[U-Boot] [PATCH] test/dm: Fix string handling issues in the eth test
Coverity scan has identified potential buffer overruns in these tests. Correct this by zeroing our buffer and using strncpy not strcpy.
Reported-by: Coverity (CID: 155462, 155463) Cc: Joe Hershberger joe.hershberger@ni.com Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Signed-off-by: Tom Rini trini@konsulko.com --- test/dm/eth.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/test/dm/eth.c b/test/dm/eth.c index 122fab924d6a..67fd660ee4f5 100644 --- a/test/dm/eth.c +++ b/test/dm/eth.c @@ -110,6 +110,7 @@ static int dm_test_eth_act(struct unit_test_state *uts) char ethaddr[DM_TEST_ETH_NUM][18]; int i;
+ memset(ethaddr, '\0', sizeof(ethaddr)); net_ping_ip = string_to_ip("1.1.2.2");
/* Prepare the test scenario */ @@ -119,7 +120,7 @@ static int dm_test_eth_act(struct unit_test_state *uts) ut_assertok(device_remove(dev[i], DM_REMOVE_NORMAL));
/* Invalidate MAC address */ - strcpy(ethaddr[i], env_get(addrname[i])); + strncpy(ethaddr[i], env_get(addrname[i]), 17); /* Must disable access protection for ethaddr before clearing */ env_set(".flags", addrname[i]); env_set(addrname[i], NULL); @@ -187,7 +188,8 @@ static int dm_test_eth_rotate(struct unit_test_state *uts) net_ping_ip = string_to_ip("1.1.2.2");
/* Invalidate eth1's MAC address */ - strcpy(ethaddr, env_get("eth1addr")); + memset(ethaddr, '\0', sizeof(ethaddr)); + strncpy(ethaddr, env_get("eth1addr"), 17); /* Must disable access protection for eth1addr before clearing */ env_set(".flags", "eth1addr"); env_set("eth1addr", NULL); @@ -200,7 +202,7 @@ static int dm_test_eth_rotate(struct unit_test_state *uts)
if (!retval) { /* Invalidate eth0's MAC address */ - strcpy(ethaddr, env_get("ethaddr")); + strncpy(ethaddr, env_get("ethaddr"), 17); /* Must disable access protection for ethaddr before clearing */ env_set(".flags", "ethaddr"); env_set("ethaddr", NULL);
Reviewed-by: Joe Hershberger joe.hershberger@ni.com
Reported-by: Coverity (CID: 155462, 155463) Cc: Joe Hershberger joe.hershberger@ni.com Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Joe Hershberger joe.hershberger@ni.com
Joe Hershberger
