[RFC PATCH 0/8] migrate u-boot-rockchip.bin to binman and generate an image for SPI
From: Quentin Schulz quentin.schulz@theobroma-systems.com
This migrates the generation of u-boot-rockchip.bin from Makefile to binman completely. There is therefore no idbloader.img anymore as it is created on the fly by binman.
This also adds support for generating the same kind of image than u-boot-rockchip.bin but for SPI flashes (specifically, a different image type generated by mkimage is necessary, in addition to a different offset in the storage medium).
This has been tested on Puma RK3399 with patches soon to be sent to the ML.
This is a pretty big change and would like people having access to Rockchip devices to extensively test those (especially those Aarch32 devices I don't have access to) whenever possible. Please also provide feedback/patches on missing docs updates.
This also helped removing the hardcoded value for the u-boot.itb offset in u-boot-rockchip.bin which prevented Puma SoM to be migrated to it.
Cheers, Quentin
Quentin Schulz (8): rockchip: generate idbloader.img content for u-boot-rockchip.bin with binman for ARM rockchip: generate u-boot-rockchip.bin with binman for ARM64 boards rockchip: remove unneeded CONFIG_SPL_PAD_TO rockchip: pad u-boot-rockchip.bin correctly rockchip: simplify binman image dependencies addition to INPUTS rockchip: allow to build SPI images even without HAS_ROM option binman: add support for skipping file concatenation for mkimage rockchip: add u-boot-rockchip-spi.bin image for booting from SPI-NOR flash
Makefile | 39 ++++-------------------- arch/arm/Kconfig | 2 +- arch/arm/dts/rk3288-u-boot.dtsi | 2 +- arch/arm/dts/rk3399-u-boot.dtsi | 2 +- arch/arm/dts/rockchip-u-boot.dtsi | 50 +++++++++++++++++++++++++++++-- arch/arm/mach-rockchip/Kconfig | 6 ++-- doc/board/rockchip/rockchip.rst | 2 +- include/configs/rockchip-common.h | 2 -- tools/binman/entries.rst | 22 ++++++++++++++ tools/binman/etype/mkimage.py | 41 ++++++++++++++++++++++--- 10 files changed, 118 insertions(+), 50 deletions(-)
idbloader.img content - currently created by way of Makefile - can be created by binman directly.
So let's do that for Rockchip ARM platforms.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- Makefile | 2 +- arch/arm/dts/rockchip-u-boot.dtsi | 15 +++++++++++++-- 2 files changed, 14 insertions(+), 3 deletions(-)
diff --git a/Makefile b/Makefile index 98867fbe06..ec6a13fd05 100644 --- a/Makefile +++ b/Makefile @@ -1000,7 +1000,7 @@ endif else ifeq ($(CONFIG_SPL),y) # Generate these inputs for binman which will create the output files -INPUTS-y += idbloader.img u-boot.img +INPUTS-y += u-boot.img endif endif endif diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index eae3ee715d..0362c97e0b 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -17,9 +17,20 @@ filename = "u-boot-rockchip.bin"; pad-byte = <0xff>;
- blob { - filename = "idbloader.img"; + mkimage { + args = "-n", CONFIG_SYS_SOC, "-T", "rksd"; +#ifndef CONFIG_TPL + u-boot-spl { + }; }; +#else + u-boot-tpl { + }; + }; + + u-boot-spl { + }; +#endif
u-boot-img { offset = <CONFIG_SPL_PAD_TO>;
This allows to build u-boot-rockchip.bin binary with binman for Rockchip ARM64 boards instead of the legacy Makefile way.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- Makefile | 28 ++-------------------------- arch/arm/Kconfig | 2 +- arch/arm/dts/rockchip-u-boot.dtsi | 5 +++++ 3 files changed, 8 insertions(+), 27 deletions(-)
diff --git a/Makefile b/Makefile index ec6a13fd05..d4f53afc66 100644 --- a/Makefile +++ b/Makefile @@ -994,8 +994,7 @@ ifeq ($(CONFIG_ARCH_ROCKCHIP),y) # On ARM64 this target is produced by binman so we don't need this dep ifeq ($(CONFIG_ARM64),y) ifeq ($(CONFIG_SPL),y) -# TODO: Get binman to generate this too -INPUTS-y += u-boot-rockchip.bin +INPUTS-y += u-boot.itb endif else ifeq ($(CONFIG_SPL),y) @@ -1488,29 +1487,6 @@ OBJCOPYFLAGS_u-boot-with-spl.bin = -I binary -O binary \ u-boot-with-spl.bin: $(SPL_IMAGE) $(SPL_PAYLOAD) FORCE $(call if_changed,pad_cat)
-ifeq ($(CONFIG_ARCH_ROCKCHIP),y) - -# TPL + SPL -ifeq ($(CONFIG_SPL)$(CONFIG_TPL),yy) -MKIMAGEFLAGS_u-boot-tpl-rockchip.bin = -n $(CONFIG_SYS_SOC) -T rksd -tpl/u-boot-tpl-rockchip.bin: tpl/u-boot-tpl.bin FORCE - $(call if_changed,mkimage) -idbloader.img: tpl/u-boot-tpl-rockchip.bin spl/u-boot-spl.bin FORCE - $(call if_changed,cat) -else -MKIMAGEFLAGS_idbloader.img = -n $(CONFIG_SYS_SOC) -T rksd -idbloader.img: spl/u-boot-spl.bin FORCE - $(call if_changed,mkimage) -endif - -ifeq ($(CONFIG_ARM64),y) -OBJCOPYFLAGS_u-boot-rockchip.bin = -I binary -O binary \ - --pad-to=$(CONFIG_SPL_PAD_TO) --gap-fill=0xff -u-boot-rockchip.bin: idbloader.img u-boot.itb FORCE - $(call if_changed,pad_cat) -endif # CONFIG_ARM64 - -endif # CONFIG_ARCH_ROCKCHIP
ifeq ($(CONFIG_ARCH_LPC32XX)$(CONFIG_SPL),yy) MKIMAGEFLAGS_lpc32xx-spl.img = -T lpc32xximage -a $(CONFIG_SPL_TEXT_BASE) @@ -2213,7 +2189,7 @@ CLEAN_FILES += include/bmp_logo.h include/bmp_logo_data.h \ tools/version.h u-boot* MLO* SPL System.map fit-dtb.blob* \ u-boot-ivt.img.log u-boot-dtb.imx.log SPL.log u-boot.imx.log \ lpc32xx-* bl31.c bl31.elf bl31_*.bin image.map tispl.bin* \ - idbloader.img flash.bin flash.log defconfig keep-syms-lto.c \ + flash.bin flash.log defconfig keep-syms-lto.c \ mkimage-out.spl.mkimage mkimage.spl.mkimage imx-boot.map \ itb.fit.fit itb.fit.itb itb.map spl.map
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 9898c7d68e..4b2464c197 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1973,7 +1973,7 @@ config ARCH_STM32MP config ARCH_ROCKCHIP bool "Support Rockchip SoCs" select BLK - select BINMAN if SPL_OPTEE || (SPL && !ARM64) + select BINMAN if SPL_OPTEE || SPL select DM select DM_GPIO select DM_I2C diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index 0362c97e0b..aef6c379e2 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -32,7 +32,12 @@ }; #endif
+#ifdef CONFIG_ARM64 + blob { + filename = "u-boot.itb"; +#else u-boot-img { +#endif offset = <CONFIG_SPL_PAD_TO>; }; };
Since binman takes care of setting the appropriate offset for the SPL payload, there's no need to define this variable anymore.
Moreover, it is technically incorrect since the padding is different depending on whether the first stage bootloader is for a SPI flash or MMC storage medium.
Finally, this allows to use the CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR config option without redefining CONFIG_SPL_PAD_TO in other board header files.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- arch/arm/dts/rockchip-u-boot.dtsi | 2 +- include/configs/rockchip-common.h | 2 -- 2 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index aef6c379e2..fc28ce5187 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -38,7 +38,7 @@ #else u-boot-img { #endif - offset = <CONFIG_SPL_PAD_TO>; + offset = <((CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR - 64) * 512)>; }; }; }; diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index 0c08776ae2..40d5a02fc8 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -9,8 +9,6 @@
#define CONFIG_SYS_NS16550_MEM32
-/* ((CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR - 64) * 512) */ -#define CONFIG_SPL_PAD_TO 8355840
#ifndef CONFIG_SPL_BUILD
On MMC storage media, the TPL/SPL needs to be flashed at offset 32KB. Instead of requesting the user to put the input the appropriate offsets, let's create u-boot-rockchip.bin with the padding already added.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- arch/arm/dts/rockchip-u-boot.dtsi | 3 ++- doc/board/rockchip/rockchip.rst | 2 +- 2 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index fc28ce5187..4cd243514e 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -18,6 +18,7 @@ pad-byte = <0xff>;
mkimage { + offset = <(32 * 1024)>; /* 32KB */ args = "-n", CONFIG_SYS_SOC, "-T", "rksd"; #ifndef CONFIG_TPL u-boot-spl { @@ -38,7 +39,7 @@ #else u-boot-img { #endif - offset = <((CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR - 64) * 512)>; + offset = <(CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)>; }; }; }; diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 4ca7b00b1f..1995882244 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -179,7 +179,7 @@ To write an image that boots from a SD card (assumed to be /dev/sda):
.. code-block:: bash
- sudo dd if=u-boot-rockchip.bin of=/dev/sda seek=64 + sudo dd if=u-boot-rockchip.bin of=/dev/sda sync
eMMC
NAK.
The storage layout provided by Rockchip leaves space for a (protective) MBR and a primary GPT. A bootloader update will overwrite the partition table if you create the image as you suggest.
mkimage {
eMMC
2.36.1
Hi Philipp,
NAK.
Ah, that was what I was missing. Thanks, makes complete sense!
Cheers, Quentin
By factoring SPL check in the first condition, this makes the checks a bit less convoluted and more readable.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- Makefile | 9 ++------- 1 file changed, 2 insertions(+), 7 deletions(-)
diff --git a/Makefile b/Makefile index d4f53afc66..ad95cd0c96 100644 --- a/Makefile +++ b/Makefile @@ -990,19 +990,14 @@ ifeq ($(CONFIG_MPC85xx)$(CONFIG_OF_SEPARATE),yy) INPUTS-y += u-boot-with-dtb.bin endif
-ifeq ($(CONFIG_ARCH_ROCKCHIP),y) -# On ARM64 this target is produced by binman so we don't need this dep +ifeq ($(CONFIG_ARCH_ROCKCHIP)$(CONFIG_SPL),yy) +# Binman image dependencies ifeq ($(CONFIG_ARM64),y) -ifeq ($(CONFIG_SPL),y) INPUTS-y += u-boot.itb endif else -ifeq ($(CONFIG_SPL),y) -# Generate these inputs for binman which will create the output files INPUTS-y += u-boot.img endif -endif -endif
INPUTS-$(CONFIG_X86) += u-boot-x86-start16.bin u-boot-x86-reset16.bin \ $(if $(CONFIG_SPL_X86_16BIT_INIT),spl/u-boot-spl.bin) \
This prepares for the creation of a u-boot-rockchip-spi.bin image similar to u-boot-rockchip.bin to the exception it's destined for SPI-NOR flashes instead of MMC storage medium.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- arch/arm/dts/rk3288-u-boot.dtsi | 2 +- arch/arm/dts/rk3399-u-boot.dtsi | 2 +- arch/arm/mach-rockchip/Kconfig | 6 ++---- 3 files changed, 4 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/rk3288-u-boot.dtsi b/arch/arm/dts/rk3288-u-boot.dtsi index 9eb696b141..e411445ed6 100644 --- a/arch/arm/dts/rk3288-u-boot.dtsi +++ b/arch/arm/dts/rk3288-u-boot.dtsi @@ -56,7 +56,7 @@ }; };
-#ifdef CONFIG_ROCKCHIP_SPI_IMAGE +#if defined(CONFIG_ROCKCHIP_SPI_IMAGE) && defined(CONFIG_HAS_ROM) &binman { rom { filename = "u-boot.rom"; diff --git a/arch/arm/dts/rk3399-u-boot.dtsi b/arch/arm/dts/rk3399-u-boot.dtsi index 716b9a433a..3c1a15fe51 100644 --- a/arch/arm/dts/rk3399-u-boot.dtsi +++ b/arch/arm/dts/rk3399-u-boot.dtsi @@ -60,7 +60,7 @@
-#ifdef CONFIG_ROCKCHIP_SPI_IMAGE +#if defined(CONFIG_ROCKCHIP_SPI_IMAGE) && defined(CONFIG_HAS_ROM) &binman { rom { filename = "u-boot.rom"; diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index c561a77e6a..b46cea2f91 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -425,12 +425,10 @@ config SPL_MMC
config ROCKCHIP_SPI_IMAGE bool "Build a SPI image for rockchip" - depends on HAS_ROM help Some Rockchip SoCs support booting from SPI flash. Enable this - option to produce a 4MB SPI-flash image (called u-boot.rom) - containing U-Boot. The image is built by binman. U-Boot sits near - the start of the image. + option to produce a SPI-flash image containing U-Boot. The image + is built by binman. U-Boot sits near the start of the image.
config LNX_KRNL_IMG_TEXT_OFFSET_BASE default SYS_TEXT_BASE
Some image types handled by mkimage require the datafiles to be passed independently (-d data1:data2) for specific handling of each. A concatenation of datafiles prior to passing them to mkimage wouldn't work.
That is the case for rksd and rkspi for example, which require page alignment (plus some weird hack for rkspi) plus size data of each stage to be embedded in the mkimage header.
This adds the ability to tell binman to pass the datafiles without prior concatenation to mkimage, by adding the multiple-data-files boolean property to the mkimage node.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- tools/binman/entries.rst | 22 +++++++++++++++++++ tools/binman/etype/mkimage.py | 41 +++++++++++++++++++++++++++++++---- 2 files changed, 59 insertions(+), 4 deletions(-)
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index ae4305c99e..60c89aec59 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1101,6 +1101,9 @@ Entry: mkimage: Binary produced by mkimage
Properties / Entry arguments: - datafile: Filename for -d argument + - multiple-data-files: boolean to tell binman to pass all files as + datafiles to mkimage instead of creating a temporary file the result + of datafiles concatenation - args: Other arguments to pass
The data passed to mkimage is collected from subnodes of the mkimage node, @@ -1117,6 +1120,25 @@ This calls mkimage to create an imximage with u-boot-spl.bin as the input file. The output from mkimage then becomes part of the image produced by binman.
+To pass all datafiles untouched to mkimage:: + + mkimage { + args = "-n rk3399 -T rkspi"; + multiple-data-files; + + u-boot-tpl { + }; + + u-boot-spl { + }; + }; + +This calls mkimage to create a Rockchip RK3399-specific first stage +bootloader, made of TPL+SPL. Since this first stage bootloader requires to +align the TPL and SPL but also some weird hacks that is handled by mkimage +directly, binman is told to not perform the concatenation of datafiles prior +to passing the data to mkimage. + To use CONFIG options in the arguments, use a string list instead, as in this example which also produces four arguments::
diff --git a/tools/binman/etype/mkimage.py b/tools/binman/etype/mkimage.py index 5f6def2287..52297c23ea 100644 --- a/tools/binman/etype/mkimage.py +++ b/tools/binman/etype/mkimage.py @@ -16,6 +16,9 @@ class Entry_mkimage(Entry):
The data passed to mkimage is collected from subnodes of the mkimage node, @@ -32,6 +35,25 @@ class Entry_mkimage(Entry): file. The output from mkimage then becomes part of the image produced by binman.
+ To pass all datafiles untouched to mkimage:: + + mkimage { + args = "-n rk3399 -T rkspi"; + multiple-data-files; + + u-boot-tpl { + }; + + u-boot-spl { + }; + }; + + This calls mkimage to create a Rockchip RK3399-specific first stage + bootloader, made of TPL+SPL. Since this first stage bootloader requires to + align the TPL and SPL but also some weird hacks that is handled by mkimage + directly, binman is told to not perform the concatenation of datafiles prior + to passing the data to mkimage. + To use CONFIG options in the arguments, use a string list instead, as in this example which also produces four arguments::
@@ -46,16 +68,27 @@ class Entry_mkimage(Entry): def __init__(self, section, etype, node): super().__init__(section, etype, node) self._args = fdt_util.GetArgs(self._node, 'args') + self._multiple_data_files = fdt_util.GetBool(self._node, 'multiple-data-files') self._mkimage_entries = OrderedDict() self.align_default = None self.ReadEntries()
def ObtainContents(self): # Use a non-zero size for any fake files to keep mkimage happy - data, input_fname, uniq = self.collect_contents_to_file( - self._mkimage_entries.values(), 'mkimage', 1024) - if data is None: - return False + fake_size = 1024 + if self._multiple_data_files: + fnames = [] + uniq = self.GetUniqueName() + for entry in self._mkimage_entries.values(): + if not entry.ObtainContents(fake_size=fake_size): + return False + fnames.append(entry.GetDefaultFilename()) + input_fname = ":".join(fnames) + else: + data, input_fname, uniq = self.collect_contents_to_file( + self._mkimage_entries.values(), 'mkimage', fake_size) + if data is None: + return False output_fname = tools.get_output_filename('mkimage-out.%s' % uniq) if self.mkimage.run_cmd('-d', input_fname, *self._args, output_fname) is not None:
I wonder if we should move this logic to binman (from mkimage) when all the boards are converted to binman?
Hi Simon,
I forgot to rephrase the commit log. As seen in patch 1/8, there actually doesn't seem to be a need for rksd for passing multiple data files to mkimage, only the TPL could be passed to mkimage and SPL appended right after that blob generated by mkimage. Maybe it's luck but it seems to work for me the few tries I did on SD card and eMMC.
Not sure this fits the "Relationship to mkimage" section in binman.rst? What part of the logic exactly would you like to move from mkimage to binman?
Cheers, Quentin
Hi Quentin,
On Mon, 18 Jul 2022 at 03:39, Quentin Schulz quentin.schulz@theobroma-systems.com wrote:
Hi Simon,
OK I see.
The concatenation of the files and the strange SPI processing, for example. It's just an idea and it is OK to keep it in mkimage.
This new image is similar to u-boot-rockchip.bin except that it's destined to be flashed on SPI-NOR flashes.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- arch/arm/dts/rockchip-u-boot.dtsi | 29 +++++++++++++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index 4cd243514e..d378d9d57b 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -42,5 +42,34 @@ offset = <(CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)>; }; }; + +#ifdef CONFIG_ROCKCHIP_SPI_IMAGE + simple-bin-spi { + filename = "u-boot-rockchip-spi.bin"; + pad-byte = <0xff>; + + mkimage { + args = "-n", CONFIG_SYS_SOC, "-T", "rkspi"; +#ifdef CONFIG_TPL + multiple-data-files; + + u-boot-tpl { + }; +#endif + u-boot-spl { + }; + }; + +#ifdef CONFIG_ARM64 + blob { + filename = "u-boot.itb"; +#else + u-boot-img { +#endif + /* Sync with u-boot,spl-payload-offset if present */ + offset = <CONFIG_SYS_SPI_U_BOOT_OFFS>; + }; + }; +#endif }; #endif
Philipp Tomsich
Quentin Schulz
Quentin Schulz
