[U-Boot] [PATCH 0/4] Support for A4M072 board
These patches add support for A4M072 MPC5200-based board. The first patch adds new board with support for all devices except for 7-segment LED display. We've decided to use 'display' command to manipulate the LED display so the second patch adds very simple generic interface to use such devices and moves hw-specific realization to drivers/misc/pdsp188x.c The third patch adds 7-segment LED display support. And the fourth file adds support for showing boot progress codes on LED display (we can't display them directly so we use a mapping).
Regards, Ilya.
This patch provides support for the A4M072 board with the following features: UART NOR flash FEC Ethernet External SRAM I2C EEPROM CompactFlash cards on IDE/ATA port USB Host PCI initialization
The 7-segment LED indicator is not yet supported.
Signed-off-by: Sergei Poselenov sposelenov@emcraft.com --- MAINTAINERS | 3 + MAKEALL | 1 + board/a4m072/Makefile | 50 ++++++ board/a4m072/a4m072.c | 263 +++++++++++++++++++++++++++++++ board/a4m072/config.mk | 39 +++++ board/a4m072/mt46v32m16.h | 37 +++++ boards.cfg | 1 + include/configs/a4m072.h | 377 +++++++++++++++++++++++++++++++++++++++++++++ include/mpc5xxx.h | 3 +- 9 files changed, 773 insertions(+), 1 deletions(-) create mode 100644 board/a4m072/Makefile create mode 100644 board/a4m072/a4m072.c create mode 100644 board/a4m072/config.mk create mode 100644 board/a4m072/mt46v32m16.h create mode 100644 include/configs/a4m072.h
diff --git a/MAINTAINERS b/MAINTAINERS index 4b91b0f..1b25b61 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -504,6 +504,9 @@ Detlev Zundel dzu@denx.de
inka4x0 MPC5200
+Sergei Poselenov sposelenov@emcraft.com + + a4m072 MPC5200 -------------------------------------------------------------------------
Unknown / orphaned boards: diff --git a/MAKEALL b/MAKEALL index b34ae33..764462a 100755 --- a/MAKEALL +++ b/MAKEALL @@ -54,6 +54,7 @@ LIST_5xx=" \ #########################################################################
LIST_5xxx=" \ + a4m072 \ BC3450 \ cm5200 \ cpci5200 \ diff --git a/board/a4m072/Makefile b/board/a4m072/Makefile new file mode 100644 index 0000000..442e2d0 --- /dev/null +++ b/board/a4m072/Makefile @@ -0,0 +1,50 @@ +# +# (C) Copyright 2003-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := $(BOARD).o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/a4m072/a4m072.c b/board/a4m072/a4m072.c new file mode 100644 index 0000000..3756975 --- /dev/null +++ b/board/a4m072/a4m072.c @@ -0,0 +1,263 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * (C) Copyright 2004 + * Mark Jonas, Freescale Semiconductor, mark.jonas@motorola.com. + * + * (C) Copyright 2010 + * Sergei Poselenov, Emcraft Systems, sposelenov@emcraft.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <mpc5xxx.h> +#include <pci.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <libfdt.h> +#include <netdev.h> + +#include "mt46v32m16.h" + +#ifndef CONFIG_SYS_RAMBOOT +static void sdram_start (int hi_addr) +{ + long hi_addr_bit = hi_addr ? 0x01000000 : 0; + long control = SDRAM_CONTROL | hi_addr_bit; + + /* unlock mode register */ + out_be32((void *)MPC5XXX_SDRAM_CTRL, control | 0x80000000); + __asm__ volatile ("sync"); + + /* precharge all banks */ + out_be32((void *)MPC5XXX_SDRAM_CTRL, control | 0x80000002); + __asm__ volatile ("sync"); + +#if SDRAM_DDR + /* set mode register: extended mode */ + out_be32((void *)MPC5XXX_SDRAM_MODE, SDRAM_EMODE); + __asm__ volatile ("sync"); + + /* set mode register: reset DLL */ + out_be32((void *)MPC5XXX_SDRAM_MODE, SDRAM_MODE | 0x04000000); + __asm__ volatile ("sync"); +#endif + + /* precharge all banks */ + out_be32((void *)MPC5XXX_SDRAM_CTRL, control | 0x80000002); + __asm__ volatile ("sync"); + + /* auto refresh */ + out_be32((void *)MPC5XXX_SDRAM_CTRL, control | 0x80000004); + __asm__ volatile ("sync"); + + /* set mode register */ + out_be32((void *)MPC5XXX_SDRAM_MODE, SDRAM_MODE); + __asm__ volatile ("sync"); + + /* normal operation */ + out_be32((void *)MPC5XXX_SDRAM_CTRL, control); + __asm__ volatile ("sync"); +} +#endif + +/* + * ATTENTION: Although partially referenced initdram does NOT make real use + * use of CONFIG_SYS_SDRAM_BASE. The code does not work if CONFIG_SYS_SDRAM_BASE + * is something else than 0x00000000. + */ + +phys_size_t initdram (int board_type) +{ + ulong dramsize = 0; + uint svr, pvr; + +#ifndef CONFIG_SYS_RAMBOOT + ulong test1, test2; + + /* setup SDRAM chip selects */ + out_be32((void *)MPC5XXX_SDRAM_CS0CFG, 0x0000001e); /* 2GB at 0x0 */ + out_be32((void *)MPC5XXX_SDRAM_CS1CFG, 0x80000000); /* disabled */ + __asm__ volatile ("sync"); + + /* setup config registers */ + out_be32((void *)MPC5XXX_SDRAM_CONFIG1, SDRAM_CONFIG1); + out_be32((void *)MPC5XXX_SDRAM_CONFIG2, SDRAM_CONFIG2); + __asm__ volatile ("sync"); + +#if SDRAM_DDR + /* set tap delay */ + out_be32((void *)MPC5XXX_CDM_PORCFG, SDRAM_TAPDELAY); + __asm__ volatile ("sync"); +#endif + + /* find RAM size using SDRAM CS0 only */ + sdram_start(0); + test1 = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, 0x80000000); + sdram_start(1); + test2 = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, 0x80000000); + if (test1 > test2) { + sdram_start(0); + dramsize = test1; + } else { + dramsize = test2; + } + + /* memory smaller than 1MB is impossible */ + if (dramsize < (1 << 20)) { + dramsize = 0; + } + + /* set SDRAM CS0 size according to the amount of RAM found */ + if (dramsize > 0) { + out_be32((void *)MPC5XXX_SDRAM_CS0CFG, + 0x13 + __builtin_ffs(dramsize >> 20) - 1); + } else { + out_be32((void *)MPC5XXX_SDRAM_CS0CFG, 0); /* disabled */ + } + +#else /* CONFIG_SYS_RAMBOOT */ + + /* retrieve size of memory connected to SDRAM CS0 */ + dramsize = in_be32((void *)MPC5XXX_SDRAM_CS0CFG) & 0xFF; + if (dramsize >= 0x13) { + dramsize = (1 << (dramsize - 0x13)) << 20; + } else { + dramsize = 0; + } + +#endif /* CONFIG_SYS_RAMBOOT */ + + /* + * On MPC5200B we need to set the special configuration delay in the + * DDR controller. Please refer to Freescale's AN3221 "MPC5200B SDRAM + * Initialization and Configuration", 3.3.1 SDelay--MBAR + 0x0190: + * + * "The SDelay should be written to a value of 0x00000004. It is + * required to account for changes caused by normal wafer processing + * parameters." + */ + svr = get_svr(); + pvr = get_pvr(); + if ((SVR_MJREV(svr) >= 2) && + (PVR_MAJ(pvr) == 1) && (PVR_MIN(pvr) == 4)) { + + out_be32((void *)MPC5XXX_SDRAM_SDELAY, 0x04); + __asm__ volatile ("sync"); + } + + return dramsize; +} + +int checkboard (void) +{ + puts ("Board: A4M072\n"); + return 0; +} + +#ifdef CONFIG_PCI +static struct pci_controller hose; + +extern void pci_mpc5xxx_init(struct pci_controller *); + +void pci_init_board(void) +{ + pci_mpc5xxx_init(&hose); +} +#endif + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +void +ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} +#endif + +int board_eth_init(bd_t *bis) +{ + int rv, num_if = 0; + + /* Initialize TSECs first */ + if ((rv = cpu_eth_init(bis)) >= 0) + num_if += rv; + else + printf("ERROR: failed to initialize FEC.\n"); + + if ((rv = pci_eth_init(bis)) >= 0) + num_if += rv; + else + printf("ERROR: failed to initialize PCI Ethernet.\n"); + + return num_if; +} +/* + * Miscellaneous late-boot configurations + * + * Initialize EEPROM write-protect GPIO pin. + */ +int misc_init_r(void) +{ +#if defined(CONFIG_SYS_EEPROM_WREN) + /* Enable GPIO pin */ + setbits_be32((void *)MPC5XXX_WU_GPIO_ENABLE, CONFIG_SYS_EEPROM_WP); + /* Set direction, output */ + setbits_be32((void *)MPC5XXX_WU_GPIO_DIR, CONFIG_SYS_EEPROM_WP); + /* De-assert write enable */ + setbits_be32((void *)MPC5XXX_WU_GPIO_DATA_O, CONFIG_SYS_EEPROM_WP); +#endif + return 0; +} +#if defined(CONFIG_SYS_EEPROM_WREN) +/* Input: <dev_addr> I2C address of EEPROM device to enable. + * <state> -1: deliver current state + * 0: disable write + * 1: enable write + * Returns: -1: wrong device address + * 0: dis-/en- able done + * 0/1: current state if <state> was -1. + */ +int eeprom_write_enable (unsigned dev_addr, int state) +{ + if (CONFIG_SYS_I2C_EEPROM_ADDR != dev_addr) { + return -1; + } else { + switch (state) { + case 1: + /* Enable write access */ + clrbits_be32((void *)MPC5XXX_WU_GPIO_DATA_O, CONFIG_SYS_EEPROM_WP); + state = 0; + break; + case 0: + /* Disable write access */ + setbits_be32((void *)MPC5XXX_WU_GPIO_DATA_O, CONFIG_SYS_EEPROM_WP); + state = 0; + break; + default: + /* Read current status back. */ + state = (0 == (in_be32((void *)MPC5XXX_WU_GPIO_DATA_O) & + CONFIG_SYS_EEPROM_WP)); + break; + } + } + return state; +} +#endif diff --git a/board/a4m072/config.mk b/board/a4m072/config.mk new file mode 100644 index 0000000..c6ba51d --- /dev/null +++ b/board/a4m072/config.mk @@ -0,0 +1,39 @@ +# +# (C) Copyright 2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +# +# a4m072 board: +# +# Valid values for TEXT_BASE is: +# +# 0xFE000000 boot low +# + +sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp + +ifndef TEXT_BASE +## Standard: boot low +TEXT_BASE = 0xFE000000 +endif + +PLATFORM_CPPFLAGS += -DTEXT_BASE=$(TEXT_BASE) -I$(TOPDIR)/board diff --git a/board/a4m072/mt46v32m16.h b/board/a4m072/mt46v32m16.h new file mode 100644 index 0000000..d7561fb --- /dev/null +++ b/board/a4m072/mt46v32m16.h @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2004 + * Mark Jonas, Freescale Semiconductor, mark.jonas@motorola.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define SDRAM_DDR 1 /* is DDR */ + +#if defined(CONFIG_MPC5200) +/* Settings for XLB = 132 MHz */ +#define SDRAM_MODE 0x018D0000 +#define SDRAM_EMODE 0x40010000 +#define SDRAM_CONTROL 0x704f0f00 +#define SDRAM_CONFIG1 0x73722930 +#define SDRAM_CONFIG2 0x47770000 +#define SDRAM_TAPDELAY 0x10000000 + +#else +#error CONFIG_MPC5200 not defined +#endif diff --git a/boards.cfg b/boards.cfg index 69c6897..9d0ced2 100644 --- a/boards.cfg +++ b/boards.cfg @@ -89,6 +89,7 @@ DB64360 powerpc 74xx_7xx db64360 Marvell DB64460 powerpc 74xx_7xx db64460 Marvell aria powerpc mpc512x - davedenx PATI powerpc mpc5xx pati mpl +a4m072 powerpc mpc5xxx a4m072 BC3450 powerpc mpc5xxx bc3450 canmb powerpc mpc5xxx cm5200 powerpc mpc5xxx diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h new file mode 100644 index 0000000..ffa5621 --- /dev/null +++ b/include/configs/a4m072.h @@ -0,0 +1,377 @@ +/* + * (C) Copyright 2003-2005 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * (C) Copyright 2010 + * Sergei Poselenov, Emcraft Systems, sposelenov@emcraft.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + * (easy to change) + */ + +#define CONFIG_MPC5xxx 1 /* This is an MPC5xxx CPU */ +#define CONFIG_MPC5200 1 /* (more precisely a MPC5200 CPU) */ +#define CONFIG_A4M072 1 /* ... on A4M072 board */ +#define CONFIG_MPC5200_DDR 1 /* ... use DDR RAM */ + +#define CONFIG_MISC_INIT_R + +#define CONFIG_SYS_MPC5XXX_CLKIN 33000000 /* ... running at 33.000000MHz */ + +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +#define CONFIG_HIGH_BATS 1 /* High BATs supported */ + +/* + * Serial console configuration + */ +#define CONFIG_PSC_CONSOLE 1 /* console is on PSC1 */ +#define CONFIG_BAUDRATE 9600 /* ... at 9600 bps */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } +/* define to enable silent console */ +#define CONFIG_SILENT_CONSOLE +#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ + +/* + * PCI Mapping: + * 0x40000000 - 0x4fffffff - PCI Memory + * 0x50000000 - 0x50ffffff - PCI IO Space + */ +#define CONFIG_PCI + +#if defined(CONFIG_PCI) +#define CONFIG_PCI_PNP 1 +#define CONFIG_PCI_SCAN_SHOW 1 +#define CONFIG_PCIAUTO_SKIP_HOST_BRIDGE 1 + +#define CONFIG_PCI_MEM_BUS 0x40000000 +#define CONFIG_PCI_MEM_PHYS CONFIG_PCI_MEM_BUS +#define CONFIG_PCI_MEM_SIZE 0x10000000 + +#define CONFIG_PCI_IO_BUS 0x50000000 +#define CONFIG_PCI_IO_PHYS CONFIG_PCI_IO_BUS +#define CONFIG_PCI_IO_SIZE 0x01000000 +#endif + +#define CONFIG_SYS_XLB_PIPELINING 1 + +#undef CONFIG_NET_MULTI +#undef CONFIG_EEPRO100 + +/* Partitions */ +#define CONFIG_MAC_PARTITION +#define CONFIG_DOS_PARTITION + +/* USB */ +#define CONFIG_USB_OHCI_NEW +#define CONFIG_USB_STORAGE +#define CONFIG_SYS_OHCI_BE_CONTROLLER +#undef CONFIG_SYS_USB_OHCI_BOARD_INIT +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE MPC5XXX_USB +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "mpc5200" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15 + +#define CONFIG_TIMESTAMP /* Print image info with timestamp */ + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_NFS +#define CONFIG_CMD_SNTP +#define CONFIG_CMD_USB +#define CONFIG_CMD_MII +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING + +#if defined(CONFIG_PCI) +#define CONFIG_CMD_PCI +#endif + +#if (TEXT_BASE == 0xFE000000) /* Boot low with 32 MB Flash */ +#define CONFIG_SYS_LOWBOOT 1 +#define CONFIG_SYS_LOWBOOT32 1 +#endif + +/* + * Autobooting + */ +#define CONFIG_BOOTDELAY 2 /* autoboot after 2 seconds */ + +#define CONFIG_SYS_AUTOLOAD "n" + +#define CONFIG_AUTOBOOT_KEYED +#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds\n", bootdelay +#define CONFIG_AUTOBOOT_DELAY_STR "asdfg" + +#undef CONFIG_BOOTARGS +#define CONFIG_PREBOOT "run try_update" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bk=run add_mtd ; run add_consolespec ; bootm 200000\0" \ + "cf1=diskboot 200000 0:1\0" \ + "bootcmd_cf1=run bcf1\0" \ + "bcf=setenv bootargs root=/dev/hda3\0" \ + "bootcmd_nfs=run bnfs\0" \ + "norargs=setenv bootargs root=/dev/mtdblock3 rootfstype=cramfs\0" \ + "bootcmd_nor=cp.b ${kernel_addr} 200000 100000; run norargs addip; run bk\0" \ + "bnfs=nfs 200000 ${rootpath}/boot/uImage ; run nfsargs addip ; run bk\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath}\0" \ + "try_update=usb start;sleep 2;usb start;sleep 1;fatload usb 0 2F0000 PCPUUPDT 2FF;usb stop;source 2F0000\0" \ + "env_addr=FE060000\0" \ + "kernel_addr=FE100000\0" \ + "rootfs_addr=FE200000\0" \ + "add_mtd=setenv bootargs ${bootargs} mtdparts=phys_mapped_flash:384k(u),640k(e),1m(k),30m(r)\0" \ + "bcf1=run cf1; run bcf; run addip; run bk\0" \ + "add_consolespec=setenv bootargs ${bootargs} console=/dev/null quiet\0" \ + "addip=if test "${ethaddr}" != "00:00:00:00:00:00" ; then if test -n ${ipaddr}; then setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}:${netdev}:off panic=1; fi ; fi\0" \ + "hostname=CPUP0\0" \ + "ethaddr=00:00:00:00:00:00\0" \ + "netdev=eth0\0" \ + "bootcmd=run bootcmd_nor\0" \ + "" +/* + * IPB Bus clocking configuration. + */ +#undef CONFIG_SYS_IPBCLK_EQUALS_XLBCLK /* define for 133MHz speed */ + +/* + * I2C configuration + */ +#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ +#define CONFIG_SYS_I2C_MODULE 2 /* Select I2C module #1 or #2 */ + +#define CONFIG_SYS_I2C_SPEED 100000 /* 100 kHz */ +#define CONFIG_SYS_I2C_SLAVE 0x7F + +/* + * EEPROM configuration + */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x52 /* 1010010x */ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 +#define CONFIG_SYS_EEPROM_WREN 1 +#define CONFIG_SYS_EEPROM_WP GPIO_PSC2_4 + +/* + * Flash configuration + */ +#define CONFIG_SYS_FLASH_BASE 0xFE000000 +#define CONFIG_SYS_FLASH_SIZE 0x02000000 +#if !defined(CONFIG_SYS_LOWBOOT) +#error "CONFIG_SYS_LOWBOOT not defined?" +#else /* CONFIG_SYS_LOWBOOT */ +#if defined(CONFIG_SYS_LOWBOOT32) +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x00060000) +#endif +#endif /* CONFIG_SYS_LOWBOOT */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of memory banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max num of sects on one chip */ +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_CS0_START} + +/* + * Environment settings + */ +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SIZE 0x10000 +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE + +#define CONFIG_ENV_OVERWRITE 1 + +/* + * Memory map + */ +#define CONFIG_SYS_MBAR 0xF0000000 +#define CONFIG_SYS_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_DEFAULT_MBAR 0x80000000 + +/* Use SRAM until RAM will be available */ +#define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM +#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE /* End of used area in DPRAM */ + + +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_BASE TEXT_BASE +#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) +# define CONFIG_SYS_RAMBOOT 1 +#endif + +#define CONFIG_SYS_MONITOR_LEN (384 << 10) /* Reserve 384 kB for Monitor */ +#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ +#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ + +/* + * Ethernet configuration + */ +#define CONFIG_MPC5xxx_FEC 1 +#define CONFIG_MPC5xxx_FEC_MII100 +/* + * Define CONFIG_MPC5xxx_FEC_MII10 to force FEC at 10Mb + */ +/* #define CONFIG_MPC5xxx_FEC_MII10 */ +#define CONFIG_PHY_ADDR 0x1f +#define CONFIG_PHY_TYPE 0x79c874 /* AMD Phy Controller */ + +/* + * GPIO configuration + */ +#define CONFIG_SYS_GPS_PORT_CONFIG 0x10000004 + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_CMDLINE_EDITING 1 +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#endif +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x00f00000 /* 1 ... 15 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ + +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ + +#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + + +/* + * Various low-level settings + */ +#define CONFIG_SYS_HID0_INIT HID0_ICE | HID0_ICFI +#define CONFIG_SYS_HID0_FINAL HID0_ICE +/* Flash at CSBoot, CS0 */ +#define CONFIG_SYS_BOOTCS_START CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_BOOTCS_SIZE CONFIG_SYS_FLASH_SIZE +#define CONFIG_SYS_BOOTCS_CFG 0x0002DD00 +#define CONFIG_SYS_CS0_START CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_CS0_SIZE CONFIG_SYS_FLASH_SIZE +/* External SRAM at CS1 */ +#define CONFIG_SYS_CS1_START 0x62000000 +#define CONFIG_SYS_CS1_SIZE 0x00400000 +#define CONFIG_SYS_CS1_CFG 0x00009930 +#define CONFIG_SYS_SRAM_BASE CONFIG_SYS_CS1_START +#define CONFIG_SYS_SRAM_SIZE CONFIG_SYS_CS1_SIZE + + +#define CONFIG_SYS_CS_BURST 0x00000000 +#define CONFIG_SYS_CS_DEADCYCLE 0x33333003 + +#define CONFIG_SYS_RESET_ADDRESS 0xff000000 + +/*----------------------------------------------------------------------- + * USB stuff + *----------------------------------------------------------------------- + */ +#define CONFIG_USB_CLOCK 0x0001BBBB +#define CONFIG_USB_CONFIG 0x00001000 /* 0x4000 for SE mode */ + +/*----------------------------------------------------------------------- + * IDE/ATA stuff Supports IDE harddisk + *----------------------------------------------------------------------- + */ + +#undef CONFIG_IDE_8xx_PCCARD /* Use IDE with PC Card Adapter */ + +#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ +#undef CONFIG_IDE_LED /* LED for ide not supported */ + +#define CONFIG_IDE_PREINIT + +#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ +#define CONFIG_SYS_IDE_MAXDEVICE 1 /* max. 2 drives per IDE bus */ + +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 + +#define CONFIG_SYS_ATA_BASE_ADDR MPC5XXX_ATA + +/* Offset for data I/O */ +#define CONFIG_SYS_ATA_DATA_OFFSET (0x0060) + +/* Offset for normal register accesses */ +#define CONFIG_SYS_ATA_REG_OFFSET (CONFIG_SYS_ATA_DATA_OFFSET) + +/* Offset for alternate registers */ +#define CONFIG_SYS_ATA_ALT_OFFSET (0x005C) + +/* Interval between registers */ +#define CONFIG_SYS_ATA_STRIDE 4 + +#define CONFIG_ATAPI 1 + +/*----------------------------------------------------------------------- + * Open firmware flat tree support + *----------------------------------------------------------------------- + */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 + +#define OF_CPU "PowerPC,5200@0" +#define OF_SOC "soc5200@f0000000" +#define OF_TBCLK (bd->bi_busfreq / 4) +#define OF_STDOUT_PATH "/soc5200@f0000000/serial@2000" + +#endif /* __CONFIG_H */ diff --git a/include/mpc5xxx.h b/include/mpc5xxx.h index 2d343c7..859d696 100644 --- a/include/mpc5xxx.h +++ b/include/mpc5xxx.h @@ -160,11 +160,12 @@ #define MPC5XXX_WU_GPIO_DATA_O (MPC5XXX_WU_GPIO + 0x000c) #define MPC5XXX_WU_GPIO_DATA_I (MPC5XXX_WU_GPIO + 0x0020)
-/* GPIO pins */ +/* GPIO pins, for Rev.B chip */ #define GPIO_WKUP_7 0x80000000UL #define GPIO_PSC6_0 0x10000000UL #define GPIO_PSC3_9 0x04000000UL #define GPIO_PSC1_4 0x01000000UL +#define GPIO_PSC2_4 0x02000000UL
#define MPC5XXX_GPIO_SIMPLE_PSC6_3 0x20000000UL #define MPC5XXX_GPIO_SIMPLE_PSC6_2 0x10000000UL
Split the display command into generic interface and hardware-specific realization for PDSP188x LED display found on hmi1001 and manroland boards. Simple interface for LED displays is defined in include/led-display.h and described in doc/README.LED_display. Driver-specific implementation was moved into drivers/misc/pdsp188x.c file (enabled with CONFIG_PDSP188x set).
Signed-off-by: Ilya Yanok yanok@emcraft.com --- common/cmd_display.c | 26 ++++++----------- doc/README.LED_display | 28 +++++++++++++++++ drivers/misc/Makefile | 1 + drivers/misc/pdsp188x.c | 57 ++++++++++++++++++++++++++++++++++++ include/configs/hmi1001.h | 1 + include/configs/manroland/common.h | 5 +++ include/led-display.h | 36 ++++++++++++++++++++++ 7 files changed, 137 insertions(+), 17 deletions(-) create mode 100644 doc/README.LED_display create mode 100644 drivers/misc/pdsp188x.c create mode 100644 include/led-display.h
diff --git a/common/cmd_display.c b/common/cmd_display.c index 6c11aa6..d5d5d8c 100644 --- a/common/cmd_display.c +++ b/common/cmd_display.c @@ -23,40 +23,32 @@
#include <common.h> #include <command.h> +#include <led-display.h>
#undef DEBUG_DISP
-#define DISP_SIZE 8 -#define CWORD_CLEAR 0x80 -#define CLEAR_DELAY (110 * 2) - int do_display (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int i; - int pos;
/* Clear display */ - *((volatile char*)(CONFIG_SYS_DISP_CWORD)) = CWORD_CLEAR; - udelay(1000 * CLEAR_DELAY); + display_set(DISPLAY_CLEAR | DISPLAY_HOME);
if (argc < 2) return (0);
- for (pos = 0, i = 1; i < argc && pos < DISP_SIZE; i++) { - char *p = argv[i], c; + for (i = 1; i < argc; i++) { + char *p = argv[i];
- if (i > 1) { - *((volatile uchar *) (CONFIG_SYS_DISP_CHR_RAM + pos++)) = ' '; -#ifdef DEBUG_DISP - putc(' '); -#endif + if (i > 1) { /* Insert a space between strings */ + display_putc(' '); }
- while ((c = *p++) != '\0' && pos < DISP_SIZE) { - *((volatile uchar *) (CONFIG_SYS_DISP_CHR_RAM + pos++)) = c; + while ((*p)) { #ifdef DEBUG_DISP - putc(c); + putc(*p); #endif + display_putc(*p++); } }
diff --git a/doc/README.LED_display b/doc/README.LED_display new file mode 100644 index 0000000..c79aca6 --- /dev/null +++ b/doc/README.LED_display @@ -0,0 +1,28 @@ +LED display internal API +======================================= + +This README describes the LED display API. + +The API is defined by the include file include/led-display.h + +The first step in to define CONFIG_CMD_DISPLAY in the board config file. +Then you need to provide the following functions to access LED display: + +void display_set(int cmd); + +This function should control the state of the LED display. Argument is +an ORed combination of the following values: + DISPLAY_CLEAR -- clear the display + DISPLAY_HOME -- set the position to the beginning of display + DISPLAY_MARK -- enable mark (decimal point), if implemented + +int display_putc(char c); + +This function should display it's parameter on the LED display in the +current position. Returns the displayed character on success or -1 in +case of failure. + +With this functions defined 'display' command will display it's +arguments on the LED display (or clear the display if called without +arguments). + diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 4f15db9..5d668f8 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -33,6 +33,7 @@ COBJS-$(CONFIG_NS87308) += ns87308.o COBJS-$(CONFIG_STATUS_LED) += status_led.o COBJS-$(CONFIG_TWL4030_LED) += twl4030_led.o COBJS-$(CONFIG_FSL_PMIC) += fsl_pmic.o +COBJS-$(CONFIG_PDSP188x) += pdsp188x.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/misc/pdsp188x.c b/drivers/misc/pdsp188x.c new file mode 100644 index 0000000..656b6ee --- /dev/null +++ b/drivers/misc/pdsp188x.c @@ -0,0 +1,57 @@ +/* + * Copyright 2010 Sergey Poselenov, Emcraft Systems, sposelenov@emcraft.com + * Copyright 2010 Ilya Yanok, Emcraft Systems, yanok@emcraft.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#include <common.h> +#include <led-display.h> +#include <asm/io.h> + +#ifdef CONFIG_CMD_DISPLAY +#define CWORD_CLEAR 0x80 +#define CLEAR_DELAY (110 * 2) +#define DISPLAY_SIZE 8 + +static int pos; /* Current display position */ + +/* Handle different display commands */ +void display_set(int cmd) +{ + if (cmd & DISPLAY_CLEAR) { + out_8((unsigned char *)CONFIG_SYS_DISP_CWORD, CWORD_CLEAR); + udelay(1000 * CLEAR_DELAY); + } + + if (cmd & DISPLAY_HOME) { + pos = 0; + } +} + +/* + * Display a character at the current display position. + * Characters beyond the display size are ignored. + */ +int display_putc(char c) +{ + if (pos >= DISPLAY_SIZE) + return -1; + + out_8((unsigned char *)CONFIG_SYS_DISP_CHR_RAM + pos++, c); + + return c; +} +#endif diff --git a/include/configs/hmi1001.h b/include/configs/hmi1001.h index f9cdcbc..e5eb966 100644 --- a/include/configs/hmi1001.h +++ b/include/configs/hmi1001.h @@ -350,6 +350,7 @@ /* Display addresses */ /*---------------------------------------------------------------------*/
+#define CONFIG_PDSP188x #define CONFIG_SYS_DISP_CHR_RAM (CONFIG_SYS_DISPLAY_BASE + 0x38) #define CONFIG_SYS_DISP_CWORD (CONFIG_SYS_DISPLAY_BASE + 0x30)
diff --git a/include/configs/manroland/common.h b/include/configs/manroland/common.h index 0224608..291b669 100644 --- a/include/configs/manroland/common.h +++ b/include/configs/manroland/common.h @@ -55,6 +55,11 @@ #define CONFIG_CMD_MII #define CONFIG_CMD_SNTP
+/* + * 8-symbol LED display (can be accessed with 'display' command) + */ +#define CONFIG_PDSP188x + #define CONFIG_TIMESTAMP 1 /* Print image info with timestamp */
/* diff --git a/include/led-display.h b/include/led-display.h new file mode 100644 index 0000000..41c3744 --- /dev/null +++ b/include/led-display.h @@ -0,0 +1,36 @@ +/* + * (C) Copyright 2005-2010 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * (C) Copyright 2010 + * Sergei Poselenov, Emcraft Systems, sposelenov@emcraft.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _led_display_h_ +#define _led_display_h_ + +/* Display Commands */ +#define DISPLAY_CLEAR 0x1 /* Clear the display */ +#define DISPLAY_HOME 0x2 /* Set cursor at home position */ +#define DISPLAY_MARK 0x4 /* Enable the decimal point led, if implemented */ + +void display_set(int cmd); +int display_putc(char c); +#endif
This patch adds support for LED display on a4m072 board. Hardware is capable of displaying only one symbol at any time. We support displaying two symbols in software (via blinking).
Signed-off-by: Ilya Yanok yanok@emcraft.com --- board/a4m072/a4m072.c | 174 ++++++++++++++++++++++++++++++++++++++++++++++ include/configs/a4m072.h | 12 +++- 2 files changed, 184 insertions(+), 2 deletions(-)
diff --git a/board/a4m072/a4m072.c b/board/a4m072/a4m072.c index 3756975..9c272a0 100644 --- a/board/a4m072/a4m072.c +++ b/board/a4m072/a4m072.c @@ -34,6 +34,7 @@ #include <asm/io.h> #include <libfdt.h> #include <netdev.h> +#include <led-display.h>
@@ -261,3 +262,176 @@ int eeprom_write_enable (unsigned dev_addr, int state) return state; } #endif + +#ifdef CONFIG_CMD_DISPLAY +#define DISPLAY_BUF_SIZE 2 +static u8 display_buf[DISPLAY_BUF_SIZE]; +static u8 display_putc_pos; +static u8 display_out_pos; + +static u8 display_dot_enable; + +void display_set(int cmd) { + + if (cmd & DISPLAY_CLEAR) { + display_buf[0] = display_buf[1] = 0; + } + + if (cmd & DISPLAY_HOME) { + display_putc_pos = 0; + } + + if (cmd & DISPLAY_MARK) { + display_dot_enable = 1; + } else { + display_dot_enable = 0; + } +} + +#define SEG_A (1<<0) +#define SEG_B (1<<1) +#define SEG_C (1<<2) +#define SEG_D (1<<3) +#define SEG_E (1<<4) +#define SEG_F (1<<5) +#define SEG_G (1<<6) +#define SEG_P (1<<7) +#define SEG__ 0 + +/* + * +- A -+ + * | | + * F B + * | | + * +- G -+ + * | | + * E C + * | | + * +- D -+ P + * + * 0..9 index 0..9 + * A..Z index 10..35 + * - index 36 + * _ index 37 + */ + +#define SYMBOL_DASH (36) +#define SYMBOL_UNDERLINE (37) + +static u8 display_char2seg7_tbl[]= +{ + SEG_A | SEG_B | SEG_C | SEG_D | SEG_E | SEG_F, /* 0 */ + SEG_B | SEG_C, /* 1 */ + SEG_A | SEG_B | SEG_D | SEG_E | SEG_G, /* 2 */ + SEG_A | SEG_B | SEG_C | SEG_D | SEG_G, /* 3 */ + SEG_B | SEG_C | SEG_F | SEG_G, /* 4 */ + SEG_A | SEG_C | SEG_D | SEG_F | SEG_G, /* 5 */ + SEG_A | SEG_C | SEG_D | SEG_E | SEG_F | SEG_G, /* 6 */ + SEG_A | SEG_B | SEG_C, /* 7 */ + SEG_A | SEG_B | SEG_C | SEG_D | SEG_E | SEG_F | SEG_G, /* 8 */ + SEG_A | SEG_B | SEG_C | SEG_D | SEG_F | SEG_G, /* 9 */ + SEG_A | SEG_B | SEG_C | SEG_E | SEG_F | SEG_G, /* A */ + SEG_C | SEG_D | SEG_E | SEG_F | SEG_G, /* b */ + SEG_A | SEG_D | SEG_E | SEG_F, /* C */ + SEG_B | SEG_C | SEG_D | SEG_E | SEG_G, /* d */ + SEG_A | SEG_D | SEG_E | SEG_F | SEG_G, /* E */ + SEG_A | SEG_E | SEG_F | SEG_G, /* F */ + SEG_A | SEG_B | SEG_C | SEG_D | SEG_F | SEG_G, /* g */ + SEG_B | SEG_C | SEG_E | SEG_F | SEG_G, /* H */ + SEG_E | SEG_F, /* I */ + SEG_B | SEG_C | SEG_D | SEG_E, /* J */ + SEG_A, /* K - special 1 */ + SEG_D | SEG_E | SEG_F, /* L */ + SEG_B, /* m - special 2 */ + SEG_C | SEG_E | SEG_G, /* n */ + SEG_C | SEG_D | SEG_E | SEG_G, /* o */ + SEG_A | SEG_B | SEG_E | SEG_F | SEG_G, /* P */ + SEG_A | SEG_B | SEG_C | SEG_F | SEG_G, /* q */ + SEG_E | SEG_G, /* r */ + SEG_A | SEG_C | SEG_D | SEG_F | SEG_G, /* S */ + SEG_D | SEG_E | SEG_F | SEG_G, /* t */ + SEG_B | SEG_C | SEG_D | SEG_E | SEG_F, /* U */ + SEG_C | SEG_D | SEG_E | SEG_F, /* V */ + SEG_C, /* w - special 3 */ + SEG_B | SEG_C | SEG_E | SEG_F | SEG_G, /* X */ + SEG_B | SEG_C | SEG_D | SEG_F | SEG_G, /* Y */ + SEG_A | SEG_B | SEG_D | SEG_E | SEG_G, /* Z */ + SEG_G, /* - */ + SEG_D /* _ */ +}; + +/* Convert char to the LED segments representation */ +static u8 display_char2seg7(char c) +{ + u8 val = 0; + + if (c >= '0' && c <= '9') + c -= '0'; + else if (c >= 'a' && c <= 'z') + c -= 'a' - 10; + else if (c >= 'A' && c <= 'Z') + c -= 'A' - 10; + else if (c == '-') + c = SYMBOL_DASH; + else if ((c == '_') || (c == '.')) + c = SYMBOL_UNDERLINE; + else + c = ' '; /* display unsupported symbols as space */ + + if (c != ' ') + val = display_char2seg7_tbl[(int)c]; + + /* Handle DP LED here */ + if (display_dot_enable) { + val |= SEG_P; + } + + return val; +} + +static inline int display_putc_nomark(char c) +{ + if (display_putc_pos >= DISPLAY_BUF_SIZE) + return -1; + + display_buf[display_putc_pos++] = display_char2seg7(c); + /* one-symbol message should be steady */ + if (display_putc_pos == 1) + display_buf[display_putc_pos] = display_char2seg7(c); + + return c; +} + +int display_putc(char c) +{ + /* Mark the codes from the "display" command with the DP LED */ + display_set(DISPLAY_MARK); + return display_putc_nomark(c); +} + +/* + * Output content of the software display buffer to the LED display every 0.5s + */ +void board_show_activity(ulong timestamp) +{ + static ulong last; + static u8 once; + u32 val; + + if (!once || (timestamp - last >= (CONFIG_SYS_HZ / 2))) { + val = display_buf[display_out_pos]; + val |= (val << 8) | (val << 16) | (val << 24); + out_be32((void *)CONFIG_SYS_DISP_CHR_RAM, val); + display_out_pos ^= 1; + last = timestamp; + once = 1; + } +} + +/* + * Empty fake function + */ +void show_activity(int arg) +{ +} +#endif diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h index ffa5621..ce931d7 100644 --- a/include/configs/a4m072.h +++ b/include/configs/a4m072.h @@ -122,6 +122,7 @@ #define CONFIG_CMD_MII #define CONFIG_CMD_DHCP #define CONFIG_CMD_PING +#define CONFIG_CMD_DISPLAY
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI @@ -264,7 +265,7 @@ /* * GPIO configuration */ -#define CONFIG_SYS_GPS_PORT_CONFIG 0x10000004 +#define CONFIG_SYS_GPS_PORT_CONFIG 0x18000004
/* * Miscellaneous configurable options @@ -315,7 +316,10 @@ #define CONFIG_SYS_CS1_CFG 0x00009930 #define CONFIG_SYS_SRAM_BASE CONFIG_SYS_CS1_START #define CONFIG_SYS_SRAM_SIZE CONFIG_SYS_CS1_SIZE - +/* LED display at CS7 */ +#define CONFIG_SYS_CS7_START 0x6a000000 +#define CONFIG_SYS_CS7_SIZE (64*1024) +#define CONFIG_SYS_CS7_CFG 0x0000bf30
#define CONFIG_SYS_CS_BURST 0x00000000 #define CONFIG_SYS_CS_DEADCYCLE 0x33333003 @@ -374,4 +378,8 @@ #define OF_TBCLK (bd->bi_busfreq / 4) #define OF_STDOUT_PATH "/soc5200@f0000000/serial@2000"
+/* Support for the 7-segment display */ +#define CONFIG_SYS_DISP_CHR_RAM CONFIG_SYS_CS7_START +#define CONFIG_SHOW_ACTIVITY /* used for display realization */ + #endif /* __CONFIG_H */
This patch adds support for displaying boot progress codes on a4m072 board using LED display. As we can display only one symbol at any time on the hardware (two symbols with blinking) we can't display progress codes directly and have to map them to 2-symbol codes. We use the following mapping on the a4m972 board: [1, 8] U [100, 108] -> 5 [-9, -1] U [-101, -100] U [-113, -103] -> -5 [9, 14] U [120, 123] U [125, 129] -> 8 [-13, -10] U [-122, -120] U [-127, -124] U {-129} -> -8 {15} -> 9 [-32, -30] -> -A [-40, -35] U [-51, -42] U [-58, -53] U [-83, -80] U {-64, -130, -140, -150} -> -B
Other progress code are ignored. One symbol codes are displayed steady while two-symbol codes are displayed using blinking. Boot progress codes are displayed with decimal got unset (as opposed to 'display' command output).
Signed-off-by: Ilya Yanok yanok@emcraft.com --- board/a4m072/a4m072.c | 79 +++++++++++++++++++++++++++++++++++++++++++--- include/configs/a4m072.h | 2 + 2 files changed, 76 insertions(+), 5 deletions(-)
diff --git a/board/a4m072/a4m072.c b/board/a4m072/a4m072.c index 9c272a0..ae7ccbb 100644 --- a/board/a4m072/a4m072.c +++ b/board/a4m072/a4m072.c @@ -35,6 +35,7 @@ #include <libfdt.h> #include <netdev.h> #include <led-display.h> +#include <linux/err.h>
@@ -410,18 +411,26 @@ int display_putc(char c) }
/* - * Output content of the software display buffer to the LED display every 0.5s + * Flush current symbol to the LED display hardware + */ +static inline void display_flush(void) +{ + u32 val = display_buf[display_out_pos]; + + val |= (val << 8) | (val << 16) | (val << 24); + out_be32((void *)CONFIG_SYS_DISP_CHR_RAM, val); +} + +/* + * Output contents of the software display buffer to the LED display every 0.5s */ void board_show_activity(ulong timestamp) { static ulong last; static u8 once; - u32 val;
if (!once || (timestamp - last >= (CONFIG_SYS_HZ / 2))) { - val = display_buf[display_out_pos]; - val |= (val << 8) | (val << 16) | (val << 24); - out_be32((void *)CONFIG_SYS_DISP_CHR_RAM, val); + display_flush(); display_out_pos ^= 1; last = timestamp; once = 1; @@ -435,3 +444,63 @@ void show_activity(int arg) { } #endif +#if defined (CONFIG_SHOW_BOOT_PROGRESS) +static int a4m072_status2code(int status, char *buf) +{ + char c = 0; + + if (((status > 0) && (status <= 8)) || + ((status >= 100) && (status <= 108)) || + ((status < 0) && (status >= -9)) || + (status == -100) || (status == -101) || + ((status <= -103) && (status >= -113))) { + c = '5'; + } else if (((status >= 9) && (status <= 14)) || + ((status >= 120) && (status <= 123)) || + ((status >= 125) && (status <= 129)) || + ((status >= -13) && (status <= -10)) || + (status == -120) || (status == -122) || + ((status <= -124) && (status >= -127)) || + (status == -129)) { + c = '8'; + } else if (status == 15) { + c = '9'; + } else if ((status <= -30) && (status >= -32)) { + c = 'A'; + } else if (((status <= -35) && (status >= -40)) || + ((status <= -42) && (status >= -51)) || + ((status <= -53) && (status >= -58)) || + (status == -64) || + ((status <= -80) && (status >= -83)) || + (status == -130) || (status == -140) || + (status == -150)) { + c = 'B'; + } + + if (c == 0) + return -EINVAL; + + buf[0] = (status < 0) ? '-' : c; + buf[1] = c; + + return 0; +} + +void show_boot_progress(int status) +{ + char buf[2]; + + if (a4m072_status2code(status, buf) < 0) + return; + + display_set(0); /* Clear DP Led */ + display_putc_nomark(buf[0]); + display_putc_nomark(buf[1]); + display_set(DISPLAY_HOME); + display_out_pos = 0; /* reset output position */ + + /* we want to flush status 15 now */ + if (status == 15) + display_flush(); +} +#endif diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h index ce931d7..a54ab1d 100644 --- a/include/configs/a4m072.h +++ b/include/configs/a4m072.h @@ -382,4 +382,6 @@ #define CONFIG_SYS_DISP_CHR_RAM CONFIG_SYS_CS7_START #define CONFIG_SHOW_ACTIVITY /* used for display realization */
+#define CONFIG_SHOW_BOOT_PROGRESS + #endif /* __CONFIG_H */
Dear Ilya Yanok,
Applied, thanks.
Dear Ilya Yanok,
Applied, thanks.
Dear Ilya Yanok,
Applied, thanks.
Dear Ilya Yanok,
Applied, thanks.
13.10.2010 0:45, Wolfgang Denk wrote:
Applied, thanks.
Ouch... I'm going to clear these patches as you requested (big NOR flash, changed default environment, changed character mapping, added dot character) and repost updated patches in a few days...
Could you please rollback the whole series? Or should I post the incremental patches?
Regards, Ilya.
Dear Ilya Yanok,
Applied, thanks.
Yes, I know. I could not wait that long. Sorry.
Yes, please post incremental patches now.
Ilya Yanok
