[PATCH v8 00/12] Actions S700 SoC support
This adds Cubieboard7[1] support based on Action Semi's S700 SoC[2], It's Quad-core ARMv8 SoC with Cortex-A53 cores. Peripheral like UART seems to be compatible with S900 SoC(basic support for it is alreay present in u-boot).
This series(v8) removes the SoC specific include instead just uses owl-common. For this patch 01/12 and 09/12 changes a bit.
Previous series(v7) fixes a serious Bug that breaks S900, it was there since v5.Thanks to Andre for pointing it out.
Series(v6)[3] does following changes:
* [PATCH v5 06/11] becomes [PATCH v6 03/11] * [PATCH v5 03/11] becomes [PATCH v6 04/11] * Introduce a new patch to move defconfig options to Kconfig which is [PATCH v6 10/12]
Series(v5)[4] just re-orders the patches so that U-BOOT(with bubblegum96_defconfig) builds after every patch of the series(suggested by Andre).
S700 support is tested[5] on Cubieboard7 board and S900 support is just compiled tested.
This patch series can be tested using below tree: https://github.com/Atomar25/u-boot/commits/s700_v8
[1]: http://www.cubietech.com/product-detail/cubieboard7/ [2]: http://www.actions-semi.com/en/productview.aspx?id=225 [3]: http://u-boot.10912.n7.nabble.com/PATCH-v6-00-12-Actions-S700-SoC-support-td... [4]: http://u-boot.10912.n7.nabble.com/PATCH-v5-00-11-Actions-S700-SoC-support-td... [5]: https://paste.ubuntu.com/p/xGYVbSytRS/
Amit Singh Tomar (12): arm: actions: Add common framework for Actions Owl Semi SoCs arm: actions: rename sysmap-s900 to sysmap-owl serial: actions: add compatible string arm: dts: sync dts for Action Semi S900 arm: dts: actions: s900: add u-boot specific dtsi file clk: actions: Add common clock driver arm: actions: add S700 SoC device tree arm: dts: actions: s700: add u-boot specific dtsi file arm: add support Actions Semi S700 actions: Move defconfig options to Kconfig arm: add Cubieboard7 board support doc: boards: add Cubieboard7 documentation
MAINTAINERS | 2 + arch/arm/Kconfig | 5 +- arch/arm/dts/Makefile | 6 +- arch/arm/dts/s700-cubieboard7.dts | 92 +++++++ arch/arm/dts/s700-u-boot.dtsi | 18 ++ arch/arm/dts/s700.dtsi | 248 +++++++++++++++++++ arch/arm/dts/s900-u-boot.dtsi | 17 ++ arch/arm/dts/s900.dtsi | 322 +++++++++++++++++++++++-- arch/arm/include/asm/arch-owl/clk_s900.h | 57 ----- arch/arm/include/asm/arch-owl/regs_s700.h | 56 +++++ arch/arm/mach-owl/Kconfig | 50 ++-- arch/arm/mach-owl/Makefile | 3 +- arch/arm/mach-owl/soc.c | 57 +++++ arch/arm/mach-owl/sysmap-owl.c | 32 +++ arch/arm/mach-owl/sysmap-s900.c | 32 --- board/ucRobotics/bubblegum_96/Kconfig | 15 -- board/ucRobotics/bubblegum_96/MAINTAINERS | 6 - board/ucRobotics/bubblegum_96/Makefile | 3 - board/ucRobotics/bubblegum_96/bubblegum_96.c | 57 ----- configs/bubblegum_96_defconfig | 12 +- configs/cubieboard7_defconfig | 9 + doc/board/actions/cubieboard7.rst | 115 +++++++++ doc/board/actions/index.rst | 10 + doc/board/index.rst | 1 + drivers/clk/owl/Kconfig | 8 +- drivers/clk/owl/Makefile | 2 +- drivers/clk/owl/clk_owl.c | 153 ++++++++++++ drivers/clk/owl/clk_owl.h | 65 +++++ drivers/clk/owl/clk_s900.c | 137 ----------- drivers/serial/serial_owl.c | 2 +- include/configs/bubblegum_96.h | 40 --- include/configs/owl-common.h | 40 +++ include/configs/s700.h | 13 + include/configs/s900.h | 16 ++ include/dt-bindings/clock/actions,s700-cmu.h | 118 +++++++++ include/dt-bindings/clock/actions,s900-cmu.h | 129 ++++++++++ include/dt-bindings/clock/s900_cmu.h | 77 ------ include/dt-bindings/reset/actions,s700-reset.h | 34 +++ include/dt-bindings/reset/actions,s900-reset.h | 65 +++++ 39 files changed, 1638 insertions(+), 486 deletions(-) create mode 100644 arch/arm/dts/s700-cubieboard7.dts create mode 100644 arch/arm/dts/s700-u-boot.dtsi create mode 100644 arch/arm/dts/s700.dtsi create mode 100644 arch/arm/dts/s900-u-boot.dtsi delete mode 100644 arch/arm/include/asm/arch-owl/clk_s900.h create mode 100644 arch/arm/include/asm/arch-owl/regs_s700.h create mode 100644 arch/arm/mach-owl/soc.c create mode 100644 arch/arm/mach-owl/sysmap-owl.c delete mode 100644 arch/arm/mach-owl/sysmap-s900.c delete mode 100644 board/ucRobotics/bubblegum_96/Kconfig delete mode 100644 board/ucRobotics/bubblegum_96/MAINTAINERS delete mode 100644 board/ucRobotics/bubblegum_96/Makefile delete mode 100644 board/ucRobotics/bubblegum_96/bubblegum_96.c create mode 100644 configs/cubieboard7_defconfig create mode 100644 doc/board/actions/cubieboard7.rst create mode 100644 doc/board/actions/index.rst create mode 100644 drivers/clk/owl/clk_owl.c create mode 100644 drivers/clk/owl/clk_owl.h delete mode 100644 drivers/clk/owl/clk_s900.c delete mode 100644 include/configs/bubblegum_96.h create mode 100644 include/configs/owl-common.h create mode 100644 include/configs/s700.h create mode 100644 include/configs/s900.h create mode 100644 include/dt-bindings/clock/actions,s700-cmu.h create mode 100644 include/dt-bindings/clock/actions,s900-cmu.h delete mode 100644 include/dt-bindings/clock/s900_cmu.h create mode 100644 include/dt-bindings/reset/actions,s700-reset.h create mode 100644 include/dt-bindings/reset/actions,s900-reset.h
This commit adds common arch support for Actions Semi Owl series SoCs and removes the Bubblegum96 board files.
Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- Changes since v7: * Removed S900 specific include file. * Removed the file list entry in MAINTAINERS file. Changes since v6: * No change. Changes since v5: * No change. Changes since v4: * No change. Changes since v3: * Corrected the file list entry in MAINTAINERS file. Changes since v2: * Moved the file list details to root MAINTAINERS file. * Updated the commit message as suggested by Mani. * Used the "Owl" keyword to describe SoC family. Changes since v1: * Moved S700 specific changes to patch 4 of 9. * Moved couple of symbols from defconfig to arch/arm/Kconfig and platform owl Kconfig. --- MAINTAINERS | 3 +- arch/arm/Kconfig | 3 +- arch/arm/mach-owl/Kconfig | 29 ++++++-------- arch/arm/mach-owl/Makefile | 1 + arch/arm/mach-owl/soc.c | 57 ++++++++++++++++++++++++++++ board/ucRobotics/bubblegum_96/Kconfig | 15 -------- board/ucRobotics/bubblegum_96/MAINTAINERS | 6 --- board/ucRobotics/bubblegum_96/Makefile | 3 -- board/ucRobotics/bubblegum_96/bubblegum_96.c | 57 ---------------------------- configs/bubblegum_96_defconfig | 4 +- include/configs/bubblegum_96.h | 40 ------------------- include/configs/owl-common.h | 40 +++++++++++++++++++ 12 files changed, 114 insertions(+), 144 deletions(-) create mode 100644 arch/arm/mach-owl/soc.c delete mode 100644 board/ucRobotics/bubblegum_96/Kconfig delete mode 100644 board/ucRobotics/bubblegum_96/MAINTAINERS delete mode 100644 board/ucRobotics/bubblegum_96/Makefile delete mode 100644 board/ucRobotics/bubblegum_96/bubblegum_96.c delete mode 100644 include/configs/bubblegum_96.h create mode 100644 include/configs/owl-common.h
diff --git a/MAINTAINERS b/MAINTAINERS index 92dda40..73ee1ac 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -272,9 +272,10 @@ M: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org S: Maintained F: arch/arm/include/asm/arch-owl/ F: arch/arm/mach-owl/ -F: board/ucRobotics/ F: drivers/clk/owl/ F: drivers/serial/serial_owl.c +F: include/configs/owl-common.h +F: configs/bubblegum_96_defconfig
ARM RENESAS RMOBILE/R-CAR M: Nobuhiro Iwamatsu iwamatsu@nigauri.org diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 5d36788..1cfdcb6 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -873,9 +873,9 @@ config ARCH_MX5
config ARCH_OWL bool "Actions Semi OWL SoCs" - select ARM64 select DM select DM_SERIAL + select OWL_SERIAL select OF_CONTROL imply CMD_DM
@@ -1865,7 +1865,6 @@ source "board/spear/spear600/Kconfig" source "board/spear/x600/Kconfig" source "board/st/stv0991/Kconfig" source "board/tcl/sl50/Kconfig" -source "board/ucRobotics/bubblegum_96/Kconfig" source "board/birdland/bav335x/Kconfig" source "board/toradex/colibri_pxa270/Kconfig" source "board/variscite/dart_6ul/Kconfig" diff --git a/arch/arm/mach-owl/Kconfig b/arch/arm/mach-owl/Kconfig index 199e772..28984c1 100644 --- a/arch/arm/mach-owl/Kconfig +++ b/arch/arm/mach-owl/Kconfig @@ -1,27 +1,22 @@ if ARCH_OWL
-config SYS_SOC - default "owl" - choice - prompt "Actions Semi OWL SoCs board select" + prompt "Actions Semi Owl SoC Variant" optional
-config TARGET_BUBBLEGUM_96 - bool "96Boards Bubblegum-96" - help - Support for 96Boards Bubblegum-96. This board complies with - 96Board Consumer Edition Specification. Features: - - Actions Semi S900 SoC (4xCortex A53, Power VR G6230 GPU) - - 2GiB RAM - - 8GiB eMMC, uSD slot - - WiFi, Bluetooth and GPS module - - 2x Host, 1x Device USB port - - HDMI - - 20-pin low speed and 40-pin high speed expanders, 6 LED, 3 buttons +config MACH_S900 + bool "Actions Semi S900 SoC" + select ARM64
endchoice
-source "board/ucRobotics/bubblegum_96/Kconfig" +config SYS_TEXT_BASE + default 0x11000000 + +config SYS_CONFIG_NAME + default "owl-common" + +config SYS_SOC + default "s900" if MACH_S900
endif diff --git a/arch/arm/mach-owl/Makefile b/arch/arm/mach-owl/Makefile index 1b43dc2..0b181c6 100644 --- a/arch/arm/mach-owl/Makefile +++ b/arch/arm/mach-owl/Makefile @@ -1,3 +1,4 @@ # SPDX-License-Identifier: GPL-2.0+
+obj-y += soc.o obj-y += sysmap-s900.o diff --git a/arch/arm/mach-owl/soc.c b/arch/arm/mach-owl/soc.c new file mode 100644 index 0000000..409cbd3 --- /dev/null +++ b/arch/arm/mach-owl/soc.c @@ -0,0 +1,57 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Actions Semi Owl SoCs platform support. + * + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +#include <cpu_func.h> +#include <linux/arm-smccc.h> +#include <linux/psci.h> +#include <common.h> +#include <asm/io.h> +#include <asm/mach-types.h> +#include <asm/psci.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * dram_init - sets uboots idea of sdram size + */ +int dram_init(void) +{ + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + return 0; +} + +/* This is called after dram_init() so use get_ram_size result */ +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = gd->ram_size; + + return 0; +} + +static void show_psci_version(void) +{ + struct arm_smccc_res res; + + arm_smccc_smc(ARM_PSCI_0_2_FN_PSCI_VERSION, 0, 0, 0, 0, 0, 0, 0, &res); + + printf("PSCI: v%ld.%ld\n", + PSCI_VERSION_MAJOR(res.a0), + PSCI_VERSION_MINOR(res.a0)); +} + +int board_init(void) +{ + show_psci_version(); + + return 0; +} + +void reset_cpu(ulong addr) +{ + psci_system_reset(); +} diff --git a/board/ucRobotics/bubblegum_96/Kconfig b/board/ucRobotics/bubblegum_96/Kconfig deleted file mode 100644 index 2dd40d9..0000000 --- a/board/ucRobotics/bubblegum_96/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if TARGET_BUBBLEGUM_96 - -config SYS_BOARD - default "bubblegum_96" - -config SYS_VENDOR - default "ucRobotics" - -config SYS_SOC - default "s900" - -config SYS_CONFIG_NAME - default "bubblegum_96" - -endif diff --git a/board/ucRobotics/bubblegum_96/MAINTAINERS b/board/ucRobotics/bubblegum_96/MAINTAINERS deleted file mode 100644 index d0cb727..0000000 --- a/board/ucRobotics/bubblegum_96/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -BUBBLEGUM_96 BOARD -M: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org -S: Maintained -F: board/ucRobotics/bubblegum_96/ -F: include/configs/bubblegum_96.h -F: configs/bubblegum_96_defconfig diff --git a/board/ucRobotics/bubblegum_96/Makefile b/board/ucRobotics/bubblegum_96/Makefile deleted file mode 100644 index c4b524d..0000000 --- a/board/ucRobotics/bubblegum_96/Makefile +++ /dev/null @@ -1,3 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ - -obj-y := bubblegum_96.o diff --git a/board/ucRobotics/bubblegum_96/bubblegum_96.c b/board/ucRobotics/bubblegum_96/bubblegum_96.c deleted file mode 100644 index c16f117..0000000 --- a/board/ucRobotics/bubblegum_96/bubblegum_96.c +++ /dev/null @@ -1,57 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Bubblegum-96 Boards Support - * - * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org - */ - -#include <cpu_func.h> -#include <linux/arm-smccc.h> -#include <linux/psci.h> -#include <common.h> -#include <asm/io.h> -#include <asm/mach-types.h> -#include <asm/psci.h> - -DECLARE_GLOBAL_DATA_PTR; - -/* - * dram_init - sets uboots idea of sdram size - */ -int dram_init(void) -{ - gd->ram_size = CONFIG_SYS_SDRAM_SIZE; - return 0; -} - -/* This is called after dram_init() so use get_ram_size result */ -int dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; - gd->bd->bi_dram[0].size = gd->ram_size; - - return 0; -} - -static void show_psci_version(void) -{ - struct arm_smccc_res res; - - arm_smccc_smc(ARM_PSCI_0_2_FN_PSCI_VERSION, 0, 0, 0, 0, 0, 0, 0, &res); - - printf("PSCI: v%ld.%ld\n", - PSCI_VERSION_MAJOR(res.a0), - PSCI_VERSION_MINOR(res.a0)); -} - -int board_init(void) -{ - show_psci_version(); - - return 0; -} - -void reset_cpu(ulong addr) -{ - psci_system_reset(); -} diff --git a/configs/bubblegum_96_defconfig b/configs/bubblegum_96_defconfig index ae44ce1..8c94def 100644 --- a/configs/bubblegum_96_defconfig +++ b/configs/bubblegum_96_defconfig @@ -1,9 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_OWL=y -CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_ENV_SIZE=0x2000 -CONFIG_TARGET_BUBBLEGUM_96=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_MACH_S900=y CONFIG_IDENT_STRING="\nBubblegum-96" CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=5 @@ -21,4 +20,3 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_CLK=y CONFIG_CLK_OWL=y CONFIG_CLK_S900=y -CONFIG_OWL_SERIAL=y diff --git a/include/configs/bubblegum_96.h b/include/configs/bubblegum_96.h deleted file mode 100644 index c739d66..0000000 --- a/include/configs/bubblegum_96.h +++ /dev/null @@ -1,40 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Board configuration file for Bubblegum-96 - * - * Copyright (C) 2015 Actions Semi Co., Ltd. - * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org - * - */ - -#ifndef _BUBBLEGUM_96_H_ -#define _BUGGLEGUM_96_H_ - -/* SDRAM Definitions */ -#define CONFIG_SYS_SDRAM_BASE 0x0 -#define CONFIG_SYS_SDRAM_SIZE 0x80000000 - -/* Generic Timer Definitions */ -#define COUNTER_FREQUENCY (24000000) /* 24MHz */ - -#define CONFIG_SYS_MALLOC_LEN (32 * 1024 * 1024) - -/* Some commands use this as the default load address */ -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7ffc0) - -/* - * This is the initial SP which is used only briefly for relocating the u-boot - * image to the top of SDRAM. After relocation u-boot moves the stack to the - * proper place. - */ -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + 0x7ff00) - -/* UART Definitions */ -#define CONFIG_BAUDRATE 115200 - -/* Console configuration */ -#define CONFIG_SYS_CBSIZE 1024 /* Console buffer size */ -#define CONFIG_SYS_MAXARGS 64 -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -#endif diff --git a/include/configs/owl-common.h b/include/configs/owl-common.h new file mode 100644 index 0000000..f77a5fa --- /dev/null +++ b/include/configs/owl-common.h @@ -0,0 +1,40 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Board configuration file for Actions Semi Owl SoCs. + * + * Copyright (C) 2015 Actions Semi Co., Ltd. + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + * + */ + +#ifndef _OWL_COMMON_CONFIG_H_ +#define _OWL_COMMON_CONFIG_H_ + +/* SDRAM Definitions */ +#define CONFIG_SYS_SDRAM_BASE 0x0 +#define CONFIG_SYS_SDRAM_SIZE 0x80000000 + +/* Generic Timer Definitions */ +#define COUNTER_FREQUENCY (24000000) /* 24MHz */ + +#define CONFIG_SYS_MALLOC_LEN (32 * 1024 * 1024) + +/* Some commands use this as the default load address */ +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7ffc0) + +/* + * This is the initial SP which is used only briefly for relocating the u-boot + * image to the top of SDRAM. After relocation u-boot moves the stack to the + * proper place. + */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + 0x7ff00) + +/* UART Definitions */ +#define CONFIG_BAUDRATE 115200 + +/* Console configuration */ +#define CONFIG_SYS_CBSIZE 1024 /* Console buffer size */ +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#endif
Reviewed-by: Andre Przywara andre.przywara@arm.com
Cheers, Andre
Changes since v7:
- Removed S900 specific include file.
- Removed the file list entry in MAINTAINERS file.
- select OWL_SERIAL select OF_CONTROL imply CMD_DM
-config SYS_SOC
- default "owl"
choice
- help
- 2GiB RAM
- HDMI
+config MACH_S900
select ARM64
endchoice
default 0x11000000
+config SYS_SOC
- Actions Semi Owl SoCs platform support.
- Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org
- dram_init - sets uboots idea of sdram size
-config SYS_BOARD
-config SYS_VENDOR
-config SYS_SOC
- default "s900"
- Bubblegum-96 Boards Support
- Board configuration file for Bubblegum-96
- Copyright (C) 2015 Actions Semi Co., Ltd.
- This is the initial SP which is used only briefly for relocating the u-boot
- image to the top of SDRAM. After relocation u-boot moves the stack to the
- proper place.
- Board configuration file for Actions Semi Owl SoCs.
- proper place.
Now that memory maps(for both S700 and S900 SoCs) can be managed using a common file, rename sysmap-s900 to sysmap-owl to reflect the same.
Reviewed-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- Changes since v7: * No changes. Changes since v6: * No changes. Changes since v5: * No changes. Changes since v4: * No changes. Changes since v3: * Added reviewed-by tag. Changes since v2: * Fixed the commit message and header. Changes since v1: * compile sysmap-owl.c against CONFIG_ARM64 now. --- arch/arm/mach-owl/Makefile | 2 +- arch/arm/mach-owl/sysmap-owl.c | 32 ++++++++++++++++++++++++++++++++ arch/arm/mach-owl/sysmap-s900.c | 32 -------------------------------- 3 files changed, 33 insertions(+), 33 deletions(-) create mode 100644 arch/arm/mach-owl/sysmap-owl.c delete mode 100644 arch/arm/mach-owl/sysmap-s900.c
diff --git a/arch/arm/mach-owl/Makefile b/arch/arm/mach-owl/Makefile index 0b181c6..f3a69eb 100644 --- a/arch/arm/mach-owl/Makefile +++ b/arch/arm/mach-owl/Makefile @@ -1,4 +1,4 @@ # SPDX-License-Identifier: GPL-2.0+
obj-y += soc.o -obj-y += sysmap-s900.o +obj-$(CONFIG_ARM64) += sysmap-owl.o diff --git a/arch/arm/mach-owl/sysmap-owl.c b/arch/arm/mach-owl/sysmap-owl.c new file mode 100644 index 0000000..81f6ca2 --- /dev/null +++ b/arch/arm/mach-owl/sysmap-owl.c @@ -0,0 +1,32 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Memory map for Actions Semi Owl series SoCs. + * + * Copyright (C) 2015 Actions Semi Co., Ltd. + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +#include <common.h> +#include <asm/armv8/mmu.h> + +static struct mm_region owl_mem_map[] = { + { + .virt = 0x0UL, /* DDR */ + .phys = 0x0UL, /* DDR */ + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0xE0000000UL, /* Peripheral block */ + .phys = 0xE0000000UL, /* Peripheral block */ + .size = 0x08000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* List terminator */ + 0, + } +}; + +struct mm_region *mem_map = owl_mem_map; diff --git a/arch/arm/mach-owl/sysmap-s900.c b/arch/arm/mach-owl/sysmap-s900.c deleted file mode 100644 index f78b639..0000000 --- a/arch/arm/mach-owl/sysmap-s900.c +++ /dev/null @@ -1,32 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Actions Semi S900 Memory map - * - * Copyright (C) 2015 Actions Semi Co., Ltd. - * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org - */ - -#include <common.h> -#include <asm/armv8/mmu.h> - -static struct mm_region s900_mem_map[] = { - { - .virt = 0x0UL, /* DDR */ - .phys = 0x0UL, /* DDR */ - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0xE0000000UL, /* Peripheral block */ - .phys = 0xE0000000UL, /* Peripheral block */ - .size = 0x08000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - /* List terminator */ - 0, - } -}; - -struct mm_region *mem_map = s900_mem_map;
This patch adds "actions,owl-uart" string to the owl uart driver. It is also defined in Linux kernel.
Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- Changes since v7: * No changes. Changes since v6: * Added Reviewd-by tag. Changes since v5: * Moved it to from 06/11 to 03/11. * Used appropriate commit message. * Removed the reviwed-by tag. Changes since v4: * Moved it to from 09/11 to 06/11. Changes since v3: * Used only owl-uart for compatible string. Changes since v2: * No changes. Changes since v1: * No changes. --- drivers/serial/serial_owl.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/serial/serial_owl.c b/drivers/serial/serial_owl.c index 7ead73e..539acdc 100644 --- a/drivers/serial/serial_owl.c +++ b/drivers/serial/serial_owl.c @@ -121,6 +121,7 @@ static const struct dm_serial_ops owl_serial_ops = {
static const struct udevice_id owl_serial_ids[] = { { .compatible = "actions,s900-serial" }, + { .compatible = "actions,owl-uart" }, { } };
Synchronize device tree bindings with v5.5-rc6 tag with commit id "b3a987b0264d".
Also, it removes older clock binding defined for S900 along with undocumented compatible string "actions,s900-serial" from serial driver and adapts clock driver to cater to new bindings.
Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- Changes since v7: * No changes. Changes since v6: * Added Reviewed-by tag. Changes since v5: * Moved it 04/11 from 03/11. * removed the undocumented compatible string "actions,s900-serial". * removed the reviewed-by tag. Changes since v4: * This patch is re-ordered, moved from 07/11 to 03/11. * Used the commit-id(12 chars long) in commit message. Changes since v3: * Added Reviewed-by: tag. Changes since v2: * Newly added patch, not there in v2/v1. --- arch/arm/dts/s900.dtsi | 322 +++++++++++++++++++++++-- drivers/clk/owl/clk_s900.c | 6 +- drivers/serial/serial_owl.c | 1 - include/dt-bindings/clock/actions,s900-cmu.h | 129 ++++++++++ include/dt-bindings/clock/s900_cmu.h | 77 ------ include/dt-bindings/reset/actions,s900-reset.h | 65 +++++ 6 files changed, 498 insertions(+), 102 deletions(-) create mode 100644 include/dt-bindings/clock/actions,s900-cmu.h delete mode 100644 include/dt-bindings/clock/s900_cmu.h create mode 100644 include/dt-bindings/reset/actions,s900-reset.h
diff --git a/arch/arm/dts/s900.dtsi b/arch/arm/dts/s900.dtsi index 2bbb30a..eb35cf7 100644 --- a/arch/arm/dts/s900.dtsi +++ b/arch/arm/dts/s900.dtsi @@ -1,17 +1,94 @@ -// SPDX-License-Identifier: GPL-2.0+ -// -// Device Tree Source for Actions Semi S900 SoC -// -// Copyright (C) 2015 Actions Semi Co., Ltd. -// Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2017 Andreas Färber + */
-/dts-v1/; -#include <dt-bindings/clock/s900_cmu.h> +#include <dt-bindings/clock/actions,s900-cmu.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/reset/actions,s900-reset.h>
/ { compatible = "actions,s900"; - #address-cells = <0x2>; - #size-cells = <0x2>; + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + cpus { + #address-cells = <2>; + #size-cells = <0>; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x0>; + enable-method = "psci"; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x1>; + enable-method = "psci"; + }; + + cpu2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x2>; + enable-method = "psci"; + }; + + cpu3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x3>; + enable-method = "psci"; + }; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + secmon@1f000000 { + reg = <0x0 0x1f000000 0x0 0x1000000>; + no-map; + }; + }; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + + arm-pmu { + compatible = "arm,cortex-a53-pmu"; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; + }; + + hosc: hosc { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + #clock-cells = <0>; + };
losc: losc { compatible = "fixed-clock"; @@ -26,28 +103,231 @@ };
soc { - u-boot,dm-pre-reloc; compatible = "simple-bus"; - #address-cells = <0x2>; - #size-cells = <0x2>; + #address-cells = <2>; + #size-cells = <2>; ranges;
+ gic: interrupt-controller@e00f1000 { + compatible = "arm,gic-400"; + reg = <0x0 0xe00f1000 0x0 0x1000>, + <0x0 0xe00f2000 0x0 0x2000>, + <0x0 0xe00f4000 0x0 0x2000>, + <0x0 0xe00f6000 0x0 0x2000>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; + interrupt-controller; + #interrupt-cells = <3>; + }; + + uart0: serial@e0120000 { + compatible = "actions,s900-uart", "actions,owl-uart"; + reg = <0x0 0xe0120000 0x0 0x2000>; + clocks = <&cmu CLK_UART0>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + uart1: serial@e0122000 { + compatible = "actions,s900-uart", "actions,owl-uart"; + reg = <0x0 0xe0122000 0x0 0x2000>; + clocks = <&cmu CLK_UART1>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + uart2: serial@e0124000 { + compatible = "actions,s900-uart", "actions,owl-uart"; + reg = <0x0 0xe0124000 0x0 0x2000>; + clocks = <&cmu CLK_UART2>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + uart3: serial@e0126000 { + compatible = "actions,s900-uart", "actions,owl-uart"; + reg = <0x0 0xe0126000 0x0 0x2000>; + clocks = <&cmu CLK_UART3>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + uart4: serial@e0128000 { + compatible = "actions,s900-uart", "actions,owl-uart"; + reg = <0x0 0xe0128000 0x0 0x2000>; + clocks = <&cmu CLK_UART4>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + uart5: serial@e012a000 { - u-boot,dm-pre-reloc; - compatible = "actions,s900-serial"; - reg = <0x0 0xe012a000 0x0 0x1000>; - clocks = <&cmu CLOCK_UART5>; + compatible = "actions,s900-uart", "actions,owl-uart"; + reg = <0x0 0xe012a000 0x0 0x2000>; + clocks = <&cmu CLK_UART5>; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; status = "disabled"; };
+ uart6: serial@e012c000 { + compatible = "actions,s900-uart", "actions,owl-uart"; + reg = <0x0 0xe012c000 0x0 0x2000>; + clocks = <&cmu CLK_UART6>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + sps: power-controller@e012e000 { + compatible = "actions,s900-sps"; + reg = <0x0 0xe012e000 0x0 0x2000>; + #power-domain-cells = <1>; + }; + cmu: clock-controller@e0160000 { - u-boot,dm-pre-reloc; compatible = "actions,s900-cmu"; reg = <0x0 0xe0160000 0x0 0x1000>; - clocks = <&losc>, <&diff24M>; - clock-names = "losc", "diff24M"; + clocks = <&hosc>, <&losc>; #clock-cells = <1>; + #reset-cells = <1>; + }; + + i2c0: i2c@e0170000 { + compatible = "actions,s900-i2c"; + reg = <0 0xe0170000 0 0x1000>; + clocks = <&cmu CLK_I2C0>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c1: i2c@e0172000 { + compatible = "actions,s900-i2c"; + reg = <0 0xe0172000 0 0x1000>; + clocks = <&cmu CLK_I2C1>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c2: i2c@e0174000 { + compatible = "actions,s900-i2c"; + reg = <0 0xe0174000 0 0x1000>; + clocks = <&cmu CLK_I2C2>; + interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c3: i2c@e0176000 { + compatible = "actions,s900-i2c"; + reg = <0 0xe0176000 0 0x1000>; + clocks = <&cmu CLK_I2C3>; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c4: i2c@e0178000 { + compatible = "actions,s900-i2c"; + reg = <0 0xe0178000 0 0x1000>; + clocks = <&cmu CLK_I2C4>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c5: i2c@e017a000 { + compatible = "actions,s900-i2c"; + reg = <0 0xe017a000 0 0x1000>; + clocks = <&cmu CLK_I2C5>; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + pinctrl: pinctrl@e01b0000 { + compatible = "actions,s900-pinctrl"; + reg = <0x0 0xe01b0000 0x0 0x1000>; + clocks = <&cmu CLK_GPIO>; + gpio-controller; + gpio-ranges = <&pinctrl 0 0 146>; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + }; + + timer: timer@e0228000 { + compatible = "actions,s900-timer"; + reg = <0x0 0xe0228000 0x0 0x8000>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "timer1"; + }; + + dma: dma-controller@e0260000 { + compatible = "actions,s900-dma"; + reg = <0x0 0xe0260000 0x0 0x1000>; + interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + dma-channels = <12>; + dma-requests = <46>; + clocks = <&cmu CLK_DMAC>; + }; + + mmc0: mmc@e0330000 { + compatible = "actions,owl-mmc"; + reg = <0x0 0xe0330000 0x0 0x4000>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cmu CLK_SD0>; + resets = <&cmu RESET_SD0>; + dmas = <&dma 2>; + dma-names = "mmc"; + status = "disabled"; + }; + + mmc1: mmc@e0334000 { + compatible = "actions,owl-mmc"; + reg = <0x0 0xe0334000 0x0 0x4000>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cmu CLK_SD1>; + resets = <&cmu RESET_SD1>; + dmas = <&dma 3>; + dma-names = "mmc"; + status = "disabled"; + }; + + mmc2: mmc@e0338000 { + compatible = "actions,owl-mmc"; + reg = <0x0 0xe0338000 0x0 0x4000>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cmu CLK_SD2>; + resets = <&cmu RESET_SD2>; + dmas = <&dma 4>; + dma-names = "mmc"; + status = "disabled"; + }; + + mmc3: mmc@e033c000 { + compatible = "actions,owl-mmc"; + reg = <0x0 0xe033c000 0x0 0x4000>; + interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cmu CLK_SD3>; + resets = <&cmu RESET_SD3>; + dmas = <&dma 46>; + dma-names = "mmc"; + status = "disabled"; }; }; }; - diff --git a/drivers/clk/owl/clk_s900.c b/drivers/clk/owl/clk_s900.c index a7c15d2..d60f199 100644 --- a/drivers/clk/owl/clk_s900.c +++ b/drivers/clk/owl/clk_s900.c @@ -12,7 +12,7 @@ #include <asm/arch-owl/regs_s900.h> #include <asm/io.h>
void owl_clk_init(struct owl_clk_priv *priv) { @@ -78,7 +78,7 @@ int owl_clk_enable(struct clk *clk) struct owl_clk_priv *priv = dev_get_priv(clk->dev);
switch (clk->id) { - case CLOCK_UART5: + case CLK_UART5: owl_uart_clk_enable(priv); break; default: @@ -93,7 +93,7 @@ int owl_clk_disable(struct clk *clk) struct owl_clk_priv *priv = dev_get_priv(clk->dev);
switch (clk->id) { - case CLOCK_UART5: + case CLK_UART5: owl_uart_clk_disable(priv); break; default: diff --git a/drivers/serial/serial_owl.c b/drivers/serial/serial_owl.c index 539acdc..bb60ca2 100644 --- a/drivers/serial/serial_owl.c +++ b/drivers/serial/serial_owl.c @@ -120,7 +120,6 @@ static const struct dm_serial_ops owl_serial_ops = { };
static const struct udevice_id owl_serial_ids[] = { - { .compatible = "actions,s900-serial" }, { .compatible = "actions,owl-uart" }, { } }; diff --git a/include/dt-bindings/clock/actions,s900-cmu.h b/include/dt-bindings/clock/actions,s900-cmu.h new file mode 100644 index 0000000..7c12515 --- /dev/null +++ b/include/dt-bindings/clock/actions,s900-cmu.h @@ -0,0 +1,129 @@ +// SPDX-License-Identifier: GPL-2.0+ +// +// Device Tree binding constants for Actions Semi S900 Clock Management Unit +// +// Copyright (c) 2014 Actions Semi Inc. +// Copyright (c) 2018 Linaro Ltd. + +#ifndef __DT_BINDINGS_CLOCK_S900_CMU_H +#define __DT_BINDINGS_CLOCK_S900_CMU_H + +#define CLK_NONE 0 + +/* fixed rate clocks */ +#define CLK_LOSC 1 +#define CLK_HOSC 2 + +/* pll clocks */ +#define CLK_CORE_PLL 3 +#define CLK_DEV_PLL 4 +#define CLK_DDR_PLL 5 +#define CLK_NAND_PLL 6 +#define CLK_DISPLAY_PLL 7 +#define CLK_DSI_PLL 8 +#define CLK_ASSIST_PLL 9 +#define CLK_AUDIO_PLL 10 + +/* system clock */ +#define CLK_CPU 15 +#define CLK_DEV 16 +#define CLK_NOC 17 +#define CLK_NOC_MUX 18 +#define CLK_NOC_DIV 19 +#define CLK_AHB 20 +#define CLK_APB 21 +#define CLK_DMAC 22 + +/* peripheral device clock */ +#define CLK_GPIO 23 + +#define CLK_BISP 24 +#define CLK_CSI0 25 +#define CLK_CSI1 26 + +#define CLK_DE0 27 +#define CLK_DE1 28 +#define CLK_DE2 29 +#define CLK_DE3 30 +#define CLK_DSI 32 + +#define CLK_GPU 33 +#define CLK_GPU_CORE 34 +#define CLK_GPU_MEM 35 +#define CLK_GPU_SYS 36 + +#define CLK_HDE 37 +#define CLK_I2C0 38 +#define CLK_I2C1 39 +#define CLK_I2C2 40 +#define CLK_I2C3 41 +#define CLK_I2C4 42 +#define CLK_I2C5 43 +#define CLK_I2SRX 44 +#define CLK_I2STX 45 +#define CLK_IMX 46 +#define CLK_LCD 47 +#define CLK_NAND0 48 +#define CLK_NAND1 49 +#define CLK_PWM0 50 +#define CLK_PWM1 51 +#define CLK_PWM2 52 +#define CLK_PWM3 53 +#define CLK_PWM4 54 +#define CLK_PWM5 55 +#define CLK_SD0 56 +#define CLK_SD1 57 +#define CLK_SD2 58 +#define CLK_SD3 59 +#define CLK_SENSOR 60 +#define CLK_SPEED_SENSOR 61 +#define CLK_SPI0 62 +#define CLK_SPI1 63 +#define CLK_SPI2 64 +#define CLK_SPI3 65 +#define CLK_THERMAL_SENSOR 66 +#define CLK_UART0 67 +#define CLK_UART1 68 +#define CLK_UART2 69 +#define CLK_UART3 70 +#define CLK_UART4 71 +#define CLK_UART5 72 +#define CLK_UART6 73 +#define CLK_VCE 74 +#define CLK_VDE 75 + +#define CLK_USB3_480MPLL0 76 +#define CLK_USB3_480MPHY0 77 +#define CLK_USB3_5GPHY 78 +#define CLK_USB3_CCE 79 +#define CLK_USB3_MAC 80 + +#define CLK_TIMER 83 + +#define CLK_HDMI_AUDIO 84 + +#define CLK_24M 85 + +#define CLK_EDP 86 + +#define CLK_24M_EDP 87 +#define CLK_EDP_PLL 88 +#define CLK_EDP_LINK 89 + +#define CLK_USB2H0_PLLEN 90 +#define CLK_USB2H0_PHY 91 +#define CLK_USB2H0_CCE 92 +#define CLK_USB2H1_PLLEN 93 +#define CLK_USB2H1_PHY 94 +#define CLK_USB2H1_CCE 95 + +#define CLK_DDR0 96 +#define CLK_DDR1 97 +#define CLK_DMM 98 + +#define CLK_ETH_MAC 99 +#define CLK_RMII_REF 100 + +#define CLK_NR_CLKS (CLK_RMII_REF + 1) + +#endif /* __DT_BINDINGS_CLOCK_S900_CMU_H */ diff --git a/include/dt-bindings/clock/s900_cmu.h b/include/dt-bindings/clock/s900_cmu.h deleted file mode 100644 index 2685a6d..0000000 --- a/include/dt-bindings/clock/s900_cmu.h +++ /dev/null @@ -1,77 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2015 Actions Semi Co., Ltd. - * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org - * - */ - -#ifndef _DT_BINDINGS_CLOCK_S900_CMU_H_ -#define _DT_BINDINGS_CLOCK_S900_CMU_H_ - -/* Module Clock ID */ -#define CLOCK_DDRCH1 0 -#define CLOCK_DMAC 1 -#define CLOCK_DDRCH0 2 -#define CLOCK_BROM 3 -#define CLOCK_NANDC0 4 -#define CLOCK_SD0 5 -#define CLOCK_SD1 6 -#define CLOCK_SD2 7 -#define CLOCK_DE 8 -#define CLOCK_LVDS 9 -#define CLOCK_EDP 10 -#define CLOCK_NANDC1 11 -#define CLOCK_DSI 12 -#define CLOCK_CSI0 13 -#define CLOCK_BISP 14 -#define CLOCK_CSI1 15 -#define CLOCK_SD3 16 -#define CLOCK_I2C4 17 -#define CLOCK_GPIO 18 -#define CLOCK_DMM 19 -#define CLOCK_I2STX 20 -#define CLOCK_I2SRX 21 -#define CLOCK_HDMIA 22 -#define CLOCK_SPDIF 23 -#define CLOCK_PCM0 24 -#define CLOCK_VDE 25 -#define CLOCK_VCE 26 -#define CLOCK_HDE 27 -#define CLOCK_SHARESRAM 28 -#define CLOCK_CMU_DDR1 29 -#define CLOCK_GPU3D 30 -#define CLOCK_CMUDDR0 31 -#define CLOCK_SPEED 32 -#define CLOCK_I2C5 33 -#define CLOCK_THERMAL 34 -#define CLOCK_HDMI 35 -#define CLOCK_PWM4 36 -#define CLOCK_PWM5 37 -#define CLOCK_UART0 38 -#define CLOCK_UART1 39 -#define CLOCK_UART2 40 -#define CLOCK_IRC 41 -#define CLOCK_SPI0 42 -#define CLOCK_SPI1 43 -#define CLOCK_SPI2 44 -#define CLOCK_SPI3 45 -#define CLOCK_I2C0 46 -#define CLOCK_I2C1 47 -#define CLOCK_PCM1 48 -#define CLOCK_IMX 49 -#define CLOCK_UART6 50 -#define CLOCK_UART3 51 -#define CLOCK_UART4 52 -#define CLOCK_UART5 53 -#define CLOCK_ETHERNET 54 -#define CLOCK_PWM0 55 -#define CLOCK_PWM1 56 -#define CLOCK_PWM2 57 -#define CLOCK_PWM3 58 -#define CLOCK_TIMER 59 -#define CLOCK_SE 60 -#define CLOCK_HDCP2TX 61 -#define CLOCK_I2C2 62 -#define CLOCK_I2C3 63 - -#endif diff --git a/include/dt-bindings/reset/actions,s900-reset.h b/include/dt-bindings/reset/actions,s900-reset.h new file mode 100644 index 0000000..42c19d0 --- /dev/null +++ b/include/dt-bindings/reset/actions,s900-reset.h @@ -0,0 +1,65 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR MIT) +// +// Device Tree binding constants for Actions Semi S900 Reset Management Unit +// +// Copyright (c) 2018 Linaro Ltd. + +#ifndef __DT_BINDINGS_ACTIONS_S900_RESET_H +#define __DT_BINDINGS_ACTIONS_S900_RESET_H + +#define RESET_CHIPID 0 +#define RESET_CPU_SCNT 1 +#define RESET_SRAMI 2 +#define RESET_DDR_CTL_PHY 3 +#define RESET_DMAC 4 +#define RESET_GPIO 5 +#define RESET_BISP_AXI 6 +#define RESET_CSI0 7 +#define RESET_CSI1 8 +#define RESET_DE 9 +#define RESET_DSI 10 +#define RESET_GPU3D_PA 11 +#define RESET_GPU3D_PB 12 +#define RESET_HDE 13 +#define RESET_I2C0 14 +#define RESET_I2C1 15 +#define RESET_I2C2 16 +#define RESET_I2C3 17 +#define RESET_I2C4 18 +#define RESET_I2C5 19 +#define RESET_IMX 20 +#define RESET_NANDC0 21 +#define RESET_NANDC1 22 +#define RESET_SD0 23 +#define RESET_SD1 24 +#define RESET_SD2 25 +#define RESET_SD3 26 +#define RESET_SPI0 27 +#define RESET_SPI1 28 +#define RESET_SPI2 29 +#define RESET_SPI3 30 +#define RESET_UART0 31 +#define RESET_UART1 32 +#define RESET_UART2 33 +#define RESET_UART3 34 +#define RESET_UART4 35 +#define RESET_UART5 36 +#define RESET_UART6 37 +#define RESET_HDMI 38 +#define RESET_LVDS 39 +#define RESET_EDP 40 +#define RESET_USB2HUB 41 +#define RESET_USB2HSIC 42 +#define RESET_USB3 43 +#define RESET_PCM1 44 +#define RESET_AUDIO 45 +#define RESET_PCM0 46 +#define RESET_SE 47 +#define RESET_GIC 48 +#define RESET_DDR_CTL_PHY_AXI 49 +#define RESET_CMU_DDR 50 +#define RESET_DMM 51 +#define RESET_HDCP2TX 52 +#define RESET_ETHERNET 53 + +#endif /* __DT_BINDINGS_ACTIONS_S900_RESET_H */
Devices like uart and clk are needed to be enabled before relocation. This patch adds u-boot.dtsi file that mark these device as dm-pre-reloc.
Reviewed-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- Changes since v7: * No changes. Changes since v6: * No changes. Changes since v5: * No changes. Changes since v4: * This patch is re-ordered, moved from 08/11 to 04/11. Changes since v3: * Replaced dtsi with dts in subject line along with arm:dts: to the prefix. * Added reviewed-by tag. Changes since v2: * Newly added patch, not there in v2/v1. --- arch/arm/dts/s900-u-boot.dtsi | 17 +++++++++++++++++ 1 file changed, 17 insertions(+) create mode 100644 arch/arm/dts/s900-u-boot.dtsi
diff --git a/arch/arm/dts/s900-u-boot.dtsi b/arch/arm/dts/s900-u-boot.dtsi new file mode 100644 index 0000000..a95f2cc --- /dev/null +++ b/arch/arm/dts/s900-u-boot.dtsi @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + */ + +/{ + soc { + u-boot,dm-pre-reloc; + }; +}; + +&uart5 { + u-boot,dm-pre-reloc; +}; + +&cmu { + u-boot,dm-pre-reloc; +};
This patch converts S900 clock driver to something common that can be used for other SoCs, for instance S700(few of clk registers are same).
Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- Changes since v7: * No changes. Changes since v6: * Fixed the bug that breaks S900(missing break in switch statement). Changes since v5: * No changes. Changes since v4: * This patch is re-ordered, moved from 08/11 to 04/11. Changes since v3: * Replaced dtsi with dts in subject line along with arm:dts: to the prefix. * Added reviewed-by tag. Changes since v2: * Newly added patch, not there in v2/v1. --- arch/arm/Kconfig | 2 + arch/arm/include/asm/arch-owl/clk_s900.h | 57 ----------- arch/arm/include/asm/arch-owl/regs_s700.h | 56 +++++++++++ configs/bubblegum_96_defconfig | 3 - drivers/clk/owl/Kconfig | 8 +- drivers/clk/owl/Makefile | 2 +- drivers/clk/owl/clk_owl.c | 153 ++++++++++++++++++++++++++++++ drivers/clk/owl/clk_owl.h | 65 +++++++++++++ drivers/clk/owl/clk_s900.c | 137 -------------------------- 9 files changed, 279 insertions(+), 204 deletions(-) delete mode 100644 arch/arm/include/asm/arch-owl/clk_s900.h create mode 100644 arch/arm/include/asm/arch-owl/regs_s700.h create mode 100644 drivers/clk/owl/clk_owl.c create mode 100644 drivers/clk/owl/clk_owl.h delete mode 100644 drivers/clk/owl/clk_s900.c
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 1cfdcb6..dba4d8c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -876,6 +876,8 @@ config ARCH_OWL select DM select DM_SERIAL select OWL_SERIAL + select CLK + select CLK_OWL select OF_CONTROL imply CMD_DM
diff --git a/arch/arm/include/asm/arch-owl/clk_s900.h b/arch/arm/include/asm/arch-owl/clk_s900.h deleted file mode 100644 index 88e88f7..0000000 --- a/arch/arm/include/asm/arch-owl/clk_s900.h +++ /dev/null @@ -1,57 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Actions Semi S900 Clock Definitions - * - * Copyright (C) 2015 Actions Semi Co., Ltd. - * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org - * - */ - -#ifndef _OWL_CLK_S900_H_ -#define _OWL_CLK_S900_H_ - -#include <clk-uclass.h> - -struct owl_clk_priv { - phys_addr_t base; -}; - -/* BUSCLK register definitions */ -#define CMU_PDBGDIV_8 7 -#define CMU_PDBGDIV_SHIFT 26 -#define CMU_PDBGDIV_DIV (CMU_PDBGDIV_8 << CMU_PDBGDIV_SHIFT) -#define CMU_PERDIV_8 7 -#define CMU_PERDIV_SHIFT 20 -#define CMU_PERDIV_DIV (CMU_PERDIV_8 << CMU_PERDIV_SHIFT) -#define CMU_NOCDIV_2 1 -#define CMU_NOCDIV_SHIFT 19 -#define CMU_NOCDIV_DIV (CMU_NOCDIV_2 << CMU_NOCDIV_SHIFT) -#define CMU_DMMCLK_SRC_APLL 2 -#define CMU_DMMCLK_SRC_SHIFT 10 -#define CMU_DMMCLK_SRC (CMU_DMMCLK_SRC_APLL << CMU_DMMCLK_SRC_SHIFT) -#define CMU_APBCLK_DIV BIT(8) -#define CMU_NOCCLK_SRC BIT(7) -#define CMU_AHBCLK_DIV BIT(4) -#define CMU_CORECLK_MASK 3 -#define CMU_CORECLK_CPLL BIT(1) -#define CMU_CORECLK_HOSC BIT(0) - -/* COREPLL register definitions */ -#define CMU_COREPLL_EN BIT(9) -#define CMU_COREPLL_HOSC_EN BIT(8) -#define CMU_COREPLL_OUT (1104 / 24) - -/* DEVPLL register definitions */ -#define CMU_DEVPLL_CLK BIT(12) -#define CMU_DEVPLL_EN BIT(8) -#define CMU_DEVPLL_OUT (660 / 6) - -/* UARTCLK register definitions */ -#define CMU_UARTCLK_SRC_DEVPLL BIT(16) - -/* DEVCLKEN1 register definitions */ -#define CMU_DEVCLKEN1_UART5 BIT(21) - -#define PLL_STABILITY_WAIT_US 50 - -#endif diff --git a/arch/arm/include/asm/arch-owl/regs_s700.h b/arch/arm/include/asm/arch-owl/regs_s700.h new file mode 100644 index 0000000..2f21c15 --- /dev/null +++ b/arch/arm/include/asm/arch-owl/regs_s700.h @@ -0,0 +1,56 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Actions Semi S700 Register Definitions + * + */ + +#ifndef _OWL_REGS_S700_H_ +#define _OWL_REGS_S700_H_ + +#define CMU_COREPLL 0x0000 +#define CMU_DEVPLL 0x0004 +#define CMU_DDRPLL 0x0008 +#define CMU_NANDPLL 0x000C +#define CMU_DISPLAYPLL 0x0010 +#define CMU_AUDIOPLL 0x0014 +#define CMU_TVOUTPLL 0x0018 +#define CMU_BUSCLK 0x001C +#define CMU_SENSORCLK 0x0020 +#define CMU_LCDCLK 0x0024 +#define CMU_DSIPLLCLK 0x0028 +#define CMU_CSICLK 0x002C +#define CMU_DECLK 0x0030 +#define CMU_SICLK 0x0034 +#define CMU_BUSCLK1 0x0038 +#define CMU_HDECLK 0x003C +#define CMU_VDECLK 0x0040 +#define CMU_VCECLK 0x0044 +#define CMU_NANDCCLK 0x004C +#define CMU_SD0CLK 0x0050 +#define CMU_SD1CLK 0x0054 +#define CMU_SD2CLK 0x0058 +#define CMU_UART0CLK 0x005C +#define CMU_UART1CLK 0x0060 +#define CMU_UART2CLK 0x0064 +#define CMU_UART3CLK 0x0068 +#define CMU_UART4CLK 0x006C +#define CMU_UART5CLK 0x0070 +#define CMU_UART6CLK 0x0074 +#define CMU_PWM0CLK 0x0078 +#define CMU_PWM1CLK 0x007C +#define CMU_PWM2CLK 0x0080 +#define CMU_PWM3CLK 0x0084 +#define CMU_PWM4CLK 0x0088 +#define CMU_PWM5CLK 0x008C +#define CMU_GPU3DCLK 0x0090 +#define CMU_CORECTL 0x009C +#define CMU_DEVCLKEN0 0x00A0 +#define CMU_DEVCLKEN1 0x00A4 +#define CMU_DEVRST0 0x00A8 +#define CMU_DEVRST1 0x00AC +#define CMU_USBPLL 0x00B0 +#define CMU_ETHERNETPLL 0x00B4 +#define CMU_CVBSPLL 0x00B8 +#define CMU_SSTSCLK 0x00C0 + +#endif diff --git a/configs/bubblegum_96_defconfig b/configs/bubblegum_96_defconfig index 8c94def..e76e9a2 100644 --- a/configs/bubblegum_96_defconfig +++ b/configs/bubblegum_96_defconfig @@ -17,6 +17,3 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIMER=y CONFIG_DEFAULT_DEVICE_TREE="bubblegum_96" CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_CLK=y -CONFIG_CLK_OWL=y -CONFIG_CLK_S900=y diff --git a/drivers/clk/owl/Kconfig b/drivers/clk/owl/Kconfig index 661f198..c6afef9 100644 --- a/drivers/clk/owl/Kconfig +++ b/drivers/clk/owl/Kconfig @@ -3,10 +3,6 @@ config CLK_OWL depends on CLK && ARCH_OWL help Enable support for clock managemet unit present in Actions Semi - OWL SoCs. + Owl series S900/S700 SoCs. +
-config CLK_S900 - bool "Actions Semi S900 clock driver" - depends on CLK_OWL && ARM64 - help - Enable support for the clocks in Actions Semi S900 SoC. diff --git a/drivers/clk/owl/Makefile b/drivers/clk/owl/Makefile index 63ab573..5218b6b 100644 --- a/drivers/clk/owl/Makefile +++ b/drivers/clk/owl/Makefile @@ -1,3 +1,3 @@ # SPDX-License-Identifier: GPL-2.0+
-obj-$(CONFIG_CLK_S900) += clk_s900.o +obj-$(CONFIG_CLK_OWL) += clk_owl.o diff --git a/drivers/clk/owl/clk_owl.c b/drivers/clk/owl/clk_owl.c new file mode 100644 index 0000000..9f114c7 --- /dev/null +++ b/drivers/clk/owl/clk_owl.c @@ -0,0 +1,153 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Common clock driver for Actions Semi SoCs. + * + * Copyright (C) 2015 Actions Semi Co., Ltd. + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +#include <common.h> +#include <dm.h> +#include "clk_owl.h" +#include <asm/io.h> +#if defined(CONFIG_MACH_S900) +#include <asm/arch-owl/regs_s900.h> +#include <dt-bindings/clock/actions,s900-cmu.h> +#elif defined(CONFIG_MACH_S700) +#include <asm/arch-owl/regs_s700.h> +#include <dt-bindings/clock/actions,s700-cmu.h> +#endif + +void owl_clk_init(struct owl_clk_priv *priv) +{ + u32 bus_clk = 0, core_pll, dev_pll; + +#if defined(CONFIG_MACH_S900) + /* Enable ASSIST_PLL */ + setbits_le32(priv->base + CMU_ASSISTPLL, BIT(0)); + udelay(PLL_STABILITY_WAIT_US); +#endif + + /* Source HOSC to DEV_CLK */ + clrbits_le32(priv->base + CMU_DEVPLL, CMU_DEVPLL_CLK); + + /* Configure BUS_CLK */ + bus_clk |= (CMU_PDBGDIV_DIV | CMU_PERDIV_DIV | CMU_NOCDIV_DIV | + CMU_DMMCLK_SRC | CMU_APBCLK_DIV | CMU_AHBCLK_DIV | + CMU_NOCCLK_SRC | CMU_CORECLK_HOSC); + writel(bus_clk, priv->base + CMU_BUSCLK); + + udelay(PLL_STABILITY_WAIT_US); + + /* Configure CORE_PLL */ + core_pll = readl(priv->base + CMU_COREPLL); + core_pll |= (CMU_COREPLL_EN | CMU_COREPLL_HOSC_EN | CMU_COREPLL_OUT); + writel(core_pll, priv->base + CMU_COREPLL); + + udelay(PLL_STABILITY_WAIT_US); + + /* Configure DEV_PLL */ + dev_pll = readl(priv->base + CMU_DEVPLL); + dev_pll |= (CMU_DEVPLL_EN | CMU_DEVPLL_OUT); + writel(dev_pll, priv->base + CMU_DEVPLL); + + udelay(PLL_STABILITY_WAIT_US); + + /* Source CORE_PLL for CORE_CLK */ + clrsetbits_le32(priv->base + CMU_BUSCLK, CMU_CORECLK_MASK, + CMU_CORECLK_CPLL); + + /* Source DEV_PLL for DEV_CLK */ + setbits_le32(priv->base + CMU_DEVPLL, CMU_DEVPLL_CLK); + + udelay(PLL_STABILITY_WAIT_US); +} + +int owl_clk_enable(struct clk *clk) +{ + struct owl_clk_priv *priv = dev_get_priv(clk->dev); + + switch (clk->id) { + case CLK_UART5: + if (priv->soc == S700) + return -EINVAL; + /* Source HOSC for UART5 interface */ + clrbits_le32(priv->base + CMU_UART5CLK, CMU_UARTCLK_SRC_DEVPLL); + /* Enable UART5 interface clock */ + setbits_le32(priv->base + CMU_DEVCLKEN1, CMU_DEVCLKEN1_UART5); + break; + case CLK_UART3: + if (priv->soc == S900) + return -EINVAL; + /* Source HOSC for UART3 interface */ + clrbits_le32(priv->base + CMU_UART3CLK, CMU_UARTCLK_SRC_DEVPLL); + /* Enable UART3 interface clock */ + setbits_le32(priv->base + CMU_DEVCLKEN1, CMU_DEVCLKEN1_UART3); + break; + default: + return -EINVAL; + } + + return 0; +} + +int owl_clk_disable(struct clk *clk) +{ + struct owl_clk_priv *priv = dev_get_priv(clk->dev); + + switch (clk->id) { + case CLK_UART5: + if (priv->soc == S700) + return -EINVAL; + /* Disable UART5 interface clock */ + clrbits_le32(priv->base + CMU_DEVCLKEN1, CMU_DEVCLKEN1_UART5); + break; + case CLK_UART3: + if (priv->soc == S900) + return -EINVAL; + /* Disable UART3 interface clock */ + clrbits_le32(priv->base + CMU_DEVCLKEN1, CMU_DEVCLKEN1_UART3); + break; + default: + return -EINVAL; + } + + return 0; +} + +static int owl_clk_probe(struct udevice *dev) +{ + struct owl_clk_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr(dev); + if (priv->base == FDT_ADDR_T_NONE) + return -EINVAL; + + /* setup necessary clocks */ + owl_clk_init(priv); + + return 0; +} + +static const struct clk_ops owl_clk_ops = { + .enable = owl_clk_enable, + .disable = owl_clk_disable, +}; + +static const struct udevice_id owl_clk_ids[] = { +#if defined(CONFIG_MACH_S900) + { .compatible = "actions,s900-cmu", .data = S900 }, +#elif defined(CONFIG_MACH_S700) + { .compatible = "actions,s700-cmu", .data = S700 }, +#endif + { } +}; + +U_BOOT_DRIVER(clk_owl) = { + .name = "clk_owl", + .id = UCLASS_CLK, + .of_match = owl_clk_ids, + .ops = &owl_clk_ops, + .priv_auto_alloc_size = sizeof(struct owl_clk_priv), + .probe = owl_clk_probe, +}; diff --git a/drivers/clk/owl/clk_owl.h b/drivers/clk/owl/clk_owl.h new file mode 100644 index 0000000..8ebf012 --- /dev/null +++ b/drivers/clk/owl/clk_owl.h @@ -0,0 +1,65 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Actions Semi SoCs Clock Definitions + * + * Copyright (C) 2015 Actions Semi Co., Ltd. + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + * + */ + +#ifndef _OWL_CLK_H_ +#define _OWL_CLK_H_ + +#include <clk-uclass.h> + +enum owl_soc { + S700, + S900, +}; + +struct owl_clk_priv { + phys_addr_t base; + enum owl_soc soc; +}; + +/* BUSCLK register definitions */ +#define CMU_PDBGDIV_8 7 +#define CMU_PDBGDIV_SHIFT 26 +#define CMU_PDBGDIV_DIV (CMU_PDBGDIV_8 << CMU_PDBGDIV_SHIFT) +#define CMU_PERDIV_8 7 +#define CMU_PERDIV_SHIFT 20 +#define CMU_PERDIV_DIV (CMU_PERDIV_8 << CMU_PERDIV_SHIFT) +#define CMU_NOCDIV_2 1 +#define CMU_NOCDIV_SHIFT 19 +#define CMU_NOCDIV_DIV (CMU_NOCDIV_2 << CMU_NOCDIV_SHIFT) +#define CMU_DMMCLK_SRC_APLL 2 +#define CMU_DMMCLK_SRC_SHIFT 10 +#define CMU_DMMCLK_SRC (CMU_DMMCLK_SRC_APLL << CMU_DMMCLK_SRC_SHIFT) +#define CMU_APBCLK_DIV BIT(8) +#define CMU_NOCCLK_SRC BIT(7) +#define CMU_AHBCLK_DIV BIT(4) +#define CMU_CORECLK_MASK 3 +#define CMU_CORECLK_CPLL BIT(1) +#define CMU_CORECLK_HOSC BIT(0) + +/* COREPLL register definitions */ +#define CMU_COREPLL_EN BIT(9) +#define CMU_COREPLL_HOSC_EN BIT(8) +#define CMU_COREPLL_OUT (1104 / 24) + +/* DEVPLL register definitions */ +#define CMU_DEVPLL_CLK BIT(12) +#define CMU_DEVPLL_EN BIT(8) +#define CMU_DEVPLL_OUT (660 / 6) + +/* UARTCLK register definitions */ +#define CMU_UARTCLK_SRC_DEVPLL BIT(16) + +#define PLL_STABILITY_WAIT_US 50 + +#define CMU_DEVCLKEN1_UART5 BIT(21) +#define CMU_DEVCLKEN1_UART3 BIT(11) + +#define CMU_DEVCLKEN1_ETH_S700 BIT(23) + +#endif diff --git a/drivers/clk/owl/clk_s900.c b/drivers/clk/owl/clk_s900.c deleted file mode 100644 index d60f199..0000000 --- a/drivers/clk/owl/clk_s900.c +++ /dev/null @@ -1,137 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Actions Semi S900 clock driver - * - * Copyright (C) 2015 Actions Semi Co., Ltd. - * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org - */ - -#include <common.h> -#include <dm.h> -#include <asm/arch-owl/clk_s900.h> -#include <asm/arch-owl/regs_s900.h> -#include <asm/io.h> - -#include <dt-bindings/clock/actions,s900-cmu.h> - -void owl_clk_init(struct owl_clk_priv *priv) -{ - u32 bus_clk = 0, core_pll, dev_pll; - - /* Enable ASSIST_PLL */ - setbits_le32(priv->base + CMU_ASSISTPLL, BIT(0)); - - udelay(PLL_STABILITY_WAIT_US); - - /* Source HOSC to DEV_CLK */ - clrbits_le32(priv->base + CMU_DEVPLL, CMU_DEVPLL_CLK); - - /* Configure BUS_CLK */ - bus_clk |= (CMU_PDBGDIV_DIV | CMU_PERDIV_DIV | CMU_NOCDIV_DIV | - CMU_DMMCLK_SRC | CMU_APBCLK_DIV | CMU_AHBCLK_DIV | - CMU_NOCCLK_SRC | CMU_CORECLK_HOSC); - writel(bus_clk, priv->base + CMU_BUSCLK); - - udelay(PLL_STABILITY_WAIT_US); - - /* Configure CORE_PLL */ - core_pll = readl(priv->base + CMU_COREPLL); - core_pll |= (CMU_COREPLL_EN | CMU_COREPLL_HOSC_EN | CMU_COREPLL_OUT); - writel(core_pll, priv->base + CMU_COREPLL); - - udelay(PLL_STABILITY_WAIT_US); - - /* Configure DEV_PLL */ - dev_pll = readl(priv->base + CMU_DEVPLL); - dev_pll |= (CMU_DEVPLL_EN | CMU_DEVPLL_OUT); - writel(dev_pll, priv->base + CMU_DEVPLL); - - udelay(PLL_STABILITY_WAIT_US); - - /* Source CORE_PLL for CORE_CLK */ - clrsetbits_le32(priv->base + CMU_BUSCLK, CMU_CORECLK_MASK, - CMU_CORECLK_CPLL); - - /* Source DEV_PLL for DEV_CLK */ - setbits_le32(priv->base + CMU_DEVPLL, CMU_DEVPLL_CLK); - - udelay(PLL_STABILITY_WAIT_US); -} - -void owl_uart_clk_enable(struct owl_clk_priv *priv) -{ - /* Source HOSC for UART5 interface */ - clrbits_le32(priv->base + CMU_UART5CLK, CMU_UARTCLK_SRC_DEVPLL); - - /* Enable UART5 interface clock */ - setbits_le32(priv->base + CMU_DEVCLKEN1, CMU_DEVCLKEN1_UART5); -} - -void owl_uart_clk_disable(struct owl_clk_priv *priv) -{ - /* Disable UART5 interface clock */ - clrbits_le32(priv->base + CMU_DEVCLKEN1, CMU_DEVCLKEN1_UART5); -} - -int owl_clk_enable(struct clk *clk) -{ - struct owl_clk_priv *priv = dev_get_priv(clk->dev); - - switch (clk->id) { - case CLK_UART5: - owl_uart_clk_enable(priv); - break; - default: - return 0; - } - - return 0; -} - -int owl_clk_disable(struct clk *clk) -{ - struct owl_clk_priv *priv = dev_get_priv(clk->dev); - - switch (clk->id) { - case CLK_UART5: - owl_uart_clk_disable(priv); - break; - default: - return 0; - } - - return 0; -} - -static int owl_clk_probe(struct udevice *dev) -{ - struct owl_clk_priv *priv = dev_get_priv(dev); - - priv->base = dev_read_addr(dev); - if (priv->base == FDT_ADDR_T_NONE) - return -EINVAL; - - /* setup necessary clocks */ - owl_clk_init(priv); - - return 0; -} - -static struct clk_ops owl_clk_ops = { - .enable = owl_clk_enable, - .disable = owl_clk_disable, -}; - -static const struct udevice_id owl_clk_ids[] = { - { .compatible = "actions,s900-cmu" }, - { } -}; - -U_BOOT_DRIVER(clk_owl) = { - .name = "clk_s900", - .id = UCLASS_CLK, - .of_match = owl_clk_ids, - .ops = &owl_clk_ops, - .priv_auto_alloc_size = sizeof(struct owl_clk_priv), - .probe = owl_clk_probe, -};
This patch adds .dtsi file(sync with Linux 5.5-rc6 with hash "b3a987b0264d") and required binding for S700 SoC that is a 64-bit Quad-core ARM Cortex-A53 cores.
It also provisions dts file to be built based on selected platform(CONFIG_MACH_S900/S700).
Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- Changes since v7: * No changes. Changes since v6: * No changes. Changes since v5: * Added reviwed-by tag. Changes since v4: * Move it to 07/11 from 05/11. Changes since v3: * Updated commit message to the Linux tag to which the dtsi file is synced. Changes since v2: * Synced DTS bindings with Linux 5.5. Changes since v1: * Moved the u-boot specific changes to s700-u-boot.dtsi, now s700.dtsi is in complete sync with Linux 4.20. --- arch/arm/dts/Makefile | 6 +- arch/arm/dts/s700.dtsi | 248 +++++++++++++++++++++++++ include/dt-bindings/clock/actions,s700-cmu.h | 118 ++++++++++++ include/dt-bindings/reset/actions,s700-reset.h | 34 ++++ 4 files changed, 404 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/s700.dtsi create mode 100644 include/dt-bindings/clock/actions,s700-cmu.h create mode 100644 include/dt-bindings/reset/actions,s700-reset.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9c593b2..308c76b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -64,8 +64,10 @@ dtb-$(CONFIG_KIRKWOOD) += \ kirkwood-pogo_e02.dtb \ kirkwood-sheevaplug.dtb
-dtb-$(CONFIG_ARCH_OWL) += \ - bubblegum_96.dtb +dtb-$(CONFIG_MACH_S900) += \ + bubblegum_96.dtb +dtb-$(CONFIG_MACH_S700) += \ + s700-cubieboard7.dtb
dtb-$(CONFIG_ROCKCHIP_PX30) += \ px30-evb.dtb \ diff --git a/arch/arm/dts/s700.dtsi b/arch/arm/dts/s700.dtsi new file mode 100644 index 0000000..2006ad5 --- /dev/null +++ b/arch/arm/dts/s700.dtsi @@ -0,0 +1,248 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2017 Andreas Färber + */ + +#include <dt-bindings/clock/actions,s700-cmu.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/reset/actions,s700-reset.h> + +/ { + compatible = "actions,s700"; + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + cpus { + #address-cells = <2>; + #size-cells = <0>; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x0>; + enable-method = "psci"; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x1>; + enable-method = "psci"; + }; + + cpu2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x2>; + enable-method = "psci"; + }; + + cpu3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x3>; + enable-method = "psci"; + }; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + secmon@1f000000 { + reg = <0x0 0x1f000000 0x0 0x1000000>; + no-map; + }; + }; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + + arm-pmu { + compatible = "arm,cortex-a53-pmu"; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; + }; + + hosc: hosc { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + #clock-cells = <0>; + }; + + losc: losc { + compatible = "fixed-clock"; + clock-frequency = <32768>; + #clock-cells = <0>; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + gic: interrupt-controller@e00f1000 { + compatible = "arm,gic-400"; + reg = <0x0 0xe00f1000 0x0 0x1000>, + <0x0 0xe00f2000 0x0 0x2000>, + <0x0 0xe00f4000 0x0 0x2000>, + <0x0 0xe00f6000 0x0 0x2000>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; + interrupt-controller; + #interrupt-cells = <3>; + }; + + uart0: serial@e0120000 { + compatible = "actions,s900-uart", "actions,owl-uart"; + reg = <0x0 0xe0120000 0x0 0x2000>; + clocks = <&cmu CLK_UART0>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + uart1: serial@e0122000 { + compatible = "actions,s900-uart", "actions,owl-uart"; + reg = <0x0 0xe0122000 0x0 0x2000>; + clocks = <&cmu CLK_UART1>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + uart2: serial@e0124000 { + compatible = "actions,s900-uart", "actions,owl-uart"; + reg = <0x0 0xe0124000 0x0 0x2000>; + clocks = <&cmu CLK_UART2>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + uart3: serial@e0126000 { + compatible = "actions,s900-uart", "actions,owl-uart"; + reg = <0x0 0xe0126000 0x0 0x2000>; + clocks = <&cmu CLK_UART3>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + uart4: serial@e0128000 { + compatible = "actions,s900-uart", "actions,owl-uart"; + reg = <0x0 0xe0128000 0x0 0x2000>; + clocks = <&cmu CLK_UART4>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + uart5: serial@e012a000 { + compatible = "actions,s900-uart", "actions,owl-uart"; + reg = <0x0 0xe012a000 0x0 0x2000>; + clocks = <&cmu CLK_UART5>; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + uart6: serial@e012c000 { + compatible = "actions,s900-uart", "actions,owl-uart"; + reg = <0x0 0xe012c000 0x0 0x2000>; + clocks = <&cmu CLK_UART6>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + cmu: clock-controller@e0168000 { + compatible = "actions,s700-cmu"; + reg = <0x0 0xe0168000 0x0 0x1000>; + clocks = <&hosc>, <&losc>; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + i2c0: i2c@e0170000 { + compatible = "actions,s700-i2c"; + reg = <0 0xe0170000 0 0x1000>; + clocks = <&cmu CLK_I2C0>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c1: i2c@e0174000 { + compatible = "actions,s700-i2c"; + reg = <0 0xe0174000 0 0x1000>; + clocks = <&cmu CLK_I2C1>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c2: i2c@e0178000 { + compatible = "actions,s700-i2c"; + reg = <0 0xe0178000 0 0x1000>; + clocks = <&cmu CLK_I2C2>; + interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c3: i2c@e017c000 { + compatible = "actions,s700-i2c"; + reg = <0 0xe017c000 0 0x1000>; + clocks = <&cmu CLK_I2C3>; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + sps: power-controller@e01b0100 { + compatible = "actions,s700-sps"; + reg = <0x0 0xe01b0100 0x0 0x100>; + #power-domain-cells = <1>; + }; + + timer: timer@e024c000 { + compatible = "actions,s700-timer"; + reg = <0x0 0xe024c000 0x0 0x4000>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "timer1"; + }; + + pinctrl: pinctrl@e01b0000 { + compatible = "actions,s700-pinctrl"; + reg = <0x0 0xe01b0000 0x0 0x1000>; + clocks = <&cmu CLK_GPIO>; + gpio-controller; + gpio-ranges = <&pinctrl 0 0 136>; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; + }; + }; +}; diff --git a/include/dt-bindings/clock/actions,s700-cmu.h b/include/dt-bindings/clock/actions,s700-cmu.h new file mode 100644 index 0000000..3e19429 --- /dev/null +++ b/include/dt-bindings/clock/actions,s700-cmu.h @@ -0,0 +1,118 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Device Tree binding constants for Actions Semi S700 Clock Management Unit + * + * Copyright (c) 2014 Actions Semi Inc. + * Author: David Liu liuwei@actions-semi.com + * + * Author: Pathiban Nallathambi pn@denx.de + * Author: Saravanan Sekar sravanhome@gmail.com + */ + +#ifndef __DT_BINDINGS_CLOCK_S700_H +#define __DT_BINDINGS_CLOCK_S700_H + +#define CLK_NONE 0 + +/* pll clocks */ +#define CLK_CORE_PLL 1 +#define CLK_DEV_PLL 2 +#define CLK_DDR_PLL 3 +#define CLK_NAND_PLL 4 +#define CLK_DISPLAY_PLL 5 +#define CLK_TVOUT_PLL 6 +#define CLK_CVBS_PLL 7 +#define CLK_AUDIO_PLL 8 +#define CLK_ETHERNET_PLL 9 + +/* system clock */ +#define CLK_CPU 10 +#define CLK_DEV 11 +#define CLK_AHB 12 +#define CLK_APB 13 +#define CLK_DMAC 14 +#define CLK_NOC0_CLK_MUX 15 +#define CLK_NOC1_CLK_MUX 16 +#define CLK_HP_CLK_MUX 17 +#define CLK_HP_CLK_DIV 18 +#define CLK_NOC1_CLK_DIV 19 +#define CLK_NOC0 20 +#define CLK_NOC1 21 +#define CLK_SENOR_SRC 22 + +/* peripheral device clock */ +#define CLK_GPIO 23 +#define CLK_TIMER 24 +#define CLK_DSI 25 +#define CLK_CSI 26 +#define CLK_SI 27 +#define CLK_DE 28 +#define CLK_HDE 29 +#define CLK_VDE 30 +#define CLK_VCE 31 +#define CLK_NAND 32 +#define CLK_SD0 33 +#define CLK_SD1 34 +#define CLK_SD2 35 + +#define CLK_UART0 36 +#define CLK_UART1 37 +#define CLK_UART2 38 +#define CLK_UART3 39 +#define CLK_UART4 40 +#define CLK_UART5 41 +#define CLK_UART6 42 + +#define CLK_PWM0 43 +#define CLK_PWM1 44 +#define CLK_PWM2 45 +#define CLK_PWM3 46 +#define CLK_PWM4 47 +#define CLK_PWM5 48 +#define CLK_GPU3D 49 + +#define CLK_I2C0 50 +#define CLK_I2C1 51 +#define CLK_I2C2 52 +#define CLK_I2C3 53 + +#define CLK_SPI0 54 +#define CLK_SPI1 55 +#define CLK_SPI2 56 +#define CLK_SPI3 57 + +#define CLK_USB3_480MPLL0 58 +#define CLK_USB3_480MPHY0 59 +#define CLK_USB3_5GPHY 60 +#define CLK_USB3_CCE 61 +#define CLK_USB3_MAC 62 + +#define CLK_LCD 63 +#define CLK_HDMI_AUDIO 64 +#define CLK_I2SRX 65 +#define CLK_I2STX 66 + +#define CLK_SENSOR0 67 +#define CLK_SENSOR1 68 + +#define CLK_HDMI_DEV 69 + +#define CLK_ETHERNET 70 +#define CLK_RMII_REF 71 + +#define CLK_USB2H0_PLLEN 72 +#define CLK_USB2H0_PHY 73 +#define CLK_USB2H0_CCE 74 +#define CLK_USB2H1_PLLEN 75 +#define CLK_USB2H1_PHY 76 +#define CLK_USB2H1_CCE 77 + +#define CLK_TVOUT 78 + +#define CLK_THERMAL_SENSOR 79 + +#define CLK_IRC_SWITCH 80 +#define CLK_PCM1 81 +#define CLK_NR_CLKS (CLK_PCM1 + 1) + +#endif /* __DT_BINDINGS_CLOCK_S700_H */ diff --git a/include/dt-bindings/reset/actions,s700-reset.h b/include/dt-bindings/reset/actions,s700-reset.h new file mode 100644 index 0000000..5e3b16b --- /dev/null +++ b/include/dt-bindings/reset/actions,s700-reset.h @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR MIT) +// +// Device Tree binding constants for Actions Semi S700 Reset Management Unit +// +// Copyright (c) 2018 Linaro Ltd. + +#ifndef __DT_BINDINGS_ACTIONS_S700_RESET_H +#define __DT_BINDINGS_ACTIONS_S700_RESET_H + +#define RESET_AUDIO 0 +#define RESET_CSI 1 +#define RESET_DE 2 +#define RESET_DSI 3 +#define RESET_GPIO 4 +#define RESET_I2C0 5 +#define RESET_I2C1 6 +#define RESET_I2C2 7 +#define RESET_I2C3 8 +#define RESET_KEY 9 +#define RESET_LCD0 10 +#define RESET_SI 11 +#define RESET_SPI0 12 +#define RESET_SPI1 13 +#define RESET_SPI2 14 +#define RESET_SPI3 15 +#define RESET_UART0 16 +#define RESET_UART1 17 +#define RESET_UART2 18 +#define RESET_UART3 19 +#define RESET_UART4 20 +#define RESET_UART5 21 +#define RESET_UART6 22 + +#endif /* __DT_BINDINGS_ACTIONS_S700_RESET_H */
Devices like uart and clk are needed to be enabled before relocation. this patch adds u-boot.dtsi file that mark these device as dm-pre-reloc.
Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- Changes since v7: * No changes. Changes since v6: * No changes. Changes since v5: * Added reviwed-by tag. Changes since v4: * Moved it to 08/11 to 06/11. Changes since v3: * Replaced dtsi with dts in subject line along with arm:dts: to the prefix. Changes since v2: * Added License. Changes since v1: * This is newly added file that was *not* present in v1 and contains u-boot specific changes. --- arch/arm/dts/s700-u-boot.dtsi | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+) create mode 100644 arch/arm/dts/s700-u-boot.dtsi
diff --git a/arch/arm/dts/s700-u-boot.dtsi b/arch/arm/dts/s700-u-boot.dtsi new file mode 100644 index 0000000..a527ccc --- /dev/null +++ b/arch/arm/dts/s700-u-boot.dtsi @@ -0,0 +1,18 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Amit Singh Tomar amittomer25@gmail.com + */ + +/{ + soc { + u-boot,dm-pre-reloc; + }; +}; + +&uart3 { + u-boot,dm-pre-reloc; +}; + +&cmu { + u-boot,dm-pre-reloc; +};
This patch adds basic support for Actions Semi based S700 SoC, which is driven by common owl framework.
Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- Changes since v7: * Removed S700 include file. Changes since v6: * No changes. Changes since v5: * Added reviewed-by tag. Changes since v4: * Moved it to 09/11 to 04/11. Changes since v3: * Added "SoC" keyword to Actions Semi S700. Changes since v2: * Fixed the commit message. * Checked for the clk->id. * Added a .data member with SoC type. * Removed #ifdefs from few places. Changes since v1: * Moved CLK and CLK_OWL symbols from defconfig to arch/arm/Kconfig. --- arch/arm/mach-owl/Kconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/mach-owl/Kconfig b/arch/arm/mach-owl/Kconfig index 28984c1..cde2ade 100644 --- a/arch/arm/mach-owl/Kconfig +++ b/arch/arm/mach-owl/Kconfig @@ -8,6 +8,10 @@ config MACH_S900 bool "Actions Semi S900 SoC" select ARM64
+config MACH_S700 + bool "Actions Semi S700 SoC" + select ARM64 + endchoice
config SYS_TEXT_BASE @@ -18,5 +22,6 @@ config SYS_CONFIG_NAME
config SYS_SOC default "s900" if MACH_S900 + default "s700" if MACH_S700
endif
Cheers, Andre
Changes since v7:
- Removed S700 include file.
+config MACH_S700
select ARM64
endchoice
endif
This patch moves some of the config options from bubblegum_96_defconfig to platform specific Kconfig file.
Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- Changes since v7: * No changes. Changes since v6: * remove unnecessary string from SYS_PROMPT. Changes since v5: * Newly added patch, was not there in earlier versions. --- arch/arm/mach-owl/Kconfig | 15 +++++++++++++++ configs/bubblegum_96_defconfig | 5 ----- 2 files changed, 15 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-owl/Kconfig b/arch/arm/mach-owl/Kconfig index 1d59d8f..8344081 100644 --- a/arch/arm/mach-owl/Kconfig +++ b/arch/arm/mach-owl/Kconfig @@ -25,4 +25,19 @@ config SYS_SOC default "s900" if MACH_S900 default "s700" if MACH_S700
+config DISTRO_DEFAULTS + default y + +config NR_DRAM_BANKS + default 1 + +config SYS_RELOC_GD_ENV_ADDR + default y + +config SYS_PROMPT + default "U-Boot => " + +config DISPLAY_BOARDINFO + default n + endif diff --git a/configs/bubblegum_96_defconfig b/configs/bubblegum_96_defconfig index e76e9a2..0883167 100644 --- a/configs/bubblegum_96_defconfig +++ b/configs/bubblegum_96_defconfig @@ -1,19 +1,14 @@ CONFIG_ARM=y CONFIG_ARCH_OWL=y CONFIG_ENV_SIZE=0x2000 -CONFIG_NR_DRAM_BANKS=1 CONFIG_MACH_S900=y CONFIG_IDENT_STRING="\nBubblegum-96" -CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyOWL5,115200n8" # CONFIG_DISPLAY_CPUINFO is not set -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SYS_PROMPT="U-Boot => " CONFIG_CMD_MD5SUM=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIMER=y CONFIG_DEFAULT_DEVICE_TREE="bubblegum_96" -CONFIG_SYS_RELOC_GD_ENV_ADDR=y
The Cubieboard is a single board computer containing a Actions S700 SoC(with 4 ARMv8 Cortex-A53 cores).
This patch adds respective defconfig alongwith .dts(copied from Linux v5.5-rc6 with hash "b3a987b0264d").
Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- Changes since v7: * No changes. Changes since v6: * Added Reviewed-by tag. Changes since v5: * Trimmed of the cubieboard7_defconfig. Changes since v4: * No changes. Changes since v3: * added reviewed-by: tag. Changes since v2: * No changes. Changes since v1: * No changes. --- arch/arm/dts/s700-cubieboard7.dts | 92 +++++++++++++++++++++++++++++++++++++++ configs/cubieboard7_defconfig | 9 ++++ 2 files changed, 101 insertions(+) create mode 100644 arch/arm/dts/s700-cubieboard7.dts create mode 100644 configs/cubieboard7_defconfig
diff --git a/arch/arm/dts/s700-cubieboard7.dts b/arch/arm/dts/s700-cubieboard7.dts new file mode 100644 index 0000000..63e375c --- /dev/null +++ b/arch/arm/dts/s700-cubieboard7.dts @@ -0,0 +1,92 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2017 Andreas Färber + */ + +/dts-v1/; + +#include "s700.dtsi" + +/ { + compatible = "cubietech,cubieboard7", "actions,s700"; + model = "CubieBoard7"; + + aliases { + serial3 = &uart3; + }; + + chosen { + stdout-path = "serial3:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; + + memory@1,e0000000 { + device_type = "memory"; + reg = <0x1 0xe0000000 0x0 0x0>; + }; +}; + +&i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_default>; +}; + +&i2c1 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_default>; +}; + +&i2c2 { + status = "disabled"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_default>; +}; + +&pinctrl { + i2c0_default: i2c0_default { + pinmux { + groups = "i2c0_mfp"; + function = "i2c0"; + }; + pinconf { + pins = "i2c0_sclk", "i2c0_sdata"; + bias-pull-up; + }; + }; + + i2c1_default: i2c1_default { + pinmux { + groups = "i2c1_dummy"; + function = "i2c1"; + }; + pinconf { + pins = "i2c1_sclk", "i2c1_sdata"; + bias-pull-up; + }; + }; + + i2c2_default: i2c2_default { + pinmux { + groups = "i2c2_dummy"; + function = "i2c2"; + }; + pinconf { + pins = "i2c2_sclk", "i2c2_sdata"; + bias-pull-up; + }; + }; +}; + +&timer { + clocks = <&hosc>; +}; + +&uart3 { + status = "okay"; +}; diff --git a/configs/cubieboard7_defconfig b/configs/cubieboard7_defconfig new file mode 100644 index 0000000..d12c293 --- /dev/null +++ b/configs/cubieboard7_defconfig @@ -0,0 +1,9 @@ +CONFIG_ARM=y +CONFIG_ARCH_OWL=y +CONFIG_MACH_S700=y +CONFIG_IDENT_STRING="\ncubieboard7" +CONFIG_BOOTDELAY=5 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyOWL3,115200n8" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DEFAULT_DEVICE_TREE="s700-cubieboard7"
This adds build and flash steps for Actions S700 based Cubieboard7 board.
Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- Changes since v7: * No changes. Changes since v6: * No changes. Changes since v5: * No changes. Changes since v4: * No changes. Changes since v3: * Convert plain text documentation to reStructuredText format. Changes since v2: * No Change. Changes since v1: * No Change. --- doc/board/actions/cubieboard7.rst | 115 ++++++++++++++++++++++++++++++++++++++ doc/board/actions/index.rst | 10 ++++ doc/board/index.rst | 1 + 3 files changed, 126 insertions(+) create mode 100644 doc/board/actions/cubieboard7.rst create mode 100644 doc/board/actions/index.rst
diff --git a/doc/board/actions/cubieboard7.rst b/doc/board/actions/cubieboard7.rst new file mode 100644 index 0000000..ce39e6b --- /dev/null +++ b/doc/board/actions/cubieboard7.rst @@ -0,0 +1,115 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright (C) 2020 Amit Singh Tomar amittomer25@gmail.com + +ACTIONS +======== + +About this +---------- + +This document describes build and flash steps for Actions S700 SoC based Cubieboard7 +board. + +Cubieboard7 initial configuration +--------------------------------- + +Default Cubieboard7 comes with pre-installed Android where U-Boot is configured with +a bootdelay of 0, entering a prompt by pressing keys does not seem to work. + +Though, one can enter ADFU mode and flash debian image(from host machine) where +getting into u-boot prompt is easy. + +Enter ADFU Mode +---------------- + +Before write the firmware, let the development board entering the ADFU mode: insert +one end of the USB cable to the PC, press and hold the ADFU button, and then connect +the other end of the USB cable to the Mini USB port of the development board, release +the ADFU button, after connecting it will enter the ADFU mode. + +Check whether entered ADFU Mode +-------------------------------- + +The user needs to run the following command on the PC side to check if the ADFU +device is detected. ID realted to "Actions Semiconductor Co., Ltd" means that +the PC side has been correctly detected ADFU device, the development board +also enter into the ADFU mode. + +.. code-block:: none + + $ lsusb + Bus 001 Device 005: ID 04f2:b2eb Chicony Electronics Co., Ltd + Bus 001 Device 004: ID 0a5c:21e6 Broadcom Corp. BCM20702 Bluetooth 4.0 [ThinkPad] + Bus 001 Device 003: ID 046d:c534 Logitech, Inc. Unifying Receiver + Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub + Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub + Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub + Bus 003 Device 013: ID 10d6:10d6 Actions Semiconductor Co., Ltd + Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub + +Flashing debian image +--------------------- + +.. code-block:: none + + $ sudo ./ActionsFWU.py --fw=debian-stretch-desktop-cb7-emmc-v2.0.fw + ActionsFWU.py : 1.0.150828.0830 + libScript.so : 2.3.150825.0951 + libFileSystem.so: 2.3.150825.0952 + libProduction.so: 2.3.150915.1527 + =====burn all partition==== + FW_VER: 3.10.37.180608 + 3% DOWNLOAD ADFUDEC ... + 5% DOWNLOAD BOOT PARA ... + 7% SWITCH ADFUDEC ... + 12% DOWNLOAD BL31 ... + 13% DOWNLOAD BL32 ... + 15% DOWNLOAD VMLINUX ... + 20% DOWNLOAD INITRD ... + 24% DOWNLOAD FDT ... + 27% DOWNLOAD ADFUS ... + 30% SWITCH ADFUS ... + 32% DOWNLOAD MBR ... + 35% DOWNLOAD PARTITIONS ... + WRITE_MBRC_PARTITION + 35% write p0 size = 2048 : ok + WRITE_BOOT_PARTITION + 35% write p1 size = 2048 : ok + WRITE_MISC_PARTITION + 36% write p2 size = 98304 : ok + WRITE_SYSTEM_PARTITION + 94% write p3 size = 4608000 : ok + FORMAT_SWAP_PARTITION + 94% write p4 size = 20480 : ok + 95% TRANSFER OVER ... + Firmware upgrade successfully! + +Debian image can be downloaded from here[1]. + +Once debian image is flashed, one can get into u-boot prompt by pressing any key and from +there run ums command(make sure, usb cable is connected between host and target): + +.. code-block:: none + + owl> ums 0 mmc 1 + +Above command would mount debian image partition on host machine. + +Building U-BOOT proper image +---------------------------- + +.. code-block:: none + + $ make clean + $ export CROSS_COMPILE=aarch64-linux-gnu- + $ make ARCH=arm cubieboard7_defconfig + $ make -j16 + $ mkimage -A arm -T firmware -C none -O u-boot -a 0x11000000 -e 0x11000000 -d u-boot-dtb.bin u-boot-dtb.img >/dev/null + +u-boot-dtb.img can now be flashed to debian image partition mounted on host machine. + +.. code-block:: none + + $ sudo dd if=u-boot-dtb.img of=/dev/sdb bs=1024 seek=3072 + +[1]: https://pan.baidu.com/s/1uawPr0Jao2HgWFLZCLzHAg#list/path=%2FCubieBoard_Down... diff --git a/doc/board/actions/index.rst b/doc/board/actions/index.rst new file mode 100644 index 0000000..c596879 --- /dev/null +++ b/doc/board/actions/index.rst @@ -0,0 +1,10 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright (C) 2020 Amit Singh Tomar amittomer25@gmail.com + +Actions +======== + +.. toctree:: + :maxdepth: 2 + + cubieboard7 diff --git a/doc/board/index.rst b/doc/board/index.rst index 51a2ae6..01b233f 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -6,6 +6,7 @@ Board-specific doc .. toctree:: :maxdepth: 2
+ actions/index AndesTech/index atmel/index coreboot/index
On 21/03/2020 17:30, Amit Singh Tomar wrote:
Hi Mani,
This adds Cubieboard7[1] support based on Action Semi's S700 SoC[2], It's Quad-core ARMv8 SoC with Cortex-A53 cores. Peripheral like UART seems to be compatible with S900 SoC(basic support for it is alreay present in u-boot).
I reviewed the series and am now happy with it - I added the missing review tags for patch 1 and 9. I find the instructions in the final patch quite convoluted and somewhat cumbersome, but I guess this is more due to the vendor boot process being somewhat closed down.
I have neither hardware, so can't test anything, but at least I compile tested every patch with bubblegum_96_defconfig, and the final patch with cubieboard7_defconfig. I hope that I didn't miss anything that would break the Bubblegum board, but please test it if you have the hardware.
Amit, thanks for your continued work on this and the prompt replies!
Cheers, Andre
This series(v8) removes the SoC specific include instead just uses owl-common. For this patch 01/12 and 09/12 changes a bit.
Previous series(v7) fixes a serious Bug that breaks S900, it was there since v5.Thanks to Andre for pointing it out.
Series(v6)[3] does following changes:
- [PATCH v5 06/11] becomes [PATCH v6 03/11]
- [PATCH v5 03/11] becomes [PATCH v6 04/11]
- Introduce a new patch to move defconfig options to Kconfig which is [PATCH v6 10/12]
Series(v5)[4] just re-orders the patches so that U-BOOT(with bubblegum96_defconfig) builds after every patch of the series(suggested by Andre).
S700 support is tested[5] on Cubieboard7 board and S900 support is just compiled tested.
This patch series can be tested using below tree: https://github.com/Atomar25/u-boot/commits/s700_v8
Amit Singh Tomar (12): arm: actions: Add common framework for Actions Owl Semi SoCs arm: actions: rename sysmap-s900 to sysmap-owl serial: actions: add compatible string arm: dts: sync dts for Action Semi S900 arm: dts: actions: s900: add u-boot specific dtsi file clk: actions: Add common clock driver arm: actions: add S700 SoC device tree arm: dts: actions: s700: add u-boot specific dtsi file arm: add support Actions Semi S700 actions: Move defconfig options to Kconfig arm: add Cubieboard7 board support doc: boards: add Cubieboard7 documentation
MAINTAINERS | 2 + arch/arm/Kconfig | 5 +- arch/arm/dts/Makefile | 6 +- arch/arm/dts/s700-cubieboard7.dts | 92 +++++++ arch/arm/dts/s700-u-boot.dtsi | 18 ++ arch/arm/dts/s700.dtsi | 248 +++++++++++++++++++ arch/arm/dts/s900-u-boot.dtsi | 17 ++ arch/arm/dts/s900.dtsi | 322 +++++++++++++++++++++++-- arch/arm/include/asm/arch-owl/clk_s900.h | 57 ----- arch/arm/include/asm/arch-owl/regs_s700.h | 56 +++++ arch/arm/mach-owl/Kconfig | 50 ++-- arch/arm/mach-owl/Makefile | 3 +- arch/arm/mach-owl/soc.c | 57 +++++ arch/arm/mach-owl/sysmap-owl.c | 32 +++ arch/arm/mach-owl/sysmap-s900.c | 32 --- board/ucRobotics/bubblegum_96/Kconfig | 15 -- board/ucRobotics/bubblegum_96/MAINTAINERS | 6 - board/ucRobotics/bubblegum_96/Makefile | 3 - board/ucRobotics/bubblegum_96/bubblegum_96.c | 57 ----- configs/bubblegum_96_defconfig | 12 +- configs/cubieboard7_defconfig | 9 + doc/board/actions/cubieboard7.rst | 115 +++++++++ doc/board/actions/index.rst | 10 + doc/board/index.rst | 1 + drivers/clk/owl/Kconfig | 8 +- drivers/clk/owl/Makefile | 2 +- drivers/clk/owl/clk_owl.c | 153 ++++++++++++ drivers/clk/owl/clk_owl.h | 65 +++++ drivers/clk/owl/clk_s900.c | 137 ----------- drivers/serial/serial_owl.c | 2 +- include/configs/bubblegum_96.h | 40 --- include/configs/owl-common.h | 40 +++ include/configs/s700.h | 13 + include/configs/s900.h | 16 ++ include/dt-bindings/clock/actions,s700-cmu.h | 118 +++++++++ include/dt-bindings/clock/actions,s900-cmu.h | 129 ++++++++++ include/dt-bindings/clock/s900_cmu.h | 77 ------ include/dt-bindings/reset/actions,s700-reset.h | 34 +++ include/dt-bindings/reset/actions,s900-reset.h | 65 +++++ 39 files changed, 1638 insertions(+), 486 deletions(-) create mode 100644 arch/arm/dts/s700-cubieboard7.dts create mode 100644 arch/arm/dts/s700-u-boot.dtsi create mode 100644 arch/arm/dts/s700.dtsi create mode 100644 arch/arm/dts/s900-u-boot.dtsi delete mode 100644 arch/arm/include/asm/arch-owl/clk_s900.h create mode 100644 arch/arm/include/asm/arch-owl/regs_s700.h create mode 100644 arch/arm/mach-owl/soc.c create mode 100644 arch/arm/mach-owl/sysmap-owl.c delete mode 100644 arch/arm/mach-owl/sysmap-s900.c delete mode 100644 board/ucRobotics/bubblegum_96/Kconfig delete mode 100644 board/ucRobotics/bubblegum_96/MAINTAINERS delete mode 100644 board/ucRobotics/bubblegum_96/Makefile delete mode 100644 board/ucRobotics/bubblegum_96/bubblegum_96.c create mode 100644 configs/cubieboard7_defconfig create mode 100644 doc/board/actions/cubieboard7.rst create mode 100644 doc/board/actions/index.rst create mode 100644 drivers/clk/owl/clk_owl.c create mode 100644 drivers/clk/owl/clk_owl.h delete mode 100644 drivers/clk/owl/clk_s900.c delete mode 100644 include/configs/bubblegum_96.h create mode 100644 include/configs/owl-common.h create mode 100644 include/configs/s700.h create mode 100644 include/configs/s900.h create mode 100644 include/dt-bindings/clock/actions,s700-cmu.h create mode 100644 include/dt-bindings/clock/actions,s900-cmu.h delete mode 100644 include/dt-bindings/clock/s900_cmu.h create mode 100644 include/dt-bindings/reset/actions,s700-reset.h create mode 100644 include/dt-bindings/reset/actions,s900-reset.h
Hi Andre,
On 22 March 2020 5:31:11 AM IST, "André Przywara" andre.przywara@arm.com wrote:
Hi Mani,
I've been shadowing this series due to not getting enough time for reviewing/testing. I hope to spend time next week on this.
Thanks Amit for your patience and updates.
Regards, Mani
Cheers, Andre
[PATCH v6 10/12]
[3]:
http://u-boot.10912.n7.nabble.com/PATCH-v6-00-12-Actions-S700-SoC-support-td...
[4]:
http://u-boot.10912.n7.nabble.com/PATCH-v5-00-11-Actions-S700-SoC-support-td...
Hi Amit,
Just tested v8 on bubblegum96 and it doesn't boot. I can't see any debug print on the console, so I'm guessing something basic going wrong. Will try to find the regression if I find some time and keep you posted.
Thanks, Mani
-- 2.7.4
Hi Mani,
Thanks for trying it. Looks like issue is with clock driver (not reading the driver data properly). Can you please try it with below series:
https://github.com/Atomar25/u-boot/commits/s700_v9
Thanks -Amit
Hi Amit,
On Tue, Mar 31, 2020 at 10:27:45AM +0530, Amit Tomer wrote:
Hi Mani,
Yes, this fixes the issue and now Bubblegum96 boots. Please send the v9 so that I can review.
Thanks, Mani
Thanks -Amit
Amit Singh Tomar
Amit Tomer
André Przywara
