[PATCH] spl: ram: fix build warning when neither RAM_DEVICE nor DFU are enabled
Fixes the following warning:
common/spl/spl_ram.c:19:14: warning: ‘spl_ram_load_read’ defined but not used [-Wunused-function] 19 | static ulong spl_ram_load_read(struct spl_load_info *load, ulong sector, | ^~~~~~~~~~~~~~~~~
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org --- common/spl/spl_ram.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/common/spl/spl_ram.c b/common/spl/spl_ram.c index 71b7a8374bb..1a5874c3949 100644 --- a/common/spl/spl_ram.c +++ b/common/spl/spl_ram.c @@ -16,6 +16,7 @@ #include <spl.h> #include <linux/libfdt.h>
+#if CONFIG_IS_ENABLED(RAM_DEVICE) || CONFIG_IS_ENABLED(DFU) static ulong spl_ram_load_read(struct spl_load_info *load, ulong sector, ulong count, void *buf) { @@ -96,6 +97,8 @@ static int spl_ram_load_image(struct spl_image_info *spl_image,
return ret; } +#endif + #if CONFIG_IS_ENABLED(RAM_DEVICE) SPL_LOAD_IMAGE_METHOD("RAM", 0, BOOT_DEVICE_RAM, spl_ram_load_image); #endif
Does this config even make sense? What is the point of enabling SPL_RAM_SUPPORT without one of the above configs?
Maybe we should make those configs select RAM_SUPPORT instead.
- #if CONFIG_IS_ENABLED(RAM_DEVICE) SPL_LOAD_IMAGE_METHOD("RAM", 0, BOOT_DEVICE_RAM, spl_ram_load_image); #endif
I don't think so.
Yes, and make SPL_RAM_SUPPORT an internal symbol so that it cannot be enabled on its own without SPL_DFU or SPL_RAM_DEVICE. Note that SPL_DFU already selects SPL_RAM_SUPPORT but SPL_RAM_DEVICE "depends on" it.
If that sounds good to you I will post a new patch.
diff --git a/common/spl/spl_ram.c b/common/spl/spl_ram.c index 71b7a8374bb..1a5874c3949 100644 --- a/common/spl/spl_ram.c +++ b/common/spl/spl_ram.c @@ -16,6 +16,7 @@ #include <spl.h> #include <linux/libfdt.h> +#if CONFIG_IS_ENABLED(RAM_DEVICE) || CONFIG_IS_ENABLED(DFU) static ulong spl_ram_load_read(struct spl_load_info *load, ulong sector, ulong count, void *buf) { @@ -96,6 +97,8 @@ static int spl_ram_load_image(struct spl_image_info *spl_image, return ret; } +#endif
Thanks,
Jerome Forissier
Sean Anderson
