[U-Boot] [PATCH] cm_t35: Fix cm_t35 for weak splash_screen_prepare
Signed-off-by: Robert Winkler robert.winkler@boundarydevices.com --- board/compulab/cm_t35/cm_t35.c | 2 +- include/configs/cm_t35.h | 1 - 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/board/compulab/cm_t35/cm_t35.c b/board/compulab/cm_t35/cm_t35.c index b0b80e5..95098af 100644 --- a/board/compulab/cm_t35/cm_t35.c +++ b/board/compulab/cm_t35/cm_t35.c @@ -120,7 +120,7 @@ static inline int splash_load_from_nand(void) } #endif /* CONFIG_CMD_NAND */
-int board_splash_screen_prepare(void) +int splash_screen_prepare(void) { char *env_splashimage_value; u32 bmp_load_addr; diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index c6e357a..b258da9 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -339,6 +339,5 @@ #define CONFIG_SPLASH_SCREEN #define CONFIG_CMD_BMP #define CONFIG_BMP_16BPP -#define CONFIG_SPLASH_SCREEN_PREPARE
#endif /* __CONFIG_H */
Hi Robert,
We lack a commit message here...
Also, I would write here (not a part of commit message) that this patch should be applied only in case the patch: "video: lcd: Make splash_screen_prepare weak, remove config macro is applied.
May be it is even better to make this patch the 3rd in the series changing the splash prepare stuff?
Igor Grinberg
Robert Winkler
