[U-Boot] [PATCHv2 1/2] armv8: Enable CPUECTLR.SMPEN for coherency
For A53, data coherency is enabled only when the CPUECTLR.SMPEN bit is set. The SMPEN bit should be set before enabling the data cache. If not enabled, the cache is not coherent with other cores and data corruption could occur.
For A57/A72, SMPEN bit enables the processor to receive instruction cache and TLB maintenance operations broadcast from other processors in the cluster. This bit should be set before enabling the caches and MMU, or performing any cache and TLB maintenance operations.
Signed-off-by: Mingkai Hu mingkai.hu@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com Signed-off-by: Mateusz Kulikowski mateusz.kulikowski@gmail.com Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V2: - Revised the help information.
arch/arm/cpu/armv8/Kconfig | 18 ++++++++++++++++++ arch/arm/cpu/armv8/start.S | 11 +++++++++++ 2 files changed, 29 insertions(+)
diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 22dce88..472b2ba 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -3,6 +3,24 @@ if ARM64 config ARMV8_MULTIENTRY bool "Enable multiple CPUs to enter into U-Boot"
+config ARMV8_SET_SMPEN + bool "Enable data coherency with other cores in cluster" + help + Say Y here if there is not any trust firmware to set + CPUECTLR_EL1.SMPEN bit before U-Boot. + + For A53, it enables data coherency with other cores in the + cluster, and for A57/A72, it enables receiving of instruction + cache and TLB maintenance operations. + Cortex A53/57/72 cores require CPUECTLR_EL1.SMPEN set even + for single core systems. Unfortunately write access to this + register may be controlled by EL3/EL2 firmware. To be more + precise, by default (if there is EL2/EL3 firmware running) + this register is RO for NS EL1. + This switch can be used to avoid writing to CPUECTLR_EL1, + it can be safely enabled when EL2/EL3 initialized SMPEN bit + or when CPU implementation doesn't include that register. + config ARMV8_SPIN_TABLE bool "Support spin-table enable method" depends on ARMV8_MULTIENTRY && OF_LIBFDT diff --git a/arch/arm/cpu/armv8/start.S b/arch/arm/cpu/armv8/start.S index 4f5f6d8..5308702 100644 --- a/arch/arm/cpu/armv8/start.S +++ b/arch/arm/cpu/armv8/start.S @@ -86,6 +86,17 @@ save_boot_params_ret: msr cpacr_el1, x0 /* Enable FP/SIMD */ 0:
+ /* + * Enalbe SMPEN bit for coherency. + * This register is not architectural but at the moment + * this bit should be set for A53/A57/A72. + */ +#ifdef CONFIG_ARMV8_SET_SMPEN + mrs x0, S3_1_c15_c2_1 /* cpuactlr_el1 */ + orr x0, x0, #0x40 + msr S3_1_c15_c2_1, x0 +#endif + /* Apply ARM core specific erratas */ bl apply_core_errata
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V2: - No change
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index cc0dc88..f71a243 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -1,5 +1,6 @@ config ARCH_LS1012A bool + select ARMV8_SET_SMPEN select FSL_LSCH2 select SYS_FSL_DDR_BE select SYS_FSL_MMDC @@ -7,6 +8,7 @@ config ARCH_LS1012A
config ARCH_LS1043A bool + select ARMV8_SET_SMPEN select FSL_LSCH2 select SYS_FSL_DDR_BE select SYS_FSL_DDR_VER_50 @@ -15,6 +17,7 @@ config ARCH_LS1043A
config ARCH_LS1046A bool + select ARMV8_SET_SMPEN select FSL_LSCH2 select SYS_FSL_DDR_BE select SYS_FSL_DDR4 @@ -24,6 +27,7 @@ config ARCH_LS1046A
config ARCH_LS2080A bool + select ARMV8_SET_SMPEN select FSL_LSCH3 select SYS_FSL_DDR4 select SYS_FSL_DDR_LE
Hi.
2017-01-06 18:41 GMT+09:00 Zhiqiang Hou Zhiqiang.Hou@nxp.com:
V2:
help
I am a bit curious about this. Are you planning to implement Trusted Firmware in the future? It this option a temporary work-around until then?
On 01/06/2017 03:19 AM, Masahiro Yamada wrote:
Hi.
V2:
help
Yes, trusted firmware has been planned and is on the way.
Yes. Actually there are other things need to be disabled once U-Boot starts at EL2.
York
V2:
This set is applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Masahiro Yamada
york sun
Zhiqiang Hou
