[U-Boot] [PATCH v1] blackfin: Move blackfin serial driver out of blackfin arch folder.
- Move blackfin serial driver to the generic driver folder. - Move blackfin serial headers to blackfin arch head folder. - Update the include path to blackfin serial header in start up code.
Signed-off-by: Sonic Zhang sonic.zhang@analog.com --- arch/blackfin/cpu/Makefile | 1 - arch/blackfin/cpu/cpu.c | 2 +- arch/blackfin/cpu/initcode.c | 5 ++--- arch/blackfin/cpu/start.S | 3 +-- arch/blackfin/{cpu => include/asm}/serial.h | 0 arch/blackfin/{cpu => include/asm}/serial1.h | 0 arch/blackfin/{cpu => include/asm}/serial4.h | 0 drivers/serial/Makefile | 1 + .../cpu/serial.c => drivers/serial/serial_bfin.c | 3 +-- include/configs/bfin_adi_common.h | 3 +++ 10 files changed, 9 insertions(+), 9 deletions(-) rename arch/blackfin/{cpu => include/asm}/serial.h (100%) rename arch/blackfin/{cpu => include/asm}/serial1.h (100%) rename arch/blackfin/{cpu => include/asm}/serial4.h (100%) rename arch/blackfin/cpu/serial.c => drivers/serial/serial_bfin.c (99%)
diff --git a/arch/blackfin/cpu/Makefile b/arch/blackfin/cpu/Makefile index 145f63e..929fc8b 100644 --- a/arch/blackfin/cpu/Makefile +++ b/arch/blackfin/cpu/Makefile @@ -23,7 +23,6 @@ COBJS-y += interrupts.o COBJS-$(CONFIG_JTAG_CONSOLE) += jtag-console.o COBJS-y += os_log.o COBJS-y += reset.o -COBJS-y += serial.o COBJS-y += traps.o
SRCS := $(SEXTRA:.o=.S) $(SOBJS:.o=.S) $(COBJS-y:.o=.c) diff --git a/arch/blackfin/cpu/cpu.c b/arch/blackfin/cpu/cpu.c index d841f64..218f57e 100644 --- a/arch/blackfin/cpu/cpu.c +++ b/arch/blackfin/cpu/cpu.c @@ -16,9 +16,9 @@ #include <asm/mach-common/bits/core.h> #include <asm/mach-common/bits/ebiu.h> #include <asm/mach-common/bits/trace.h> +#include <asm/serial.h>
#include "cpu.h" -#include "serial.h" #include "initcode.h"
ulong bfin_poweron_retx; diff --git a/arch/blackfin/cpu/initcode.c b/arch/blackfin/cpu/initcode.c index 8ef0b92..8147943 100644 --- a/arch/blackfin/cpu/initcode.c +++ b/arch/blackfin/cpu/initcode.c @@ -15,10 +15,9 @@ #include <asm/blackfin.h> #include <asm/mach-common/bits/bootrom.h> #include <asm/mach-common/bits/core.h> +#include <asm/serial.h>
-#define BUG() while (1) { asm volatile("emuexcpt;"); } - -#include "serial.h" +#define BUG() while (1) asm volatile("emuexcpt;");
#ifndef __ADSPBF60x__ #include <asm/mach-common/bits/ebiu.h> diff --git a/arch/blackfin/cpu/start.S b/arch/blackfin/cpu/start.S index 32b3ec7..63bffb4 100644 --- a/arch/blackfin/cpu/start.S +++ b/arch/blackfin/cpu/start.S @@ -34,8 +34,7 @@ #include <asm/blackfin.h> #include <asm/mach-common/bits/core.h> #include <asm/mach-common/bits/pll.h> - -#include "serial.h" +#include <asm/serial.h>
/* It may seem odd that we make calls to functions even though we haven't * relocated ourselves yet out of {flash,ram,wherever}. This is OK because diff --git a/arch/blackfin/cpu/serial.h b/arch/blackfin/include/asm/serial.h similarity index 100% rename from arch/blackfin/cpu/serial.h rename to arch/blackfin/include/asm/serial.h diff --git a/arch/blackfin/cpu/serial1.h b/arch/blackfin/include/asm/serial1.h similarity index 100% rename from arch/blackfin/cpu/serial1.h rename to arch/blackfin/include/asm/serial1.h diff --git a/arch/blackfin/cpu/serial4.h b/arch/blackfin/include/asm/serial4.h similarity index 100% rename from arch/blackfin/cpu/serial4.h rename to arch/blackfin/include/asm/serial4.h diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 5e8b648..f56fcd9 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -54,6 +54,7 @@ COBJS-$(CONFIG_XILINX_UARTLITE) += serial_xuartlite.o COBJS-$(CONFIG_SANDBOX_SERIAL) += sandbox.o COBJS-$(CONFIG_SCIF_CONSOLE) += serial_sh.o COBJS-$(CONFIG_ZYNQ_SERIAL) += serial_zynq.o +COBJS-$(CONFIG_BFIN_SERIAL) += serial_bfin.o
ifndef CONFIG_SPL_BUILD COBJS-$(CONFIG_USB_TTY) += usbtty.o diff --git a/arch/blackfin/cpu/serial.c b/drivers/serial/serial_bfin.c similarity index 99% rename from arch/blackfin/cpu/serial.c rename to drivers/serial/serial_bfin.c index c453a03..0443b84 100644 --- a/arch/blackfin/cpu/serial.c +++ b/drivers/serial/serial_bfin.c @@ -43,13 +43,12 @@ #include <serial.h> #include <linux/compiler.h> #include <asm/blackfin.h> +#include <asm/serial.h>
DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_UART_CONSOLE
-#include "serial.h" - #ifdef CONFIG_DEBUG_SERIAL static uart_lsr_t cached_lsr[256]; static uart_lsr_t cached_rbr[256]; diff --git a/include/configs/bfin_adi_common.h b/include/configs/bfin_adi_common.h index 0bcccf8..c751dd7 100644 --- a/include/configs/bfin_adi_common.h +++ b/include/configs/bfin_adi_common.h @@ -111,6 +111,9 @@ #ifndef CONFIG_BAUDRATE # define CONFIG_BAUDRATE 57600 #endif +#ifdef CONFIG_UART_CONSOLE +# define CONFIG_BFIN_SERIAL +#endif
/* * Debug Settings
Sonic Zhang
