[RESEND PATCH] net: dwc_eth_qos: update the compatible supported for STM32
Update the compatible associated with the STM32 MPU glue in the DWC ethernet driver.
The supported compatible is the specific "st,stm32mp1-dwmac" as indicated in Linux binding Documentation/devicetree/bindings/net/stm32-dwmac.txt and not the "snps,dwmac-4.20a" only used to the select IP version.
This glue is implemented in Linux kernel in: drivers/net/ethernet/stmicro/stmmac/dwmac-stm32.c
For information in stm32mp151.dtsi, the 2 compatibles are supported:
ethernet0: ethernet@5800a000 { compatible = "st,stm32mp1-dwmac", "snps,dwmac-4.20a"; ... };
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com --- RESEND with fix patman on Series-cc
drivers/net/dwc_eth_qos.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index f67c5f4570..5e7ad6c658 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -2166,7 +2166,7 @@ static const struct udevice_id eqos_ids[] = { .data = (ulong)&eqos_tegra186_config }, { - .compatible = "snps,dwmac-4.20a", + .compatible = "st,stm32mp1-dwmac", .data = (ulong)&eqos_stm32_config }, {
Hi Patrick
.data = (ulong)&eqos_stm32_config }, {.compatible = "st,stm32mp1-dwmac",
Reviewed-by: Patrice Chotard patrice.chotard@st.com
Patrice
Patrice CHOTARD
Patrick Delaunay
