[U-Boot] Possible bug in imx6ul nand
Hello Everyone,
I tried to run "nand erase.part" and "nand erase.chip" on imx6ul isiot board and it hangs up and after some time it starts to give this error message:
MXS NAND: DMA read error MXS NAND: Error sending command
I printed error number which was -110, did anybody else face this problem?
I did try to erase nand with "flash_erase" from linux and it worked with throwing any error. In and all it seems like a uboot issue.
Thanks a lot, Shyam
Hi
On Wed, Jun 19, 2019 at 9:33 AM Shyam Saini shyam@amarulasolutions.com wrote:
Hello Everyone,
Di di you check pinmux on the bus? I think that is not muxed. You are booting from mmc and the bootrom just not configure it because your boot sequence is prio on mmc
Michael
Thanks a lot, Shyam
Michael Nazzareno Trimarchi
Shyam Saini
