[PATCH v2 0/2] Enable booting from SPI flash on ROCK Pi 4
This series brings up and enables booting from the SPI flash present on some variants of the ROCK Pi 4 in U-Boot.
The first patch syncs the ROCK Pi 4A devicetree from Linux, which contains the SPI flash node.
The second patch enables support in U-Boot for the SPI flash chip and booting U-Boot from the SPI flash on the Radxa ROCK Pi 4.
This series may be found at [0].
[0]: https://gitlab.collabora.com/obbardc/u-boot/-/tree/wip/obbardc/rockchip-rock...
Changes in v2: - Collect Reviewed-by tags. - Rebase on top of rockchip/for-next. - Sync configuration changes with savedefconfig. - Remove GigaDevice SPI flash chip support (suggested by Kever Y). - Re-enable CONFIG_SPL_FIT_SIGNATURE=y (fixed in rockchip/for-next, solves multiple problems mentioned in v1. Thanks Jonas!). - Remove spl-boot-order from rk3399-rock-pi-4a-u-boot.dtsi (suggested by Jonas K). - Enable CONFIG_SPI_FLASH_SFDP_SUPPORT=y (suggested by Jonas K). - v1: https://lists.denx.de/pipermail/u-boot/2024-March/547173.html
Christopher Obbard (2): arm: rockchip: sync ROCK Pi 4A DTS from Linux rockchip: rock-pi-4-rk3399: enable booting from SPI flash
arch/arm/dts/rk3399-rock-pi-4a-u-boot.dtsi | 7 +++++++ arch/arm/dts/rk3399-rock-pi-4a.dts | 10 ++++++++++ configs/rock-pi-4-rk3399_defconfig | 17 ++++++++++++++--- 3 files changed, 31 insertions(+), 3 deletions(-)
To prepare for ROCK Pi 4A SPI flash support, sync the DTS from Linux which includes an SPI flash node.
Kernel tag: v6.6-rc1 Kernel commits: - eddf73029770 ("arm64: dts: rockchip: Enable internal SPI flash for ROCK \ Pi 4A/B/C")
Reviewed-by: Kever Yang kever.yang@rock-chips.com Signed-off-by: Christopher Obbard chris.obbard@collabora.com ---
Changes in v2: - Collect Reviewed-by tag from Kever Y.
arch/arm/dts/rk3399-rock-pi-4a.dts | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/dts/rk3399-rock-pi-4a.dts b/arch/arm/dts/rk3399-rock-pi-4a.dts index 931334aa3d6..d5df8939a65 100644 --- a/arch/arm/dts/rk3399-rock-pi-4a.dts +++ b/arch/arm/dts/rk3399-rock-pi-4a.dts @@ -12,3 +12,13 @@ model = "Radxa ROCK Pi 4A"; compatible = "radxa,rockpi4a", "radxa,rockpi4", "rockchip,rk3399"; }; + +&spi1 { + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <10000000>; + }; +};
Reviewed-by: Jonas Karlman jonas@kwiboo.se
Regards, Jonas
Changes in v2:
+&spi1 {
- status = "okay";
- flash@0 {
reg = <0>;
Some variants of the ROCK Pi 4 series have an SPI flash chip populated which can be booted from. This patch enables support in U-Boot for building the image for the SPI flash, support for booting U-Boot from the SPI flash chip and support in U-Boot for accessing the SPI flash using `sf` commands.
Not all variants (e.g. ROCK Pi 4B, ROCK 4 Model C Plus, ROCK 4SE) come populated with an SPI flash chip, but have the footprint on the board so a user could solder their own to the board. With this patchset applied, these board variants without an SPI flash chip still boot from MMC.
I have enabled support for both Winbond and XTX SPI flash devices since different hardware variants have different devices populated:
- `rockpi4_v13_sch_20181112.pdf` contains a Winbond part `W25Q64FWZPIG` - `rockpi4_v14_sch_20210114.pdf` contains an XTX part `XT25F32BWOIGT`
The ROCK Pi 4 I have is marked as "ROCK PI 4 v1.48" and contains an SPI flash chip from XTX:
=> sf probe SF: Detected xt25f32 with page size 256 Bytes, erase size 4 KiB, total 4 MiB
In the interest of supporting all board variants and not regressing existing users who boot from MMC, I have enabled support for booting from both SPI flash chip variants in the defconfig and left the environment storage location as MMC to not break existing users who have the environment stored on MMC.
Changes in v2: - Rebase on top of rockchip/for-next. - Sync configuration changes with savedefconfig. - Remove GigaDevice SPI flash chip support (suggested by Kever Y). - Re-enable CONFIG_SPL_FIT_SIGNATURE=y (fixed in rockchip/for-next, solves multiple problems mentioned in v1. Thanks Jonas!). - Remove spl-boot-order from rk3399-rock-pi-4a-u-boot.dtsi (suggested by Jonas K). - Enable CONFIG_SPI_FLASH_SFDP_SUPPORT=y (suggested by Jonas K).
arch/arm/dts/rk3399-rock-pi-4a-u-boot.dtsi | 7 +++++++ configs/rock-pi-4-rk3399_defconfig | 17 ++++++++++++++--- 2 files changed, 21 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/rk3399-rock-pi-4a-u-boot.dtsi b/arch/arm/dts/rk3399-rock-pi-4a-u-boot.dtsi index 85ee5770add..38385621deb 100644 --- a/arch/arm/dts/rk3399-rock-pi-4a-u-boot.dtsi +++ b/arch/arm/dts/rk3399-rock-pi-4a-u-boot.dtsi @@ -4,3 +4,10 @@ */
#include "rk3399-rock-pi-4-u-boot.dtsi" + +&spi1 { + flash@0 { + bootph-pre-ram; + bootph-some-ram; + }; +}; diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index bca44beca12..315b8b853fc 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -3,25 +3,30 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock-pi-4a" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_SPI_IMAGE=y CONFIG_TARGET_ROCKPI4_RK3399=y CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_PCI=y CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_SPL_FIT_SIGNATURE=y -CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-pi-4a.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0xE0000 CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y CONFIG_TPL=y CONFIG_CMD_BOOTZ=y @@ -40,14 +45,20 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_ROCKCHIP_IODOMAIN=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XTX=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y CONFIG_NVME_PCI=y @@ -61,6 +72,7 @@ CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y @@ -81,7 +93,6 @@ CONFIG_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y CONFIG_DISPLAY_ROCKCHIP_HDMI=y -CONFIG_SPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y
Hi Christopher,
With a small nit below this is:
Changes in v2:
+&spi1 {
- flash@0 {
bootph-pre-ram;
bootph-some-ram;
This may stop scripts from working.
I am getting very close to send out a big rk3399 DT sync and update series [1] on top of your series. That series will move to imply LEGACY_IMAGE_FORMAT in Kconfig file, so this does not matter that much.
Please let me know if you will revert this line or if I should send out my series on top of this patch as-is :-)
[1] https://github.com/Kwiboo/u-boot-rockchip/commits/rk3399-2024.07-wip
Regards, Jonas
Hi Jonas,
On Mon, 2024-03-18 at 11:37 +0100, Jonas Karlman wrote:
Hi Christopher,
Changes in v2:
Jonas K).
diff --git a/arch/arm/dts/rk3399-rock-pi-4a-u-boot.dtsi b/arch/arm/dts/rk3399-rock-pi-4a-u-boot.dtsi index 85ee5770add..38385621deb 100644 --- a/arch/arm/dts/rk3399-rock-pi-4a-u-boot.dtsi +++ b/arch/arm/dts/rk3399-rock-pi-4a-u-boot.dtsi @@ -4,3 +4,10 @@ */ #include "rk3399-rock-pi-4-u-boot.dtsi"
+&spi1 {
- flash@0 {
bootph-pre-ram;
bootph-some-ram;
+}; diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4- rk3399_defconfig index bca44beca12..315b8b853fc 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -3,25 +3,30 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock-pi-4a" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_SPI_IMAGE=y CONFIG_TARGET_ROCKPI4_RK3399=y CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_PCI=y CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_SPL_FIT_SIGNATURE=y -CONFIG_LEGACY_IMAGE_FORMAT=y
Thanks for the review!
I will spin v3 of this series next week.
Regards, Jonas
CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-pi-4a.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0xE0000 CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y CONFIG_TPL=y CONFIG_CMD_BOOTZ=y @@ -40,14 +45,20 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock- parents" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_ROCKCHIP_IODOMAIN=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XTX=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y CONFIG_NVME_PCI=y @@ -61,6 +72,7 @@ CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y @@ -81,7 +93,6 @@ CONFIG_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y CONFIG_DISPLAY_ROCKCHIP_HDMI=y -CONFIG_SPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y
Thanks !
Christopher Obbard
Jonas Karlman
