[PATCH v3] ARM: dts: imxrt1050: Migrate to OF_UPSTREAM
The device tree for imxrt1050 is now available in the /dts/upstream directory. Migrate board to use OF_UPSTREAM.
Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1 -> V2: - No change V2 -> V3: - Remove imxrt1050-evk.dtb from Makefile --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/imxrt1050-evk.dts | 72 -- arch/arm/dts/imxrt1050-pinfunc.h | 993 --------------------------- arch/arm/dts/imxrt1050.dtsi | 160 ----- configs/imxrt1050-evk_defconfig | 3 +- configs/imxrt1050-evk_fspi_defconfig | 3 +- 6 files changed, 5 insertions(+), 1229 deletions(-) delete mode 100644 arch/arm/dts/imxrt1050-evk.dts delete mode 100644 arch/arm/dts/imxrt1050-pinfunc.h delete mode 100644 arch/arm/dts/imxrt1050.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b7df72453ac..430cb4cf0ec 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -920,8 +920,7 @@ dtb-$(CONFIG_ARCH_IMX9) += \ imx93-var-som-symphony.dtb \ imx93-phyboard-segin.dtb
-dtb-$(CONFIG_ARCH_IMXRT) += imxrt1050-evk.dtb \ - imxrt1020-evk.dtb \ +dtb-$(CONFIG_ARCH_IMXRT) += imxrt1020-evk.dtb \ imxrt1170-evk.dtb \
dtb-$(CONFIG_RZA1) += \ diff --git a/arch/arm/dts/imxrt1050-evk.dts b/arch/arm/dts/imxrt1050-evk.dts deleted file mode 100644 index 6a9c10decf5..00000000000 --- a/arch/arm/dts/imxrt1050-evk.dts +++ /dev/null @@ -1,72 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (C) 2019 - * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com - */ - -/dts-v1/; -#include "imxrt1050.dtsi" -#include "imxrt1050-pinfunc.h" - -/ { - model = "NXP IMXRT1050-evk board"; - compatible = "fsl,imxrt1050-evk", "fsl,imxrt1050"; - - chosen { - stdout-path = &lpuart1; - }; - - aliases { - gpio0 = &gpio1; - gpio1 = &gpio2; - gpio2 = &gpio3; - gpio3 = &gpio4; - gpio4 = &gpio5; - mmc0 = &usdhc1; - serial0 = &lpuart1; - }; - - memory@80000000 { - device_type = "memory"; - reg = <0x80000000 0x2000000>; - }; -}; - -&lpuart1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_lpuart1>; - status = "okay"; -}; - -&iomuxc { - pinctrl-names = "default"; - pinctrl_lpuart1: lpuart1grp { - fsl,pins = < - MXRT1050_IOMUXC_GPIO_AD_B0_12_LPUART1_TXD 0xf1 - MXRT1050_IOMUXC_GPIO_AD_B0_13_LPUART1_RXD 0xf1 - >; - }; - - pinctrl_usdhc0: usdhc0grp { - fsl,pins = < - MXRT1050_IOMUXC_GPIO_B1_12_USDHC1_CD_B 0x1B000 - MXRT1050_IOMUXC_GPIO_B1_14_USDHC1_VSELECT 0xB069 - MXRT1050_IOMUXC_GPIO_SD_B0_00_USDHC1_CMD 0x17061 - MXRT1050_IOMUXC_GPIO_SD_B0_01_USDHC1_CLK 0x17061 - MXRT1050_IOMUXC_GPIO_SD_B0_05_USDHC1_DATA3 0x17061 - MXRT1050_IOMUXC_GPIO_SD_B0_04_USDHC1_DATA2 0x17061 - MXRT1050_IOMUXC_GPIO_SD_B0_03_USDHC1_DATA1 0x17061 - MXRT1050_IOMUXC_GPIO_SD_B0_02_USDHC1_DATA0 0x17061 - >; - }; -}; - -&usdhc1 { - pinctrl-names = "default", "state_100mhz", "state_200mhz", "sleep"; - pinctrl-0 = <&pinctrl_usdhc0>; - pinctrl-1 = <&pinctrl_usdhc0>; - pinctrl-2 = <&pinctrl_usdhc0>; - pinctrl-3 = <&pinctrl_usdhc0>; - cd-gpios = <&gpio2 28 GPIO_ACTIVE_LOW>; - status = "okay"; -}; diff --git a/arch/arm/dts/imxrt1050-pinfunc.h b/arch/arm/dts/imxrt1050-pinfunc.h deleted file mode 100644 index 22c14a3262a..00000000000 --- a/arch/arm/dts/imxrt1050-pinfunc.h +++ /dev/null @@ -1,993 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright (C) 2019 - * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com - */ - -#ifndef _DT_BINDINGS_PINCTRL_IMXRT1050_PINFUNC_H -#define _DT_BINDINGS_PINCTRL_IMXRT1050_PINFUNC_H - -#define IMX_PAD_SION 0x40000000 - -/* - * The pin function ID is a tuple of - * <mux_reg conf_reg input_reg mux_mode input_val> - */ - -#define MXRT1050_IOMUXC_GPIO_EMC_00_SEMC_DA00 0x014 0x204 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_00_FLEXPWM4_PWM0_A 0x014 0x204 0x494 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_00_LPSPI2_SCK 0x014 0x204 0x500 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_00_XBAR_INOUT2 0x014 0x204 0x60C 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_00_FLEXIO1_D00 0x014 0x204 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_00_GPIO4_IO00 0x014 0x204 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_01_SEMC_DA01 0x018 0x208 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_01_FLEXPWM4_PWM0_B 0x018 0x208 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_01_LPSPI2_PCS0 0x018 0x208 0x4FC 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_01_XBAR_INOUT3 0x018 0x208 0x610 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_01_FLEXIO1_D01 0x018 0x208 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_01_GPIO4_IO01 0x018 0x208 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_02_SEMC_DA02 0x01C 0x20C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_02_FLEXPWM4_PWM1_A 0x01C 0x20C 0x498 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_02_LPSPI2_SDO 0x01C 0x20C 0x508 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_02_XBAR_INOUT4 0x01C 0x20C 0x614 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_02_FLEXIO1_D02 0x01C 0x20C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_02_GPIO4_IO02 0x01C 0x20C 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_03_SEMC_DA03 0x020 0x210 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_03_FLEXPWM4_PWM1_B 0x020 0x210 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_03_LPSPI2_SDI 0x020 0x210 0x504 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_03_XBAR_INOUT5 0x020 0x210 0x618 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_03_FLEXIO1_D03 0x020 0x210 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_03_GPIO4_IO03 0x020 0x210 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_04_SEMC_DA04 0x024 0x214 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_04_FLEXPWM4_PWM2_A 0x024 0x214 0x49C 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_04_SAI2_TX_DATA 0x024 0x214 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_04_XBAR_INOUT6 0x024 0x214 0x61C 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_04_FLEXIO1_D04 0x024 0x214 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_04_GPIO4_IO04 0x024 0x214 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_05_SEMC_DA05 0x028 0x218 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_05_FLEXPWM4_PWM2_B 0x028 0x218 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_05_SAI2_TX_SYNC 0x028 0x218 0x5C4 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_05_XBAR_INOUT7 0x028 0x218 0x620 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_05_FLEXIO1_D05 0x028 0x218 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_05_GPIO4_IO05 0x028 0x218 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_06_SEMC_DA06 0x02C 0x21C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_06_FLEXPWM2_PWM0_A 0x02C 0x21C 0x478 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_06_SAI2_TX_BCLK 0x02C 0x21C 0x5C0 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_06_XBAR_INOUT8 0x02C 0x21C 0x624 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_06_FLEXIO1_D06 0x02C 0x21C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_06_GPIO4_IO06 0x02C 0x21C 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_07_SEMC_DA07 0x030 0x220 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_07_FLEXPWM2_PWM0_B 0x030 0x220 0x488 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_07_SAI2_MCLK 0x030 0x220 0x5B0 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_07_XBAR_INOUT9 0x030 0x220 0x628 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_07_FLEXIO1_D07 0x030 0x220 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_07_GPIO4_IO07 0x030 0x220 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_08_SEMC_DM00 0x034 0x224 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_08_FLEXPWM2_PWM1_A 0x034 0x224 0x47C 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_08_SAI2_RX_DATA 0x034 0x224 0x5B8 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_08_XBAR_INOUT17 0x034 0x224 0x62C 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_08_FLEXIO1_D08 0x034 0x224 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_08_GPIO4_IO08 0x034 0x224 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_09_SEMC_ADDR00 0x038 0x228 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_09_FLEXPWM2_PWM1_B 0x038 0x228 0x48C 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_09_SAI2_RX_SYNC 0x038 0x228 0x5BC 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_09_FLEXCAN2_TX 0x038 0x228 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_09_FLEXIO1_D09 0x038 0x228 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_09_GPIO4_IO09 0x038 0x228 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_10_SEMC_ADDR01 0x03C 0x22C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_10_FLEXPWM2_PWM2_A 0x03C 0x22C 0x480 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_10_SAI2_RX_BCLK 0x03C 0x22C 0x5B4 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_10_FLEXCAN2_RX 0x03C 0x22C 0x450 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_10_FLEXIO1_D10 0x03C 0x22C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_10_GPIO4_IO10 0x03C 0x22C 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_11_SEMC_ADDR02 0x040 0x230 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_11_FLEXPWM2_PWM2_B 0x040 0x230 0x490 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_11_LPI2C4_SDA 0x040 0x230 0x4E8 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_11_USDHC2_RESET_B 0x040 0x230 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_11_FLEXIO1_D11 0x040 0x230 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_11_GPIO4_IO11 0x040 0x230 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_12_SEMC_ADDR03 0x044 0x234 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_12_XBAR_INOUT24 0x044 0x234 0x640 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_12_LPI2C4_SCL 0x044 0x234 0x4E4 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_12_USDHC2_WP 0x044 0x234 0x5D8 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_12_FLEXPWM1_PWM3_A 0x044 0x234 0x454 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_12_GPIO4_IO12 0x044 0x234 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_13_SEMC_ADDR04 0x048 0x238 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_13_XBAR_INOUT25 0x048 0x238 0x650 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_13_LPUART3_TXD 0x048 0x238 0x53C 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_13_MQS_RIGHT 0x048 0x238 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_13_FLEXPWM1_PWM3_B 0x048 0x238 0x464 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_13_GPIO4_IO13 0x048 0x238 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_14_SEMC_ADDR05 0x04C 0x23C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_14_XBAR_INOUT19 0x04C 0x23C 0x654 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_14_LPUART3_RXD 0x04C 0x23C 0x538 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_14_MQS_LEFT 0x04C 0x23C 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_14_LPSPI2_PCS1 0x04C 0x23C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_14_GPIO4_IO14 0x04C 0x23C 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_15_SEMC_ADDR06 0x050 0x240 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_15_XBAR_INOUT20 0x050 0x240 0x634 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_15_LPUART3_CTS_B 0x050 0x240 0x534 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_15_SPDIF_OUT 0x050 0x240 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_15_TMR3_TIMER0 0x050 0x240 0x57C 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_15_GPIO4_IO15 0x050 0x240 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_16_SEMC_ADDR07 0x054 0x244 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_16_XBAR_INOUT21 0x054 0x244 0x658 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_16_LPUART3_RTS_B 0x054 0x244 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_16_SPDIF_IN 0x054 0x244 0x5C8 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_16_TMR3_TIMER1 0x054 0x244 0x580 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_16_GPIO4_IO16 0x054 0x244 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_17_SEMC_ADDR08 0x058 0x248 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_17_FLEXPWM4_PWM3_A 0x058 0x248 0x4A0 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_17_LPUART4_CTS_B 0x058 0x248 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_17_FLEXCAN1_TX 0x058 0x248 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_17_TMR3_TIMER2 0x058 0x248 0x584 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_17_GPIO4_IO17 0x058 0x248 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_18_SEMC_ADDR09 0x05C 0x24C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_18_FLEXPWM4_PWM3_B 0x05C 0x24C 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_18_LPUART4_RTS_B 0x05C 0x24C 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_18_FLEXCAN1_RX 0x05C 0x24C 0x44C 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_18_TMR3_TIMER3 0x05C 0x24C 0x588 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_18_GPIO4_IO18 0x05C 0x24C 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_18_SNVS_VIO_5_CTL 0x05C 0x24C 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_19_SEMC_ADDR11 0x060 0x250 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_19_FLEXPWM2_PWM3_A 0x060 0x250 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_19_LPUART4_TXD 0x060 0x250 0x544 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_19_ENET_RX_DATA01 0x060 0x250 0x438 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_19_TMR2_TIMER0 0x060 0x250 0x56C 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_19_GPIO4_IO19 0x060 0x250 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_19_SNVS_VIO_5 0x060 0x250 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_20_SEMC_ADDR12 0x064 0x254 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_20_FLEXPWM2_PWM3_B 0x064 0x254 0x484 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_20_LPUART4_RXD 0x064 0x254 0x540 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_20_ENET_RX_DATA00 0x064 0x254 0x434 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_20_TMR2_TIMER0 0x064 0x254 0x570 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_20_GPIO4_IO20 0x064 0x254 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_21_SEMC_BA0 0x068 0x258 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_21_FLEXPWM3_PWM3_A 0x068 0x258 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_21_LPI2C3_SDA 0x068 0x258 0x4E0 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_21_ENET_TX_DATA01 0x068 0x258 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_21_TMR2_TIMER2 0x068 0x258 0x574 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_21_GPIO4_IO21 0x068 0x258 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_22_SEMC_BA1 0x06C 0x25C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_22_FLEXPWM3_PWM3_B 0x06C 0x25C 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_22_LPI2C3_SCL 0x06C 0x25C 0x4DC 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_22_ENET_TX_DATA00 0x06C 0x25C 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_22_TMR2_TIMER3 0x06C 0x25C 0x578 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_22_GPIO4_IO22 0x06C 0x25C 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_23_SEMC_ADDR10 0x070 0x260 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_23_FLEXPWM1_PWM0_A 0x070 0x260 0x458 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_23_LPUART5_TXD 0x070 0x260 0x54C 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_23_ENET_RX_EN 0x070 0x260 0x43C 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_23_GPT1_CAPTURE2 0x070 0x260 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_23_GPIO4_IO23 0x070 0x260 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_24_SEMC_CAS 0x074 0x264 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_24_FLEXPWM1_PWM0_B 0x074 0x264 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_24_LPUART5_RXD 0x074 0x264 0x548 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_24_ENET_TX_EN 0x074 0x264 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_24_GPT1_CAPTURE1 0x074 0x264 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_24_GPIO4_IO24 0x074 0x264 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_25_SEMC_RAS 0x078 0x268 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_25_FLEXPWM1_PWM1_A 0x078 0x268 0x45C 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_25_LPUART6_TXD 0x078 0x268 0x554 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_25_ENET_TX_CLK 0x078 0x268 0x448 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_25_ENET_REF_CLK 0x078 0x268 0x42C 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_25_GPIO4_IO25 0x078 0x268 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_26_SEMC_CLK 0x07C 0x26C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_26_FLEXPWM1_PWM1_B 0x07C 0x26C 0x46C 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_26_LPUART6_RXD 0x07C 0x26C 0x550 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_26_ENET_RX_ER 0x07C 0x26C 0x440 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_26_FLEXIO1_D12 0x07C 0x26C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_26_GPIO4_IO26 0x07C 0x26C 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_27_SEMC_CKE 0x080 0x270 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_27_FLEXPWM1_PWM2_A 0x080 0x270 0x460 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_27_LPUART5_RTS_B 0x080 0x270 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_27_LPSPI1_SCK 0x080 0x270 0x4F0 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_27_FLEXIO1_D13 0x080 0x270 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_27_GPIO4_IO27 0x080 0x270 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_28_SEMC_WE 0x084 0x274 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_28_FLEXPWM1_PWM2_B 0x084 0x274 0x470 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_28_LPUART5_CTS_B 0x084 0x274 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_28_LPSPI1_SDO 0x084 0x274 0x4F8 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_28_FLEXIO1_D14 0x084 0x274 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_28_GPIO4_IO28 0x084 0x274 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_29_SEMC_CS0 0x088 0x278 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_29_FLEXPWM3_PWM0_A 0x088 0x278 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_29_LPUART6_RTS_B 0x088 0x278 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_29_LPSPI1_SDI 0x088 0x278 0x4F4 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_29_FLEXIO1_D15 0x088 0x278 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_29_GPIO4_IO29 0x088 0x278 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_30_SEMC_DA08 0x08C 0x27C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_30_FLEXPWM3_PWM0_B 0x08C 0x27C 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_30_LPUART6_CTS_B 0x08C 0x27C 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_30_LPSPI1_PCS0 0x08C 0x27C 0x4EC 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_30_CSI_DATA23 0x08C 0x27C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_30_GPIO4_IO30 0x08C 0x27C 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_31_SEMC_DA09 0x090 0x280 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_31_FLEXPWM3_PWM1_A 0x090 0x280 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_31_LPUART7_TXD 0x090 0x280 0x55C 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_31_LPSPI1_PCS1 0x090 0x280 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_31_CSI_DATA22 0x090 0x280 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_31_GPIO4_IO31 0x090 0x280 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_32_SEMC_DA10 0x094 0x284 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_32_FLEXPWM3_PWM1_B 0x094 0x284 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_32_LPUART7_RXD 0x094 0x284 0x558 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_32_CCM_PMIC_READY 0x094 0x284 0x3FC 0x3 0x4 -#define MXRT1050_IOMUXC_GPIO_EMC_32_CSI_DATA21 0x094 0x284 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_32_GPIO3_IO18 0x094 0x284 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_33_SEMC_DA11 0x098 0x288 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_33_FLEXPWM3_PWM2_A 0x098 0x288 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_33_USDHC1_RESET_B 0x098 0x288 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_33_SAI3_RX_DATA 0x098 0x288 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_33_CSI_DATA20 0x098 0x288 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_33_GPIO3_IO19 0x098 0x288 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_34_SEMC_DA12 0x09C 0x28C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_34_FLEXPWM3_PWM2_B 0x09C 0x28C 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_34_USDHC1_VSELECT 0x09C 0x28C 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_34_SAI3_RX_SYNC 0x09C 0x28C 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_34_CSI_DATA19 0x09C 0x28C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_34_GPIO3_IO20 0x09C 0x28C 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_35_SEMC_DA13 0x0A0 0x290 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_35_XBAR_INOUT18 0x0A0 0x290 0x630 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_35_GPT1_COMPARE1 0x0A0 0x290 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_35_SAI3_RX_BCLK 0x0A0 0x290 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_35_CSI_DATA18 0x0A0 0x290 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_35_GPIO3_IO21 0x0A0 0x290 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_35_USDHC1_CD_B 0x0A0 0x290 0x5D4 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_36_SEMC_DA14 0x0A4 0x294 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_36_XBAR_INOUT22 0x0A4 0x294 0x638 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_36_GPT1_COMPARE2 0x0A4 0x294 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_36_SAI3_TX_DATA 0x0A4 0x294 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_36_CSI_DATA17 0x0A4 0x294 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_36_GPIO3_IO22 0x0A4 0x294 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_36_USDHC1_WP 0x0A4 0x294 0x5D8 0x6 0x1 - -#define MXRT1050_IOMUXC_GPIO_EMC_37_SEMC_DA15 0x0A8 0x298 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_37_XBAR_INOUT23 0x0A8 0x298 0x63C 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_37_GPT1_COMPARE3 0x0A8 0x298 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_37_SAI3_MCLK 0x0A8 0x298 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_37_CSI_DATA16 0x0A8 0x298 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_37_GPIO3_IO23 0x0A8 0x298 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_37_USDHC2_WP 0x0A8 0x298 0x608 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_38_SEMC_DM01 0x0AC 0x29C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_38_FLEXPWM1_PWM3_A 0x0AC 0x29C 0x454 0x1 0x2 -#define MXRT1050_IOMUXC_GPIO_EMC_38_LPUART8_TXD 0x0AC 0x29C 0x564 0x2 0x2 -#define MXRT1050_IOMUXC_GPIO_EMC_38_SAI3_TX_BCLK 0x0AC 0x29C 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_38_CSI_FIELD 0x0AC 0x29C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_38_GPIO3_IO24 0x0AC 0x29C 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_38_USDHC2_VSELECT 0x0AC 0x29C 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_39_SEMC_DQS 0x0B0 0x2A0 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_39_FLEXPWM1_PWM3_B 0x0B0 0x2A0 0x464 0x1 0x2 -#define MXRT1050_IOMUXC_GPIO_EMC_39_LPUART8_RXD 0x0B0 0x2A0 0x560 0x2 0x2 -#define MXRT1050_IOMUXC_GPIO_EMC_39_SAI3_TX_SYNC 0x0B0 0x2A0 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_39_WDOG1_B 0x0B0 0x2A0 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_39_GPIO3_IO25 0x0B0 0x2A0 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_39_USDHC2_CD_B 0x0B0 0x2A0 0x5E0 0x6 0x1 - -#define MXRT1050_IOMUXC_GPIO_EMC_40_SEMC_RDY 0x0B4 0x2A4 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_40_GPT2_CAPTURE2 0x0B4 0x2A4 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_40_LPSPI1_PCS2 0x0B4 0x2A4 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_40_USB_OTG2_OC 0x0B4 0x2A4 0x5CC 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_40_ENET_MDC 0x0B4 0x2A4 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_40_GPIO3_IO26 0x0B4 0x2A4 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_40_USDHC2_RESET_B 0x0B4 0x2A4 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_EMC_41_SEMC_CSX0 0x0B8 0x2A8 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_41_GPT2_CAPTURE1 0x0B8 0x2A8 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_41_LPSPI1_PCS3 0x0B8 0x2A8 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_41_USB_OTG2_PWR 0x0B8 0x2A8 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_41_ENET_MDIO 0x0B8 0x2A8 0x430 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_EMC_41_GPIO3_IO27 0x0B8 0x2A8 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_EMC_41_USDHC2_VSELECT 0x0B8 0x2A8 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_00_FLEXPWM2_PWM3_A 0x0BC 0x2AC 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_00_XBAR_INOUT14 0x0BC 0x2AC 0x644 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_00_REF_CLK_32K 0x0BC 0x2AC 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_00_USB_OTG2_ID 0x0BC 0x2AC 0x3F8 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_00_LPI2C1_SCLS 0x0BC 0x2AC 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_00_GPIO1_IO00 0x0BC 0x2AC 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_00_USDHC1_RESET_B 0x0BC 0x2AC 0x000 0x6 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_00_LPSPI3_SCK 0x0BC 0x2AC 0x510 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_01_FLEXPWM2_PWM3_B 0x0C0 0x2B0 0x484 0x0 0x2 -#define MXRT1050_IOMUXC_GPIO_AD_B0_01_XBAR_INOUT15 0x0C0 0x2B0 0x648 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_01_REF_CLK_24M 0x0C0 0x2B0 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_01_USB_OTG1_ID 0x0C0 0x2B0 0x3F4 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_01_LPI2C1_SDAS 0x0C0 0x2B0 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_01_GPIO1_IO01 0x0C0 0x2B0 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_01_EWM_OUT_B 0x0C0 0x2B0 0x000 0x6 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_01_LPSPI3_SDO 0x0C0 0x2B0 0x518 0x7 0x1 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_02_FLEXCAN2_TX 0x0C4 0x2B4 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_02_XBAR_INOUT16 0x0C4 0x2B4 0x64C 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_02_LPUART6_TXD 0x0C4 0x2B4 0x554 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_02_USB_OTG1_PWR 0x0C4 0x2B4 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_02_FLEXPWM1_PWM0_X 0x0C4 0x2B4 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_02_GPIO1_IO02 0x0C4 0x2B4 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_02_LPI2C1_HREQ 0x0C4 0x2B4 0x000 0x6 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_02_LPSPI3_SDI 0x0C4 0x2B4 0x514 0x7 0x1 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_03_FLEXCAN2_RX 0x0C8 0x2B8 0x450 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_03_XBAR_INOUT17 0x0C8 0x2B8 0x62C 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_03_LPUART6_RXD 0x0C8 0x2B8 0x550 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_03_USB_OTG1_OC 0x0C8 0x2B8 0x5D0 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_03_FLEXPWM1_PWM1_X 0x0C8 0x2B8 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_03_GPIO1_IO03 0x0C8 0x2B8 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_03_REF_CLK_24M 0x0C8 0x2B8 0x000 0x6 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_03_LPSPI3_PCS0 0x0C8 0x2B8 0x50C 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_04_SRC_BOOT_MODE00 0x0CC 0x2BC 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_04_MQS_RIGHT 0x0CC 0x2BC 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_04_ENET_TX_DATA03 0x0CC 0x2BC 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_04_SAI2_TX_SYNC 0x0CC 0x2BC 0x5C4 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_04_CSI_DATA09 0x0CC 0x2BC 0x41C 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_04_GPIO1_IO04 0x0CC 0x2BC 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_04_PIT_TRIGGER00 0x0CC 0x2BC 0x000 0x6 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_04_LPSPI3_PCS1 0x0CC 0x2BC 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_05_SRC_BOOT_MODE01 0x0D0 0x2C0 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_05_MQS_LEFT 0x0D0 0x2C0 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_05_ENET_TX_DATA02 0x0D0 0x2C0 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_05_SAI2_TX_BCLK 0x0D0 0x2C0 0x5C0 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_05_CSI_DATA08 0x0D0 0x2C0 0x418 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_05_GPIO1_IO05 0x0D0 0x2C0 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_05_XBAR_INOUT17 0x0D0 0x2C0 0x62C 0x6 0x2 -#define MXRT1050_IOMUXC_GPIO_AD_B0_05_LPSPI3_PCS2 0x0D0 0x2C0 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_06_JTAG_TMS 0x0D4 0x2C4 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_06_GPT2_COMPARE1 0x0D4 0x2C4 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_06_ENET_RX_CLK 0x0D4 0x2C4 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_06_SAI2_RX_BCLK 0x0D4 0x2C4 0x5B4 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_06_CSI_DATA07 0x0D4 0x2C4 0x414 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_06_GPIO1_IO06 0x0D4 0x2C4 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_06_XBAR_INOUT18 0x0D4 0x2C4 0x630 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_06_LPSPI3_PCS3 0x0D4 0x2C4 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_07_JTAG_TCK 0x0D8 0x2C8 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_07_GPT2_COMPARE2 0x0D8 0x2C8 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_07_ENET_TX_ER 0x0D8 0x2C8 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_07_SAI2_RX_SYNC 0x0D8 0x2C8 0x5BC 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_07_CSI_DATA06 0x0D8 0x2C8 0x410 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_07_GPIO1_IO07 0x0D8 0x2C8 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_07_XBAR_INOUT19 0x0D8 0x2C8 0x654 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_07_ENET_1588_EVENT3_OUT 0x0D8 0x2C8 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_08_JTAG_MOD 0x0DC 0x2CC 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_08_GPT2_COMPARE3 0x0DC 0x2CC 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_08_ENET_RX_DATA03 0x0DC 0x2CC 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_08_SAI2_RX_DATA 0x0DC 0x2CC 0x5B8 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_08_CSI_DATA05 0x0DC 0x2CC 0x40C 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_08_GPIO1_IO08 0x0DC 0x2CC 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_08_XBAR_INOUT20 0x0DC 0x2CC 0x634 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_08_ENET_1588_EVENT3_IN 0x0DC 0x2CC 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_09_JTAG_TDI 0x0E0 0x2D0 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_09_FLEXPWM2_PWM3_A 0x0E0 0x2D0 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_09_ENET_RX_DATA02 0x0E0 0x2D0 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_09_SAI2_TX_DATA 0x0E0 0x2D0 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_09_CSI_DATA04 0x0E0 0x2D0 0x408 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_09_GPIO1_IO09 0x0E0 0x2D0 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_09_XBAR_INOUT21 0x0E0 0x2D0 0x658 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_09_GPT2_CLK 0x0E0 0x2D0 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_10_JTAG_TDO 0x0E4 0x2D4 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_10_FLEXPWM1_PWM3_A 0x0E4 0x2D4 0x454 0x1 0x3 -#define MXRT1050_IOMUXC_GPIO_AD_B0_10_ENET_CRS 0x0E4 0x2D4 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_10_SAI2_MCLK 0x0E4 0x2D4 0x5B0 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_10_CSI_DATA03 0x0E4 0x2D4 0x404 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_10_GPIO1_IO10 0x0E4 0x2D4 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_10_XBAR_INOUT22 0x0E4 0x2D4 0x638 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_10_ENET_1588_EVENT0_OUT 0x0E4 0x2D4 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_11_JTAG_TRSTB 0x0E8 0x2D8 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_11_FLEXPWM1_PWM3_B 0x0E8 0x2D8 0x464 0x1 0x3 -#define MXRT1050_IOMUXC_GPIO_AD_B0_11_ENET_COL 0x0E8 0x2D8 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_11_WDOG1_B 0x0E8 0x2D8 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_11_CSI_DATA02 0x0E8 0x2D8 0x400 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_11_GPIO1_IO11 0x0E8 0x2D8 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_11_XBAR_INOUT23 0x0E8 0x2D8 0x63C 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_11_ENET_1588_EVENT0_IN 0x0E8 0x2D8 0x444 0x7 0x1 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_12_LPI2C4_SCL 0x0EC 0x2DC 0x4E4 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_12_CCM_PMIC_READY 0x0EC 0x2DC 0x3FC 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_12_LPUART1_TXD 0x0EC 0x2DC 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_12_WDOG2_B 0x0EC 0x2DC 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_12_FLEXPWM1_PWM2_X 0x0EC 0x2DC 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_12_GPIO1_IO12 0x0EC 0x2DC 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_12_ENET_1588_EVENT1_OUT 0x0EC 0x2DC 0x000 0x6 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_12_NMI 0x0EC 0x2DC 0x568 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_13_LPI2C4_SDA 0x0F0 0x2E0 0x4E8 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_13_GPT1_CLK 0x0F0 0x2E0 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_13_LPUART1_RXD 0x0F0 0x2E0 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_13_EWM_OUT_B 0x0F0 0x2E0 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_13_FLEXPWM1_PWM3_X 0x0F0 0x2E0 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_13_GPIO1_IO13 0x0F0 0x2E0 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_13_ENET_1588_EVENT1_IN 0x0F0 0x2E0 0x000 0x6 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_13_REF_CLK_24M 0x0F0 0x2E0 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_14_USB_OTG2_OC 0x0F4 0x2E4 0x5CC 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_14_XBAR_INOUT24 0x0F4 0x2E4 0x640 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B0_14_LPUART1_CTS_B 0x0F4 0x2E4 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_14_ENET_1588_EVENT0_OUT 0x0F4 0x2E4 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_14_CSI_VSYNC 0x0F4 0x2E4 0x428 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_14_GPIO1_IO14 0x0F4 0x2E4 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_14_FLEXCAN2_TX 0x0F4 0x2E4 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B0_15_USB_OTG2_PWR 0x0F8 0x2E8 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_15_XBAR_INOUT25 0x0F8 0x2E8 0x650 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_15_LPUART1_RTS_B 0x0F8 0x2E8 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_15_ENET_1588_EVENT0_IN 0x0F8 0x2E8 0x444 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_15_CSI_HSYNC 0x0F8 0x2E8 0x420 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_15_GPIO1_IO15 0x0F8 0x2E8 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B0_15_FLEXCAN2_RX 0x0F8 0x2E8 0x450 0x6 0x2 -#define MXRT1050_IOMUXC_GPIO_AD_B0_15_WDOG1_WDOG_RST_B_DEB 0x0F8 0x2E8 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_00_USB_OTG2_ID 0x0FC 0x2EC 0x3F8 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_00_TMR3_TIMER0 0x0FC 0x2EC 0x57C 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_00_LPUART2_CTS_B 0x0FC 0x2EC 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_00_LPI2C1_SCL 0x0FC 0x2EC 0x4CC 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_00_WDOG1_B 0x0FC 0x2EC 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_00_GPIO1_IO16 0x0FC 0x2EC 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_00_USDHC1_WP 0x0FC 0x2EC 0x5D8 0x6 0x2 -#define MXRT1050_IOMUXC_GPIO_AD_B1_00_KPP_ROW07 0x0FC 0x2EC 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_01_USB_OTG1_PWR 0x100 0x2F0 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_01_TMR3_TIMER1 0x100 0x2F0 0x580 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_01_LPUART2_RTS_B 0x100 0x2F0 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_01_LPI2C1_SDA 0x100 0x2F0 0x4D0 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_01_CCM_PMIC_READY 0x100 0x2F0 0x3FC 0x4 0x2 -#define MXRT1050_IOMUXC_GPIO_AD_B1_01_GPIO1_IO17 0x100 0x2F0 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_01_USDHC1_VSELECT 0x100 0x2F0 0x000 0x6 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_01_KPP_COL07 0x100 0x2F0 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_02_USB_OTG1_ID 0x104 0x2F4 0x3F4 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_02_TMR3_TIMER2 0x104 0x2F4 0x584 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_02_LPUART2_TXD 0x104 0x2F4 0x530 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_02_SPDIF_OUT 0x104 0x2F4 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_02_ENET_1588_EVENT2_OUT 0x104 0x2F4 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_02_GPIO1_IO18 0x104 0x2F4 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_02_USDHC1_CD_B 0x104 0x2F4 0x5D4 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_02_KPP_ROW06 0x104 0x2F4 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_03_USB_OTG1_OC 0x108 0x2F8 0x5D0 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_03_TMR3_TIMER3 0x108 0x2F8 0x588 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_03_LPUART2_RXD 0x108 0x2F8 0x52C 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_03_SPDIF_IN 0x108 0x2F8 0x5C8 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_03_ENET_1588_EVENT2_IN 0x108 0x2F8 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_03_GPIO1_IO19 0x108 0x2F8 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_03_USDHC2_CD_B 0x108 0x2F8 0x5E0 0x6 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_03_KPP_COL06 0x108 0x2F8 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_04_FLEXSPI_B_DATA3 0x10C 0x2FC 0x4C4 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_04_ENET_MDC 0x10C 0x2FC 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_04_LPUART3_CTS_B 0x10C 0x2FC 0x534 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_04_SPDIF_SR_CLK 0x10C 0x2FC 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_04_CSI_PIXCLK 0x10C 0x2FC 0x424 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_04_GPIO1_IO20 0x10C 0x2FC 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_04_USDHC2_DATA0 0x10C 0x2FC 0x5E8 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_04_KPP_ROW05 0x10C 0x2FC 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_05_FLEXSPI_B_DATA2 0x110 0x300 0x4C0 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_05_ENET_MDIO 0x110 0x300 0x430 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_05_LPUART3_RTS_B 0x110 0x300 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_05_SPDIF_OUT 0x110 0x300 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_05_CSI_MCLK 0x110 0x300 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_05_GPIO1_IO21 0x110 0x300 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_05_USDHC2_DATA1 0x110 0x300 0x5EC 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_05_KPP_COL05 0x110 0x300 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_06_FLEXSPI_B_DATA1 0x114 0x304 0x4BC 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_06_LPI2C3_SDA 0x114 0x304 0x4E0 0x1 0x2 -#define MXRT1050_IOMUXC_GPIO_AD_B1_06_LPUART3_TXD 0x114 0x304 0x53C 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_06_SPDIF_LOCK 0x114 0x304 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_06_CSI_VSYNC 0x114 0x304 0x428 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_06_GPIO1_IO22 0x114 0x304 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_06_USDHC2_DATA2 0x114 0x304 0x5F0 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_06_KPP_ROW04 0x114 0x304 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_07_FLEXSPI_B_DATA0 0x118 0x308 0x4B8 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_07_LPI2C3_SCL 0x118 0x308 0x4DC 0x1 0x2 -#define MXRT1050_IOMUXC_GPIO_AD_B1_07_LPUART3_RXD 0x118 0x308 0x538 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_07_SPDIF_EXT_CLK 0x118 0x308 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_07_CSI_HSYNC 0x118 0x308 0x420 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_07_GPIO1_IO23 0x118 0x308 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_07_USDHC2_DATA3 0x118 0x308 0x5F4 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_07_KPP_COL04 0x118 0x308 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_08_FLEXSPI_A_SS1_B 0x11C 0x30C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_08_FLEXPWM4_PWM0_A 0x11C 0x30C 0x494 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_08_FLEXCAN1_TX 0x11C 0x30C 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_08_CCM_PMIC_READY 0x11C 0x30C 0x3FC 0x3 0x3 -#define MXRT1050_IOMUXC_GPIO_AD_B1_08_CSI_DATA09 0x11C 0x30C 0x41C 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_08_GPIO1_IO24 0x11C 0x30C 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_08_USDHC2_CMD 0x11C 0x30C 0x5E4 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_08_KPP_ROW03 0x11C 0x30C 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_09_FLEXSPI_A_DQS 0x120 0x310 0x4A4 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_09_FLEXPWM4_PWM1_A 0x120 0x310 0x498 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_09_FLEXCAN1_RX 0x120 0x310 0x44C 0x2 0x2 -#define MXRT1050_IOMUXC_GPIO_AD_B1_09_SAI1_MCLK 0x120 0x310 0x58C 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_09_CSI_DATA08 0x120 0x310 0x418 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_09_GPIO1_IO25 0x120 0x310 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_09_USDHC2_CLK 0x120 0x310 0x5DC 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_09_KPP_COL03 0x120 0x310 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_10_FLEXSPI_A_DATA3 0x124 0x314 0x4B4 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_10_WDOG1_B 0x124 0x314 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_10_LPUART8_TXD 0x124 0x314 0x564 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_10_SAI1_RX_SYNC 0x124 0x314 0x5A4 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_10_CSI_DATA07 0x124 0x314 0x414 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_10_GPIO1_IO26 0x124 0x314 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_10_USDHC2_WP 0x124 0x314 0x608 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_10_KPP_ROW02 0x124 0x314 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_11_FLEXSPI_A_DATA2 0x128 0x318 0x4B0 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_11_EWM_OUT_B 0x128 0x318 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_11_LPUART8_RXD 0x128 0x318 0x560 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_11_SAI1_RX_BCLK 0x128 0x318 0x590 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_11_CSI_DATA06 0x128 0x318 0x410 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_11_GPIO1_IO27 0x128 0x318 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_11_USDHC2_RESET_B 0x128 0x318 0x000 0x6 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_11_KPP_COL02 0x128 0x318 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_12_FLEXSPI_A_DATA1 0x12C 0x31C 0x4AC 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_12_ACMP1_OUT 0x12C 0x31C 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_12_LPSPI3_PCS0 0x12C 0x31C 0x50C 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_12_SAI1_RX_DATA00 0x12C 0x31C 0x594 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_12_CSI_DATA05 0x12C 0x31C 0x40C 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_12_GPIO1_IO28 0x12C 0x31C 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_12_USDHC2_DATA4 0x12C 0x31C 0x5F8 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_12_KPP_ROW01 0x12C 0x31C 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_13_FLEXSPI_A_DATA0 0x130 0x320 0x4A8 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_13_ACMP2_OUT 0x130 0x320 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_13_LPSPI3_SDI 0x130 0x320 0x514 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_13_SAI1_TX_DATA00 0x130 0x320 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_13_CSI_DATA04 0x130 0x320 0x408 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_13_GPIO1_IO29 0x130 0x320 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_13_USDHC2_DATA5 0x130 0x320 0x5FC 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_13_KPP_COL01 0x130 0x320 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_14_FLEXSPI_A_SCLK 0x134 0x324 0x4C8 0x0 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_14_ACMP3_OUT 0x134 0x324 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_14_LPSPI3_SDO 0x134 0x324 0x518 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_14_SAI1_TX_BCLK 0x134 0x324 0x5A8 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_14_CSI_DATA03 0x134 0x324 0x404 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_14_GPIO1_IO30 0x134 0x324 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_14_USDHC2_DATA6 0x134 0x324 0x600 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_14_KPP_ROW00 0x134 0x324 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_AD_B1_15_FLEXSPI_A_SS0_B 0x138 0x328 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_15_ACMP4_OUT 0x138 0x328 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_15_LPSPI3_SCK 0x138 0x328 0x510 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_15_SAI1_TX_SYNC 0x138 0x328 0x5AC 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_15_CSI_DATA02 0x138 0x328 0x400 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_15_GPIO1_IO31 0x138 0x328 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_AD_B1_15_USDHC2_DATA7 0x138 0x328 0x604 0x6 0x1 -#define MXRT1050_IOMUXC_GPIO_AD_B1_15_KPP_COL00 0x138 0x328 0x000 0x7 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_00_LCD_CLK 0x13C 0x32C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_00_TMR1_TIMER0 0x13C 0x32C 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_00_MQS_RIGHT 0x13C 0x32C 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_00_LPSPI4_PCS0 0x13C 0x32C 0x51C 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_00_FLEXIO2_D00 0x13C 0x32C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_00_GPIO2_IO00 0x13C 0x32C 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_00_SEMC_CSX1 0x13C 0x32C 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_01_LCD_ENABLE 0x140 0x330 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_01_TMR1_TIMER1 0x140 0x330 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_01_MQS_LEFT 0x140 0x330 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_01_LPSPI4_SDI 0x140 0x330 0x524 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_01_FLEXIO2_D01 0x140 0x330 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_01_GPIO2_IO01 0x140 0x330 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_01_SEMC_CSX2 0x140 0x330 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_02_LCD_HSYNC 0x144 0x334 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_02_TMR1_TIMER2 0x144 0x334 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_02_FLEXCAN1_TX 0x144 0x334 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_02_LPSPI4_SDO 0x144 0x334 0x528 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_02_FLEXIO2_D02 0x144 0x334 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_02_GPIO2_IO02 0x144 0x334 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_02_SEMC_CSX3 0x144 0x334 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_03_LCD_VSYNC 0x148 0x338 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_03_TMR2_TIMER0 0x148 0x338 0x56C 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B0_03_FLEXCAN1_RX 0x148 0x338 0x44C 0x2 0x3 -#define MXRT1050_IOMUXC_GPIO_B0_03_LPSPI4_SCK 0x148 0x338 0x520 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_03_FLEXIO2_D03 0x148 0x338 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_03_GPIO2_IO03 0x148 0x338 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_03_WDOG2_RESET_B_DEB 0x148 0x338 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_04_LCD_DATA00 0x14C 0x33C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_04_TMR2_TIMER1 0x14C 0x33C 0x570 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B0_04_LPI2C2_SCL 0x14C 0x33C 0x4D4 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_B0_04_ARM_TRACE00 0x14C 0x33C 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_04_FLEXIO2_D04 0x14C 0x33C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_04_GPIO2_IO04 0x14C 0x33C 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_04_SRC_BT_CFG00 0x14C 0x33C 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_05_LCD_DATA01 0x150 0x340 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_05_TMR2_TIMER2 0x150 0x340 0x574 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B0_05_LPI2C2_SDA 0x150 0x340 0x4D8 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_B0_05_ARM_TRACE01 0x150 0x340 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_05_FLEXIO2_D05 0x150 0x340 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_05_GPIO2_IO05 0x150 0x340 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_05_SRC_BT_CFG01 0x150 0x340 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_06_LCD_DATA02 0x154 0x344 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_06_TMR3_TIMER0 0x154 0x344 0x57C 0x1 0x2 -#define MXRT1050_IOMUXC_GPIO_B0_06_FLEXPWM2_PWM0_A 0x154 0x344 0x478 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_B0_06_ARM_TRACE02 0x154 0x344 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_06_FLEXIO2_D06 0x154 0x344 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_06_GPIO2_IO06 0x154 0x344 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_06_SRC_BT_CFG02 0x154 0x344 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_07_LCD_DATA03 0x158 0x348 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_07_TMR3_TIMER1 0x158 0x348 0x580 0x1 0x2 -#define MXRT1050_IOMUXC_GPIO_B0_07_FLEXPWM2_PWM0_B 0x158 0x348 0x488 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_B0_07_ARM_TRACE03 0x158 0x348 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_07_FLEXIO2_D07 0x158 0x348 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_07_GPIO2_IO07 0x158 0x348 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_07_SRC_BT_CFG03 0x158 0x348 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_08_LCD_DATA04 0x15C 0x34C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_08_TMR3_TIMER2 0x15C 0x34C 0x584 0x1 0x2 -#define MXRT1050_IOMUXC_GPIO_B0_08_FLEXPWM2_PWM1_A 0x15C 0x34C 0x47C 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_B0_08_LPUART3_TXD 0x15C 0x34C 0x53C 0x3 0x2 -#define MXRT1050_IOMUXC_GPIO_B0_08_FLEXIO2_D08 0x15C 0x34C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_08_GPIO2_IO08 0x15C 0x34C 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_08_SRC_BT_CFG04 0x15C 0x34C 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_09_LCD_DATA05 0x160 0x350 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_09_TMR4_TIMER0 0x160 0x350 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_09_FLEXPWM2_PWM1_B 0x160 0x350 0x48C 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_B0_09_LPUART3_RXD 0x160 0x350 0x538 0x3 0x2 -#define MXRT1050_IOMUXC_GPIO_B0_09_FLEXIO2_D09 0x160 0x350 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_09_GPIO2_IO09 0x160 0x350 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_09_SRC_BT_CFG05 0x160 0x350 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_10_LCD_DATA06 0x164 0x354 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_10_TMR4_TIMER1 0x164 0x354 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_10_FLEXPWM2_PWM2_A 0x164 0x354 0x480 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_B0_10_SAI1_TX_DATA03 0x164 0x354 0x598 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_B0_10_FLEXIO2_D10 0x164 0x354 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_10_GPIO2_IO10 0x164 0x354 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_10_SRC_BT_CFG06 0x164 0x354 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_11_LCD_DATA07 0x168 0x358 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_11_TMR4_TIMER2 0x168 0x358 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_11_FLEXPWM2_PWM2_B 0x168 0x358 0x490 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_B0_11_SAI1_TX_DATA02 0x168 0x358 0x59C 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_B0_11_FLEXIO2_D11 0x168 0x358 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_11_GPIO2_IO11 0x168 0x358 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_11_SRC_BT_CFG07 0x168 0x358 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_12_LCD_DATA08 0x16C 0x35C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_12_XBAR_INOUT10 0x16C 0x35C 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_12_ARM_TRACE_CLK 0x16C 0x35C 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_12_SAI1_TX_DATA01 0x16C 0x35C 0x5A0 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_B0_12_FLEXIO2_D12 0x16C 0x35C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_12_GPIO2_IO12 0x16C 0x35C 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_12_SRC_BT_CFG08 0x16C 0x35C 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_13_LCD_DATA09 0x170 0x360 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_13_XBAR_INOUT11 0x170 0x360 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_13_ARM_TRACE_SWO 0x170 0x360 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_13_SAI1_MCLK 0x170 0x360 0x58C 0x3 0x2 -#define MXRT1050_IOMUXC_GPIO_B0_13_FLEXIO2_D13 0x170 0x360 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_13_GPIO2_IO13 0x170 0x360 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_13_SRC_BT_CFG09 0x170 0x360 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_14_LCD_DATA10 0x174 0x364 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_14_XBAR_INOUT12 0x174 0x364 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_14_ARM_CM7_TXEV 0x174 0x364 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_14_SAI1_RX_SYNC 0x174 0x364 0x5A4 0x3 0x2 -#define MXRT1050_IOMUXC_GPIO_B0_14_FLEXIO2_D14 0x174 0x364 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_14_GPIO2_IO14 0x174 0x364 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_14_SRC_BT_CFG10 0x174 0x364 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B0_15_LCD_DATA11 0x178 0x368 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_15_XBAR_INOUT13 0x178 0x368 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_15_ARM_CM7_RXEV 0x178 0x368 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_15_SAI1_RX_BCLK 0x178 0x368 0x590 0x3 0x2 -#define MXRT1050_IOMUXC_GPIO_B0_15_FLEXIO2_D15 0x178 0x368 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_15_GPIO2_IO15 0x178 0x368 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B0_15_SRC_BT_CFG11 0x178 0x368 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B1_00_LCD_DATA12 0x17C 0x36C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_00_XBAR_INOUT14 0x17C 0x36C 0x644 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_00_LPUART4_TXD 0x17C 0x36C 0x544 0x2 0x2 -#define MXRT1050_IOMUXC_GPIO_B1_00_SAI1_RX_DATA00 0x17C 0x36C 0x594 0x3 0x2 -#define MXRT1050_IOMUXC_GPIO_B1_00_FLEXIO2_D16 0x17C 0x36C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_00_GPIO2_IO16 0x17C 0x36C 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_00_FLEXPWM1_PWM3_A 0x17C 0x36C 0x454 0x6 0x4 - -#define MXRT1050_IOMUXC_GPIO_B1_01_LCD_DATA13 0x180 0x370 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_01_XBAR_INOUT15 0x180 0x370 0x648 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_01_LPUART4_RXD 0x180 0x370 0x540 0x2 0x2 -#define MXRT1050_IOMUXC_GPIO_B1_01_SAI1_TX_DATA00 0x180 0x370 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_01_FLEXIO2_D17 0x180 0x370 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_01_GPIO2_IO17 0x180 0x370 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_01_FLEXPWM1_PWM3_B 0x180 0x370 0x464 0x6 0x4 - -#define MXRT1050_IOMUXC_GPIO_B1_02_LCD_DATA14 0x184 0x374 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_02_XBAR_INOUT16 0x184 0x374 0x64C 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_02_LPSPI4_PCS2 0x184 0x374 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_02_SAI1_TX_BCLK 0x184 0x374 0x5A8 0x3 0x2 -#define MXRT1050_IOMUXC_GPIO_B1_02_FLEXIO2_D18 0x184 0x374 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_02_GPIO2_IO18 0x184 0x374 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_02_FLEXPWM2_PWM3_A 0x184 0x374 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B1_03_LCD_DATA15 0x188 0x378 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_03_XBAR_INOUT17 0x188 0x378 0x62C 0x1 0x3 -#define MXRT1050_IOMUXC_GPIO_B1_03_LPSPI4_PCS1 0x188 0x378 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_03_SAI1_TX_SYNC 0x188 0x378 0x5AC 0x3 0x2 -#define MXRT1050_IOMUXC_GPIO_B1_03_FLEXIO2_D19 0x188 0x378 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_03_GPIO2_IO19 0x188 0x378 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_03_FLEXPWM2_PWM3_B 0x188 0x378 0x484 0x6 0x3 - -#define MXRT1050_IOMUXC_GPIO_B1_04_LCD_DATA16 0x18C 0x37C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_04_LPSPI4_PCS0 0x18C 0x37C 0x51C 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_04_CSI_DATA15 0x18C 0x37C 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_04_ENET_RX_DATA00 0x18C 0x37C 0x434 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_04_FLEXIO2_D20 0x18C 0x37C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_04_GPIO2_IO20 0x18C 0x37C 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_B1_05_LCD_DATA17 0x190 0x380 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_05_LPSPI4_SDI 0x190 0x380 0x524 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_05_CSI_DATA14 0x190 0x380 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_05_ENET_RX_DATA01 0x190 0x380 0x438 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_05_FLEXIO2_D21 0x190 0x380 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_05_GPIO2_IO21 0x190 0x380 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_B1_06_LCD_DATA18 0x194 0x384 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_06_LPSPI4_SDO 0x194 0x384 0x528 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_06_CSI_DATA13 0x194 0x384 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_06_ENET_RX_EN 0x194 0x384 0x43C 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_06_FLEXIO2_D22 0x194 0x384 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_06_GPIO2_IO22 0x194 0x384 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_B1_07_LCD_DATA19 0x198 0x388 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_07_LPSPI4_SCK 0x198 0x388 0x520 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_07_CSI_DATA12 0x198 0x388 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_07_ENET_TX_DATA00 0x198 0x388 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_07_FLEXIO2_D23 0x198 0x388 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_07_GPIO2_IO23 0x198 0x388 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_B1_08_LCD_DATA20 0x19C 0x38C 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_08_TMR1_TIMER3 0x19C 0x38C 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_08_CSI_DATA11 0x19C 0x38C 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_08_ENET_TX_DATA01 0x19C 0x38C 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_08_FLEXIO2_D24 0x19C 0x38C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_08_GPIO2_IO24 0x19C 0x38C 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_08_FLEXCAN2_TX 0x19C 0x38C 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B1_09_LCD_DATA21 0x1A0 0x390 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_09_TMR2_TIMER3 0x1A0 0x390 0x578 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_09_CSI_DATA10 0x1A0 0x390 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_09_ENET_TX_EN 0x1A0 0x390 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_09_FLEXIO2_D25 0x1A0 0x390 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_09_GPIO2_IO25 0x1A0 0x390 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_09_FLEXCAN2_RX 0x1A0 0x390 0x450 0x6 0x3 - -#define MXRT1050_IOMUXC_GPIO_B1_10_LCD_DATA22 0x1A4 0x394 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_10_TMR3_TIMER3 0x1A4 0x394 0x588 0x1 0x2 -#define MXRT1050_IOMUXC_GPIO_B1_10_CSI_DATA00 0x1A4 0x394 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_10_ENET_TX_CLK 0x1A4 0x394 0x448 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_10_FLEXIO2_D26 0x1A4 0x394 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_10_GPIO2_IO26 0x1A4 0x394 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_10_ENET_REF_CLK 0x1A4 0x394 0x42C 0x6 0x1 - -#define MXRT1050_IOMUXC_GPIO_B1_11_LCD_DATA23 0x1A8 0x398 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_11_TMR4_TIMER3 0x1A8 0x398 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_11_CSI_DATA01 0x1A8 0x398 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_11_ENET_RX_ER 0x1A8 0x398 0x440 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_11_FLEXIO2_D27 0x1A8 0x398 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_11_GPIO2_IO27 0x1A8 0x398 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_11_LPSPI4_PCS3 0x1A8 0x398 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B1_12_LPUART5_TXD 0x1AC 0x39C 0x54C 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_12_CSI_PIXCLK 0x1AC 0x39C 0x424 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_12_ENET_1588_EVENT0_IN 0x1AC 0x39C 0x444 0x3 0x2 -#define MXRT1050_IOMUXC_GPIO_B1_12_FLEXIO2_D28 0x1AC 0x39C 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_12_GPIO2_IO28 0x1AC 0x39C 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_12_USDHC1_CD_B 0x1AC 0x39C 0x5D4 0x6 0x2 - -#define MXRT1050_IOMUXC_GPIO_B1_13_WDOG1_B 0x1B0 0x3A0 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_13_LPUART5_RXD 0x1B0 0x3A0 0x548 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_13_CSI_VSYNC 0x1B0 0x3A0 0x428 0x2 0x2 -#define MXRT1050_IOMUXC_GPIO_B1_13_ENET_1588_EVENT0_OUT 0x1B0 0x3A0 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_13_FLEXIO2_D29 0x1B0 0x3A0 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_13_GPIO2_IO29 0x1B0 0x3A0 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_13_USDHC1_WP 0x1B0 0x3A0 0x5D8 0x6 0x3 - -#define MXRT1050_IOMUXC_GPIO_B1_14_ENET_MDC 0x1B4 0x3A4 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_14_FLEXPWM4_PWM2_A 0x1B4 0x3A4 0x49C 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_14_CSI_HSYNC 0x1B4 0x3A4 0x420 0x2 0x2 -#define MXRT1050_IOMUXC_GPIO_B1_14_XBAR_INOUT02 0x1B4 0x3A4 0x60C 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_14_FLEXIO2_D30 0x1B4 0x3A4 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_14_GPIO2_IO30 0x1B4 0x3A4 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_14_USDHC1_VSELECT 0x1B4 0x3A4 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_B1_15_ENET_MDIO 0x1B8 0x3A8 0x430 0x0 0x2 -#define MXRT1050_IOMUXC_GPIO_B1_15_FLEXPWM4_PWM3_A 0x1B8 0x3A8 0x4A0 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_15_CSI_MCLK 0x1B8 0x3A8 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_15_XBAR_INOUT03 0x1B8 0x3A8 0x610 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_B1_15_FLEXIO2_D31 0x1B8 0x3A8 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_15_GPIO2_IO31 0x1B8 0x3A8 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_B1_15_USDHC1_RESET_B 0x1B8 0x3A8 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B0_00_USDHC1_CMD 0x1BC 0x3AC 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_00_FLEXPWM1_PWM0_A 0x1BC 0x3AC 0x458 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_00_LPI2C3_SCL 0x1BC 0x3AC 0x4DC 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_00_XBAR_INOUT04 0x1BC 0x3AC 0x614 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_00_LPSPI1_SCK 0x1BC 0x3AC 0x4F0 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_00_GPIO3_IO12 0x1BC 0x3AC 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_00_FLEXSPI_A_SS1_B 0x1BC 0x3AC 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B0_01_USDHC1_CLK 0x1C0 0x3B0 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_01_FLEXPWM1_PWM0_B 0x1C0 0x3B0 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_01_LPI2C3_SDA 0x1C0 0x3B0 0x4E0 0x2 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_01_XBAR_INOUT05 0x1C0 0x3B0 0x618 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_01_LPSPI1_PCS0 0x1C0 0x3B0 0x4EC 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_01_GPIO3_IO13 0x1C0 0x3B0 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_01_FLEXSPI_B_SS1_B 0x1C0 0x3B0 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B0_02_USDHC1_DATA0 0x1C4 0x3B4 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_02_FLEXPWM1_PWM1_A 0x1C4 0x3B4 0x45C 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_02_LPUART8_CTS_B 0x1C4 0x3B4 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_02_XBAR_INOUT06 0x1C4 0x3B4 0x61C 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_02_LPSPI1_SDO 0x1C4 0x3B4 0x4F8 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_02_GPIO3_IO14 0x1C4 0x3B4 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B0_03_USDHC1_DATA1 0x1C8 0x3B8 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_03_FLEXPWM1_PWM1_B 0x1C8 0x3B8 0x46C 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_03_LPUART8_RTS_B 0x1C8 0x3B8 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_03_XBAR_INOUT07 0x1C8 0x3B8 0x620 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_03_LPSPI1_SDI 0x1C8 0x3B8 0x4F4 0x4 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_03_GPIO3_IO15 0x1C8 0x3B8 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B0_04_USDHC1_DATA2 0x1CC 0x3BC 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_04_FLEXPWM1_PWM2_A 0x1CC 0x3BC 0x460 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_04_LPUART8_TXD 0x1CC 0x3BC 0x564 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_04_XBAR_INOUT08 0x1CC 0x3BC 0x624 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_04_FLEXSPI_B_SS0_B 0x1CC 0x3BC 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_04_GPIO3_IO16 0x1CC 0x3BC 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_04_CCM_CLKO1 0x1CC 0x3BC 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B0_05_USDHC1_DATA3 0x1D0 0x3C0 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_05_FLEXPWM1_PWM2_B 0x1D0 0x3C0 0x470 0x1 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_05_LPUART8_RXD 0x1D0 0x3C0 0x560 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_05_XBAR_INOUT09 0x1D0 0x3C0 0x628 0x3 0x1 -#define MXRT1050_IOMUXC_GPIO_SD_B0_05_FLEXSPI_B_DQS 0x1D0 0x3C0 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_05_GPIO3_IO17 0x1D0 0x3C0 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B0_05_CCM_CLKO2 0x1D0 0x3C0 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B1_00_USDHC2_DATA3 0x1D4 0x3C4 0x5F4 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_00_FLEXSPI_B_DATA3 0x1D4 0x3C4 0x4C4 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_00_FLEXPWM1_PWM3_A 0x1D4 0x3C4 0x454 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_00_SAI1_TX_DATA03 0x1D4 0x3C4 0x598 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_00_LPUART4_TXD 0x1D4 0x3C4 0x544 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_00_GPIO3_IO00 0x1D4 0x3C4 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B1_01_USDHC2_DATA2 0x1D8 0x3C8 0x5F0 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_01_FLEXSPI_B_DATA2 0x1D8 0x3C8 0x4C0 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_01_FLEXPWM1_PWM3_B 0x1D8 0x3C8 0x464 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_01_SAI1_TX_DATA02 0x1D8 0x3C8 0x59C 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_01_LPUART4_RXD 0x1D8 0x3C8 0x540 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_01_GPIO3_IO01 0x1D8 0x3C8 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B1_02_USDHC2_DATA1 0x1DC 0x3CC 0x5EC 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_02_FLEXSPI_B_DATA1 0x1DC 0x3CC 0x4BC 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_02_FLEXPWM2_PWM3_A 0x1DC 0x3CC 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_02_SAI1_TX_DATA01 0x1DC 0x3CC 0x5A0 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_02_FLEXCAN1_TX 0x1DC 0x3CC 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_02_GPIO3_IO02 0x1DC 0x3CC 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_02_CCM_WAIT 0x1DC 0x3CC 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B1_03_USDHC2_DATA0 0x1E0 0x3D0 0x5E8 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_03_FLEXSPI_B_DATA0 0x1E0 0x3D0 0x4B8 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_03_FLEXPWM2_PWM3_B 0x1E0 0x3D0 0x484 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_03_SAI1_MCLK 0x1E0 0x3D0 0x58C 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_03_FLEXCAN1_RX 0x1E0 0x3D0 0x44C 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_03_GPIO3_IO03 0x1E0 0x3D0 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_03_CCM_PMIC_READY 0x1E0 0x3D0 0x3FC 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B1_04_USDHC2_CLK 0x1E4 0x3D4 0x5DC 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_04_FLEXSPI_B_SCLK 0x1E4 0x3D4 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_04_LPI2C1_SCL 0x1E4 0x3D4 0x4CC 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_04_SAI1_RX_SYNC 0x1E4 0x3D4 0x5A4 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_04_FLEXCAN1_A_SS1_B 0x1E4 0x3D4 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_04_GPIO3_IO04 0x1E4 0x3D4 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_04_CCM_STOP 0x1E4 0x3D4 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B1_05_USDHC2_CMD 0x1E8 0x3D8 0x5E4 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_05_FLEXSPI_A_DQS 0x1E8 0x3D8 0x4A4 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_05_LPI2C1_SDA 0x1E8 0x3D8 0x4D0 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_05_SAI1_RX_BCLK 0x1E8 0x3D8 0x590 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_05_FLEXCAN1_B_SS0_B 0x1E8 0x3D8 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_05_GPIO3_IO05 0x1E8 0x3D8 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B1_06_USDHC2_RESET_B 0x1EC 0x3DC 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_06_FLEXSPI_A_SS0_B 0x1EC 0x3DC 0x000 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_06_LPUART7_CTS_B 0x1EC 0x3DC 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_06_SAI1_RX_DATA00 0x1EC 0x3DC 0x594 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_06_LPSPI2_PCS0 0x1EC 0x3DC 0x4FC 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_06_GPIO3_IO06 0x1EC 0x3DC 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B1_07_SEMC_CSX1 0x1F0 0x3E0 0x000 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_07_FLEXSPI_A_SCLK 0x1F0 0x3E0 0x4C8 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_07_LPUART7_RTS_B 0x1F0 0x3E0 0x000 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_07_SAI1_TX_DATA00 0x1F0 0x3E0 0x000 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_07_LPSPI2_SCK 0x1F0 0x3E0 0x500 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_07_GPIO3_IO07 0x1F0 0x3E0 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_07_CCM_REF_EN_B 0x1F0 0x3E0 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B1_08_USDHC2_DATA4 0x1F4 0x3E4 0x5F8 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_08_FLEXSPI_A_DATA0 0x1F4 0x3E4 0x4A8 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_08_LPUART7_TXD 0x1F4 0x3E4 0x55C 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_08_SAI1_TX_BLCK 0x1F4 0x3E4 0x5A8 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_08_LPSPI2_SDO 0x1F4 0x3E4 0x508 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_08_GPIO3_IO08 0x1F4 0x3E4 0x000 0x5 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_08_SEMC_CSX2 0x1F4 0x3E4 0x000 0x6 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B1_09_USDHC2_DATA5 0x1F8 0x3E8 0x5FC 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_09_FLEXSPI_A_DATA1 0x1F8 0x3E8 0x4AC 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_09_LPUART7_RXD 0x1F8 0x3E8 0x558 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_09_SAI1_TX_SYNC 0x1F8 0x3E8 0x5AC 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_09_LPSPI2_SDI 0x1F8 0x3E8 0x504 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_09_GPIO3_IO09 0x1F8 0x3E8 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B1_10_USDHC2_DATA6 0x1FC 0x3EC 0x600 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_10_FLEXSPI_A_DATA2 0x1FC 0x3EC 0x4B0 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_10_LPUART2_RXD 0x1FC 0x3EC 0x52C 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_10_LPI2C2_SDA 0x1FC 0x3EC 0x4D8 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_10_LPSPI2_PCS2 0x1FC 0x3EC 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_10_GPIO3_IO10 0x1FC 0x3EC 0x000 0x5 0x0 - -#define MXRT1050_IOMUXC_GPIO_SD_B1_11_USDHC2_DATA7 0x200 0x3F0 0x604 0x0 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_11_FLEXSPI_A_DATA3 0x200 0x3F0 0x4B4 0x1 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_11_LPUART2_TXD 0x200 0x3F0 0x530 0x2 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_11_LPI2C2_SCL 0x200 0x3F0 0x4D4 0x3 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_11_LPSPI2_PCS3 0x200 0x3F0 0x000 0x4 0x0 -#define MXRT1050_IOMUXC_GPIO_SD_B1_11_GPIO3_IO11 0x200 0x3F0 0x000 0x5 0x0 - -#endif /* _DT_BINDINGS_PINCTRL_IMXRT1050_PINFUNC_H */ diff --git a/arch/arm/dts/imxrt1050.dtsi b/arch/arm/dts/imxrt1050.dtsi deleted file mode 100644 index a25eae9bd38..00000000000 --- a/arch/arm/dts/imxrt1050.dtsi +++ /dev/null @@ -1,160 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (C) 2019 - * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com - */ - -#include "armv7-m.dtsi" -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/clock/imxrt1050-clock.h> -#include <dt-bindings/gpio/gpio.h> - -/ { - #address-cells = <1>; - #size-cells = <1>; - - clocks { - osc: osc { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <24000000>; - }; - - osc3M: osc3M { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <3000000>; - }; - }; - - soc { - lpuart1: serial@40184000 { - compatible = "fsl,imxrt1050-lpuart", "fsl,imx7ulp-lpuart"; - reg = <0x40184000 0x4000>; - interrupts = <20>; - clocks = <&clks IMXRT1050_CLK_LPUART1>; - clock-names = "ipg"; - status = "disabled"; - }; - - iomuxc: pinctrl@401f8000 { - compatible = "fsl,imxrt1050-iomuxc"; - reg = <0x401f8000 0x4000>; - fsl,mux_mask = <0x7>; - }; - - anatop: anatop@400d8000 { - compatible = "fsl,imxrt-anatop"; - reg = <0x400d8000 0x4000>; - }; - - clks: clock-controller@400fc000 { - compatible = "fsl,imxrt1050-ccm"; - reg = <0x400fc000 0x4000>; - interrupts = <95>, <96>; - clocks = <&osc>; - clock-names = "osc"; - #clock-cells = <1>; - assigned-clocks = <&clks IMXRT1050_CLK_PLL1_BYPASS>, - <&clks IMXRT1050_CLK_PLL1_BYPASS>, - <&clks IMXRT1050_CLK_PLL2_BYPASS>, - <&clks IMXRT1050_CLK_PLL3_BYPASS>, - <&clks IMXRT1050_CLK_PLL3_PFD1_664_62M>, - <&clks IMXRT1050_CLK_PLL2_PFD2_396M>; - assigned-clock-parents = <&clks IMXRT1050_CLK_PLL1_REF_SEL>, - <&clks IMXRT1050_CLK_PLL1_ARM>, - <&clks IMXRT1050_CLK_PLL2_SYS>, - <&clks IMXRT1050_CLK_PLL3_USB_OTG>, - <&clks IMXRT1050_CLK_PLL3_USB_OTG>, - <&clks IMXRT1050_CLK_PLL2_SYS>; - }; - - edma1: dma-controller@400e8000 { - #dma-cells = <2>; - compatible = "fsl,imx7ulp-edma"; - reg = <0x400e8000 0x4000>, - <0x400ec000 0x4000>; - dma-channels = <32>; - interrupts = <0>, <1>, <2>, <3>, <4>, <5>, <6>, <7>, <8>, - <9>, <10>, <11>, <12>, <13>, <14>, <15>, <16>; - clock-names = "dma", "dmamux0"; - clocks = <&clks IMXRT1050_CLK_DMA>, - <&clks IMXRT1050_CLK_DMA_MUX>; - }; - - usdhc1: mmc@402c0000 { - compatible = "fsl,imxrt1050-usdhc", "fsl,imx6sl-usdhc"; - reg = <0x402c0000 0x4000>; - interrupts = <110>; - clocks = <&clks IMXRT1050_CLK_IPG_PDOF>, - <&clks IMXRT1050_CLK_AHB_PODF>, - <&clks IMXRT1050_CLK_USDHC1>; - clock-names = "ipg", "ahb", "per"; - bus-width = <4>; - fsl,wp-controller; - no-1-8-v; - max-frequency = <4000000>; - fsl,tuning-start-tap = <20>; - fsl,tuning-step = <2>; - status = "disabled"; - }; - - gpio1: gpio@401b8000 { - compatible = "fsl,imxrt1050-gpio", "fsl,imx35-gpio"; - reg = <0x401b8000 0x4000>; - interrupts = <80>, <81>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio2: gpio@401bc000 { - compatible = "fsl,imxrt1050-gpio", "fsl,imx35-gpio"; - reg = <0x401bc000 0x4000>; - interrupts = <82>, <83>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio3: gpio@401c0000 { - compatible = "fsl,imxrt1050-gpio", "fsl,imx35-gpio"; - reg = <0x401c0000 0x4000>; - interrupts = <84>, <85>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio4: gpio@401c4000 { - compatible = "fsl,imxrt1050-gpio", "fsl,imx35-gpio"; - reg = <0x401c4000 0x4000>; - interrupts = <86>, <87>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio5: gpio@400c0000 { - compatible = "fsl,imxrt1050-gpio", "fsl,imx35-gpio"; - reg = <0x400c0000 0x4000>; - interrupts = <88>, <89>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpt: timer@401ec000 { - compatible = "fsl,imxrt1050-gpt", "fsl,imx6dl-gpt", "fsl,imx6sl-gpt"; - reg = <0x401ec000 0x4000>; - interrupts = <100>; - clocks = <&osc3M>; - clock-names = "per"; - }; - }; -}; diff --git a/configs/imxrt1050-evk_defconfig b/configs/imxrt1050-evk_defconfig index b488ff1b7da..918713a1c7d 100644 --- a/configs/imxrt1050-evk_defconfig +++ b/configs/imxrt1050-evk_defconfig @@ -13,7 +13,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20020000 CONFIG_ENV_OFFSET=0x80000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imxrt1050-evk" +CONFIG_DEFAULT_DEVICE_TREE="nxp/imx/imxrt1050-evk" CONFIG_TARGET_IMXRT1050_EVK=y CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y @@ -48,6 +48,7 @@ CONFIG_CMD_USB=y # CONFIG_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/imxrt1050-evk_fspi_defconfig b/configs/imxrt1050-evk_fspi_defconfig index 5d58e723a70..86acd158391 100644 --- a/configs/imxrt1050-evk_fspi_defconfig +++ b/configs/imxrt1050-evk_fspi_defconfig @@ -15,7 +15,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20020000 CONFIG_ENV_OFFSET=0x80000 CONFIG_IMX_CONFIG="board/freescale/imxrt1050-evk/imximage-nor.cfg" CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imxrt1050-evk" +CONFIG_DEFAULT_DEVICE_TREE="nxp/imx/imxrt1050-evk" CONFIG_TARGET_IMXRT1050_EVK=y CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y @@ -50,6 +50,7 @@ CONFIG_CMD_USB=y # CONFIG_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y
On Mon, Jan 27, 2025 at 6:19 PM Jesse Taube mr.bossman075@gmail.com wrote:
The device tree for imxrt1050 is now available in the /dts/upstream directory. Migrate board to use OF_UPSTREAM.
Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com
Reviewed-by: Fabio Estevam festevam@gmail.com
Fabio Estevam
Jesse Taube
