[U-Boot] [RFC] arm: mvebu: Add Helios4 Armada 38x initial support
The helios4 is built on the SolidRun Armada 38x SOM. The port os based on the ClearFog board, using information from https://github.com/helios-4/u-boot-marvell as well as dtb input from https://github.com/helios-4/linux-marvell
Currently ECC is not enabled
Signed-off-by: Dennis Gilmore dennis@ausil.us --- arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-388-helios4.dts | 454 ++++++++++++++++++++++++++++ arch/arm/mach-mvebu/Kconfig | 7 + board/solidrun/helios4/MAINTAINERS | 6 + board/solidrun/helios4/Makefile | 5 + board/solidrun/helios4/README | 46 +++ board/solidrun/helios4/helios4.c | 160 ++++++++++ board/solidrun/helios4/kwbimage.cfg | 12 + configs/helios4_defconfig | 57 ++++ include/configs/helios4.h | 185 ++++++++++++ 10 files changed, 933 insertions(+) create mode 100644 arch/arm/dts/armada-388-helios4.dts create mode 100644 board/solidrun/helios4/MAINTAINERS create mode 100644 board/solidrun/helios4/Makefile create mode 100644 board/solidrun/helios4/README create mode 100644 board/solidrun/helios4/helios4.c create mode 100644 board/solidrun/helios4/kwbimage.cfg create mode 100644 configs/helios4_defconfig create mode 100644 include/configs/helios4.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index a0349a8975..a18f4bbf7b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -91,6 +91,7 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-375-db.dtb \ armada-388-clearfog.dtb \ armada-388-gp.dtb \ + armada-388-helios4.dtb \ armada-385-amc.dtb \ armada-7040-db.dtb \ armada-7040-db-nand.dtb \ diff --git a/arch/arm/dts/armada-388-helios4.dts b/arch/arm/dts/armada-388-helios4.dts new file mode 100644 index 0000000000..562cce4c2b --- /dev/null +++ b/arch/arm/dts/armada-388-helios4.dts @@ -0,0 +1,454 @@ +/* + * Device Tree file for SolidRun Clearfog revision A1 rev 2.0 (88F6828) + * + * Copyright (C) 2015 Russell King + * + * This board is in development; the contents of this file work with + * the A1 rev 2.0 of the board, which does not represent final + * production board. Things will change, don't expect this file to + * remain compatible info the future. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include <dt-bindings/input/input.h> +#include <dt-bindings/gpio/gpio.h> +#include "armada-388.dtsi" + +/ { + model = "Helios4"; + compatible = "solidrun,helios4", "marvell,armada388", + "marvell,armada385", "marvell,armada380"; + + aliases { + /* So that mvebu u-boot can update the MAC addresses */ + ethernet1 = ð0; + spi1 = &spi1; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory { + device_type = "memory"; + reg = <0x00000000 0x10000000>; /* 256 MB */ + }; + + reg_3p3v: regulator-3p3v { + compatible = "regulator-fixed"; + regulator-name = "3P3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + system-leds { + compatible = "gpio-leds"; + status-led { + label = "helios4:green:status"; + gpios = <&gpio0 24 GPIO_ACTIVE_LOW>; + linux,default-trigger = "heartbeat"; + default-state = "on"; + }; + + fault-led { + label = "helios4:red:fault"; + gpios = <&gpio0 25 GPIO_ACTIVE_LOW>; + default-state = "keep"; + }; + }; + + io-leds { + compatible = "gpio-leds"; + sata1-led { + label = "helios4:green:ata1"; + gpios = <&gpio1 17 GPIO_ACTIVE_LOW>; + linux,default-trigger = "ata1"; + default-state = "off"; + }; + sata2-led { + label = "helios4:green:ata2"; + gpios = <&gpio1 18 GPIO_ACTIVE_LOW>; + linux,default-trigger = "ata2"; + default-state = "off"; + }; + sata3-led { + label = "helios4:green:ata3"; + gpios = <&gpio1 20 GPIO_ACTIVE_LOW>; + linux,default-trigger = "ata3"; + default-state = "off"; + }; + sata4-led { + label = "helios4:green:ata4"; + gpios = <&gpio1 21 GPIO_ACTIVE_LOW>; + linux,default-trigger = "ata4"; + default-state = "off"; + }; + usb-led { + label = "helios4:green:usb"; + gpios = <&gpio1 22 GPIO_ACTIVE_LOW>; + linux,default-trigger = "usb-host"; + default-state = "off"; + }; + }; + + fan1: j10-pwm { + compatible = "pwm-fan"; + pwms = <&gpio1 9 3800>; + }; + + fan2: j17-pwm { + compatible = "pwm-fan"; + pwms = <&gpio1 23 3800>; + }; + + + soc { + ranges = <MBUS_ID(0xf0, 0x01) 0 0xf1000000 0x100000 + MBUS_ID(0x01, 0x1d) 0 0xfff00000 0x100000 + MBUS_ID(0x09, 0x19) 0 0xf1100000 0x10000 + MBUS_ID(0x09, 0x15) 0 0xf1110000 0x10000>; + + internal-regs { + + ethernet@70000 { + mac-address = [00 50 43 02 02 01]; + pinctrl-0 = <&ge0_rgmii_pins>; + pinctrl-names = "default"; + phy = <&phy_dedicated>; + phy-mode = "rgmii-id"; + status = "okay"; + }; + + + i2c@11000 { + /* Is there anything on this? */ + clock-frequency = <100000>; + pinctrl-0 = <&i2c0_pins>; + pinctrl-names = "default"; + status = "okay"; + + /* + * PCA9655 GPIO expander, up to 1MHz clock. + * 0-CON3 CLKREQ# + * 1-CON3 PERST# + * 2-CON2 PERST# + * 3-CON3 W_DISABLE + * 4-CON2 CLKREQ# + * 5-USB3 overcurrent + * 6-USB3 power + * 7-CON2 W_DISABLE + * 8-JP4 P1 + * 9-JP4 P4 + * 10-JP4 P5 + * 11-m.2 DEVSLP + * 12-SFP_LOS + * 13-SFP_TX_FAULT + * 14-SFP_TX_DISABLE + * 15-SFP_MOD_DEF0 + */ + expander0: gpio-expander@20 { + /* + * This is how it should be: + * compatible = "onnn,pca9655", + * "nxp,pca9555"; + * but you can't do this because of + * the way I2C works. + */ + compatible = "nxp,pca9555"; + gpio-controller; + #gpio-cells = <2>; + reg = <0x20>; + + usb3_ilimit { + gpio-hog; + gpios = <5 GPIO_ACTIVE_LOW>; + input; + line-name = "usb3-current-limit"; + }; + usb3_power { + gpio-hog; + gpios = <6 GPIO_ACTIVE_HIGH>; + output-high; + line-name = "usb3-power"; + }; + m2_devslp { + gpio-hog; + gpios = <11 GPIO_ACTIVE_HIGH>; + output-low; + line-name = "m.2 devslp"; + }; + }; + + /* The MCP3021 is 100kHz clock only */ + mikrobus_adc: mcp3021@4c { + compatible = "microchip,mcp3021"; + reg = <0x4c>; + }; + + /* Also something at 0x64 */ + }; + + i2c@11100 { + /* + * Routed to SFP, mikrobus, and PCIe. + * SFP limits this to 100kHz, and requires + * an AT24C01A/02/04 with address pins tied + * low, which takes addresses 0x50 and 0x51. + * Mikrobus doesn't specify beyond an I2C + * bus being present. + * PCIe uses ARP to assign addresses, or + * 0x63-0x64. + */ + clock-frequency = <100000>; + pinctrl-0 = <&helios4_i2c1_pins>; + pinctrl-names = "default"; + status = "okay"; + }; + + mdio@72004 { + pinctrl-0 = <&mdio_pins>; + pinctrl-names = "default"; + + phy_dedicated: ethernet-phy@0 { + /* + * Annoyingly, the marvell phy driver + * configures the LED register, rather + * than preserving reset-loaded setting. + * We undo that rubbish here. + */ + marvell,reg-init = <3 16 0 0x101e>; + reg = <0>; + }; + }; + + pinctrl@18000 { + helios4_i2c1_pins: i2c1-pins { + /* SFP, PCIe, mSATA, mikrobus */ + marvell,pins = "mpp26", "mpp27"; + marvell,function = "i2c1"; + }; + helios4_sdhci_cd_pins: helios4-sdhci-cd-pins { + marvell,pins = "mpp20"; + marvell,function = "gpio"; + }; + helios4_sdhci_pins: helios4-sdhci-pins { + marvell,pins = "mpp21", "mpp28", + "mpp37", "mpp38", + "mpp39", "mpp40"; + marvell,function = "sd0"; + }; + helios4_spi1_cs_pins: spi1-cs-pins { + marvell,pins = "mpp55"; + marvell,function = "spi1"; + }; + mikro_pins: mikro-pins { + /* int: mpp22 rst: mpp29 */ + marvell,pins = "mpp22", "mpp29"; + marvell,function = "gpio"; + }; + mikro_spi_pins: mikro-spi-pins { + marvell,pins = "mpp43"; + marvell,function = "spi1"; + }; + mikro_uart_pins: mikro-uart-pins { + marvell,pins = "mpp24", "mpp25"; + marvell,function = "ua1"; + }; + rear_button_pins: rear-button-pins { + marvell,pins = "mpp34"; + marvell,function = "gpio"; + }; + }; + + rtc@a3800 { + /* + * If the rtc doesn't work, run "date reset" + * twice in u-boot. + */ + status = "okay"; + }; + + sata@a8000 { + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + + sata0: sata-port@0 { + reg = <0>; + }; + + sata1: sata-port@1 { + reg = <1>; + }; + }; + + sata@e0000 { + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + + sata2: sata-port@0 { + reg = <0>; + }; + + sata3: sata-port@1 { + reg = <1>; + }; + }; + + sdhci@d8000 { + bus-width = <4>; + cd-gpios = <&gpio0 20 GPIO_ACTIVE_LOW>; + no-1-8-v; + pinctrl-0 = <&helios4_sdhci_pins + &helios4_sdhci_cd_pins>; + pinctrl-names = "default"; + status = "okay"; + vmmc = <®_3p3v>; + wp-inverted; + }; + + serial@12000 { + pinctrl-0 = <&uart0_pins>; + pinctrl-names = "default"; + status = "okay"; + u-boot,dm-pre-reloc; + }; + + serial@12100 { + /* mikrobus uart */ + pinctrl-0 = <&mikro_uart_pins>; + pinctrl-names = "default"; + status = "okay"; + }; + + spi1: spi@10680 { + /* + * CS0: W25Q32 + * CS1: + * CS2: mikrobus + */ + pinctrl-0 = <&spi1_pins &helios4_spi1_cs_pins &mikro_spi_pins>; + pinctrl-names = "default"; + status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "w25q32", "jedec,spi-nor", "spi-flash"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <3000000>; + }; + }; + + usb3@f8000 { + status = "okay"; + }; + }; + + }; + + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-0 = <&rear_button_pins>; + pinctrl-names = "default"; + + button_0 { + /* The rear SW3 button */ + label = "Rear Button"; + gpios = <&gpio1 2 GPIO_ACTIVE_LOW>; + linux,can-disable; + linux,code = <BTN_0>; + }; + }; +}; + +/* ++#define A38x_CUSTOMER_BOARD_1_MPP16_23 0x00400011 +MPP18: gpio ? (pca9655 int?) +MPP19: gpio ? (clkreq?) +MPP20: gpio ? (sd0 detect) +MPP21: sd0:cmd x sd0 +MPP22: gpio x mikro int +MPP23: gpio x switch irq ++#define A38x_CUSTOMER_BOARD_1_MPP24_31 0x22043333 +MPP24: ua1:rxd x mikro rx +MPP25: ua1:txd x mikro tx +MPP26: i2c1:sck x mikro sck +MPP27: i2c1:sda x mikro sda +MPP28: sd0:clk x sd0 +MPP29: gpio x mikro rst +MPP30: ge1:txd2 ? (config) +MPP31: ge1:txd3 ? (config) ++#define A38x_CUSTOMER_BOARD_1_MPP32_39 0x44400002 +MPP32: ge1:txctl ? (unused) +MPP33: gpio ? (pic_com0) +MPP34: gpio x rear button (pic_com1) +MPP35: gpio ? (pic_com2) +MPP36: gpio ? (unused) +MPP37: sd0:d3 x sd0 +MPP38: sd0:d0 x sd0 +MPP39: sd0:d1 x sd0 ++#define A38x_CUSTOMER_BOARD_1_MPP40_47 0x41144004 +MPP40: sd0:d2 x sd0 +MPP41: gpio x switch reset +MPP42: gpio ? sw1-1 +MPP43: spi1:cs2 x mikro cs +MPP44: sata3:prsnt ? (unused) +MPP45: ref:clk_out0 ? +MPP46: ref:clk_out1 x switch clk +MPP47: 4 ? (unused) ++#define A38x_CUSTOMER_BOARD_1_MPP48_55 0x40333333 +MPP48: tdm:pclk +MPP49: tdm:fsync +MPP50: tdm:drx +MPP51: tdm:dtx +MPP52: tdm:int +MPP53: tdm:rst +MPP54: gpio ? (pwm) +MPP55: spi1:cs1 x slic ++#define A38x_CUSTOMER_BOARD_1_MPP56_63 0x00004444 +MPP56: spi1:mosi x mikro mosi +MPP57: spi1:sck x mikro sck +MPP58: spi1:miso x mikro miso +MPP59: spi1:cs0 x w25q32 +*/ diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index f431cff950..0b47642d0c 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -75,6 +75,10 @@ config TARGET_CLEARFOG bool "Support ClearFog" select 88F6820
+config TARGET_HELIOS4 + bool "Support Helios4" + select 88F6820 + config TARGET_MVEBU_ARMADA_37XX bool "Support Armada 37xx platforms" select ARMADA_3700 @@ -132,6 +136,7 @@ endchoice
config SYS_BOARD default "clearfog" if TARGET_CLEARFOG + default "helios4" if TARGET_HELIOS4 default "mvebu_armada-37xx" if TARGET_MVEBU_ARMADA_37XX default "db-88f6720" if TARGET_DB_88F6720 default "db-88f6820-gp" if TARGET_DB_88F6820_GP @@ -146,6 +151,7 @@ config SYS_BOARD
config SYS_CONFIG_NAME default "clearfog" if TARGET_CLEARFOG + default "helios4" if TARGET_HELIOS4 default "mvebu_armada-37xx" if TARGET_MVEBU_ARMADA_37XX default "db-88f6720" if TARGET_DB_88F6720 default "db-88f6820-gp" if TARGET_DB_88F6820_GP @@ -166,6 +172,7 @@ config SYS_VENDOR default "Marvell" if TARGET_DB_88F6820_AMC default "Marvell" if TARGET_MVEBU_ARMADA_8K default "solidrun" if TARGET_CLEARFOG + default "solidrun" if TARGET_HELIOS4 default "Synology" if TARGET_DS414 default "CZ.NIC" if TARGET_TURRIS_OMNIA default "CZ.NIC" if TARGET_TURRIS_MOX diff --git a/board/solidrun/helios4/MAINTAINERS b/board/solidrun/helios4/MAINTAINERS new file mode 100644 index 0000000000..298e5011c7 --- /dev/null +++ b/board/solidrun/helios4/MAINTAINERS @@ -0,0 +1,6 @@ +CLEARFOG BOARD +M: Stefan Roese sr@denx.de +S: Maintained +F: board/soldrun/clearfog/ +F: include/configs/clearfog.h +F: configs/clearfog_defconfig diff --git a/board/solidrun/helios4/Makefile b/board/solidrun/helios4/Makefile new file mode 100644 index 0000000000..84be38c572 --- /dev/null +++ b/board/solidrun/helios4/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2015 Stefan Roese sr@denx.de + +obj-y := helios4.o diff --git a/board/solidrun/helios4/README b/board/solidrun/helios4/README new file mode 100644 index 0000000000..b067bd1624 --- /dev/null +++ b/board/solidrun/helios4/README @@ -0,0 +1,46 @@ +Update from original Marvell U-Boot to mainline U-Boot: +------------------------------------------------------- + +Generate the U-Boot image with these commands: + +$ make helios4_defconfig +$ make + +The resulting image including the SPL binary with the +full DDR setup is "u-boot-spl.kwb". + +Now all you need to do is copy this image on a SD card. +For example with this command: + +$ sudo dd if=u-boot-spl.kwb of=/dev/sdX bs=512 seek=1 + +Please use the correct device node for your setup instead +of "/dev/sdX" here! + +Boot selection: +--------------- + +Before powering up the board, boot selection should be done via the SW1 dip +switch (0: OFF, 1: ON): + + - SPI: 00010 + - SD/eMMC: 00111 + - SATA1: 11100 + - UART: 11110 + +Boot from UART: +--------------- + +Connect the on-board micro-USB (CF Pro: CON11, CF Base: CON5) +to your host. + +Set the SW1 DIP switches to UART boot (see above). + +Run the following command to initiate U-Boot download: + + ./tools/kwboot -b u-boot-spl.kwb /dev/ttyUSBX + +Use the correct UART device node for /dev/ttyUSBX. + +When download finishes start your favorite terminal emulator +on /dev/ttyUSBX. diff --git a/board/solidrun/helios4/helios4.c b/board/solidrun/helios4/helios4.c new file mode 100644 index 0000000000..6c27e99043 --- /dev/null +++ b/board/solidrun/helios4/helios4.c @@ -0,0 +1,160 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2015 Stefan Roese sr@denx.de + */ + +#include <common.h> +#include <i2c.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> + +#include "../drivers/ddr/marvell/a38x/ddr3_init.h" +#include <../serdes/a38x/high_speed_env_spec.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define ETH_PHY_CTRL_REG 0 +#define ETH_PHY_CTRL_POWER_DOWN_BIT 11 +#define ETH_PHY_CTRL_POWER_DOWN_MASK (1 << ETH_PHY_CTRL_POWER_DOWN_BIT) + +/* + * Those values and defines are taken from the Marvell U-Boot version + * "u-boot-2013.01-15t1-helios4" as well as the upstream config for clearfog + */ +#define BOARD_GPP_OUT_ENA_LOW 0xffffffff +#define BOARD_GPP_OUT_ENA_MID 0xffffffff + +#define BOARD_GPP_OUT_VAL_LOW 0x0 +#define BOARD_GPP_OUT_VAL_MID 0x0 +#define BOARD_GPP_POL_LOW 0x0 +#define BOARD_GPP_POL_MID 0x0 + +/* IO expander on Marvell GP board includes e.g. fan enabling */ +struct marvell_io_exp { + u8 chip; + u8 addr; + u8 val; +}; + +static struct marvell_io_exp io_exp[] = { + {0, 6, 0xf9}, + {0, 2, 0x46}, /* Assert reset signals and enable USB3 current limiter */ + {0, 6, 0xb9} +}; + +static struct serdes_map board_serdes_map[] = { + {SATA0, SERDES_SPEED_6_GBPS, SERDES_DEFAULT_MODE, 0, 0}, + {USB3_HOST0, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, + {SATA1, SERDES_SPEED_6_GBPS, SERDES_DEFAULT_MODE, 0, 0}, + {SATA3, SERDES_SPEED_6_GBPS, SERDES_DEFAULT_MODE, 0, 0}, + {SATA2, SERDES_SPEED_6_GBPS, SERDES_DEFAULT_MODE, 0, 0}, + {USB3_HOST1, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +}; + +int hws_board_topology_load(struct serdes_map **serdes_map_array, u8 *count) +{ + *serdes_map_array = board_serdes_map; + *count = ARRAY_SIZE(board_serdes_map); + return 0; +} + +/* + * Define the DDR layout / topology here in the board file. This will + * be used by the DDR3 init code in the SPL U-Boot version to configure + * the DDR3 controller. + */ +static struct mv_ddr_topology_map board_topology_map = { + DEBUG_LEVEL_ERROR, + 0x1, /* active interfaces */ + /* cs_mask, mirror, dqs_swap, ck_swap X PUPs */ + { { { {0x1, 0, 0, 0}, + {0x1, 0, 0, 0}, + {0x1, 0, 0, 0}, + {0x1, 0, 0, 0}, + {0x1, 0, 0, 0} }, + SPEED_BIN_DDR_1600K, /* speed_bin */ + MV_DDR_DEV_WIDTH_16BIT, /* memory_width */ + MV_DDR_DIE_CAP_8GBIT, /* mem_size */ + DDR_FREQ_800, /* frequency */ + 0, 0, /* cas_wl cas_l */ + MV_DDR_TEMP_LOW, /* temperature */ + MV_DDR_TIM_DEFAULT} }, /* timing */ + BUS_MASK_32BIT_ECC, /* Busses mask */ + MV_DDR_CFG_DEFAULT, /* ddr configuration data source */ + { {0} }, /* raw spd data */ + {0} /* timing parameters */ +}; + +struct mv_ddr_topology_map *mv_ddr_topology_map_get(void) +{ + /* Return the board topology as defined in the board code */ + return &board_topology_map; +} + +int board_early_init_f(void) +{ + /* Configure MPP */ + writel(0x11111111, MVEBU_MPP_BASE + 0x00); + writel(0x11111111, MVEBU_MPP_BASE + 0x04); + writel(0x10400011, MVEBU_MPP_BASE + 0x08); + writel(0x22043333, MVEBU_MPP_BASE + 0x0c); + writel(0x44400002, MVEBU_MPP_BASE + 0x10); + writel(0x41144004, MVEBU_MPP_BASE + 0x14); + writel(0x40333333, MVEBU_MPP_BASE + 0x18); + writel(0x00004444, MVEBU_MPP_BASE + 0x1c); + + /* Set GPP Out value */ + writel(BOARD_GPP_OUT_VAL_LOW, MVEBU_GPIO0_BASE + 0x00); + writel(BOARD_GPP_OUT_VAL_MID, MVEBU_GPIO1_BASE + 0x00); + + /* Set GPP Polarity */ + writel(BOARD_GPP_POL_LOW, MVEBU_GPIO0_BASE + 0x0c); + writel(BOARD_GPP_POL_MID, MVEBU_GPIO1_BASE + 0x0c); + + /* Set GPP Out Enable */ + writel(BOARD_GPP_OUT_ENA_LOW, MVEBU_GPIO0_BASE + 0x04); + writel(BOARD_GPP_OUT_ENA_MID, MVEBU_GPIO1_BASE + 0x04); + + return 0; +} + +int board_init(void) +{ + int i; + + /* Address of boot parameters */ + gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; + + /* Toggle GPIO41 to reset onboard switch and phy */ + clrbits_le32(MVEBU_GPIO1_BASE + 0x0, BIT(9)); + clrbits_le32(MVEBU_GPIO1_BASE + 0x4, BIT(9)); + /* GPIO 19 on ClearFog rev 2.1 controls the uSOM onboard phy reset */ + clrbits_le32(MVEBU_GPIO0_BASE + 0x0, BIT(19)); + clrbits_le32(MVEBU_GPIO0_BASE + 0x4, BIT(19)); + mdelay(1); + setbits_le32(MVEBU_GPIO1_BASE + 0x0, BIT(9)); + setbits_le32(MVEBU_GPIO0_BASE + 0x0, BIT(19)); + mdelay(10); + + /* Init I2C IO expanders */ + for (i = 0; i < ARRAY_SIZE(io_exp); i++) + i2c_write(io_exp[i].chip, io_exp[i].addr, 1, &io_exp[i].val, 1); + + return 0; +} + +int checkboard(void) +{ + puts("Board: Helios4\n"); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + cpu_eth_init(bis); /* Built in controller(s) come first */ + return pci_eth_init(bis); +} diff --git a/board/solidrun/helios4/kwbimage.cfg b/board/solidrun/helios4/kwbimage.cfg new file mode 100644 index 0000000000..f41d25a8a1 --- /dev/null +++ b/board/solidrun/helios4/kwbimage.cfg @@ -0,0 +1,12 @@ +# +# Copyright (C) 2015 Stefan Roese sr@denx.de +# + +# Armada 38x use version 1 image format +VERSION 1 + +# Boot Media configurations +BOOT_FROM sdio + +# Binary Header (bin_hdr) with DDR3 training code +BINARY spl/u-boot-spl-dtb.bin 0000005b 00000068 diff --git a/configs/helios4_defconfig b/configs/helios4_defconfig new file mode 100644 index 0000000000..c0180e99b5 --- /dev/null +++ b/configs/helios4_defconfig @@ -0,0 +1,57 @@ +CONFIG_ARM=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00800000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_HELIOS4=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL=y +CONFIG_DEFAULT_DEVICE_TREE="armada-388-helios4" +CONFIG_DEBUG_UART=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x141 +CONFIG_SPL_I2C_SUPPORT=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +# CONFIG_SPL_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_MMC=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_MV=y +CONFIG_AHCI=y +CONFIG_SCSI_AHCI=y +CONFIG_SCSI=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHY_GIGE=y +CONFIG_MVNETA=y +CONFIG_PCI=y +CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550=y +CONFIG_KIRKWOOD_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_STORAGE=y diff --git a/include/configs/helios4.h b/include/configs/helios4.h new file mode 100644 index 0000000000..efc1c3f751 --- /dev/null +++ b/include/configs/helios4.h @@ -0,0 +1,185 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2015 Stefan Roese sr@denx.de + */ + +#ifndef _CONFIG_HELIOS4_H +#define _CONFIG_HELIOS4_H + +/* + * High Level Configuration Options (easy to change) + */ + +/* + * TEXT_BASE needs to be below 16MiB, since this area is scrubbed + * for DDR ECC byte filling in the SPL before loading the main + * U-Boot into it. + */ +#define CONFIG_SYS_TCLK 250000000 /* 250MHz */ + +/* + * Commands configuration + */ + +/* I2C */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MVTWSI +#define CONFIG_I2C_MVTWSI_BASE0 MVEBU_TWSI_BASE +#define CONFIG_SYS_I2C_SLAVE 0x0 +#define CONFIG_SYS_I2C_SPEED 100000 + +/* SPI NOR flash default params, used by sf commands */ +#define CONFIG_SF_DEFAULT_BUS 1 + +/* + * SDIO/MMC Card Configuration + */ +#define CONFIG_SYS_MMC_BASE MVEBU_SDIO_BASE + +/* USB/EHCI configuration */ +#define CONFIG_EHCI_IS_TDI + +#define CONFIG_ENV_MIN_ENTRIES 128 + +/* + * SATA/SCSI/AHCI configuration + */ +#define CONFIG_SCSI_AHCI_PLAT +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 2 +#define CONFIG_SYS_SCSI_MAX_LUN 2 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) + +/* Environment in MMC */ +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SECT_SIZE 0x200 +#define CONFIG_ENV_SIZE 0x10000 +/* + * For SD - reserve 1 LBA for MBR + 1M for u-boot image. The MMC/eMMC + * boot image starts @ LBA-0. + * As result in MMC/eMMC case it will be a 1 sector gap between u-boot + * image and environment + */ +#define CONFIG_ENV_OFFSET 0xf0000 +#define CONFIG_ENV_ADDR CONFIG_ENV_OFFSET + +#define CONFIG_PHY_MARVELL /* there is a marvell phy */ +#define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */ + +/* PCIe support */ +#ifndef CONFIG_SPL_BUILD +#define CONFIG_PCI_MVEBU +#define CONFIG_PCI_SCAN_SHOW +#endif + +/* Keep device tree and initrd in lower memory so the kernel can access them */ +#define RELOCATION_LIMITS_ENV_SETTINGS \ + "fdt_high=0x10000000\0" \ + "initrd_high=0x10000000\0" + +/* SPL */ +/* + * Select the boot device here + * + * Currently supported are: + * SPL_BOOT_SPI_NOR_FLASH - Booting via SPI NOR flash + * SPL_BOOT_SDIO_MMC_CARD - Booting via SDIO/MMC card (partition 1) + */ +#define SPL_BOOT_SPI_NOR_FLASH 1 +#define SPL_BOOT_SDIO_MMC_CARD 2 +#define CONFIG_SPL_BOOT_DEVICE SPL_BOOT_SDIO_MMC_CARD + +/* Defines for SPL */ +#define CONFIG_SPL_SIZE (140 << 10) +#define CONFIG_SPL_TEXT_BASE 0x40000030 +#define CONFIG_SPL_MAX_SIZE (CONFIG_SPL_SIZE - 0x0030) + +#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) +#define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_MALLOC_SIMPLE +#endif + +#define CONFIG_SPL_STACK (0x40000000 + ((192 - 16) << 10)) +#define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4) + +#if CONFIG_SPL_BOOT_DEVICE == SPL_BOOT_SPI_NOR_FLASH +/* SPL related SPI defines */ +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 +#define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_SPI_U_BOOT_OFFS +#endif + +#if CONFIG_SPL_BOOT_DEVICE == SPL_BOOT_SDIO_MMC_CARD +/* SPL related MMC defines */ +#define CONFIG_SYS_MMC_U_BOOT_OFFS (160 << 10) +#define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_MMC_U_BOOT_OFFS +#ifdef CONFIG_SPL_BUILD +#define CONFIG_FIXED_SDHCI_ALIGNED_BUFFER 0x00180000 /* in SDRAM */ +#endif + +/* Enable DDR support in SPL (DDR3 training from Marvell bin_hdr) */ +#define CONFIG_SPD_EEPROM 0x4e +#define CONFIG_BOARD_ECC_SUPPORT /* this board supports ECC */ + +#endif + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" + +/* Include the common distro boot environment */ +#ifndef CONFIG_SPL_BUILD + +#ifdef CONFIG_MMC +#define BOOT_TARGET_DEVICES_MMC(func) func(MMC, mmc, 0) +#else +#define BOOT_TARGET_DEVICES_MMC(func) +#endif + +#ifdef CONFIG_USB_STORAGE +#define BOOT_TARGET_DEVICES_USB(func) func(USB, usb, 0) +#else +#define BOOT_TARGET_DEVICES_USB(func) +#endif + +#ifdef CONFIG_SATA +#define BOOT_TARGET_DEVICES_SATA(func) func(SATA, sata, 0) +#else +#define BOOT_TARGET_DEVICES_SATA(func) +#endif + +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_DEVICES_MMC(func) \ + BOOT_TARGET_DEVICES_USB(func) \ + BOOT_TARGET_DEVICES_SATA(func) \ + func(PXE, pxe, na) \ + func(DHCP, dhcp, na) + +#define KERNEL_ADDR_R __stringify(0x800000) +#define FDT_ADDR_R __stringify(0x100000) +#define RAMDISK_ADDR_R __stringify(0x1800000) +#define SCRIPT_ADDR_R __stringify(0x200000) +#define PXEFILE_ADDR_R __stringify(0x300000) + +#define LOAD_ADDRESS_ENV_SETTINGS \ + "kernel_addr_r=" KERNEL_ADDR_R "\0" \ + "fdt_addr_r=" FDT_ADDR_R "\0" \ + "ramdisk_addr_r=" RAMDISK_ADDR_R "\0" \ + "scriptaddr=" SCRIPT_ADDR_R "\0" \ + "pxefile_addr_r=" PXEFILE_ADDR_R "\0" + +#include <config_distro_bootcmd.h> + +#define CONFIG_EXTRA_ENV_SETTINGS \ + RELOCATION_LIMITS_ENV_SETTINGS \ + LOAD_ADDRESS_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ + "console=ttyS0,115200\0" \ + BOOTENV + +#endif /* CONFIG_SPL_BUILD */ + +#endif /* _CONFIG_HELIOS4_H */
Hi Dennis,
Comments below
Actually looks like it is.
Linux and u-boot have recently adopted a new SPDX format for these licences. Have a look at some of the other dts files. If this exists in the upstream kernel it's probably been updated.
- Device Tree file for SolidRun Clearfog revision A1 rev 2.0 (88F6828)
- Copyright (C) 2015 Russell King
- This board is in development; the contents of this file work with
- the A1 rev 2.0 of the board, which does not represent final
- production board. Things will change, don't expect this file to
- remain compatible info the future.
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively
- b) Permission is hereby granted, free of charge, to any person
conditions:
model = "Helios4";
aliases {
ethernet1 = ð0;
spi1 = &spi1;
chosen {
memory {
system-leds {
status-led {
fault-led {
io-leds {
sata1-led {
sata2-led {
sata3-led {
sata4-led {
usb-led {
fan1: j10-pwm {
fan2: j17-pwm {
soc {
internal-regs {
ethernet@70000 {
status = "okay";
i2c@11000 {
status = "okay";
* 0-CON3 CLKREQ#
* 1-CON3 PERST#
* 2-CON2 PERST#
* 3-CON3 W_DISABLE
* 4-CON2 CLKREQ#
* 6-USB3 power
* 7-CON2 W_DISABLE
* 8-JP4 P1
* 9-JP4 P4
* 10-JP4 P5
* 11-m.2 DEVSLP
* 12-SFP_LOS
* 13-SFP_TX_FAULT
* 14-SFP_TX_DISABLE
* 15-SFP_MOD_DEF0
* "nxp,pca9555";
gpio-controller;
#gpio-cells = <2>;
reg = <0x20>;
usb3_ilimit {
gpio-hog;
gpios = <5
GPIO_ACTIVE_LOW>;
input;
line-name =
usb3_power {
gpio-hog;
gpios = <6
GPIO_ACTIVE_HIGH>;
output-high;
m2_devslp {
gpio-hog;
gpios = <11
GPIO_ACTIVE_HIGH>;
output-low;
reg = <0x4c>;
i2c@11100 {
tied
0x51.
* 0x63-0x64.
status = "okay";
mdio@72004 {
driver
rather
setting.
reg = <0>;
pinctrl@18000 {
"mpp37", "mpp38",
"mpp39", "mpp40";
rtc@a3800 {
reset"
* twice in u-boot.
status = "okay";
sata@a8000 {
status = "okay";
#size-cells = <0>;
reg = <0>;
reg = <1>;
sata@e0000 {
status = "okay";
#size-cells = <0>;
reg = <0>;
reg = <1>;
sdhci@d8000 {
bus-width = <4>;
no-1-8-v;
status = "okay";
vmmc = <®_3p3v>;
wp-inverted;
serial@12000 {
status = "okay";
serial@12100 {
/* mikrobus uart */
status = "okay";
spi1: spi@10680 {
* CS0: W25Q32
* CS1:
* CS2: mikrobus
status = "okay";
spi-flash@0 {
#size-cells = <0>;
usb3@f8000 {
status = "okay";
gpio-keys {
button_0 {
linux,can-disable;
This probably belongs somewhere else.
select 88F6820
+S: Maintained
Looks like this needs updating.
- SPI: 00010
- SD/eMMC: 00111
- SATA1: 11100
- UART: 11110
- ./tools/kwboot -b u-boot-spl.kwb /dev/ttyUSBX
I think you need the -p option to modify the boot source in the image header for uart.
- Copyright (C) 2015 Stefan Roese sr@denx.de
- Those values and defines are taken from the Marvell U-Boot version
- "u-boot-2013.01-15t1-helios4" as well as the upstream config for
clearfog
u8 chip;
u8 addr;
u8 val;
{0, 6, 0xf9},
limiter */
{0, 6, 0xb9}
- Define the DDR layout / topology here in the board file. This will
- be used by the DDR3 init code in the SPL U-Boot version to configure
- the DDR3 controller.
DEBUG_LEVEL_ERROR,
{0x1, 0, 0, 0},
{0x1, 0, 0, 0},
{0x1, 0, 0, 0},
{0x1, 0, 0, 0} },
This is probably where that comment from the dts file belongs.
/* Configure MPP */
U-boot has a proper gpio driver for the SoC gpios so I don't think this is strictly needed.
int i;
mdelay(1);
mdelay(10);
This can be updated to use the generic gpio lib.
&io_exp[i].val, 1);
@@ -0,0 +1,12 @@
SPDX licence needed
- High Level Configuration Options (easy to change)
- TEXT_BASE needs to be below 16MiB, since this area is scrubbed
- for DDR ECC byte filling in the SPL before loading the main
- U-Boot into it.
- Commands configuration
These aren't needed if you switch to DM_I2C
- SDIO/MMC Card Configuration
- SATA/SCSI/AHCI configuration
- For SD - reserve 1 LBA for MBR + 1M for u-boot image. The MMC/eMMC
- boot image starts @ LBA-0.
- As result in MMC/eMMC case it will be a 1 sector gap between u-boot
- image and environment
+/* SPL */ +/*
- Select the boot device here
- Currently supported are:
- SPL_BOOT_SPI_NOR_FLASH - Booting via SPI NOR flash
- SPL_BOOT_SDIO_MMC_CARD - Booting via SDIO/MMC card (partition 1)
- mv-common.h should be defined after CMD configs since it used them
- to enable certain macros
BOOTENV
2.17.0
Hi Dennis,
Which specific SoM?
Please address all the comments that Chris already mentioned in his review.
Thanks, Stefan
- armada-388-helios4.dtb \ armada-385-amc.dtb \ armada-7040-db.dtb \ armada-7040-db-nand.dtb \
- whole.
- Or, alternatively
conditions:
- model = "Helios4";
- compatible = "solidrun,helios4", "marvell,armada388",
- aliases {
ethernet1 = ð0;
spi1 = &spi1;
- chosen {
- memory {
- reg_3p3v: regulator-3p3v {
system-leds {
status-led {
fault-led {
io-leds {
sata1-led {
sata2-led {
sata3-led {
sata4-led {
usb-led {
fan1: j10-pwm {
fan2: j17-pwm {
- soc {
internal-regs {
ethernet@70000 {
status = "okay";
i2c@11000 {
status = "okay";
* 0-CON3 CLKREQ#
* 1-CON3 PERST#
* 2-CON2 PERST#
* 3-CON3 W_DISABLE
* 4-CON2 CLKREQ#
* 6-USB3 power
* 7-CON2 W_DISABLE
* 8-JP4 P1
* 9-JP4 P4
* 10-JP4 P5
* 11-m.2 DEVSLP
* 12-SFP_LOS
* 13-SFP_TX_FAULT
* 14-SFP_TX_DISABLE
* 15-SFP_MOD_DEF0
* "nxp,pca9555";
gpio-controller;
#gpio-cells = <2>;
reg = <0x20>;
usb3_ilimit {
gpio-hog;
input;
usb3_power {
gpio-hog;
output-high;
m2_devslp {
gpio-hog;
output-low;
reg = <0x4c>;
i2c@11100 {
* 0x63-0x64.
status = "okay";
mdio@72004 {
reg = <0>;
pinctrl@18000 {
"mpp37", "mpp38",
"mpp39", "mpp40";
rtc@a3800 {
* twice in u-boot.
status = "okay";
sata@a8000 {
status = "okay";
#size-cells = <0>;
reg = <0>;
reg = <1>;
sata@e0000 {
status = "okay";
#size-cells = <0>;
reg = <0>;
reg = <1>;
sdhci@d8000 {
bus-width = <4>;
no-1-8-v;
status = "okay";
vmmc = <®_3p3v>;
wp-inverted;
serial@12000 {
status = "okay";
serial@12100 {
/* mikrobus uart */
status = "okay";
spi1: spi@10680 {
* CS0: W25Q32
* CS1:
* CS2: mikrobus
status = "okay";
spi-flash@0 {
#size-cells = <0>;
usb3@f8000 {
status = "okay";
- gpio-keys {
button_0 {
linux,can-disable;
- bool "Support Helios4"
- select 88F6820
- config TARGET_MVEBU_ARMADA_37XX bool "Support Armada 37xx platforms" select ARMADA_3700
- default "helios4" if TARGET_HELIOS4 default "mvebu_armada-37xx" if TARGET_MVEBU_ARMADA_37XX default "db-88f6720" if TARGET_DB_88F6720 default "db-88f6820-gp" if TARGET_DB_88F6820_GP
- default "solidrun" if TARGET_HELIOS4 default "Synology" if TARGET_DS414 default "CZ.NIC" if TARGET_TURRIS_OMNIA default "CZ.NIC" if TARGET_TURRIS_MOX
- SPI: 00010
- SD/eMMC: 00111
- SATA1: 11100
- UART: 11110
- "u-boot-2013.01-15t1-helios4" as well as the upstream config for clearfog
- u8 chip;
- u8 addr;
- u8 val;
- {0, 6, 0xf9},
- {0, 2, 0x46}, /* Assert reset signals and enable USB3 current limiter */
- {0, 6, 0xb9}
- {SATA0, SERDES_SPEED_6_GBPS, SERDES_DEFAULT_MODE, 0, 0},
- {USB3_HOST0, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0},
- {SATA1, SERDES_SPEED_6_GBPS, SERDES_DEFAULT_MODE, 0, 0},
- {SATA3, SERDES_SPEED_6_GBPS, SERDES_DEFAULT_MODE, 0, 0},
- {SATA2, SERDES_SPEED_6_GBPS, SERDES_DEFAULT_MODE, 0, 0},
- {USB3_HOST1, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0},
- *serdes_map_array = board_serdes_map;
- *count = ARRAY_SIZE(board_serdes_map);
- DEBUG_LEVEL_ERROR,
- 0x1, /* active interfaces */
- /* cs_mask, mirror, dqs_swap, ck_swap X PUPs */
- { { { {0x1, 0, 0, 0},
{0x1, 0, 0, 0},
{0x1, 0, 0, 0},
{0x1, 0, 0, 0},
{0x1, 0, 0, 0} },
- BUS_MASK_32BIT_ECC, /* Busses mask */
- MV_DDR_CFG_DEFAULT, /* ddr configuration data source */
- { {0} }, /* raw spd data */
- {0} /* timing parameters */
- /* Return the board topology as defined in the board code */
- return &board_topology_map;
- /* Configure MPP */
- writel(0x11111111, MVEBU_MPP_BASE + 0x00);
- writel(0x11111111, MVEBU_MPP_BASE + 0x04);
- writel(0x10400011, MVEBU_MPP_BASE + 0x08);
- writel(0x22043333, MVEBU_MPP_BASE + 0x0c);
- writel(0x44400002, MVEBU_MPP_BASE + 0x10);
- writel(0x41144004, MVEBU_MPP_BASE + 0x14);
- writel(0x40333333, MVEBU_MPP_BASE + 0x18);
- writel(0x00004444, MVEBU_MPP_BASE + 0x1c);
- /* Set GPP Out value */
- writel(BOARD_GPP_OUT_VAL_LOW, MVEBU_GPIO0_BASE + 0x00);
- writel(BOARD_GPP_OUT_VAL_MID, MVEBU_GPIO1_BASE + 0x00);
- /* Set GPP Polarity */
- writel(BOARD_GPP_POL_LOW, MVEBU_GPIO0_BASE + 0x0c);
- writel(BOARD_GPP_POL_MID, MVEBU_GPIO1_BASE + 0x0c);
- /* Set GPP Out Enable */
- writel(BOARD_GPP_OUT_ENA_LOW, MVEBU_GPIO0_BASE + 0x04);
- writel(BOARD_GPP_OUT_ENA_MID, MVEBU_GPIO1_BASE + 0x04);
- int i;
- /* Address of boot parameters */
- gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100;
- /* Toggle GPIO41 to reset onboard switch and phy */
- clrbits_le32(MVEBU_GPIO1_BASE + 0x0, BIT(9));
- clrbits_le32(MVEBU_GPIO1_BASE + 0x4, BIT(9));
- /* GPIO 19 on ClearFog rev 2.1 controls the uSOM onboard phy reset */
- clrbits_le32(MVEBU_GPIO0_BASE + 0x0, BIT(19));
- clrbits_le32(MVEBU_GPIO0_BASE + 0x4, BIT(19));
- mdelay(1);
- setbits_le32(MVEBU_GPIO1_BASE + 0x0, BIT(9));
- setbits_le32(MVEBU_GPIO0_BASE + 0x0, BIT(19));
- mdelay(10);
- /* Init I2C IO expanders */
- for (i = 0; i < ARRAY_SIZE(io_exp); i++)
- puts("Board: Helios4\n");
- cpu_eth_init(bis); /* Built in controller(s) come first */
- return pci_eth_init(bis);
- U-Boot into it.
- "fdt_high=0x10000000\0" \
- "initrd_high=0x10000000\0"
+/* SPL */ +/*
- BOOT_TARGET_DEVICES_MMC(func) \
- BOOT_TARGET_DEVICES_USB(func) \
- BOOT_TARGET_DEVICES_SATA(func) \
- func(PXE, pxe, na) \
- func(DHCP, dhcp, na)
- "kernel_addr_r=" KERNEL_ADDR_R "\0" \
- "fdt_addr_r=" FDT_ADDR_R "\0" \
- "ramdisk_addr_r=" RAMDISK_ADDR_R "\0" \
- "scriptaddr=" SCRIPT_ADDR_R "\0" \
- "pxefile_addr_r=" PXEFILE_ADDR_R "\0"
- RELOCATION_LIMITS_ENV_SETTINGS \
- LOAD_ADDRESS_ENV_SETTINGS \
- "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \
- "console=ttyS0,115200\0" \
- BOOTENV
Viele Grüße, Stefan
El mar, 29-05-2018 a las 08:41 +0200, Stefan Roese escribió:
Hi Dennis,
Which specific SoM?
https://www.solid-run.com/introducing-helios4-personal-cloud/ is announcing it from SolidRun it is based on https://www.solid-run.com/ma rvell-armada-family/armada-som-system-on-module/ the one used in the helios4 has 2GiB of ECC ram. The microsom is split out in the kernel dts files https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linu x.git/tree/arch/arm/boot/dts/armada-38x-solidrun-microsom.dtsi
ECC is enabled and working, it had not been earlier.
Working on addressing them all.
Thanks
Dennis
Thanks, Stefan
(88F6828)
with
to
terms
dual
- whole.
of
the
- Or, alternatively
documentation
and/or
the
conditions:
be
Software.
WARRANTIES
ARISING
OR
- aliases {
addresses */
ethernet1 = ð0;
spi1 = &spi1;
- chosen {
- memory {
system-leds {
status-led {
fault-led {
io-leds {
sata1-led {
sata2-led {
sata3-led {
sata4-led {
usb-led {
fan1: j10-pwm {
fan2: j17-pwm {
- soc {
0x100000
0x100000
0x10000>;
internal-regs {
ethernet@70000 {
status = "okay";
i2c@11000 {
status = "okay";
1MHz clock.
* 0-CON3 CLKREQ#
* 1-CON3 PERST#
* 2-CON2 PERST#
* 3-CON3 W_DISABLE
* 4-CON2 CLKREQ#
* 6-USB3 power
* 7-CON2 W_DISABLE
* 8-JP4 P1
* 9-JP4 P4
* 10-JP4 P5
* 11-m.2 DEVSLP
* 12-SFP_LOS
* 13-SFP_TX_FAULT
* 14-SFP_TX_DISABLE
* 15-SFP_MOD_DEF0
be:
* compatible =
"onnn,pca9655",
* "nxp,pca9555";
because of
compatible =
"nxp,pca9555";
gpio-controller;
#gpio-cells = <2>;
reg = <0x20>;
usb3_ilimit {
gpio-hog;
gpios = <5
GPIO_ACTIVE_LOW>;
input;
line-name = "usb3-
current-limit";
usb3_power {
gpio-hog;
gpios = <6
GPIO_ACTIVE_HIGH>;
output-high;
line-name = "usb3-
power";
m2_devslp {
gpio-hog;
gpios = <11
GPIO_ACTIVE_HIGH>;
output-low;
line-name = "m.2
devslp";
only */
compatible =
reg = <0x4c>;
i2c@11100 {
PCIe.
requires
pins tied
0x50 and 0x51.
an I2C
addresses, or
* 0x63-0x64.
status = "okay";
mdio@72004 {
phy driver
register, rather
loaded setting.
here.
0x101e>;
reg = <0>;
pinctrl@18000 {
mikrobus */
"mpp27";
sdhci-cd-pins {
pins {
"mpp28",
"mpp37",
"mpp38",
"mpp39",
"mpp40";
"mpp29";
"mpp25";
rtc@a3800 {
"date reset"
* twice in u-boot.
status = "okay";
sata@a8000 {
status = "okay";
#size-cells = <0>;
reg = <0>;
reg = <1>;
sata@e0000 {
status = "okay";
#size-cells = <0>;
reg = <0>;
reg = <1>;
sdhci@d8000 {
bus-width = <4>;
GPIO_ACTIVE_LOW>;
no-1-8-v;
s>;
status = "okay";
vmmc = <®_3p3v>;
wp-inverted;
serial@12000 {
status = "okay";
serial@12100 {
/* mikrobus uart */
status = "okay";
spi1: spi@10680 {
* CS0: W25Q32
* CS1:
* CS2: mikrobus
status = "okay";
spi-flash@0 {
#size-cells = <0>;
0 */
spi-max-frequency =
<3000000>;
usb3@f8000 {
status = "okay";
- gpio-keys {
button_0 {
linux,can-disable;
+/* ++#define A38x_CUSTOMER_BOARD_1_MPP16_23 0x00400011 +MPP18: gpio ? (pca9655 int?) +MPP19: gpio ? (clkreq?) +MPP20: gpio ? (sd0 detect) +MPP21: sd0:cmd x sd0 +MPP22: gpio x mikro int +MPP23: gpio x switch irq ++#define A38x_CUSTOMER_BOARD_1_MPP24_31 0x22043333 +MPP24: ua1:rxd x mikro rx +MPP25: ua1:txd x mikro tx +MPP26: i2c1:sck x mikro sck +MPP27: i2c1:sda x mikro sda +MPP28: sd0:clk x sd0 +MPP29: gpio x mikro rst +MPP30: ge1:txd2 ? (config) +MPP31: ge1:txd3 ? (config) ++#define A38x_CUSTOMER_BOARD_1_MPP32_39 0x44400002 +MPP32: ge1:txctl ? (unused) +MPP33: gpio ? (pic_com0) +MPP34: gpio x rear button (pic_com1) +MPP35: gpio ? (pic_com2) +MPP36: gpio ? (unused) +MPP37: sd0:d3 x sd0 +MPP38: sd0:d0 x sd0 +MPP39: sd0:d1 x sd0 ++#define A38x_CUSTOMER_BOARD_1_MPP40_47 0x41144004 +MPP40: sd0:d2 x sd0 +MPP41: gpio x switch reset +MPP42: gpio ? sw1-1 +MPP43: spi1:cs2 x mikro cs +MPP44: sata3:prsnt ? (unused) +MPP45: ref:clk_out0 ? +MPP46: ref:clk_out1 x switch clk +MPP47: 4 ? (unused) ++#define A38x_CUSTOMER_BOARD_1_MPP48_55 0x40333333 +MPP48: tdm:pclk +MPP49: tdm:fsync +MPP50: tdm:drx +MPP51: tdm:dtx +MPP52: tdm:int +MPP53: tdm:rst +MPP54: gpio ? (pwm) +MPP55: spi1:cs1 x slic ++#define A38x_CUSTOMER_BOARD_1_MPP56_63 0x00004444 +MPP56: spi1:mosi x mikro mosi +MPP57: spi1:sck x mikro sck +MPP58: spi1:miso x mikro miso +MPP59: spi1:cs0 x w25q32 +*/ diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach- mvebu/Kconfig index f431cff950..0b47642d0c 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -75,6 +75,10 @@ config TARGET_CLEARFOG bool "Support ClearFog" select 88F6820
- select 88F6820
- SPI: 00010
- SD/eMMC: 00111
- SATA1: 11100
- UART: 11110
version
for clearfog
- u8 chip;
- u8 addr;
- u8 val;
- {0, 6, 0xf9},
current limiter */
- {0, 6, 0xb9}
0},
0}, +};
will
configure
{0x1, 0, 0, 0},
{0x1, 0, 0, 0},
{0x1, 0, 0, 0},
{0x1, 0, 0, 0} },
data source */
- int i;
phy reset */
- mdelay(1);
- mdelay(10);
&io_exp[i].val, 1);
- U-Boot into it.
MMC/eMMC
boot
+/* SPL */ +/*
(partition 1)
+#define SPL_BOOT_SPI_NOR_FLASH 1 +#define SPL_BOOT_SDIO_MMC_CARD 2 +#define CONFIG_SPL_BOOT_DEVICE SPL_BOOT_SDIO_MMC_CA RD
+#if CONFIG_SPL_BOOT_DEVICE == SPL_BOOT_SPI_NOR_FLASH +/* SPL related SPI defines */ +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 +#define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_SPI_U_BOO T_OFFS +#endif
+#if CONFIG_SPL_BOOT_DEVICE == SPL_BOOT_SDIO_MMC_CARD +/* SPL related MMC defines */ +#define CONFIG_SYS_MMC_U_BOOT_OFFS (160 << 10) +#define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_M MC_U_BOOT_OFFS +#ifdef CONFIG_SPL_BUILD +#define CONFIG_FIXED_SDHCI_ALIGNED_BUFFER 0x00180000 /* in SDRAM */ +#endif
them
- BOOTENV
Viele Grüße, Stefan
Chris Packham
Dennis Gilmore
dgilmore@redhat.com
Stefan Roese
