[U-Boot] [PATCH 1/2] spl: define kernel and dtb name for falcon mode from menuconfig
If we use falcon mode with ext or fat filesystem, we have to define CONFIG_SPL_FS_LOAD_KERNEL_NAME and CONFIG_SPL_FS_LOAD_ARGS_NAME in the board header.
However a header can be used for different boards (e.g Marsboard and riotboardlike use embestmx6boards.h). We can aslo have some project with binaries in different places.
The two previous problem let me think that it can be easier to add this information in the config file and have an entry in menuconfig to define them, instead of patching source code.
This patch propose a solution.
Signed-off-by: Fabien Lahoudere fabien.lahoudere@collabora.com --- common/spl/Kconfig | 18 ++++++++++++++++++ configs/riotboard_spl_defconfig | 2 +- include/configs/embestmx6boards.h | 2 -- 3 files changed, 19 insertions(+), 3 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index d0564621d4..dd0c4eb8ac 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -551,6 +551,24 @@ config SPL_OS_BOOT Enable booting directly to an OS from SPL. for more info read doc/README.falcon
+config SPL_FS_LOAD_KERNEL_NAME + string "Falcon mode image name" + depends on (SPL_OS_BOOT && (SPL_EXT_SUPPORT || SPL_FAT_SUPPORT)) + default "uImage" + help + If falcon mode is enabled (SPL_OS_BOOT) and you chose to boot + from ext or fat partition, you need to define the name of the + kernel to boot. + +config SPL_FS_LOAD_ARGS_NAME + string "Falcon mode device tree name" + depends on (SPL_OS_BOOT && SPL_OF_LIBFDT && (SPL_EXT_SUPPORT || SPL_FAT_SUPPORT)) + default "args" + help + If falcon mode is enabled (SPL_OS_BOOT) and you need a device + tree to bootchose to boot from ext or fat partition, define here + the name of the dtb. + if SPL_OS_BOOT config SYS_OS_BASE hex "addr, where OS is found" diff --git a/configs/riotboard_spl_defconfig b/configs/riotboard_spl_defconfig index 8b5459aa1a..6561cc91f9 100644 --- a/configs/riotboard_spl_defconfig +++ b/configs/riotboard_spl_defconfig @@ -17,9 +17,9 @@ CONFIG_BOOTCOMMAND="run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_ARGS_NAME="imx6dl-riotboard.dtb" # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 7e7de4dae6..98681fb3e0 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -113,8 +113,6 @@ #include "imx6_spl.h" /* RiOTboard */ #define CONFIG_SYS_SPL_ARGS_ADDR 0x13000000 -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "imx6dl-riotboard.dtb"
#define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0 /* offset 69KB */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0 /* offset 69KB */
Move kernel and dtb name variable from headers to defconfig or use default value from KConfig.
Signed-off-by: Fabien Lahoudere fabien.lahoudere@collabora.com --- configs/xilinx_zynqmp_zc1232_revA_defconfig | 2 ++ configs/xilinx_zynqmp_zc1254_revA_defconfig | 2 ++ configs/xilinx_zynqmp_zc1275_revA_defconfig | 2 ++ configs/xilinx_zynqmp_zc1275_revB_defconfig | 2 ++ configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 2 ++ configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 2 ++ configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig | 2 ++ configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 2 ++ configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 2 ++ configs/xilinx_zynqmp_zcu100_revC_defconfig | 2 ++ configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 2 ++ configs/xilinx_zynqmp_zcu102_revA_defconfig | 2 ++ configs/xilinx_zynqmp_zcu102_revB_defconfig | 2 ++ configs/xilinx_zynqmp_zcu104_revA_defconfig | 2 ++ configs/xilinx_zynqmp_zcu104_revC_defconfig | 2 ++ configs/xilinx_zynqmp_zcu106_revA_defconfig | 2 ++ configs/xilinx_zynqmp_zcu111_revA_defconfig | 2 ++ include/configs/imx6-engicam.h | 2 -- include/configs/imx6_logic.h | 2 -- include/configs/imx6dl-mamoj.h | 2 -- include/configs/mccmon6.h | 3 ++- include/configs/mx6sabreauto.h | 2 -- include/configs/mx6sabresd.h | 2 -- include/configs/pico-imx6ul.h | 2 -- include/configs/pico-imx7d.h | 2 -- include/configs/tam3517-common.h | 4 ---- include/configs/ti_armv7_common.h | 4 ---- include/configs/vyasa-rk3288.h | 2 -- include/configs/xilinx_zynqmp.h | 5 ----- include/configs/zynq-common.h | 3 ++- 30 files changed, 38 insertions(+), 31 deletions(-)
diff --git a/configs/xilinx_zynqmp_zc1232_revA_defconfig b/configs/xilinx_zynqmp_zc1232_revA_defconfig index 7521fc4e34..551a07e3f0 100644 --- a/configs/xilinx_zynqmp_zc1232_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1232_revA_defconfig @@ -14,6 +14,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zc1254_revA_defconfig b/configs/xilinx_zynqmp_zc1254_revA_defconfig index e0822b931e..f7164d80e6 100644 --- a/configs/xilinx_zynqmp_zc1254_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1254_revA_defconfig @@ -14,6 +14,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zc1275_revA_defconfig b/configs/xilinx_zynqmp_zc1275_revA_defconfig index 3afed69737..81206ba94c 100644 --- a/configs/xilinx_zynqmp_zc1275_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1275_revA_defconfig @@ -14,6 +14,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zc1275_revB_defconfig b/configs/xilinx_zynqmp_zc1275_revB_defconfig index 7e31b1112f..219be45d3e 100644 --- a/configs/xilinx_zynqmp_zc1275_revB_defconfig +++ b/configs/xilinx_zynqmp_zc1275_revB_defconfig @@ -15,6 +15,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index ec26dd70fd..425de6dea0 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index c2b3d189ec..b9d7b27b44 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig index b853e2f56f..832ba693cf 100644 --- a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig @@ -15,6 +15,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index a0bbc0fbde..350c6045c1 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -13,6 +13,8 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index 0625d195c9..bdbdcf0780 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -14,6 +14,8 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zcu100_revC_defconfig b/configs/xilinx_zynqmp_zcu100_revC_defconfig index dc1e7cd824..9bd8da3c2c 100644 --- a/configs/xilinx_zynqmp_zcu100_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu100_revC_defconfig @@ -15,6 +15,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index e41366ecf7..c965920edf 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index 02dd5ed2b7..47b0a33e68 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 78deb6a967..cddf96defd 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zcu104_revA_defconfig b/configs/xilinx_zynqmp_zcu104_revA_defconfig index ff57ca8674..274e1eeb32 100644 --- a/configs/xilinx_zynqmp_zcu104_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revA_defconfig @@ -15,6 +15,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zcu104_revC_defconfig b/configs/xilinx_zynqmp_zcu104_revC_defconfig index 33258e41b2..69fd23cc2f 100644 --- a/configs/xilinx_zynqmp_zcu104_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revC_defconfig @@ -15,6 +15,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zcu106_revA_defconfig b/configs/xilinx_zynqmp_zcu106_revA_defconfig index 210c9a347f..3f5697bc81 100644 --- a/configs/xilinx_zynqmp_zcu106_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu106_revA_defconfig @@ -15,6 +15,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/configs/xilinx_zynqmp_zcu111_revA_defconfig b/configs/xilinx_zynqmp_zcu111_revA_defconfig index 8bace6d808..3ae09762ca 100644 --- a/configs/xilinx_zynqmp_zcu111_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu111_revA_defconfig @@ -15,6 +15,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y diff --git a/include/configs/imx6-engicam.h b/include/configs/imx6-engicam.h index 7baa265934..f5890b3585 100644 --- a/include/configs/imx6-engicam.h +++ b/include/configs/imx6-engicam.h @@ -167,8 +167,6 @@
/* Falcon Mode */ #ifdef CONFIG_SPL_OS_BOOT -# define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -# define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" # define CONFIG_CMD_SPL # define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000 # define CONFIG_CMD_SPL_WRITE_SIZE (128 * SZ_1K) diff --git a/include/configs/imx6_logic.h b/include/configs/imx6_logic.h index e55941408c..dcdabbbc7d 100644 --- a/include/configs/imx6_logic.h +++ b/include/configs/imx6_logic.h @@ -160,8 +160,6 @@ #endif
/* Falcon Mode */ -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" #define CONFIG_SYS_SPL_ARGS_ADDR 0x15000000
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/imx6dl-mamoj.h b/include/configs/imx6dl-mamoj.h index 030dbedce8..b7d3e0e8b7 100644 --- a/include/configs/imx6dl-mamoj.h +++ b/include/configs/imx6dl-mamoj.h @@ -63,8 +63,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
/* Falcon */ -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" #define CONFIG_CMD_SPL #define CONFIG_SYS_SPL_ARGS_ADDR 0x13000000 #define CONFIG_CMD_SPL_WRITE_SIZE (128 * SZ_1K) diff --git a/include/configs/mccmon6.h b/include/configs/mccmon6.h index 644f339993..2ee23a6db7 100644 --- a/include/configs/mccmon6.h +++ b/include/configs/mccmon6.h @@ -28,8 +28,9 @@ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR (0x800) #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS (0x80) #define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR (0x1000) -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" +#if !defined CONFIG_SPL_FS_LOAD_ARGS_NAME #define CONFIG_SPL_FS_LOAD_ARGS_NAME "imx6q-mccmon.dtb" +#endif
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M) diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index e444930dc8..ee19605139 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -29,8 +29,6 @@
/* Falcon Mode */ #ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" #define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 555942a2c2..0c2e89e7e0 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -21,8 +21,6 @@ #include "mx6sabre_common.h"
/* Falcon Mode */ -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" #define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index 8082b74c9c..aac79479be 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -16,8 +16,6 @@
#ifdef CONFIG_SPL_OS_BOOT /* Falcon Mode */ -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" #define CONFIG_SYS_SPL_ARGS_ADDR 0x88000000
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index 2bc42a04a0..aa34c8b509 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -14,8 +14,6 @@
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index dd71d89840..37e7993575 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -155,10 +155,6 @@ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
-/* FAT */ -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" - /* RAW SD card / eMMC */ #define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0x900 /* address 0x120000 */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x80 /* address 0x10000 */ diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 55b9b45eec..6a5dfede2b 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -168,10 +168,6 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
#ifdef CONFIG_SPL_OS_BOOT -/* FAT */ -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" - /* RAW SD card / eMMC */ #define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0x1700 /* address 0x2E0000 */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x1500 /* address 0x2A0000 */ diff --git a/include/configs/vyasa-rk3288.h b/include/configs/vyasa-rk3288.h index 382fdac4c0..5867e33923 100644 --- a/include/configs/vyasa-rk3288.h +++ b/include/configs/vyasa-rk3288.h @@ -24,8 +24,6 @@ #define CONFIG_SPL_OS_BOOT
/* Falcon Mode */ -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" #define CONFIG_CMD_SPL #define CONFIG_SYS_SPL_ARGS_ADDR 0x0ffe5000 #define CONFIG_CMD_SPL_WRITE_SIZE (128 * SZ_1K) diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 0ab32611ce..9a77fe3043 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -209,13 +209,8 @@ # define CONFIG_SYS_SPI_U_BOOT_OFFS 0x170000 #endif
-/* u-boot is like dtb */ -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "u-boot.bin" #define CONFIG_SYS_SPL_ARGS_ADDR 0x8000000
-/* ATF is my kernel image */ -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "atf-uboot.ub" - /* FIT load address for RAM boot */ #define CONFIG_SPL_LOAD_FIT_ADDRESS 0x10000000
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 864f3220f3..a990a48770 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -252,8 +252,9 @@ /* Address in RAM where the parameters must be copied by SPL. */ #define CONFIG_SYS_SPL_ARGS_ADDR 0x10000000
+#if !defined CONFIG_SPL_FS_LOAD_ARGS_NAME #define CONFIG_SPL_FS_LOAD_ARGS_NAME "system.dtb" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" +#endif
/* Not using MMC raw mode - just for compilation purpose */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0
Fabien Lahoudere
