[U-Boot] [PATCH] nios2: convert dma mapping to use dm cpu data
Convert dma mapping to use dm cpu data.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/nios2/include/asm/dma-mapping.h | 21 +++++++++++---------- 1 file changed, 11 insertions(+), 10 deletions(-)
diff --git a/arch/nios2/include/asm/dma-mapping.h b/arch/nios2/include/asm/dma-mapping.h index 1350e3b..403166b 100644 --- a/arch/nios2/include/asm/dma-mapping.h +++ b/arch/nios2/include/asm/dma-mapping.h @@ -1,23 +1,24 @@ #ifndef __ASM_NIOS2_DMA_MAPPING_H #define __ASM_NIOS2_DMA_MAPPING_H
-/* dma_alloc_coherent() return cache-line aligned allocation which is mapped +/* + * dma_alloc_coherent() return cache-line aligned allocation which is mapped * to uncached io region. - * - * IO_REGION_BASE should be defined in board config header file - * 0x80000000 for nommu, 0xe0000000 for mmu */
static inline void *dma_alloc_coherent(size_t len, unsigned long *handle) { - void *addr = malloc(len + CONFIG_SYS_DCACHELINE_SIZE); + DECLARE_GLOBAL_DATA_PTR; + unsigned long addr = + (unsigned long)malloc(len + gd->arch.dcache_line_size); + if (!addr) return 0; - flush_dcache((unsigned long)addr, len + CONFIG_SYS_DCACHELINE_SIZE); - *handle = ((unsigned long)addr + - (CONFIG_SYS_DCACHELINE_SIZE - 1)) & - ~(CONFIG_SYS_DCACHELINE_SIZE - 1) & ~(IO_REGION_BASE); - return (void *)(*handle | IO_REGION_BASE); + flush_dcache(addr, len + gd->arch.dcache_line_size); + *handle = (addr + gd->arch.dcache_line_size - 1) & + ~(gd->arch.dcache_line_size - 1) & ~gd->arch.io_region_base; + + return (void *)(*handle | gd->arch.io_region_base); }
#endif /* __ASM_NIOS2_DMA_MAPPING_H */
Convert dma_alloc_coherent to use memalign.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 use memalign.
arch/nios2/include/asm/dma-mapping.h | 21 ++++++++------------- 1 file changed, 8 insertions(+), 13 deletions(-)
diff --git a/arch/nios2/include/asm/dma-mapping.h b/arch/nios2/include/asm/dma-mapping.h index 1350e3b..e3a338d 100644 --- a/arch/nios2/include/asm/dma-mapping.h +++ b/arch/nios2/include/asm/dma-mapping.h @@ -1,23 +1,18 @@ #ifndef __ASM_NIOS2_DMA_MAPPING_H #define __ASM_NIOS2_DMA_MAPPING_H
-/* dma_alloc_coherent() return cache-line aligned allocation which is mapped +#include <asm/io.h> + +/* + * dma_alloc_coherent() return cache-line aligned allocation which is mapped * to uncached io region. - * - * IO_REGION_BASE should be defined in board config header file - * 0x80000000 for nommu, 0xe0000000 for mmu */ - static inline void *dma_alloc_coherent(size_t len, unsigned long *handle) { - void *addr = malloc(len + CONFIG_SYS_DCACHELINE_SIZE); - if (!addr) - return 0; - flush_dcache((unsigned long)addr, len + CONFIG_SYS_DCACHELINE_SIZE); - *handle = ((unsigned long)addr + - (CONFIG_SYS_DCACHELINE_SIZE - 1)) & - ~(CONFIG_SYS_DCACHELINE_SIZE - 1) & ~(IO_REGION_BASE); - return (void *)(*handle | IO_REGION_BASE); + *handle = (unsigned long)memalign(ARCH_DMA_MINALIGN, len); + flush_dcache_range(*handle, *handle + len); + + return ioremap(*handle, len); }
v2 use memalign.
- dma_alloc_coherent() return cache-line aligned allocation which is
- IO_REGION_BASE should be defined in board config header file
- 0x80000000 for nommu, 0xe0000000 for mmu
- if (!addr)
- *handle = (unsigned long)memalign(ARCH_DMA_MINALIGN, len);
- flush_dcache_range(*handle, *handle + len);
- return ioremap(*handle, len);
I'd suggest that you do this:
void *reg; unsigned long *h = memalign(...); flush_dcache_range();
reg = ioremap(); if (!reg) fail here
*handle = h; // modify handle after we know ioremap succeeded.
return reg;
Best regards, Marek Vasut
Hi Marek,
return reg;
Thanks a lot for your suggestion. It is much clear with this.
Best regards, Thomas
Hi Marek,
I look into the code again. I think it is the memalign() that might fail due to out of memory. While the ioremap() of nios2 won't fail. So I added a check on memalign() return. Please see v3.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 use memalign. v3 check memalign() return for out of memory.
arch/nios2/include/asm/dma-mapping.h | 23 ++++++++++------------- 1 file changed, 10 insertions(+), 13 deletions(-)
diff --git a/arch/nios2/include/asm/dma-mapping.h b/arch/nios2/include/asm/dma-mapping.h index 1350e3b..0618dc2 100644 --- a/arch/nios2/include/asm/dma-mapping.h +++ b/arch/nios2/include/asm/dma-mapping.h @@ -1,23 +1,20 @@ #ifndef __ASM_NIOS2_DMA_MAPPING_H #define __ASM_NIOS2_DMA_MAPPING_H
-/* dma_alloc_coherent() return cache-line aligned allocation which is mapped +#include <asm/io.h> + +/* + * dma_alloc_coherent() return cache-line aligned allocation which is mapped * to uncached io region. - * - * IO_REGION_BASE should be defined in board config header file - * 0x80000000 for nommu, 0xe0000000 for mmu */ - static inline void *dma_alloc_coherent(size_t len, unsigned long *handle) { - void *addr = malloc(len + CONFIG_SYS_DCACHELINE_SIZE); - if (!addr) - return 0; - flush_dcache((unsigned long)addr, len + CONFIG_SYS_DCACHELINE_SIZE); - *handle = ((unsigned long)addr + - (CONFIG_SYS_DCACHELINE_SIZE - 1)) & - ~(CONFIG_SYS_DCACHELINE_SIZE - 1) & ~(IO_REGION_BASE); - return (void *)(*handle | IO_REGION_BASE); + *handle = (unsigned long)memalign(ARCH_DMA_MINALIGN, len); + if (!*handle) + return NULL; + flush_dcache_range(*handle, *handle + len); + + return ioremap(*handle, len); }
- if (!addr)
This still modifies the handle in both cases (failure and success). We really want to modify external variables in case of failure, no?
- if (!*handle)
return NULL;
Hi Marek,
The *handle return a DMA address, and the function itself return a virtual address. Both of them should be set to NULL in case of failure. It might be wrong to keep DMA address looks alive but actually dead.
Best regards, Thomas Chou
On Saturday, October 10, 2015 at 07:33:06 AM, Thomas Chou wrote:
Hi Marek,
Hi!
So you depend on this property of memalign(), ok, I see. Thanks for clarifying!
I don't quite understand this sentence, can you please rephrase it ?
Hi Marek,
Sorry. I meant the *handle, which is the DMA address, should be invalidated to NULL when the allocation failed.
On Sunday, October 11, 2015 at 03:48:58 AM, Thomas Chou wrote:
Hi Marek,
OK
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 use memalign. v3 check memalign() return for out of memory. v4 use malloc_cache_aligned().
arch/nios2/include/asm/dma-mapping.h | 24 +++++++++++------------- 1 file changed, 11 insertions(+), 13 deletions(-)
diff --git a/arch/nios2/include/asm/dma-mapping.h b/arch/nios2/include/asm/dma-mapping.h index 1350e3b..bfaf662 100644 --- a/arch/nios2/include/asm/dma-mapping.h +++ b/arch/nios2/include/asm/dma-mapping.h @@ -1,23 +1,21 @@ #ifndef __ASM_NIOS2_DMA_MAPPING_H #define __ASM_NIOS2_DMA_MAPPING_H
-/* dma_alloc_coherent() return cache-line aligned allocation which is mapped +#include <memalign.h> +#include <asm/io.h> + +/* + * dma_alloc_coherent() return cache-line aligned allocation which is mapped * to uncached io region. - * - * IO_REGION_BASE should be defined in board config header file - * 0x80000000 for nommu, 0xe0000000 for mmu */ - static inline void *dma_alloc_coherent(size_t len, unsigned long *handle) { - void *addr = malloc(len + CONFIG_SYS_DCACHELINE_SIZE); - if (!addr) - return 0; - flush_dcache((unsigned long)addr, len + CONFIG_SYS_DCACHELINE_SIZE); - *handle = ((unsigned long)addr + - (CONFIG_SYS_DCACHELINE_SIZE - 1)) & - ~(CONFIG_SYS_DCACHELINE_SIZE - 1) & ~(IO_REGION_BASE); - return (void *)(*handle | IO_REGION_BASE); + *handle = (unsigned long)malloc_cache_aligned(len); + if (!*handle) + return NULL; + flush_dcache_range(*handle, *handle + len); + + return ioremap(*handle, len); }
- if (!addr)
- *handle = (unsigned long)malloc_cache_aligned(len);
- if (!*handle)
return NULL;
Wouldn't invalidate_dcache_range() be enough here ? You don't care about the data in the newly allocated area at this point I guess -- either you fill them in and then flush, for DMA from CPU to device OR you receive data from device to CPU and then you invalidate this buffer again.
Hi Marek,
No. We cannot use invalidate cache here. This is related to cache design of nios2, kind of direct mapped cache.
On Monday, October 12, 2015 at 02:55:03 PM, Thomas Chou wrote:
Hi Marek,
Hi Thomas,
Can you please expand on this ?
btw. I was thinking about this whole cache situation. Please don't get me wrong, my intention is not to put way more work unto you and/or grind you about minor details. I hope it doesn't look that way to you.
Hi Marek,
Hi Marek,
Hi Thomas,
This is rather hardware depended.
Please refer to page 7 about cache implementation on the "Nios II Core Implementation Detail" manual,
https://www.altera.com/content/dam/altera-www/global/en_US/pdfs/literature/h...
And page 227, 8-44 about initd and initda instructions on the "Nios II Classic Processor Reference Guide",
The initda instruction might do the job. But nios2 cpu with 4 bytes dcache line size does not support this instruction. So we don't implement the invalidate_dcache_range/all() in u-boot yet.
Of course, we can add the invalidate cache ops if we can drop the support of nios2 cpu with 4 bytes dcache line size.
No worries. It is just that I had very little free time last night to give more details. You are welcome.
Hi Marek,
Thanks a lot for your suggestion. I added invalidate_dcache_range() which will check if the initda instruction is supported by the nios2 cpu.
On Wednesday, October 14, 2015 at 03:48:21 AM, Thomas Chou wrote:
Hi Marek,
Hi!
Ah, thanks!
On Tuesday, October 13, 2015 at 02:17:53 AM, Thomas Chou wrote:
Hi Marek,
Hi!
Hi Marek,
Hi Thomas,
https://www.altera.com/content/dam/altera-www/global/en_US/pdfs/literature/ hb/nios2/n2cpu_nii51015.pdf
https://www.altera.com/content/dam/altera-www/global/en_US/pdfs/literature/ hb/nios2/n2cpu_nii5v1.pdf
I'd say that's the instruction we need, yep.
Where did you find this information ?
Thanks!
Please find it on the foot note of table 7, page 8 of "Nios II Core Implementation Detail" manual,
The 4-byte line data cache implementation substitutes the flushd instruction for the flushda instruction and triggers an unimplemented instruction exception for the initda instruction. The 16-byte and 32-byte line data cache implementations fully support the flushda and initda instructions.
I see, thank you for looking it up for me. This inconsistency is sad :-(
Hello Thomas,
On Mon, 12 Oct 2015 20:55:03 +0800, Thomas Chou thomas@wytron.com.tw wrote:
Hi Marek,
Not sure I'm getting this, so for my own education: what prevents from invalidating the cache, or IOW, what would happen if it was invalidated at this point rather than flushed?
Amicalement,
Hi Albert,
This is a hardware limitation. The nios2 cpu with 4 bytes dcache line size does not support the initda instruction, which is needed to invalidate dcache.
Recently we added a check, if the nios2 cpu support initda instruction, then we use invalidate_dcache, otherwise we use flush_dcache.
Hello Thomas,
On Mon, 19 Oct 2015 16:18:06 +0800, Thomas Chou thomas@wytron.com.tw wrote:
Hi Albert,
Now I understand. Thanks!
Amicalement,
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 use memalign. v3 check memalign() return for out of memory. v4 use malloc_cache_aligned(). v5 use invalidate_dcache_range() as Marek suggested.
diff --git a/arch/nios2/include/asm/dma-mapping.h b/arch/nios2/include/asm/dma-mapping.h index 1350e3b..118f734 100644 --- a/arch/nios2/include/asm/dma-mapping.h +++ b/arch/nios2/include/asm/dma-mapping.h @@ -1,23 +1,21 @@ #ifndef __ASM_NIOS2_DMA_MAPPING_H #define __ASM_NIOS2_DMA_MAPPING_H
-/* dma_alloc_coherent() return cache-line aligned allocation which is mapped +#include <memalign.h> +#include <asm/io.h> + +/* + * dma_alloc_coherent() return cache-line aligned allocation which is mapped * to uncached io region. - * - * IO_REGION_BASE should be defined in board config header file - * 0x80000000 for nommu, 0xe0000000 for mmu */ - static inline void *dma_alloc_coherent(size_t len, unsigned long *handle) { - void *addr = malloc(len + CONFIG_SYS_DCACHELINE_SIZE); - if (!addr) - return 0; - flush_dcache((unsigned long)addr, len + CONFIG_SYS_DCACHELINE_SIZE); - *handle = ((unsigned long)addr + - (CONFIG_SYS_DCACHELINE_SIZE - 1)) & - ~(CONFIG_SYS_DCACHELINE_SIZE - 1) & ~(IO_REGION_BASE); - return (void *)(*handle | IO_REGION_BASE); + *handle = (unsigned long)malloc_cache_aligned(len); + if (!*handle) + return NULL; + invalidate_dcache_range(*handle, *handle + len); + + return ioremap(*handle, len); }
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 use memalign. v3 check memalign() return for out of memory. v4 use malloc_cache_aligned(). v5 use invalidate_dcache_range() as Marek suggested. v6 defer assignment of handle as Marek suggested.
arch/nios2/include/asm/dma-mapping.h | 27 ++++++++++++++------------- 1 file changed, 14 insertions(+), 13 deletions(-)
diff --git a/arch/nios2/include/asm/dma-mapping.h b/arch/nios2/include/asm/dma-mapping.h index 1350e3b..1562d35 100644 --- a/arch/nios2/include/asm/dma-mapping.h +++ b/arch/nios2/include/asm/dma-mapping.h @@ -1,23 +1,24 @@ #ifndef __ASM_NIOS2_DMA_MAPPING_H #define __ASM_NIOS2_DMA_MAPPING_H
-/* dma_alloc_coherent() return cache-line aligned allocation which is mapped +#include <memalign.h> +#include <asm/io.h> + +/* + * dma_alloc_coherent() return cache-line aligned allocation which is mapped * to uncached io region. - * - * IO_REGION_BASE should be defined in board config header file - * 0x80000000 for nommu, 0xe0000000 for mmu */ - static inline void *dma_alloc_coherent(size_t len, unsigned long *handle) { - void *addr = malloc(len + CONFIG_SYS_DCACHELINE_SIZE); + unsigned long addr = (unsigned long)malloc_cache_aligned(len); + if (!addr) - return 0; - flush_dcache((unsigned long)addr, len + CONFIG_SYS_DCACHELINE_SIZE); - *handle = ((unsigned long)addr + - (CONFIG_SYS_DCACHELINE_SIZE - 1)) & - ~(CONFIG_SYS_DCACHELINE_SIZE - 1) & ~(IO_REGION_BASE); - return (void *)(*handle | IO_REGION_BASE); -} + return NULL; + + invalidate_dcache_range(addr, addr + len); + if (handle) + *handle = addr;
+ return ioremap(addr, len); +} #endif /* __ASM_NIOS2_DMA_MAPPING_H */
Thanks!
Applied to u-boot-nios.
Albert ARIBAUD
Thomas Chou
