[PATCH v2] sunxi: add PineCube board
PineCube is an IP camera development kit released by Pine64.
It comes with the following compoents:
- A mainboard with Sochip S3 SoC, a 16MByte SPI Flash, AXP209 PMIC, a power-only microUSB connector, a USB Type-A connector, a 10/100Mbps Ethernet port and FPC connectors for camera and daughter board. - An OV5640-based camera module which is connected to the parallel CSI bus of the mainboard. - A daughterboard with several buttons, a SD slot, some IR LEDs, a microphone and a speaker connector.
As the device tree is synchronized in a previous commit, just add MAINTAINER item and a defconfig.
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- Changes in v2: - Removed LDO3 hack in U-Boot because LDO3 is kept disabled in U-Boot.
board/sunxi/MAINTAINERS | 5 +++++ configs/pinecube_defconfig | 15 +++++++++++++++ 2 files changed, 20 insertions(+) create mode 100644 configs/pinecube_defconfig
diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index d3755ae41a..735801ae1d 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -440,6 +440,11 @@ M: Vasily Khoruzhick anarsoul@gmail.com S: Maintained F: configs/pinebook_defconfig
+PINECUBE BOARD: +M: Icenowy Zheng icenowy@aosc.io +S: Maintained +F: configs/pinecube_defconfig + PINE64 BOARDS M: Andre Przywara andre.przywara@arm.com S: Maintained diff --git a/configs/pinecube_defconfig b/configs/pinecube_defconfig new file mode 100644 index 0000000000..a8c404f6b1 --- /dev/null +++ b/configs/pinecube_defconfig @@ -0,0 +1,15 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL=y +CONFIG_MACH_SUN8I_V3S=y +CONFIG_SUNXI_DRAM_DDR3_1333=y +CONFIG_DRAM_CLK=504 +CONFIG_DRAM_ODT_EN=y +CONFIG_I2C0_ENABLE=y +CONFIG_DEFAULT_DEVICE_TREE="sun8i-s3-pinecube" +CONFIG_SPL_I2C_SUPPORT=y +# CONFIG_NETDEVICES is not set +CONFIG_AXP209_POWER=y +CONFIG_AXP_DCDC2_VOLT=1250 +CONFIG_AXP_DCDC3_VOLT=3300 +CONFIG_CONS_INDEX=3
It was, but it is missing the line in the dts Makefile: ... dts/Makefile:33: recipe for target 'arch/arm/dts/sun8i-s3-pinecube.dtb' failed ...
Can you please add this and resend?
And out of curiosity: what's with the Ethernet? Looks like a straight-forward sun8i-emac, doesn't it?
Cheers, Andre
Changes in v2:
André Przywara
Icenowy Zheng
