[U-Boot] [PATCH v2] x86: Drop FSP error defines and use EFI instead
Now that we have an efi.h header we can use that for FSP error defines. Drop the FSP ones.
Changes in v2: - Drop checking against EFI_STATUS since this reduces code readability
arch/x86/include/asm/fsp/fsp_types.h | 11 ----------- arch/x86/lib/fsp/fsp_common.c | 3 ++- 2 files changed, 2 insertions(+), 12 deletions(-)
diff --git a/arch/x86/include/asm/fsp/fsp_types.h b/arch/x86/include/asm/fsp/fsp_types.h index f32d827..4fe69f2 100644 --- a/arch/x86/include/asm/fsp/fsp_types.h +++ b/arch/x86/include/asm/fsp/fsp_types.h @@ -68,15 +68,4 @@ struct efi_guid { #define SIGNATURE_64(A, B, C, D, E, F, G, H) \ (SIGNATURE_32(A, B, C, D) | ((u64)(SIGNATURE_32(E, F, G, H)) << 32))
-/* - * Define FSP API return status code. - * Compatiable with EFI_STATUS defined in PI Spec. - */ -#define FSP_SUCCESS 0 -#define FSP_INVALID_PARAM 0x80000002 -#define FSP_UNSUPPORTED 0x80000003 -#define FSP_DEVICE_ERROR 0x80000007 -#define FSP_NOT_FOUND 0x8000000E -#define FSP_ALREADY_STARTED 0x80000014 - #endif diff --git a/arch/x86/lib/fsp/fsp_common.c b/arch/x86/lib/fsp/fsp_common.c index 6f72c6d..6a0a026 100644 --- a/arch/x86/lib/fsp/fsp_common.c +++ b/arch/x86/lib/fsp/fsp_common.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <efi.h> #include <errno.h> #include <asm/io.h> #include <asm/post.h> @@ -46,7 +47,7 @@ void board_final_cleanup(void) /* call into FspNotify */ debug("Calling into FSP (notify phase INIT_PHASE_BOOT): "); status = fsp_notify(NULL, INIT_PHASE_BOOT); - if (status != FSP_SUCCESS) + if (status) debug("fail, error code %x\n", status); else debug("OK\n");
Hi Simon,
Changes in v2:
- Define FSP API return status code.
- Compatiable with EFI_STATUS defined in PI Spec.
Is this intentional? As I said in the v1 patch, there is no need to include <efi.h>
Regards, Bin
Bin Meng
