Re: [U-Boot] [PATCH v4 2/2] gpio: Add GPIO driver for Marvell SoC Armada100
----- "Prafulla Wadaskar" prafulla@marvell.com wrote:
-----Original Message----- From: Ajay Bhargav [mailto:ajay.bhargav@einfochips.com] Sent: Wednesday, August 10, 2011 2:47 PM To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Ajay Bhargav Subject: [PATCH v4 2/2] gpio: Add GPIO driver for Marvell SoC
Armada100
This patch adds support for generic GPIO driver framework for
Marvell
SoC Armada100.
v4 - updated gpio.h file, removed modification in Armada100.h
You are not following standard patch submission practice as indicated here http://www.denx.de/wiki/view/U-Boot/Patches#Sending_updated_patch_versions
You need to document entire change history for each patch to be submitted below ---, this is important
Sorry for mistake.. Do i need to add history in each patch or first patch of a series patch? I mean if I am submitting 2 patches in series I define history in patch 1/2. Am I right?
Thanks & Regards, Ajay Bhargav
-----Original Message----- From: Ajay Bhargav [mailto:ajay.bhargav@einfochips.com] Sent: Wednesday, August 10, 2011 3:49 PM To: Prafulla Wadaskar Cc: u-boot@lists.denx.de Subject: Re: [PATCH v4 2/2] gpio: Add GPIO driver for Marvell SoC Armada100
Armada100
Marvell
SoC Armada100.
You should add relevant history for each patch, if in your patch series one patch is being changed, change log for that particular path is must for other patches you may say, "Not changed in this version"
You may refer some other patches submitted/accepted on the list.
Regards.. Prafulla . .
Ajay Bhargav
Prafulla Wadaskar
