[PATCH] arm: dts: ls1028a: Add dspi flash device node to qds
Add dspi flash device node to fsl-ls1028a-qds.dtsi
Signed-off-by: Zhao Qiang qiang.zhao@nxp.com --- arch/arm/dts/fsl-ls1028a-qds.dtsi | 74 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 74 insertions(+)
diff --git a/arch/arm/dts/fsl-ls1028a-qds.dtsi b/arch/arm/dts/fsl-ls1028a-qds.dtsi index 4f56f40..6cdcce1 100644 --- a/arch/arm/dts/fsl-ls1028a-qds.dtsi +++ b/arch/arm/dts/fsl-ls1028a-qds.dtsi @@ -15,20 +15,94 @@ compatible = "fsl,ls1028a-qds", "fsl,ls1028a"; aliases { spi0 = &fspi; + spi1 = &dspi0; + spi2 = &dspi1; + spi3 = &dspi2; };
&dspi0 { + bus-num = <0>; status = "okay"; + + dflash0: sst25wf040b { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3000000>; + spi-cpol; + spi-cpha; + reg = <0>; + }; + + dflash1: en25s64 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3000000>; + spi-cpol; + spi-cpha; + reg = <1>; + }; + dflash2: n25q128a { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3000000>; + spi-cpol; + spi-cpha; + reg = <2>; + }; };
&dspi1 { + bus-num = <0>; status = "okay"; + + dflash3: sst25wf040b { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3000000>; + spi-cpol; + spi-cpha; + reg = <0>; + }; + + dflash4: en25s64 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3000000>; + spi-cpol; + spi-cpha; + reg = <1>; + }; + dflash5: n25q128a { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3000000>; + spi-cpol; + spi-cpha; + reg = <2>; + }; };
&dspi2 { + bus-num = <0>; status = "okay"; + + dflash8: en25s64 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3000000>; + spi-cpol; + spi-cpha; + reg = <0>; + }; };
&esdhc0 {
Qiang Zhao
