[U-Boot] [PATCH 0/4] MIPS: make config options more generic
This patch series contains cleanups and enhancements to consolidate the INCA-IP related config options and to make them more generic. Additionally, the cache operation mode is now configurable. All changes are needed to prepare the support of newer MIPS based Lantiq XWAY SoCs.
Daniel Schwierzeck (4): MIPS: INCA-IP: rename inca-swap-bytes host tool MIPS: rename INFINEON_EBU_BOOTCFG to CONFIG_SYS_XWAY_EBU_BOOTFG MIPS: make cache operation mode configurable README: update MIPS related informations
README | 35 +++++++++++++++++++++++- arch/mips/cpu/mips32/start.S | 19 ++++++++++--- include/configs/incaip.h | 4 ++- tools/Makefile | 8 +++--- tools/{inca-swap-bytes.c => xway-swap-bytes.c} | 0 5 files changed, 56 insertions(+), 10 deletions(-) rename tools/{inca-swap-bytes.c => xway-swap-bytes.c} (100%)
The INCA-IP SoC belongs to the Lantiq XWAY SoC product portfolio. For the upcoming support of other Lantiq SoC devices this tool should not solely depend on the INCA-IP board.
Rename the tool to xway-swap-bytes and add an config option to enable compilation optionally.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- include/configs/incaip.h | 2 ++ tools/Makefile | 8 ++++---- tools/{inca-swap-bytes.c => xway-swap-bytes.c} | 0 3 files changed, 6 insertions(+), 4 deletions(-) rename tools/{inca-swap-bytes.c => xway-swap-bytes.c} (100%)
diff --git a/include/configs/incaip.h b/include/configs/incaip.h index f2950e8..57eb2fa 100644 --- a/include/configs/incaip.h +++ b/include/configs/incaip.h @@ -31,6 +31,8 @@ #define CONFIG_MIPS32 1 /* MIPS 4Kc CPU core */ #define CONFIG_INCA_IP 1 /* on a INCA-IP Board */
+#define CONFIG_XWAY_SWAP_BYTES + /* * Clock for the MIPS core (MHz) * allowed values: 100000000, 133000000, and 150000000 (default) diff --git a/tools/Makefile b/tools/Makefile index 97f83f8..7d77b43 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -43,7 +43,7 @@ ifneq ($(HOST_TOOLS_ALL),) CONFIG_LCD_LOGO = y CONFIG_CMD_LOADS = y CONFIG_CMD_NET = y -CONFIG_INCA_IP = y +CONFIG_XWAY_SWAP_BYTES = y CONFIG_NETCONSOLE = y CONFIG_SHA1_CHECK_UB_IMG = y endif @@ -65,7 +65,7 @@ BIN_FILES-$(CONFIG_VIDEO_LOGO) += bmp_logo$(SFX) BIN_FILES-$(CONFIG_BUILD_ENVCRC) += envcrc$(SFX) BIN_FILES-$(CONFIG_CMD_NET) += gen_eth_addr$(SFX) BIN_FILES-$(CONFIG_CMD_LOADS) += img2srec$(SFX) -BIN_FILES-$(CONFIG_INCA_IP) += inca-swap-bytes$(SFX) +BIN_FILES-$(CONFIG_XWAY_SWAP_BYTES) += xway-swap-bytes$(SFX) BIN_FILES-y += mkimage$(SFX) BIN_FILES-$(CONFIG_NETCONSOLE) += ncb$(SFX) BIN_FILES-$(CONFIG_SHA1_CHECK_UB_IMG) += ubsha1$(SFX) @@ -85,7 +85,7 @@ OBJ_FILES-$(CONFIG_BUILD_ENVCRC) += envcrc.o NOPED_OBJ_FILES-y += fit_image.o OBJ_FILES-$(CONFIG_CMD_NET) += gen_eth_addr.o OBJ_FILES-$(CONFIG_CMD_LOADS) += img2srec.o -OBJ_FILES-$(CONFIG_INCA_IP) += inca-swap-bytes.o +OBJ_FILES-$(CONFIG_XWAY_SWAP_BYTES) += xway-swap-bytes.o NOPED_OBJ_FILES-y += kwbimage.o NOPED_OBJ_FILES-y += imximage.o NOPED_OBJ_FILES-y += mkimage.o @@ -175,7 +175,7 @@ $(obj)img2srec$(SFX): $(obj)img2srec.o $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ $(HOSTSTRIP) $@
-$(obj)inca-swap-bytes$(SFX): $(obj)inca-swap-bytes.o +$(obj)xway-swap-bytes$(SFX): $(obj)xway-swap-bytes.o $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ $(HOSTSTRIP) $@
diff --git a/tools/inca-swap-bytes.c b/tools/xway-swap-bytes.c similarity index 100% rename from tools/inca-swap-bytes.c rename to tools/xway-swap-bytes.c
This define is a board-specific config option and should be renamed to follow the U-Boot naming convention. Additionally, add an explaining comment for this option.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- arch/mips/cpu/mips32/start.S | 13 ++++++++++--- include/configs/incaip.h | 2 +- 2 files changed, 11 insertions(+), 4 deletions(-)
diff --git a/arch/mips/cpu/mips32/start.S b/arch/mips/cpu/mips32/start.S index 5d7467d..e829b02 100644 --- a/arch/mips/cpu/mips32/start.S +++ b/arch/mips/cpu/mips32/start.S @@ -64,9 +64,16 @@ _start: RVECENT(reset,0) # U-boot entry point RVECENT(reset,1) # software reboot -#ifdef CONFIG_INCA_IP - .word INFINEON_EBU_BOOTCFG # EBU init code, fetched during - .word 0x00000000 # booting phase of the flash +#ifdef CONFIG_SYS_XWAY_EBU_BOOTCFG + /* + * Almost all Lantiq XWAY SoC devices have an external bus unit (EBU) to + * access external NOR flashes. If the board boots from NOR flash the + * internal BootROM does a blind read at address 0xB0000010 to read the + * initial configuration for that EBU in order to access the flash + * device with correct parameters. This config option is board-specific. + */ + .word CONFIG_SYS_XWAY_EBU_BOOTCFG + .word 0x00000000 #else RVECENT(romReserved,2) #endif diff --git a/include/configs/incaip.h b/include/configs/incaip.h index 57eb2fa..0e5ad2b 100644 --- a/include/configs/incaip.h +++ b/include/configs/incaip.h @@ -41,7 +41,7 @@ #define CONFIG_CPU_CLOCK_RATE 150000000 #endif
-#define INFINEON_EBU_BOOTCFG 0x40C4 /* CMULT = 8 */ +#define CONFIG_SYS_XWAY_EBU_BOOTCFG 0x40C4 /* CMULT = 8 */
#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */
Currently the cache operation mode is hard-coded to CONF_CM_CACHABLE_NONCOHERENT. This is not appropiate for CPUs or SOCs which operate at a different mode.
This patch makes the cache operation mode configurable via board config.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- arch/mips/cpu/mips32/start.S | 6 +++++- 1 files changed, 5 insertions(+), 1 deletions(-)
diff --git a/arch/mips/cpu/mips32/start.S b/arch/mips/cpu/mips32/start.S index e829b02..9c1b2f7 100644 --- a/arch/mips/cpu/mips32/start.S +++ b/arch/mips/cpu/mips32/start.S @@ -27,6 +27,10 @@ #include <asm/regdef.h> #include <asm/mipsregs.h>
+#ifndef CONFIG_SYS_MIPS_CACHE_MODE +#define CONFIG_SYS_MIPS_CACHE_MODE CONF_CM_CACHABLE_NONCOHERENT +#endif + /* * For the moment disable interrupts, mark the kernel mode and * set ST0_KX so that the CPU does not spit fire when using @@ -249,7 +253,7 @@ reset: nop
/* ... and enable them */ - li t0, CONF_CM_CACHABLE_NONCOHERENT + li t0, CONFIG_SYS_MIPS_CACHE_MODE mtc0 t0, CP0_CONFIG #endif
Amend section 'Directory Hierarchy' for current MIPS directory. Describe config options for MIPS.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- README | 35 ++++++++++++++++++++++++++++++++++- 1 files changed, 34 insertions(+), 1 deletions(-)
diff --git a/README b/README index cb08816..62d2d44 100644 --- a/README +++ b/README @@ -180,6 +180,7 @@ Directory Hierarchy: /lib Architecture specific library files /mips Files generic to MIPS architecture /cpu CPU specific files + /mips32 Files specific to MIPS32 CPUs /lib Architecture specific library files /nios2 Files generic to Altera NIOS2 architecture /cpu CPU specific files @@ -382,6 +383,38 @@ The following options need to be configured: 2. The core frequency as calculated above is multiplied by this value.
+- MIPS CPU options: + CONFIG_SYS_INIT_SP_OFFSET + + Offset relative to CONFIG_SYS_SDRAM_BASE for initial stack + pointer. This is needed for the temporary stack before + relocation. + + CONFIG_SYS_MIPS_CACHE_MODE + + Cache operation mode for the MIPS CPU. + See also arch/mips/include/asm/mipsregs.h. + Possible values are: + CONF_CM_CACHABLE_NO_WA + CONF_CM_CACHABLE_WA + CONF_CM_UNCACHED + CONF_CM_CACHABLE_NONCOHERENT + CONF_CM_CACHABLE_CE + CONF_CM_CACHABLE_COW + CONF_CM_CACHABLE_CUW + CONF_CM_CACHABLE_ACCELERATED + + CONFIG_SYS_XWAY_EBU_BOOTCFG + + Special option for Lantiq XWAY SoCs for booting from NOR flash. + See also arch/mips/cpu/mips32/start.S. + + CONFIG_XWAY_SWAP_BYTES + + Enable compilation of tools/xway-swap-bytes needed for Lantiq + XWAY SoCs for booting from NOR flash. The U-Boot image needs to + be swapped if a flash programmer is used. + - Linux Kernel Interface: CONFIG_CLOCKS_IN_MHZ
@@ -3070,7 +3103,7 @@ Low Level (hardware related) configuration options: globally (CONFIG_CMD_MEM).
- CONFIG_SKIP_LOWLEVEL_INIT - [ARM only] If this variable is defined, then certain + [ARM, MIPS only] If this variable is defined, then certain low level initializations (like setting up the memory controller) are omitted and/or U-Boot does not relocate itself into RAM.
Hi Daniel,
Daniel Schwierzeck wrote on 2011-07-27:
my ack to the complete series:
Acked-by: Thomas Langer thomas.langer@lantiq.com
Best Regards, Thomas
On 07/28/2011 05:14 PM, thomas.langer@lantiq.com wrote:
Hi Daniel,
Thanks for the patches, looks good. Will push shortly.
Shinya
Daniel Schwierzeck
Shinya Kuribayashi
