[U-Boot] [PATCH] common: Fix logic in fpga programming
Stop boot process if fpga programming fails.
common/image.c | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/common/image.c b/common/image.c index bd07e86701a4..e3486e46a459 100644 --- a/common/image.c +++ b/common/image.c @@ -1375,11 +1375,10 @@ int boot_get_fpga(int argc, char * const argv[], bootm_headers_t *images, img_len, BIT_PARTIAL); }
- printf(" Programming %s bitstream... ", name); if (err) - printf("failed\n"); - else - printf("OK\n"); + return 1; + + printf(" Programming %s bitstream... OK", name); break; default: printf("The given image format is not supported (corrupt?)\n");
if (err)printf(" Programming %s bitstream... ", name);
printf("failed\n");
else
printf("OK\n");
return 1;
Wouldn't "return err;" or "return -EIO;" make sense here instead of a magic "1"?
break; default: printf("The given image format is not supported (corrupt?)\n");printf(" Programming %s bitstream... OK", name);
Kind regards,
Mike Looijmans System Expert
TOPIC Products Materiaalweg 4, NL-5681 RJ Best Postbus 440, NL-5680 AK Best Telefoon: +31 (0) 499 33 69 79 E-mail: mike.looijmans@topicproducts.com Website: www.topicproducts.com
Please consider the environment before printing this e-mail
printf("failed\n");
else
printf("OK\n");
return 1;
Good idea. Will send v2
Thanks, Michal
Dear Michal...
In message 1e029d3a67722c20d8b6194d3388efe5ca92f5bf.1481881501.git.michal.simek@xilinx.com you wrote:
printf("failed\n");
else
printf("OK\n");
return 1;
Good old U-Boot style says we print a message when we start an operation, and then an OK / failed when done. When the system crashes in this command, you can see at last where it crashed, i. e. what the last running command was.
Your change breaks this - in the error path nothing gets printed.
This is even worse, as even though the system keeps running the user has no indication of what failed...
I suggest to keep the printf() as before, and just fix the return code thing.
On 20.12.2016 18:30, Wolfgang Denk wrote:
Dear Michal...
printf("failed\n");
else
printf("OK\n");
return 1;
Based on this style the first part of this message should be called at the beginning of this function not in this possition.
If you look at the code 253 ret = boot_get_fpga(argc, argv, &images, IH_ARCH_DEFAULT, 254 NULL, NULL); 255 if (ret) { 256 printf("FPGA image is corrupted or invalid\n"); 257 return 1; 258 }
There is already printf for error.
Isn't it message above enough?
Thanks, Michal
Dear Michal,
True,,,
Hm... Sorry, I did not follow all brachnes thrugh the code this i snot exactly obvious from the patch.
In the patch, I see only a "return 1;".
Dear Wolfgang,
On 21.12.2016 00:19, Wolfgang Denk wrote:
Dear Michal,
True,,,
ok.
Like in every patch which error out in the middle of function and return 0 at the end. Please look at that function and you will see that at the end there is return 0.
Thanks, Michal
Michal Simek
Mike Looijmans
