[U-Boot] Pull request: u-boot-spi/master
Hi Tom,
Please pull this PR.
thanks! Jagan.
The following changes since commit 1f6049e2501b5c35c61435dbc05ba96743202674:
tools/mkimage: Make the path to the dtc binary that mkimage calls configurable (2017-09-24 07:33:03 -0400)
git://git.denx.de/u-boot-spi.git master
for you to fetch changes up to db10809c17c7cd8960d0c45248bbef6e76251ad7:
Fix s25fl256s position in spi_flash_ids list (2017-09-25 13:00:34 +0530)
---------------------------------------------------------------- Marek Vasut (1): sf: Fix S25FL116K entry
Peng Fan (1): spi: mxc_spi: support driver model
Suresh Gupta (1): spi: fsl_qspi: Add controller busy check before new spi operation
Vsevolod Gribov (1): Fix s25fl256s position in spi_flash_ids list
Yogesh Gaur (1): mtd/spi: Add MT35XU512ABA1G12 NOR flash support
drivers/mtd/spi/spi_flash_ids.c | 5 +- drivers/spi/fsl_qspi.c | 28 ++++++- drivers/spi/fsl_qspi.h | 4 + drivers/spi/mxc_spi.c | 181 +++++++++++++++++++++++++++++++++------- 4 files changed, 183 insertions(+), 35 deletions(-)
Hi Jagan,
Hi Tom,
Would you find some time and look into following patch:
http://patchwork.ozlabs.org/patch/813266/
Thanks in advance, Łukasz
thanks! Jagan.
drivers/mtd/spi/spi_flash_ids.c | 5 +- drivers/spi/fsl_qspi.c | 28 ++++++- drivers/spi/fsl_qspi.h | 4 + drivers/spi/mxc_spi.c | 181 +++++++++++++++++++++++++++++++++------- 4 files changed, 183 insertions(+), 35 deletions(-) _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
On Mon, Sep 25, 2017 at 2:11 PM, Łukasz Majewski lukma@denx.de wrote:
Hi Jagan,
Hi Tom,
Of-course, will comment on respective patch itself.
thanks!
On Mon, Sep 25, 2017 at 01:21:35PM +0530, Jagan Teki wrote:
Hi Tom,
thanks! Jagan.
Jagan Teki
Łukasz Majewski
