[U-Boot] ARM Pull Request for next
Hi Wolfgang
Please pull The following changes since commit f8ddcd58221cab63dd25c2324dd2032487f748b1: Graf Yang (1): Blackfin: bf518f-ezbrd: reset ethernet PHY during init
git://git.denx.de/u-boot-arm.git next
David Brownell (10): DaVinci Ethernet cleanup DaVinci now respects SKIP_LOWLEVEL_INIT davinci: move psc support board-->cpu davinci: cpu-specific build uses conditional make syntax davinci: split out some dm644x-specific bits from psc davinci: fix dm644x buglets davinci: add basic dm355/dm350/dm335 support davinci: display correct clock info davinci dm6446evm NAND update dm355 evm support
Jean-Christophe PLAGNIOL-VILLARD (12): arm946es: remove non used timer arm: cleanup remaining CONFIG_INIT_CRITICAL ixp/interrupts: Move conditional compilation to Makefile at91rm9200: move reset code to reset.c OMAP3: Remove dublicated interrupt code OMAP3: Reorganize Makefile style arm: timer and interrupt init rework arm920/926/926: remove non needed header ARM: Update mach-types arm/dcc: use static support to allow to use it at anytime arm/dcc: add xscale support at91: regroup IP hw init in one file per soc
Sandeep Paulraj (1): ARM DaVinci:Consolidate common u-boot.lds
Sanjeev Premi (1): OMAP3EVM: Set default bootfile
Tom Rix (7): ARM Add blue colour LED to status_led. LED Add documentation describing the status_led and colour led API. ZOOM1 Remove more legacy NAND defines. OMAP Consolidate common u-boot.lds to cpu layer. ZOOM2 Add initial support for Zoom2 OMAP3 Port kernel omap gpio interface. ZOOM2 Add support for debug board detection.
s-paulraj@ti.com (1): ARM DaVinci: Minor Updates to base addresses
MAINTAINERS | 4 + MAKEALL | 2 + Makefile | 6 + board/armltd/integratorap/integratorap.c | 2 +- board/armltd/integratorcp/integratorcp.c | 2 +- board/atmel/at91cap9adk/at91cap9adk.c | 1 - board/davinci/common/Makefile | 2 +- board/davinci/common/misc.c | 45 +- board/davinci/common/misc.h | 2 - board/davinci/dm355evm/Makefile | 52 + board/davinci/dm355evm/config.mk | 11 + board/davinci/dm355evm/dm355evm.c | 108 ++ board/davinci/dvevm/dvevm.c | 3 - board/davinci/schmoogie/schmoogie.c | 3 - board/davinci/schmoogie/u-boot.lds | 52 - board/davinci/sffsdr/sffsdr.c | 3 - board/davinci/sffsdr/u-boot.lds | 52 - board/davinci/sonata/sonata.c | 3 - board/davinci/sonata/u-boot.lds | 52 - board/m501sk/m501sk.c | 2 +- board/netstar/netstar.c | 2 +- board/omap3/beagle/u-boot.lds | 63 - board/omap3/common/Makefile | 1 + board/omap3/evm/u-boot.lds | 63 - board/omap3/overo/u-boot.lds | 63 - board/omap3/pandora/u-boot.lds | 63 - board/omap3/zoom2/Makefile | 50 + board/omap3/zoom2/config.mk | 33 + board/omap3/zoom2/debug_board.c | 59 + board/omap3/zoom2/zoom2.c | 76 + board/omap3/zoom2/zoom2.h | 149 ++ board/voiceblue/voiceblue.c | 2 +- cpu/arm1136/mx31/Makefile | 3 +- cpu/arm1136/mx31/{interrupts.c => timer.c} | 3 +- cpu/arm1136/omap24xx/Makefile | 3 +- cpu/arm1136/omap24xx/{interrupts.c => timer.c} | 3 +- cpu/arm1176/s3c64xx/Makefile | 2 +- cpu/arm1176/s3c64xx/{interrupts.c => timer.c} | 2 +- cpu/arm720t/interrupts.c | 46 +- cpu/arm920t/at91rm9200/Makefile | 14 +- cpu/arm920t/at91rm9200/reset.c | 71 + cpu/arm920t/at91rm9200/{interrupts.c => timer.c} | 39 +- cpu/arm920t/cpu.c | 1 - cpu/arm920t/imx/Makefile | 4 +- cpu/arm920t/imx/{interrupts.c => timer.c} | 3 +- cpu/arm920t/interrupts.c | 1 - cpu/arm920t/ks8695/Makefile | 3 +- cpu/arm920t/ks8695/{interrupts.c => timer.c} | 12 +- cpu/arm920t/s3c24x0/Makefile | 5 +- cpu/arm920t/s3c24x0/{interrupts.c => timer.c} | 3 +- cpu/arm925t/Makefile | 5 +- cpu/arm925t/{interrupts.c => timer.c} | 2 +- cpu/arm926ejs/Makefile | 2 +- cpu/arm926ejs/at91/Makefile | 35 +- cpu/arm926ejs/at91/at91cap9_devices.c | 176 ++ cpu/arm926ejs/at91/at91cap9_macb.c | 54 - cpu/arm926ejs/at91/at91cap9_serial.c | 76 - cpu/arm926ejs/at91/at91cap9_spi.c | 100 -- cpu/arm926ejs/at91/at91sam9260_devices.c | 184 +++ cpu/arm926ejs/at91/at91sam9260_macb.c | 63 - cpu/arm926ejs/at91/at91sam9260_serial.c | 76 - cpu/arm926ejs/at91/at91sam9260_spi.c | 99 -- .../{at91sam9261_spi.c => at91sam9261_devices.c} | 49 + cpu/arm926ejs/at91/at91sam9261_serial.c | 76 - cpu/arm926ejs/at91/at91sam9263_devices.c | 184 +++ cpu/arm926ejs/at91/at91sam9263_macb.c | 54 - cpu/arm926ejs/at91/at91sam9263_serial.c | 76 - cpu/arm926ejs/at91/at91sam9263_spi.c | 99 -- cpu/arm926ejs/at91/at91sam9263_usb.c | 35 - .../{at91sam9rl_serial.c => at91sam9rl_devices.c} | 37 + cpu/arm926ejs/at91/at91sam9rl_spi.c | 64 - cpu/arm926ejs/cpu.c | 1 - cpu/arm926ejs/davinci/Makefile | 16 +- cpu/arm926ejs/davinci/config.mk | 37 + cpu/arm926ejs/davinci/cpu.c | 131 ++ .../common/psc.h => cpu/arm926ejs/davinci/dm355.c | 33 +- cpu/arm926ejs/davinci/dm644x.c | 96 ++ .../davinci/common => cpu/arm926ejs/davinci}/psc.c | 103 +- cpu/arm926ejs/davinci/timer.c | 1 - .../dvevm => cpu/arm926ejs/davinci}/u-boot.lds | 0 cpu/arm926ejs/interrupts.c | 57 - cpu/arm926ejs/nomadik/timer.c | 1 - cpu/arm926ejs/omap/cpuinfo.c | 1 - cpu/arm926ejs/omap/timer.c | 1 - cpu/arm926ejs/versatile/timer.c | 1 - cpu/arm946es/Makefile | 3 +- cpu/arm946es/cpu.c | 1 - cpu/arm946es/interrupts.c | 158 -- cpu/arm946es/start.S | 4 +- cpu/arm_cortexa8/omap3/Makefile | 9 +- cpu/arm_cortexa8/omap3/config.mk | 2 + cpu/arm_cortexa8/omap3/gpio.c | 185 +++ cpu/arm_cortexa8/omap3/interrupts.c | 266 --- cpu/arm_cortexa8/omap3/timer.c | 138 ++ .../zoom1 => cpu/arm_cortexa8/omap3}/u-boot.lds | 5 - cpu/arm_intcm/start.S | 4 +- cpu/ixp/Makefile | 5 +- cpu/ixp/interrupts.c | 63 +- cpu/ixp/timer.c | 54 + cpu/lh7a40x/Makefile | 2 +- cpu/lh7a40x/cpu.c | 1 - cpu/lh7a40x/{interrupts.c => timer.c} | 3 +- cpu/pxa/Makefile | 8 +- cpu/pxa/{interrupts.c => timer.c} | 7 +- cpu/s3c44b0/Makefile | 5 +- cpu/s3c44b0/{interrupts.c => timer.c} | 2 +- cpu/sa1100/Makefile | 4 +- cpu/sa1100/{interrupts.c => timer.c} | 5 +- doc/README.LED | 78 + doc/README.omap3 | 47 +- drivers/serial/arm_dcc.c | 170 +-- include/arm920t.h | 12 - include/arm926ejs.h | 8 - include/arm946es.h | 8 - include/asm-arm/arch-davinci/hardware.h | 74 +- include/asm-arm/arch-omap3/gpio.h | 86 + include/asm-arm/mach-types.h | 1704 +++++++++++++++++++- include/asm-arm/u-boot-arm.h | 3 + include/configs/SMN42.h | 2 - include/configs/armadillo.h | 2 +- include/configs/davinci_dm355evm.h | 190 +++ include/configs/davinci_dvevm.h | 9 + include/configs/davinci_schmoogie.h | 2 + include/configs/davinci_sffsdr.h | 5 +- include/configs/davinci_sonata.h | 2 + include/configs/gcplus.h | 2 +- include/configs/integratorap.h | 2 +- include/configs/ixdpg425.h | 1 + include/configs/lpc2292sodimm.h | 2 - include/configs/omap3_evm.h | 2 + include/configs/omap3_zoom1.h | 13 - include/configs/omap3_zoom2.h | 226 +++ include/configs/pdnb3.h | 1 + include/status_led.h | 4 + lib_arm/board.c | 7 + 135 files changed, 4571 insertions(+), 2299 deletions(-) create mode 100644 board/davinci/dm355evm/Makefile create mode 100644 board/davinci/dm355evm/config.mk create mode 100644 board/davinci/dm355evm/dm355evm.c delete mode 100644 board/davinci/schmoogie/u-boot.lds delete mode 100644 board/davinci/sffsdr/u-boot.lds delete mode 100644 board/davinci/sonata/u-boot.lds delete mode 100644 board/omap3/beagle/u-boot.lds delete mode 100644 board/omap3/evm/u-boot.lds delete mode 100644 board/omap3/overo/u-boot.lds delete mode 100644 board/omap3/pandora/u-boot.lds create mode 100644 board/omap3/zoom2/Makefile create mode 100644 board/omap3/zoom2/config.mk create mode 100644 board/omap3/zoom2/debug_board.c create mode 100644 board/omap3/zoom2/zoom2.c create mode 100644 board/omap3/zoom2/zoom2.h rename cpu/arm1136/mx31/{interrupts.c => timer.c} (97%) rename cpu/arm1136/omap24xx/{interrupts.c => timer.c} (97%) rename cpu/arm1176/s3c64xx/{interrupts.c => timer.c} (99%) create mode 100644 cpu/arm920t/at91rm9200/reset.c rename cpu/arm920t/at91rm9200/{interrupts.c => timer.c} (78%) rename cpu/arm920t/imx/{interrupts.c => timer.c} (98%) rename cpu/arm920t/ks8695/{interrupts.c => timer.c} (93%) rename cpu/arm920t/s3c24x0/{interrupts.c => timer.c} (99%) rename cpu/arm925t/{interrupts.c => timer.c} (99%) create mode 100644 cpu/arm926ejs/at91/at91cap9_devices.c delete mode 100644 cpu/arm926ejs/at91/at91cap9_macb.c delete mode 100644 cpu/arm926ejs/at91/at91cap9_serial.c delete mode 100644 cpu/arm926ejs/at91/at91cap9_spi.c create mode 100644 cpu/arm926ejs/at91/at91sam9260_devices.c delete mode 100644 cpu/arm926ejs/at91/at91sam9260_macb.c delete mode 100644 cpu/arm926ejs/at91/at91sam9260_serial.c delete mode 100644 cpu/arm926ejs/at91/at91sam9260_spi.c rename cpu/arm926ejs/at91/{at91sam9261_spi.c => at91sam9261_devices.c} (72%) delete mode 100644 cpu/arm926ejs/at91/at91sam9261_serial.c create mode 100644 cpu/arm926ejs/at91/at91sam9263_devices.c delete mode 100644 cpu/arm926ejs/at91/at91sam9263_macb.c delete mode 100644 cpu/arm926ejs/at91/at91sam9263_serial.c delete mode 100644 cpu/arm926ejs/at91/at91sam9263_spi.c delete mode 100644 cpu/arm926ejs/at91/at91sam9263_usb.c rename cpu/arm926ejs/at91/{at91sam9rl_serial.c => at91sam9rl_devices.c} (70%) delete mode 100644 cpu/arm926ejs/at91/at91sam9rl_spi.c create mode 100644 cpu/arm926ejs/davinci/config.mk create mode 100644 cpu/arm926ejs/davinci/cpu.c rename board/davinci/common/psc.h => cpu/arm926ejs/davinci/dm355.c (63%) create mode 100644 cpu/arm926ejs/davinci/dm644x.c rename {board/davinci/common => cpu/arm926ejs/davinci}/psc.c (56%) rename {board/davinci/dvevm => cpu/arm926ejs/davinci}/u-boot.lds (100%) delete mode 100644 cpu/arm926ejs/interrupts.c delete mode 100644 cpu/arm946es/interrupts.c create mode 100644 cpu/arm_cortexa8/omap3/gpio.c delete mode 100644 cpu/arm_cortexa8/omap3/interrupts.c create mode 100644 cpu/arm_cortexa8/omap3/timer.c rename {board/omap3/zoom1 => cpu/arm_cortexa8/omap3}/u-boot.lds (90%) rename cpu/lh7a40x/{interrupts.c => timer.c} (98%) rename cpu/pxa/{interrupts.c => timer.c} (96%) rename cpu/s3c44b0/{interrupts.c => timer.c} (98%) rename cpu/sa1100/{interrupts.c => timer.c} (95%) create mode 100644 doc/README.LED delete mode 100644 include/arm920t.h delete mode 100644 include/arm926ejs.h delete mode 100644 include/arm946es.h create mode 100644 include/asm-arm/arch-omap3/gpio.h create mode 100644 include/configs/davinci_dm355evm.h create mode 100644 include/configs/omap3_zoom2.h
Best Regards, J.
Dear Jean-Christophe PLAGNIOL-VILLARD,
In message 20090515202302.GK16288@game.jcrosoft.org you wrote:
Hi Wolfgang
Sorry, this tree does not apply cleanly to the current "next" branch:
... CONFLICT (delete/modify): board/davinci/schmoogie/u-boot.lds deleted in fc7f767e037b8d6bc753447a502d551d39f0c774 and modified in HEAD. Version HEAD of board/davinci/schmoogie/u-boot.lds left in tree. CONFLICT (delete/modify): board/davinci/sffsdr/u-boot.lds deleted in fc7f767e037b8d6bc753447a502d551d39f0c774 and modified in HEAD. Version HEAD of board/davinci/sffsdr/u-boot.lds left in tree. CONFLICT (delete/modify): board/davinci/sonata/u-boot.lds deleted in fc7f767e037b8d6bc753447a502d551d39f0c774 and modified in HEAD. Version HEAD of board/davinci/sonata/u-boot.lds left in tree. CONFLICT (delete/modify): board/omap3/beagle/u-boot.lds deleted in fc7f767e037b8d6bc753447a502d551d39f0c774 and modified in HEAD. Version HEAD of board/omap3/beagle/u-boot.lds left in tree. CONFLICT (delete/modify): board/omap3/evm/u-boot.lds deleted in fc7f767e037b8d6bc753447a502d551d39f0c774 and modified in HEAD. Version HEAD of board/omap3/evm/u-boot.lds left in tree. CONFLICT (delete/modify): board/omap3/overo/u-boot.lds deleted in fc7f767e037b8d6bc753447a502d551d39f0c774 and modified in HEAD. Version HEAD of board/omap3/overo/u-boot.lds left in tree. CONFLICT (delete/modify): board/omap3/pandora/u-boot.lds deleted in fc7f767e037b8d6bc753447a502d551d39f0c774 and modified in HEAD. Version HEAD of board/omap3/pandora/u-boot.lds left in tree. ... CONFLICT (delete/modify): cpu/arm926ejs/at91/at91sam9260_macb.c deleted in fc7f767e037b8d6bc753447a502d551d39f0c774 and modified in HEAD. Version HEAD of cpu/arm926ejs/at91/at91sam9260_macb.c left in tree. ... CONFLICT (delete/modify): cpu/arm926ejs/interrupts.c deleted in fc7f767e037b8d6bc753447a502d551d39f0c774 and modified in HEAD. Version HEAD of cpu/arm926ejs/interrupts.c left in tree. ... CONFLICT (delete/modify): cpu/arm946es/interrupts.c deleted in fc7f767e037b8d6bc753447a502d551d39f0c774 and modified in HEAD. Version HEAD of cpu/arm946es/interrupts.c left in tree. ... CONFLICT (delete/modify): cpu/arm_cortexa8/omap3/interrupts.c deleted in fc7f767e037b8d6bc753447a502d551d39f0c774 and modified in HEAD. Version HEAD of cpu/arm_cortexa8/omap3/interrupts.c left in tree. ... Automatic merge failed; fix conflicts and then commit the result.
Please clean up & rebase your tree and submit a new pull request.
Thanks.
