[U-Boot] [PATCH] rockchip: rockchip, sdram-channel 0xff fix remaining dts
Add an extra byte so that this data is not byteswapped.
Signed-off-by: Sandy Patterson apatterson@sightlogix.com ---
arch/arm/dts/rk3288-rock2-square.dts | 2 +- arch/arm/dts/rk3288-veyron.dtsi | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/rk3288-rock2-square.dts b/arch/arm/dts/rk3288-rock2-square.dts index 34073c9..2c30355 100644 --- a/arch/arm/dts/rk3288-rock2-square.dts +++ b/arch/arm/dts/rk3288-rock2-square.dts @@ -192,7 +192,7 @@ 0x5 0x0>; rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 0xa60 0x40 0x10 0x0>; - rockchip,sdram-channel = /bits/ 8 <0x1 0xa 0x3 0x2 0x1 0x0 0xf 0xf>; + rockchip,sdram-channel = /bits/ 8 <0x1 0xa 0x3 0x2 0x1 0x0 0xf 0xf 0xff>; rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; };
diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi index 421d212..d9d5187 100644 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ b/arch/arm/dts/rk3288-veyron.dtsi @@ -253,7 +253,7 @@ 0x5 0x0>; rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 0xa60 0x40 0x10 0x0>; - rockchip,sdram-channel = /bits/ 8 <0x1 0xa 0x3 0x2 0x1 0x0 0xf 0xf>; + rockchip,sdram-channel = /bits/ 8 <0x1 0xa 0x3 0x2 0x1 0x0 0xf 0xf 0xff>; rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; };
Hi Sandy,
Do these board use OF_PLATDATA? I thought not.
-- 1.9.1
Hi Simon,
On 2016年08月01日 09:51, Simon Glass wrote:
Hi Sandy,
Yes, only firefly-rk3288 board use OF_PLATDATA. But driver get rk3288_sdram_channel via fdtdec_get_byte_array with the size which is sizeof(struct rk3288_sdram_channel). In commit 9ca7e67 rockchip: Update the sdram-channel property to support of-platdata, you add dummy element in struct rk3288_sdram_channel and size was changed to 9. Without this fix, driver get rk3288_sdram_channel failed.
Maybe add CONFIG_IS_ENABLED(OF_PLATDATA) for distinction is better, how about?
struct rk3288_sdram_channel { u8 rank; u8 col; u8 bk; u8 bw; u8 dbw; u8 row_3_4; u8 cs0_row; u8 cs1_row; #if CONFIG_IS_ENABLED(OF_PLATDATA) /* * For of-platdata, which would otherwise convert this into two * byte-swapped integers. With a size of 9 bytes, this struct will * appear in of-platdata as a byte array. */ u8 dummy; #endif };
};rockchip,sdram-channel = /bits/ 8 <0x1 0xa 0x3 0x2 0x1 0x0 0xf 0xf 0xff>; rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>;
-- 1.9.1
Regards, Simon _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Ziyuan,
On 31 July 2016 at 20:13, Ziyuan Xu xzy.xu@rock-chips.com wrote:
Hi Simon,
Hi Sandy,
Yes, but I'm happy with either solution. Your one may be a little easier to understand, but if someone switches a board over to OF_PLATDATA then it will be confusing... Please let me know which you prefer.
Hi Simon,
On 2016年08月01日 10:21, Simon Glass wrote:
Hi Ziyuan,
Hi Simon,
Hi Sandy,
OF_PLATDATA is used to reduce the size of the SPL, right? In most cases, some rk3288 boards use OF_LIBFDT. If OF_PLATDATA is really required, I think your comment is very clear. I perfer my above opinion? :-)
Hi Ziyuan,
On 31 July 2016 at 20:36, Ziyuan Xu xzy.xu@rock-chips.com wrote:
Hi Simon,
Hi Ziyuan,
Hi Simon,
Hi Sandy,
I'm going to apply this patch, but please feel free to send a patch to change this over if you wish.
Applied to u-boot-rockchip, thanks!
Sandy Patterson
Ziyuan Xu
