[U-Boot] [PATCH 0/9] sunxi: A83T improvements
This series is a bunch of improvements for A83T boards, the Bananapi M3 and Cubietruck Plus in particular:
- eMMC is enabled if it wasn't enabled already - EMAC is enabled for Ethernet support - MUSB switched to gadget mode
EMAC is not fully tested. The MII and auto-negotiation part looks good. But I got "CACHE: Misaligned operation at range [bbf38940, bbf38a18]" when the EMAC is first initialized and I didn't seem to be getting any packets through. AFAIK the EMAC is the same as the H3/H5 one, minus the internal PHY support. So it should just work, and if it doesn't then the problem lies elsewhere. If this is not acceptable, feel free to drop the last four patches.
ChenYu
Chen-Yu Tsai (9): sunxi: rename Bananapi M3 dts file name sunxi: Enable eMMC on Cubietruck Plus sunxi: Fix USB PHY control register offset for A83T sunxi: Switch MUSB to gadget mode on the Bananapi M3 sunxi: Switch MUSB to gadget mode on the Cubietruck Plus net: sun8i_emac: Support RX/TX delay chains net: sun8i_emac: Fix build for non-H3/H5 SoCs sunxi: Enable EMAC on the Cubietruck Plus sunxi: Enable EMAC on the Bananapi M3
arch/arm/dts/Makefile | 4 +-- arch/arm/dts/sun8i-a83t-bananapi-m3-u-boot.dtsi | 41 ++++++++++++++++++++++ ...ovoip-bpi-m3.dts => sun8i-a83t-bananapi-m3.dts} | 0 .../arm/dts/sun8i-a83t-cubietruck-plus-u-boot.dtsi | 39 ++++++++++++++++++++ arch/arm/mach-sunxi/usb_phy.c | 2 +- configs/Cubietruck_plus_defconfig | 4 ++- configs/Sinovoip_BPI_M3_defconfig | 5 +-- drivers/net/sun8i_emac.c | 28 +++++++++++++++ 8 files changed, 117 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/sun8i-a83t-bananapi-m3-u-boot.dtsi rename arch/arm/dts/{sun8i-a83t-sinovoip-bpi-m3.dts => sun8i-a83t-bananapi-m3.dts} (100%) create mode 100644 arch/arm/dts/sun8i-a83t-cubietruck-plus-u-boot.dtsi
The upstream (Linux) device tree file for the Bananapi M3 follows the convention of using the well known brand name, instead of the vendor name, for naming. The file was recently added to upstream in commit 359b5a1e1c2d ("ARM: sun8i: a83t: Add device tree for Sinovoip Bananapi BPI-M3")
Rename the device tree file in U-boot to match.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- arch/arm/dts/Makefile | 4 ++-- .../{sun8i-a83t-sinovoip-bpi-m3.dts => sun8i-a83t-bananapi-m3.dts} | 0 configs/Sinovoip_BPI_M3_defconfig | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-) rename arch/arm/dts/{sun8i-a83t-sinovoip-bpi-m3.dts => sun8i-a83t-bananapi-m3.dts} (100%)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 762429c463d1..b7550104c340 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -307,8 +307,8 @@ dtb-$(CONFIG_MACH_SUN8I_A33) += \ sun8i-r16-parrot.dtb dtb-$(CONFIG_MACH_SUN8I_A83T) += \ sun8i-a83t-allwinner-h8homlet-v2.dtb \ - sun8i-a83t-cubietruck-plus.dtb \ - sun8i-a83t-sinovoip-bpi-m3.dtb + sun8i-a83t-bananapi-m3.dtb \ + sun8i-a83t-cubietruck-plus.dtb dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h2-plus-orangepi-zero.dtb \ sun8i-h3-bananapi-m2-plus.dtb \ diff --git a/arch/arm/dts/sun8i-a83t-sinovoip-bpi-m3.dts b/arch/arm/dts/sun8i-a83t-bananapi-m3.dts similarity index 100% rename from arch/arm/dts/sun8i-a83t-sinovoip-bpi-m3.dts rename to arch/arm/dts/sun8i-a83t-bananapi-m3.dts diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index 04d81693ebd8..f321d94e04eb 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -13,7 +13,7 @@ CONFIG_USB0_ID_DET="PH11" CONFIG_USB1_VBUS_PIN="PD24" CONFIG_AXP_GPIO=y CONFIG_SATAPWR="PD25" -CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-sinovoip-bpi-m3" +CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-bananapi-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y CONFIG_SPL=y
Applied, thanks! Maxime
Set CONFIG_MMC_SUNXI_SLOT_EXTRA=2 to enable the eMMC controller to access eMMC on the board.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- configs/Cubietruck_plus_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index 34444ec0bd09..3d999192cbc1 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -4,6 +4,7 @@ CONFIG_MACH_SUN8I_A83T=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=15355 CONFIG_DRAM_ODT_EN=y +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" CONFIG_USB0_ID_DET="PH11"
It was recently discovered that the USB PHY control register offset on the A83T is 0x410 like on the A33, not 0x404. Fix it.
Fixes: 0c935acb9e5d ("sunxi: usb_phy: Add support for A83T USB PHYs") Signed-off-by: Chen-Yu Tsai wens@csie.org --- arch/arm/mach-sunxi/usb_phy.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-sunxi/usb_phy.c b/arch/arm/mach-sunxi/usb_phy.c index 9bf0b5633d4a..3fbef0050e3f 100644 --- a/arch/arm/mach-sunxi/usb_phy.c +++ b/arch/arm/mach-sunxi/usb_phy.c @@ -19,7 +19,7 @@ #include <errno.h>
#define SUNXI_USB_PMU_IRQ_ENABLE 0x800 -#ifdef CONFIG_MACH_SUN8I_A33 +#if defined CONFIG_MACH_SUN8I_A33 || defined CONFIG_MACH_SUN8I_A83T #define SUNXI_USB_CSR 0x410 #else #define SUNXI_USB_CSR 0x404
Hi
Ok, so I think I screw this one up.
I had already a patch for that that was queued by Jagan into another branch.
I've merged both branches, it should superseed this patch.
Maxime
The Bananapi M3 has a micro-USB OTG port. It supports both host and gadget mode. Having the OTG port operate in gadget mode is more useful, as we can use it for fastboot or Ethernet over USB.
The board has 2 other USB host ports that are supported. These can be used for connecting peripherals.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- configs/Sinovoip_BPI_M3_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index f321d94e04eb..e48983fc3310 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -27,5 +27,5 @@ CONFIG_AXP_DCDC5_VOLT=1200 CONFIG_AXP_DLDO3_VOLT=2500 CONFIG_AXP_SW_ON=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_MUSB_HOST=y +CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y
I wonder whether this could become the default.
As far as I can see, having it as host can only be useful on the tablets we support.
Maybe we can add a config option for tablets device, and if it's set, enable in host mode, and if not defaults to gadget.
Eventually, we could move all the options that are not really useful on anything but a tablet that we currently select, like USB_KEYBOARD
Maxime
On Fri, Sep 22, 2017 at 4:14 PM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
There are also the cases where the OTG controller is routed to a USB host port. These are likely set top boxes. It would probably be better to have the user be able to explicitly set it to gadget mode if they want to do development, but otherwise be in host mode by default.
ChenYu
I don't know, maybe I'm heavily (confirmation) biased, but I've seen far more people using the micro USB as a gadget (or at least, not as a host, just powering the board), than people using it as hosts.
Actually, apart from the boards that are wiring it to an USB-A connector, I haven't seen anyone use that kind of setup, ever.
For the tablets where it's your only option to interact with the device since you don't have any UARTs, it makes sense. Same thing for the ones that wire it to a USB-A connector. But for all the boards out there with a micro or mini USB connector that can power them, I really feel like the default should be to a gadget.
Maxime
The Cubietruck Plus has a micro-USB OTG port. It supports both host and gadget mode. Having the OTG port operate in gadget mode is more useful, as we can use it for fastboot or Ethernet over USB.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- configs/Cubietruck_plus_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index 3d999192cbc1..3aefcc58413c 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -26,5 +26,5 @@ CONFIG_AXP_DLDO3_VOLT=2500 CONFIG_AXP_DLDO4_VOLT=3300 CONFIG_AXP_FLDO1_VOLT=1200 CONFIG_USB_EHCI_HCD=y -CONFIG_USB_MUSB_HOST=y +CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y
The EMAC syscon has configurable RX/TX delay chains for use with RGMII PHYs.
This adds support for configuring them via device tree properties. The property names and format were defined in Linux's dwmac-sun8i binding that was merged at one point.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- drivers/net/sun8i_emac.c | 25 +++++++++++++++++++++++++ 1 file changed, 25 insertions(+)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 09bbb2cdb5ca..5fa1b4c170d7 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -56,6 +56,10 @@ #define H3_EPHY_SELECT BIT(15) /* 1: internal PHY, 0: external PHY */
#define SC_RMII_EN BIT(13) +#define SC_TXDC_SHIFT 10 +#define SC_TXDC_MASK GENMASK(2, 0) +#define SC_RXDC_SHIFT 5 +#define SC_RXDC_MASK GENMASK(4, 0) #define SC_EPIT BIT(2) /* 1: RGMII, 0: MII */ #define SC_ETCS_MASK GENMASK(1, 0) #define SC_ETCS_EXT_GMII 0x1 @@ -125,6 +129,8 @@ struct emac_eth_dev { u32 addr; u32 tx_slot; bool use_internal_phy; + u32 tx_delay; + u32 rx_delay;
enum emac_variant variant; void *mac_reg; @@ -290,6 +296,12 @@ static int sun8i_emac_set_syscon(struct emac_eth_dev *priv) if (priv->variant == H3_EMAC || priv->variant == A64_EMAC) reg &= ~SC_RMII_EN;
+ /* Configure RX/TX delay chains */ + reg &= ~(SC_RXDC_MASK << SC_RXDC_SHIFT); + reg &= ~(SC_TXDC_MASK << SC_TXDC_SHIFT); + reg |= (priv->rx_delay & SC_RXDC_MASK) << SC_RXDC_SHIFT; + reg |= (priv->tx_delay & SC_TXDC_MASK) << SC_TXDC_SHIFT; + switch (priv->interface) { case PHY_INTERFACE_MODE_MII: /* default */ @@ -836,6 +848,19 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) } #endif
+ /* Get RX/TX delays for RGMII */ + priv->rx_delay = fdtdec_get_uint(gd->fdt_blob, dev_of_offset(dev), + "allwinner,rx-delay-ps", 0); + if (priv->rx_delay % 100 || priv->rx_delay > 3100) + debug("%s: invalid rx delay value\n", __func__); + priv->rx_delay /= 100; + + priv->tx_delay = fdtdec_get_uint(gd->fdt_blob, dev_of_offset(dev), + "allwinner,tx-delay-ps", 0); + if (priv->tx_delay % 100 || priv->tx_delay > 800) + debug("%s: invalid tx delay value\n", __func__); + priv->tx_delay /= 100; + return 0; }
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Maxime
u32 tx_delay;
u32 rx_delay; enum emac_variant variant; void *mac_reg;
Why not use bitfield_replace_by_mask() from include/bitfield.h?
-- 2.14.1
On Wed, Sep 27, 2017 at 11:53 PM, Joe Hershberger joe.hershberger@ni.com wrote:
u32 tx_delay;
Because I wasn't aware of such helpers. If that's preferred I'll respin the patch.
ChenYu
-- 2.14.1
Only the H3/H5 SoCs have an internal PHY and its related clock and reset controls.
Use an #ifdef to guard the internal PHY control code block so it can be built for other SoCs, such as the A83T or A64.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- drivers/net/sun8i_emac.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 5fa1b4c170d7..0a98a04967da 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -616,6 +616,8 @@ static void sun8i_emac_board_setup(struct emac_eth_dev *priv) { struct sunxi_ccm_reg *ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE;
+#ifdef CONFIG_MACH_SUNXI_H3_H5 + /* Only H3/H5 have clock controls for internal EPHY */ if (priv->use_internal_phy) { /* Set clock gating for ephy */ setbits_le32(&ccm->bus_gate4, BIT(AHB_GATE_OFFSET_EPHY)); @@ -623,6 +625,7 @@ static void sun8i_emac_board_setup(struct emac_eth_dev *priv) /* Deassert EPHY */ setbits_le32(&ccm->ahb_reset2_cfg, BIT(AHB_RESET_OFFSET_EPHY)); } +#endif
/* Set clock gating for emac */ setbits_le32(&ccm->ahb_gate0, BIT(AHB_GATE_OFFSET_GMAC));
Maxime
Reviewed-by: Joe Hershberger joe.hershberger@ni.com
On Wed, Sep 27, 2017 at 11:46 PM, Joe Hershberger joe.hershberger@ni.com wrote:
This hasn't been applied yet. Can someone apply this? Jagan?
Thanks ChenYu
Few emac patches on this series still under review, was this independent fix?
I would consider it an independent fix. Nothing prevents people from manually enabling the EMAC driver on other SoCs. They will then get a build fail that this patch fixes.
As for the other patches, I respin them soon enough.
ChenYu
Applied to u-boot-sunxi/master
thanks!
The Cubietruck Plus has an RTL8211E PHY connected to the EMAC using RGMII. The PHY is powered by DLDO4 @ 3.3V, while the I/O pins are powered by DLDO3 @ 2.5V.
This patch adds a U-boot specific dtsi file for the board adding an enabled EMAC node, and enables the EMAC driver in the defconfig. The binding used here is the old revision currently supported in U-boot. There is no stable binding nor support in upstream Linux at this time.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- .../arm/dts/sun8i-a83t-cubietruck-plus-u-boot.dtsi | 39 ++++++++++++++++++++++ configs/Cubietruck_plus_defconfig | 1 + 2 files changed, 40 insertions(+) create mode 100644 arch/arm/dts/sun8i-a83t-cubietruck-plus-u-boot.dtsi
diff --git a/arch/arm/dts/sun8i-a83t-cubietruck-plus-u-boot.dtsi b/arch/arm/dts/sun8i-a83t-cubietruck-plus-u-boot.dtsi new file mode 100644 index 000000000000..b4e216c14264 --- /dev/null +++ b/arch/arm/dts/sun8i-a83t-cubietruck-plus-u-boot.dtsi @@ -0,0 +1,39 @@ +#include "sunxi-u-boot.dtsi" + +/ { + aliases { + ethernet0 = &emac; + }; + + soc { + emac: ethernet@01c30000 { + compatible = "allwinner,sun8i-a83t-emac"; + reg = <0x01c30000 0x2000>, <0x01c00030 0x4>; + reg-names = "emac", "syscon"; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy = <&phy1>; + status = "okay"; + + phy1: ethernet-phy@1 { + reg = <1>; + }; + }; + }; +}; + +&pio { + rgmii_pins: rgmii_pins { + allwinner,pins = "PD8", "PD9", "PD10", "PD11", + "PD12", "PD13", "PD15", + "PD16", "PD17", "PD18", "PD19", + "PD20", "PD21", "PD22", "PD23"; + allwinner,function = "emac"; + allwinner,drive = <3>; + allwinner,pull = <0>; + }; +}; diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index 3aefcc58413c..ee8b901d0d08 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -22,6 +22,7 @@ CONFIG_SPL=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN8I_EMAC=y CONFIG_AXP_DLDO3_VOLT=2500 CONFIG_AXP_DLDO4_VOLT=3300 CONFIG_AXP_FLDO1_VOLT=1200
The Bananapi M3 has an RTL8211E PHY connected to the EMAC using RGMII. The PHY is powered by DCDC1 through SW @ 3.3V.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- arch/arm/dts/sun8i-a83t-bananapi-m3-u-boot.dtsi | 41 +++++++++++++++++++++++++ configs/Sinovoip_BPI_M3_defconfig | 1 + 2 files changed, 42 insertions(+) create mode 100644 arch/arm/dts/sun8i-a83t-bananapi-m3-u-boot.dtsi
diff --git a/arch/arm/dts/sun8i-a83t-bananapi-m3-u-boot.dtsi b/arch/arm/dts/sun8i-a83t-bananapi-m3-u-boot.dtsi new file mode 100644 index 000000000000..9c7977e67b92 --- /dev/null +++ b/arch/arm/dts/sun8i-a83t-bananapi-m3-u-boot.dtsi @@ -0,0 +1,41 @@ +#include "sunxi-u-boot.dtsi" + +/ { + aliases { + ethernet0 = &emac; + }; + + soc { + emac: ethernet@01c30000 { + compatible = "allwinner,sun8i-a83t-emac"; + reg = <0x01c30000 0x2000>, <0x01c00030 0x4>; + reg-names = "emac", "syscon"; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy = <&phy1>; + allwinner,rx-delay-ps = <700>; + allwinner,tx-delay-ps = <700>; + status = "okay"; + + phy1: ethernet-phy@1 { + reg = <1>; + }; + }; + }; +}; + +&pio { + rgmii_pins: rgmii_pins { + allwinner,pins = "PD8", "PD9", "PD10", "PD11", + "PD12", "PD13", "PD15", + "PD16", "PD17", "PD18", "PD19", + "PD20", "PD21", "PD22", "PD23"; + allwinner,function = "emac"; + allwinner,drive = <3>; + allwinner,pull = <0>; + }; +}; diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index e48983fc3310..efdf3c7396fd 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN8I_EMAC=y CONFIG_AXP_DCDC5_VOLT=1200 CONFIG_AXP_DLDO3_VOLT=2500 CONFIG_AXP_SW_ON=y
Chen-Yu Tsai
Jagan Teki
Joe Hershberger
Maxime Ripard
