EVENT 0x2eUL + u16 info1; + u32 info2; + u32 info3_v; +#define CMPL_BASE_V 0x1UL + u32 info4; +}; + +struct lm_cmp_info_t { + void *bd_virt; + u16 cons_idx; + u16 ring_cnt; + u8 completion_bit; + u8 res[3]; +}; + +struct rx_pkt_cmpl { + u16 flags_type; + u16 len; + u32 opaque; + u8 agg_bufs_v1; + u8 rss_hash_type; + u8 payload_offset; + u8 unused1; + u32 rss_hash; +}; + +struct rx_pkt_cmpl_hi { + u32 flags2; + u32 metadata; + u16 errors_v2; +#define RX_PKT_CMPL_V2 0x1UL +#define RX_PKT_CMPL_ERRORS_BUFFER_ERROR_SFT 1 + u16 cfa_code; + u32 reorder; +}; + +struct rx_prod_pkt_bd { + u16 flags_type; +#define RX_PROD_PKT_BD_TYPE_RX_PROD_PKT 0x4UL + u16 len; + u32 opaque; + union dma_addr64_t dma; +}; + +struct lm_rx_info_t { + void *bd_virt; + void *iob[NUM_RX_BUFFERS]; + void *iob_rx; + u16 iob_len; + u16 iob_recv; + u16 iob_cnt; + u16 buf_cnt; /* Total Rx buffer descriptors. */ + u16 ring_cnt; + u16 cons_idx; /* Last processed consumer index. */ + u32 rx_cnt; + u32 rx_buf_cnt; + u32 err; + u32 crc; + u32 dropped; +}; + +#define VALID_DRIVER_REG 0x0001 +#define VALID_STAT_CTX 0x0002 +#define VALID_RING_CQ 0x0004 +#define VALID_RING_TX 0x0008 +#define VALID_RING_RX 0x0010 +#define VALID_RING_GRP 0x0020 +#define VALID_VNIC_ID 0x0040 +#define VALID_RX_IOB 0x0080 +#define VALID_L2_FILTER 0x0100 + +enum RX_FLAGS { + PKT_DONE = 0, + PKT_RECEIVED = 1, + PKT_DROPPED = 2, +}; + +struct bnxt { + struct udevice *pdev; + const char *name; + unsigned int cardnum; + void *hwrm_addr_req; + void *hwrm_addr_resp; + void *hwrm_addr_data; + dma_addr_t data_addr_mapping; + dma_addr_t req_addr_mapping; + dma_addr_t resp_addr_mapping; + struct lm_tx_info_t tx; /* Tx info. */ + struct lm_rx_info_t rx; /* Rx info. */ + struct lm_cmp_info_t cq; /* completion info. */ + u16 last_resp_code; + u16 seq_id; + u32 flag_hwrm; + u32 flags; + u16 vendor_id; + u16 device_id; + u16 subsystem_vendor; + u16 subsystem_device; + u16 cmd_reg; + u8 irq; + void __iomem *bar0; + void __iomem *bar1; + void __iomem *bar2; + u16 chip_num; + /* chip num:16-31, rev:12-15, metal:4-11, bond_id:0-3 */ + u32 chip_id; + u32 hwrm_cmd_timeout; + u16 hwrm_spec_code; + u16 hwrm_max_req_len; + u16 hwrm_max_ext_req_len; + u8 fw_maj; + u8 fw_min; + u8 fw_bld; + u8 fw_rsvd; + u8 mac_addr[ETH_ALEN]; /* HW MAC address */ + u8 mac_set[ETH_ALEN]; /* NVM Configured MAC */ + u16 fid; + u8 port_idx; + u8 ordinal_value; + u16 mtu; + u16 ring_grp_id; + u16 cq_ring_id; + u16 tx_ring_id; + u16 rx_ring_id; + u16 current_link_speed; + u16 link_status; + u16 wait_link_timeout; + u64 l2_filter_id; + u16 vnic_id; + u16 stat_ctx_id; + u32 medium; + u16 support_speeds; + u32 link_set; + u8 media_detect; + u8 media_change; + u16 max_vfs; + u16 vf_res_strategy; + u16 min_vnics; + u16 max_vnics; + u16 max_msix; + u16 min_hw_ring_grps; + u16 max_hw_ring_grps; + u16 min_tx_rings; + u16 max_tx_rings; + u16 min_rx_rings; + u16 max_rx_rings; + u16 min_cp_rings; + u16 max_cp_rings; + u16 min_rsscos_ctxs; + u16 max_rsscos_ctxs; + u16 min_l2_ctxs; + u16 max_l2_ctxs; + u16 min_stat_ctxs; + u16 max_stat_ctxs; + u16 num_cmpl_rings; + u16 num_tx_rings; + u16 num_rx_rings; + u16 num_stat_ctxs; + u16 num_hw_ring_grps; + bool card_en; +}; + +#define SHORT_CMD_SUPPORTED VER_GET_RESP_DEV_CAPS_CFG_SHORT_CMD_SUPPORTED +#define SHORT_CMD_REQUIRED VER_GET_RESP_DEV_CAPS_CFG_SHORT_CMD_REQUIRED +#define CQ_DOORBELL_KEY_IDX(a) \ + (CMPL_DOORBELL_KEY_CMPL | \ + CMPL_DOORBELL_IDX_VALID | \ + (u32)(a)) +#define TX_BD_FLAGS \ + (TX_BD_SHORT_TYPE_TX_BD_SHORT | \ + TX_BD_SHORT_FLAGS_NO_CMPL | \ + TX_BD_SHORT_FLAGS_COAL_NOW | \ + TX_BD_SHORT_FLAGS_PACKET_END | \ + (1 << TX_BD_SHORT_FLAGS_BD_CNT_SFT)) +#define MEM_HWRM_RESP memalign(BNXT_DMA_ALIGNMENT, RESP_BUF_SIZE_ALIGNED) +#define PORT_PHY_FLAGS (BNXT_FLAG_NPAR_MODE | BNXT_FLAG_MULTI_HOST) +#define RING_FREE(bp, rid, flag) bnxt_hwrm_ring_free(bp, rid, flag) +#define QCFG_PHY_ALL (SUPPORT_SPEEDS | DETECT_MEDIA | PHY_SPEED | PHY_STATUS) + +#endif /* _BNXT_H_ */ diff --git a/drivers/net/bnxt/bnxt_dbg.h b/drivers/net/bnxt/bnxt_dbg.h new file mode 100644 index 000000000000..e9e9f6efefd7 --- /dev/null +++ b/drivers/net/bnxt/bnxt_dbg.h @@ -0,0 +1,536 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019-2021 Broadcom. + */ + +#ifndef _BXNT_DBG_H_ +#define _BXNT_DBG_H_ + +/* Adjust commented out lines below to enable debug. */ +/* #define DEBUG_PCI */ +/* #define DEBUG_MEMORY */ +/* #define DEBUG_LINK */ +/* #define DEBUG_CHIP */ +/* #define DEBUG_FAIL */ +/* #define DEBUG_HWRM_CMDS */ +/* #define DEBUG_HWRM_DUMP */ +/* #define DEBUG_CQ */ +/* #define DEBUG_CQ_DUMP */ +/* #define DEBUG_TX */ +/* #define DEBUG_TX_DUMP */ +/* #define DEBUG_RX */ +/* #define DEBUG_RX_DUMP */ + +#if \ + defined(DEBUG_PCI) || \ + defined(DEBUG_MEMORY) || \ + defined(DEBUG_LINK) || \ + defined(DEBUG_CHIP) || \ + defined(DEBUG_FAIL) || \ + defined(DEBUG_HWRM_CMDS) || \ + defined(DEBUG_HWRM_DUMP) || \ + defined(DEBUG_CQ) || \ + defined(DEBUG_CQ_DUMP) || \ + defined(DEBUG_TX) || \ + defined(DEBUG_TX_DUMP) || \ + defined(DEBUG_RX) || \ + defined(DEBUG_RX_DUMP) +#define DEBUG_DEFAULT +#endif + +#if defined(DEBUG_DEFAULT) +#define dbg_prn printf +#define MAX_CHAR_SIZE(a) (u32)((1 << (a)) - 1) +#define DISP_U8 0x00 +#define DISP_U16 0x01 +#define DISP_U32 0x02 +#define DISP_U64 0x03 + +void dumpmemory1(u8 *buffer, u32 length, u8 flag) +{ + u32 jj = 0; + u8 i, c; + + printf("\n %p:", buffer); + for (jj = 0; jj < 16; jj++) { + if (!(jj & MAX_CHAR_SIZE(flag))) + printf(" "); + if (jj < length) + printf("%02x", buffer[jj]); + else + printf(" "); + if ((jj & 0xF) == 0xF) { + printf(" "); + for (i = 0; i < 16; i++) { + if (i < length) { + c = buffer[jj + i - 15]; + if (c >= 0x20 && c < 0x7F) + ; + else + c = '.'; + printf("%c", c); + } + } + } + } +} + +void dump_mem(u8 *buffer, u32 length, u8 flag) +{ + u32 length16, remlen, jj; + + length16 = length & 0xFFFFFFF0; + remlen = length & 0xF; + for (jj = 0; jj < length16; jj += 16) + dumpmemory1((u8 *)&buffer[jj], 16, flag); + if (remlen) + dumpmemory1((u8 *)&buffer[length16], remlen, flag); + if (length16 || remlen) + printf("\n"); +} +#endif + +#if defined(DEBUG_PCI) +void dbg_pci(struct bnxt *bp, const char *func, u16 cmd_reg) +{ + printf("- %s()\n", func); + printf(" Vendor id : %04X\n", bp->vendor_id); + printf(" Device id : %04X\n", bp->device_id); + printf(" Irq : %d\n", bp->irq); + printf(" PCI Command Reg : %04X %04X\n", bp->cmd_reg, cmd_reg); + printf(" Sub Vendor id : %04X\n", bp->subsystem_vendor); + printf(" Sub Device id : %04X\n", bp->subsystem_device); + printf(" BAR (0) : %p\n", bp->bar0); + printf(" BAR (1) : %p\n", bp->bar1); + printf(" BAR (2) : %p\n", bp->bar2); +} +#else +#define dbg_pci(bp, func, creg) +#endif + +#if defined(DEBUG_MEMORY) +void dbg_mem(struct bnxt *bp, const char *func) +{ + printf("- %s()\n", func); + printf(" bp Addr : %p", bp); + printf(" Len %4d", (u16)sizeof(struct bnxt)); + printf(" phy %llx\n", virt_to_bus(bp)); + printf(" bp->hwrm_req_addr : %p", bp->hwrm_addr_req); + printf(" Len %4d", (u16)REQ_BUFFER_SIZE); + printf(" phy %llx\n", bp->req_addr_mapping); + printf(" bp->hwrm_resp_addr : %p", bp->hwrm_addr_resp); + printf(" Len %4d", (u16)RESP_BUFFER_SIZE); + printf(" phy %llx\n", bp->resp_addr_mapping); + printf(" bp->tx.bd_virt : %p", bp->tx.bd_virt); + printf(" Len %4d", (u16)TX_RING_DMA_BUFFER_SIZE); + printf(" phy %llx\n", virt_to_bus(bp->tx.bd_virt)); + printf(" bp->rx.bd_virt : %p", bp->rx.bd_virt); + printf(" Len %4d", (u16)RX_RING_DMA_BUFFER_SIZE); + printf(" phy %llx\n", virt_to_bus(bp->rx.bd_virt)); + printf(" bp->cq.bd_virt : %p", bp->cq.bd_virt); + printf(" Len %4d", (u16)CQ_RING_DMA_BUFFER_SIZE); + printf(" phy %llx\n", virt_to_bus(bp->cq.bd_virt)); +} +#else +#define dbg_mem(bp, func) +#endif + +#if defined(DEBUG_CHIP) +void print_fw_ver(struct hwrm_ver_get_output *resp, u32 tmo) +{ + if (resp->hwrm_intf_maj_8b < 1) { + dbg_prn(" HWRM interface %d.%d.%d is older than 1.0.0.\n", + resp->hwrm_intf_maj_8b, resp->hwrm_intf_min_8b, + resp->hwrm_intf_upd_8b); + dbg_prn(" Update FW with HWRM interface 1.0.0 or newer.\n"); + } + dbg_prn(" FW Version : %d.%d.%d.%d\n", + resp->hwrm_fw_maj_8b, resp->hwrm_fw_min_8b, + resp->hwrm_fw_bld_8b, resp->hwrm_fw_rsvd_8b); + printf(" cmd timeout : %d\n", tmo); +} + +void dbg_func_resource_qcaps(struct bnxt *bp) +{ + /* Ring Groups */ + printf(" min_hw_ring_grps : %d\n", bp->min_hw_ring_grps); + printf(" max_hw_ring_grps : %d\n", bp->max_hw_ring_grps); + /* TX Rings */ + printf(" min_tx_rings : %d\n", bp->min_tx_rings); + printf(" max_tx_rings : %d\n", bp->max_tx_rings); + /* RX Rings */ + printf(" min_rx_rings : %d\n", bp->min_rx_rings); + printf(" max_rx_rings : %d\n", bp->max_rx_rings); + /* Completion Rings */ + printf(" min_cq_rings : %d\n", bp->min_cp_rings); + printf(" max_cq_rings : %d\n", bp->max_cp_rings); + /* Statistic Contexts */ + printf(" min_stat_ctxs : %d\n", bp->min_stat_ctxs); + printf(" max_stat_ctxs : %d\n", bp->max_stat_ctxs); +} + +void print_func_qcaps(struct bnxt *bp) +{ + printf(" Port Number : %d\n", bp->port_idx); + printf(" fid : 0x%04x\n", bp->fid); + dbg_prn(" PF MAC : %02x:%02x:%02x:%02x:%02x:%02x\n", + bp->mac_addr[0], + bp->mac_addr[1], + bp->mac_addr[2], + bp->mac_addr[3], + bp->mac_addr[4], + bp->mac_addr[5]); +} + +void print_func_qcfg(struct bnxt *bp) +{ + printf(" ordinal_value : %d\n", bp->ordinal_value); + printf(" stat_ctx_id : %x\n", bp->stat_ctx_id); + dbg_prn(" FW MAC : %02x:%02x:%02x:%02x:%02x:%02x\n", + bp->mac_addr[0], + bp->mac_addr[1], + bp->mac_addr[2], + bp->mac_addr[3], + bp->mac_addr[4], + bp->mac_addr[5]); +} + +void dbg_set_speed(u32 speed) +{ + u32 speed1 = ((speed & LINK_SPEED_DRV_MASK) >> LINK_SPEED_DRV_SHIFT); + + printf(" Set Link Speed : "); + switch (speed & LINK_SPEED_DRV_MASK) { + case LINK_SPEED_DRV_1G: + printf("1 GBPS"); + break; + case LINK_SPEED_DRV_10G: + printf("10 GBPS"); + break; + case LINK_SPEED_DRV_25G: + printf("25 GBPS"); + break; + case LINK_SPEED_DRV_40G: + printf("40 GBPS"); + break; + case LINK_SPEED_DRV_50G: + printf("50 GBPS"); + break; + case LINK_SPEED_DRV_100G: + printf("100 GBPS"); + break; + case LINK_SPEED_DRV_AUTONEG: + printf("AUTONEG"); + break; + default: + printf("%x", speed1); + break; + } + printf("\n"); +} + +void dbg_chip_info(struct bnxt *bp) +{ + printf(" Stat Ctx ID : %d\n", bp->stat_ctx_id); + printf(" Grp ID : %d\n", bp->ring_grp_id); + printf(" CQ Ring Id : %d\n", bp->cq_ring_id); + printf(" Tx Ring Id : %d\n", bp->tx_ring_id); + printf(" Rx ring Id : %d\n", bp->rx_ring_id); +} + +void print_num_rings(struct bnxt *bp) +{ + printf(" num_cmpl_rings : %d\n", bp->num_cmpl_rings); + printf(" num_tx_rings : %d\n", bp->num_tx_rings); + printf(" num_rx_rings : %d\n", bp->num_rx_rings); + printf(" num_ring_grps : %d\n", bp->num_hw_ring_grps); + printf(" num_stat_ctxs : %d\n", bp->num_stat_ctxs); +} + +void dbg_flags(const char *func, u32 flags) +{ + printf("- %s()\n", func); + printf(" bp->flags : 0x%04x\n", flags); +} +#else +#define print_fw_ver(resp, tmo) +#define dbg_func_resource_qcaps(bp) +#define print_func_qcaps(bp) +#define print_func_qcfg(bp) +#define dbg_set_speed(speed) +#define dbg_chip_info(bp) +#define print_num_rings(bp) +#define dbg_flags(func, flags) +#endif + +#if defined(DEBUG_HWRM_CMDS) || defined(DEBUG_FAIL) +void dump_hwrm_req(struct bnxt *bp, const char *func, u32 len, u32 tmo) +{ + dbg_prn("- %s(0x%04x) cmd_len %d cmd_tmo %d", + func, (u16)((struct input *)bp->hwrm_addr_req)->req_type, + len, tmo); +#if defined(DEBUG_HWRM_DUMP) + dump_mem((u8 *)bp->hwrm_addr_req, len, DISP_U8); +#else + printf("\n"); +#endif +} + +void debug_resp(struct bnxt *bp, const char *func, u32 resp_len, u16 err) +{ + dbg_prn("- %s(0x%04x) - ", + func, (u16)((struct input *)bp->hwrm_addr_req)->req_type); + if (err == STATUS_SUCCESS) + printf("Done"); + else if (err != STATUS_TIMEOUT) + printf("Fail err 0x%04x", err); + else + printf("timedout"); +#if defined(DEBUG_HWRM_DUMP) + if (err != STATUS_TIMEOUT) + dump_mem((u8 *)bp->hwrm_addr_resp, resp_len, DISP_U8); + else + printf("\n"); +#else + printf("\n"); +#endif +} + +void dbg_hw_cmd(struct bnxt *bp, + const char *func, u16 cmd_len, + u16 resp_len, u32 cmd_tmo, u16 err) +{ +#if !defined(DEBUG_HWRM_CMDS) + if (err && err != STATUS_TIMEOUT) +#endif + { + dump_hwrm_req(bp, func, cmd_len, cmd_tmo); + debug_resp(bp, func, resp_len, err); + } +} +#else +#define dbg_hw_cmd(bp, func, cmd_len, resp_len, cmd_tmo, err) +#endif + +#if defined(DEBUG_HWRM_CMDS) +void dbg_short_cmd(u8 *req, const char *func, u32 len) +{ + struct hwrm_short_input *sreq; + + sreq = (struct hwrm_short_input *)req; + dbg_prn("- %s(0x%04x) short_cmd_len %d", + func, + sreq->req_type, + (int)len); +#if defined(DEBUG_HWRM_DUMP) + dump_mem((u8 *)sreq, len, DISP_U8); +#else + printf("\n"); +#endif +} +#else +#define dbg_short_cmd(sreq, func, len) +#endif + +#if defined(DEBUG_RX) +void dump_rx_bd(struct rx_pkt_cmpl *rx_cmp, + struct rx_pkt_cmpl_hi *rx_cmp_hi, + u32 desc_idx) +{ + printf(" RX desc_idx %d\n", desc_idx); + printf("- rx_cmp %llx", virt_to_bus(rx_cmp)); +#if defined(DEBUG_RX_DUMP) + dump_mem((u8 *)rx_cmp, (u32)sizeof(struct rx_pkt_cmpl), DISP_U8); +#else + printf("\n"); +#endif + printf("- rx_cmp_hi %llx", virt_to_bus(rx_cmp_hi)); +#if defined(DEBUG_RX_DUMP) + dump_mem((u8 *)rx_cmp_hi, (u32)sizeof(struct rx_pkt_cmpl_hi), DISP_U8); +#else + printf("\n"); +#endif +} + +void dbg_rxp(u8 *iob, u16 rx_len, u16 flag) +{ + printf("- RX iob %llx Len %d ", virt_to_bus(iob), rx_len); + if (flag == PKT_RECEIVED) + printf(" PKT RECEIVED"); + else if (flag == PKT_DROPPED) + printf(" PKT DROPPED"); +#if defined(DEBUG_RX_DUMP) + dump_mem(iob, (u32)rx_len, DISP_U8); +#else + printf("\n"); +#endif +} + +void dbg_rx_cid(u16 idx, u16 cid) +{ + dbg_prn("- RX old cid %d new cid %d\n", idx, cid); +} + +void dbg_rx_alloc_iob_fail(u16 idx, u16 cid) +{ + dbg_prn(" Rx alloc_iob (%d) failed", idx); + dbg_prn(" for cons_id %d\n", cid); +} + +void dbg_rx_iob(void *iob, u16 idx, u16 cid) +{ + dbg_prn(" Rx alloc_iob (%d) %p bd_virt (%d)\n", + idx, iob, cid); +} + +void dbg_rx_pkt(struct bnxt *bp, const char *func, uchar *pkt, int len) +{ + if (bp->rx.iob_recv == PKT_RECEIVED) { + dbg_prn("- %s: %llx %d\n", func, + virt_to_bus(pkt), len); + } +} +#else +#define dump_rx_bd(rx_cmp, rx_cmp_hi, desc_idx) +#define dbg_rxp(iob, rx_len, flag) +#define dbg_rx_cid(idx, cid) +#define dbg_rx_alloc_iob_fail(idx, cid) +#define dbg_rx_iob(iob, idx, cid) +#define dbg_rx_pkt(bp, func, pkt, len) +#endif + +#if defined(DEBUG_CQ) +void dump_CQ(struct cmpl_base *cmp, u16 cons_idx) +{ + printf("- CQ Type "); + + switch (cmp->type & CMPL_BASE_TYPE_MASK) { + case CMPL_BASE_TYPE_STAT_EJECT: + printf("(se)"); + break; + case CMPL_BASE_TYPE_HWRM_ASYNC_EVENT: + printf("(ae)"); + break; + case CMPL_BASE_TYPE_TX_L2: + printf("(tx)"); + break; + case CMPL_BASE_TYPE_RX_L2: + printf("(rx)"); + break; + default: + printf("%04x", (u16)(cmp->type & CMPL_BASE_TYPE_MASK)); + break; + } + printf(" cid %d", cons_idx); +#if defined(DEBUG_CQ_DUMP) + dump_mem((u8 *)cmp, (u32)sizeof(struct cmpl_base), DISP_U8); +#else + printf("\n"); +#endif +} +#else +#define dump_CQ(cq, id) +#endif + +#if defined(DEBUG_TX) +void dump_tx_stat(struct bnxt *bp) +{ + printf(" TX stats cnt %d req_cnt %d", bp->tx.cnt, bp->tx.cnt_req); + printf(" prod_id %d cons_id %d\n", bp->tx.prod_id, bp->tx.cons_id); +} + +void dump_tx_pkt(void *packet, dma_addr_t mapping, int len) +{ + printf(" TX Addr %llx Size %d", mapping, len); +#if defined(DEBUG_TX_DUMP) + dump_mem((u8 *)packet, len, DISP_U8); +#else + printf("\n"); +#endif +} + +void dump_tx_bd(struct tx_bd_short *tx_bd, u16 len) +{ + printf(" Tx BD Addr %llx Size %d", virt_to_bus(tx_bd), len); +#if defined(DEBUG_TX_DUMP) + dump_mem((u8 *)tx_bd, (u32)len, DISP_U8); +#else + printf("\n"); +#endif +} + +void dbg_no_tx_bd(void) +{ + printf(" Tx ring full\n"); +} +#else +#define dump_tx_stat(bp) +#define dump_tx_pkt(packet, mapping, len) +#define dump_tx_bd(prod_bd, len) +#define dbg_no_tx_bd() +#endif + +#if defined(DEBUG_MEMORY) +void dbg_mem_free_done(const char *func) +{ + printf("- %s - Done\n", func); +} +#else +#define dbg_mem_free_done(func) +#endif + +#if defined(DEBUG_FAIL) +void dbg_mem_alloc_fail(const char *func) +{ + printf("- %s() Fail\n", func); +} +#else +#define dbg_mem_alloc_fail(func) +#endif + +#if defined(DEBUG_LINK) +static void dump_evt(u8 *cmp, u32 type, u16 cid) +{ + u32 size = sizeof(struct cmpl_base); + u8 c = 'C'; + + switch (type) { + case CMPL_BASE_TYPE_HWRM_ASYNC_EVENT: + break; + default: + return; + } + dbg_prn("- %cQ Type (ae) cid %d", c, cid); + dump_mem(cmp, size, DISP_U8); +} + +void dbg_link_status(struct bnxt *bp) +{ + dbg_prn(" Port(%d) : Link", bp->port_idx); + if (bp->link_status == STATUS_LINK_ACTIVE) { + dbg_prn("Up"); + } else { + dbg_prn("Down\n"); + dbg_prn(" media_detect : %x", bp->media_detect); + } + dbg_prn("\n"); +} + +void dbg_link_state(struct bnxt *bp, u32 tmo) +{ + if (bp->link_status == STATUS_LINK_ACTIVE) + printf(" Link wait time : %d ms\n", tmo); +} + +void dbg_phy_speed(struct bnxt *bp, char *name) +{ + printf(" Current Speed : %s\n", name); +} +#else +#define dump_evt(cmp, ty, cid) +#define dbg_link_status(bp) +#define dbg_link_state(bp, tmo) +#define dbg_phy_speed(bp, name) +#endif + +#endif /* _BXNT_DBG_H_ */ diff --git a/drivers/net/bnxt/bnxt_hsi.h b/drivers/net/bnxt/bnxt_hsi.h new file mode 100644 index 000000000000..81cc5da9e4d7 --- /dev/null +++ b/drivers/net/bnxt/bnxt_hsi.h @@ -0,0 +1,889 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + /* + * Copyright 2019-2021 Broadcom. + */ + +#ifndef _BNXT_HSI_H_ +#define _BNXT_HSI_H_ + +/* input (size:128b/16B) */ +struct input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; +}; + +/* output (size:64b/8B) */ +struct output { + __le16 error_code; + __le16 req_type; + __le16 seq_id; + __le16 resp_len; +}; + +/* hwrm_short_input (size:128b/16B) */ +struct hwrm_short_input { + __le16 req_type; + __le16 signature; +#define SHORT_REQ_SIGNATURE_SHORT_CMD 0x4321UL + __le16 unused_0; + __le16 size; + __le64 req_addr; +}; + +#define HWRM_VER_GET 0x0UL +#define HWRM_FUNC_RESET 0x11UL +#define HWRM_FUNC_QCAPS 0x15UL +#define HWRM_FUNC_QCFG 0x16UL +#define HWRM_FUNC_CFG 0x17UL +#define HWRM_FUNC_DRV_UNRGTR 0x1aUL +#define HWRM_FUNC_DRV_RGTR 0x1dUL +#define HWRM_PORT_PHY_CFG 0x20UL +#define HWRM_PORT_MAC_CFG 0x21UL +#define HWRM_PORT_PHY_QCFG 0x27UL +#define HWRM_VNIC_ALLOC 0x40UL +#define HWRM_VNIC_FREE 0x41UL +#define HWRM_VNIC_CFG 0x42UL +#define HWRM_RING_ALLOC 0x50UL +#define HWRM_RING_FREE 0x51UL +#define HWRM_RING_GRP_ALLOC 0x60UL +#define HWRM_RING_GRP_FREE 0x61UL +#define HWRM_CFA_L2_FILTER_ALLOC 0x90UL +#define HWRM_CFA_L2_FILTER_FREE 0x91UL +#define HWRM_CFA_L2_SET_RX_MASK 0x93UL +#define HWRM_STAT_CTX_ALLOC 0xb0UL +#define HWRM_STAT_CTX_FREE 0xb1UL +#define HWRM_FUNC_RESOURCE_QCAPS 0x190UL +#define HWRM_NVM_FLUSH 0xfff0UL +#define HWRM_NVM_GET_VARIABLE 0xfff1UL +#define HWRM_NVM_SET_VARIABLE 0xfff2UL + +#define HWRM_NA_SIGNATURE ((__le32)(-1)) +#define HWRM_MAX_REQ_LEN 128 +#define HWRM_VERSION_MAJOR 1 +#define HWRM_VERSION_MINOR 10 +#define HWRM_VERSION_UPDATE 0 + +/* hwrm_ver_get_input (size:192b/24B) */ +struct hwrm_ver_get_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + u8 hwrm_intf_maj; + u8 hwrm_intf_min; + u8 hwrm_intf_upd; + u8 unused_0[5]; +}; + +/* hwrm_ver_get_output (size:1408b/176B) */ +struct hwrm_ver_get_output { + __le16 error_code; + __le16 req_type; + __le16 seq_id; + __le16 resp_len; + u8 hwrm_intf_maj_8b; + u8 hwrm_intf_min_8b; + u8 hwrm_intf_upd_8b; + u8 hwrm_intf_rsvd_8b; + u8 hwrm_fw_maj_8b; + u8 hwrm_fw_min_8b; + u8 hwrm_fw_bld_8b; + u8 hwrm_fw_rsvd_8b; + u8 mgmt_fw_maj_8b; + u8 mgmt_fw_min_8b; + u8 mgmt_fw_bld_8b; + u8 mgmt_fw_rsvd_8b; + u8 netctrl_fw_maj_8b; + u8 netctrl_fw_min_8b; + u8 netctrl_fw_bld_8b; + u8 netctrl_fw_rsvd_8b; + __le32 dev_caps_cfg; +#define VER_GET_RESP_DEV_CAPS_CFG_SHORT_CMD_SUPPORTED 0x4UL +#define VER_GET_RESP_DEV_CAPS_CFG_SHORT_CMD_REQUIRED 0x8UL + u8 roce_fw_maj_8b; + u8 roce_fw_min_8b; + u8 roce_fw_bld_8b; + u8 roce_fw_rsvd_8b; + char hwrm_fw_name[16]; + char mgmt_fw_name[16]; + char netctrl_fw_name[16]; + u8 reserved2[16]; + char roce_fw_name[16]; + __le16 chip_num; + u8 chip_rev; + u8 chip_metal; + u8 chip_bond_id; + u8 chip_platform_type; + __le16 max_req_win_len; + __le16 max_resp_len; + __le16 def_req_timeout; + u8 flags; + u8 unused_0[2]; + u8 always_1; + __le16 hwrm_intf_major; + __le16 hwrm_intf_minor; + __le16 hwrm_intf_build; + __le16 hwrm_intf_patch; + __le16 hwrm_fw_major; + __le16 hwrm_fw_minor; + __le16 hwrm_fw_build; + __le16 hwrm_fw_patch; + __le16 mgmt_fw_major; + __le16 mgmt_fw_minor; + __le16 mgmt_fw_build; + __le16 mgmt_fw_patch; + __le16 netctrl_fw_major; + __le16 netctrl_fw_minor; + __le16 netctrl_fw_build; + __le16 netctrl_fw_patch; + __le16 roce_fw_major; + __le16 roce_fw_minor; + __le16 roce_fw_build; + __le16 roce_fw_patch; + __le16 max_ext_req_len; + u8 unused_1[5]; + u8 valid; +}; + +/* hwrm_async_event_cmpl (size:128b/16B) */ +struct hwrm_async_event_cmpl { + __le16 type; + __le16 event_id; +#define ASYNC_EVENT_CMPL_EVENT_ID_LINK_STATUS_CHANGE 0x0UL + __le32 event_data2; + u8 opaque_v; + u8 timestamp_lo; + __le16 timestamp_hi; + __le32 event_data1; +}; + +/* hwrm_func_reset_input (size:192b/24B) */ +struct hwrm_func_reset_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le32 enables; + __le16 vf_id; + u8 func_reset_level; +#define FUNC_RESET_REQ_FUNC_RESET_LEVEL_RESETME 0x1UL + u8 unused_0; +}; + +/* hwrm_func_qcaps_input (size:192b/24B) */ +struct hwrm_func_qcaps_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le16 fid; + u8 unused_0[6]; +}; + +/* hwrm_func_qcaps_output (size:640b/80B) */ +struct hwrm_func_qcaps_output { + __le16 error_code; + __le16 req_type; + __le16 seq_id; + __le16 resp_len; + __le16 fid; + __le16 port_id; + __le32 flags; + u8 mac_address[6]; + __le16 max_rsscos_ctx; + __le16 max_cmpl_rings; + __le16 max_tx_rings; + __le16 max_rx_rings; + __le16 max_l2_ctxs; + __le16 max_vnics; + __le16 first_vf_id; + __le16 max_vfs; + __le16 max_stat_ctx; + __le32 max_encap_records; + __le32 max_decap_records; + __le32 max_tx_em_flows; + __le32 max_tx_wm_flows; + __le32 max_rx_em_flows; + __le32 max_rx_wm_flows; + __le32 max_mcast_filters; + __le32 max_flow_id; + __le32 max_hw_ring_grps; + __le16 max_sp_tx_rings; + u8 unused_0; + u8 valid; +}; + +/* hwrm_func_qcfg_input (size:192b/24B) */ +struct hwrm_func_qcfg_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le16 fid; + u8 unused_0[6]; +}; + +/* hwrm_func_qcfg_output (size:704b/88B) */ +struct hwrm_func_qcfg_output { + __le16 error_code; + __le16 req_type; + __le16 seq_id; + __le16 resp_len; + __le16 fid; + __le16 port_id; + __le16 vlan; + __le16 flags; +#define FUNC_QCFG_RESP_FLAGS_MULTI_HOST 0x20UL + u8 mac_address[6]; + __le16 pci_id; + __le16 alloc_rsscos_ctx; + __le16 alloc_cmpl_rings; + __le16 alloc_tx_rings; + __le16 alloc_rx_rings; + __le16 alloc_l2_ctx; + __le16 alloc_vnics; + __le16 mtu; + __le16 mru; + __le16 stat_ctx_id; + u8 port_partition_type; +#define FUNC_QCFG_RESP_PORT_PARTITION_TYPE_NPAR1_0 0x2UL + u8 port_pf_cnt; + __le16 dflt_vnic_id; + __le16 max_mtu_configured; + __le32 min_bw; + __le32 max_bw; + u8 evb_mode; + u8 options; + __le16 alloc_vfs; + __le32 alloc_mcast_filters; + __le32 alloc_hw_ring_grps; + __le16 alloc_sp_tx_rings; + __le16 alloc_stat_ctx; + __le16 alloc_msix; + __le16 registered_vfs; + u8 unused_1[3]; + u8 always_1; + __le32 reset_addr_poll; + u8 unused_2[3]; + u8 valid; +}; + +/* hwrm_func_cfg_input (size:704b/88B) */ +struct hwrm_func_cfg_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le16 fid; + __le16 num_msix; + __le32 flags; + __le32 enables; +#define FUNC_CFG_REQ_ENABLES_NUM_CMPL_RINGS 0x8UL +#define FUNC_CFG_REQ_ENABLES_NUM_TX_RINGS 0x10UL +#define FUNC_CFG_REQ_ENABLES_NUM_RX_RINGS 0x20UL +#define FUNC_CFG_REQ_ENABLES_NUM_STAT_CTXS 0x100UL +#define FUNC_CFG_REQ_ENABLES_ASYNC_EVENT_CR 0x4000UL +#define FUNC_CFG_REQ_ENABLES_NUM_HW_RING_GRPS 0x80000UL + __le16 mtu; + __le16 mru; + __le16 num_rsscos_ctxs; + __le16 num_cmpl_rings; + __le16 num_tx_rings; + __le16 num_rx_rings; + __le16 num_l2_ctxs; + __le16 num_vnics; + __le16 num_stat_ctxs; + __le16 num_hw_ring_grps; + u8 dflt_mac_addr[6]; + __le16 dflt_vlan; + __be32 dflt_ip_addr[4]; + __le32 min_bw; + __le32 max_bw; + __le16 async_event_cr; + u8 vlan_antispoof_mode; + u8 allowed_vlan_pris; + u8 evb_mode; + u8 options; + __le16 num_mcast_filters; +}; + +/* hwrm_func_drv_rgtr_input (size:896b/112B) */ +struct hwrm_func_drv_rgtr_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le32 flags; + __le32 enables; +#define FUNC_DRV_RGTR_REQ_ENABLES_OS_TYPE 0x1UL +#define FUNC_DRV_RGTR_REQ_ENABLES_VER 0x2UL +#define FUNC_DRV_RGTR_REQ_ENABLES_ASYNC_EVENT_FWD 0x10UL + __le16 os_type; +#define FUNC_DRV_RGTR_REQ_OS_TYPE_OTHER 0x1UL + u8 ver_maj_8b; + u8 ver_min_8b; + u8 ver_upd_8b; + u8 unused_0[3]; + __le32 timestamp; + u8 unused_1[4]; + __le32 vf_req_fwd[8]; + __le32 async_event_fwd[8]; + __le16 ver_maj; + __le16 ver_min; + __le16 ver_upd; + __le16 ver_patch; +}; + +/* hwrm_func_drv_unrgtr_input (size:192b/24B) */ +struct hwrm_func_drv_unrgtr_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le32 flags; +#define FUNC_DRV_UNRGTR_REQ_FLAGS_PREPARE_FOR_SHUTDOWN 0x1UL + u8 unused_0[4]; +}; + +/* hwrm_func_resource_qcaps_input (size:192b/24B) */ +struct hwrm_func_resource_qcaps_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le16 fid; + u8 unused_0[6]; +}; + +/* hwrm_func_resource_qcaps_output (size:448b/56B) */ +struct hwrm_func_resource_qcaps_output { + __le16 error_code; + __le16 req_type; + __le16 seq_id; + __le16 resp_len; + __le16 max_vfs; + __le16 max_msix; + __le16 vf_reservation_strategy; + __le16 min_rsscos_ctx; + __le16 max_rsscos_ctx; + __le16 min_cmpl_rings; + __le16 max_cmpl_rings; + __le16 min_tx_rings; + __le16 max_tx_rings; + __le16 min_rx_rings; + __le16 max_rx_rings; + __le16 min_l2_ctxs; + __le16 max_l2_ctxs; + __le16 min_vnics; + __le16 max_vnics; + __le16 min_stat_ctx; + __le16 max_stat_ctx; + __le16 min_hw_ring_grps; + __le16 max_hw_ring_grps; + __le16 max_tx_scheduler_inputs; + __le16 flags; + u8 unused_0[5]; + u8 valid; +}; + +/* hwrm_func_vlan_qcfg_input (size:192b/24B) */ +struct hwrm_func_vlan_qcfg_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le16 fid; + u8 unused_0[6]; +}; + +/* hwrm_port_phy_cfg_input (size:448b/56B) */ +struct hwrm_port_phy_cfg_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le32 flags; +#define PORT_PHY_CFG_REQ_FLAGS_RESET_PHY 0x1UL +#define PORT_PHY_CFG_REQ_FLAGS_FORCE 0x4UL + __le32 enables; +#define PORT_PHY_CFG_REQ_ENABLES_AUTO_MODE 0x1UL +#define PORT_PHY_CFG_REQ_ENABLES_AUTO_DUPLEX 0x2UL +#define PORT_PHY_CFG_REQ_ENABLES_AUTO_PAUSE 0x4UL +#define PORT_PHY_CFG_REQ_ENABLES_AUTO_LINK_SPEED_MASK 0x10UL + __le16 port_id; + __le16 force_link_speed; +#define PORT_PHY_CFG_REQ_FORCE_LINK_SPEED_1GB 0xaUL +#define PORT_PHY_CFG_REQ_FORCE_LINK_SPEED_10GB 0x64UL +#define PORT_PHY_CFG_REQ_FORCE_LINK_SPEED_25GB 0xfaUL +#define PORT_PHY_CFG_REQ_FORCE_LINK_SPEED_40GB 0x190UL +#define PORT_PHY_CFG_REQ_FORCE_LINK_SPEED_50GB 0x1f4UL +#define PORT_PHY_CFG_REQ_FORCE_LINK_SPEED_100GB 0x3e8UL + u8 auto_mode; +#define PORT_PHY_CFG_REQ_AUTO_MODE_SPEED_MASK 0x4UL + u8 auto_duplex; +#define PORT_PHY_CFG_REQ_AUTO_DUPLEX_BOTH 0x2UL + u8 auto_pause; +#define PORT_PHY_CFG_REQ_AUTO_PAUSE_TX 0x1UL +#define PORT_PHY_CFG_REQ_AUTO_PAUSE_RX 0x2UL + u8 unused_0; + __le16 auto_link_speed; + __le16 auto_link_speed_mask; +#define PORT_PHY_CFG_REQ_AUTO_LINK_SPEED_MASK_100MB 0x2UL +#define PORT_PHY_CFG_REQ_AUTO_LINK_SPEED_MASK_1GB 0x8UL +#define PORT_PHY_CFG_REQ_AUTO_LINK_SPEED_MASK_10GB 0x40UL +#define PORT_PHY_CFG_REQ_AUTO_LINK_SPEED_MASK_25GB 0x100UL +#define PORT_PHY_CFG_REQ_AUTO_LINK_SPEED_MASK_40GB 0x200UL +#define PORT_PHY_CFG_REQ_AUTO_LINK_SPEED_MASK_50GB 0x400UL +#define PORT_PHY_CFG_REQ_AUTO_LINK_SPEED_MASK_100GB 0x800UL + u8 wirespeed; + u8 lpbk; + u8 force_pause; + u8 unused_1; + __le32 preemphasis; + __le16 eee_link_speed_mask; + u8 unused_2[2]; + __le32 tx_lpi_timer; + __le32 unused_3; +}; + +/* hwrm_port_phy_qcfg_input (size:192b/24B) */ +struct hwrm_port_phy_qcfg_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le16 port_id; + u8 unused_0[6]; +}; + +/* hwrm_port_phy_qcfg_output (size:768b/96B) */ +struct hwrm_port_phy_qcfg_output { + __le16 error_code; + __le16 req_type; + __le16 seq_id; + __le16 resp_len; + u8 link; +#define PORT_PHY_QCFG_RESP_LINK_LINK 0x2UL + u8 unused_0; + __le16 link_speed; +#define PORT_PHY_QCFG_RESP_LINK_SPEED_100MB 0x1UL +#define PORT_PHY_QCFG_RESP_LINK_SPEED_1GB 0xaUL +#define PORT_PHY_QCFG_RESP_LINK_SPEED_2GB 0x14UL +#define PORT_PHY_QCFG_RESP_LINK_SPEED_2_5GB 0x19UL +#define PORT_PHY_QCFG_RESP_LINK_SPEED_10GB 0x64UL +#define PORT_PHY_QCFG_RESP_LINK_SPEED_20GB 0xc8UL +#define PORT_PHY_QCFG_RESP_LINK_SPEED_25GB 0xfaUL +#define PORT_PHY_QCFG_RESP_LINK_SPEED_40GB 0x190UL +#define PORT_PHY_QCFG_RESP_LINK_SPEED_50GB 0x1f4UL +#define PORT_PHY_QCFG_RESP_LINK_SPEED_100GB 0x3e8UL +#define PORT_PHY_QCFG_RESP_LINK_SPEED_10MB 0xffffUL + u8 duplex_cfg; + u8 pause; + __le16 support_speeds; +#define PORT_QCFG_SUPPORT_SPEEDS_100MBHD 0x1UL +#define PORT_QCFG_SUPPORT_SPEEDS_100MB 0x2UL +#define PORT_QCFG_SUPPORT_SPEEDS_1GBHD 0x4UL +#define PORT_QCFG_SUPPORT_SPEEDS_1GB 0x8UL +#define PORT_QCFG_SUPPORT_SPEEDS_2GB 0x10UL +#define PORT_QCFG_SUPPORT_SPEEDS_2_5GB 0x20UL +#define PORT_QCFG_SUPPORT_SPEEDS_10GB 0x40UL +#define PORT_QCFG_SUPPORT_SPEEDS_20GB 0x80UL +#define PORT_QCFG_SUPPORT_SPEEDS_25GB 0x100UL +#define PORT_QCFG_SUPPORT_SPEEDS_50GB 0x400UL +#define PORT_QCFG_SUPPORT_SPEEDS_100GB 0x800UL +#define PORT_QCFG_SUPPORT_SPEEDS_200GB 0x4000UL + __le16 force_link_speed; + u8 auto_mode; + u8 auto_pause; + __le16 auto_link_speed; + __le16 auto_link_speed_mask; + u8 wirespeed; + u8 lpbk; + u8 force_pause; + u8 module_status; + __le32 preemphasis; + u8 phy_maj; + u8 phy_min; + u8 phy_bld; + u8 phy_type; + u8 media_type; + u8 xcvr_pkg_type; + u8 eee_config_phy_addr; + u8 parallel_detect; + __le16 link_partner_adv_speeds; + u8 link_partner_adv_auto_mode; + u8 link_partner_adv_pause; + __le16 adv_eee_link_speed_mask; + __le16 link_partner_adv_eee_link_speed_mask; + __le32 xcvr_identifier_type_tx_lpi_timer; + __le16 fec_cfg; + u8 duplex_state; + u8 option_flags; + char phy_vendor_name[16]; + char phy_vendor_partnumber[16]; + u8 unused_2[7]; + u8 valid; +}; + +/* hwrm_port_mac_cfg_input (size:320b/40B) */ +struct hwrm_port_mac_cfg_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le32 flags; + __le32 enables; + __le16 port_id; + u8 ipg; + u8 lpbk; +#define PORT_MAC_CFG_REQ_LPBK_NONE 0x0UL + u8 vlan_pri2cos_map_pri; + u8 reserved1; + u8 tunnel_pri2cos_map_pri; + u8 dscp2pri_map_pri; + __le16 rx_ts_capture_ptp_msg_type; + __le16 tx_ts_capture_ptp_msg_type; + u8 cos_field_cfg; + u8 unused_0[3]; +}; + +/* hwrm_vnic_alloc_input (size:192b/24B) */ +struct hwrm_vnic_alloc_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le32 flags; +#define VNIC_ALLOC_REQ_FLAGS_DEFAULT 0x1UL + u8 unused_0[4]; +}; + +/* hwrm_vnic_alloc_output (size:128b/16B) */ +struct hwrm_vnic_alloc_output { + __le16 error_code; + __le16 req_type; + __le16 seq_id; + __le16 resp_len; + __le32 vnic_id; + u8 unused_0[3]; + u8 valid; +}; + +/* hwrm_vnic_free_input (size:192b/24B) */ +struct hwrm_vnic_free_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le32 vnic_id; + u8 unused_0[4]; +}; + +/* hwrm_vnic_cfg_input (size:320b/40B) */ +struct hwrm_vnic_cfg_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le32 flags; + __le32 enables; +#define VNIC_CFG_REQ_ENABLES_DFLT_RING_GRP 0x1UL +#define VNIC_CFG_REQ_ENABLES_MRU 0x10UL + __le16 vnic_id; + __le16 dflt_ring_grp; + __le16 rss_rule; + __le16 cos_rule; + __le16 lb_rule; + __le16 mru; + __le16 default_rx_ring_id; + __le16 default_cmpl_ring_id; +}; + +/* hwrm_ring_alloc_input (size:704b/88B) */ +struct hwrm_ring_alloc_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le32 enables; +#define RING_ALLOC_REQ_ENABLES_RX_BUF_SIZE_VALID 0x100UL + u8 ring_type; +#define RING_ALLOC_REQ_RING_TYPE_L2_CMPL 0x0UL +#define RING_ALLOC_REQ_RING_TYPE_TX 0x1UL +#define RING_ALLOC_REQ_RING_TYPE_RX 0x2UL + u8 unused_0; + __le16 flags; + __le64 page_tbl_addr; + __le32 fbo; + u8 page_size; + u8 page_tbl_depth; + u8 unused_1[2]; + __le32 length; + __le16 logical_id; + __le16 cmpl_ring_id; + __le16 queue_id; + __le16 rx_buf_size; + __le16 rx_ring_id; + __le16 nq_ring_id; + __le16 ring_arb_cfg; + __le16 unused_3; + __le32 reserved3; + __le32 stat_ctx_id; + __le32 reserved4; + __le32 max_bw; + u8 int_mode; +#define RING_ALLOC_REQ_INT_MODE_POLL 0x3UL + u8 unused_4[3]; + __le64 cq_handle; +}; + +/* hwrm_ring_alloc_output (size:128b/16B) */ +struct hwrm_ring_alloc_output { + __le16 error_code; + __le16 req_type; + __le16 seq_id; + __le16 resp_len; + __le16 ring_id; + __le16 logical_ring_id; + u8 unused_0[3]; + u8 valid; +}; + +/* hwrm_ring_free_input (size:192b/24B) */ +struct hwrm_ring_free_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + u8 ring_type; +#define RING_FREE_REQ_RING_TYPE_L2_CMPL 0x0UL +#define RING_FREE_REQ_RING_TYPE_TX 0x1UL +#define RING_FREE_REQ_RING_TYPE_RX 0x2UL + u8 unused_0; + __le16 ring_id; + u8 unused_1[4]; +}; + +/* hwrm_ring_grp_alloc_input (size:192b/24B) */ +struct hwrm_ring_grp_alloc_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le16 cr; + __le16 rr; + __le16 ar; + __le16 sc; +}; + +/* hwrm_ring_grp_alloc_output (size:128b/16B) */ +struct hwrm_ring_grp_alloc_output { + __le16 error_code; + __le16 req_type; + __le16 seq_id; + __le16 resp_len; + __le32 ring_group_id; + u8 unused_0[3]; + u8 valid; +}; + +/* hwrm_ring_grp_free_input (size:192b/24B) */ +struct hwrm_ring_grp_free_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le32 ring_group_id; + u8 unused_0[4]; +}; + +/* hwrm_cfa_l2_filter_alloc_input (size:768b/96B) */ +struct hwrm_cfa_l2_filter_alloc_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le32 flags; +#define CFA_L2_FILTER_ALLOC_REQ_FLAGS_PATH_RX 0x1UL + __le32 enables; +#define CFA_L2_FILTER_ALLOC_REQ_ENABLES_L2_ADDR 0x1UL +#define CFA_L2_FILTER_ALLOC_REQ_ENABLES_L2_ADDR_MASK 0x2UL +#define CFA_L2_FILTER_ALLOC_REQ_ENABLES_DST_ID 0x8000UL + u8 l2_addr[6]; + u8 unused_0[2]; + u8 l2_addr_mask[6]; + __le16 l2_ovlan; + __le16 l2_ovlan_mask; + __le16 l2_ivlan; + __le16 l2_ivlan_mask; + u8 unused_1[2]; + u8 t_l2_addr[6]; + u8 unused_2[2]; + u8 t_l2_addr_mask[6]; + __le16 t_l2_ovlan; + __le16 t_l2_ovlan_mask; + __le16 t_l2_ivlan; + __le16 t_l2_ivlan_mask; + u8 src_type; +#define CFA_L2_FILTER_ALLOC_REQ_SRC_TYPE_NPORT 0x0UL + u8 unused_3; + __le32 src_id; + u8 tunnel_type; + u8 unused_4; + __le16 dst_id; + __le16 mirror_vnic_id; + u8 pri_hint; + u8 unused_5; + __le32 unused_6; + __le64 l2_filter_id_hint; +}; + +/* hwrm_cfa_l2_filter_alloc_output (size:192b/24B) */ +struct hwrm_cfa_l2_filter_alloc_output { + __le16 error_code; + __le16 req_type; + __le16 seq_id; + __le16 resp_len; + __le64 l2_filter_id; + __le32 flow_id; + u8 unused_0[3]; + u8 valid; +}; + +/* hwrm_cfa_l2_filter_free_input (size:192b/24B) */ +struct hwrm_cfa_l2_filter_free_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le64 l2_filter_id; +}; + +/* hwrm_cfa_l2_set_rx_mask_input (size:448b/56B) */ +struct hwrm_cfa_l2_set_rx_mask_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le32 vnic_id; + __le32 mask; +#define CFA_L2_SET_RX_MASK_REQ_MASK_MCAST 0x2UL +#define CFA_L2_SET_RX_MASK_REQ_MASK_ALL_MCAST 0x4UL +#define CFA_L2_SET_RX_MASK_REQ_MASK_BCAST 0x8UL +#define CFA_L2_SET_RX_MASK_REQ_MASK_PROMISCUOUS 0x10UL + __le64 mc_tbl_addr; + __le32 num_mc_entries; + u8 unused_0[4]; + __le64 vlan_tag_tbl_addr; + __le32 num_vlan_tags; + u8 unused_1[4]; +}; + +/* hwrm_stat_ctx_alloc_input (size:256b/32B) */ +struct hwrm_stat_ctx_alloc_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le64 stats_dma_addr; + __le32 update_period_ms; + u8 stat_ctx_flags; + u8 unused_0[3]; +}; + +/* hwrm_stat_ctx_alloc_output (size:128b/16B) */ +struct hwrm_stat_ctx_alloc_output { + __le16 error_code; + __le16 req_type; + __le16 seq_id; + __le16 resp_len; + __le32 stat_ctx_id; + u8 unused_0[3]; + u8 valid; +}; + +/* hwrm_stat_ctx_free_input (size:192b/24B) */ +struct hwrm_stat_ctx_free_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le32 stat_ctx_id; + u8 unused_0[4]; +}; + +/* hwrm_nvm_flush_input (size:128b/16B) */ +struct hwrm_nvm_flush_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; +}; + +/* hwrm_nvm_get_variable_input (size:320b/40B) */ +struct hwrm_nvm_get_variable_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le64 dest_data_addr; + __le16 data_len; + __le16 option_num; + __le16 dimensions; + __le16 index_0; + __le16 index_1; + __le16 index_2; + __le16 index_3; + u8 flags; + u8 unused_0; +}; + +/* hwrm_nvm_set_variable_input (size:320b/40B) */ +struct hwrm_nvm_set_variable_input { + __le16 req_type; + __le16 cmpl_ring; + __le16 seq_id; + __le16 target_id; + __le64 resp_addr; + __le64 src_data_addr; + __le16 data_len; + __le16 option_num; + __le16 dimensions; + __le16 index_0; + __le16 index_1; + __le16 index_2; + __le16 index_3; + u8 flags; + u8 unused_0; +}; + +#endif /* _BNXT_HSI_H_ */ diff --git a/include/pci_ids.h b/include/pci_ids.h index 7ecedc7f04cf..3c5434c0eda8 100644 --- a/include/pci_ids.h +++ b/include/pci_ids.h @@ -151,6 +151,9 @@ #define PCI_DEVICE_ID_BERKOM_A4T 0xffa4 #define PCI_DEVICE_ID_BERKOM_SCITEL_QUADRO 0xffa8
+#define PCI_VENDOR_ID_BROADCOM 0x14e4 +#define PCI_DEVICE_ID_NXT_57320 0x16F0 + #define PCI_VENDOR_ID_COMPAQ 0x0e11 #define PCI_DEVICE_ID_COMPAQ_TOKENRING 0x0508 #define PCI_DEVICE_ID_COMPAQ_TACHYON 0xa0fc
Load NetXtreme firmware in board_init when BNXT_ETH is selected.
Signed-off-by: Bharat Gooty bharat.gooty@broadcom.com
Signed-off-by: Roman Bacik roman.bacik@broadcom.com ---
(no changes since v4)
Changes in v4: - remove bnxt commands - load bnxt firmware in board_init
Changes in v3: - remove commands set/get mac/speed - add doc/bnxt.rst
board/broadcom/bcmns3/ns3.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/board/broadcom/bcmns3/ns3.c b/board/broadcom/bcmns3/ns3.c index 32acf367842a..88036c16c951 100644 --- a/board/broadcom/bcmns3/ns3.c +++ b/board/broadcom/bcmns3/ns3.c @@ -150,7 +150,10 @@ int board_init(void)
if (bl33_info->version != BL33_INFO_VERSION) printf("*** warning: ATF BL31 and U-Boot not in sync! ***\n"); - +#if CONFIG_IS_ENABLED(BNXT_ETH) + if (chimp_fastboot_optee() != 0) + printf("*** warning: secure chimp fastboot failed! ***\n"); +#endif return 0; }
On Mon, Nov 8, 2021 at 10:40 AM Roman Bacik roman.bacik@broadcom.com wrote:
Broadcom bnxt L2 driver support. Used by the Broadcom iproc platforms.
Signed-off-by: Bharat Gooty bharat.gooty@broadcom.com Reviewed-by: Ramon Fried rfried.dev@gmail.com
Changes in v9:
- remove bnxt_ver.h
- add DRIVER_VERSION_* definitions to bnxt.h
- remove pci_read_/pci_write_/pci_map_ definitions from bnxt.h
Changes in v8:
- remove PCICFG_ME_REGISTER
Changes in v7:
- move bnxt_*.h files to drivers/net/bnxt/
- remove display_banner()
- replace pci_map_bar() with dm_pci_map_bar()
- remove changes to dev->flags_
- move PCI DID and VID definitions to include/pci_ids.h
- move bnxt_nics[] to bnxt.c
- move bnxt_alloc_mem to bnxt_read_rom_hw
- return proper error codes in bnxt_read_rom_hwaddr
Changes in v6:
- remove bnxt_eth_* env variables
- clean up include headers
Changes in v5:
- remove bnxt_env_set_ethaddr/bnxt_env_del_ethaddr methods
- add .read_rom_hwaddr = bnxt_read_rom_hwaddr
- move bnxt_bring_pci/bnxt_bring_chip to bnxt_read_rom_hwddr
- move mac copy from priv to plat to bnxt_read_rom_hwaddr
Changes in v4:
- remove static num_cards and use dev_seq(dev) instead
- add .probe
- merged probe/remove methods
- select PCI_INIT_R when BNXT_ETH is selected
Changes in v3:
- change printf to debug in display_banner
- remove get/set/print mac/speed
- remove bnxt_hwrm_set_nvmem
Changes in v2:
- rebase and remove DM_PCI dependency from BNXT_ETH
- remove tautology assignment from debug_resp()
drivers/net/Kconfig | 1 + drivers/net/Makefile | 1 + drivers/net/bnxt/Kconfig | 7 + drivers/net/bnxt/Makefile | 5 + drivers/net/bnxt/bnxt.c | 1706 +++++++++++++++++++++++++++++++++++ drivers/net/bnxt/bnxt.h | 390 ++++++++ drivers/net/bnxt/bnxt_dbg.h | 536 +++++++++++ drivers/net/bnxt/bnxt_hsi.h | 889 ++++++++++++++++++ include/pci_ids.h | 3 + 9 files changed, 3538 insertions(+) create mode 100644 drivers/net/bnxt/Kconfig create mode 100644 drivers/net/bnxt/Makefile create mode 100644 drivers/net/bnxt/bnxt.c create mode 100644 drivers/net/bnxt/bnxt.h create mode 100644 drivers/net/bnxt/bnxt_dbg.h create mode 100644 drivers/net/bnxt/bnxt_hsi.h
int ret;
if (ret) {
return ret;
bnxt_bring_pci(bp);
if (ret) {
return -ENODATA;
We will move the code above back to the probe method in v10 as requested. I was wrong, there was no need to move it here. Thanks,
Roman
Roman Bacik
