[PATCH] clk: Consolidate some clock functions
These functions are exactly the same as their "nodev" varients, except they accept a device and not an ofnode. Rewrite them to just call the other function.
Signed-off-by: Sean Anderson seanga2@gmail.com ---
drivers/clk/clk-uclass.c | 22 ++-------------------- 1 file changed, 2 insertions(+), 20 deletions(-)
diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index c20c928bf1..4ab876517a 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -138,14 +138,7 @@ static int clk_get_by_indexed_prop(struct udevice *dev, const char *prop_name,
int clk_get_by_index(struct udevice *dev, int index, struct clk *clk) { - struct ofnode_phandle_args args; - int ret; - - ret = dev_read_phandle_with_args(dev, "clocks", "#clock-cells", 0, - index, &args); - - return clk_get_by_index_tail(ret, dev_ofnode(dev), &args, "clocks", - index, clk); + return clk_get_by_index_nodev(dev_ofnode(dev), index, clk); }
int clk_get_by_index_nodev(ofnode node, int index, struct clk *clk) @@ -400,18 +393,7 @@ int clk_set_defaults(struct udevice *dev, enum clk_defaults_stage stage)
int clk_get_by_name(struct udevice *dev, const char *name, struct clk *clk) { - int index; - - debug("%s(dev=%p, name=%s, clk=%p)\n", __func__, dev, name, clk); - clk->dev = NULL; - - index = dev_read_stringlist_search(dev, "clock-names", name); - if (index < 0) { - debug("fdt_stringlist_search() failed: %d\n", index); - return index; - } - - return clk_get_by_index(dev, index, clk); + return clk_get_by_name_nodev(dev_ofnode(dev), name, clk); } #endif /* OF_REAL */
Applied, thanks!
[1/1] clk: Consolidate some clock functions commit: e7075ff7b3dce82e4fd6246b87f3c44fabf6323b
Sean Anderson
