[U-Boot-Users] [PATCH] ppc4xx: Add CFG_MEM_TOP_HIDE to Denali SPD-based SDRAM setup
Signed-off-by: Larry Johnson lrj@acm.org --- cpu/ppc4xx/denali_spd_ddr2.c | 27 ++++++++++++++------------- 1 files changed, 14 insertions(+), 13 deletions(-)
diff --git a/cpu/ppc4xx/denali_spd_ddr2.c b/cpu/ppc4xx/denali_spd_ddr2.c index 60f89c9..e20c9eb 100644 --- a/cpu/ppc4xx/denali_spd_ddr2.c +++ b/cpu/ppc4xx/denali_spd_ddr2.c @@ -1093,10 +1093,10 @@ long int initdram(int board_type)
program_ddr0_06(dimm_ranks, iic0_dimm_addr, num_dimm_banks, sdram_freq);
- /*------------------------------------------------------------------ + /* * TODO: tFAW not found in SPD. Value of 13 taken from Sequoia - * board SDRAM, but may be overly concervate. - *-----------------------------------------------------------------*/ + * board SDRAM, but may be overly conservative. + */ mtsdram(DDR0_07, DDR0_07_NO_CMD_INIT_ENCODE(0) | DDR0_07_TFAW_ENCODE(13) | DDR0_07_AUTO_REFRESH_MODE_ENCODE(1) | @@ -1181,26 +1181,29 @@ long int initdram(int board_type) denali_wait_for_dlllock();
#if defined(CONFIG_DDR_DATA_EYE) - /* -----------------------------------------------------------+ - * Perform data eye search if requested. - * ----------------------------------------------------------*/ - program_tlb(0, CFG_SDRAM_BASE, dram_size, TLB_WORD2_I_ENABLE); + /* + * Map the first 1 MiB of memory in the TLB, and perform the data eye + * search. + */ + program_tlb(0, CFG_SDRAM_BASE, TLB_1MB_SIZE, TLB_WORD2_I_ENABLE); denali_core_search_data_eye(); denali_sdram_register_dump(); - remove_tlb(CFG_SDRAM_BASE, dram_size); + remove_tlb(CFG_SDRAM_BASE, TLB_1MB_SIZE); #endif
#if defined(CONFIG_ZERO_SDRAM) || defined(CONFIG_DDR_ECC) program_tlb(0, CFG_SDRAM_BASE, dram_size, 0); sync(); - eieio(); /* Zero the memory */ debug("Zeroing SDRAM..."); - dcbz_area(CFG_SDRAM_BASE, dram_size); +#if defined(CFG_MEM_TOP_HIDE) + dcbz_area(CFG_SDRAM_BASE, dram_size - CFG_MEM_TOP_HIDE); +#else +#error Please define CFG_MEM_TOP_HIDE (see README) in your board config file +#endif dflush(); debug("Completed\n"); sync(); - eieio(); remove_tlb(CFG_SDRAM_BASE, dram_size);
#if defined(CONFIG_DDR_ECC) @@ -1211,7 +1214,6 @@ long int initdram(int board_type) u32 val;
sync(); - eieio(); /* Clear error status */ mfsdram(DDR0_00, val); mtsdram(DDR0_00, val | DDR0_00_INT_ACK_ALL); @@ -1229,7 +1231,6 @@ long int initdram(int board_type) print_mcsr(); #endif sync(); - eieio(); } #endif /* defined(CONFIG_DDR_ECC) */ #endif /* defined(CONFIG_ZERO_SDRAM) || defined(CONFIG_DDR_ECC) */
Applied to u-boot-ppc4xx. Thanks.
Best regards, Stefan
Larry Johnson
Stefan Roese
