[U-Boot] [PATCH] Add new Elpida memory configuration for ads5121
Rev 3 and earlier stay with Micron memory settings. Rev 4 boards manufactured before Nov-08 #1180 also will use Micron settings. More recent boards use Elpida settings.
Signed-off-by: Martha Marx mmarx@silicontkx.com --- board/ads5121/ads5121.c | 114 +++++++++++++++++++++++++++++++++----------- include/configs/ads5121.h | 41 ++++++++++------ 2 files changed, 110 insertions(+), 45 deletions(-)
diff --git a/board/ads5121/ads5121.c b/board/ads5121/ads5121.c index 6c40e94..1983492 100644 --- a/board/ads5121/ads5121.c +++ b/board/ads5121/ads5121.c @@ -124,9 +124,15 @@ phys_size_t initdram (int board_type) * fixed sdram init -- the board doesn't use memory modules that have serial presence * detect or similar mechanism for discovery of the DRAM settings */ + long int fixed_sdram (void) { + u32 use_micron = 0; volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; + ushort brd_rev = *(vu_short *) (CONFIG_SYS_CPLD_BASE + 0x00); + char *mac, *end, macaddr[6]; + u32 brddate, macchk; + u32 msize = CONFIG_SYS_DDR_SIZE * 1024 * 1024; u32 msize_log2 = __ilog2 (msize); u32 i; @@ -174,41 +180,91 @@ long int fixed_sdram (void) im->mddrc.lut_table4_alternate_upper = CONFIG_SYS_MDDRCGRP_LUT4_AU; im->mddrc.lut_table4_alternate_lower = CONFIG_SYS_MDDRCGRP_LUT4_AL;
+ if (brd_rev >= 0x0400 && (mac = getenv("ethaddr"))) { + for (i=0; i<6; i++) { + macaddr[i] = mac ? + simple_strtoul (mac, &end, 16) : 0; + if (mac) + mac = (*end) ? end+1 : end; + } + brddate = (macaddr[3] << 16) + (macaddr[4] << 8) + macaddr[5]; + macchk = (macaddr[0] << 16) + (macaddr[1] << 8) + macaddr[2]; + debug("brddate = %d\n\t",brddate); + /* Boards made before Nov-08 #1180 use Micron memory; 001e59 is the STx vendor # */ + if (macchk == 0x001e59 && brddate <= 8111180) + use_micron = 1; + } else if (brd_rev < 0x400) { + use_micron = 1; + } + + debug("Using %s Memory settings\n\t", use_micron ? "Micron" : "Elpida"); + /* Initialize MDDRC */ - im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG; - im->mddrc.ddr_time_config0 = CONFIG_SYS_MDDRC_TIME_CFG0; - im->mddrc.ddr_time_config1 = CONFIG_SYS_MDDRC_TIME_CFG1; - im->mddrc.ddr_time_config2 = CONFIG_SYS_MDDRC_TIME_CFG2; + if (use_micron) { + im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_MICRON; + im->mddrc.ddr_time_config0 = CONFIG_SYS_MDDRC_TIME_CFG0; + im->mddrc.ddr_time_config1 = CONFIG_SYS_MDDRC_TIME_CFG1_MICRON; + im->mddrc.ddr_time_config2 = CONFIG_SYS_MDDRC_TIME_CFG2_MICRON; + } else { + im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_ELPIDA; + im->mddrc.ddr_time_config0 = CONFIG_SYS_MDDRC_TIME_CFG0; + im->mddrc.ddr_time_config1 = CONFIG_SYS_MDDRC_TIME_CFG1_ELPIDA; + im->mddrc.ddr_time_config2 = CONFIG_SYS_MDDRC_TIME_CFG2_ELPIDA; + }
/* Initialize DDR */ for (i = 0; i < 10; i++) - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - - im->mddrc.ddr_command = CONFIG_SYS_MICRON_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_EM2; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_EM2; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_EM3; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_EN_DLL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_OCD_DEFAULT; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + + im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + + if (use_micron) { + /* Micron init sequence */ + im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM2; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM2; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM3; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EN_DLL; + im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; + udelay(200); + } else { + /* Elpida init sequence - works for Micron too but runs slower */ + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM2; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM3; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EN_DLL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RES_DLL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_ELPIDA_INIT_DEV_OP; + udelay(200); + } + im->mddrc.ddr_command = CONFIG_SYS_DDR_OCD_DEFAULT; + im->mddrc.ddr_command = CONFIG_SYS_DDR_OCD_EXIT; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + for (i = 0; i < 10; i++) + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; /* Start MDDRC */ im->mddrc.ddr_time_config0 = CONFIG_SYS_MDDRC_TIME_CFG0_RUN; - im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_RUN; + + if (use_micron) + im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_MICRON_RUN; + else + im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_ELPIDA_RUN;
return msize; } diff --git a/include/configs/ads5121.h b/include/configs/ads5121.h index 8fda3f2..ab06276 100644 --- a/include/configs/ads5121.h +++ b/include/configs/ads5121.h @@ -130,29 +130,38 @@ * [09:05] DRAM tRP: * [04:00] DRAM tRPA */ +#define CONFIG_SYS_MDDRC_SYS_CFG_RUN ~(0x10000000) #ifdef CONFIG_ADS5121_REV2 -#define CONFIG_SYS_MDDRC_SYS_CFG 0xF8604A00 -#define CONFIG_SYS_MDDRC_SYS_CFG_RUN 0xE8604A00 -#define CONFIG_SYS_MDDRC_TIME_CFG1 0x54EC1168 -#define CONFIG_SYS_MDDRC_TIME_CFG2 0x35210864 +#define CONFIG_SYS_MDDRC_SYS_CFG_MICRON 0xF8604A00 +#define CONFIG_SYS_MDDRC_TIME_CFG1_MICRON 0x54EC1168 +#define CONFIG_SYS_MDDRC_TIME_CFG2_MICRON 0x35210864 #else -#define CONFIG_SYS_MDDRC_SYS_CFG 0xFA804A00 -#define CONFIG_SYS_MDDRC_SYS_CFG_RUN 0xEA804A00 -#define CONFIG_SYS_MDDRC_TIME_CFG1 0x68EC1168 -#define CONFIG_SYS_MDDRC_TIME_CFG2 0x34310864 +#define CONFIG_SYS_MDDRC_SYS_CFG_MICRON 0xFA804A00 +#define CONFIG_SYS_MDDRC_SYS_CFG_MICRON_RUN 0xEA804A00 +#define CONFIG_SYS_MDDRC_TIME_CFG1_MICRON 0x68EC1168 +#define CONFIG_SYS_MDDRC_TIME_CFG2_MICRON 0x34310864 #endif +#define CONFIG_SYS_MDDRC_SYS_CFG_ELPIDA 0xFA802b40 +#define CONFIG_SYS_MDDRC_SYS_CFG_ELPIDA_RUN 0xEA802b40 +#define CONFIG_SYS_MDDRC_TIME_CFG1_ELPIDA 0x690e1189 +#define CONFIG_SYS_MDDRC_TIME_CFG2_ELPIDA 0x35410864 + #define CONFIG_SYS_MDDRC_SYS_CFG_EN 0xF0000000 +#define CONFIG_SYS_MDDRC_SYS_CFG_CLK_BIT (1 << 29) +#define CONFIG_SYS_MDDRC_SYS_CFG_CKE_BIT (1 << 30) #define CONFIG_SYS_MDDRC_TIME_CFG0 0x00003D2E #define CONFIG_SYS_MDDRC_TIME_CFG0_RUN 0x06183D2E - -#define CONFIG_SYS_MICRON_NOP 0x01380000 -#define CONFIG_SYS_MICRON_PCHG_ALL 0x01100400 -#define CONFIG_SYS_MICRON_EM2 0x01020000 -#define CONFIG_SYS_MICRON_EM3 0x01030000 -#define CONFIG_SYS_MICRON_EN_DLL 0x01010000 -#define CONFIG_SYS_MICRON_RFSH 0x01080000 #define CONFIG_SYS_MICRON_INIT_DEV_OP 0x01000432 -#define CONFIG_SYS_MICRON_OCD_DEFAULT 0x01010780 +#define CONFIG_SYS_ELPIDA_INIT_DEV_OP 0x01000842 +#define CONFIG_SYS_DDR_NOP 0x01380000 +#define CONFIG_SYS_DDR_PCHG_ALL 0x01100400 +#define CONFIG_SYS_DDR_EM2 0x01020000 +#define CONFIG_SYS_DDR_EM3 0x01030000 +#define CONFIG_SYS_DDR_EN_DLL 0x01010000 +#define CONFIG_SYS_DDR_RES_DLL 0x01000932 +#define CONFIG_SYS_DDR_RFSH 0x01080000 +#define CONFIG_SYS_DDR_OCD_DEFAULT 0x01010780 +#define CONFIG_SYS_DDR_OCD_EXIT 0x01010400
/* DDR Priority Manager Configuration */ #define CONFIG_SYS_MDDRCGRP_PM_CFG1 0x00077777
Drops the CONFIG_SYS_
Signed-off-by: Martha Marx mmarx@silicontkx.com --- board/ads5121/ads5121.c | 138 ++++++++++++++++++++++---------------------- include/configs/ads5121.h | 104 +++++++++++++++++----------------- 2 files changed, 121 insertions(+), 121 deletions(-)
diff --git a/board/ads5121/ads5121.c b/board/ads5121/ads5121.c index 1983492..306f184 100644 --- a/board/ads5121/ads5121.c +++ b/board/ads5121/ads5121.c @@ -153,32 +153,32 @@ long int fixed_sdram (void) __asm__ __volatile__ ("isync");
/* Enable DDR */ - im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_EN; + im->mddrc.ddr_sys_config = MDDRC_SYS_CFG_EN;
/* Initialize DDR Priority Manager */ - im->mddrc.prioman_config1 = CONFIG_SYS_MDDRCGRP_PM_CFG1; - im->mddrc.prioman_config2 = CONFIG_SYS_MDDRCGRP_PM_CFG2; - im->mddrc.hiprio_config = CONFIG_SYS_MDDRCGRP_HIPRIO_CFG; - im->mddrc.lut_table0_main_upper = CONFIG_SYS_MDDRCGRP_LUT0_MU; - im->mddrc.lut_table0_main_lower = CONFIG_SYS_MDDRCGRP_LUT0_ML; - im->mddrc.lut_table1_main_upper = CONFIG_SYS_MDDRCGRP_LUT1_MU; - im->mddrc.lut_table1_main_lower = CONFIG_SYS_MDDRCGRP_LUT1_ML; - im->mddrc.lut_table2_main_upper = CONFIG_SYS_MDDRCGRP_LUT2_MU; - im->mddrc.lut_table2_main_lower = CONFIG_SYS_MDDRCGRP_LUT2_ML; - im->mddrc.lut_table3_main_upper = CONFIG_SYS_MDDRCGRP_LUT3_MU; - im->mddrc.lut_table3_main_lower = CONFIG_SYS_MDDRCGRP_LUT3_ML; - im->mddrc.lut_table4_main_upper = CONFIG_SYS_MDDRCGRP_LUT4_MU; - im->mddrc.lut_table4_main_lower = CONFIG_SYS_MDDRCGRP_LUT4_ML; - im->mddrc.lut_table0_alternate_upper = CONFIG_SYS_MDDRCGRP_LUT0_AU; - im->mddrc.lut_table0_alternate_lower = CONFIG_SYS_MDDRCGRP_LUT0_AL; - im->mddrc.lut_table1_alternate_upper = CONFIG_SYS_MDDRCGRP_LUT1_AU; - im->mddrc.lut_table1_alternate_lower = CONFIG_SYS_MDDRCGRP_LUT1_AL; - im->mddrc.lut_table2_alternate_upper = CONFIG_SYS_MDDRCGRP_LUT2_AU; - im->mddrc.lut_table2_alternate_lower = CONFIG_SYS_MDDRCGRP_LUT2_AL; - im->mddrc.lut_table3_alternate_upper = CONFIG_SYS_MDDRCGRP_LUT3_AU; - im->mddrc.lut_table3_alternate_lower = CONFIG_SYS_MDDRCGRP_LUT3_AL; - im->mddrc.lut_table4_alternate_upper = CONFIG_SYS_MDDRCGRP_LUT4_AU; - im->mddrc.lut_table4_alternate_lower = CONFIG_SYS_MDDRCGRP_LUT4_AL; + im->mddrc.prioman_config1 = MDDRCGRP_PM_CFG1; + im->mddrc.prioman_config2 = MDDRCGRP_PM_CFG2; + im->mddrc.hiprio_config = MDDRCGRP_HIPRIO_CFG; + im->mddrc.lut_table0_main_upper = MDDRCGRP_LUT0_MU; + im->mddrc.lut_table0_main_lower = MDDRCGRP_LUT0_ML; + im->mddrc.lut_table1_main_upper = MDDRCGRP_LUT1_MU; + im->mddrc.lut_table1_main_lower = MDDRCGRP_LUT1_ML; + im->mddrc.lut_table2_main_upper = MDDRCGRP_LUT2_MU; + im->mddrc.lut_table2_main_lower = MDDRCGRP_LUT2_ML; + im->mddrc.lut_table3_main_upper = MDDRCGRP_LUT3_MU; + im->mddrc.lut_table3_main_lower = MDDRCGRP_LUT3_ML; + im->mddrc.lut_table4_main_upper = MDDRCGRP_LUT4_MU; + im->mddrc.lut_table4_main_lower = MDDRCGRP_LUT4_ML; + im->mddrc.lut_table0_alternate_upper = MDDRCGRP_LUT0_AU; + im->mddrc.lut_table0_alternate_lower = MDDRCGRP_LUT0_AL; + im->mddrc.lut_table1_alternate_upper = MDDRCGRP_LUT1_AU; + im->mddrc.lut_table1_alternate_lower = MDDRCGRP_LUT1_AL; + im->mddrc.lut_table2_alternate_upper = MDDRCGRP_LUT2_AU; + im->mddrc.lut_table2_alternate_lower = MDDRCGRP_LUT2_AL; + im->mddrc.lut_table3_alternate_upper = MDDRCGRP_LUT3_AU; + im->mddrc.lut_table3_alternate_lower = MDDRCGRP_LUT3_AL; + im->mddrc.lut_table4_alternate_upper = MDDRCGRP_LUT4_AU; + im->mddrc.lut_table4_alternate_lower = MDDRCGRP_LUT4_AL;
if (brd_rev >= 0x0400 && (mac = getenv("ethaddr"))) { for (i=0; i<6; i++) { @@ -201,70 +201,70 @@ long int fixed_sdram (void)
/* Initialize MDDRC */ if (use_micron) { - im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_MICRON; - im->mddrc.ddr_time_config0 = CONFIG_SYS_MDDRC_TIME_CFG0; - im->mddrc.ddr_time_config1 = CONFIG_SYS_MDDRC_TIME_CFG1_MICRON; - im->mddrc.ddr_time_config2 = CONFIG_SYS_MDDRC_TIME_CFG2_MICRON; + im->mddrc.ddr_sys_config = MDDRC_SYS_CFG_MICRON; + im->mddrc.ddr_time_config0 = MDDRC_TIME_CFG0; + im->mddrc.ddr_time_config1 = MDDRC_TIME_CFG1_MICRON; + im->mddrc.ddr_time_config2 = MDDRC_TIME_CFG2_MICRON; } else { - im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_ELPIDA; - im->mddrc.ddr_time_config0 = CONFIG_SYS_MDDRC_TIME_CFG0; - im->mddrc.ddr_time_config1 = CONFIG_SYS_MDDRC_TIME_CFG1_ELPIDA; - im->mddrc.ddr_time_config2 = CONFIG_SYS_MDDRC_TIME_CFG2_ELPIDA; + im->mddrc.ddr_sys_config = MDDRC_SYS_CFG_ELPIDA; + im->mddrc.ddr_time_config0 = MDDRC_TIME_CFG0; + im->mddrc.ddr_time_config1 = MDDRC_TIME_CFG1_ELPIDA; + im->mddrc.ddr_time_config2 = MDDRC_TIME_CFG2_ELPIDA; }
/* Initialize DDR */ for (i = 0; i < 10; i++) - im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = DDR_NOP;
- im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; - im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; - im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = DDR_PCHG_ALL; + im->mddrc.ddr_command = DDR_NOP; + im->mddrc.ddr_command = DDR_RFSH; + im->mddrc.ddr_command = DDR_NOP; + im->mddrc.ddr_command = DDR_RFSH; + im->mddrc.ddr_command = DDR_NOP;
if (use_micron) { /* Micron init sequence */ - im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; - im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; - im->mddrc.ddr_command = CONFIG_SYS_DDR_EM2; - im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; - im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_DDR_EM2; - im->mddrc.ddr_command = CONFIG_SYS_DDR_EM3; - im->mddrc.ddr_command = CONFIG_SYS_DDR_EN_DLL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; - im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; + im->mddrc.ddr_command = MICRON_INIT_DEV_OP; + im->mddrc.ddr_command = DDR_NOP; + im->mddrc.ddr_command = DDR_EM2; + im->mddrc.ddr_command = DDR_NOP; + im->mddrc.ddr_command = DDR_PCHG_ALL; + im->mddrc.ddr_command = DDR_EM2; + im->mddrc.ddr_command = DDR_EM3; + im->mddrc.ddr_command = DDR_EN_DLL; + im->mddrc.ddr_command = MICRON_INIT_DEV_OP; + im->mddrc.ddr_command = DDR_PCHG_ALL; + im->mddrc.ddr_command = DDR_RFSH; + im->mddrc.ddr_command = DDR_RFSH; + im->mddrc.ddr_command = DDR_RFSH; + im->mddrc.ddr_command = MICRON_INIT_DEV_OP; udelay(200); } else { /* Elpida init sequence - works for Micron too but runs slower */ - im->mddrc.ddr_command = CONFIG_SYS_DDR_EM2; - im->mddrc.ddr_command = CONFIG_SYS_DDR_EM3; - im->mddrc.ddr_command = CONFIG_SYS_DDR_EN_DLL; - im->mddrc.ddr_command = CONFIG_SYS_DDR_RES_DLL; - im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_ELPIDA_INIT_DEV_OP; + im->mddrc.ddr_command = DDR_EM2; + im->mddrc.ddr_command = DDR_EM3; + im->mddrc.ddr_command = DDR_EN_DLL; + im->mddrc.ddr_command = DDR_RES_DLL; + im->mddrc.ddr_command = DDR_PCHG_ALL; + im->mddrc.ddr_command = DDR_RFSH; + im->mddrc.ddr_command = DDR_RFSH; + im->mddrc.ddr_command = DDR_RFSH; + im->mddrc.ddr_command = ELPIDA_INIT_DEV_OP; udelay(200); } - im->mddrc.ddr_command = CONFIG_SYS_DDR_OCD_DEFAULT; - im->mddrc.ddr_command = CONFIG_SYS_DDR_OCD_EXIT; - im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = DDR_OCD_DEFAULT; + im->mddrc.ddr_command = DDR_OCD_EXIT; + im->mddrc.ddr_command = DDR_NOP; for (i = 0; i < 10; i++) - im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = DDR_NOP; /* Start MDDRC */ - im->mddrc.ddr_time_config0 = CONFIG_SYS_MDDRC_TIME_CFG0_RUN; + im->mddrc.ddr_time_config0 = MDDRC_TIME_CFG0_RUN;
if (use_micron) - im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_MICRON_RUN; + im->mddrc.ddr_sys_config = MDDRC_SYS_CFG_MICRON_RUN; else - im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_ELPIDA_RUN; + im->mddrc.ddr_sys_config = MDDRC_SYS_CFG_ELPIDA_RUN;
return msize; } diff --git a/include/configs/ads5121.h b/include/configs/ads5121.h index ab06276..3fe3c50 100644 --- a/include/configs/ads5121.h +++ b/include/configs/ads5121.h @@ -130,63 +130,63 @@ * [09:05] DRAM tRP: * [04:00] DRAM tRPA */ -#define CONFIG_SYS_MDDRC_SYS_CFG_RUN ~(0x10000000) +#define MDDRC_SYS_CFG_RUN ~(0x10000000) #ifdef CONFIG_ADS5121_REV2 -#define CONFIG_SYS_MDDRC_SYS_CFG_MICRON 0xF8604A00 -#define CONFIG_SYS_MDDRC_TIME_CFG1_MICRON 0x54EC1168 -#define CONFIG_SYS_MDDRC_TIME_CFG2_MICRON 0x35210864 +#define MDDRC_SYS_CFG_MICRON 0xF8604A00 +#define MDDRC_TIME_CFG1_MICRON 0x54EC1168 +#define MDDRC_TIME_CFG2_MICRON 0x35210864 #else -#define CONFIG_SYS_MDDRC_SYS_CFG_MICRON 0xFA804A00 -#define CONFIG_SYS_MDDRC_SYS_CFG_MICRON_RUN 0xEA804A00 -#define CONFIG_SYS_MDDRC_TIME_CFG1_MICRON 0x68EC1168 -#define CONFIG_SYS_MDDRC_TIME_CFG2_MICRON 0x34310864 +#define MDDRC_SYS_CFG_MICRON 0xFA804A00 +#define MDDRC_SYS_CFG_MICRON_RUN 0xEA804A00 +#define MDDRC_TIME_CFG1_MICRON 0x68EC1168 +#define MDDRC_TIME_CFG2_MICRON 0x34310864 #endif -#define CONFIG_SYS_MDDRC_SYS_CFG_ELPIDA 0xFA802b40 -#define CONFIG_SYS_MDDRC_SYS_CFG_ELPIDA_RUN 0xEA802b40 -#define CONFIG_SYS_MDDRC_TIME_CFG1_ELPIDA 0x690e1189 -#define CONFIG_SYS_MDDRC_TIME_CFG2_ELPIDA 0x35410864 - -#define CONFIG_SYS_MDDRC_SYS_CFG_EN 0xF0000000 -#define CONFIG_SYS_MDDRC_SYS_CFG_CLK_BIT (1 << 29) -#define CONFIG_SYS_MDDRC_SYS_CFG_CKE_BIT (1 << 30) -#define CONFIG_SYS_MDDRC_TIME_CFG0 0x00003D2E -#define CONFIG_SYS_MDDRC_TIME_CFG0_RUN 0x06183D2E -#define CONFIG_SYS_MICRON_INIT_DEV_OP 0x01000432 -#define CONFIG_SYS_ELPIDA_INIT_DEV_OP 0x01000842 -#define CONFIG_SYS_DDR_NOP 0x01380000 -#define CONFIG_SYS_DDR_PCHG_ALL 0x01100400 -#define CONFIG_SYS_DDR_EM2 0x01020000 -#define CONFIG_SYS_DDR_EM3 0x01030000 -#define CONFIG_SYS_DDR_EN_DLL 0x01010000 -#define CONFIG_SYS_DDR_RES_DLL 0x01000932 -#define CONFIG_SYS_DDR_RFSH 0x01080000 -#define CONFIG_SYS_DDR_OCD_DEFAULT 0x01010780 -#define CONFIG_SYS_DDR_OCD_EXIT 0x01010400 +#define MDDRC_SYS_CFG_ELPIDA 0xFA802b40 +#define MDDRC_SYS_CFG_ELPIDA_RUN 0xEA802b40 +#define MDDRC_TIME_CFG1_ELPIDA 0x690e1189 +#define MDDRC_TIME_CFG2_ELPIDA 0x35410864 + +#define MDDRC_SYS_CFG_EN 0xF0000000 +#define MDDRC_SYS_CFG_CLK_BIT (1 << 29) +#define MDDRC_SYS_CFG_CKE_BIT (1 << 30) +#define MDDRC_TIME_CFG0 0x00003D2E +#define MDDRC_TIME_CFG0_RUN 0x06183D2E +#define MICRON_INIT_DEV_OP 0x01000432 +#define ELPIDA_INIT_DEV_OP 0x01000842 +#define DDR_NOP 0x01380000 +#define DDR_PCHG_ALL 0x01100400 +#define DDR_EM2 0x01020000 +#define DDR_EM3 0x01030000 +#define DDR_EN_DLL 0x01010000 +#define DDR_RES_DLL 0x01000932 +#define DDR_RFSH 0x01080000 +#define DDR_OCD_DEFAULT 0x01010780 +#define DDR_OCD_EXIT 0x01010400
/* DDR Priority Manager Configuration */ -#define CONFIG_SYS_MDDRCGRP_PM_CFG1 0x00077777 -#define CONFIG_SYS_MDDRCGRP_PM_CFG2 0x00000000 -#define CONFIG_SYS_MDDRCGRP_HIPRIO_CFG 0x00000001 -#define CONFIG_SYS_MDDRCGRP_LUT0_MU 0xFFEEDDCC -#define CONFIG_SYS_MDDRCGRP_LUT0_ML 0xBBAAAAAA -#define CONFIG_SYS_MDDRCGRP_LUT1_MU 0x66666666 -#define CONFIG_SYS_MDDRCGRP_LUT1_ML 0x55555555 -#define CONFIG_SYS_MDDRCGRP_LUT2_MU 0x44444444 -#define CONFIG_SYS_MDDRCGRP_LUT2_ML 0x44444444 -#define CONFIG_SYS_MDDRCGRP_LUT3_MU 0x55555555 -#define CONFIG_SYS_MDDRCGRP_LUT3_ML 0x55555558 -#define CONFIG_SYS_MDDRCGRP_LUT4_MU 0x11111111 -#define CONFIG_SYS_MDDRCGRP_LUT4_ML 0x11111122 -#define CONFIG_SYS_MDDRCGRP_LUT0_AU 0xaaaaaaaa -#define CONFIG_SYS_MDDRCGRP_LUT0_AL 0xaaaaaaaa -#define CONFIG_SYS_MDDRCGRP_LUT1_AU 0x66666666 -#define CONFIG_SYS_MDDRCGRP_LUT1_AL 0x66666666 -#define CONFIG_SYS_MDDRCGRP_LUT2_AU 0x11111111 -#define CONFIG_SYS_MDDRCGRP_LUT2_AL 0x11111111 -#define CONFIG_SYS_MDDRCGRP_LUT3_AU 0x11111111 -#define CONFIG_SYS_MDDRCGRP_LUT3_AL 0x11111111 -#define CONFIG_SYS_MDDRCGRP_LUT4_AU 0x11111111 -#define CONFIG_SYS_MDDRCGRP_LUT4_AL 0x11111111 +#define MDDRCGRP_PM_CFG1 0x00077777 +#define MDDRCGRP_PM_CFG2 0x00000000 +#define MDDRCGRP_HIPRIO_CFG 0x00000001 +#define MDDRCGRP_LUT0_MU 0xFFEEDDCC +#define MDDRCGRP_LUT0_ML 0xBBAAAAAA +#define MDDRCGRP_LUT1_MU 0x66666666 +#define MDDRCGRP_LUT1_ML 0x55555555 +#define MDDRCGRP_LUT2_MU 0x44444444 +#define MDDRCGRP_LUT2_ML 0x44444444 +#define MDDRCGRP_LUT3_MU 0x55555555 +#define MDDRCGRP_LUT3_ML 0x55555558 +#define MDDRCGRP_LUT4_MU 0x11111111 +#define MDDRCGRP_LUT4_ML 0x11111122 +#define MDDRCGRP_LUT0_AU 0xaaaaaaaa +#define MDDRCGRP_LUT0_AL 0xaaaaaaaa +#define MDDRCGRP_LUT1_AU 0x66666666 +#define MDDRCGRP_LUT1_AL 0x66666666 +#define MDDRCGRP_LUT2_AU 0x11111111 +#define MDDRCGRP_LUT2_AL 0x11111111 +#define MDDRCGRP_LUT3_AU 0x11111111 +#define MDDRCGRP_LUT3_AL 0x11111111 +#define MDDRCGRP_LUT4_AU 0x11111111 +#define MDDRCGRP_LUT4_AL 0x11111111
/* * NOR FLASH on the Local Bus
Dear Martha Marx,
Please submit this patch first, before adding Elpida support. Patche swill be smaller and muchbetter to read that way.
Please base this patch on master branch. I will make sure to rebase the "next" branch before then applying the Eplida patch (which should go into the "next" branch so we can use eth_getenv_enetaddr().
Thanks.
Dear Martha Marx!
I have tested your patches and they worked well - they even solved a DRAM init problem at power on (u-boot hangs at power on when the board is warmed up - I wonder if my board is defective or is this a problem of the supplied u-boot?).
However - it would be great to have the ELPIDA Support in U-Boot mainline - Mr. Denk said he needs the requested changes to add it to mainline (see http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/54983/focus= 55035).
How are your plans according to that - should I wait for an update or is the board frozen to this last patch ?
Best regards, Arno Fischer
Dear Martha Marx,
Can you please swap the order of your patches, i. e. first perform the global CONFIG_SYS_ rename, and then apply the Elpida support patch?
- fixed sdram init -- the board doesn't use memory modules that have serial presence
- detect or similar mechanism for discovery of the DRAM settings
- u32 use_micron = 0; volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR;
- ushort brd_rev = *(vu_short *) (CONFIG_SYS_CPLD_BASE + 0x00);
- char *mac, *end, macaddr[6];
- u32 brddate, macchk;
- u32 msize = CONFIG_SYS_DDR_SIZE * 1024 * 1024; u32 msize_log2 = __ilog2 (msize); u32 i;
- if (brd_rev >= 0x0400 && (mac = getenv("ethaddr"))) {
macaddr[i] = mac ?
if (mac)
Please rebase your patch(es) against the "next" branch, so you can use eth_getenv_enetaddr() instead of manually paring the MAC address.
- /* Boards made before Nov-08 #1180 use Micron memory; 001e59 is the STx vendor # */
Wrong indentation; line too long.
use_micron = 1;
- } else if (brd_rev < 0x400) {
use_micron = 1;
- debug("Using %s Memory settings\n\t", use_micron ? "Micron" : "Elpida");
- /* Initialize MDDRC */
if (use_micron) {
} else {
- if (use_micron) {
- /* Micron init sequence */
Wrong indentation.
udelay(200);
- } else {
- /* Elpida init sequence - works for Micron too but runs slower */
Wrong indentation.
udelay(200);
Empty line, please.
Empty line, please.
- for (i = 0; i < 10; i++)
Empty line, please.
Thanks.
Arno Fischer
Martha Marx
