[U-Boot-Users] [PATCH] ADS5121 cleanup compile warnings
board/ads5121/iopin.c Replace bit fields in struct iopin_t with a single field and intialize it via plain old macros. This fixes the type pun warnings and makes the code more readable.
board/ads5121/ads5121.c Add include iopin.h to ads5121.c for the iopin_initialize prototype.
Remove unused variables from board_early_init_f
Add an extern void ads5121_diu_init(void)
Signed-off-by: John Rigby jrigby@freescale.com --- board/ads5121/ads5121.c | 6 ++- board/ads5121/iopin.c | 111 +++++++++++++++++++++++++++------------------- 2 files changed, 69 insertions(+), 48 deletions(-)
diff --git a/board/ads5121/ads5121.c b/board/ads5121/ads5121.c index de59991..e622e35 100644 --- a/board/ads5121/ads5121.c +++ b/board/ads5121/ads5121.c @@ -23,6 +23,7 @@
#include <common.h> #include <mpc512x.h> +#include "iopin.h" #include <asm/bitops.h> #include <command.h> #include <fdt_support.h> @@ -47,13 +48,14 @@ #define CSAW_START(start) ((start) & 0xFFFF0000) #define CSAW_STOP(start, size) (((start) + (size) - 1) >> 16)
+extern void ads5121_diu_init(void); + long int fixed_sdram(void);
int board_early_init_f (void) { volatile immap_t *im = (immap_t *) CFG_IMMR; - u32 lpcaw, tmp32; - int i; + u32 lpcaw;
/* * Initialize Local Window for the CPLD registers access (CS2 selects diff --git a/board/ads5121/iopin.c b/board/ads5121/iopin.c index 6a35c81..a6792a0 100644 --- a/board/ads5121/iopin.c +++ b/board/ads5121/iopin.c @@ -25,71 +25,90 @@ #include <linux/types.h> #include "iopin.h"
-/* - * IO PAD TYPES - * for all types fmux is used to select the funtion - * ds sets the slew rate - * STD pins nothing extra (can set ds & fmux only) - * STD_PU pue=1 to enable pull & pud sets whether up or down resistors - * STD_ST st sets the Schmitt trigger - * STD_PU_ST pue & pud sets pull-up/down resistors as in STD_PU - * st sets the Schmitt trigger - * PCI hold sets output delay - * PCI_ST hold sets output delay and st sets the Schmitt trigger - */ +/* IO pin fields */ +#define IO_PIN_FMUX(v) ((v) << 7) /* pin function */ +#define IO_PIN_HOLD(v) ((v) << 5) /* hold time, pci only */ +#define IO_PIN_PUD(v) ((v) << 4) /* if PUE, 0=pull-down, 1=pull-up */ +#define IO_PIN_PUE(v) ((v) << 3) /* pull up/down enable */ +#define IO_PIN_ST(v) ((v) << 2) /* schmitt trigger */ +#define IO_PIN_DS(v) ((v)) /* slew rate */
static struct iopin_t { - u_short p_offset; /* offset from IOCTL_MEM_OFFSET */ - u_short p_no; /* number of pins to set this way */ - u_short bit_or:7; /* Do bitwise OR instead of setting */ - u_short fmux:2; /* pad function select 0-3 */ - u_short hold:2; /* PCI pad types only; */ - u_short pud:1; /* pull resistor; PU types only; */ - /* if pue=1 then 0=pull-down, 1=pull-up */ - u_short pue:1; /* Pull resistor enable; _PU types only */ - u_short st:1; /* Schmitt trigger enable; _ST types only */ - u_short ds:2; /* Slew rate class, 0=class1, ..., 3=class4 */ + int p_offset; /* offset from IOCTL_MEM_OFFSET */ + int nr_pins; /* number of pins to set this way */ + int bit_or; /* or in the value instead of overwrite */ + u_long val; /* value to write or or */ } ioregs_init[] = { -/* FUNC1=FEC_RX_DV Sets Next 3 to FEC pads */ - {IOCTL_SPDIF_TXCLK, 3, 0, 1, 0, 0, 0, 0, 3}, -/* Set highest Slew on 9 PATA pins */ - {IOCTL_PATA_CE1, 9, 1, 0, 0, 0, 0, 0, 3}, -/* FUNC1=FEC_COL Sets Next 15 to FEC pads */ - {IOCTL_PSC0_0, 15, 0, 1, 0, 0, 0, 0, 3}, -/* FUNC1=SPDIF_TXCLK */ - {IOCTL_LPC_CS1, 1, 0, 1, 0, 0, 0, 1, 3}, -/* FUNC2=SPDIF_TX and sets Next pin to SPDIF_RX */ - {IOCTL_I2C1_SCL, 2, 0, 2, 0, 0, 0, 1, 3}, -/* FUNC2=DIU CLK */ - {IOCTL_PSC6_0, 1, 0, 2, 0, 0, 0, 1, 3}, -/* FUNC2=DIU_HSYNC */ - {IOCTL_PSC6_1, 1, 0, 2, 0, 0, 0, 0, 3}, -/* FUNC2=DIUVSYNC Sets Next 26 to DIU Pads */ - {IOCTL_PSC6_4, 26, 0, 2, 0, 0, 0, 0, 3} + /* FUNC1=FEC_RX_DV Sets Next 3 to FEC pads */ + { + IOCTL_SPDIF_TXCLK, 3, 0, + IO_PIN_FMUX(1) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(3) + }, + /* Set highest Slew on 9 PATA pins */ + { + IOCTL_PATA_CE1, 9, 1, + IO_PIN_FMUX(0) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(3) + }, + /* FUNC1=FEC_COL Sets Next 15 to FEC pads */ + { + IOCTL_PSC0_0, 15, 0, + IO_PIN_FMUX(1) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(3) + }, + /* FUNC1=SPDIF_TXCLK */ + { + IOCTL_LPC_CS1, 1, 0, + IO_PIN_FMUX(1) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(1) | IO_PIN_DS(3) + }, + /* FUNC2=SPDIF_TX and sets Next pin to SPDIF_RX */ + { + IOCTL_I2C1_SCL, 2, 0, + IO_PIN_FMUX(2) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(1) | IO_PIN_DS(3) + }, + /* FUNC2=DIU CLK */ + { + IOCTL_PSC6_0, 1, 0, + IO_PIN_FMUX(2) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(1) | IO_PIN_DS(3) + }, + /* FUNC2=DIU_HSYNC */ + { + IOCTL_PSC6_1, 1, 0, + IO_PIN_FMUX(2) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(3) + }, + /* FUNC2=DIUVSYNC Sets Next 26 to DIU Pads */ + { + IOCTL_PSC6_4, 26, 0, + IO_PIN_FMUX(2) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(3) + } };
void iopin_initialize(void) { short i, j, n, p; u_long *reg; + immap_t *im = (immap_t *)CFG_IMMR; + + reg = (u_long *)&(im->io_ctrl.regs[0]);
if (sizeof(ioregs_init) == 0) return;
- immap_t *im = (immap_t *)CFG_IMMR; - reg = (u_long *)&(im->io_ctrl.regs[0]); n = sizeof(ioregs_init) / sizeof(ioregs_init[0]);
for (i = 0; i < n; i++) { for (p = 0, j = ioregs_init[i].p_offset / sizeof(u_long); - p < ioregs_init[i].p_no; p++, j++) { - /* lowest 9 bits sets the register */ + p < ioregs_init[i].nr_pins; p++, j++) { if (ioregs_init[i].bit_or) - reg[j] |= *((u_long *) &ioregs_init[i].p_no) - & 0x000001ff; + reg[j] |= ioregs_init[i].val; else - reg[j] = *((u_long *) &ioregs_init[i].p_no) - & 0x000001ff; + reg[j] = ioregs_init[i].val; } } return;
John Rigby
