[U-Boot] pull request for u-boot-tegra/master
Albert,
Please pull u-boot-tegra/master into ARM/master. Please ignore previous pull requests for these patches (Tegra20 SPL from Allen Martin), as some additional work was needed to make them viable for all compilers & chips. Also, I've included Tom Rini's latest 2 lowlevel_init fixes, as Allen's work depends on them. Thanks!
The following changes since commit 7253ddf4acd3da2c8ac78c98f3ae7d6017499f72: Stephen Warren (1): ARM: add Raspberry Pi model B board, using BCM2835 SoC
git://git.denx.de/u-boot-tegra master
Allen Martin (16): mkconfig: add support for SPL CPU tegra20: rename tegra2 -> tegra20 tegra20: move tegra20 SoC code to arch/arm/cpu/tegra20-common tegra20: rename CONFIG_MACH_TEGRA_GENERIC tegra20: tec: add tegra20-common-post.h tegra20: make board mkdir commands unconditional mkconfig: remove bashisms and cleanup config.mk generation ARM: Fix arm720t SPL build tegra20: remove timer_init from SPL build ARM: add tegra20 support to arm720t tegra20: add u-boot-*-tegra.bin targets tegra20: move SDRAM param save to later in boot tegra20: enable SPL for tegra20 boards arm: enable libgcc build for SPL spl: fix SPL build of private libgcc tegra20: Remove armv4t build flags
Tom Rini (2): omap4/5/am33xx: Make lowlevel_init available to all armv7 platforms armv7: Make lowlevel_init.S's lowlevel_init do ABI compatible stack
MAINTAINERS | 18 ++-- Makefile | 26 ++++ arch/arm/cpu/arm720t/cpu.c | 2 + arch/arm/cpu/arm720t/interrupts.c | 5 + arch/arm/cpu/arm720t/start.S | 25 +++- .../cpu/{armv7/tegra2 => arm720t/tegra20}/Makefile | 28 +--- .../arch-tegra2 => cpu/arm720t/tegra20}/board.h | 11 +- .../{armv7/tegra2 => arm720t/tegra20}/config.mk | 12 -- .../{armv7/tegra2/ap20.c => arm720t/tegra20/cpu.c} | 148 ++------------------ .../ap20.h => cpu/arm720t/tegra20/cpu.h} | 15 +-- arch/arm/cpu/arm720t/tegra20/spl.c | 133 ++++++++++++++++++ arch/arm/cpu/armv7/Makefile | 6 +- .../pmu.h => cpu/armv7/lowlevel_init.S} | 35 ++++- arch/arm/cpu/armv7/omap-common/lowlevel_init.S | 18 --- arch/arm/cpu/armv7/start.S | 6 +- arch/arm/cpu/armv7/{tegra2 => tegra20}/Makefile | 15 +-- .../cpu/armv7/{tegra2 => tegra20}/cmd_enterrcm.c | 4 +- arch/arm/cpu/armv7/{tegra2 => tegra20}/config.mk | 12 -- arch/arm/cpu/armv7/{tegra2 => tegra20}/usb.c | 2 +- .../cpu/{armv7/tegra2 => tegra20-common}/Makefile | 29 ++--- arch/arm/cpu/tegra20-common/ap20.c | 131 +++++++++++++++++ .../cpu/{armv7/tegra2 => tegra20-common}/board.c | 39 ++---- .../cpu/{armv7/tegra2 => tegra20-common}/clock.c | 10 +- .../cpu/{armv7/tegra2 => tegra20-common}/crypto.c | 0 .../cpu/{armv7/tegra2 => tegra20-common}/crypto.h | 0 .../arm/cpu/{armv7/tegra2 => tegra20-common}/emc.c | 2 +- .../cpu/{armv7/tegra2 => tegra20-common}/funcmux.c | 2 +- .../tegra2 => tegra20-common}/lowlevel_init.S | 0 .../cpu/{armv7/tegra2 => tegra20-common}/pinmux.c | 4 +- .../arm/cpu/{armv7/tegra2 => tegra20-common}/pmu.c | 2 +- .../{armv7/tegra2 => tegra20-common}/sys_info.c | 2 +- .../cpu/{armv7/tegra2 => tegra20-common}/timer.c | 2 +- .../{armv7/tegra2 => tegra20-common}/warmboot.c | 18 ++-- .../tegra2 => tegra20-common}/warmboot_avp.c | 4 +- .../tegra2 => tegra20-common}/warmboot_avp.h | 0 arch/arm/include/asm/arch-am33xx/hardware.h | 3 +- arch/arm/include/asm/arch-am33xx/omap.h | 1 - arch/arm/include/asm/arch-omap4/omap.h | 1 - arch/arm/include/asm/arch-omap5/omap.h | 2 - .../asm/{arch-tegra2 => arch-tegra20}/ap20.h | 4 +- .../asm/{arch-tegra2 => arch-tegra20}/apb_misc.h | 0 .../asm/{arch-tegra2 => arch-tegra20}/board.h | 0 .../asm/{arch-tegra2 => arch-tegra20}/clk_rst.h | 0 .../asm/{arch-tegra2 => arch-tegra20}/clock.h | 0 .../asm/{arch-tegra2 => arch-tegra20}/emc.h | 0 .../asm/{arch-tegra2 => arch-tegra20}/flow.h | 0 .../asm/{arch-tegra2 => arch-tegra20}/funcmux.h | 2 +- .../asm/{arch-tegra2 => arch-tegra20}/fuse.h | 0 .../asm/{arch-tegra2 => arch-tegra20}/gp_padctrl.h | 2 +- .../asm/{arch-tegra2 => arch-tegra20}/gpio.h | 2 +- arch/arm/include/asm/arch-tegra20/hardware.h | 29 ++++ .../asm/{arch-tegra2 => arch-tegra20}/mmc.h | 8 +- .../asm/{arch-tegra2 => arch-tegra20}/pinmux.h | 0 .../asm/{arch-tegra2 => arch-tegra20}/pmc.h | 0 .../asm/{arch-tegra2 => arch-tegra20}/pmu.h | 0 .../asm/{arch-tegra2 => arch-tegra20}/scu.h | 0 .../{arch-tegra2 => arch-tegra20}/sdram_param.h | 0 .../asm/{arch-tegra2 => arch-tegra20}/sys_proto.h | 4 +- .../tegra2.h => arch-tegra20/tegra20.h} | 18 ++-- .../asm/{arch-tegra2 => arch-tegra20}/tegra_i2c.h | 2 +- .../asm/{arch-tegra2 => arch-tegra20}/tegra_spi.h | 4 +- .../asm/{arch-tegra2 => arch-tegra20}/timer.h | 6 +- .../uart-spi-switch.h | 0 .../asm/{arch-tegra2 => arch-tegra20}/uart.h | 0 .../asm/{arch-tegra2 => arch-tegra20}/usb.h | 0 .../asm/{arch-tegra2 => arch-tegra20}/warmboot.h | 0 arch/arm/lib/Makefile | 2 +- board/avionic-design/common/tamonten.c | 4 +- .../dts/{tegra2-medcom.dts => tegra20-medcom.dts} | 0 .../dts/{tegra2-plutux.dts => tegra20-plutux.dts} | 0 .../dts/{tegra2-tec.dts => tegra20-tec.dts} | 0 board/avionic-design/medcom/Makefile | 2 - board/avionic-design/plutux/Makefile | 2 - board/avionic-design/tec/Makefile | 2 - .../dts/{tegra2-paz00.dts => tegra20-paz00.dts} | 0 board/compal/paz00/Makefile | 2 - board/compal/paz00/paz00.c | 6 +- ...{tegra2-trimslice.dts => tegra20-trimslice.dts} | 0 board/compulab/trimslice/Makefile | 2 - board/compulab/trimslice/trimslice.c | 6 +- board/nvidia/common/board.c | 17 ++- board/nvidia/common/emc.c | 2 +- board/nvidia/common/uart-spi-switch.c | 2 +- .../{tegra2-harmony.dts => tegra20-harmony.dts} | 2 +- .../{tegra2-seaboard.dts => tegra20-seaboard.dts} | 0 .../{tegra2-ventana.dts => tegra20-ventana.dts} | 2 +- .../{tegra2-whistler.dts => tegra20-whistler.dts} | 2 +- board/nvidia/harmony/harmony.c | 6 +- board/nvidia/seaboard/seaboard.c | 6 +- board/nvidia/whistler/whistler.c | 6 +- boards.cfg | 23 ++-- doc/README.SPL | 12 ++ drivers/gpio/tegra_gpio.c | 12 +- drivers/i2c/tegra_i2c.c | 12 +- drivers/input/Makefile | 2 +- drivers/mmc/tegra_mmc.c | 32 ++-- drivers/mmc/tegra_mmc.h | 12 +- drivers/spi/tegra_spi.c | 10 +- include/configs/am335x_evm.h | 4 +- include/configs/harmony.h | 14 +- include/configs/medcom.h | 12 +- include/configs/omap4_common.h | 7 +- include/configs/omap5_evm.h | 7 +- include/configs/paz00.h | 12 +- include/configs/plutux.h | 12 +- include/configs/seaboard.h | 20 ++-- include/configs/tec.h | 12 +- ...{tegra2-common-post.h => tegra20-common-post.h} | 73 +++++++++- .../configs/{tegra2-common.h => tegra20-common.h} | 44 ++++-- include/configs/trimslice.h | 14 +- include/configs/ventana.h | 12 +- include/configs/whistler.h | 14 +- include/fdtdec.h | 12 +- include/serial.h | 2 +- mkconfig | 25 +++- spl/Makefile | 10 ++ 116 files changed, 793 insertions(+), 555 deletions(-) copy arch/arm/cpu/{armv7/tegra2 => arm720t/tegra20}/Makefile (56%) copy arch/arm/{include/asm/arch-tegra2 => cpu/arm720t/tegra20}/board.h (81%) copy arch/arm/cpu/{armv7/tegra2 => arm720t/tegra20}/config.mk (73%) rename arch/arm/cpu/{armv7/tegra2/ap20.c => arm720t/tegra20/cpu.c} (63%) copy arch/arm/{include/asm/arch-tegra2/ap20.h => cpu/arm720t/tegra20/cpu.h} (93%) create mode 100644 arch/arm/cpu/arm720t/tegra20/spl.c copy arch/arm/{include/asm/arch-tegra2/pmu.h => cpu/armv7/lowlevel_init.S} (57%) copy arch/arm/cpu/armv7/{tegra2 => tegra20}/Makefile (69%) rename arch/arm/cpu/armv7/{tegra2 => tegra20}/cmd_enterrcm.c (94%) rename arch/arm/cpu/armv7/{tegra2 => tegra20}/config.mk (74%) rename arch/arm/cpu/armv7/{tegra2 => tegra20}/usb.c (99%) rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/Makefile (66%) create mode 100644 arch/arm/cpu/tegra20-common/ap20.c rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/board.c (79%) rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/clock.c (99%) rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/crypto.c (100%) rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/crypto.h (100%) rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/emc.c (99%) rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/funcmux.c (99%) rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/lowlevel_init.S (100%) rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/pinmux.c (99%) rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/pmu.c (98%) rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/sys_info.c (98%) rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/timer.c (98%) rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/warmboot.c (95%) rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/warmboot_avp.c (98%) rename arch/arm/cpu/{armv7/tegra2 => tegra20-common}/warmboot_avp.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/ap20.h (98%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/apb_misc.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/board.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/clk_rst.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/clock.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/emc.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/flow.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/funcmux.h (97%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/fuse.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/gp_padctrl.h (98%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/gpio.h (99%) create mode 100644 arch/arm/include/asm/arch-tegra20/hardware.h rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/mmc.h (84%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/pinmux.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/pmc.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/pmu.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/scu.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/sdram_param.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/sys_proto.h (93%) rename arch/arm/include/asm/{arch-tegra2/tegra2.h => arch-tegra20/tegra20.h} (87%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/tegra_i2c.h (99%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/tegra_spi.h (96%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/timer.h (92%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/uart-spi-switch.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/uart.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/usb.h (100%) rename arch/arm/include/asm/{arch-tegra2 => arch-tegra20}/warmboot.h (100%) rename board/avionic-design/dts/{tegra2-medcom.dts => tegra20-medcom.dts} (100%) rename board/avionic-design/dts/{tegra2-plutux.dts => tegra20-plutux.dts} (100%) rename board/avionic-design/dts/{tegra2-tec.dts => tegra20-tec.dts} (100%) rename board/compal/dts/{tegra2-paz00.dts => tegra20-paz00.dts} (100%) rename board/compulab/dts/{tegra2-trimslice.dts => tegra20-trimslice.dts} (100%) rename board/nvidia/dts/{tegra2-harmony.dts => tegra20-harmony.dts} (92%) rename board/nvidia/dts/{tegra2-seaboard.dts => tegra20-seaboard.dts} (100%) rename board/nvidia/dts/{tegra2-ventana.dts => tegra20-ventana.dts} (92%) rename board/nvidia/dts/{tegra2-whistler.dts => tegra20-whistler.dts} (94%) rename include/configs/{tegra2-common-post.h => tegra20-common-post.h} (74%) rename include/configs/{tegra2-common.h => tegra20-common.h} (84%)
Tom Warren
