[U-Boot] [PATCH 1/3] buildman: Drop comment about Ctrl-C problem
This bug is now fixed, so drop this comment.
tools/buildman/README | 2 -- 1 file changed, 2 deletions(-)
diff --git a/tools/buildman/README b/tools/buildman/README index 5a709c6ff9e..d688b7cf006 100644 --- a/tools/buildman/README +++ b/tools/buildman/README @@ -1169,8 +1169,6 @@ access to log files. Also it would be nice if buildman could 'hunt' for problems, perhaps by building a few boards for each arch, or checking commits for changed files and building only boards which use those files.
-A specific problem to fix is that Ctrl-C does not exit buildman cleanly when -multiple builder threads are active.
Credits =======
Add a -O option which allows building with clang.
tools/buildman/README | 10 ++++++++++ tools/buildman/cmdline.py | 2 ++ tools/buildman/control.py | 2 +- tools/buildman/toolchain.py | 18 ++++++++++++++---- 4 files changed, 27 insertions(+), 5 deletions(-)
diff --git a/tools/buildman/README b/tools/buildman/README index d688b7cf006..56a99c70a2a 100644 --- a/tools/buildman/README +++ b/tools/buildman/README @@ -1046,6 +1046,16 @@ value for 'altbootcmd', but lost one for ' altbootcmd'.
The -U option uses the u-boot.env files which are produced by a build.
+ +Building with clang +=================== + +To build with clang (sandbox only), use the -O option to override the +toolchain. For example: + + buildman -O clang-7 --board sandbox + + Other options =============
diff --git a/tools/buildman/cmdline.py b/tools/buildman/cmdline.py index 93d09ca08d7..832a5145d28 100644 --- a/tools/buildman/cmdline.py +++ b/tools/buildman/cmdline.py @@ -74,6 +74,8 @@ def ParseArgs(): parser.add_option('-o', '--output-dir', type='string', dest='output_dir', default='..', help='Directory where all builds happen and buildman has its workspace (default is ../)') + parser.add_option('-O', '--override-toolchain', type='string', + help="Override host toochain to use for sandbox (e.g. 'clang-7')") parser.add_option('-Q', '--quick', action='store_true', default=False, help='Do a rough build, with limited warning resolution') parser.add_option('-p', '--full-path', action='store_true', diff --git a/tools/buildman/control.py b/tools/buildman/control.py index c900211510e..27916d3c355 100644 --- a/tools/buildman/control.py +++ b/tools/buildman/control.py @@ -141,7 +141,7 @@ def DoBuildman(options, args, toolchains=None, make_func=None, boards=None,
no_toolchains = toolchains is None if no_toolchains: - toolchains = toolchain.Toolchains() + toolchains = toolchain.Toolchains(options.override_toolchain)
if options.fetch_arch: if options.fetch_arch == 'list': diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index 4b35f400e97..a4a2e0e73a1 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -54,9 +54,11 @@ class Toolchain: arch: Architecture of toolchain as determined from the first component of the filename. E.g. arm-linux-gcc becomes arm priority: Toolchain priority (0=highest, 20=lowest) + override_toolchain: Toolchain to use for sandbox, overriding the normal + one """ def __init__(self, fname, test, verbose=False, priority=PRIORITY_CALC, - arch=None): + arch=None, override_toolchain=None): """Create a new toolchain object.
Args: @@ -68,6 +70,7 @@ class Toolchain: """ self.gcc = fname self.path = os.path.dirname(fname) + self.override_toolchain = override_toolchain
# Find the CROSS_COMPILE prefix to use for U-Boot. For example, # 'arm-linux-gnueabihf-gcc' turns into 'arm-linux-gnueabihf-'. @@ -81,6 +84,8 @@ class Toolchain: self.arch = arch else: self.arch = self.cross[:pos] if pos != -1 else 'sandbox' + if self.arch == 'sandbox' and override_toolchain: + self.gcc = override_toolchain
env = self.MakeEnvironment(False)
@@ -154,7 +159,10 @@ class Toolchain: env = dict(os.environ) wrapper = self.GetWrapper()
- if full_path: + if self.override_toolchain: + env['HOSTCC'] = self.override_toolchain + env['CC'] = self.override_toolchain + elif full_path: env['CROSS_COMPILE'] = wrapper + os.path.join(self.path, self.cross) else: env['CROSS_COMPILE'] = wrapper + self.cross @@ -180,10 +188,11 @@ class Toolchains: paths: List of paths to check for toolchains (may contain wildcards) """
- def __init__(self): + def __init__(self, override_toolchain=None): self.toolchains = {} self.prefixes = {} self.paths = [] + self.override_toolchain = override_toolchain self._make_flags = dict(bsettings.GetItems('make-flags'))
def GetPathList(self, show_warning=True): @@ -234,7 +243,8 @@ class Toolchains: priority: Priority to use for this toolchain arch: Toolchain architecture, or None if not known """ - toolchain = Toolchain(fname, test, verbose, priority, arch) + toolchain = Toolchain(fname, test, verbose, priority, arch, + self.override_toolchain) add_it = toolchain.ok if toolchain.arch in self.toolchains: add_it = (toolchain.priority <
Now that buildman supports clang, use it.
.travis.yml | 13 +++---------- 1 file changed, 3 insertions(+), 10 deletions(-)
diff --git a/.travis.yml b/.travis.yml index a061f02399c..59a00d065e3 100644 --- a/.travis.yml +++ b/.travis.yml @@ -109,16 +109,9 @@ script: # # From buildman, exit code 129 means warnings only. If we've been asked to # use clang only do one configuration. - - if [[ "${TOOLCHAIN}" == "clang" ]]; then + - if [[ "${BUILDMAN}" != "" ]]; then ret=0; - make O=../.bm-work/${TEST_PY_BD} HOSTCC=clang-7 CC=clang-7 -j$(nproc) - KCFLAGS=-Werror sandbox_config all || ret=$?; - if [[ $ret -ne 0 ]]; then - exit $ret; - fi; - elif [[ "${BUILDMAN}" != "" ]]; then - ret=0; - tools/buildman/buildman -P -E ${BUILDMAN} || ret=$?; + tools/buildman/buildman -P -E ${BUILDMAN} ${OVERRIDE}|| ret=$?; if [[ $ret -ne 0 && $ret -ne 129 ]]; then tools/buildman/buildman -sdeP ${BUILDMAN}; exit $ret; @@ -343,7 +336,7 @@ matrix: env: - TEST_PY_BD="sandbox" BUILDMAN="^sandbox$" - TOOLCHAIN="clang" + OVERRIDE="clang-7" - name: "test/py sandbox_spl" env: - TEST_PY_BD="sandbox_spl"
Applied to u-boot-dm/master, thanks!
sjg@google.com
