[PATCH] defconfigs: Add a config for AM43xx HS EVM with QSPI Boot support
On AM43xx HS devices, QSPI boot is XIP and we use a single stage bootloader. Add a defconfig for this.
Signed-off-by: Andrew Davis afd@ti.com --- MAINTAINERS | 1 + configs/am43xx_hs_evm_qspi_defconfig | 74 ++++++++++++++++++++++++++++ 2 files changed, 75 insertions(+) create mode 100644 configs/am43xx_hs_evm_qspi_defconfig
diff --git a/MAINTAINERS b/MAINTAINERS index b85629d9b1..39c274c99c 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1363,6 +1363,7 @@ F: arch/arm/mach-k3/config_secure.mk F: configs/am335x_hs_evm_defconfig F: configs/am335x_hs_evm_uart_defconfig F: configs/am43xx_hs_evm_defconfig +F: configs/am43xx_hs_evm_qspi_defconfig F: configs/am57xx_hs_evm_defconfig F: configs/am57xx_hs_evm_usb_defconfig F: configs/dra7xx_hs_evm_defconfig diff --git a/configs/am43xx_hs_evm_qspi_defconfig b/configs/am43xx_hs_evm_qspi_defconfig new file mode 100644 index 0000000000..5cf447704d --- /dev/null +++ b/configs/am43xx_hs_evm_qspi_defconfig @@ -0,0 +1,74 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +# CONFIG_SYS_THUMB_BUILD is not set +CONFIG_ARCH_OMAP2PLUS=y +CONFIG_TI_SECURE_DEVICE=y +CONFIG_ISW_ENTRY_ADDR=0x300018e0 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x110000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="am43x-epos-evm" +CONFIG_AM43XX=y +CONFIG_TI_SECURE_EMIF_REGION_START=0xbdb00000 +CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 +CONFIG_TI_SECURE_EMIF_PROTECTED_REGION_SIZE=0x01c00000 +CONFIG_ENV_OFFSET_REDUND=0x120000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4033ff00 +CONFIG_QSPI_BOOT=y +CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_BOARD_EARLY_INIT_F=y +# CONFIG_MISC_INIT_R is not set +CONFIG_SYS_MAXARGS=64 +CONFIG_CMD_ASKENV=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_OF_LIST="am4372-generic am437x-sk-evm am437x-idk-evm" +CONFIG_DTB_RESELECT=y +CONFIG_MULTI_DTB_FIT=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RETRY_COUNT=10 +CONFIG_BOOTP_SEND_HOSTNAME=y +CONFIG_SYS_RX_ETH_BUFFER=64 +CONFIG_DM=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_MMC_OMAP_HS=y +CONFIG_SF_DEFAULT_SPEED=48000000 +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_MII=y +CONFIG_DRIVER_TI_CPSW=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_TI_QSPI=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_XHCI_OMAP=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_OMAP=y +CONFIG_USB_DWC3_PHY_OMAP=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0403 +CONFIG_USB_GADGET_PRODUCT_NUM=0xbd00 +CONFIG_USB_GADGET_DOWNLOAD=y
Andrew Davis
