[U-Boot] [PATCH resend 0/2] config_distro_bootcmd: Avoid usb getting scanned tw
Hi All,
I did not get any feedback on the original posting of these series, can I please get some feedback ?
If I can get acks for this from people involved in config_distro_bootcmd (Warren, Dennis ?) then I can queue this up in u-boot-sunxi/next unless people want to see this merged through some other tree.
Regards,
Hans
When using usb-keyboard support, typically usb will already get started from preboot. In this case doing it again in the bootcmd is undesirable.
Allow the user of config_distro_bootcmd to indicate that usb is inited in preboot through the user setting BOOTENV_PREBOOT_INITS_USB.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- include/config_distro_bootcmd.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index be616e8..fd01a34 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -91,7 +91,11 @@
#ifdef CONFIG_CMD_USB #define BOOTENV_RUN_USB_INIT "run usb_init; " +#ifndef BOOTENV_PREBOOT_INITS_USB #define BOOTENV_SET_USB_NEED_INIT "setenv usb_need_init; " +#else +#define BOOTENV_SET_USB_NEED_INIT "setenv usb_need_init false; " +#endif #define BOOTENV_SHARED_USB \ "usb_init=" \ "if ${usb_need_init}; then " \
Sorry, I don't recall seeing this whenever it was posted before.
Conceptually this seems fine. One issue it has is with the following sequence:
PREBOOT inits USB, no USB drive found (not plugged in) User CTRL-Cs boot sequence User plugs in USB drive User runs "boot" or "run bootcmd" -> USB not re-detected, so system doesn't boot from USB.
Perhaps the best way to solve this is to have a flag controlling whether BOOTENV_SET_USB_NEED_INIT sets $usb_need_init?
preboot: setenv usb_do_set_usb_need_init false
BOOTENV_SET_USB_NEED_INIT: # Normally unset -> true # In your case, preboot sets this to false if ${usb_do_set_usb_need_init}; then setenv usb_need_init else # Next time $boot is run, this will be unset -> true # so we will re-init USB setenv usb_do_set_usb_need_init # This time through, we skip USB init setenv usb_need_init false endif
Of course, that doesn't solve the problem of the user aborting auto-boot before it's ever run once. Perhaps better would be a flag that BOOTENV_SET_USB_NEED_INIT can use to distinguish auto-boot and manual invocation, i.e.:
BOOTENV_SET_USB_NEED_INIT: # U-Boot C code sets this appropriatelyL if ${auto_boot}; then # Auto case: Init USB unless preboot set a flag if ${usb_do_set_usb_need_init}; then setenv usb_need_init else # Next time $boot is run, this will be unset -> true # so we will re-init USB setenv usb_do_set_usb_need_init # This time through, we skip USB init setenv usb_need_init false endif else # Manual case: Always init USB setenv usb_need_init endif
Or do we just assume that if the user plugs in a new USB device after boot, they must manually run USB initialization? If so, we cam simplify the existing $usb_need_init a bit...
Looking at all the extra code (and possible bugs / problems that code may introduce), I think that it makes sense to just expect the user to run "usb reset" after plugging in a new device.
Regards,
Hans
Use the new BOOTENV_PREBOOT_INITS_USB define to avoid usb being scanned twice when using usb kbd + usb boot.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- include/configs/sunxi-common.h | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 3f890b2..7b958f8 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -302,12 +302,11 @@ func(PXE, pxe, na) \ func(DHCP, dhcp, na)
-#include <config_distro_bootcmd.h> - #ifdef CONFIG_USB_KEYBOARD #define CONSOLE_STDIN_SETTINGS \ "preboot=usb start\0" \ "stdin=serial,usbkbd\0" +#define BOOTENV_PREBOOT_INITS_USB #else #define CONSOLE_STDIN_SETTINGS \ "stdin=serial\0" @@ -327,6 +326,8 @@ CONSOLE_STDIN_SETTINGS \ CONSOLE_STDOUT_SETTINGS
+#include <config_distro_bootcmd.h> + #define CONFIG_EXTRA_ENV_SETTINGS \ CONSOLE_ENV_SETTINGS \ MEM_LAYOUT_ENV_SETTINGS \
Subject to Dennis and/or Stephen acking the first patch from the sunxi point of view this one is: Acked-by: Ian Campbell ijc@hellion.org.uk
Hans de Goede
Ian Campbell
Stephen Warren
