[PATCH v2] mtd: spi-nor: Add IS25LP02G flash support
Add support for ISSI 256MB flash IS25LP02G. This part supports 4byte opcodes. It also supports dual and quad read.
Signed-off-by: Sreekanth Sunnam Sreekanth.Sunnam@amd.com Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- Changes in v2: - Fixed the name to Sreekanth Sunnam. --- drivers/mtd/spi/spi-nor-ids.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 3cb132dcff..9a73198227 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -217,6 +217,8 @@ const struct flash_info spi_nor_ids[] = { SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("is25lp01g", 0x9d601b, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("is25lp02g", 0x9d6022, 0, 64 * 1024, 4096, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("is25wp008", 0x9d7014, 0, 64 * 1024, 16, SPI_NOR_QUAD_READ) }, { INFO("is25wp016", 0x9d7015, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ) }, { INFO("is25wp032", 0x9d7016, 0, 64 * 1024, 64,
Changes in v2:
- { INFO("is25lp02g", 0x9d6022, 0, 64 * 1024, 4096,
{ INFO("is25wp008", 0x9d7014, 0, 64 * 1024, 16, SPI_NOR_QUAD_READ) }, { INFO("is25wp016", 0x9d7015, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ) }, { INFO("is25wp032", 0x9d7016, 0, 64 * 1024, 64,SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
Jagan/Tom: Do you want to take it? Or should I take it via my tree?
Thanks, Michal
Changes in v2:
Picked on my tree.
Jagan.
On Mon, Dec 4, 2023 at 2:23 PM Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com wrote:
Changes in v2:
Applied to u-boot-spi/master
Jagan Teki
Michal Simek
