[U-Boot] [PATCH 0/4] Convert omap3-spi driver to Driver Model
Hi Simon,
This patchset tries to convert the TI omap3_spi driver to Driver Model. It has been tested on a TI BeagleBoard xM.
Best Regards Christophe
Christophe Ricard (4): spi: omap3: Remove unused variable irqstatus in omap3_spi_txrx spi: spi-uclass: Set slave wordlen with SPI_DEFAULT_WORDLEN spi: omap3: Convert to DM spi: omap3: Convert fully to DM_SPI
drivers/spi/Kconfig | 6 + drivers/spi/omap3_spi.c | 411 +++++++++++++++++++++++++++-------------------- drivers/spi/omap3_spi.h | 109 ------------- drivers/spi/spi-uclass.c | 1 + 4 files changed, 240 insertions(+), 287 deletions(-) delete mode 100644 drivers/spi/omap3_spi.h
Signed-off-by: Christophe Ricard christophe-h.ricard@st.com ---
drivers/spi/omap3_spi.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/drivers/spi/omap3_spi.c b/drivers/spi/omap3_spi.c index 85f9e85..95cdfa3 100644 --- a/drivers/spi/omap3_spi.c +++ b/drivers/spi/omap3_spi.c @@ -336,7 +336,6 @@ int omap3_spi_txrx(struct spi_slave *slave, unsigned int len, struct omap3_spi_slave *ds = to_omap3_spi(slave); ulong start; int chconf = readl(&ds->regs->channel[ds->slave.cs].chconf); - int irqstatus = readl(&ds->regs->irqstatus); int i=0;
/*Enable SPI channel*/ @@ -351,7 +350,6 @@ int omap3_spi_txrx(struct spi_slave *slave, unsigned int len, /*Shift in and out 1 byte at time*/ for (i=0; i < len; i++){ /* Write: wait for TX empty (TXS == 1)*/ - irqstatus |= (1<< (4*(ds->slave.bus))); start = get_timer(0); while (!(readl(&ds->regs->channel[ds->slave.cs].chstat) & OMAP3_MCSPI_CHSTAT_TXS)) {
On 17 January 2016 at 03:56, Christophe Ricard christophe.ricard@gmail.com wrote:
Reviewed-by: Jagan Teki jteki@openedev.com
In some case wordlen may not be set. Use SPI_DEFAULT_WORDLEN as default.
drivers/spi/spi-uclass.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index 677c020..5561f36 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -158,6 +158,7 @@ static int spi_child_pre_probe(struct udevice *dev) slave->max_hz = plat->max_hz; slave->mode = plat->mode; slave->mode_rx = plat->mode_rx; + slave->wordlen = SPI_DEFAULT_WORDLEN;
return 0; }
Convert omap3_spi driver to DM and keep compatibility with previous mode.
drivers/spi/Kconfig | 6 + drivers/spi/omap3_spi.c | 439 ++++++++++++++++++++++++++++++++++++++++++------ drivers/spi/omap3_spi.h | 14 +- 3 files changed, 402 insertions(+), 57 deletions(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 2cdb110..b8c2498 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -155,6 +155,12 @@ config ZYNQ_QSPI Zynq QSPI IP core. This IP is used to connect the flash in 4-bit qspi, 8-bit dual stacked and shared 4-bit dual parallel.
+config OMAP3_SPI + bool "McSPI driver for OMAP" + help + SPI master controller for OMAP24XX and later Multichannel SPI + (McSPI) modules. + endif # if DM_SPI
config FSL_ESPI diff --git a/drivers/spi/omap3_spi.c b/drivers/spi/omap3_spi.c index 95cdfa3..09fb1ef 100644 --- a/drivers/spi/omap3_spi.c +++ b/drivers/spi/omap3_spi.c @@ -11,10 +11,14 @@ * * Modified by Ruslan Araslanov ruslan.araslanov@vitecmm.com * + * Copyright (c) 2016 Christophe Ricard christophe.ricard@gmail.com + * - Added support for DM_SPI + * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> +#include <dm.h> #include <spi.h> #include <malloc.h> #include <asm/io.h> @@ -22,9 +26,17 @@
#define SPI_WAIT_TIMEOUT 10
+#ifdef CONFIG_DM_SPI +static void spi_reset(struct udevice *dev) +#else static void spi_reset(struct omap3_spi_slave *ds) +#endif { unsigned int tmp; +#ifdef CONFIG_DM_SPI + struct omap3_spi_slave *ds = dev_get_priv(dev->parent); + +#endif
writel(OMAP3_MCSPI_SYSCONFIG_SOFTRESET, &ds->regs->sysconfig); do { @@ -39,20 +51,50 @@ static void spi_reset(struct omap3_spi_slave *ds) writel(OMAP3_MCSPI_WAKEUPENABLE_WKEN, &ds->regs->wakeupenable); }
+#ifdef CONFIG_DM_SPI +static void omap3_spi_write_chconf(struct udevice *dev, int val) +#else static void omap3_spi_write_chconf(struct omap3_spi_slave *ds, int val) +#endif { - writel(val, &ds->regs->channel[ds->slave.cs].chconf); + unsigned int cs; +#ifdef CONFIG_DM_SPI + struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); + struct omap3_spi_slave *ds = dev_get_priv(dev->parent); + + + cs = platdata->cs; +#else + cs = ds->slave.cs; +#endif + + writel(val, &ds->regs->channel[cs].chconf); /* Flash post writes to make immediate effect */ - readl(&ds->regs->channel[ds->slave.cs].chconf); + readl(&ds->regs->channel[cs].chconf); }
+#ifdef CONFIG_DM_SPI +static void omap3_spi_set_enable(struct udevice *dev, int enable) +#else static void omap3_spi_set_enable(struct omap3_spi_slave *ds, int enable) +#endif { - writel(enable, &ds->regs->channel[ds->slave.cs].chctrl); + unsigned int cs; +#ifdef CONFIG_DM_SPI + struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); + struct omap3_spi_slave *ds = dev_get_priv(dev->parent); + + cs = platdata->cs; +#else + cs = ds->slave.cs; +#endif + + writel(enable, &ds->regs->channel[cs].chctrl); /* Flash post writes to make immediate effect */ - readl(&ds->regs->channel[ds->slave.cs].chctrl); + readl(&ds->regs->channel[cs].chctrl); }
+#ifndef CONFIG_DM_SPI void spi_init() { /* do nothing */ @@ -138,10 +180,32 @@ void spi_free_slave(struct spi_slave *slave) free(ds); }
+int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return 1; +} +#endif + +#ifdef CONFIG_DM_SPI +static int omap3_spi_claim_bus(struct udevice *dev) +#else int spi_claim_bus(struct spi_slave *slave) +#endif { - struct omap3_spi_slave *ds = to_omap3_spi(slave); + unsigned int cs; + struct omap3_spi_slave *ds; unsigned int conf, div = 0; +#ifdef CONFIG_DM_SPI + struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); + struct spi_slave *slave = dev_get_parent_priv(dev); + + ds = dev_get_priv(dev->parent); + cs = platdata->cs; + ds->freq = slave->max_hz; +#else + ds = to_omap3_spi(slave); + cs = ds->slave.cs; +#endif
/* McSPI global module configuration */
@@ -149,7 +213,11 @@ int spi_claim_bus(struct spi_slave *slave) * setup when switching from (reset default) slave mode * to single-channel master mode */ +#ifdef CONFIG_DM_SPI + spi_reset(dev); +#else spi_reset(ds); +#endif conf = readl(&ds->regs->modulctrl); conf &= ~(OMAP3_MCSPI_MODULCTRL_STEST | OMAP3_MCSPI_MODULCTRL_MS); conf |= OMAP3_MCSPI_MODULCTRL_SINGLE; @@ -165,8 +233,7 @@ int spi_claim_bus(struct spi_slave *slave) } else div = 0xC;
- conf = readl(&ds->regs->channel[ds->slave.cs].chconf); - + conf = readl(&ds->regs->channel[cs].chconf); /* standard 4-wire master mode: SCK, MOSI/out, MISO/in, nCS * REVISIT: this controller could support SPI_3WIRE mode. */ @@ -184,7 +251,7 @@ int spi_claim_bus(struct spi_slave *slave)
/* wordlength */ conf &= ~OMAP3_MCSPI_CHCONF_WL_MASK; - conf |= (ds->slave.wordlen - 1) << 7; + conf |= (slave->wordlen - 1) << 7;
/* set chipselect polarity; manage with FORCE */ if (!(ds->mode & SPI_CS_HIGH)) @@ -209,113 +276,222 @@ int spi_claim_bus(struct spi_slave *slave) /* Transmit & receive mode */ conf &= ~OMAP3_MCSPI_CHCONF_TRM_MASK;
+#ifdef CONFIG_DM_SPI + omap3_spi_write_chconf(dev, conf); +#else omap3_spi_write_chconf(ds,conf); +#endif
return 0; }
+#ifdef CONFIG_DM_SPI +int omap3_spi_release_bus(struct udevice *dev) +#else void spi_release_bus(struct spi_slave *slave) +#endif { +#ifndef CONFIG_DM_SPI struct omap3_spi_slave *ds = to_omap3_spi(slave); - +#endif /* Reset the SPI hardware */ +#ifdef CONFIG_DM_SPI + spi_reset(dev); +#else spi_reset(ds); +#endif + +#ifdef CONFIG_DM_SPI + return 0; +#endif }
+#ifdef CONFIG_DM_SPI +int omap3_spi_write(struct udevice *dev, unsigned int len, const void *txp, + unsigned long flags) +#else int omap3_spi_write(struct spi_slave *slave, unsigned int len, const void *txp, unsigned long flags) +#endif { - struct omap3_spi_slave *ds = to_omap3_spi(slave); - int i; + struct omap3_spi_slave *ds; + int i, chconf; ulong start; - int chconf = readl(&ds->regs->channel[ds->slave.cs].chconf); + unsigned int cs; +#ifdef CONFIG_DM_SPI + struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); + struct spi_slave *slave = dev_get_parent_priv(dev); +
+ ds = dev_get_priv(dev->parent); + cs = platdata->cs; +#else + ds = to_omap3_spi(slave); + cs = ds->slave.cs; +#endif + + chconf = readl(&ds->regs->channel[cs].chconf); + +#ifdef CONFIG_DM_SPI /* Enable the channel */ - omap3_spi_set_enable(ds,OMAP3_MCSPI_CHCTRL_EN); + omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_EN); +#else + /* Enable the channel */ + omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_EN); +#endif
chconf &= ~(OMAP3_MCSPI_CHCONF_TRM_MASK | OMAP3_MCSPI_CHCONF_WL_MASK); +#ifdef CONFIG_DM_SPI + chconf |= (slave->wordlen - 1) << 7; +#else chconf |= (ds->slave.wordlen - 1) << 7; +#endif chconf |= OMAP3_MCSPI_CHCONF_TRM_TX_ONLY; chconf |= OMAP3_MCSPI_CHCONF_FORCE; - omap3_spi_write_chconf(ds,chconf); +#ifdef CONFIG_DM_SPI + omap3_spi_write_chconf(dev, chconf); +#else + omap3_spi_write_chconf(ds, chconf); +#endif
for (i = 0; i < len; i++) { /* wait till TX register is empty (TXS == 1) */ start = get_timer(0); - while (!(readl(&ds->regs->channel[ds->slave.cs].chstat) & + while (!(readl(&ds->regs->channel[cs].chstat) & OMAP3_MCSPI_CHSTAT_TXS)) { if (get_timer(start) > SPI_WAIT_TIMEOUT) { printf("SPI TXS timed out, status=0x%08x\n", - readl(&ds->regs->channel[ds->slave.cs].chstat)); + readl(&ds->regs->channel[cs].chstat)); return -1; } } + /* Write the data */ - unsigned int *tx = &ds->regs->channel[ds->slave.cs].tx; + unsigned int *tx = &ds->regs->channel[cs].tx; +#ifdef CONFIG_DM_SPI + if (slave->wordlen > 16) +#else if (ds->slave.wordlen > 16) +#endif writel(((u32 *)txp)[i], tx); +#ifdef CONFIG_DM_SPI + else if (slave->wordlen > 8) +#else else if (ds->slave.wordlen > 8) +#endif writel(((u16 *)txp)[i], tx); else writel(((u8 *)txp)[i], tx); }
/* wait to finish of transfer */ - while ((readl(&ds->regs->channel[ds->slave.cs].chstat) & + while ((readl(&ds->regs->channel[cs].chstat) & (OMAP3_MCSPI_CHSTAT_EOT | OMAP3_MCSPI_CHSTAT_TXS)) != - (OMAP3_MCSPI_CHSTAT_EOT | OMAP3_MCSPI_CHSTAT_TXS)); + (OMAP3_MCSPI_CHSTAT_EOT | OMAP3_MCSPI_CHSTAT_TXS)) + ;
+#ifdef CONFIG_DM_SPI + /* Disable the channel otherwise the next immediate RX will get affected */ + omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_DIS); +#else /* Disable the channel otherwise the next immediate RX will get affected */ - omap3_spi_set_enable(ds,OMAP3_MCSPI_CHCTRL_DIS); + omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_DIS); +#endif
if (flags & SPI_XFER_END) {
chconf &= ~OMAP3_MCSPI_CHCONF_FORCE; - omap3_spi_write_chconf(ds,chconf); +#ifdef CONFIG_DM_SPI + omap3_spi_write_chconf(dev, chconf); +#else + omap3_spi_write_chconf(ds, chconf); +#endif } + return 0; }
+#ifdef CONFIG_DM_SPI +int omap3_spi_read(struct udevice *dev, unsigned int len, void *rxp, + unsigned long flags) +#else int omap3_spi_read(struct spi_slave *slave, unsigned int len, void *rxp, unsigned long flags) +#endif { - struct omap3_spi_slave *ds = to_omap3_spi(slave); - int i; + struct omap3_spi_slave *ds; + int i, chconf; ulong start; - int chconf = readl(&ds->regs->channel[ds->slave.cs].chconf); + unsigned int cs; +#ifdef CONFIG_DM_SPI + struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); + struct spi_slave *slave = dev_get_parent_priv(dev);
+ + ds = dev_get_priv(dev->parent); + cs = platdata->cs; +#else + ds = to_omap3_spi(slave); + cs = ds->slave.cs; +#endif + chconf = readl(&ds->regs->channel[cs].chconf); + +#ifdef CONFIG_DM_SPI + /* Enable the channel */ + omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_EN); +#else /* Enable the channel */ - omap3_spi_set_enable(ds,OMAP3_MCSPI_CHCTRL_EN); + omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_EN); +#endif
chconf &= ~(OMAP3_MCSPI_CHCONF_TRM_MASK | OMAP3_MCSPI_CHCONF_WL_MASK); +#ifdef CONFIG_DM_SPI + chconf |= (slave->wordlen - 1) << 7; +#else chconf |= (ds->slave.wordlen - 1) << 7; +#endif chconf |= OMAP3_MCSPI_CHCONF_TRM_RX_ONLY; chconf |= OMAP3_MCSPI_CHCONF_FORCE; - omap3_spi_write_chconf(ds,chconf); +#ifdef CONFIG_DM_SPI + omap3_spi_write_chconf(dev, chconf); +#else + omap3_spi_write_chconf(ds, chconf); +#endif
- writel(0, &ds->regs->channel[ds->slave.cs].tx); + writel(0, &ds->regs->channel[cs].tx);
for (i = 0; i < len; i++) { start = get_timer(0); /* Wait till RX register contains data (RXS == 1) */ - while (!(readl(&ds->regs->channel[ds->slave.cs].chstat) & + while (!(readl(&ds->regs->channel[cs].chstat) & OMAP3_MCSPI_CHSTAT_RXS)) { if (get_timer(start) > SPI_WAIT_TIMEOUT) { printf("SPI RXS timed out, status=0x%08x\n", - readl(&ds->regs->channel[ds->slave.cs].chstat)); + readl(&ds->regs->channel[cs].chstat)); return -1; } } - /* Disable the channel to prevent furher receiving */ if(i == (len - 1)) - omap3_spi_set_enable(ds,OMAP3_MCSPI_CHCTRL_DIS); +#ifdef CONFIG_DM_SPI + omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_DIS); +#else + omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_DIS); +#endif
/* Read the data */ - unsigned int *rx = &ds->regs->channel[ds->slave.cs].rx; + unsigned int *rx = &ds->regs->channel[cs].rx; +#ifdef CONFIG_DM_SPI + if (slave->wordlen > 16) +#else if (ds->slave.wordlen > 16) +#endif ((u32 *)rxp)[i] = readl(rx); +#ifdef CONFIG_DM_SPI + else if (slave->wordlen > 8) +#else else if (ds->slave.wordlen > 8) +#endif ((u16 *)rxp)[i] = (u16)readl(rx); else ((u8 *)rxp)[i] = (u8)readl(rx); @@ -323,89 +499,177 @@ int omap3_spi_read(struct spi_slave *slave, unsigned int len, void *rxp,
if (flags & SPI_XFER_END) { chconf &= ~OMAP3_MCSPI_CHCONF_FORCE; - omap3_spi_write_chconf(ds,chconf); +#ifdef CONFIG_DM_SPI + omap3_spi_write_chconf(dev, chconf); +#else + omap3_spi_write_chconf(ds, chconf); +#endif }
return 0; }
+#ifdef CONFIG_DM_SPI +/*McSPI Transmit Receive Mode*/ +int omap3_spi_txrx(struct udevice *dev, unsigned int len, + const void *txp, void *rxp, unsigned long flags) +#else /*McSPI Transmit Receive Mode*/ int omap3_spi_txrx(struct spi_slave *slave, unsigned int len, const void *txp, void *rxp, unsigned long flags) +#endif { - struct omap3_spi_slave *ds = to_omap3_spi(slave); + struct omap3_spi_slave *ds; ulong start; - int chconf = readl(&ds->regs->channel[ds->slave.cs].chconf); + int chconf; int i=0; + unsigned int cs; +#ifdef CONFIG_DM_SPI + struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); + struct spi_slave *slave = dev_get_parent_priv(dev); +
+ ds = dev_get_priv(dev->parent); + cs = platdata->cs; +#else + ds = to_omap3_spi(slave); + cs = ds->slave.cs; +#endif + chconf = readl(&ds->regs->channel[cs].chconf); + +#ifdef CONFIG_DM_SPI + /*Enable SPI channel*/ + omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_EN); +#else /*Enable SPI channel*/ - omap3_spi_set_enable(ds,OMAP3_MCSPI_CHCTRL_EN); + omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_EN); +#endif
/*set TRANSMIT-RECEIVE Mode*/ chconf &= ~(OMAP3_MCSPI_CHCONF_TRM_MASK | OMAP3_MCSPI_CHCONF_WL_MASK); +#ifdef CONFIG_DM_SPI + chconf |= (slave->wordlen - 1) << 7; +#else chconf |= (ds->slave.wordlen - 1) << 7; +#endif chconf |= OMAP3_MCSPI_CHCONF_FORCE; - omap3_spi_write_chconf(ds,chconf); +#ifdef CONFIG_DM_SPI + omap3_spi_write_chconf(dev, chconf); +#else + omap3_spi_write_chconf(ds, chconf); +#endif
/*Shift in and out 1 byte at time*/ for (i=0; i < len; i++){ /* Write: wait for TX empty (TXS == 1)*/ start = get_timer(0); - while (!(readl(&ds->regs->channel[ds->slave.cs].chstat) & + while (!(readl(&ds->regs->channel[cs].chstat) & OMAP3_MCSPI_CHSTAT_TXS)) { if (get_timer(start) > SPI_WAIT_TIMEOUT) { printf("SPI TXS timed out, status=0x%08x\n", - readl(&ds->regs->channel[ds->slave.cs].chstat)); + readl(&ds->regs->channel[cs].chstat)); return -1; } } /* Write the data */ - unsigned int *tx = &ds->regs->channel[ds->slave.cs].tx; + unsigned int *tx = &ds->regs->channel[cs].tx; +#ifdef CONFIG_DM_SPI + if (slave->wordlen > 16) +#else if (ds->slave.wordlen > 16) +#endif writel(((u32 *)txp)[i], tx); +#ifdef CONFIG_DM_SPI + else if (slave->wordlen > 8) +#else else if (ds->slave.wordlen > 8) +#endif writel(((u16 *)txp)[i], tx); else writel(((u8 *)txp)[i], tx);
/*Read: wait for RX containing data (RXS == 1)*/ start = get_timer(0); - while (!(readl(&ds->regs->channel[ds->slave.cs].chstat) & + while (!(readl(&ds->regs->channel[cs].chstat) & OMAP3_MCSPI_CHSTAT_RXS)) { if (get_timer(start) > SPI_WAIT_TIMEOUT) { printf("SPI RXS timed out, status=0x%08x\n", - readl(&ds->regs->channel[ds->slave.cs].chstat)); + readl(&ds->regs->channel[cs].chstat)); return -1; } } /* Read the data */ - unsigned int *rx = &ds->regs->channel[ds->slave.cs].rx; + unsigned int *rx = &ds->regs->channel[cs].rx; +#ifdef CONFIG_DM_SPI + if (slave->wordlen > 16) +#else if (ds->slave.wordlen > 16) +#endif ((u32 *)rxp)[i] = readl(rx); +#ifdef CONFIG_DM_SPI + else if (slave->wordlen > 8) +#else else if (ds->slave.wordlen > 8) +#endif ((u16 *)rxp)[i] = (u16)readl(rx); else ((u8 *)rxp)[i] = (u8)readl(rx); } + +#ifdef CONFIG_DM_SPI + /* Disable the channel */ + omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_DIS); +#else /* Disable the channel */ - omap3_spi_set_enable(ds,OMAP3_MCSPI_CHCTRL_DIS); + omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_DIS); +#endif
/*if transfer must be terminated disable the channel*/ if (flags & SPI_XFER_END) { chconf &= ~OMAP3_MCSPI_CHCONF_FORCE; - omap3_spi_write_chconf(ds,chconf); +#ifdef CONFIG_DM_SPI + omap3_spi_write_chconf(dev, chconf); +#else + omap3_spi_write_chconf(ds, chconf); +#endif }
return 0; }
+#ifdef CONFIG_DM_SPI +int omap3_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +#else int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, void *din, unsigned long flags) +#endif { - struct omap3_spi_slave *ds = to_omap3_spi(slave); - unsigned int len; + struct omap3_spi_slave *ds; + unsigned int len, cs; int ret = -1; +#ifdef CONFIG_DM_SPI + struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); + struct spi_slave *slave = dev_get_parent_priv(dev); + + ds = dev_get_priv(dev->parent); + cs = platdata->cs; +#else + ds = to_omap3_spi(slave); + cs = ds->slave.cs; +#endif
+#ifdef CONFIG_DM_SPI + if (slave->wordlen < 4 || slave->wordlen > 32) { + printf("omap3_spi: invalid wordlen %d\n", slave->wordlen); + return -1; + } + + if (bitlen % slave->wordlen) + return -1; + + len = bitlen / slave->wordlen; +#else if (ds->slave.wordlen < 4 || ds->slave.wordlen > 32) { printf("omap3_spi: invalid wordlen %d\n", ds->slave.wordlen); return -1; @@ -415,41 +679,104 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, return -1;
len = bitlen / ds->slave.wordlen; +#endif
if (bitlen == 0) { /* only change CS */ - int chconf = readl(&ds->regs->channel[ds->slave.cs].chconf); + int chconf = readl(&ds->regs->channel[cs].chconf);
if (flags & SPI_XFER_BEGIN) { - omap3_spi_set_enable(ds,OMAP3_MCSPI_CHCTRL_EN); +#ifdef CONFIG_DM_SPI + omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_EN); +#else + omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_EN); +#endif chconf |= OMAP3_MCSPI_CHCONF_FORCE; - omap3_spi_write_chconf(ds,chconf); +#ifdef CONFIG_DM_SPI + omap3_spi_write_chconf(dev, chconf); +#else + omap3_spi_write_chconf(ds, chconf); +#endif } if (flags & SPI_XFER_END) { chconf &= ~OMAP3_MCSPI_CHCONF_FORCE; - omap3_spi_write_chconf(ds,chconf); - omap3_spi_set_enable(ds,OMAP3_MCSPI_CHCTRL_DIS); +#ifdef CONFIG_DM_SPI + omap3_spi_write_chconf(dev, chconf); + omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_DIS); +#else + omap3_spi_write_chconf(ds, chconf); + omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_DIS); +#endif } ret = 0; } else { +#ifdef CONFIG_DM_SPI + if (dout != NULL && din != NULL) + ret = omap3_spi_txrx(dev, len, dout, din, flags); + else if (dout != NULL) + ret = omap3_spi_write(dev, len, dout, flags); + else if (din != NULL) + ret = omap3_spi_read(dev, len, din, flags); +#else if (dout != NULL && din != NULL) ret = omap3_spi_txrx(slave, len, dout, din, flags); else if (dout != NULL) ret = omap3_spi_write(slave, len, dout, flags); else if (din != NULL) ret = omap3_spi_read(slave, len, din, flags); +#endif } return ret; }
-int spi_cs_is_valid(unsigned int bus, unsigned int cs) +void spi_cs_activate(struct spi_slave *slave) { - return 1; }
-void spi_cs_activate(struct spi_slave *slave) +void spi_cs_deactivate(struct spi_slave *slave) { }
-void spi_cs_deactivate(struct spi_slave *slave) +#ifdef CONFIG_DM_SPI +static int omap3_spi_probe(struct udevice *dev) { + struct omap3_spi_slave *ds = dev_get_priv(dev); + + ds->regs = (struct mcspi *)dev_get_addr(dev); + + return 0; } + +static int omap3_spi_set_speed(struct udevice *dev, unsigned int speed) +{ + return 0; +} + +static int omap3_spi_set_mode(struct udevice *bus, uint mode) +{ + return 0; +} + + +static const struct dm_spi_ops omap3_spi_ops = { + .claim_bus = omap3_spi_claim_bus, + .release_bus = omap3_spi_release_bus, + .xfer = omap3_spi_xfer, + .set_speed = omap3_spi_set_speed, + .set_mode = omap3_spi_set_mode, +}; + +static const struct udevice_id omap3_spi_ids[] = { + { .compatible = "ti,omap2-mcspi" }, + { .compatible = "ti,omap4-mcspi" }, + { } +}; + +U_BOOT_DRIVER(omap3_spi) = { + .name = "omap3_spi", + .id = UCLASS_SPI, + .of_match = omap3_spi_ids, + .probe = omap3_spi_probe, + .ops = &omap3_spi_ops, + .priv_auto_alloc_size = sizeof(struct omap3_spi_slave), +}; +#endif diff --git a/drivers/spi/omap3_spi.h b/drivers/spi/omap3_spi.h index 6a07c6d..a974ca3 100644 --- a/drivers/spi/omap3_spi.h +++ b/drivers/spi/omap3_spi.h @@ -88,22 +88,34 @@ struct mcspi { #define OMAP3_MCSPI_WAKEUPENABLE_WKEN BIT(0)
struct omap3_spi_slave { +#ifndef CONFIG_DM_SPI struct spi_slave slave; +#endif struct mcspi *regs; unsigned int freq; unsigned int mode; };
+#ifndef CONFIG_DM_SPI static inline struct omap3_spi_slave *to_omap3_spi(struct spi_slave *slave) { return container_of(slave, struct omap3_spi_slave, slave); } +#endif
+#ifdef CONFIG_DM_SPI +int omap3_spi_txrx(struct udevice *dev, unsigned int len, const void *txp, + void *rxp, unsigned long flags); +int omap3_spi_write(struct udevice *dev, unsigned int len, const void *txp, + unsigned long flags); +int omap3_spi_read(struct udevice *dev, unsigned int len, void *rxp, + unsigned long flags); +#else int omap3_spi_txrx(struct spi_slave *slave, unsigned int len, const void *txp, void *rxp, unsigned long flags); int omap3_spi_write(struct spi_slave *slave, unsigned int len, const void *txp, unsigned long flags); int omap3_spi_read(struct spi_slave *slave, unsigned int len, void *rxp, unsigned long flags); - +#endif #endif /* _OMAP3_SPI_H_ */
+Mugunthan, Tom
This is a pretty painful conversion, with lots of #ifdefs. I think it would be possible to use a common pointer type and reduce this.
But perhaps it does not matter - how long must we be in the state of supporting legacy SPI? Can we convert all TI boards to driver model?
On Wed, Jan 20, 2016 at 07:46:15PM -0700, Simon Glass wrote:
+Mugunthan, Tom
We _really_ need some way to support more than one board per binary before we can move everything to DM only.
I think we can kind of do this today if we stick to using platform data for everything that's board-specific rather than SoC-defined. What we talked about at ELCE was auto-generating the pdata from the device tree, I think.
+Hans
Hi Tom,
+Mugunthan, Tom
We discussed this on IRC but since that doesn't exist as far as the mailing list is concerned...
The current plan is:
- Adjust build system to optionally build a u-boot.img in FIT format that includes the U-Boot binary and >1 device tree files - Adjust SPL to load this - Add a way for SPL to determine which device tree to select (by calling a board-specific function) - Have SPL pass this selected device tree to U-Boot when it starts
Thus we should be able to support more than one board with a single U-Boot image. Of course this is not a perfect solution (e.g. it is inefficient since the DTs are likely to be largely the same) but it should be a good first step.
I'm going to try this out with sunxi initially and plan to get some patches out by the end of the week.
Hi Simon,
On Mon, Jan 25, 2016 at 06:11:24PM -0700, Simon Glass wrote:
+Hans
Hi Tom,
+Mugunthan, Tom
Can dtb be sperated from the final u-boot.img, if using SPL? I mean let SPL load the u-boot.img and the dtb to correct DRAM address. And the dtb is shared with linux kernel.
Regards, Peng.
Regards, Simon _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Peng,
On 25 January 2016 at 18:55, Peng Fan van.freenix@gmail.com wrote:
Hi Simon,
+Hans
Hi Tom,
+Mugunthan, Tom
The way I have it is that u-boot.img include U-Boot and multiple .dtb files. Then SPL selects the correct one and passes it to U-Boot.
It could be passed to the kernel also, but then you would need to upgrade your firmware to upgrade your kernel. If that's what you want, it would not be hard to implement. But I am not planning that for this work - it seems like a separate feature to me.
Regards, Peng.
Regards Simon
On Tue, Jan 26, 2016 at 09:55:43AM +0800, Peng Fan wrote:
Hi Simon,
+Hans
Hi Tom,
+Mugunthan, Tom
This sounds similar, but different. The problem I'm asking to be solved is that at the starting point, there are no DTBs on the hardware. But we can in software easily and reliable tell which of say 3 boards we are on. At that point, we need to make sure that both SPL and then U-Boot know which board they are on. And if in U-Boot we use the DT to pass in all data, it has to be correct. It sounds to me like you're describing the case where the HW has the dtb stored at a known location and you just don't need it embedded within SPL/U-Boot.
Hi Simon,
+Hans
Hi Tom,
+Mugunthan, Tom
Oh. Thanks for explanation.
Yeah. I mean not embedded dtb into SPL/U-Boot, just let it be sperate file.
Thanks, Peng.
-- Tom
Hi Simon,
+Hans
Hi Tom,
+Mugunthan, Tom
On 17 January 2016 at 03:56, Christophe Ricard christophe.ricard@gmail.com wrote: > Convert omap3_spi driver to DM and keep compatibility with previous > mode. > > Signed-off-by: Christophe Ricard christophe-h.ricard@st.com > --- > > drivers/spi/Kconfig | 6 + > drivers/spi/omap3_spi.c | 439 ++++++++++++++++++++++++++++++++++++++++++------ > drivers/spi/omap3_spi.h | 14 +- > 3 files changed, 402 insertions(+), 57 deletions(-)
Can you explain how this would work, or the use case for it? We can't always assume we're reading u-boot.img off FAT for example.
Hi Simon,
+Hans
Hi Tom,
On Wed, Jan 20, 2016 at 07:46:15PM -0700, Simon Glass wrote: > +Mugunthan, Tom > > On 17 January 2016 at 03:56, Christophe Ricard > christophe.ricard@gmail.com wrote: > > Convert omap3_spi driver to DM and keep compatibility with previous > > mode. > > > > Signed-off-by: Christophe Ricard christophe-h.ricard@st.com > > --- > > > > drivers/spi/Kconfig | 6 + > > drivers/spi/omap3_spi.c | 439 ++++++++++++++++++++++++++++++++++++++++++------ > > drivers/spi/omap3_spi.h | 14 +- > > 3 files changed, 402 insertions(+), 57 deletions(-) > > This is a pretty painful conversion, with lots of #ifdefs. I think it > would be possible to use a common pointer type and reduce this. > > But perhaps it does not matter - how long must we be in the state of > supporting legacy SPI? Can we convert all TI boards to driver model?
I have no idea on this for now (:.
Regards, Peng.
-- Tom
Hi Simon, Tom,
I assume the approach you are taking is also valuable for the i2c: omap24xx patch serie: http://lists.denx.de/pipermail/u-boot/2016-January/241676.html
What are your recommendation about the pending patches ? Should i send back only the one not taking care of the DM conversion and send another serie later ?
I have seen some work ongoing on this topic on the u-boot-fdt tree on the spl-working branch. Is there a more accurate place to follow this work ?
On 26/01/2016 02:55, Peng Fan wrote:
Hi Simon,
+Hans
Hi Tom,
+Mugunthan, Tom
Regards, Peng.
On Sat, Feb 06, 2016 at 11:27:21PM +0100, Christophe Ricard wrote:
Hi Simon, Tom,
For i2c, aside from needing to defer removing the non-DM code for a while yet, there were some review comments to address in a v2 or answer as intentional. For SPI, it's all looking good and I'm assuming Jagan will have a SPI PR soon. Thanks!
Hi Simon,
+Hans
Hi Tom,
+Mugunthan, Tom
Regards, Peng.
Hi Simon, Tom,
Yes, by this week-end.
Hi Simon,
+Hans
Hi Tom,
+Mugunthan, Tom
On 17 January 2016 at 03:56, Christophe Ricard christophe.ricard@gmail.com wrote: >Convert omap3_spi driver to DM and keep compatibility with previous >mode. > >Signed-off-by: Christophe Ricard christophe-h.ricard@st.com >--- > > drivers/spi/Kconfig | 6 + > drivers/spi/omap3_spi.c | 439 ++++++++++++++++++++++++++++++++++++++++++------ > drivers/spi/omap3_spi.h | 14 +- > 3 files changed, 402 insertions(+), 57 deletions(-) This is a pretty painful conversion, with lots of #ifdefs. I think it would be possible to use a common pointer type and reduce this.
Regards, Peng.
Hi Simon, Tom,
Any idea 4/4 got differed in patchwork [1], do we have next version patches for these?
[1] https://patchwork.ozlabs.org/patch/569241/
Hi Simon,
+Hans
Hi Tom,
On Wed, Jan 20, 2016 at 07:46:15PM -0700, Simon Glass wrote: >+Mugunthan, Tom > >On 17 January 2016 at 03:56, Christophe Ricard >christophe.ricard@gmail.com wrote: >>Convert omap3_spi driver to DM and keep compatibility with previous >>mode. >> >>Signed-off-by: Christophe Ricard christophe-h.ricard@st.com >>--- >> >> drivers/spi/Kconfig | 6 + >> drivers/spi/omap3_spi.c | 439 ++++++++++++++++++++++++++++++++++++++++++------ >> drivers/spi/omap3_spi.h | 14 +- >> 3 files changed, 402 insertions(+), 57 deletions(-) >This is a pretty painful conversion, with lots of #ifdefs. I think it >would be possible to use a common pointer type and reduce this. > >But perhaps it does not matter - how long must we be in the state of >supporting legacy SPI? Can we convert all TI boards to driver model? We _really_ need some way to support more than one board per binary before we can move everything to DM only.
Regards, Peng.
Hi Jagan,
My understanding is that some work are ongoing around spl in order to support correctly DM for all spi/i2c bus drivers. As a consequence patch 4 got differed.
Hopefully Simon or Tom can comment.
Are you ok in applying patch 1 and 2 only ? or should i send a new serie with only patch 1 and 2 ?
Hi Simon, Tom,
Hi Simon,
+Hans
Hi Tom,
On 21 January 2016 at 05:24, Tom Rini trini@konsulko.com wrote: > On Wed, Jan 20, 2016 at 07:46:15PM -0700, Simon Glass wrote: >> +Mugunthan, Tom >> >> On 17 January 2016 at 03:56, Christophe Ricard >> christophe.ricard@gmail.com wrote: >>> Convert omap3_spi driver to DM and keep compatibility with previous >>> mode. >>> >>> Signed-off-by: Christophe Ricard christophe-h.ricard@st.com >>> --- >>> >>> drivers/spi/Kconfig | 6 + >>> drivers/spi/omap3_spi.c | 439 ++++++++++++++++++++++++++++++++++++++++++------ >>> drivers/spi/omap3_spi.h | 14 +- >>> 3 files changed, 402 insertions(+), 57 deletions(-) >> This is a pretty painful conversion, with lots of #ifdefs. I think it >> would be possible to use a common pointer type and reduce this. >> >> But perhaps it does not matter - how long must we be in the state of >> supporting legacy SPI? Can we convert all TI boards to driver model? > We _really_ need some way to support more than one board per binary > before we can move everything to DM only. > > I think we can kind of do this today if we stick to using platform data > for everything that's board-specific rather than SoC-defined. What we > talked about at ELCE was auto-generating the pdata from the device tree, > I think. We discussed this on IRC but since that doesn't exist as far as the mailing list is concerned...
Regards, Peng.
On Wed, Feb 10, 2016 at 10:00:55PM +0100, Christophe Ricard wrote:
Hi Jagan,
Yes, I deferred 4/4 because until we convert all of the platforms to DM (and Simon is making progress on what's required there).
1, 2 and 3? should be fine to go now and you shouldn't need to re-send them.
Hi Simon, Tom,
Hi Simon,
On Mon, Jan 25, 2016 at 06:11:24PM -0700, Simon Glass wrote: >+Hans > >Hi Tom, > >On 21 January 2016 at 05:24, Tom Rini trini@konsulko.com wrote: >>On Wed, Jan 20, 2016 at 07:46:15PM -0700, Simon Glass wrote: >>>+Mugunthan, Tom >>> >>>On 17 January 2016 at 03:56, Christophe Ricard >>>christophe.ricard@gmail.com wrote: >>>>Convert omap3_spi driver to DM and keep compatibility with previous >>>>mode. >>>> >>>>Signed-off-by: Christophe Ricard christophe-h.ricard@st.com >>>>--- >>>> >>>> drivers/spi/Kconfig | 6 + >>>> drivers/spi/omap3_spi.c | 439 ++++++++++++++++++++++++++++++++++++++++++------ >>>> drivers/spi/omap3_spi.h | 14 +- >>>> 3 files changed, 402 insertions(+), 57 deletions(-) >>>This is a pretty painful conversion, with lots of #ifdefs. I think it >>>would be possible to use a common pointer type and reduce this. >>> >>>But perhaps it does not matter - how long must we be in the state of >>>supporting legacy SPI? Can we convert all TI boards to driver model? >>We _really_ need some way to support more than one board per binary >>before we can move everything to DM only. >> >>I think we can kind of do this today if we stick to using platform data >>for everything that's board-specific rather than SoC-defined. What we >>talked about at ELCE was auto-generating the pdata from the device tree, >>I think. >We discussed this on IRC but since that doesn't exist as far as the >mailing list is concerned... > >The current plan is: > >- Adjust build system to optionally build a u-boot.img in FIT format >that includes the U-Boot binary and >1 device tree files >- Adjust SPL to load this >- Add a way for SPL to determine which device tree to select (by >calling a board-specific function) >- Have SPL pass this selected device tree to U-Boot when it starts Can dtb be sperated from the final u-boot.img, if using SPL? I mean let SPL load the u-boot.img and the dtb to correct DRAM address. And the dtb is shared with linux kernel.
Regards, Peng. >Thus we should be able to support more than one board with a single >U-Boot image. Of course this is not a perfect solution (e.g. it is >inefficient since the DTs are likely to be largely the same) but it >should be a good first step. > >I'm going to try this out with sunxi initially and plan to get some >patches out by the end of the week.
On 11 February 2016 at 02:30, Christophe Ricard christophe.ricard@gmail.com wrote:
Hi Jagan,
3/4 looks not good to me with so many ifdef, may we can do something clear similar to kirkwood_spi does.
Hi Simon, Tom,
Hi Simon,
On Mon, Jan 25, 2016 at 06:11:24PM -0700, Simon Glass wrote: > > +Hans > > Hi Tom, > > On 21 January 2016 at 05:24, Tom Rini trini@konsulko.com wrote: >> >> On Wed, Jan 20, 2016 at 07:46:15PM -0700, Simon Glass wrote: >>> >>> +Mugunthan, Tom >>> >>> On 17 January 2016 at 03:56, Christophe Ricard >>> christophe.ricard@gmail.com wrote: >>>> >>>> Convert omap3_spi driver to DM and keep compatibility with >>>> previous >>>> mode. >>>> >>>> Signed-off-by: Christophe Ricard christophe-h.ricard@st.com >>>> --- >>>> >>>> drivers/spi/Kconfig | 6 + >>>> drivers/spi/omap3_spi.c | 439 >>>> ++++++++++++++++++++++++++++++++++++++++++------ >>>> drivers/spi/omap3_spi.h | 14 +- >>>> 3 files changed, 402 insertions(+), 57 deletions(-) >>> >>> This is a pretty painful conversion, with lots of #ifdefs. I think >>> it >>> would be possible to use a common pointer type and reduce this. >>> >>> But perhaps it does not matter - how long must we be in the state >>> of >>> supporting legacy SPI? Can we convert all TI boards to driver >>> model? >> >> We _really_ need some way to support more than one board per binary >> before we can move everything to DM only. >> >> I think we can kind of do this today if we stick to using platform >> data >> for everything that's board-specific rather than SoC-defined. What >> we >> talked about at ELCE was auto-generating the pdata from the device >> tree, >> I think. > > We discussed this on IRC but since that doesn't exist as far as the > mailing list is concerned... > > The current plan is: > > - Adjust build system to optionally build a u-boot.img in FIT format > that includes the U-Boot binary and >1 device tree files > - Adjust SPL to load this > - Add a way for SPL to determine which device tree to select (by > calling a board-specific function) > - Have SPL pass this selected device tree to U-Boot when it starts
Regards, Peng. > > Thus we should be able to support more than one board with a single > U-Boot image. Of course this is not a perfect solution (e.g. it is > inefficient since the DTs are likely to be largely the same) but it > should be a good first step. > > I'm going to try this out with sunxi initially and plan to get some > patches out by the end of the week.
Hi Jagan,
I did some dm conversion on these long back which looks similar like kirkwood_spi, will post them as well so-that we can discuss.
Hi Simon, Tom,
On 26/01/2016 02:55, Peng Fan wrote: > > Hi Simon, > > On Mon, Jan 25, 2016 at 06:11:24PM -0700, Simon Glass wrote: >> >> +Hans >> >> Hi Tom, >> >> On 21 January 2016 at 05:24, Tom Rini trini@konsulko.com wrote: >>> >>> On Wed, Jan 20, 2016 at 07:46:15PM -0700, Simon Glass wrote: >>>> >>>> +Mugunthan, Tom >>>> >>>> On 17 January 2016 at 03:56, Christophe Ricard >>>> christophe.ricard@gmail.com wrote: >>>>> >>>>> Convert omap3_spi driver to DM and keep compatibility with >>>>> previous >>>>> mode. >>>>> >>>>> Signed-off-by: Christophe Ricard christophe-h.ricard@st.com >>>>> --- >>>>> >>>>> drivers/spi/Kconfig | 6 + >>>>> drivers/spi/omap3_spi.c | 439 >>>>> ++++++++++++++++++++++++++++++++++++++++++------ >>>>> drivers/spi/omap3_spi.h | 14 +- >>>>> 3 files changed, 402 insertions(+), 57 deletions(-) >>>> >>>> This is a pretty painful conversion, with lots of #ifdefs. I think >>>> it >>>> would be possible to use a common pointer type and reduce this. >>>> >>>> But perhaps it does not matter - how long must we be in the state >>>> of >>>> supporting legacy SPI? Can we convert all TI boards to driver >>>> model? >>> >>> We _really_ need some way to support more than one board per binary >>> before we can move everything to DM only. >>> >>> I think we can kind of do this today if we stick to using platform >>> data >>> for everything that's board-specific rather than SoC-defined. What >>> we >>> talked about at ELCE was auto-generating the pdata from the device >>> tree, >>> I think. >> >> We discussed this on IRC but since that doesn't exist as far as the >> mailing list is concerned... >> >> The current plan is: >> >> - Adjust build system to optionally build a u-boot.img in FIT format >> that includes the U-Boot binary and >1 device tree files >> - Adjust SPL to load this >> - Add a way for SPL to determine which device tree to select (by >> calling a board-specific function) >> - Have SPL pass this selected device tree to U-Boot when it starts > > Can dtb be sperated from the final u-boot.img, if using SPL? > I mean let SPL load the u-boot.img and the dtb to correct DRAM > address. > And the dtb is shared with linux kernel. > > Regards, > Peng. >> >> Thus we should be able to support more than one board with a single >> U-Boot image. Of course this is not a perfect solution (e.g. it is >> inefficient since the DTs are likely to be largely the same) but it >> should be a good first step. >> >> I'm going to try this out with sunxi initially and plan to get some >> patches out by the end of the week.
-- Jagan.
For several reasons: - code clarity - DM trends in u-boot ...
It is better to make omap3_spi driver 100% DM_SPI based.
drivers/spi/omap3_spi.c | 474 +++++++++++------------------------------------- drivers/spi/omap3_spi.h | 121 ------------ 2 files changed, 102 insertions(+), 493 deletions(-) delete mode 100644 drivers/spi/omap3_spi.h
diff --git a/drivers/spi/omap3_spi.c b/drivers/spi/omap3_spi.c index 09fb1ef..8ea2cc5 100644 --- a/drivers/spi/omap3_spi.c +++ b/drivers/spi/omap3_spi.c @@ -22,22 +22,93 @@ #include <spi.h> #include <malloc.h> #include <asm/io.h> -#include "omap3_spi.h" + +#if defined(CONFIG_AM33XX) || defined(CONFIG_AM43XX) +#define OMAP3_MCSPI1_BASE 0x48030100 +#define OMAP3_MCSPI2_BASE 0x481A0100 +#else +#define OMAP3_MCSPI1_BASE 0x48098000 +#define OMAP3_MCSPI2_BASE 0x4809A000 +#define OMAP3_MCSPI3_BASE 0x480B8000 +#define OMAP3_MCSPI4_BASE 0x480BA000 +#endif + +#define OMAP3_MCSPI_MAX_FREQ 48000000 + +/* OMAP3 McSPI registers */ +struct mcspi_channel { + unsigned int chconf; /* 0x2C, 0x40, 0x54, 0x68 */ + unsigned int chstat; /* 0x30, 0x44, 0x58, 0x6C */ + unsigned int chctrl; /* 0x34, 0x48, 0x5C, 0x70 */ + unsigned int tx; /* 0x38, 0x4C, 0x60, 0x74 */ + unsigned int rx; /* 0x3C, 0x50, 0x64, 0x78 */ +}; + +struct mcspi { + unsigned char res1[0x10]; + unsigned int sysconfig; /* 0x10 */ + unsigned int sysstatus; /* 0x14 */ + unsigned int irqstatus; /* 0x18 */ + unsigned int irqenable; /* 0x1C */ + unsigned int wakeupenable; /* 0x20 */ + unsigned int syst; /* 0x24 */ + unsigned int modulctrl; /* 0x28 */ + struct mcspi_channel channel[4]; /* channel0: 0x2C - 0x3C, bus 0 & 1 & 2 & 3 */ + /* channel1: 0x40 - 0x50, bus 0 & 1 */ + /* channel2: 0x54 - 0x64, bus 0 & 1 */ + /* channel3: 0x68 - 0x78, bus 0 */ +}; + +/* per-register bitmasks */ +#define OMAP3_MCSPI_SYSCONFIG_SMARTIDLE (2 << 3) +#define OMAP3_MCSPI_SYSCONFIG_ENAWAKEUP (1 << 2) +#define OMAP3_MCSPI_SYSCONFIG_AUTOIDLE (1 << 0) +#define OMAP3_MCSPI_SYSCONFIG_SOFTRESET (1 << 1) + +#define OMAP3_MCSPI_SYSSTATUS_RESETDONE (1 << 0) + +#define OMAP3_MCSPI_MODULCTRL_SINGLE (1 << 0) +#define OMAP3_MCSPI_MODULCTRL_MS (1 << 2) +#define OMAP3_MCSPI_MODULCTRL_STEST (1 << 3) + +#define OMAP3_MCSPI_CHCONF_PHA (1 << 0) +#define OMAP3_MCSPI_CHCONF_POL (1 << 1) +#define OMAP3_MCSPI_CHCONF_CLKD_MASK (0x0f << 2) +#define OMAP3_MCSPI_CHCONF_EPOL (1 << 6) +#define OMAP3_MCSPI_CHCONF_WL_MASK (0x1f << 7) +#define OMAP3_MCSPI_CHCONF_TRM_RX_ONLY (0x01 << 12) +#define OMAP3_MCSPI_CHCONF_TRM_TX_ONLY (0x02 << 12) +#define OMAP3_MCSPI_CHCONF_TRM_MASK (0x03 << 12) +#define OMAP3_MCSPI_CHCONF_DMAW (1 << 14) +#define OMAP3_MCSPI_CHCONF_DMAR (1 << 15) +#define OMAP3_MCSPI_CHCONF_DPE0 (1 << 16) +#define OMAP3_MCSPI_CHCONF_DPE1 (1 << 17) +#define OMAP3_MCSPI_CHCONF_IS (1 << 18) +#define OMAP3_MCSPI_CHCONF_TURBO (1 << 19) +#define OMAP3_MCSPI_CHCONF_FORCE (1 << 20) + +#define OMAP3_MCSPI_CHSTAT_RXS (1 << 0) +#define OMAP3_MCSPI_CHSTAT_TXS (1 << 1) +#define OMAP3_MCSPI_CHSTAT_EOT (1 << 2) + +#define OMAP3_MCSPI_CHCTRL_EN (1 << 0) +#define OMAP3_MCSPI_CHCTRL_DIS (0 << 0) + +#define OMAP3_MCSPI_WAKEUPENABLE_WKEN (1 << 0) + +struct omap3_spi_slave { + struct mcspi *regs; + unsigned int freq; + unsigned int mode; +};
-#ifdef CONFIG_DM_SPI static void spi_reset(struct udevice *dev) -#else -static void spi_reset(struct omap3_spi_slave *ds) -#endif { unsigned int tmp; -#ifdef CONFIG_DM_SPI struct omap3_spi_slave *ds = dev_get_priv(dev->parent);
-#endif - writel(OMAP3_MCSPI_SYSCONFIG_SOFTRESET, &ds->regs->sysconfig); do { tmp = readl(&ds->regs->sysstatus); @@ -51,161 +122,37 @@ static void spi_reset(struct omap3_spi_slave *ds) writel(OMAP3_MCSPI_WAKEUPENABLE_WKEN, &ds->regs->wakeupenable); }
-#ifdef CONFIG_DM_SPI static void omap3_spi_write_chconf(struct udevice *dev, int val) -#else -static void omap3_spi_write_chconf(struct omap3_spi_slave *ds, int val) -#endif { - unsigned int cs; -#ifdef CONFIG_DM_SPI struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); struct omap3_spi_slave *ds = dev_get_priv(dev->parent); - - - cs = platdata->cs; -#else - cs = ds->slave.cs; -#endif + unsigned int cs = platdata->cs;
writel(val, &ds->regs->channel[cs].chconf); /* Flash post writes to make immediate effect */ readl(&ds->regs->channel[cs].chconf); }
-#ifdef CONFIG_DM_SPI static void omap3_spi_set_enable(struct udevice *dev, int enable) -#else -static void omap3_spi_set_enable(struct omap3_spi_slave *ds, int enable) -#endif { - unsigned int cs; -#ifdef CONFIG_DM_SPI struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); struct omap3_spi_slave *ds = dev_get_priv(dev->parent); - - cs = platdata->cs; -#else - cs = ds->slave.cs; -#endif + unsigned int cs = platdata->cs;
writel(enable, &ds->regs->channel[cs].chctrl); /* Flash post writes to make immediate effect */ readl(&ds->regs->channel[cs].chctrl); }
-#ifndef CONFIG_DM_SPI -void spi_init() -{ - /* do nothing */ -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct omap3_spi_slave *ds; - struct mcspi *regs; - - /* - * OMAP3 McSPI (MultiChannel SPI) has 4 busses (modules) - * with different number of chip selects (CS, channels): - * McSPI1 has 4 CS (bus 0, cs 0 - 3) - * McSPI2 has 2 CS (bus 1, cs 0 - 1) - * McSPI3 has 2 CS (bus 2, cs 0 - 1) - * McSPI4 has 1 CS (bus 3, cs 0) - */ - - switch (bus) { - case 0: - regs = (struct mcspi *)OMAP3_MCSPI1_BASE; - break; -#ifdef OMAP3_MCSPI2_BASE - case 1: - regs = (struct mcspi *)OMAP3_MCSPI2_BASE; - break; -#endif -#ifdef OMAP3_MCSPI3_BASE - case 2: - regs = (struct mcspi *)OMAP3_MCSPI3_BASE; - break; -#endif -#ifdef OMAP3_MCSPI4_BASE - case 3: - regs = (struct mcspi *)OMAP3_MCSPI4_BASE; - break; -#endif - default: - printf("SPI error: unsupported bus %i. \ - Supported busses 0 - 3\n", bus); - return NULL; - } - - if (((bus == 0) && (cs > 3)) || - ((bus == 1) && (cs > 1)) || - ((bus == 2) && (cs > 1)) || - ((bus == 3) && (cs > 0))) { - printf("SPI error: unsupported chip select %i \ - on bus %i\n", cs, bus); - return NULL; - } - - if (max_hz > OMAP3_MCSPI_MAX_FREQ) { - printf("SPI error: unsupported frequency %i Hz. \ - Max frequency is 48 Mhz\n", max_hz); - return NULL; - } - - if (mode > SPI_MODE_3) { - printf("SPI error: unsupported SPI mode %i\n", mode); - return NULL; - } - - ds = spi_alloc_slave(struct omap3_spi_slave, bus, cs); - if (!ds) { - printf("SPI error: malloc of SPI structure failed\n"); - return NULL; - } - - ds->regs = regs; - ds->freq = max_hz; - ds->mode = mode; - - return &ds->slave; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct omap3_spi_slave *ds = to_omap3_spi(slave); - - free(ds); -} - -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - return 1; -} -#endif - -#ifdef CONFIG_DM_SPI static int omap3_spi_claim_bus(struct udevice *dev) -#else -int spi_claim_bus(struct spi_slave *slave) -#endif { - unsigned int cs; - struct omap3_spi_slave *ds; unsigned int conf, div = 0; -#ifdef CONFIG_DM_SPI struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); struct spi_slave *slave = dev_get_parent_priv(dev); + struct omap3_spi_slave *ds = dev_get_priv(dev->parent); + unsigned int cs = platdata->cs;
- ds = dev_get_priv(dev->parent); - cs = platdata->cs; ds->freq = slave->max_hz; -#else - ds = to_omap3_spi(slave); - cs = ds->slave.cs; -#endif
@@ -213,11 +160,7 @@ int spi_claim_bus(struct spi_slave *slave) * setup when switching from (reset default) slave mode * to single-channel master mode */ -#ifdef CONFIG_DM_SPI spi_reset(dev); -#else - spi_reset(ds); -#endif conf = readl(&ds->regs->modulctrl); conf &= ~(OMAP3_MCSPI_MODULCTRL_STEST | OMAP3_MCSPI_MODULCTRL_MS); conf |= OMAP3_MCSPI_MODULCTRL_SINGLE; @@ -276,83 +219,38 @@ int spi_claim_bus(struct spi_slave *slave) /* Transmit & receive mode */ conf &= ~OMAP3_MCSPI_CHCONF_TRM_MASK;
-#ifdef CONFIG_DM_SPI omap3_spi_write_chconf(dev, conf); -#else - omap3_spi_write_chconf(ds,conf); -#endif
return 0; }
-#ifdef CONFIG_DM_SPI int omap3_spi_release_bus(struct udevice *dev) -#else -void spi_release_bus(struct spi_slave *slave) -#endif { -#ifndef CONFIG_DM_SPI - struct omap3_spi_slave *ds = to_omap3_spi(slave); -#endif /* Reset the SPI hardware */ -#ifdef CONFIG_DM_SPI spi_reset(dev); -#else - spi_reset(ds); -#endif
-#ifdef CONFIG_DM_SPI return 0; -#endif }
-#ifdef CONFIG_DM_SPI int omap3_spi_write(struct udevice *dev, unsigned int len, const void *txp, unsigned long flags) -#else -int omap3_spi_write(struct spi_slave *slave, unsigned int len, const void *txp, - unsigned long flags) -#endif { - struct omap3_spi_slave *ds; int i, chconf; ulong start; - unsigned int cs; -#ifdef CONFIG_DM_SPI struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); struct spi_slave *slave = dev_get_parent_priv(dev); - - - ds = dev_get_priv(dev->parent); - cs = platdata->cs; -#else - ds = to_omap3_spi(slave); - cs = ds->slave.cs; -#endif + struct omap3_spi_slave *ds = dev_get_priv(dev->parent); + unsigned int cs = platdata->cs;
-#ifdef CONFIG_DM_SPI /* Enable the channel */ omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_EN); -#else - /* Enable the channel */ - omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_EN); -#endif - chconf &= ~(OMAP3_MCSPI_CHCONF_TRM_MASK | OMAP3_MCSPI_CHCONF_WL_MASK); -#ifdef CONFIG_DM_SPI chconf |= (slave->wordlen - 1) << 7; -#else - chconf |= (ds->slave.wordlen - 1) << 7; -#endif chconf |= OMAP3_MCSPI_CHCONF_TRM_TX_ONLY; chconf |= OMAP3_MCSPI_CHCONF_FORCE; -#ifdef CONFIG_DM_SPI omap3_spi_write_chconf(dev, chconf); -#else - omap3_spi_write_chconf(ds, chconf); -#endif
for (i = 0; i < len; i++) { /* wait till TX register is empty (TXS == 1) */ @@ -368,17 +266,9 @@ int omap3_spi_write(struct spi_slave *slave, unsigned int len, const void *txp,
/* Write the data */ unsigned int *tx = &ds->regs->channel[cs].tx; -#ifdef CONFIG_DM_SPI if (slave->wordlen > 16) -#else - if (ds->slave.wordlen > 16) -#endif writel(((u32 *)txp)[i], tx); -#ifdef CONFIG_DM_SPI else if (slave->wordlen > 8) -#else - else if (ds->slave.wordlen > 8) -#endif writel(((u16 *)txp)[i], tx); else writel(((u8 *)txp)[i], tx); @@ -390,73 +280,38 @@ int omap3_spi_write(struct spi_slave *slave, unsigned int len, const void *txp, (OMAP3_MCSPI_CHSTAT_EOT | OMAP3_MCSPI_CHSTAT_TXS)) ;
-#ifdef CONFIG_DM_SPI /* Disable the channel otherwise the next immediate RX will get affected */ omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_DIS); -#else - /* Disable the channel otherwise the next immediate RX will get affected */ - omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_DIS); -#endif
chconf &= ~OMAP3_MCSPI_CHCONF_FORCE; -#ifdef CONFIG_DM_SPI omap3_spi_write_chconf(dev, chconf); -#else - omap3_spi_write_chconf(ds, chconf); -#endif }
return 0; }
-#ifdef CONFIG_DM_SPI -int omap3_spi_read(struct udevice *dev, unsigned int len, void *rxp, - unsigned long flags) -#else -int omap3_spi_read(struct spi_slave *slave, unsigned int len, void *rxp, - unsigned long flags) -#endif +static int omap3_spi_read(struct udevice *dev, unsigned int len, void *rxp, + unsigned long flags) { - struct omap3_spi_slave *ds; - int i, chconf; - ulong start; - unsigned int cs; -#ifdef CONFIG_DM_SPI struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); struct spi_slave *slave = dev_get_parent_priv(dev); + struct omap3_spi_slave *ds = dev_get_priv(dev->parent); + int i, chconf; + ulong start; + unsigned int cs = platdata->cs;
- - ds = dev_get_priv(dev->parent); - cs = platdata->cs; -#else - ds = to_omap3_spi(slave); - cs = ds->slave.cs; -#endif chconf = readl(&ds->regs->channel[cs].chconf);
chconf &= ~(OMAP3_MCSPI_CHCONF_TRM_MASK | OMAP3_MCSPI_CHCONF_WL_MASK); -#ifdef CONFIG_DM_SPI chconf |= (slave->wordlen - 1) << 7; -#else - chconf |= (ds->slave.wordlen - 1) << 7; -#endif chconf |= OMAP3_MCSPI_CHCONF_TRM_RX_ONLY; chconf |= OMAP3_MCSPI_CHCONF_FORCE; -#ifdef CONFIG_DM_SPI omap3_spi_write_chconf(dev, chconf); -#else - omap3_spi_write_chconf(ds, chconf); -#endif
@@ -473,25 +328,13 @@ int omap3_spi_read(struct spi_slave *slave, unsigned int len, void *rxp, } /* Disable the channel to prevent furher receiving */ if(i == (len - 1)) -#ifdef CONFIG_DM_SPI omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_DIS); -#else - omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_DIS); -#endif
/* Read the data */ unsigned int *rx = &ds->regs->channel[cs].rx; -#ifdef CONFIG_DM_SPI if (slave->wordlen > 16) -#else - if (ds->slave.wordlen > 16) -#endif ((u32 *)rxp)[i] = readl(rx); -#ifdef CONFIG_DM_SPI else if (slave->wordlen > 8) -#else - else if (ds->slave.wordlen > 8) -#endif ((u16 *)rxp)[i] = (u16)readl(rx); else ((u8 *)rxp)[i] = (u8)readl(rx); @@ -499,65 +342,34 @@ int omap3_spi_read(struct spi_slave *slave, unsigned int len, void *rxp,
if (flags & SPI_XFER_END) { chconf &= ~OMAP3_MCSPI_CHCONF_FORCE; -#ifdef CONFIG_DM_SPI omap3_spi_write_chconf(dev, chconf); -#else - omap3_spi_write_chconf(ds, chconf); -#endif }
return 0; }
-#ifdef CONFIG_DM_SPI /*McSPI Transmit Receive Mode*/ -int omap3_spi_txrx(struct udevice *dev, unsigned int len, - const void *txp, void *rxp, unsigned long flags) -#else -/*McSPI Transmit Receive Mode*/ -int omap3_spi_txrx(struct spi_slave *slave, unsigned int len, - const void *txp, void *rxp, unsigned long flags) -#endif +static int omap3_spi_txrx(struct udevice *dev, unsigned int len, + const void *txp, void *rxp, unsigned long flags) { - struct omap3_spi_slave *ds; + struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); + struct spi_slave *slave = dev_get_parent_priv(dev); + struct omap3_spi_slave *ds = dev_get_priv(dev->parent); ulong start; int chconf; int i=0; - unsigned int cs; -#ifdef CONFIG_DM_SPI - struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); - struct spi_slave *slave = dev_get_parent_priv(dev); - + unsigned int cs = platdata->cs;
-#ifdef CONFIG_DM_SPI /*Enable SPI channel*/ omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_EN); -#else - /*Enable SPI channel*/ - omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_EN); -#endif
/*set TRANSMIT-RECEIVE Mode*/ chconf &= ~(OMAP3_MCSPI_CHCONF_TRM_MASK | OMAP3_MCSPI_CHCONF_WL_MASK); -#ifdef CONFIG_DM_SPI chconf |= (slave->wordlen - 1) << 7; -#else - chconf |= (ds->slave.wordlen - 1) << 7; -#endif chconf |= OMAP3_MCSPI_CHCONF_FORCE; -#ifdef CONFIG_DM_SPI omap3_spi_write_chconf(dev, chconf); -#else - omap3_spi_write_chconf(ds, chconf); -#endif
/*Shift in and out 1 byte at time*/ for (i=0; i < len; i++){ @@ -573,17 +385,9 @@ int omap3_spi_txrx(struct spi_slave *slave, unsigned int len, } /* Write the data */ unsigned int *tx = &ds->regs->channel[cs].tx; -#ifdef CONFIG_DM_SPI if (slave->wordlen > 16) -#else - if (ds->slave.wordlen > 16) -#endif writel(((u32 *)txp)[i], tx); -#ifdef CONFIG_DM_SPI else if (slave->wordlen > 8) -#else - else if (ds->slave.wordlen > 8) -#endif writel(((u16 *)txp)[i], tx); else writel(((u8 *)txp)[i], tx); @@ -600,66 +404,35 @@ int omap3_spi_txrx(struct spi_slave *slave, unsigned int len, } /* Read the data */ unsigned int *rx = &ds->regs->channel[cs].rx; -#ifdef CONFIG_DM_SPI if (slave->wordlen > 16) -#else - if (ds->slave.wordlen > 16) -#endif ((u32 *)rxp)[i] = readl(rx); -#ifdef CONFIG_DM_SPI else if (slave->wordlen > 8) -#else - else if (ds->slave.wordlen > 8) -#endif ((u16 *)rxp)[i] = (u16)readl(rx); else ((u8 *)rxp)[i] = (u8)readl(rx); }
-#ifdef CONFIG_DM_SPI /* Disable the channel */ omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_DIS); -#else - /* Disable the channel */ - omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_DIS); -#endif
/*if transfer must be terminated disable the channel*/ if (flags & SPI_XFER_END) { chconf &= ~OMAP3_MCSPI_CHCONF_FORCE; -#ifdef CONFIG_DM_SPI omap3_spi_write_chconf(dev, chconf); -#else - omap3_spi_write_chconf(ds, chconf); -#endif }
return 0; }
-#ifdef CONFIG_DM_SPI -int omap3_spi_xfer(struct udevice *dev, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) -#else -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) -#endif +static int omap3_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) { - struct omap3_spi_slave *ds; - unsigned int len, cs; - int ret = -1; -#ifdef CONFIG_DM_SPI struct dm_spi_slave_platdata *platdata = dev_get_parent_platdata(dev); struct spi_slave *slave = dev_get_parent_priv(dev); + struct omap3_spi_slave *ds = dev_get_priv(dev->parent); + unsigned int len, cs = platdata->cs; + int ret = -1;
- ds = dev_get_priv(dev->parent); - cs = platdata->cs; -#else - ds = to_omap3_spi(slave); - cs = ds->slave.cs; -#endif - -#ifdef CONFIG_DM_SPI if (slave->wordlen < 4 || slave->wordlen > 32) { printf("omap3_spi: invalid wordlen %d\n", slave->wordlen); return -1; @@ -669,74 +442,32 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, return -1;
len = bitlen / slave->wordlen; -#else - if (ds->slave.wordlen < 4 || ds->slave.wordlen > 32) { - printf("omap3_spi: invalid wordlen %d\n", ds->slave.wordlen); - return -1; - } - - if (bitlen % ds->slave.wordlen) - return -1; - - len = bitlen / ds->slave.wordlen; -#endif
if (bitlen == 0) { /* only change CS */ int chconf = readl(&ds->regs->channel[cs].chconf);
if (flags & SPI_XFER_BEGIN) { -#ifdef CONFIG_DM_SPI omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_EN); -#else - omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_EN); -#endif chconf |= OMAP3_MCSPI_CHCONF_FORCE; -#ifdef CONFIG_DM_SPI omap3_spi_write_chconf(dev, chconf); -#else - omap3_spi_write_chconf(ds, chconf); -#endif } if (flags & SPI_XFER_END) { chconf &= ~OMAP3_MCSPI_CHCONF_FORCE; -#ifdef CONFIG_DM_SPI omap3_spi_write_chconf(dev, chconf); omap3_spi_set_enable(dev, OMAP3_MCSPI_CHCTRL_DIS); -#else - omap3_spi_write_chconf(ds, chconf); - omap3_spi_set_enable(ds, OMAP3_MCSPI_CHCTRL_DIS); -#endif } ret = 0; } else { -#ifdef CONFIG_DM_SPI if (dout != NULL && din != NULL) ret = omap3_spi_txrx(dev, len, dout, din, flags); else if (dout != NULL) ret = omap3_spi_write(dev, len, dout, flags); else if (din != NULL) ret = omap3_spi_read(dev, len, din, flags); -#else - if (dout != NULL && din != NULL) - ret = omap3_spi_txrx(slave, len, dout, din, flags); - else if (dout != NULL) - ret = omap3_spi_write(slave, len, dout, flags); - else if (din != NULL) - ret = omap3_spi_read(slave, len, din, flags); -#endif } return ret; }
-void spi_cs_activate(struct spi_slave *slave) -{ -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ -} - -#ifdef CONFIG_DM_SPI static int omap3_spi_probe(struct udevice *dev) { struct omap3_spi_slave *ds = dev_get_priv(dev); @@ -779,4 +510,3 @@ U_BOOT_DRIVER(omap3_spi) = { .ops = &omap3_spi_ops, .priv_auto_alloc_size = sizeof(struct omap3_spi_slave), }; -#endif diff --git a/drivers/spi/omap3_spi.h b/drivers/spi/omap3_spi.h deleted file mode 100644 index a974ca3..0000000 --- a/drivers/spi/omap3_spi.h +++ /dev/null @@ -1,121 +0,0 @@ -/* - * Register definitions for the OMAP3 McSPI Controller - * - * Copyright (C) 2010 Dirk Behme dirk.behme@googlemail.com - * - * Parts taken from linux/drivers/spi/omap2_mcspi.c - * Copyright (C) 2005, 2006 Nokia Corporation - * - * Modified by Ruslan Araslanov ruslan.araslanov@vitecmm.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _OMAP3_SPI_H_ -#define _OMAP3_SPI_H_ - -#if defined(CONFIG_AM33XX) || defined(CONFIG_AM43XX) -#define OMAP3_MCSPI1_BASE 0x48030100 -#define OMAP3_MCSPI2_BASE 0x481A0100 -#else -#define OMAP3_MCSPI1_BASE 0x48098000 -#define OMAP3_MCSPI2_BASE 0x4809A000 -#define OMAP3_MCSPI3_BASE 0x480B8000 -#define OMAP3_MCSPI4_BASE 0x480BA000 -#endif - -#define OMAP3_MCSPI_MAX_FREQ 48000000 - -/* OMAP3 McSPI registers */ -struct mcspi_channel { - unsigned int chconf; /* 0x2C, 0x40, 0x54, 0x68 */ - unsigned int chstat; /* 0x30, 0x44, 0x58, 0x6C */ - unsigned int chctrl; /* 0x34, 0x48, 0x5C, 0x70 */ - unsigned int tx; /* 0x38, 0x4C, 0x60, 0x74 */ - unsigned int rx; /* 0x3C, 0x50, 0x64, 0x78 */ -}; - -struct mcspi { - unsigned char res1[0x10]; - unsigned int sysconfig; /* 0x10 */ - unsigned int sysstatus; /* 0x14 */ - unsigned int irqstatus; /* 0x18 */ - unsigned int irqenable; /* 0x1C */ - unsigned int wakeupenable; /* 0x20 */ - unsigned int syst; /* 0x24 */ - unsigned int modulctrl; /* 0x28 */ - struct mcspi_channel channel[4]; /* channel0: 0x2C - 0x3C, bus 0 & 1 & 2 & 3 */ - /* channel1: 0x40 - 0x50, bus 0 & 1 */ - /* channel2: 0x54 - 0x64, bus 0 & 1 */ - /* channel3: 0x68 - 0x78, bus 0 */ -}; - -/* per-register bitmasks */ -#define OMAP3_MCSPI_SYSCONFIG_SMARTIDLE (2 << 3) -#define OMAP3_MCSPI_SYSCONFIG_ENAWAKEUP BIT(2) -#define OMAP3_MCSPI_SYSCONFIG_AUTOIDLE BIT(0) -#define OMAP3_MCSPI_SYSCONFIG_SOFTRESET BIT(1) - -#define OMAP3_MCSPI_SYSSTATUS_RESETDONE BIT(0) - -#define OMAP3_MCSPI_MODULCTRL_SINGLE BIT(0) -#define OMAP3_MCSPI_MODULCTRL_MS BIT(2) -#define OMAP3_MCSPI_MODULCTRL_STEST BIT(3) - -#define OMAP3_MCSPI_CHCONF_PHA BIT(0) -#define OMAP3_MCSPI_CHCONF_POL BIT(1) -#define OMAP3_MCSPI_CHCONF_CLKD_MASK GENMASK(5, 2) -#define OMAP3_MCSPI_CHCONF_EPOL BIT(6) -#define OMAP3_MCSPI_CHCONF_WL_MASK GENMASK(11, 7) -#define OMAP3_MCSPI_CHCONF_TRM_RX_ONLY BIT(12) -#define OMAP3_MCSPI_CHCONF_TRM_TX_ONLY BIT(13) -#define OMAP3_MCSPI_CHCONF_TRM_MASK GENMASK(13, 12) -#define OMAP3_MCSPI_CHCONF_DMAW BIT(14) -#define OMAP3_MCSPI_CHCONF_DMAR BIT(15) -#define OMAP3_MCSPI_CHCONF_DPE0 BIT(16) -#define OMAP3_MCSPI_CHCONF_DPE1 BIT(17) -#define OMAP3_MCSPI_CHCONF_IS BIT(18) -#define OMAP3_MCSPI_CHCONF_TURBO BIT(19) -#define OMAP3_MCSPI_CHCONF_FORCE BIT(20) - -#define OMAP3_MCSPI_CHSTAT_RXS BIT(0) -#define OMAP3_MCSPI_CHSTAT_TXS BIT(1) -#define OMAP3_MCSPI_CHSTAT_EOT BIT(2) - -#define OMAP3_MCSPI_CHCTRL_EN BIT(0) -#define OMAP3_MCSPI_CHCTRL_DIS (0 << 0) - -#define OMAP3_MCSPI_WAKEUPENABLE_WKEN BIT(0) - -struct omap3_spi_slave { -#ifndef CONFIG_DM_SPI - struct spi_slave slave; -#endif - struct mcspi *regs; - unsigned int freq; - unsigned int mode; -}; - -#ifndef CONFIG_DM_SPI -static inline struct omap3_spi_slave *to_omap3_spi(struct spi_slave *slave) -{ - return container_of(slave, struct omap3_spi_slave, slave); -} -#endif - -#ifdef CONFIG_DM_SPI -int omap3_spi_txrx(struct udevice *dev, unsigned int len, const void *txp, - void *rxp, unsigned long flags); -int omap3_spi_write(struct udevice *dev, unsigned int len, const void *txp, - unsigned long flags); -int omap3_spi_read(struct udevice *dev, unsigned int len, void *rxp, - unsigned long flags); -#else -int omap3_spi_txrx(struct spi_slave *slave, unsigned int len, const void *txp, - void *rxp, unsigned long flags); -int omap3_spi_write(struct spi_slave *slave, unsigned int len, const void *txp, - unsigned long flags); -int omap3_spi_read(struct spi_slave *slave, unsigned int len, void *rxp, - unsigned long flags); -#endif -#endif /* _OMAP3_SPI_H_ */
participants (5)
Christophe Ricard
Jagan Teki
Peng Fan
