[U-Boot] [PATCH v3 09/13] ext4: After completely filled group, scan next group from the beginning
The last free block of a block group may be in its middle. After it has been allocated, the next block group should be scanned from its beginning.
The following command triggers the bad behaviour (on a blocksize 1024 fs):
./sandbox/u-boot -c 'i=0; host bind 0 ./disk.raw ; while test $i -lt 260 ; do echo $i; setexpr i $i + 1; ext4write host 0:2 0 /X${i} 0x1450; done ; ext4write host 0:2 0 /X240 0x2000 ; '
When 'X240' is extended from 5200 byte to 8192 byte, the new blocks should start from the first free block (8811), but it uses the blocks 8098-8103 and 16296-16297 -- 8103 + 1 + 8192 = 16296. This can be shown with debugfs, commands 'ffb' and 'stat X240'.
Signed-off-by: Stefan Brüns stefan.bruens@rwth-aachen.de --- fs/ext4/ext4_common.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
v3: Patch added to series
diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c index 1ebdbe6..362668b 100644 --- a/fs/ext4/ext4_common.c +++ b/fs/ext4/ext4_common.c @@ -895,8 +895,8 @@ uint32_t ext4fs_get_new_blk_no(void)
goto fail; } else { -restart: fs->curr_blkno++; +restart: /* get the blockbitmap index respective to blockno */ bg_idx = fs->curr_blkno / blk_per_grp; if (fs->blksz == 1024) { @@ -914,8 +914,9 @@ restart:
if (bgd[bg_idx].free_blocks == 0) { debug("block group %u is full. Skipping\n", bg_idx); - fs->curr_blkno = fs->curr_blkno + blk_per_grp; - fs->curr_blkno--; + fs->curr_blkno = (bg_idx + 1) * blk_per_grp; + if (fs->blksz == 1024) + fs->curr_blkno += 1; goto restart; }
@@ -932,6 +933,7 @@ restart: bg_idx) != 0) { debug("going for restart for the block no %ld %u\n", fs->curr_blkno, bg_idx); + fs->curr_blkno++; goto restart; }
Hi Stefan,
goto fail;
bg_idx);
blk_per_grp;
fs->curr_blkno--;
}fs->curr_blkno += 1; goto restart;
}fs->curr_blkno++; goto restart;
Reviewed-by: Lukasz Majewski l.majewski@samsung.com
Lukasz Majewski
Stefan Brüns
