[PATCH] arm: socfpga: Add function to get Board ID
Board ID is defined in JTAG User Code register. This function retrieves the Board ID and perform validation on it.
Signed-off-by: Yau Wai Gan yau.wai.gan@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- arch/arm/mach-socfpga/board.c | 39 +++++++++++++++++++ .../mach-socfpga/include/mach/mailbox_s10.h | 1 + 2 files changed, 40 insertions(+)
diff --git a/arch/arm/mach-socfpga/board.c b/arch/arm/mach-socfpga/board.c index 914a44970d..11abf864f5 100644 --- a/arch/arm/mach-socfpga/board.c +++ b/arch/arm/mach-socfpga/board.c @@ -7,9 +7,11 @@
#include <common.h> #include <asm/arch/clock_manager.h> +#include <asm/arch/mailbox_s10.h> #include <asm/arch/misc.h> #include <asm/arch/reset_manager.h> #include <asm/arch/secure_vab.h> +#include <asm/arch/smc_api.h> #include <asm/global_data.h> #include <asm/io.h> #include <errno.h> @@ -23,6 +25,8 @@
DECLARE_GLOBAL_DATA_PTR;
+#define DEFAULT_JTAG_USERCODE 0xFFFFFFFF + void s_init(void) { #ifndef CONFIG_ARM64 /* @@ -92,6 +96,41 @@ int g_dnl_board_usb_cable_connected(void) } #endif
+u8 socfpga_get_board_id(void) +{ + u8 board_id = 0; + u32 jtag_usercode; + int err; + +#if !IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_SPL_ATF) + err = smc_get_usercode(&jtag_usercode); +#else + u32 resp_len = 1; + + err = mbox_send_cmd(MBOX_ID_UBOOT, MBOX_GET_USERCODE, MBOX_CMD_DIRECT, 0, + NULL, 0, &resp_len, &jtag_usercode); +#endif + + if (err) { + puts("Fail to read JTAG Usercode. Default Board ID to 0\n"); + return board_id; + } + + debug("Valid JTAG Usercode: %u\n", jtag_usercode); + + if (jtag_usercode == DEFAULT_JTAG_USERCODE) { + debug("JTAG Usercode is not set. Default Board ID to 0\n"); + } else if (jtag_usercode >= 0 && jtag_usercode <= 255) { + board_id = jtag_usercode; + debug("Valid JTAG Usercode. Set Board ID to %u\n", board_id); + } else { + puts("Board ID is not in range 0 to 255\n"); + } + + return board_id; +} + + #ifdef CONFIG_SPL_BUILD __weak int board_fit_config_name_match(const char *name) { diff --git a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h index fbaf11597e..2cc7c89044 100644 --- a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h +++ b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h @@ -119,6 +119,7 @@ enum ALT_SDM_MBOX_RESP_CODE { #define MBOX_RECONFIG_DATA 8 #define MBOX_RECONFIG_STATUS 9 #define MBOX_VAB_SRC_CERT 11 +#define MBOX_GET_USERCODE 19 #define MBOX_QSPI_OPEN 50 #define MBOX_QSPI_CLOSE 51 #define MBOX_QSPI_DIRECT 59
Jit Loon Lim
