[PATCH v7 0/2] Add OpenPiton-riscv64 board support
This patch set is to add OpenPiton board support. Patches are split into several parts:
- [PATCH 1/2] add OpenPiton support to mmc driver - [PATCH 2/2] add support for OpenPiton board
Description
- for mmc driver, it's settings are automatically configured at hardware level. We only need to expose the memory mapped interface through U-Boot driver model - For OpenPiton, as we need to embed the device tree blob into the bitstream, there is currently no itb support
Tests checks
- Able to boot Debian Linux from SD card on Digilent Genesys 2 - Checkpatch is performed, with some warnings ignored
Changelogs - V2 . fix styles and typos in [1/2] and [2/2] . add board documentation in [2/2] - V3 . fix styles in [1/2] - V4 . fix checkpatch warnings in [1/2] except MAINTAINERS - V5 . major changes in device tree . changed to OF_SEPARATE . formatting update for mmc - V6 . eliminate debug outputs altogether . separate defconfigs between SPL and u-boot proper . style updates thanks to Sean - V7 . mmc dm fixes . mmc style updates, improving readibility . mmc add write support . OpenPiton RISC-V 64 board Kconfig fixes
Acknowledgements
We'd like to thank all maintainers who have reviewed our code. But we'd like to thank Sean and Jaehoon in particular for taking much time and energy to help us write better code.
Tianrui Wei (2): board: riscv: add openpiton-riscv64 SoC support mmc: openpiton: add piton_mmc driver
arch/riscv/Kconfig | 4 + arch/riscv/dts/Makefile | 1 + arch/riscv/dts/openpiton-riscv64.dts | 153 ++++++++ board/openpiton/riscv64/Kconfig | 40 +++ board/openpiton/riscv64/MAINTAINERS | 8 + board/openpiton/riscv64/Makefile | 5 + board/openpiton/riscv64/openpiton-riscv64.c | 33 ++ configs/openpiton_riscv64_defconfig | 76 ++++ configs/openpiton_riscv64_spl_defconfig | 87 +++++ doc/board/index.rst | 1 + doc/board/openpiton/index.rst | 9 + doc/board/openpiton/riscv64.rst | 376 ++++++++++++++++++++ drivers/mmc/Kconfig | 9 + drivers/mmc/Makefile | 1 + drivers/mmc/piton_mmc.c | 181 ++++++++++ include/configs/openpiton-riscv64.h | 61 ++++ 16 files changed, 1045 insertions(+) create mode 100644 arch/riscv/dts/openpiton-riscv64.dts create mode 100644 board/openpiton/riscv64/Kconfig create mode 100644 board/openpiton/riscv64/MAINTAINERS create mode 100644 board/openpiton/riscv64/Makefile create mode 100644 board/openpiton/riscv64/openpiton-riscv64.c create mode 100644 configs/openpiton_riscv64_defconfig create mode 100644 configs/openpiton_riscv64_spl_defconfig create mode 100644 doc/board/openpiton/index.rst create mode 100644 doc/board/openpiton/riscv64.rst create mode 100644 drivers/mmc/piton_mmc.c create mode 100644 include/configs/openpiton-riscv64.h
Tianrui Wei
